MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "AssocPair.hpp" 00002 00003 #include <cstdlib> 00004 00005 #include "Lasso.hpp" 00006 00007 #ifdef ENABLE_IGEOM 00008 #include "GeomAssocPairSide.hpp" 00009 #endif 00010 #ifdef ENABLE_FBIGEOM 00011 #include "FBGeomAssocPairSide.hpp" 00012 #endif 00013 #ifdef ENABLE_IMESH 00014 #include "MeshAssocPairSide.hpp" 00015 #endif 00016 00017 int AssocPair::currId = 0; 00018 00019 AssocPair::AssocPair( iRel_Instance p_instance, 00020 iBase_Instance iface0, 00021 iRel_RelationType ent_or_set0, 00022 iRel_IfaceType type0, 00023 iRel_RelationStatus p_status0, 00024 iBase_Instance iface1, 00025 iRel_RelationType ent_or_set1, 00026 iRel_IfaceType type1, 00027 iRel_RelationStatus p_status1 ) 00028 : instance( p_instance ) 00029 { 00030 pairId = currId++; 00031 00032 iBase_Instance ifaces[] = { iface0, iface1 }; 00033 iRel_IfaceType types[] = { type0, type1 }; 00034 for( int i = 0; i < 2; i++ ) 00035 { 00036 switch( types[i] ) 00037 { 00038 #ifdef ENABLE_IGEOM 00039 case iRel_IGEOM_IFACE: 00040 relSides[i] = new GeomAssocPairSide( instance, ifaces[i], pairId ); 00041 break; 00042 #endif 00043 #ifdef ENABLE_FBIGEOM 00044 case iRel_FBIGEOM_IFACE: 00045 relSides[i] = new FBGeomAssocPairSide( instance, ifaces[i], pairId ); 00046 break; 00047 #endif 00048 #ifdef ENABLE_IMESH 00049 case iRel_IMESH_IFACE: 00050 relSides[i] = new MeshAssocPairSide( instance, ifaces[i], pairId ); 00051 break; 00052 #endif 00053 default: 00054 relSides[i] = NULL; 00055 } 00056 } 00057 00058 entOrSet[0] = ent_or_set0; 00059 entOrSet[1] = ent_or_set1; 00060 relStatus[0] = p_status0; 00061 relStatus[1] = p_status1; 00062 } 00063 00064 AssocPair::~AssocPair() 00065 { 00066 for( int i = 0; i < 2; i++ ) 00067 delete relSides[i]; 00068 } 00069 00070 int AssocPair::get_all_entities( int iface_no, 00071 int dimension, 00072 iBase_EntityHandle** entities, 00073 int* entities_alloc, 00074 int* entities_size ) 00075 { 00076 return relSides[iface_no]->get_all_entities( dimension, entities, entities_alloc, entities_size ); 00077 } 00078 00079 int AssocPair::get_all_sets( int iface_no, iBase_EntitySetHandle** sets, int* sets_alloc, int* sets_size ) 00080 { 00081 return relSides[iface_no]->get_all_sets( sets, sets_alloc, sets_size ); 00082 } 00083 00084 int AssocPair::get_entities( int iface_no, 00085 int dimension, 00086 iBase_EntitySetHandle set_handle, 00087 iBase_EntityHandle** entities, 00088 int* entities_alloc, 00089 int* entities_size ) 00090 { 00091 return relSides[iface_no]->get_entities( dimension, set_handle, entities, entities_alloc, entities_size ); 00092 } 00093 00094 int AssocPair::get_ents_dims( int iface_no, 00095 iBase_EntityHandle* entities, 00096 int entities_size, 00097 int** ent_types, 00098 int* ent_types_alloc, 00099 int* ent_types_size ) 00100 { 00101 return relSides[iface_no]->get_ents_dims( entities, entities_size, ent_types, ent_types_alloc, ent_types_size ); 00102 } 00103 00104 int AssocPair::set_relation( iBase_EntityHandle ent1, iBase_EntityHandle ent2 ) 00105 { 00106 if( entOrSet[0] == iRel_SET || entOrSet[1] == iRel_SET ) ERRORR( iBase_FAILURE, "Invalid relation type" ); 00107 00108 // check that if we're passing in an ent for a 'both'-type 00109 // assoc, there's already a set associated to the other ent 00110 iBase_EntityHandle tmp_ent; 00111 if( entOrSet[0] == iRel_BOTH && relSides[1]->get_relation_side( &ent2, 