testSmooth2.cpp File Reference
#include "FBiGeom.h"
#include "FBiGeom_MOAB.hpp"
#include "iMesh.h"
#include <iostream>
#include <set>
#include <algorithm>
#include <vector>
#include <iterator>
#include <iomanip>
#include <cassert>
#include <cstring>
#include <cmath>
+ Include dependency graph for testSmooth2.cpp:
Classes
class  SimpleArray< T >
Defines
#define CHECK(STR)   if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
#define STRINGIFY(S)   XSTRINGIFY( S )
#define XSTRINGIFY(S)   #S
#define ARRAY_INOUT(A)   A.ptr(), &( A ).capacity(), &( A ).size()
#define ARRAY_IN(A)   &( A )[0], ( A ).size()
Typedefs
typedef iBase_TagHandle TagHandle
typedef iBase_EntityHandle GentityHandle
typedef iBase_EntitySetHandle GentitysetHandle
Functions
static bool print_error (const char *desc, int err, FBiGeom_Instance geom, const char *file, int line)
void FBiGeom_newGeomFromMesh (iMesh_Instance mesh, iBase_EntitySetHandle set, const char *options, FBiGeom_Instance *geom, int *err, int options_len)
void FBiGeom_dtor2 (FBiGeom_Instance instance, int *err)
bool smooth_test (const std::string &filename, FBiGeom_Instance)
bool tags_test (FBiGeom_Instance geom)
bool tag_get_set_test (FBiGeom_Instance geom)
bool tag_info_test (FBiGeom_Instance geom)
bool gentityset_test (FBiGeom_Instance geom, bool, bool)
bool topology_adjacencies_test (FBiGeom_Instance geom)
bool geometry_evaluation_test (FBiGeom_Instance geom)
bool construct_test (FBiGeom_Instance geom)
bool primitives_test (FBiGeom_Instance geom)
bool transforms_test (FBiGeom_Instance geom)
bool booleans_test (FBiGeom_Instance geom)
bool shutdown_test2 (FBiGeom_Instance geom, std::string &engine_opt)
bool save_entset_test (FBiGeom_Instance geom)
bool mesh_size_test (FBiGeom_Instance geom)
bool normals_test (FBiGeom_Instance geom)
bool ray_test (FBiGeom_Instance geom)
void handle_error_code (const bool result, int &number_failed, int &, int &number_successful)
int main (int argc, char *argv[])
static bool compare_box (const double *expected_min, const double *expected_max, const double *actual_min, const double *actual_max)
static int get_entities (FBiGeom_Instance geom, int entity_type, std::vector< iBase_EntityHandle > &entities_out, iBase_TagHandle id_tag=0, std::vector< int > *ids_out=0)
static int check_firmness (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &entities, const std::vector< int > &ids, iBase_TagHandle firmness_tag, const char *expected_value, const char *ent_type_str)
static int count_num_with_tag (FBiGeom_Instance geom, const std::vector< iBase_EntityHandle > &ents, iBase_TagHandle tag)
Define Documentation
#define ARRAY_IN (   A)    &( A )[0], ( A ).size()
Definition at line 135 of file testSmooth2.cpp.
#define ARRAY_INOUT (   A)    A.ptr(), &( A ).capacity(), &( A ).size()
Definition at line 134 of file testSmooth2.cpp.
#define CHECK (   STR)    if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
Definition at line 27 of file testSmooth2.cpp.
Referenced by main(), and shutdown_test2().
#define STRINGIFY (   S)    XSTRINGIFY( S )
Definition at line 30 of file testSmooth2.cpp.
Referenced by main().
#define XSTRINGIFY (   S)    #S
Definition at line 31 of file testSmooth2.cpp.
Typedef Documentation
Definition at line 48 of file testSmooth2.cpp.
Definition at line 49 of file testSmooth2.cpp.
Definition at line 47 of file testSmooth2.cpp.
Function Documentation
static int check_firmness ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  entities,
const std::vector< int > &  ids,
const char *  expected_value,
const char *  ent_type_str
) [static]
Definition at line 1455 of file testSmooth2.cpp.
