MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <Range.hpp>
Collaboration diagram for moab::Range:Classes | |
| class | const_iterator |
| a const iterator which iterates over an Range More... | |
| class | const_pair_iterator |
| class | const_reverse_iterator |
| a const reverse iterator which iterates over an Range More... | |
| class | pair_iterator |
| used to iterate over sub-ranges of a range More... | |
| struct | PairNode |
Public Types | |
| typedef const_iterator | iterator |
| typedef const_reverse_iterator | reverse_iterator |
| typedef EntityHandle | value_type |
Public Member Functions | |
| Range & | operator-= (const Range &rhs) |
| just like subtract, but as an operator | |
| Range () | |
| default constructor | |
| Range (const Range ©) | |
| copy constructor | |
| Range (EntityHandle val1, EntityHandle val2) | |
| another constructor that takes an initial range | |
| Range & | operator= (const Range ©) |
| operator= | |
| ~Range () | |
| destructor | |
| const_iterator | begin () const |
| return the beginning const iterator of this range | |
| const_reverse_iterator | rbegin () const |
| return the beginning const reverse iterator of this range | |
| const_iterator | end () const |
| return the ending const iterator for this range | |
| const_reverse_iterator | rend () const |
| return the ending const reverse iterator for this range | |
| size_t | size () const |
| return the number of values this Ranges represents | |
| size_t | psize () const |
| return the number of range pairs in the list | |
| bool | empty () const |
| iterator | insert (iterator hint, EntityHandle val) |
| iterator | insert (EntityHandle val) |
| insert an item into the list and return the iterator for the inserted item | |
| iterator | insert (iterator hint, EntityHandle first, EntityHandle last) |
| iterator | insert (EntityHandle val1, EntityHandle val2) |
| template<typename T > | |
| iterator | insert_list (T begin_iter, T end_iter) |
| template<class T > | |
| iterator | insert (typename T::const_iterator begin_iter, typename T::const_iterator end_iter) |
| iterator | insert (const T *begin_iter, const T *end_iter) |
| iterator | erase (iterator iter) |
| remove an item from this list and return an iterator to the next item | |
| iterator | erase (iterator iter1, iterator iter2) |
| remove a range of items from the list | |
| iterator | erase (EntityHandle val) |
| erases a value from this container | |
| const EntityHandle & | front () const |
| get first entity in range | |
| const EntityHandle & | back () const |
| get last entity in range | |
| EntityHandle | pop_front () |
| remove first entity from range | |
| EntityHandle | pop_back () |
| remove last entity from range | |
| const_iterator | find (EntityHandle val) const |
| find an item int the list and return an iterator at that value | |
| const_iterator | lower_bound (EntityHandle val) const |
| const_iterator | upper_bound (EntityHandle val) const |
| const_iterator | lower_bound (EntityType type) const |
| const_iterator | upper_bound (EntityType type) const |
| std::pair< const_iterator, const_iterator > | equal_range (EntityType type) const |
| const_iterator | lower_bound (EntityType type, const_iterator first) const |
| const_iterator | upper_bound (EntityType type, const_iterator first) const |
| bool | all_of_type (EntityType type) const |
| bool | all_of_dimension (int dimension) const |
| unsigned | num_of_type (EntityType type) const |
| unsigned | num_of_dimension (int dim) const |
| void | clear () |
| clears the contents of the list | |
| const std::string | str_rep (const char *indent_prefix=NULL) const |
| for debugging | |
| void | print (const char *indent_prefix=NULL) const |
| void | print (std::ostream &s, const char *indent_prefix=NULL) const |
| unsigned long | get_memory_use () const |
| double | compactness () const |
| void | insert (Range::const_iterator begin, Range::const_iterator end) |
| void | merge (const Range &range) |
| merges this Range with another range | |
| void | merge (Range::const_iterator beginr, Range::const_iterator endr) |
| merge a subset of some other range | |
| void | swap (Range &range) |
| swap the contents of this range with another one | |
| void | sanity_check () const |
| check for internal consistency | |
| bool | contains (const Range &other) const |
| Check if this range is a non-strict superset of some other range. | |
| Range | subset_by_type (EntityType t) const |
| return a subset of this range, by type | |
| Range | subset_by_dimension (int dim) const |
| return a subset of this range, by dimension | |
| EntityHandle | operator[] (EntityID index) const |
| int | index (EntityHandle handle) const |
| pair_iterator | pair_begin () |
| pair_iterator | pair_end () |
| const_pair_iterator | const_pair_begin () const |
| const_pair_iterator | const_pair_end () const |
| const_pair_iterator | pair_begin () const |
| const_pair_iterator | pair_end () const |
| template<typename Iterator > | |
| Range::iterator | insert_list (Iterator begin_iter, Iterator end_iter) |
Static Public Member Functions | |
| static const_iterator | lower_bound (const_iterator first, const_iterator last, EntityHandle val) |
| return an iterator to the first value >= val | |
| static const_iterator | upper_bound (const_iterator first, const_iterator last, EntityHandle val) |
Protected Member Functions | |
| void | delete_pair_node (PairNode *dead_node) |
| if dead_node is not mHead, remove it from the list and free it's memory. | |
Protected Attributes | |
| PairNode | mHead |
Friends | |
| Range | intersect (const Range &, const Range &) |
| intersect two ranges, placing the results in the return range | |
| Range | subtract (const Range &, const Range &) |
| subtract range2 from this, placing the results in the return range | |
the class Range
| typedef const_iterator moab::Range::iterator |
| typedef EntityHandle moab::Range::value_type |
| moab::Range::Range | ( | ) | [inline] |
| moab::Range::Range | ( | const Range & | copy | ) |
copy constructor
Definition at line 179 of file Range.cpp.
