MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * bvh_tree.hpp 00003 * Ryan H. Lewis 00004 * (C) 2012 00005 * 00006 * An element tree partitions a mesh composed of elements. 00007 * We subdivide the bounding box of a me, by putting boxes 00008 * on the left if there center is on the left of a split line 00009 * and vice versa. 00010 */ 00011 #include <vector> 00012 #include <set> 00013 #include <iostream> 00014 #include <map> 00015 #include <algorithm> 00016 #include <bitset> 00017 #include <numeric> 00018 #include <cmath> 00019 #include <tr1/unordered_map> 00020 #include <limits> 00021 #include "common_tree.hpp" 00022 00023 //#define BVH_TREE_DEBUG 00024 #ifndef BVH_TREE_HPP 00025 #define BVH_TREE_HPP 00026 00027 namespace ct = moab::common_tree; 00028 00029 namespace moab 00030 { 00031 00032 // forward declarations 00033 template < typename _Entity_handles, typename _Box, typename _Moab, typename _Parametrizer > 00034 class Bvh_tree; 00035 00036 // non-exported functionality 00037 namespace 00038 { 00039 namespace _bvh 00040 { 00041 template < typename Box, typename Entity_handle > 00042 struct _Node 00043 { 00044 typedef typename std::vector< std::pair< Box, Entity_handle > > Entities; 00045 std::size_t dim; 00046 std::size_t child; 00047 double Lmax, Rmin; 00048 Entities entities; 00049 _Node& operator=( const _Node& f ) 00050 { 00051 dim = f.dim; 00052 child = f.child; 00053 Lmax = f.Lmax; 00054 Rmin = f.Rmin; 00055 entities = f.entities; 00056 return *this; 00057 } 00058 }; // _Node 00059 00060 template < typename Split > 00061 class Split_comparator 00062 { 00063 // deprecation of binary_function 00064 typedef Split first_argument_type; 00065 typedef Split second_argument_type; 00066 typedef bool result_type; 00067 00068 inline double objective( const Split& a ) const 00069 { 00070 return a.Lmax * a.nl - a.Rmin * a.nr; 00071 } 00072 00073 public: 00074 bool operator()( const Split& a, const Split& b ) const 00075 { 00076 return objective( a ) < objective( b ); 00077 } 00078 }; // Split_comparator 00079 00080 template < typename Iterator > 00081 class Iterator_comparator 00082 { 00083 // deprecation of binary_function 00084 typedef Iterator first_argument_type; 00085 typedef Iterator second_argument_type; 00086 typedef bool result_type; 00087 00088 public: 00089 bool operator()( const Iterator& a, const Iterator& b ) const 00090 { 00091 return a->second.second < b->second.second || 00092 ( !( b->second.second < a->second.second ) && a->first < b->first ); 00093 } 00094 }; // Split_comparator 00095 00096 class _Split_data 00097 { 00098 public: 00099 typedef ct::Box< double > Box; 00100 _Split_data() 00101 : dim( 0 ), nl( 0 ), nr( 0 ), split( 0.0 ), Lmax( 0.0 ), Rmin( 0.0 ), bounding_box(), left_box(), 00102 right_box() 00103 { 00104 } 00105 _Split_data( const _Split_data& f ) 00106 : dim( f.dim ), nl( f.nl ), nr( f.nr ), split( f.split ), Lmax( f.Lmax ), Rmin( f.Rmin ), 00107 bounding_box( f.bounding_box ), left_box( f.left_box ), right_box( f.right_box ) 00108 { 00109 } 00110 std::size_t dim; 00111 std::size_t nl; 00112 std::size_t nr; 00113 double split; 00114 double Lmax, Rmin; 00115 Box bounding_box; 00116 Box left_box; 00117 Box right_box; 00118 _Split_data& operator=( const _Split_data& f ) 00119 { 00120 dim = f.dim; 00121 nl = f.nl; 00122 nr = f.nr; 00123 split = f.split; 00124 Lmax = f.Lmax; 00125 Rmin = f.Rmin; 00126 bounding_box = f.bounding_box; 00127 left_box = f.left_box; 00128 