References FBiGeom_getArrData, iBase_FAILURE, and iBase_SUCCESS.
    const int firmness_size = 4;
    std::vector< char > firmness( firmness_size * entities.size() );
    char* byte_ptr = &firmness[0];
    int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size;
    FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err );
    if( iBase_SUCCESS != err ) return err;
    bool all_correct = true;
    for( unsigned i = 0; i < entities.size(); ++i )
        if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false;
    if( !all_correct )
        std::cout << "ERROR: Expected \"" << expected_value << "\" firmness "
                  << "for all " << ent_type_str << "." << std::endl;
        std::cout << "ID  Actual  " << std::endl;
            std::cout << std::setw( 2 ) << ids[i] << "  " << std::string( &firmness[firmness_size * i], firmness_size )
                      << std::endl;
        return iBase_FAILURE;
    return iBase_SUCCESS;
static bool compare_box ( const double *  expected_min,
const double *  expected_max,
const double *  actual_min,
const double *  actual_max
) [static]
Definition at line 1244 of file testSmooth2.cpp.
    bool same   = true;
    double dtol = 1.0e-6;
    for( int i = 0; i < 3; ++i )
        if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] ||
            expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] )
            same = false;
    return same;
Test:
TSTTG construct Test
  • Check construction of geometry
static int count_num_with_tag ( FBiGeom_Instance  geom,
const std::vector< iBase_EntityHandle > &  ents,
iBase_TagHandle  tag
) [static]
Definition at line 1487 of file testSmooth2.cpp.
References FBiGeom_getData, FBiGeom_getTagSizeBytes, iBase_SUCCESS, and iBase_TAG_NOT_FOUND.
    int err, bytes;
    FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err );
    if( iBase_SUCCESS != err ) return -1;
    std::vector< char > data( bytes );
    int success_count = 0;
    for( size_t i = 0; i < ents.size(); ++i )
        char* ptr = &data[0];
        int junk1 = bytes, junk2;
        FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
        if( iBase_TAG_NOT_FOUND == err ) continue;
        ++success_count;
    return success_count;
void FBiGeom_dtor2 ( FBiGeom_Instance  instance,
int *  err
Definition at line 119 of file FBiGeom_MOAB.cpp.
References FBE_cast(), moab::FBEngine::get_gtt(), and iBase_SUCCESS.
Referenced by shutdown_test2().
    moab::FBEngine* fbe = FBE_cast( instance );
    if( fbe )
        moab::GeomTopoTool* gtt = fbe->get_gtt();
        if( gtt ) delete gtt;
        delete fbe;
    MBiGeom** mbigeom = reinterpret_cast< MBiGeom** >( &instance );
    if( *mbigeom ) delete *mbigeom;
    *err = iBase_SUCCESS;
void FBiGeom_newGeomFromMesh ( iMesh_Instance  mesh,
const char *  options,
FBiGeom_Instance *  geom,
int *  err,
int  options_len
Definition at line 94 of file FBiGeom_MOAB.cpp.
References geom, iBase_SUCCESS, moab::FBEngine::Init(), MBiMesh::mbImpl, and mesh.
    MBiMesh* mbimesh           = reinterpret_cast< MBiMesh* >( mesh );
    moab::Interface* mbi       = mbimesh->mbImpl;
    moab::EntityHandle rootSet = reinterpret_cast< moab::EntityHandle >( set );
    moab::GeomTopoTool* gtt    = new moab::GeomTopoTool( mbi, true, rootSet );
    bool smooth                = false;  // decide from options
    char smth[]                = "SMOOTH;";
    const char* res            = strstr( options, smth );
    if( res != NULL ) smooth = true;
    moab::FBEngine* fbe = new moab::FBEngine( mbi, gtt, smooth );
    MBiGeom** mbigeom   = reinterpret_cast< MBiGeom** >( geom );
    *mbigeom            = NULL;
    *mbigeom            = new MBiGeom( mbimesh, fbe );
    // will do now the initialization of the engine;
    // heavy duty computation
    fbe->Init();
bool gentityset_test ( FBiGeom_Instance  geom,
bool  ,
bool
Test:
TSTT gentity sets test (just implemented parts for now)
  • Check gentity sets
Test:
FBiGeom_MOAB topology adjacencies Test
  • Check topology information
  • Check adjacency
static int get_entities ( FBiGeom_Instance  geom,
int  entity_type,
std::vector< iBase_EntityHandle > &  entities_out,
iBase_TagHandle  id_tag = 0,
std::vector< int > *  ids_out = 0
) [static]
Definition at line 1423 of file testSmooth2.cpp.