References alloc_pair(), mHead, moab::Range::PairNode::mNext, and moab::Range::PairNode::mPrev.
// set the head node to point to itself
mHead.mNext = mHead.mPrev = &mHead;
mHead.first = mHead.second = 0;
const PairNode* copy_node = copy.mHead.mNext;
PairNode* new_node = &mHead;
for( ; copy_node != &( copy.mHead ); copy_node = copy_node->mNext )
PairNode* tmp_node = alloc_pair( new_node->mNext, new_node, copy_node->first, copy_node->second );
new_node->mNext->mPrev = tmp_node;
new_node->mNext = tmp_node;
new_node = tmp_node;
| moab::Range::Range | ( | EntityHandle | val1, |
| EntityHandle | val2 | ||
Definition at line 172 of file Range.cpp.
| moab::Range::~Range | ( | ) | [inline] |
| bool moab::Range::all_of_dimension | ( | int | dimension | ) | const |
True if all entities in range are of passed dimension (also true if range is empty)
Definition at line 884 of file Range.cpp.
References back(), moab::CN::Dimension(), empty(), front(), and moab::TYPE_FROM_HANDLE().
Referenced by moab::OrientedBoxTreeTool::build(), check_parallel_read(), moab::Skinner::find_skin(), moab::Skinner::find_skin_vertices(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::Core::get_vertices(), and mb_mesh_sets_test().
return empty() || ( CN::Dimension( TYPE_FROM_HANDLE( front() ) ) == dimension &&
CN::Dimension( TYPE_FROM_HANDLE( back() ) ) == dimension );
| bool moab::Range::all_of_type | ( | EntityType | type | ) | const |
True if all entities in range are of passed type (also true if range is empty)
Definition at line 879 of file Range.cpp.
References back(), empty(), front(), and moab::TYPE_FROM_HANDLE().
Referenced by check_ho_elements(), moab::WriteNCDF::gather_mesh_information(), generate_random_points(), moab::ReorderTool::handle_order_from_sets_and_adj(), iMOAB_GetBlockInfo(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::OrientedBoxTreeTool::join_trees(), main(), mb_mesh_sets_test(), mb_skin_surface_test_common(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), read_sets(), recursive_check_tree(), test_read_set_contents(), test_read_sets_common(), and moab::WriteNCDF::write_elementblocks().
return empty() || ( TYPE_FROM_HANDLE( front() ) == type && TYPE_FROM_HANDLE( back() ) == type );
| const EntityHandle & moab::Range::back | ( | ) | const [inline] |
Definition at line 912 of file Range.hpp.
References mHead, and moab::Range::PairNode::mPrev.
Referenced by all_of_dimension(), all_of_type(), check_parallel_read(), erase_test(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadHDF5::get_partition(), make_mesh(), mb_skin_curve_test_common(), mb_skin_poly_test(), mb_skin_surface_test_common(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), moab::AdaptiveKDTree::merge_leaf(), moab::BSPTree::merge_leaf(), pop_back(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_sparse_tag_indices(), moab::GeomTopoTool::resize_rootSets(), subset_by_dimension_test(), test_get_by_tag_value_dense(), test_get_ents_with_default_value(), test_list_set_with_stale_handles(), test_pack_elements(), test_pack_higher_order(), test_pack_sets_of_sets(), test_ranged_set_with_stale_handles(), test_read_adjacencies(), test_read_material_on_nodes(), and test_read_two_sets_elems().
| Range::const_iterator moab::Range::begin | ( | ) | const [inline] |
Definition at line 860 of file Range.hpp.
References mHead, and moab::Range::PairNode::mNext.
Referenced by moab::GeomTopoTool::A_is_in_B(), add_dead_elems_to_impl_compl(), moab::SpatialLocator::add_elems(), add_field_value(), moab::ParallelComm::add_verts(), adj_perf(), ahf_test(), moab::SharedSetData::append_local_handles(), moab::SmoothFace::area(), moab::IntxAreaUtils::area_on_sphere(), moab::WriteSTL::ascii_write_triangles(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::WriteUtil::assign_ids(), moab::DualTool::atomic_pillow(), moab::WriteSTL::binary_write_triangles(), moab::FBEngine::boundary_mesh_edges_on_face(), moab::FBEngine::boundary_nodes_on_face(), moab::box_from_axes(), moab::MeshGeneration::BrickInstance(), SphereDecomp::build_hexes(), moab::BVHTree::build_tree(), build_tree(), moab::AxisBox::calculate(), moab::FBEngine::chain_able_edge(), moab::FBEngine::chain_two_edges(), moab::Core::check_adjacencies(), check_answers(), check_big_meshset(), moab::ParallelComm::check_clean_iface(), moab::DualTool::check_dual_adjs(), moab::DualTool::check_dual_equiv_edges(), moab::AEntityFactory::check_equiv_entities(), moab::NCHelperMPAS::check_existing_mesh(), check_handle_tag(), check_handle_tag_type(), check_ho_elements(), check_identical_mesh(), check_mesh_is_tet(), check_meshset_common(), moab::GeomTopoTool::check_model(), check_order_by_sets_and_adj(), check_parallel_read(), moab::ParallelComm::check_sent_ents(), check_set_contents(), check_shared_ents(), check_tree(), moab::Skinner::classify_2d_boundary(), moab::Intx2Mesh::clean(), moab::ParallelComm::clean_shared_tags(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), moab::Core::clear_meshset(), closedsurface_uref_hirec_convergence_study(), closest_point_in_triangles(), moab::OrientedBoxTreeTool::closest_to_location(), moab::closest_to_triangles(), moab::HalfFacetRep::collect_and_compare(), moab::MeshTopoUtil::common_entity(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), compare(), compare_set_contents(), compare_sets(), moab::HiReconstruction::compute_average_vertex_normals_surf(), moab::HiReconstruction::compute_average_vertex_tangents_curve(), moab::SmoothFace::compute_control_points_on_edges(), moab::NestedRefine::compute_coordinates(), compute_dual_mesh(), moab::SmoothFace::compute_internal_control_points_on_facets(), compute_lagrange_mesh_on_sphere