right_box = f.right_box; 00129 return *this; 00130 } 00131 }; //_Split_data 00132 00133 class _Bucket 00134 { 00135 public: 00136 _Bucket() : size( 0 ), bounding_box() {} 00137 _Bucket( const _Bucket& f ) : size( f.size ), bounding_box( f.bounding_box ) {} 00138 _Bucket( const std::size_t size_ ) : size( size_ ), bounding_box() {} 00139 std::size_t size; 00140 ct::Box< double > bounding_box; 00141 _Bucket& operator=( const _Bucket& f ) 00142 { 00143 bounding_box = f.bounding_box; 00144 size = f.size; 00145 return *this; 00146 } 00147 }; //_Split_data 00148 } // namespace _bvh 00149 } // namespace 00150 00151 template < typename _Entity_handles, typename _Box, typename _Moab, typename _Parametrizer > 00152 class Bvh_tree 00153 { 00154 // public types 00155 public: 00156 typedef _Entity_handles Entity_handles; 00157 typedef _Box Box; 00158 typedef _Moab Moab; 00159 typedef _Parametrizer Parametrizer; 00160 typedef typename Entity_handles::value_type Entity_handle; 00161 00162 // private types 00163 private: 00164 typedef Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer > Self; 00165 typedef typename std::pair< Box, Entity_handle > Leaf_element; 00166 typedef _bvh::_Node< Box, Entity_handle > Node; 00167 typedef typename std::vector< Node > Nodes; 00168 // public methods 00169 public: 00170 // Constructor 00171 Bvh_tree( Entity_handles& _entities, Moab& _moab, Box& _bounding_box, Parametrizer& _entity_contains ) 00172 : entity_handles_( _entities ), tree_(), moab( _moab ), bounding_box( _bounding_box ), 00173 entity_contains( _entity_contains ) 00174 { 00175 typedef typename Entity_handles::iterator Entity_handle_iterator; 00176 typedef ct::_Element_data< const _Box, double > Element_data; 00177 typedef typename std::tr1::unordered_map< Entity_handle, Element_data > Entity_map; 00178 typedef typename Entity_map::iterator Entity_map_iterator; 00179 typedef std::vector< Entity_map_iterator > Vector; 00180 // a fully balanced tree will have 2*_entities.size() 00181 // which is one doubling away.. 00182 tree_.reserve( entity_handles_.size() ); 00183 Entity_map entity_map( entity_handles_.size() ); 00184 ct::construct_element_map( entity_handles_, entity_map, bounding_box, moab ); 00185 #ifdef BVH_TREE_DEBUG 00186 for( Entity_map_iterator i = entity_map.begin(); i != entity_map.end(); ++i ) 00187 { 00188 if( !box_contains_box( bounding_box, i->second.first, 0 ) ) 00189 { 00190 std::cerr << "BB:" << bounding_box << "EB:" << i->second.first << std::endl; 00191 std::exit( -1 ); 00192 } 00193 } 00194 #endif 00195 //_bounding_box = bounding_box; 00196 Vector entity_ordering; 00197 construct_ordering( entity_map, entity_ordering ); 00198 // We only build nonempty trees 00199 if( entity_ordering.size() ) 00200 { 00201 // initially all bits are set 00202 tree_.push_back( Node() ); 00203 const int depth = build_tree( entity_ordering.begin(), entity_ordering.end(), 0, bounding_box ); 00204 #ifdef BVH_TREE_DEBUG 00205 typedef typename Nodes::iterator Node_iterator; 00206 typedef typename Node::Entities::iterator Entity_iterator; 00207 std::set< Entity_handle > entity_handles; 00208 for( Node_iterator i = tree_.begin(); i != tree_.end(); ++i ) 00209 { 00210 for( Entity_iterator j = i->entities.begin(); j != i->entities.end(); ++j ) 00211 { 00212 entity_handles.insert( j->second ); 00213 } 00214 } 00215 if( entity_handles.size() != entity_handles_.size() ) 00216 { 00217 std::cout << "Entity Handle Size Mismatch!" << std::endl; 