References FBiGeom_getEntities, FBiGeom_getIntArrData, FBiGeom_getNumOfType, FBiGeom_getRootSet, iBase_SUCCESS, and id_tag.
    int err, num;
    iBase_EntitySetHandle root;
    FBiGeom_getRootSet( geom, &root, &err );
    FBiGeom_getNumOfType( geom, root, entity_type, &num, &err );
    entities_out.resize( num );
    int junk1                    = entities_out.size(), junk2;
    iBase_EntityHandle* junk_ptr = &entities_out[0];
    FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
    assert( num == junk1 && num == junk2 );
    if( !ids_out ) return iBase_SUCCESS;
    ids_out->resize( num );
    int* int_ptr = &( *ids_out )[0];
    FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
void handle_error_code ( const bool  result,
int &  number_failed,
int &  ,
int &  number_successful
Definition at line 156 of file testSmooth2.cpp.
    if( result )
        std::cout << "Success";
        number_successful++;
    else
        std::cout << "Failure";
        number_failed++;
int main ( int  argc,
char *  argv[]
Definition at line 170 of file testSmooth2.cpp.
References CHECK, FBiGeom_newGeomFromMesh(), filename, geom, geometry_evaluation_test(), handle_error_code(), iBase_SUCCESS, iMesh_createEntSet, iMesh_dtor, iMesh_load, iMesh_newMesh, mesh, normals_test(), number_tests, number_tests_failed, number_tests_successful, ray_test(), root_set, shutdown_test2(), smooth_test(), STRINGIFY, tags_test(), and topology_adjacencies_test().
    std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m";
    if( argc == 1 )
        std::cout << "Using default input file: " << filename << std::endl;
    else if( argc == 2 )
        filename = argv[1];
    else
        std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
        return 1;
    int err;
    int number_tests                 = 0;
    int number_tests_successful      = 0;
    int number_tests_not_implemented = 0;
    int number_tests_failed          = 0;
    // initialize the FBiGeom, in a different way
    iMesh_Instance mesh = NULL;
    FBiGeom_Instance geom;
    iMesh_newMesh( NULL, &mesh, &err, 0 );
        std::cerr << " Error code: " << err << "  At        : " << __FILE__ << ':' << __LINE__ << std::endl;
    iBase_EntitySetHandle root_set;
    iMesh_createEntSet( mesh, 0, &root_set, &err );
        std::cerr << " Error code: " << err << " failed to create a model set"
    iMesh_load( mesh, root_set, filename.c_str(), NULL, &err, filename.length(), 0 );
        std::cerr << " Error code: " << err << " failed load the file"
    std::string opts( "SMOOTH;" );
    // new constructor
    FBiGeom_newGeomFromMesh( mesh, root_set, opts.c_str(), &geom, &err, opts.length() );
    CHECK( "Interface initialization didn't work properly." );
    // Print out Header information
    std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
    // gLoad test
    bool result;
    std::cout << "   Smooth faceting load and initialization: \n";
    result = smooth_test( filename, geom );
    handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
    number_tests++;
    std::cout << "\n";
    // tags test
    std::cout << "   tags: ";
    result = tags_test( geom );
    number_tests++;
    std::cout << "\n";
     // gentitysets test
     std::cout << "   gentity sets: ";
     result = gentityset_test(geom, false, false);
     handle_error_code(result, number_tests_failed,
     number_tests_successful);
     number_tests++;
     std::cout << "\n";
    // topology adjacencies test
    std::cout << "   topology adjacencies: ";
    result = topology_adjacencies_test( geom );
    number_tests++;