(), SphereDecomp::compute_nodes(), moab::ParCommGraph::compute_partition(), moab::SmoothFace::compute_tangents_for_each_edge(), compute_tracer_case1(), compute_velocity_case1(), moab::TempestRemapper::ComputeOverlapMesh(), moab::DualTool::construct_dual(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::BVHTree::construct_element_vec(), moab::DualTool::construct_hex_dual(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::construct_hm_3D(), moab::DualTool::construct_hp_parent_child(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::construct_vertex_ranges(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::ReadHDF5::convert_range_to_handle(), moab::HigherOrderFactory::convert_sequence(), moab::SpectralMeshTool::convert_to_coarse(), moab::copy_sorted_file_ids(), moab::WriteHDF5::count_set_size(), EntityCount::create_adjacencies(), moab::ReadCCMIO::create_cell_from_faces(), moab::AEntityFactory::create_explicit_adjs(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::NestedRefine::create_hm_storage_single_level(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_lagr_mesh(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperMPAS::create_local_vertices(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ReadGmsh::create_sets(), IntxUtilsCSLAM::create_span_quads(), moab::SpectralMeshTool::create_spectral_elems(), moab::AEntityFactory::create_vert_elem_adjacencies(), vtkMoabReader::CreateSubBlocks(), moab::Intx2Mesh::createTags(), cube_tri_curve_coincidence_test(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::DualTool::delete_dual_entities(), moab::ParallelComm::delete_entities(), delete_existing_tree(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::HalfFacetRep::determine_border_vertices(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_incident_halffaces(), moab::HalfFacetRep::determine_incident_halfverts(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), moab::Intx2Mesh::DetermineOrderedNeighbors(), do_file(), do_linear_test(), do_ray_fire_test(), do_test_mode(), dot_children(), dot_contained(), dot_nodes(), dot_write_id_nodes(), moab::SmoothFace::DumpModelControlPoints(), moab::GeomTopoTool::duplicate_model(), moab::IntxUtils::enforce_convexity(), equal_range(), erase_test(), moab::NestedRefine::estimate_hm_storage(), moab::Core::estimated_memory_use(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::DualTool::face_shrink(), smoab::faceIdsPerCell(), FBiGeom_getEnt2ndAdj(), smoab::DataSetConverter::fill(), fill_coord_on_edges(), moab::ParallelComm::filter_pstatus(), moab::Tree::find_all_trees(), find_block(), moab::ScdInterface::find_boxes(), find_coincident_edges(), find_coincident_elements(), find_coincident_nodes(), moab::ElemEvaluator::find_containing_entity(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::VarLenSparseTag::find_entities_with_value(), moab::SparseTag::find_entities_with_value(), moab::ParallelComm::find_existing_entity(), moab::Skinner::find_geometric_skin(), moab::Skinner::find_inferred_edges(), moab::find_map_values(), moab::HalfFacetRep::find_matching_halfedge(), moab::HalfFacetRep::find_matching_halfface(), moab::HalfFacetRep::find_matching_implicit_edge_in_cell(), moab::MergeMesh::find_merged_to(), moab::BVHTree::find_point(), moab::ReadHDF5::find_sets_containing(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::find_tag_values(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::FBEngine::find_vertex_set_for_node(), moab::GeomQueryTool::find_volume_slow(), smoab::Interface::findDetachedEntities(), smoab::Interface::findEntitiesWithDimension(), smoab::Interface::findEntitiesWithMultipleParents(), smoab::Interface::findEntitiesWithTag(), smoab::Interface::findEntityRootParents(), moab::Intx2Mesh::FindMaxEdgesInSet(), smoab::ExtractShell::findSkins(), moab::IntxUtils::fix_degenerate_quads(), fix_surface_senses(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_ents(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), moab::DualTool::fs_get_quad_loops(), moab::DualTool::fs_get_quads(), moab::DualTool::fsr_get_fourth_quad(), moab::ParallelComm::gather_data(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), gather_related_test(), gather_set_stats(), moab::GeomTopoTool::generate_implicit_complement(), generate_random_points(), moab::TempestRemapper::GenerateMeshMetadata(), moab::GeomTopoTool::geometrize_surface_set(), geometry_evaluation_test(), moab::ScdBox::get_adj_edge_or_face(), moab::Core::get_adjacencies(), moab::get_adjacencies_intersection(), moab::get_adjacencies_union(), moab::MeshTopoUtil::get_average_position(), get_barycenters(), get_boundary_entities(), get_by_all_types_and_tag(), get_children_by_dimension(), moab::NestedRefine::get_connectivity(), moab::Core::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::GeomTopoTool::get_ct_children_by_dimension(), moab::SparseTag::get_data(), moab::VarLenSparseTag::get_data(), get_departure_grid(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::WriteUtil::get_element_connect(), moab::MeshSet::get_entities(), moab::ReorderTool::get_entities(), moab::TypeSequenceManager::get_entities(), moab::MeshSet::get_entities_by_dimension(), moab::Core::get_entities_by_handle(), moab::MeshSet::get_entities_by_type(), get_ents(), get_ents_from_geometric_sets(), get_ghost_entities(), moab::ParallelComm::get_ghosted_entities(), moab::Coupler::get_gl_points_on_elements(), get_gnomonic_plane(), moab::DualTool::get_graphics_points(), moab::HalfFacetRep::get_half_facet_in_comp(), moab::ParallelComm::get_iface_entities(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), moab::ParallelComm::get_interface_sets(), get_