00218 } 00219 typedef typename Entity_handles::iterator Entity_iterator_; 00220 for( Entity_iterator_ i = entity_handles_.begin(); i != entity_handles_.end(); ++i ) 00221 { 00222 if( entity_handles.find( *i ) == entity_handles.end() ) 00223 { 00224 std::cout << "Tree is missing an entity! " << std::endl; 00225 } 00226 } 00227 00228 #endif 00229 std::cout << "max tree depth: " << depth << std::endl; 00230 } 00231 } 00232 00233 // Copy constructor 00234 Bvh_tree( Self& s ) 00235 : entity_handles_( s.entity_handles_ ), tree_( s.tree_ ), moab( s.moab ), bounding_box( s.bounding_box ), 00236 entity_contains( s.entity_contains ) 00237 { 00238 } 00239 00240 // see FastMemoryEfficientCellLocationinUnstructuredGridsForVisualization.pdf 00241 // around page 9 00242 #define NUM_SPLITS 4 00243 #define NUM_BUCKETS ( NUM_SPLITS + 1 ) // NUM_SPLITS+1 00244 #define SMAX 5 00245 // Paper arithmetic is over-optimized.. this is safer. 00246 template < typename Box > 00247 std::size_t bucket_index( const Box& box, const Box& interval, const std::size_t dim ) const 00248 { 00249 const double min = interval.min[dim]; 00250 const double length = ( interval.max[dim] - min ) / NUM_BUCKETS; 00251 const double center = ( ( box.max[dim] + box.min[dim] ) / 2.0 ) - min; 00252 #ifdef BVH_TREE_DEBUG 00253 #ifdef BVH_SHOW_INDEX 00254 std::cout << "[ " << min << " , " << interval.max[dim] << " ]" << std::endl; 00255 std::cout << "[ " << box.min[dim] << " , " << box.max[dim] << " ]" << std::endl; 00256 std::cout << "Length of bucket" << length << std::endl; 00257 std::cout << "Center: " << ( box.max[dim] + box.min[dim] ) / 2.0 << std::endl; 00258 std::cout << "Distance of center from min: " << center << std::endl; 00259 std::cout << "ratio: " << center / length << std::endl; 00260 std::cout << "index: " << std::ceil( center / length ) - 1 << std::endl; 00261 #endif 00262 #endif 00263 return std::ceil( center / length ) - 1; 00264 } 00265 00266 template < typename Iterator, typename Bounding_box, typename Buckets > 00267 void establish_buckets( const Iterator begin, 00268 const Iterator end, 00269 const Bounding_box& interval, 00270 Buckets& buckets ) const 00271 { 00272 // put each element into its bucket 00273 for( Iterator i = begin; i != end; ++i ) 00274 { 00275 const Bounding_box& box = ( *i )->second.first; 00276 for( std::size_t dim = 0; dim < NUM_DIM; ++dim ) 00277 { 00278 const std::size_t index = bucket_index( box, interval, dim ); 00279 _bvh::_Bucket& bucket = buckets[dim][index]; 00280 if( bucket.size > 0 ) 00281 { 00282 ct::update_bounding_box( bucket.bounding_box, box ); 00283 } 00284 else 00285 { 00286 bucket.bounding_box = box; 00287 } 00288 bucket.size++; 00289 } 00290 } 00291 #ifdef BVH_TREE_DEBUG 00292 Bounding_box elt_union = ( *begin )->second.first; 00293 for( Iterator i = begin; i != end; ++i ) 00294 { 00295 const Bounding_box& box = ( *i )->second.first; 00296 ct::update_bounding_box( elt_union, box ); 00297 for( std::size_t dim = 0; dim < NUM_DIM; ++dim ) 00298 { 00299 const std::size_t index = bucket_index( box, interval, dim ); 00300 _bvh::_Bucket& bucket = buckets[dim][index]; 00301 if( !box_contains_box( bucket.bounding_box, box ) ) 00302 { 00303 std::cerr << "Buckets not covering elements!" << std::endl; 00304 } 00305 } 00306 } 00307 if( !box_contains_box( elt_union, interval ) ) 00308 { 00309 std::cout << "element union: " << std::endl << elt_union; 00310 std::cout << "intervals: " << std::endl << interval; 00311 std::cout << "union of elts does not contain original box!" << std::endl; 00312 } 00313 if( !box_contains_box( interval, elt_union ) ) 00314 { 00315 std::cout << "original box does not contain union of elts" << std::endl; 00316 std::cout << interval << std::endl; 00317 std::cout << elt_union << std::endl; 00318 } 00319 typedef typename Buckets::value_type Bucket_list; 00320 typedef typename Bucket_list::const_iterator Bucket_iterator; 00321 for( std::size_t d = 0; d < NUM_DIM; ++d ) 00322 { 00323 std::vector< std::size_t > nonempty; 00324 const Bucket_list& buckets_ = buckets[d]; 00325 std::size_t j = 0; 00326 for( Bucket_iterator i = buckets_.begin(); i != buckets_.end(); ++i, ++j ) 00327 { 00328 if( i->size > 0 ) 00329 { 00330 nonempty.push_back( j ); 00331 } 00332 } 00333 Bounding_box test_box = buckets_[nonempty.front()].bounding_box; 00334 for( std::size_t i = 0; i < nonempty.size(); ++i ) 00335 { 00336 ct::update_bounding_box( test_box, buckets_[nonempty[i]].bounding_box ); 00337 } 00338 if( !box_contains_box( test_box, interval ) ) 00339 { 00340 std::cout << "union of buckets in dimension: " << d << "does not contain original box!" << std::endl; 00341 } 00342 if( !box_contains_box( interval, test_box ) ) 00343 { 00344 std::cout << "original box does " 00345 << "not contain union of buckets" 00346 << "in dimension: " << d << std::endl; 00347 std::cout << interval << std::endl; 00348 std::cout << test_box << std::endl; 00349 } 00350 } 00351 #endif 00352 } 00353 00354 template < typename Box, typename Iterator > 00355 std::size_t set_interval( Box& interval, const Iterator begin, const Iterator end ) const 00356 { 00357 bool first = true; 00358 std::size_t count = 0; 00359 for( Iterator b = begin; b != end; ++b ) 00360 { 00361 const Box& box = b->bounding_box; 00362 count += b->size; 00363 if( b->size != 0 ) 00364 { 00365 if( first ) 00366 { 00367 interval = box; 00368 first = false; 00369 } 00370 else 00371 { 00372 ct::update_bounding_box( interval, box ); 00373 } 00374 } 00375 } 00376 return count; 00377 } 00378 00379 template < typename Splits, typename Buckets, typename Split_data > 00380 void initialize_splits( Splits& splits, const Buckets& buckets, const Split_data& data ) const 00381 { 00382 typedef typename Buckets::value_type Bucket_list; 00383 typedef typename Bucket_list::value_type Bucket; 00384 typedef typename Bucket_list::const_iterator Bucket_iterator; 00385 typedef typename Splits::value_type Split_list; 00386 typedef typename Split_list::value_type Split; 00387 typedef typename Split_list::iterator Split_iterator; 00388 for( std::size_t d = 0; d < NUM_DIM; ++d ) 00389 { 00390 const Split_iterator splits_begin = splits[d].begin(); 00391 const Split_iterator splits_end = splits[d].end(); 00392 const Bucket_iterator left_begin = buckets[d].begin(); 00393 const Bucket_iterator _end = buckets[d].end(); 00394 Bucket_iterator left_end = buckets[d].begin() + 1; 00395 for( Split_iterator s = splits_begin; s != splits_end; ++s, ++left_end ) 00396 { 00397 s->nl = set_interval( s->left_box, left_begin, left_end ); 00398 if( s->nl == 0 ) 00399 { 00400 s->left_box = data.bounding_box; 00401 s->left_box.max[d] = s->left_box.min[d]; 00402 } 00403 s->nr = set_interval( s->right_box, left_end, _end ); 00404 if( s->nr == 0 ) 00405 { 00406 s->right_box = data.bounding_box; 00407 s->right_box.min[d] = s->right_box.max[d]; 00408 } 00409 s->Lmax = s->left_box.max[d]; 00410 s->Rmin = s->right_box.min[d]; 