MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"#include "moab/Core.hpp"#include "moab_mpi.h"#include "TestUtil.hpp"#include "MBTagConventions.hpp"#include <iostream>#include <sstream>
Include dependency graph for ghost_thin_layers.cpp:Go to the source code of this file.
Functions | |
| void | test_correct_ghost () |
| void | test_read_with_thin_ghost_layer () |
| int | main (int argc, char *argv[]) |
Variables | |
| std::string | filename = "unittest/io/ln4.h5m" |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 73 of file ghost_thin_layers.cpp.
References filename, MPI_COMM_WORLD, rank, RUN_TEST, test_correct_ghost(), and test_read_with_thin_ghost_layer().
MPI_Init( &argc, &argv );
int nproc, rank;
MPI_Comm_size( MPI_COMM_WORLD, &nproc );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
if( nproc <= 3 )
std::cout << " launch it on at least 4 processes. \n";
MPI_Finalize();
return 0;
int result = 0;
if( argc >= 2 ) filename = argv[1]; // to be able to test other files too
result += RUN_TEST( test_read_with_thin_ghost_layer );
result += RUN_TEST( test_correct_ghost );
MPI_Finalize();
return 0;
| void test_correct_ghost | ( | ) |
Definition at line 14 of file ghost_thin_layers.cpp.
References CHECK_ERR, moab::ParallelComm::correct_thin_ghost_layers(), ErrorCode, moab::ParallelComm::exchange_ghost_cells(), filename, moab::Interface::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, outfile, rank, and moab::Interface::write_file().
Referenced by main().
int nproc, rank;
// Get MOAB instance
Interface* mb = new( std::nothrow ) Core;
ErrorCode rval = MB_SUCCESS;
// Get the ParallelComm instance
ParallelComm* pcomm = new ParallelComm( mb, MPI_COMM_WORLD );
char read_opts[] = "PARALLEL=READ_PART;PARALLEL_RESOLVE_SHARED_ENTS;PARTITION=PARALLEL_"
"PARTITION;PARALLEL_GHOSTS=2.0.1";
rval = mb->load_file( filename.c_str(), 0, read_opts );CHECK_ERR( rval );
if( nproc >= 3 )
rval = pcomm->correct_thin_ghost_layers();CHECK_ERR( rval );
rval = pcomm->exchange_ghost_cells( 2, 0, 2, 0, true );CHECK_ERR( rval ); // true to store remote handles
// write in serial the database , on each rank
std::ostringstream outfile;
outfile << "testReadThin_n" << nproc << "." << rank << ".h5m";
rval = mb->write_file( outfile.str().c_str() ); // everything on local root
CHECK_ERR( rval );
delete mb;
| void test_read_with_thin_ghost_layer | ( | ) |
Definition at line 47 of file ghost_thin_layers.cpp.
References CHECK_ERR, ErrorCode, moab::ParallelComm::exchange_ghost_cells(), filename, moab::Core::load_file(), mb, MB_SUCCESS, MPI_COMM_WORLD, outfile, rank, and moab::Core::write_file().
int nproc, rank;
moab::Core* mb = new moab::Core();
"PARTITION;PARALLEL_GHOSTS=2.0.1;PARALLEL_THIN_GHOST_LAYER;";
outfile << "testReadGhost_n" << nproc << "." << rank << ".h5m";
CHECK_ERR( rval );
delete mb;
| std::string filename = "unittest/io/ln4.h5m" |
Definition at line 10 of file ghost_thin_layers.cpp.