intersection_weights(), moab::NestedRefine::get_lid_inci_child(), get_linear_reconstruction(), moab::ParallelComm::get_local_handles(), moab::MeshTopoUtil::get_manifold(), get_max_volume(), moab::AEntityFactory::get_memory_use(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::ReorderTool::get_new_handles(), moab::MeshSet::get_non_set_entities(), moab::HiReconstruction::get_normals_surf(), moab::DualTool::get_opposite_verts(), get_owner_handles(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_part_neighbor_ids(), moab::ReadHDF5::get_partition(), moab::ParallelComm::get_pstatus_entities(), moab::ParallelComm::get_remote_handles(), moab::ReorderTool::get_reordered_handles(), moab::ReadABAQUS::get_set_by_name(), moab::WriteCCMIO::get_sets(), moab::ParallelComm::get_sharing_data(), moab::HalfFacetRep::get_sibling_map(), moab::WriteNCDF::get_sideset_elems(), get_signed_volume(), moab::WriteHDF5::get_tag_data_length(), moab::BitTag::get_tagged(), moab::get_tagged(), moab::DenseTag::get_tagged_entities(), moab::ReadHDF5::get_tagged_entities(), moab::HiReconstruction::get_tangents_curve(), moab::MeshSetSequence::get_type(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::Core::get_vertex_coordinates(), moab::NestedRefine::get_vertex_duplicates(), smoab::getAllCells(), moab::IntxUtils::global_gnomonic_projection(), moab::ReorderTool::handle_order_from_int_tag(), hcFilter(), identify_set(), iMesh_createStructuredMesh(), iMesh_getEntArr2ndAdj(), iMesh_getEntsByTagsRec(), iMesh_getEntSetsByTagsRec(), iMeshP_getAdjEntities(), iMOAB_GetElementOwnership(), iMOAB_GetMeshInfo(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), iMOAB_SetDoubleTagStorageWithGid(), ZoltanPartitioner::include_closure(), index(), moab::SmoothFace::init_gradient(), moab::HalfFacetRep::init_surface(), moab::HalfFacetRep::init_volume(), moab::Skinner::initialize(), moab::WriteNCDF::initialize_exodus_file(), insert_hint_test(), moab::ReadHDF5::insert_in_id_map(), insert_list(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::DualTool::is_blind(), moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), moab::OrientedBoxTreeTool::join_trees(), laplacianFilter(), smoab::detail::LinearCellConnectivity::LinearCellConnectivity(), moab::DualTool::list_entities(), moab::Core::list_entities(), moab::ParallelComm::list_entities(), moab::ReadParallel::load_file(), moab::ReadABAQUS::load_file(), moab::ReadSms::load_file_impl(), moab::WriteGMV::local_write_mesh(), lower_bound(), main(), make_tris_from_quads(), manufacture_lagrange_mesh_on_sphere(), moab::WriteDamsel::map_sparse_tags(), match_tri_edges_w_curve(), match_vertices_and_elements(), mb_adjacencies_create_delete_test(), mb_adjacent_vertex_test(), mb_bar_connectivity_test(), mb_bit_tags_test(), mb_common_tag_test(), mb_hex_connectivity_test(), mb_mesh_set_appends(), mb_mesh_set_list_replace_test(), mb_mesh_set_parent_child_test(), mb_mesh_set_set_replace_test(), mb_mesh_sets_test(), mb_quad_connectivity_test(), mb_range_seq_intersect_test(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_pyramids(), mb_skin_higher_order_regions_common(), mb_skin_subset_common(), mb_skin_surface_test_common(), mb_skin_verts_common(), mb_split_test(), mb_tet_connectivity_test(), mb_topo_util_test(), mb_tri_connectivity_test(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), moab::FBEngine::measure(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), merge(), moab::AEntityFactory::merge_adjust_adjacencies(), merge_duplicate_vertices(), moab::MergeMesh::merge_higher_dimensions(), merge_input_surfs(), merge_test(), moab::MergeMesh::merge_using_integer_tag(), min_edge_length(), smoab::detail::MixedCellConnectivity::MixedCellConnectivity(), smoab::detail::ReadSparseTag::multiSetRead(), moab::Coupler::nat_param(), moab::DualTool::next_loop_vertex(), normalize_elems(), normals_test(), nothing_but_type(), obbstat_write(), obbvis_create(), operator-=(), operator[](), moab::DualTool::order_chord(), orient_faces_outward(), moab::GeomTopoTool::other_entity(), overlap_test_measure_area(), overlap_test_ray_fire(), overlap_test_surface_sense(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_tags(), pack_unpack_noremoteh(), parallel_create_mesh(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::GeomQueryTool::point_in_volume_slow(), moab::IntxAreaUtils::positive_orientation(), moab::AdaptiveKDTree::print(), moab::Core::print(), moab::TreeNodePrinter::print_contents(), print_mbrange(), print_output(), print_partitioned_entities(), moab::WriteHDF5Parallel::print_set_sharing_data(), print_stats(), moab::HalfFacetRep::print_tags(), moab::print_type_sets(), smoab::Interface::printRange(), moab::ReadDamsel::process_entity_tags(), quads_to_tris(), query_elem_to_vert(), query_elem_to_vert_direct(), query_struct_elem_to_vert(), query_vert_to_elem(), query_vert_to_elem_direct(), smoab::RangeToVector(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::OrientedBoxTreeTool::ray_intersect_triangles(), read_cylcube_groups_test(), moab::ReadHDF5VarLen::read_data(), moab::ReadHDF5::read_dense_tag(), McnpData::read_mcnpfile(), moab::ReadHDF5::read_node_adj_elems(), moab::Tqdcfr::read_nodes(), moab::ReadNCDF::read_nodesets(), moab::ReadHDF5VarLen::read_offsets(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_set_ids_recursive(), read_sets(), moab::ReadHDF5::read_sets(), moab::ReadNCDF::read_sidesets(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag_values_partial(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), moab::MeshSetSequence::recursive_get_sets(), moab::FBEngine::redistribute_boundary_edges_to_faces(), moab::ParallelComm::reduce_tags(), moab::MeshRefiner::refine(), regression_insert_set_1(), moab::VarLenSparseTag::remove_data(), moab::SparseTag::remove_data(), remove_empty_cgm_surfs_and_vols(), remove_entities_from_sets(), remove_from_back(), remove_from_vector(), moab::IntxUtils::remove_padded_vertices(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::ReorderTool::reorder_entities(), moab::NestedRefine::reorder_indices(), moab::ReorderTool::reorder_tag_data(), replace_faceted_cgm_surfs(), report_sets(), moab::HalfFacetRep::resize_hf_maps(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), moab::DualTool::rev_atomic_pillow(), moab::DualTool::rev_face_shrink(), moab::IntxUtils::ScaleToRadius(), moab::ScdBox::ScdBox(), moab::BitPage::search(), moab::ParCommGraph::send_tag_values(), moab::FBEngine::separate(), moab::GeomTopoTool::separate_by_dimension(), moab::Core::set_coords(), moab::SparseTag::set_data(), moab::VarLenSparseTag::set_data(), set_density(), moab::ReadHDF5Dataset::set_file_ids(), moab::HalfFacetRep::set_sibling_map(), moab::ParallelComm::settle_intersection_points(), setup_mesh(), moab::Core::side_element(), skin_common(), moab::FBEngine::smooth_new_intx_points(), moab::AdaptiveKDTree::sphere_intersect_triangles(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_boundary(), moab::FBEngine::split_edge_at_mesh_node(), moab::MeshTopoUtil::split_entities_manifold(), moab::MeshTopoUtil::split_entity_nonmanifold(), moab::FBEngine::split_internal_edge(), moab::ParCommGraph::split_owned_range(), moab::FBEngine::split_quads(), moab::FBEngine::split_surface_with_direction(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), moab::ReadHDF5::store_file_ids(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), subset_by_dimension(), moab::subtract(), summarize_cell_volume_change(), tag_elements(), moab::ParallelComm::tag_iface_entities(), moab::ScdInterface::tag_shared_vertices(), tag_time(), tag_vertices(), moab::ParallelMergeMesh::TagSharedElements(), test_add_entities(), test_adjacencies(), test_assign_global_ids(), test_bc_sets(), test_bit_tag_big(), test_boolean(), test_check_meshsets(), test_clear_bit(), test_closedsurface_mesh(), test_coords_connect_iterate(), test_delete_entities(), test_delete_obb_tree(), test_delete_tag_data(), test_element(), test_elements(), test_elements_on_several_procs(), test_file_set(), test_filter_pstatus(), test_gather_sets_ranged(), test_geometric_sets(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_entity_tags(), test_get_ents_with_default_value(), test_get_set(), test_get_set_bit(), test_get_set_variable_length(), test_ghost_elements(), test_ghost_tag_exchange(), test_global_value_common(), test_ho_elements(), test_iterates(), test_linear_hex(), test_linear_quad(), test_linear_reconstruction(), test_list_set_with_stale_handles(), test_measure_area(), test_mesh(), test_moab_v3_poly_format(), test_pack_bit_tag_data(), test_pack_poly(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), test_quadratic_hex(), test_ranged_set_with_stale_handles(), test_ray_fire(), test_read_bc_sets(), test_read_double_tag(), test_read_handle_tag(), test_read_handle_tag_common(), test_read_int_tag(), test_read_opaque_tag(), test_read_real_tag(), test_read_set_contents(), test_read_sets_common(), test_read_side(), test_read_sides(), test_read_tags(), test_read_vertices(), test_remove_entities(), test_restore_obb_trees(), test_root_sets_resize(), test_scd_invalid(), test_sequences_after_ghosting(), test_set_flags(), test_sets_fileids(), test_spectral_hex(), test_spectral_quad(), test_surface_sense(), test_tag_iterate_common(), test_tag_iterate_invalid(), test_unitcircle(), test_unitsphere(), test_var_length_big_data(), test_var_length_data_common(), test_var_length_handle_tag(), test_var_length_parallel(), test_write_different_element_types(), test_write_shared_sets(), TestErrorHandling_4(), time_forward_eval(), time_integrate(), time_jacobian(), time_reverse_eval(), moab::DualTool::traverse_hyperplane(), umr_perf_test(), moab::unite(), moab::ParallelComm::unpack_sets(), moab::BoundBox::update(), moab::ReadNCDF::update(), update_density(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::NestedRefine::update_local_ahf(), moab::ParallelComm::update_remote_data(), moab::ReorderTool::update_set_contents(), moab::NestedRefine::update_special_tags(), moab::Intx2MeshOnSphere::update_tracer_data(), moab::NestedRefine::update_tracking_verts(), upper_bound(), verdict_test1(), TreeValidator::visit(), moab::RayIntersectSets::visit(), moab::TreeNodePrinter::visit(), moab::WriteHDF5::write_adjacencies(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteVtk::write_bit_tag(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteHDF5::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteGmsh::write_file(), moab::WriteAns::write_file(), moab::WriteTemplate::write_file(), moab::WriteSLAC::write_file(), moab::WriteDamsel::write_file(), moab::WriteNCDF::write_file(), moab::Core::write_file(), write_file(), moab::WriteNCDF::write_global_node_order_map(), moab::WriteTemplate::write_matsets(), moab::WriteSLAC::write_matsets(), moab::WriteVtk::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::WriteHDF5::write_nodes(), moab::ScdNCWriteHelper::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteCCMIO::write_problem_description(), moab::WriteHDF5::write_set_data(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_ids(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_tag_values(), write_tree_blocks(), moab::WriteHDF5::write_var_len_data(), moab::WriteHDF5::write_var_len_indices(), moab::IODebugTrack::~IODebugTrack(), and moab::Tqdcfr::~Tqdcfr().
