GeomAssocPairSide Class Reference
#include <GeomAssocPairSide.hpp>
+ Inheritance diagram for GeomAssocPairSide:
+ Collaboration diagram for GeomAssocPairSide:
Public Member Functions
 GeomAssocPairSide (iRel_Instance relation, iBase_Instance instance, int id)
virtual ~GeomAssocPairSide ()
virtual iBase_Instance instance () const
virtual iRel_IfaceType type () const
virtual int create_relation_side ()
virtual int destroy_relation_side ()
virtual int get_all_entities (int dimension, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_all_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_entities (int dimension, iBase_EntitySetHandle set_handle, iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_ents_dims (iBase_EntityHandle *entities, int entities_size, int **ent_types, int *ent_types_alloc, int *ent_types_size)
virtual int get_related_ents (iBase_EntityHandle **entities, int *entities_alloc, int *entities_size)
virtual int get_related_sets (iBase_EntitySetHandle **sets, int *sets_alloc, int *sets_size)
virtual int get_relation_side (iBase_EntityHandle *entities, int num_entities, void *values)
virtual int get_relation_side (iBase_EntitySetHandle *sets, int num_sets, void *values)
virtual int set_relation_side (iBase_EntityHandle *entities, int num_entities, const void *values)
virtual int set_relation_side (iBase_EntitySetHandle *sets, int num_sets, const void *values)
virtual int rmv_relation_side (iBase_EntityHandle *entities, int num_entities)
virtual int rmv_relation_side (iBase_EntitySetHandle *sets, int num_sets)
virtual int get_iterator (iBase_EntitySetHandle set, iBase_EntityIterator *iter)
virtual int get_gids (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_gids (iBase_EntitySetHandle *sets, int num_sets, int *values)
virtual int get_dims (iBase_EntityHandle *entities, int num_entities, int *values)
virtual int get_dims (iBase_EntitySetHandle *sets, int num_sets, int *values)
Private Attributes
iGeom_Instance instance_
int id
iBase_TagHandle relation_tag
iBase_TagHandle gid_tag
Detailed Description
Definition at line 7 of file GeomAssocPairSide.hpp.
GeomAssocPairSide::GeomAssocPairSide ( iRel_Instance  relation,
int  id
Definition at line 28 of file GeomAssocPairSide.cpp.
References create_relation_side(), gid_tag, GLOBAL_ID_TAG_NAME, iBase_INTEGER, iBase_TAG_NOT_FOUND, and instance_.
    : relation( p_relation ), instance_( reinterpret_cast< iGeom_Instance >( p_instance ) ), id( p_id )
    int result;
    create_relation_side();
    iGeom_getTagHandle( instance_, GLOBAL_ID_TAG_NAME, &gid_tag, &result, strlen( GLOBAL_ID_TAG_NAME ) );
    if( result == iBase_TAG_NOT_FOUND )
        iGeom_createTag( instance_, GLOBAL_ID_TAG_NAME, 1, iBase_INTEGER, &gid_tag, &result,
Member Function Documentation
Implements AssocPairSide.
Definition at line 58 of file GeomAssocPairSide.cpp.
References iBase_ENTITY_HANDLE, iBase_SUCCESS, iBase_TAG_NOT_FOUND, id, instance_, PROCESS_ERROR, relation_tag, RELATION_TAG_NAME, and RETURNR.
Referenced by GeomAssocPairSide().
    int result;
    std::stringstream ss;
    ss << RELATION_TAG_NAME << id;
    std::string rel_tag_name( ss.str() );
    iGeom_getTagHandle( instance_, rel_tag_name.c_str(), &relation_tag, &result, rel_tag_name.size() );
        iGeom_createTag( instance_, rel_tag_name.c_str(), 1, iBase_ENTITY_HANDLE, &relation_tag, &result,
    PROCESS_ERROR;
    RETURNR( iBase_SUCCESS );
Definition at line 76 of file GeomAssocPairSide.cpp.
References iBase_SUCCESS, instance_, PROCESS_ERROR, relation_tag, and RETURNR.
Referenced by ~GeomAssocPairSide().
    if( relation_tag )
        int result;
        iGeom_destroyTag( instance_, relation_tag, true, &result );
        relation_tag = NULL;
        PROCESS_ERROR;
int GeomAssocPairSide::get_all_entities ( int  dimension,
iBase_EntityHandle **  entities,
int *  entities_alloc,
int *  entities_size
) [virtual]
Definition at line 90 of file GeomAssocPairSide.cpp.
References iBase_ALL_TYPES, iBase_SUCCESS, instance_, PROCESS_ERROR, and RETURNR.
    int this_type = ( dimension == -1 ? iBase_ALL_TYPES : dimension );
    int result;
    iGeom_getEntities( instance_, 0, this_type, entities, entities_alloc, entities_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_all_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 103 of file GeomAssocPairSide.cpp.
References iBase_SUCCESS, instance_, PROCESS_ERROR, and RETURNR.
    int result;
    iGeom_getEntSets( instance_, 0, 0, sets, sets_alloc, sets_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_dims ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 262 of file GeomAssocPairSide.cpp.
