MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <iostream>#include <vector>#include <algorithm>#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/MeshTopoUtil.hpp"#include "moab/HalfFacetRep.hpp"#include "TestUtil.hpp"
Include dependency graph for adj_moab_test.cpp:Go to the source code of this file.
Functions | |
| void | handle_error_code (ErrorCode rv, int &number_failed, int &number_successful) |
| ErrorCode | ahf_test (const char *filename) |
| int | main (int argc, char *argv[]) |
Variables | |
| int | number_tests_successful = 0 |
| int | number_tests_failed = 0 |
Definition at line 48 of file adj_moab_test.cpp.
References moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), moab::Interface::create_meshset(), moab::HalfFacetRep::deinitialize(), moab::Range::end(), moab::error(), ErrorCode, moab::Interface::get_adjacencies(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Interface::get_connectivity(), moab::HalfFacetRep::get_down_adjacencies(), moab::Interface::get_entities_by_dimension(), moab::HalfFacetRep::get_neighbor_adjacencies(), moab::ParallelComm::get_pcomm(), moab::HalfFacetRep::get_up_adjacencies(), moab::HalfFacetRep::initialize(), moab::Interface::load_file(), MB_SUCCESS, MESHSET_SET, MPI_COMM_WORLD, read_options, moab::Range::size(), and moab::subtract().
Referenced by main().
Core moab;
Interface* mbImpl = &moab;
ParallelComm* pc = NULL;
MeshTopoUtil mtu( mbImpl );
ErrorCode error;
EntityHandle fileset;
error = mbImpl->create_meshset( moab::MESHSET_SET, fileset );CHECK_ERR( error );
#ifdef MOAB_HAVE_MPI
int procs = 1;
MPI_Comm_size( MPI_COMM_WORLD, &procs );
if( procs > 1 )
read_options = "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS;";
error = mbImpl->load_file( filename, &fileset, read_options.c_str() );CHECK_ERR( error );
else if( procs == 1 )
#endif
error = mbImpl->load_file( filename, &fileset );CHECK_ERR( error );
#endif
/*Create ranges for handles of explicit elements of the mixed mesh*/
Range verts, edges, faces, cells;
error = mbImpl->get_entities_by_dimension( fileset, 0, verts );CHECK_ERR( error );
error = mbImpl->get_entities_by_dimension( fileset, 1, edges );CHECK_ERR( error );
error = mbImpl->get_entities_by_dimension( fileset, 2, faces );CHECK_ERR( error );
error = mbImpl->get_entities_by_dimension( fileset, 3, cells );CHECK_ERR( error );
// Create an ahf instance
pc = ParallelComm::get_pcomm( mbImpl, 0 );
if( !pc ) pc = new moab::ParallelComm( &moab, MPI_COMM_WORLD );
#endif
HalfFacetRep ahf( &moab, pc, fileset );
// Call the initialize function which creates the maps for each dimension
error = ahf.initialize();CHECK_ERR( error );
std::cout << "Finished AHF initialization" << std::endl;
// Perform queries
std::vector< EntityHandle > adjents;
Range mbents, ahfents;
// 1D Queries //
// IQ1: For every vertex, obtain incident edges
if( edges.size() )
Range everts;
error = mbImpl->get_connectivity( edges, everts, true );CHECK_ERR( error );
for( Range::iterator i = everts.begin(); i != everts.end(); ++i )
adjents.clear();
error = ahf.get_up_adjacencies( *i, 1, adjents );CHECK_ERR( error );
mbents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 1, false, mbents );CHECK_ERR( error );
CHECK_EQUAL( mbents.size(), adjents.size() );
std::sort( adjents.begin(), adjents.end() );
std::copy( adjents.begin(), adjents.end(), range_inserter( ahfents ) );
mbents = subtract( mbents, ahfents );
CHECK( !mbents.size() );
// NQ1: For every edge, obtain neighbor edges
if( edges.size() )
for( Range::iterator i = edges.begin(); i != edges.end(); ++i )
adjents.clear();
error = ahf.get_neighbor_adjacencies( *i, adjents );CHECK_ERR( error );
mbents.clear();
error = mtu.get_bridge_adjacencies( *i, 0, 1, mbents );CHECK_ERR( error );
std::cout << "Finished 1D queries" << std::endl;
// 2D Queries
// IQ21: For every vertex, obtain incident faces
if( faces.size() )
Range fverts;
error = mbImpl->get_connectivity( faces, fverts, true );CHECK_ERR( error );
for( Range::iterator i = fverts.begin(); i != fverts.end(); ++i )