00411 s->split = std::distance( splits_begin, s ); 00412 s->dim = d; 00413 } 00414 #ifdef BVH_TREE_DEBUG 00415 for( Split_iterator s = splits_begin; s != splits_end; ++s, ++left_end ) 00416 { 00417 typename Split::Box test_box = s->left_box; 00418 ct::update_bounding_box( test_box, s->right_box ); 00419 if( !box_contains_box( data.bounding_box, test_box ) ) 00420 { 00421 std::cout << "nr: " << s->nr << std::endl; 00422 std::cout << "Test box: " << std::endl << test_box; 00423 std::cout << "Left box: " << std::endl << s->left_box; 00424 std::cout << "Right box: " << std::endl << s->right_box; 00425 std::cout << "Interval: " << std::endl << data.bounding_box; 00426 std::cout << "Split boxes larger than bb" << std::endl; 00427 } 00428 if( !box_contains_box( test_box, data.bounding_box ) ) 00429 { 00430 std::cout << "bb larger than union " 00431 << "of split boxes" << std::endl; 00432 } 00433 } 00434 #endif 00435 } 00436 } 00437 00438 template < typename Iterator, typename Split_data > 00439 void order_elements( const Iterator& begin, const Iterator& end, const Split_data& data ) const 00440 { 00441 typedef typename Iterator::value_type Map_iterator; 00442 for( Iterator i = begin; i != end; ++i ) 00443 { 00444 const int index = bucket_index( ( *i )->second.first, data.bounding_box, data.dim ); 00445 ( *i )->second.second = ( index <= data.split ) ? 0 : 1; 00446 } 00447 std::sort( begin, end, _bvh::Iterator_comparator< Map_iterator >() ); 00448 } 00449 00450 template < typename Iterator, typename Split_data > 00451 void median_order( const Iterator& begin, const Iterator& end, Split_data& data ) const 00452 { 00453 typedef typename Iterator::value_type Map_iterator; 00454 for( Iterator i = begin; i != end; ++i ) 00455 { 00456 const double center = compute_box_center( ( *i )->second.first, data.dim ); 00457 ( *i )->second.second = center; 00458 } 00459 std::sort( begin, end, _bvh::Iterator_comparator< Map_iterator >() ); 00460 const std::size_t total = std::distance( begin, end ); 00461 Iterator middle = begin + ( total / 2 ); 00462 double middle_center = ( *middle )->second.second; 00463 middle_center += ( *( ++middle ) )->second.second; 00464 middle_center /= 2.0; 00465 data.split = middle_center; 00466 data.nl = std::distance( begin, middle ) + 1; 00467 data.nr = total - data.nl; 00468 middle++; 00469 data.left_box = ( *begin )->second.first; 00470 data.right_box = ( *middle )->second.first; 00471 for( Iterator i = begin; i != middle; ++i ) 00472 { 00473 ( *i )->second.second = 0; 00474 update_bounding_box( data.left_box, ( *i )->second.first ); 00475 } 00476 for( Iterator i = middle; i != end; ++i ) 00477 { 00478 ( *i )->second.second = 1; 00479 update_bounding_box( data.right_box, ( *i )->second.first ); 00480 } 00481 data.Rmin = data.right_box.min[data.dim]; 00482 data.Lmax = data.left_box.max[data.dim]; 00483 #ifdef BVH_TREE_DEBUG 00484 typename Split_data::Box test_box = data.left_box; 00485 ct::update_bounding_box( test_box, data.right_box ); 00486 if( !box_contains_box( data.bounding_box, test_box ) ) 00487 { 00488 std::cerr << "MEDIAN: BB Does not contain splits" << std::endl; 00489 } 00490 if( !box_contains_box( test_box, data.bounding_box ) ) 00491 { 00492 std::cerr << "MEDIAN: splits do not contain BB" << std::endl; 00493 } 00494 #endif 00495 } 00496 00497 template < typename Splits, typename Split_data > 00498 void choose_best_split( const Splits& splits, Split_data& data ) const 00499 { 