References iBase_FAILURE, and RETURNR.
int GeomAssocPairSide::get_dims ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 267 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_entities ( int  dimension,
int *  entities_size
) [virtual]
Definition at line 112 of file GeomAssocPairSide.cpp.
    int result;
    iGeom_getEntities( instance_, set_handle, this_type, entities, entities_alloc, entities_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_ents_dims ( iBase_EntityHandle *  entities,
int  entities_size,
int **  ent_types,
int *  ent_types_alloc,
int *  ent_types_size
) [virtual]
Definition at line 126 of file GeomAssocPairSide.cpp.
    int result;
    iGeom_getArrType( instance_, entities, entities_size, ent_types, ent_types_alloc, ent_types_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_gids ( iBase_EntityHandle *  entities,
int  num_entities,
int *  values
) [virtual]
Definition at line 233 of file GeomAssocPairSide.cpp.
References gid_tag, iBase_SUCCESS, instance_, PROCESS_ERROR, and RETURNR.
    int values_alloc = num_entities * sizeof( int );
    int values_size;
    int result;
    iGeom_getArrData( instance_, entities, num_entities, gid_tag, reinterpret_cast< void** >( &values ), &values_alloc,
                      &values_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_gids ( iBase_EntitySetHandle *  sets,
int  num_sets,
int *  values
) [virtual]
Definition at line 245 of file GeomAssocPairSide.cpp.
    char* data       = reinterpret_cast< char* >( values );
    int values_alloc = sizeof( int );
    int values_size;
    int result;
    for( int i = 0; i < num_sets; i++ )
        iGeom_getEntSetData( instance_, sets[i], gid_tag, reinterpret_cast< void** >( &data ), &values_alloc,
        data += values_size;
        PROCESS_ERROR;
Definition at line 226 of file GeomAssocPairSide.cpp.
References iBase_ALL_TYPES, iBase_SUCCESS, instance_, and RETURNR.
    int result;
    iGeom_initEntIter( instance_, set, iBase_ALL_TYPES, iter, &result );
int GeomAssocPairSide::get_related_ents ( iBase_EntityHandle **  entities,
int *  entities_size
) [virtual]
Definition at line 139 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_related_sets ( iBase_EntitySetHandle **  sets,
int *  sets_alloc,
int *  sets_size
) [virtual]
Definition at line 146 of file GeomAssocPairSide.cpp.
int GeomAssocPairSide::get_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
void *  values
) [virtual]
Definition at line 151 of file GeomAssocPairSide.cpp.
    int values_alloc = num_entities * sizeof( iBase_EntityHandle );
    int values_size;
    int result;
    iGeom_getArrData( instance_, entities, num_entities, relation_tag, &values, &values_alloc, &values_size, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::get_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
void *  values
) [virtual]
Definition at line 162 of file GeomAssocPairSide.cpp.
    char* data       = static_cast< char* >( values );
    int values_alloc = sizeof( iBase_EntityHandle );
    int values_size;
    int result;
        iGeom_getEntSetData( instance_, sets[i], relation_tag, reinterpret_cast< void** >( &data ), &values_alloc,
        PROCESS_ERROR;
Definition at line 48 of file GeomAssocPairSide.cpp.
References instance_.
    return instance_;
int GeomAssocPairSide::rmv_relation_side ( iBase_EntityHandle *  entities,
int  num_entities
) [virtual]
Definition at line 204 of file GeomAssocPairSide.cpp.
    int result;
    iGeom_rmvArrTag( instance_, entities, num_entities, relation_tag, &result );
    PROCESS_ERROR;
int GeomAssocPairSide::rmv_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets
) [virtual]
Definition at line 213 of file GeomAssocPairSide.cpp.
    int result;
        iGeom_rmvEntSetTag( instance_, sets[i], relation_tag, &result );
        PROCESS_ERROR;
int GeomAssocPairSide::set_relation_side ( iBase_EntityHandle *  entities,
int  num_entities,
const void *  values
) [virtual]
Definition at line 179 of file GeomAssocPairSide.cpp.
    int result;
    iGeom_setArrData( instance_, entities, num_entities, relation_tag, static_cast< const char* >( values ),
                      num_entities * sizeof( iBase_EntityHandle ), &result );
    PROCESS_ERROR;
int GeomAssocPairSide::set_relation_side ( iBase_EntitySetHandle *  sets,
int  num_sets,
const void *  values
) [virtual]
Definition at line 189 of file GeomAssocPairSide.cpp.
References iBase_SUCCESS, instance_, PROCESS_ERROR, relation_tag, RETURNR, and size.
    const char* data = static_cast< const char* >( values );
    int size         = sizeof( iBase_EntityHandle );
    int result;
        iGeom_setEntSetData( instance_, sets[i], relation_tag, data, size, &result );
        data += size;
        PROCESS_ERROR;
Definition at line 53 of file GeomAssocPairSide.cpp.
References iRel_IGEOM_IFACE.
    return iRel_IGEOM_IFACE;
Member Data Documentation
Definition at line 64 of file GeomAssocPairSide.hpp.
Referenced by GeomAssocPairSide(), and get_gids().
int GeomAssocPairSide::id [private]
Definition at line 61 of file GeomAssocPairSide.hpp.
Referenced by create_relation_side().
Definition at line 59 of file GeomAssocPairSide.hpp.
List of all members.