adjents.clear();
error = ahf.get_up_adjacencies( *i, 2, adjents );CHECK_ERR( error );
mbents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 2, false, mbents );CHECK_ERR( error );
// IQ22: For every edge, obtain incident faces
if( edges.size() && faces.size() )
adjents.clear();
mbents.clear();
// NQ2: For every face, obtain neighbor faces
if( faces.size() )
for( Range::iterator i = faces.begin(); i != faces.end(); ++i )
adjents.clear();
mbents.clear();
error = mtu.get_bridge_adjacencies( *i, 1, 2, mbents );CHECK_ERR( error );
// DQ 21: For every face, obtain its edges
adjents.clear();
error = ahf.get_down_adjacencies( *i, 1, adjents );CHECK_ERR( error );
mbents.clear();
std::cout << "Finished 2D queries: " << std::endl;
// 3D Queries
// IQ 31: For every vertex, obtain incident cells
if( cells.size() )
Range cverts;
error = mbImpl->get_connectivity( cells, cverts, true );CHECK_ERR( error );
for( Range::iterator i = cverts.begin(); i != cverts.end(); ++i )
adjents.clear();
error = ahf.get_up_adjacencies( *i, 3, adjents );CHECK_ERR( error );
mbents.clear();
error = mbImpl->get_adjacencies( &*i, 1, 3, false, mbents );CHECK_ERR( error );
// IQ 32: For every edge, obtain incident cells
if( edges.size() && cells.size() )
adjents.clear();
mbents.clear();
if( adjents.size() != mbents.size() )
// std::cout<<"ahf results = "<<std::endl;
// ahfents.print();
// std::cout<<"native results = "<<std::endl;
// mbents.print();
// IQ33: For every face, obtain incident cells
if( faces.size() && cells.size() )
adjents.clear();
mbents.clear();
// ahfents.print();
// mbents.print();
// NQ3: For every cell, obtain neighbor cells
if( cells.size() )
for( Range::iterator i = cells.begin(); i != cells.end(); ++i )
adjents.clear();
mbents.clear();
error = mtu.get_bridge_adjacencies( *i, 2, 3, mbents );CHECK_ERR( error );
// DQ 31: For every cell, obtain its edges
adjents.clear();
mbents.clear();
// DQ 32: For every cell, obtain its faces
adjents.clear();
error = ahf.get_down_adjacencies( *i, 2, adjents );CHECK_ERR( error );
mbents.clear();
std::cout << "Finished 3D queries" << std::endl;
error = ahf.deinitialize();CHECK_ERR( error );
return MB_SUCCESS;
| void handle_error_code | ( | ErrorCode | rv, |
| int & | number_failed, | ||
| int & | number_successful | ||
Definition at line 28 of file adj_moab_test.cpp.
References MB_SUCCESS, MPI_COMM_WORLD, and rank.
if( rv == MB_SUCCESS )
int rank = 0;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
if( rank == 0 ) std::cout << "Success";
#else
#endif
number_successful++;
else
std::cout << "Failure";
number_failed++;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 353 of file adj_moab_test.cpp.
References ahf_test(), ErrorCode, filename, handle_error_code(), MPI_COMM_WORLD, number_tests_failed, number_tests_successful, and rank.
MPI_Init( &argc, &argv );
int nprocs, rank;
MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
#endif
std::string filename;
#ifdef MOAB_HAVE_HDF5
#ifdef MOAB_HAVE_AHF
filename = TestDir + "unittest/spectral.h5m";
#else
filename = TestDir + "unittest/32hex_ef.h5m";
#endif
#else
filename = TestDir + "unittest/hexes_mixed.vtk";
#endif
if( argc == 1 )
if( rank == 0 ) std::cout << "Using default input file:" << filename << std::endl;
#else
#endif
else if( argc == 2 )
filename = std::string( argv[1] );
else
std::cerr << "Usage: " << argv[0] << " [filename]" << std::endl;
return 1;
ErrorCode result;
if( rank == 0 ) std::cout << " para_ahf_test: ";
#else
std::cout << "ahf_test:";
#endif
result = ahf_test( filename.c_str() );
handle_error_code( result, number_tests_failed, number_tests_successful );
std::cout << "\n";
MPI_Finalize();
#endif
return number_tests_failed;
| int number_tests_failed = 0 |
Definition at line 26 of file adj_moab_test.cpp.
Referenced by _run_test(), check_split(), main(), and split_quads_test().
| int number_tests_successful = 0 |
Definition at line 25 of file adj_moab_test.cpp.
Referenced by check_split(), main(), and split_quads_test().