00500 typedef typename Splits::const_iterator List_iterator; 00501 typedef typename List_iterator::value_type::const_iterator Split_iterator; 00502 typedef typename Split_iterator::value_type Split; 00503 std::vector< Split > best_splits; 00504 typedef typename _bvh::Split_comparator< Split > Comparator; 00505 Comparator compare; 00506 for( List_iterator i = splits.begin(); i != splits.end(); ++i ) 00507 { 00508 Split_iterator j = std::min_element( i->begin(), i->end(), compare ); 00509 best_splits.push_back( *j ); 00510 } 00511 data = *std::min_element( best_splits.begin(), best_splits.end(), compare ); 00512 } 00513 00514 template < typename Iterator, typename Split_data > 00515 void find_split( const Iterator& begin, const Iterator& end, Split_data& data ) const 00516 { 00517 typedef typename Iterator::value_type Map_iterator; 00518 typedef typename Map_iterator::value_type::second_type Box_data; 00519 typedef typename Box_data::first_type _Bounding_box; // Note, not global typedef moab::common_tree::Box< 00520 // double> Bounding_box; 00521 typedef typename std::vector< Split_data > Split_list; 00522 typedef typename std::vector< Split_list > Splits; 00523 typedef typename Splits::iterator Split_iterator; 00524 typedef typename std::vector< _bvh::_Bucket > Bucket_list; 00525 typedef typename std::vector< Bucket_list > Buckets; 00526 Buckets buckets( NUM_DIM, Bucket_list( NUM_BUCKETS ) ); 00527 Splits splits( NUM_DIM, Split_list( NUM_SPLITS, data ) ); 00528 00529 const _Bounding_box interval = data.bounding_box; 00530 establish_buckets( begin, end, interval, buckets ); 00531 initialize_splits( splits, buckets, data ); 00532 choose_best_split( splits, data ); 00533 const bool use_median = ( 0 == data.nl ) || ( data.nr == 0 ); 00534 if( !use_median ) 00535 { 00536 order_elements( begin, end, data ); 00537 } 00538 else 00539 { 00540 median_order( begin, end, data ); 00541 } 00542 #ifdef BVH_TREE_DEBUG 00543 bool seen_one = false, issue = false; 00544 bool first_left = true, first_right = true; 00545 std::size_t count_left = 0, count_right = 0; 00546 typename Split_data::Box left_box, right_box; 00547 for( Iterator i = begin; i != end; ++i ) 00548 { 00549 double order = ( *i )->second.second; 00550 if( order != 0 && order != 1 ) 00551 { 00552 std::cerr << "Invalid order element !"; 00553 std::cerr << order << std::endl; 00554 std::exit( -1 ); 00555 } 00556 if( order == 1 ) 00557 { 00558 seen_one = 1; 00559 count_right++; 00560 if( first_right ) 00561 { 00562 right_box = ( *i )->second.first; 00563 first_right = false; 00564 } 00565 else 00566 { 00567 ct::update_bounding_box( right_box, ( *i )->second.first ); 00568 } 00569 if( !box_contains_box( data.right_box, ( *i )->second.first ) ) 00570 { 00571 if( !issue ) 00572 { 00573 std::cerr << "Bounding right box issue!" << std::endl; 00574 } 00575 issue = true; 00576 } 00577 } 00578 if( order == 0 ) 00579 { 00580 count_left++; 00581 if( first_left ) 00582 { 00583 left_box = ( *i )->second.first; 00584 first_left = false; 00585 } 00586 else 00587 { 00588 ct::update_bounding_box( left_box, ( *i )->second.first ); 00589 } 00590 if( !box_contains_box( data.left_box, ( *i )->second.first ) ) 00591 { 00592 if( !issue ) 00593 { 00594 std::cerr << "Bounding left box issue!" << std::endl; 00595 } 00596 issue = true; 00597 } 00598 if( seen_one ) 00599 { 00600 std::cerr << "Invalid ordering!" << std::endl; 00601 std::cout << ( *( i - 1 ) )->second.second << order << std::endl; 