| void moab::Range::clear | ( | ) |
Definition at line 197 of file Range.cpp.
References free_pair(), mHead, moab::Range::PairNode::mNext, and moab::Range::PairNode::mPrev.
Referenced by adj_perf(), ahf_test(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), moab::ReadUtil::assign_ids(), moab::OrientedBoxTreeTool::build_sets(), check_children(), check_identical_mesh(), check_num_verts(), check_tree(), check_valid_connectivity(), moab::Skinner::classify_2d_boundary(), moab::TempestRemapper::clear(), moab::OrientedBoxTreeTool::closest_to_location(), coincident_counts(), compare(), moab::MeshTopoUtil::construct_aentities(), moab::DualTool::construct_hp_parent_child(), moab::GeomTopoTool::construct_vertex_ranges(), contains_test(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::WriteHDF5::count_set_size(), moab::ReadGmsh::create_geometric_topology(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_int_ents(), moab::AEntityFactory::create_vert_elem_adjacencies(), moab::Core::create_vertices(), vtkMoabReader::CreateSubBlocks(), delete_existing_tree(), do_file(), do_kdtree_test(), do_test_mode(), dot_get_sets(), erase_test(), moab::WriteHDF5Parallel::exchange_file_ids(), FBiGeom_getArrAdj(), FBiGeom_getEnt2ndAdj(), moab::ParallelComm::filter_pstatus(), moab::AdaptiveKDTree::find_close_triangle(), moab::MergeMesh::find_merged_to(), moab::ReadHDF5::find_sets_containing(), moab::DualTool::fs_get_quads(), moab::DualTool::fsr_get_fourth_quad(), moab::WriteHDF5Parallel::gather_interface_meshes(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::ReadUtil::gather_related_ents(), get_adjacent_elems(), moab::MeshTopoUtil::get_bridge_adjacencies(), get_by_all_types_and_tag(), get_children_by_dimension(), EntityCount::get_counts(), moab::GeomTopoTool::get_ct_children_by_dimension(), get_entities(), get_expected_ghosts(), moab::DualTool::get_graphics_points(), moab::Coupler::get_matching_entities(), get_max_volume(), moab::DualTool::get_opposite_verts(), moab::ParallelComm::get_sent_ents(), moab::ReadABAQUS::get_set_elements(), moab::ReadABAQUS::get_set_nodes(), moab::WriteCCMIO::get_sets(), moab::ParallelComm::get_shared_entities(), moab::SharedSetData::get_shared_sets(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::WriteHDF5::get_tag_data_length(), moab::FBEngine::get_vert_edges(), moab::WriteHDF5::get_write_entities(), moab::FBEngine::getAdjacentEntities(), moab::FBEngine::getEgVtxSense(), moab::FBEngine::getEntities(), moab::TempestRemapper::GetOverlapAugmentedEntities(), heappermute(), iMOAB_UpdateMeshInfo(), ZoltanPartitioner::include_closure(), moab::SmoothFace::init_gradient(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), intersect_test(), moab::ReadCGNS::load_file(), moab::ReadGmsh::load_file(), moab::ReadParallel::load_file(), moab::ReadSms::load_file_impl(), moab::ReadHDF5::load_file_impl(), moab::WriteGMV::local_write_mesh(), main(), make_mesh(), make_tris_from_quads(), mb_memory_use_test(), mb_mesh_set_flag_test(), mb_mesh_set_list_replace_test(), mb_mesh_set_set_replace_test(), mb_mesh_sets_test(), mb_poly_adjacency_test(), mb_poly_adjacency_test2(), mb_range_seq_intersect_test(), mb_skin_curve_test_common(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_regions_common(), mb_skin_poly_test(), mb_skin_subset_common(), mb_skin_verts_common(), mb_split_test(), mb_topo_util_test(), mb_type_is_maxtype_test(), mb_write_mesh_test(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), merge_2D_elem(), merge_3D_elem(), moab::MergeMesh::merge_higher_dimensions(), moab::AdaptiveKDTree::merge_leaf(), moab::BSPTree::merge_leaf(), merge_test(), merge_with_tag_test(), moab::DualTool::next_loop_vertex(), operator=(), moab::ParallelComm::pack_entities(), pack_unpack_noremoteh(), parallel_create_mesh(), ZoltanPartitioner::partition_owned_cells(), moab::GeomQueryTool::point_in_volume_slow(), moab::ParallelMergeMesh::PopulateMySkinEnts(), moab::Core::print(), print_file_stats(), print_output(), print_partitioned_entities(), query_vert_to_elem_direct(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::OrientedBoxTreeTool::ray_intersect_triangles(), moab::ReadABAQUS::read_element_set(), DeformMeshRemap::read_file(), McnpData::read_mcnpfile(), moab::ReadABAQUS::read_node_set(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sparse_tag_indices(), regression_mmiller_8_2010(), regression_tag_on_nonexistent_entity(), remove_entities_from_sets(), report_nsets(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::FBEngine::separate(), moab::ReadHDF5Dataset::set_all_file_ids(), skin_common(), moab::OrientedBoxTreeTool::sphere_intersect_triangles(), moab::split_box(), moab::MeshTopoUtil::split_entities_manifold(), moab::FBEngine::split_surface(), moab::MeshTopoUtil::star_next_entity(), subtract_test(), swap_test(), tag_depth(), tag_elements(), moab::ParallelComm::tag_iface_entities(), tag_time(), tag_vertices(), test_add_entities(), test_adjacencies(), test_bc_sets(), test_build_tree_bisect_triangles(), test_check_meshsets(), test_closest_triangle(), test_elements_on_several_procs(), test_gather_sets_ranged(), test_geometric_sets(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_ents_with_default_value(), test_ghost_elements(), test_ghost_tag_exchange(), test_pack_bit_tag_data(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), test_ray_intersect_triangles(), test_read_adjacencies(), test_read_bc_sets(), test_read_set_sets(), test_read_sides(), test_remove_entities(), test_restore_obb_trees(), test_set_flags(), test_shared_sets(), test_sphere_intersect_triangles(), test_var_length_big_data(), test_var_length_data_common(), test_var_length_handle_tag(), test_var_length_parallel(), test_write_unbalanced(), moab::DualTool::traverse_hyperplane(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_special_tags(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteTemplate::write_file(), moab::WriteSLAC::write_file(), moab::WriteNCDF::write_file(), moab::WriteHDF5::write_finished(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), write_tree_blocks(), and ~Range().
| double moab::Range::compactness | ( | ) | const [inline] |
Definition at line 952 of file Range.hpp.
References get_memory_use(), and size().
Referenced by moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), and moab::ParallelComm::send_entities().
unsigned int num_ents = size();
return ( num_ents ? ( (double)get_memory_use() / (double)( num_ents * sizeof( EntityHandle ) ) ) : -1 );
| const_pair_iterator moab::Range::const_pair_begin | ( | ) | const [inline] |
Definition at line 748 of file Range.hpp.
Referenced by moab::WriteHDF5::assign_ids(), moab::RangeSetIterator::build_pair_vec(), moab::SequenceManager::check_valid_entities(), moab::BitTag::clear_data(), moab::DenseTag::clear_data(), const_pair_iterator_test(), moab::HigherOrderFactory::convert(), moab::convert_to_ranged_ids(), moab::SequenceManager::delete_entities(), moab::ReadHDF5::delete_non_side_elements(), moab::Core::get_coords(), moab::BitTag::get_data(), moab::DenseTag::get_data(), moab::VarLenDenseTag::get_data(), moab::SequenceManager::get_memory_use(), index(), moab::MeshSet::insert_entity_ranges(), insert_hint_test(), moab::ReadHDF5::insert_in_id_map(), moab::intersect(), moab::DebugOutput::list_ints_real(), moab::DebugOutput::list_range_real(), moab::merge_ranged_ids(), num_of_dimension(), num_of_type(), operator-=(), moab::operator==(), moab::PACK_RANGE(), moab::ParallelComm::pack_range_map(), psize(), moab::WriteHDF5::range_to_blocked_list(), moab::WriteHDF5::range_to_id_list(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_data(), moab::BitTag::remove_data(), moab::VarLenDenseTag::remove_data(), moab::MeshSet::remove_entity_ranges(), moab::BitTag::set_data(), moab::DenseTag::set_data(), moab::VarLenDenseTag::set_data(), str_rep(), moab::subtract(), test_get_set(), test_get_set_variable_length(), and moab::IODebugTrack::~IODebugTrack().
| const_pair_iterator moab::Range::const_pair_end | ( | ) | const [inline] |
Definition at line 752 of file Range.hpp.
Referenced by moab::WriteHDF5::assign_ids(), moab::RangeSetIterator::build_pair_vec(), moab::SequenceManager::check_valid_entities(), moab::BitTag::clear_data(), moab::DenseTag::clear_data(), moab::HigherOrderFactory::convert(), moab::convert_to_ranged_ids(), moab::SequenceManager::delete_entities(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::Core::get_coords(), moab::BitTag::get_data(), moab::DenseTag::get_data(), moab::VarLenDenseTag::get_data(), moab::SequenceManager::get_memory_use(), index(), moab::MeshSet::insert_entity_ranges(), insert_hint_test(), moab::ReadHDF5::insert_in_id_map(), moab::DebugOutput::list_ints_real(), moab::DebugOutput::list_range_real(), moab::merge_ranged_ids(), num_of_dimension(), num_of_type(), moab::operator==(), moab::PACK_RANGE(), moab::ParallelComm::pack_range_map(), psize(), moab::WriteHDF5::range_to_blocked_list(), moab::WriteHDF5::range_to_id_list(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_data(), moab::BitTag::remove_data(), moab::VarLenDenseTag::remove_data(), moab::MeshSet::remove_entity_ranges(), moab::BitTag::set_data(), moab::DenseTag::set_data(), moab::VarLenDenseTag::set_data(), str_rep(), test_get_set(), test_get_set_variable_length(), and moab::IODebugTrack::~IODebugTrack().
return const_pair_iterator( &mHead );
| bool moab::Range::contains | ( | const Range & | other | ) | const |
Definition at line 1005 of file Range.cpp.