1, &tmp_ent ) != iBase_SUCCESS ) 00112 ERRORR( iBase_FAILURE, "Couldn't find associated set on left side" ); 00113 if( entOrSet[1] == iRel_BOTH && relSides[0]->get_relation_side( &ent1, 1, &tmp_ent ) != iBase_SUCCESS ) 00114 ERRORR( iBase_FAILURE, "Couldn't find associated set on right side" ); 00115 00116 // set ent1 => ent2 00117 if( relStatus[0] == iRel_ACTIVE ) CHK_ERRORR( relSides[0]->set_relation_side( &ent1, 1, &ent2 ) ); 00118 00119 // set ent1 <= ent2 00120 if( relStatus[1] == iRel_ACTIVE ) CHK_ERRORR( relSides[1]->set_relation_side( &ent2, 1, &ent1 ) ); 00121 00122 RETURNR( iBase_SUCCESS ); 00123 } 00124 00125 int AssocPair::set_relation( iBase_EntityHandle ent1, iBase_EntitySetHandle set2 ) 00126 { 00127 if( entOrSet[0] == iRel_SET || entOrSet[1] == iRel_ENTITY ) ERRORR( iBase_FAILURE, "Invalid relation type" ); 00128 00129 // check that if we're passing in an ent for a 'both'-type 00130 // assoc, there's already a set associated to the other ent 00131 iBase_EntityHandle tmp_ent; 00132 if( entOrSet[0] == iRel_BOTH && relSides[1]->get_relation_side( &set2, 1, &tmp_ent ) != iBase_SUCCESS ) 00133 ERRORR( iBase_FAILURE, "Couldn't find associated set on left side" ); 00134 00135 // set ent1 => set2 00136 if( relStatus[0] == iRel_ACTIVE ) CHK_ERRORR( relSides[0]->set_relation_side( &ent1, 1, &set2 ) ); 00137 00138 // set ent1 <= set2 00139 if( relStatus[1] == iRel_ACTIVE ) CHK_ERRORR( relSides[1]->set_relation_side( &set2, 1, &ent1 ) ); 00140 00141 // if the right side is a 'both'-type association, set the contents of set2 00142 // to point to ent1 as well 00143 if( entOrSet[1] == iRel_BOTH ) CHK_ERRORR( populate_recursive( 1, set2, ent1 ) ); 00144 00145 RETURNR( iBase_SUCCESS ); 00146 } 00147 00148 int AssocPair::set_relation( iBase_EntitySetHandle set1, iBase_EntityHandle ent2 ) 00149 { 00150 if( entOrSet[0] == iRel_ENTITY || entOrSet[1] == iRel_SET ) ERRORR( iBase_FAILURE, "Invalid relation type" ); 00151 00152 // check that if we're passing in an ent for a 'both'-type 00153 // assoc, there's already a set associated to the other ent 00154 iBase_EntityHandle tmp_ent; 00155 if( entOrSet[1] == iRel_BOTH && relSides[0]->get_relation_side( &set1, 1, &tmp_ent ) != iBase_SUCCESS ) 00156 ERRORR( iBase_FAILURE, "Couldn't find associated set on right side" ); 00157 00158 // set set1 => ent2 00159 if( relStatus[0] == iRel_ACTIVE ) CHK_ERRORR( relSides[0]->set_relation_side( &set1, 1, &ent2 ) ); 00160 00161 // set ent1 <= set2 00162 if( relStatus[1] == iRel_ACTIVE ) CHK_ERRORR( relSides[1]->set_relation_side( &ent2, 1, &set1 ) ); 00163 00164 // if the left side is a 'both'-type association, set the contents of set1 00165 // to point to ent2 as well 00166 if( entOrSet[0] == iRel_BOTH ) CHK_ERRORR( populate_recursive( 0, set1, ent2 ) ); 00167 00168 RETURNR( iBase_SUCCESS ); 00169 } 00170 00171 int AssocPair::set_relation( iBase_EntitySetHandle set1, iBase_EntitySetHandle set2 ) 00172 { 00173 if( entOrSet[0] == iRel_ENTITY || entOrSet[1] == iRel_ENTITY ) ERRORR( iBase_FAILURE, "Invalid relation type" ); 00174 00175 // set set1 => set2 00176 if( relStatus[0] == iRel_ACTIVE ) CHK_ERRORR( relSides[0]->set_relation_side( &set1, 1, &set2 ) ); 00177 00178 // set set1 <= set2 00179 if( relStatus[1] == iRel_ACTIVE ) CHK_ERRORR( relSides[1]->set_relation_side( &set2, 1, &set1 ) ); 00180 00181 // if either side is a 'both'-type