    std::cout << "\n";
    // geometry evaluation test
    std::cout << "   geometry evaluation: \n";
    result = geometry_evaluation_test( geom );
    number_tests++;
    std::cout << "\n";
    // normals evaluation test
    std::cout << "   normals geometry evaluation: \n";
    result = normals_test( geom );
    number_tests++;
    std::cout << "\n";
    // ray tracing test
    std::cout << "   ray intersection test: \n";
    result = ray_test( geom );
    number_tests++;
    std::cout << "\n";
     // construct test
     std::cout << "   construct: ";
     result = construct_test(geom);
     number_tests++;
     std::cout << "\n";
     // primitives test
     std::cout << "   primitives: ";
     result = primitives_test(geom);
     number_tests++;
     std::cout << "\n";
     // transforms test
     std::cout << "   transforms: ";
     result = transforms_test(geom);
     number_tests++;
     std::cout << "\n";
     // booleans test
     std::cout << "   booleans: ";
     result = booleans_test(geom);
     number_tests++;
     std::cout << "\n";
     #if defined(HAVE_ACIS) && !defined(FORCE_OCC)
     std::cout << "   mesh size: ";
     result = mesh_size_test(geom);
     number_tests++;
     std::cout << "\n";
     // save entset test
     std::cout << "   save entset: ";
     result = save_entset_test(geom);
     number_tests++;
     std::cout << "\n";
     #endif
    // shutdown test
    std::cout << "   shutdown: ";
    std::string engine_opt;
    result = shutdown_test2( geom, engine_opt );
    number_tests++;
    std::cout << "\n";
    // shutdown imesh instance too
    iMesh_dtor( mesh, &err );
    CHECK( "shutdown imesh error" );
    // summary
    std::cout << "\nTSTT TEST SUMMARY: \n"
              << "   Number Tests:           " << number_tests << "\n"
              << "   Number Successful:      " << number_tests_successful << "\n"
              << "   Number Not Implemented: " << number_tests_not_implemented << "\n"
              << "   Number Failed:          " << number_tests_failed << "\n\n"
              << std::endl;
    return number_tests_failed;
static bool print_error ( const char *  desc,
int  err,
const char *  file,
int  line
) [static]
Definition at line 33 of file testSmooth2.cpp.
References buffer, and FBiGeom_getDescription.
    char buffer[1024];
    FBiGeom_getDescription( geom, buffer, sizeof( buffer ) );
    buffer[sizeof( buffer ) - 1] = '\0';
    std::cerr << "ERROR: " << desc << std::endl
              << "  Error code: " << err << std::endl
              << "  Error desc: " << buffer << std::endl
              << "  At        : " << file << ':' << line << std::endl;
    return false;  // must always return false or CHECK macro will break
bool ray_test ( FBiGeom_Instance  geom)
bool shutdown_test2 ( FBiGeom_Instance  geom,
std::string &  engine_opt
Definition at line 1611 of file testSmooth2.cpp.
References CHECK, and FBiGeom_dtor2().
    int err;
    // test shutdown2
    FBiGeom_dtor2( geom, &err );
    CHECK( "Interface destruction didn't work properly." );
    //   FBiGeom_newGeom(engine_opt.c_str(), &geom, &err, engine_opt.length());
    //   CHECK( "Interface re-construction didn't work properly." );
    //   FBiGeom_dtor(geom, &err);
    //   CHECK( "2nd Interface destruction didn't work properly." );
    return true;
bool smooth_test ( const std::string &  filename,
Test:
Load Mesh
  • Load a mesh file
bool tags_test ( FBiGeom_Instance  geom)
Test:
Test tag creating, reading, writing, deleting
  • Load a mesh file
Test:
TSTTG topology adjacencies Test
  • Check adjacency