00602 exit( -1 ); 00603 } 00604 } 00605 } 00606 if( !box_contains_box( left_box, data.left_box ) ) 00607 { 00608 std::cout << "left elts do not contain left box" << std::endl; 00609 } 00610 if( !box_contains_box( data.left_box, left_box ) ) 00611 { 00612 std::cout << "left box does not contain left elts" << std::endl; 00613 } 00614 if( !box_contains_box( right_box, data.right_box ) ) 00615 { 00616 std::cout << "right elts do not contain right box" << std::endl; 00617 } 00618 if( !box_contains_box( data.right_box, right_box ) ) 00619 { 00620 std::cout << "right box do not contain right elts" << std::endl; 00621 } 00622 if( count_left != data.nl || count_right != data.nr ) 00623 { 00624 std::cerr << "counts are off!" << std::endl; 00625 std::cerr << "total: " << std::distance( begin, end ) << std::endl; 00626 std::cerr << "Dim: " << data.dim << std::endl; 00627 std::cerr << data.Lmax << " , " << data.Rmin << std::endl; 00628 std::cerr << "Right box: " << std::endl << data.right_box << "Left box: " << std::endl << data.left_box; 00629 std::cerr << "supposed to be: " << data.nl << " " << data.nr << std::endl; 00630 std::cerr << "accountant says: " << count_left << " " << count_right << std::endl; 00631 std::exit( -1 ); 00632 } 00633 #endif 00634 } 00635 00636 // private functionality 00637 private: 00638 template < typename Iterator > 00639 int build_tree( const Iterator begin, const Iterator end, const int index, const Box& box, const int depth = 0 ) 00640 { 00641 #ifdef BVH_TREE_DEBUG 00642 for( Iterator i = begin; i != end; ++i ) 00643 { 00644 if( !box_contains_box( box, ( *i )->second.first, 0 ) ) 00645 { 00646 std::cerr << "depth: " << depth << std::endl; 00647 std::cerr << "BB:" << box << "EB:" << ( *i )->second.first << std::endl; 00648 std::exit( -1 ); 00649 } 00650 } 00651 #endif 00652 00653 const std::size_t total_num_elements = std::distance( begin, end ); 00654 Node& node = tree_[index]; 00655 // logic for splitting conditions 00656 if( total_num_elements > SMAX ) 00657 { 00658 _bvh::_Split_data data; 00659 data.bounding_box = box; 00660 find_split( begin, end, data ); 00661 // assign data to node 00662 node.Lmax = data.Lmax; 00663 node.Rmin = data.Rmin; 00664 node.dim = data.dim; 00665 node.child = tree_.size(); 00666 // insert left, right children; 00667 tree_.push_back( Node() ); 00668 tree_.push_back( Node() ); 00669 const int left_depth = build_tree( begin, begin + data.nl, node.child, data.left_box, depth + 1 ); 00670 const int right_depth = build_tree( begin + data.nl, end, node.child + 1, data.right_box, depth + 1 ); 00671 return std::max( left_depth, right_depth ); 00672 } 00673 node.dim = 3; 00674 ct::assign_entities( node.entities, begin, end ); 00675 return depth; 00676 } 00677 00678 template < typename Vector, typename Node_index, typename Result > 00679 Result& _find_point( const Vector& point, const Node_index& index, const double tol, Result& result ) const 00680 { 00681 typedef typename Node::Entities::const_iterator Entity_iterator; 00682 const Node& node = tree_[index]; 00683 if( node.dim == 3 ) 00684 { 00685 for( Entity_iterator i = node.entities.begin(); i != node.entities.end(); ++i ) 00686 { 00687 if( ct::box_contains_point( i->first, point, tol ) ) 00688 { 00689 const std::pair< bool, Vector > r = entity_contains( moab, i->second, point ); 00690 if( r.first ) 00691 { 00692 return result = std::make_pair( i->second, r.second ); 00693 } 00694 } 00695 } 00696 result = Result( 0, point ); 00697 return result; 00698 } 00699 // the extra tol here considers the case where 00700 // 0 < Rmin - Lmax < 2tol 00701 if( ( node.Lmax + tol ) < ( node.Rmin - tol ) ) 00702 { 00703 if( point[node.dim] <= ( node.Lmax + tol ) ) 00704 { 00705 return _find_point( point, node.child, tol, result ); 00706 } 00707 else if( point[node.dim] >= ( node.Rmin - tol ) ) 00708 { 00709 return _find_point( point, node.child + 1, tol, result ); 00710 } 00711 result = Result( 0, point ); 00712 return result; // point lies in empty space. 00713 } 00714 // Boxes overlap 00715 // left of Rmin, you must be on the left 00716 // we can't be sure about the boundaries since the boxes overlap 00717 // this was a typo in the paper which caused pain. 00718 if( point[node.dim] < ( node.Rmin - tol ) ) 00719 { 00720 return _find_point( point, node.child, tol, result ); 00721 // if you are on the right Lmax, you must be on the right 00722 } 00723 else if( point[node.dim] > ( node.Lmax + tol ) ) 00724 { 00725 return _find_point( point, node.child + 1, tol, result ); 00726 } 00727 /* pg5 of paper 00728 * However, instead of always traversing either subtree 00729 * first (e.g. left always before right), we first traverse 00730 * the subtree whose bounding plane has the larger distance to the 00731 * sought point. This results in less overall traversal, and the correct 00732 * cell is identified more quickly. 00733 */ 00734 // Sofar all testing confirms that this 'heuristic' is 00735 // significantly slower. 00736 // I conjecture this is because it gets improperly 00737 // branch predicted.. 00738 // bool dir = (point[ node.dim] - node.Rmin) <= 00739 // (node.Lmax - point[ node.dim]); 00740 bool dir = false; 00741 _find_point( point, node.child + dir, tol, result ); 00742 if( result.first == 0 ) 00743 { 00744 return _find_point( point, node.child + ( !dir ), tol, result ); 00745 } 00746 return result; 00747 } 00748 00749 // public functionality 00750 public: 00751 template < typename Vector, typename Result > 00752 Result& find( const Vector& point, const double tol, Result& result ) const 00753 { 00754 typedef typename Vector::const_iterator Point_iterator; 00755 return _find_point( point, 0, tol, result ); 00756 } 00757 00758 // public functionality 00759 public: 00760 template < typename Vector > 00761 Entity_handle bruteforce_find( const Vector& point, const double tol ) const 00762 { 00763 typedef typename Vector::const_iterator Point_iterator; 00764 typedef typename Nodes::value_type Node; 00765 typedef typename Nodes::const_iterator Node_iterator; 00766 typedef typename Node::Entities::const_iterator Entity_iterator; 00767 for( Node_iterator i = tree_.begin(); i != tree_.end(); ++i ) 00768 { 00769 if( i->dim == 3 ) 00770 { 00771 for( Entity_iterator j = i->entities.begin(); j != i->entities.end(); ++j ) 00772 { 00773 if( ct::box_contains_point( j->first, point, tol ) ) 00774 { 00775 const std::pair< bool, Vector > result = entity_contains( moab, j->second, point ); 00776 if( result.first ) 00777 { 00778 return j->second; 00779 } 00780 } 00781 } 00782 } 00783 } 00784 return 0; 00785 } 00786 00787 // public accessor methods 00788 public: 00789 // private data members 00790 private: 00791 const Entity_handles& entity_handles_; 00792 Nodes tree_; 00793 Moab& moab; 00794 Box bounding_box; 00795 Parametrizer& entity_contains; 00796 00797 }; // class Bvh_tree 00798 00799 } // namespace moab 00800 00801 #endif // BVH_TREE_HPP