association, set the contents of set1 00182 // to point to set2 as well (and/or vice-versa) 00183 if( entOrSet[0] == iRel_BOTH ) CHK_ERRORR( populate_recursive( 0, set1, set2 ) ); 00184 if( entOrSet[1] == iRel_BOTH ) CHK_ERRORR( populate_recursive( 1, set2, set1 ) ); 00185 00186 RETURNR( iBase_SUCCESS ); 00187 } 00188 00189 int AssocPair::get_relation( int iface_no, 00190 iBase_EntityHandle* entities, 00191 int num_entities, 00192 iBase_EntityHandle* tag_values ) 00193 { 00194 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00195 if( entOrSet[!iface_no] != iRel_ENTITY ) // other iface is sets 00196 ERRORR( iBase_INVALID_ENTITY_HANDLE, "Expected EntitySet, got Entity" ); 00197 00198 return relSides[iface_no]->get_relation_side( entities, num_entities, tag_values ); 00199 } 00200 00201 int AssocPair::get_relation( int iface_no, iBase_EntitySetHandle* sets, int num_sets, iBase_EntityHandle* tag_values ) 00202 { 00203 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00204 if( entOrSet[!iface_no] != iRel_ENTITY ) // other iface is sets 00205 ERRORR( iBase_INVALID_ENTITY_HANDLE, "Expected EntitySet, got Entity" ); 00206 00207 return relSides[iface_no]->get_relation_side( sets, num_sets, tag_values ); 00208 } 00209 00210 int AssocPair::get_relation( int iface_no, 00211 iBase_EntityHandle* entities, 00212 int num_entities, 00213 iBase_EntitySetHandle* tag_values ) 00214 { 00215 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00216 if( entOrSet[!iface_no] == iRel_ENTITY ) // other iface is not sets 00217 ERRORR( iBase_INVALID_ENTITY_HANDLE, "Expected Entity, got EntitySet" ); 00218 00219 return relSides[iface_no]->get_relation_side( entities, num_entities, tag_values ); 00220 } 00221 00222 int AssocPair::get_relation( int iface_no, 00223 iBase_EntitySetHandle* sets, 00224 int num_sets, 00225 iBase_EntitySetHandle* tag_values ) 00226 { 00227 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00228 if( entOrSet[!iface_no] == iRel_ENTITY ) // other iface is not sets 00229 ERRORR( iBase_INVALID_ENTITY_HANDLE, "Expected Entity, got EntitySet" ); 00230 00231 return relSides[iface_no]->get_relation_side( sets, num_sets, tag_values ); 00232 } 00233 00234 int AssocPair::get_relation( int iface_no, 00235 iBase_EntityHandle* entities, 00236 int num_entities, 00237 iBase_EntityIterator* tag_values ) 00238 { 00239 std::vector< iBase_EntitySetHandle > sets( num_entities );CHK_ERRORR( get_relation( iface_no, entities, num_entities, &sets[0] ) ); 00240 00241 for( int i = 0; i < num_entities; i++ ) 00242 CHK_ERRORR( relSides[i]->get_iterator( sets[i], &tag_values[i] ) ); 00243 00244 RETURNR( iBase_SUCCESS ); 00245 } 00246 00247 int AssocPair::get_relation( int iface_no, iBase_EntitySetHandle* sets, int num_sets, iBase_EntityIterator* tag_values ) 00248 { 00249 std::vector< iBase_EntitySetHandle > sets2( num_sets );CHK_ERRORR( get_relation( iface_no, sets, num_sets, &sets2[0] ) ); 00250 00251 for( int i = 0; i < num_sets; i++ ) 00252 CHK_ERRORR( relSides[iface_no]->get_iterator( sets2[i], &tag_values[i] ) ); 00253 00254 RETURNR( iBase_SUCCESS ); 00255 } 00256 00257 int AssocPair::rmv_relation( int iface_no, iBase_EntityHandle* entities, int num_entities ) 00258 { 00259 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00260 00261 // TODO: handle "both" case 00262 00263 // Remove the opposite side first 00264 if( relStatus[!iface_no] == iRel_ACTIVE ) 00265 { 00266 if( entOrSet[!iface_no] == iRel_ENTITY ) 00267 { 00268 std::vector< iBase_EntityHandle > other_entities( num_entities );CHK_ERRORR( get_relation( iface_no, entities, num_entities, &other_entities[0] ) );CHK_ERRORR( relSides[!iface_no]->rmv_relation_side( &other_entities[0], num_entities ) ); 00269 } 00270 else 00271 { 00272 std::vector< iBase_EntitySetHandle > other_sets( num_entities );CHK_ERRORR( get_relation( iface_no, entities, num_entities, &other_sets[0] ) );CHK_ERRORR( relSides[!iface_no]->rmv_relation_side( &other_sets[0], num_entities ) ); 00273 } 00274 } 00275 00276 return relSides[iface_no]->rmv_relation_side( entities, num_entities ); 00277 } 00278 00279 int AssocPair::rmv_relation( int iface_no, iBase_EntitySetHandle* sets, int num_sets ) 00280 { 00281 if( relStatus[iface_no] == iRel_NOTEXIST ) ERRORR( iBase_FAILURE, "Relation does not exist on this side" ); 00282 00283 // TODO: handle "both" case 00284 00285 // Remove the opposite side first 00286 if( relStatus[!iface_no] == iRel_ACTIVE ) 00287 { 00288 if( entOrSet[!iface_no] == iRel_ENTITY ) 00289 { 00290 std::vector< iBase_EntityHandle > other_entities( num_sets );CHK_ERRORR( get_relation( iface_no, sets, num_sets, &other_entities[0] ) );CHK_ERRORR( relSides[!iface_no]->rmv_relation_side( &other_entities[0], num_sets ) ); 00291 } 00292 else 00293 { 00294 std::vector< iBase_EntitySetHandle > other_sets( num_sets );CHK_ERRORR( get_relation( iface_no, sets, num_sets, &other_sets[0] ) );CHK_ERRORR( relSides[!iface_no]->rmv_relation_side( &other_sets[0], num_sets ) ); 00295 } 00296 } 00297 00298 return relSides[iface_no]->rmv_relation_side( sets, num_sets ); 00299 } 00300 00301 int AssocPair::get_gids( int iface_no, iBase_EntityHandle* entities, int num_entities, int* tag_values ) 00302 { 00303 return relSides[iface_no]->get_gids( entities, num_entities, tag_values ); 00304 } 00305 00306 int AssocPair::get_gids( int iface_no, iBase_EntitySetHandle* sets, int num_sets, int* tag_values ) 00307 { 00308 return relSides[iface_no]->get_gids( sets, num_sets, tag_values ); 00309 } 00310 00311 int AssocPair::get_dims( int iface_no, iBase_EntityHandle* entities, int num_entities, int* tag_values ) 00312 { 00313 return relSides[iface_no]->get_dims( entities, num_entities, tag_values ); 00314 } 00315 00316 int AssocPair::get_dims( int iface_no, iBase_EntitySetHandle* sets, int num_sets, int* tag_values ) 00317 { 00318 return relSides[iface_no]->get_dims( sets, num_sets, tag_values ); 00319 } 00320 00321 int AssocPair::change_type( int iface_no, iRel_RelationType type ) 00322 { 00323 if( entOrSet[iface_no] == type ) RETURNR( iBase_SUCCESS ); 00324 if( entOrSet[iface_no] == iRel_ENTITY || type == iRel_ENTITY ) 00325 ERRORR( iBase_FAILURE, "Can only change type from \"set\" to \"both\", or " 00326 "vice-versa" ); 00327 00328 entOrSet[iface_no] = type; 00329 if( relStatus[iface_no] != iRel_ACTIVE ) RETURNR( iBase_SUCCESS ); 00330 00331 iBase_EntitySetHandle* sets = NULL; 00332 int set_alloc = 0, set_size;CHK_ERRORR( relSides[iface_no]->get_related_sets( &sets, &set_alloc, &set_size ) ); 00333 if( type == iRel_BOTH ) 00334 { 00335 if( entOrSet[!iface_no] == iRel_ENTITY ) 00336 { 00337 std::vector< iBase_EntityHandle > related_ents( set_size );CHK_ERRORR( relSides[iface_no]->get_relation_side( sets, set_size, &related_ents[0] ) ); 00338 00339 for( int