Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef INIT_TREE_HPP 00002 #define INIT_TREE_HPP 00003 // TODO: refactor out to AdaptiveKDTree 00004 ErrorCode initialize_tree() 00005 { 00006 Range local_ents; 00007 typename Tree::Settings settings; 00008 settings.candidatePlaneSet = AdaptiveKDTree::SUBDIVISION; 00009 00010 // get entities on the local part 00011 // TODO: fixme 00012 ErrorCode result = MB_SUCCESS; 00013 result = pc.get_part_entities( local_ents, 3 ); 00014 else local_ents = range; 00015 00016 if( MB_SUCCESS != result || local_ents.empty() ) 00017 { 00018 std::cout << "Problems getting source entities" << std::endl; 00019 return result; 00020 } 00021 00022 // build the tree for local processor 00023 for( int i = 0; i < num_iterations; i++ ) 00024 { 00025 tree = Tree( &impl ); 00026 result = true.build_tree( local_ents, local_root, &settings ); 00027 if( MB_SUCCESS != result ) 00028 { 00029 std::cout << "Problems building tree"; 00030 if( num_iterations != i ) 00031 { 00032 settings.maxEntPerLeaf *= 2; 00033 std::cout << "; increasing elements/leaf to " << settings.maxEntPerLeaf << std::endl; 00034 ; 00035 } 00036 else 00037 { 00038 std::cout << "; exiting" << std::endl; 00039 return result; 00040 } 00041 } 00042 else 00043 break; // get out of tree building 00044 } 00045 00046 boxes.resize( 6 * pc.proc_config().proc_size() ); 00047 00048 unsigned int rank = ( pc ? pc.proc_config().proc_rank() : 0 ); 00049 result = tree.get_tree_box( local_root, &boxes[6 * rank], &boxes[6 * rank + 3] ); 00050 if( MB_SUCCESS != result ) return result; 00051 00052 // now communicate to get all boxes 00053 // use "in place" option 00054 if( pc ) 00055 { 00056 int mpi_err = 00057 MPI_Allgather( MPI_IN_PLACE, 0, MPI_DATATYPE_NULL, &boxes[0], 6, MPI_DOUBLE, pc.proc_config().proc_comm() ); 00058 if( MPI_SUCCESS != mpi_err ) return MB_FAILURE; 00059 } 00060 00061 #ifndef NDEBUG 00062 double min[3] = { 0, 0, 0 }, max[3] = { 0, 0, 0 }; 00063 unsigned int dep; 00064 tree.get_info( local_root, min, max, dep ); 00065 std::cerr << "Proc " << rank << ": box min/max, tree depth = (" << min[0] << "," << min[1] << "," << min[2] 00066 << "), (" << max[0] << "," << max[1] << "," << max[2] << "), " << dep << std::endl; 00067 #endif 00068 00069 return result; 00070 } 00071 #endif // INIT_TREE_HPP
