MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/ReadUtilIface.hpp"#include "moab/CartVect.hpp"#include <iostream>#include <fstream>
Include dependency graph for BoundaryContinents.cpp:Go to the source code of this file.
Functions | |
| double | getLat (CartVect p) |
| double | getLon (CartVect p) |
| int | main (int argc, char **argv) |
Variables | |
| string | bd_name = string( MESH_DIR ) + string( "/../examples/earth/boundary_points.dat" ) |
| string | loops = string( MESH_DIR ) + string( "/../examples/earth/SaveLoopCounts" ) |
Definition at line 21 of file BoundaryContinents.cpp.
References moab::CartVect::normalize().
Referenced by main().
p.normalize();
return asin( p[2] );
Definition at line 26 of file BoundaryContinents.cpp.
p.normalize();
double lon;
lon = atan2( p[1], p[0] );
if( lon < -2.95 )
{ // this is Behring Strait :)
return 2.0 * M_PI + lon;
else
return lon;
| int main | ( | int | argc, |
| char ** | argv | ||
get loops for boundaries
Definition at line 42 of file BoundaryContinents.cpp.
References moab::Interface::add_entities(), bd_name, moab::Range::begin(), moab::Interface::create_meshset(), moab::Interface::create_vertices(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ReadUtilIface::get_element_connect(), getLat(), getLon(), moab::Interface::globalId_tag(), moab::Range::insert(), length_squared(), loops, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MBEDGE, MESHSET_SET, moab::Interface::query_interface(), moab::Interface::set_coords(), moab::Range::size(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
// Get MOAB instance
Interface* mb = new( std::nothrow ) Core;
if( NULL == mb ) return 1;
if( argc > 1 )
// User has input file for boundary describing continents
bd_name = argv[1];
if( argc > 2 )
// User has input file for loops for continents/islands
loops = argv[2];
std::vector< double > coords;
ifstream bdFile( bd_name.c_str() );
if( !bdFile )
cout << endl << "Failed to open file " << bd_name << endl;
return 1;
coords.resize( 0 );
while( !bdFile.eof() )
double co;
bdFile >> co;
coords.push_back( co );
cout << " number of boundary points:" << coords.size() / 3 << "\n";
/// get loops for boundaries
vector< int > loopsindx;
ifstream loopFile( loops.c_str() );
while( !loopFile.eof() )
int indx;
loopFile >> indx;
loopsindx.push_back( indx );
cout << "number of loops: " << loopsindx.size() / 2 << "\n";
ReadUtilIface* readMeshIface;
mb->query_interface( readMeshIface );
Range verts;
ErrorCode rval = mb->create_vertices( &coords[0], coords.size() / 3, verts );MB_CHK_SET_ERR( rval, "do not create boundary vertices" );
Tag gid = mb->globalId_tag();
int num_edges = 0;
for( size_t i = 0; i < loopsindx.size() / 2; i++ )
num_edges += ( loopsindx[2 * i + 1] - loopsindx[2 * i] + 1 );
EntityHandle handle;
EntityHandle* conn_array;
rval = readMeshIface->get_element_connect( num_edges, 2, MBEDGE, 1, handle, conn_array );MB_CHK_SET_ERR( rval, "do not elems" );
int i1 = 0; // index in edge connectivity
for( int j = loopsindx[2 * i]; j <= loopsindx[2 * i + 1]; j++ )
int j2;
j2 = j;
if( j == loopsindx[2 * i + 1] ) j2 = loopsindx[2 * i] - 1; // close the loop
conn_array[2 * i1] = verts[j - 1]; // vertices for sure start at 1
conn_array[2 * i1 + 1] = verts[j2]; // vertices for sure start at 1
i1++;
// the last vertex is first one in the loop
Range bedges( handle, handle + num_edges - 1 );
EntityHandle bound_set;
rval = mb->create_meshset( MESHSET_SET, bound_set );MB_CHK_SET_ERR( rval, "Can't create boundary edges set" );
rval = mb->add_entities( bound_set, bedges );MB_CHK_SET_ERR( rval, "Can't add edges to boundary set" );
// set global ids for vertices and edges
vector< int > gids;
gids.resize( verts.size() );
for( int j = 0; j < (int)verts.size(); j++ )
gids[j] = j + 1;
rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on verts" );
// we have less edges than vertices, we can reuse the array for edges too
rval = mb->tag_set_data( gid, bedges, &gids[0] );MB_CHK_SET_ERR( rval, "Can't set global ids on edges" );
mb->write_file( "bound.vtk", 0, 0, &bound_set, 1 );
// now project the mesh in 2d plane
// get all the vertices coordinates
std::vector< CartVect > co3;
co3.resize( verts.size() );
rval = mb->get_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't get vertex coords" );
for( size_t i = 0; i < verts.size(); i++ )
CartVect p = co3[i];
double lat1 = getLat( p );
double lon1 = getLon( p );
co3[i] = CartVect( lon1, lat1, 0. );
rval = mb->set_coords( verts, &( co3[0][0] ) );MB_CHK_SET_ERR( rval, "Can't set new vertex coords" );
// remove edges in 2d that are too long (longer than 6; they are on the other side..., periodic)
Range longEdges;
for( Range::iterator eit = bedges.begin(); eit != bedges.end(); ++eit )
EntityHandle eh = *eit;
const EntityHandle* conn;
int nconn;
rval = mb->get_connectivity( eh, conn, nconn );MB_CHK_ERR( rval );
// get coordinates of nodes
CartVect c2[2];
rval = mb->get_coords( conn, 2, &( c2[0][0] ) );MB_CHK_ERR( rval );
double dist = ( c2[1] - c2[0] ).length_squared();
if( dist > 36. ) // too long edge in 2d, remove it
longEdges.insert( eh );
rval = mb->delete_entities( longEdges );MB_CHK_ERR( rval );
mb->write_file( "bound2d.vtk" );
delete mb;
return 0;
Definition at line 18 of file BoundaryContinents.cpp.
Definition at line 19 of file BoundaryContinents.cpp.