i = 0; i < set_size; i++ ) 00340 CHK_ERRORR( populate_recursive( iface_no, sets[i], related_ents[i] ) ); 00341 } 00342 else 00343 { 00344 std::vector< iBase_EntitySetHandle > related_sets( set_size );CHK_ERRORR( relSides[iface_no]->get_relation_side( sets, set_size, &related_sets[0] ) ); 00345 00346 for( int i = 0; i < set_size; i++ ) 00347 CHK_ERRORR( populate_recursive( iface_no, sets[i], related_sets[i] ) ); 00348 } 00349 } 00350 else if( type == iRel_SET ) 00351 { 00352 for( int i = 0; i < set_size; i++ ) 00353 CHK_ERRORR( unpopulate_recursive( iface_no, sets[i] ) ); 00354 } 00355 00356 free( sets ); 00357 RETURNR( iBase_SUCCESS ); 00358 } 00359 00360 int AssocPair::change_status( int iface_no, iRel_RelationStatus status ) 00361 { 00362 if( relStatus[iface_no] == status ) RETURNR( iBase_SUCCESS ); 00363 00364 relStatus[iface_no] = status; 00365 00366 if( status == iRel_NOTEXIST ) 00367 { 00368 // Destroy the assoc tag 00369 CHK_ERRORR( relSides[iface_no]->destroy_relation_side() ); 00370 } 00371 else if( status == iRel_INACTIVE ) 00372 { 00373 // Create the assoc tag 00374 CHK_ERRORR( relSides[iface_no]->create_relation_side() ); 00375 } 00376 // Update the assoc tag 00377 else if( status == iRel_ACTIVE ) 00378 { 00379 CHK_ERRORR( relSides[iface_no]->destroy_relation_side() );CHK_ERRORR( relSides[iface_no]->create_relation_side() ); 00380 00381 if( entOrSet[!iface_no] == iRel_ENTITY ) 00382 { 00383 iBase_EntityHandle* entities = NULL; 00384 int ent_alloc = 0, ent_size; 00385 00386 CHK_ERRORR( relSides[!iface_no]->get_related_ents( &entities, &ent_alloc, &ent_size ) ); 00387 if( entOrSet[iface_no] == iRel_ENTITY ) 00388 { 00389 std::vector< iBase_EntityHandle > related_ents( ent_size ); 00390 int result = relSides[!iface_no]->get_relation_side( entities, ent_size, &related_ents[0] ); 00391 00392 if( result == iBase_SUCCESS ) 00393 { 00394 if( iface_no == 0 ) 00395 for( int i = 0; i < ent_size; i++ ) 00396 CHK_ERRORR( set_relation( related_ents[i], entities[i] ) ); 00397 else 00398 for( int i = 0; i < ent_size; i++ ) 00399 CHK_ERRORR( set_relation( entities[i], related_ents[i] ) ); 00400 } 00401 } 00402 else 00403 { 00404 std::vector< iBase_EntitySetHandle > related_sets( ent_size ); 00405 int result = relSides[!iface_no]->get_relation_side( entities, ent_size, &related_sets[0] ); 00406 00407 if( result == iBase_SUCCESS ) 00408 { 00409 if( iface_no == 0 ) 00410 for( int i = 0; i < ent_size; i++ ) 00411 CHK_ERRORR( set_relation( related_sets[i], entities[i] ) ); 00412 else 00413 for( int i = 0; i < ent_size; i++ ) 00414 CHK_ERRORR( set_relation( entities[i], related_sets[i] ) ); 00415 } 00416 } 00417 00418 free( entities ); 00419 } 00420 else 00421 { 00422 iBase_EntitySetHandle* sets = NULL; 00423 int set_alloc = 0, set_size; 00424 00425 CHK_ERRORR( relSides[!iface_no]->get_related_sets( &sets, &set_alloc, &set_size ) ); 00426 if( entOrSet[iface_no] == iRel_ENTITY ) 00427 { 00428 std::vector< iBase_EntityHandle > related_ents( set_size ); 00429 int result = relSides[!iface_no]->get_relation_side( sets, set_size, &related_ents[0] ); 00430 00431 if( result == iBase_SUCCESS ) 00432 { 00433 if( iface_no == 0 ) 00434 for( int i = 0; i < set_size; i++ ) 00435 CHK_ERRORR( set_relation( related_ents[i], sets[i] ) ); 00436 else 00437 for( int i = 0; i < set_size; i++ ) 00438 CHK_ERRORR( set_relation( sets[i], related_ents[i] ) ); 00439 } 00440 } 00441 else 00442 { 00443 std::vector< iBase_EntitySetHandle > related_sets( set_size ); 00444 int result = relSides[!iface_no]->get_relation_side( sets, set_size, &related_sets[0] ); 00445 00446 if( result == iBase_SUCCESS ) 00447 { 00448 if( iface_no == 0 ) 00449 for( int i = 0; i < set_size; i++ ) 00450 CHK_ERRORR( set_relation( related_sets[i], sets[i] ) ); 00451 else 00452 for( int i = 0; i < set_size; i++ ) 00453 CHK_ERRORR( set_relation( sets[i], related_sets[i] ) ); 00454 } 00455 } 00456 00457 free( sets ); 00458 } 00459 } 00460 else 00461 { 00462 ERRORR( iBase_INVALID_ARGUMENT, "Invalid argument for relation status" ); 00463 } 00464 00465 RETURNR( iBase_SUCCESS ); 00466 } 00467 00468 bool AssocPair::equivalent( iBase_Instance iface0, iBase_Instance iface1, bool* order_switched ) 00469 { 00470 if( iface0 == relSides[0]->instance() && iface1 == relSides[1]->instance() ) 00471 { 00472 if( order_switched ) *order_switched = false; 00473 return true; 00474 } 00475 else if( iface0 == relSides[1]->instance() && iface1 == relSides[0]->instance() ) 00476 { 00477 if( order_switched ) *order_switched = true; 00478 return true; 00479 } 00480 else 00481 return false; 00482 } 00483 00484 bool AssocPair::equivalent( iRel_IfaceType type0, iRel_IfaceType type1, bool* order_switched ) 00485 { 00486 if( type0 == relSides[0]->type() && type1 == relSides[1]->type() ) 00487 { 00488 if( order_switched ) *order_switched = false; 00489 return true; 00490 } 00491 else if( type0 == relSides[1]->type() && type1 == relSides[0]->type() ) 00492 { 00493 if( order_switched ) *order_switched = true; 00494 return true; 00495 } 00496 else 00497 return false; 00498 } 00499 00500 bool AssocPair::contains( iBase_Instance iface ) 00501 { 00502 return ( iface == relSides[0]->instance() || iface == relSides[1]->instance() ); 00503 } 00504 00505 int AssocPair::populate_recursive( int iface_no, iBase_EntitySetHandle set, iBase_EntityHandle related_ent ) 00506 { 00507 iBase_EntityHandle* entities = NULL; 00508 int entities_alloc = 0, entities_size; 00509 00510 CHK_ERRORR( relSides[iface_no]->get_entities( -1, set, &entities, &entities_alloc, &entities_size ) ); 00511 00512 for( int i = 0; i < entities_size; i++ ) 00513 CHK_ERRORR( relSides[iface_no]->set_relation_side( entities + i, 1, &related_ent ) ); 00514 00515 free( entities ); 00516 RETURNR( iBase_SUCCESS ); 00517 } 00518 00519 int AssocPair::populate_recursive( int iface_no, iBase_EntitySetHandle set, iBase_EntitySetHandle related_set ) 00520 { 00521 iBase_EntityHandle* entities = NULL; 00522 int entities_alloc, entities_size; 00523 00524 CHK_ERRORR( relSides[iface_no]->get_entities( -1, set, &entities, &entities_alloc, &entities_size ) ); 00525 00526 for( int i = 0; i < entities_size; i++ ) 00527 CHK_ERRORR( relSides[iface_no]->set_relation_side( entities + i, 1, &related_set ) ); 00528 00529 free( entities ); 00530 RETURNR( iBase_SUCCESS ); 00531 } 00532 00533 int AssocPair::unpopulate_recursive( int iface_no, iBase_EntitySetHandle set ) 00534 { 00535 iBase_EntityHandle* entities = NULL; 00536 int entities_alloc = 0, entities_size; 00537 00538 CHK_ERRORR( relSides[iface_no]->get_entities( -1, set, &entities, &entities_alloc, &entities_size ) );CHK_ERRORR( relSides[iface_no]->rmv_relation_side( entities, entities_size ) ); 00539 00540 free( entities ); 00541 RETURNR( iBase_SUCCESS ); 00542 }