References empty(), mHead, and moab::Range::PairNode::mNext.
Referenced by moab::WriteHDF5::check_dense_format_tag(), contains_test(), and moab::Skinner::find_skin_scd().
if( othr.empty() ) return true;
if( empty() ) return false;
// neither range is empty, so both have valid pair nodes
// other than dummy mHead
const PairNode* this_node = mHead.mNext;
const PairNode* othr_node = othr.mHead.mNext;
for( ;; )
// Loop while the node in this list is entirely before
// the node in the other list.
while( this_node->second < othr_node->first )
this_node = this_node->mNext;
if( this_node == &mHead ) return false;
// If other node is not entirely contained in this node
// then other list is not contained in this list
if( this_node->first > othr_node->first ) break;
// Loop while other node is entirely contained in this node.
while( othr_node->second <= this_node->second )
othr_node = othr_node->mNext;
if( othr_node == &othr.mHead ) return true;
// If other node overlapped end of this node
if( othr_node->first <= this_node->second ) break;
// should be unreachable
return false;
| void moab::Range::delete_pair_node | ( | PairNode * | dead_node | ) | [protected] |
Definition at line 471 of file Range.cpp.
Referenced by erase(), operator-=(), pop_back(), pop_front(), and moab::subtract().
| bool moab::Range::empty | ( | ) | const [inline] |
return whether empty or not always use "if(!Ranges::empty())" instead of "if(Ranges::size())"
Definition at line 885 of file Range.hpp.
Referenced by add_dead_elems_to_impl_compl(), moab::SpatialLocator::add_elems(), all_of_dimension(), all_of_type(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), build_tree(), moab::OrientedBoxTreeTool::build_tree(), check_children(), moab::WriteHDF5::check_dense_format_tag(), moab::DualTool::check_dual_equiv_edges(), moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperGCRM::check_existing_mesh(), moab::NCHelperMPAS::check_existing_mesh(), moab::ParallelComm::check_global_ids(), check_handle_tag(), check_ho_elements(), check_meshset_common(), moab::HalfFacetRep::check_mixed_entity_type(), moab::GeomTopoTool::check_model(), moab::ParallelComm::check_my_shared_handles(), check_parallel_read(), moab::Skinner::classify_2d_boundary(), moab::MeshTag::clear_data(), closest_point_in_triangles(), moab::OrientedBoxTreeTool::closest_to_location(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::MeshTopoUtil::common_entity(), moab::ParCommGraph::compute_partition(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::NestedRefine::construct_hm_2D(), moab::DualTool::construct_hp_parent_child(), moab::GeomTopoTool::construct_obb_tree(), contains(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::SpectralMeshTool::convert_to_coarse(), count_owned_entities(), moab::Coupler::Coupler(), moab::ReadIDEAS::create_elements(), moab::ReadGmsh::create_geometric_topology(), moab::ParallelComm::create_iface_pc_links(), create_mesh_no_holes(), moab::ReadParallel::create_partition_sets(), moab::ReadGmsh::create_sets(), moab::SpatialLocator::create_tree(), moab::DataCoupler::DataCoupler(), moab::DualTool::delete_dual_entities(), MBiMesh::delete_entities(), moab::Core::delete_entities(), delete_existing_tree(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), do_file(), do_ray_fire_test(), moab::MeshTopoUtil::equivalent_entities(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::DualTool::face_shrink(), moab::ParallelComm::filter_pstatus(), moab::Tree::find_all_trees(), moab::ScdInterface::find_boxes(), moab::AdaptiveKDTree::find_close_triangle(), moab::ParallelComm::find_existing_entity(), moab::Skinner::find_geometric_skin(), moab::MergeMesh::find_merged_to(), DeformMeshRemap::find_other_sets(), moab::ReadHDF5::find_sets_containing(), moab::Skinner::find_skin(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices(), smoab::findFaceSets(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_ents(), moab::WriteCCMIO::gather_matset_info(), moab::WriteVtk::gather_mesh(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), generate_random_points(), moab::GeomTopoTool::geometrize_surface_set(), moab::get_adjacencies_intersection(), moab::MeshTopoUtil::get_average_position(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::MeshTag::get_data(), moab::WriteUtil::get_element_connect(), moab::Core::get_entities_by_type_and_tag(), get_ents(), moab::ReadUtil::get_gather_set(), moab::ParallelComm::get_ghosted_entities(), moab::ParallelData::get_interface_sets(), moab::Tqdcfr::get_mesh_entities(), moab::WriteUtil::get_node_coords(), moab::ParallelComm::get_remote_handles(), moab::ParallelComm::get_sent_ents(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::ReadHDF5::get_subset_ids(), moab::ParallelComm::get_tag_send_list(), moab::Core::get_vertices(), moab::IntxUtils::global_gnomonic_projection(), iMesh_destroyTag(), iMOAB_CreateElements(), iMOAB_CreateVertices(), iMOAB_DeregisterApplication(), iMOAB_GetBlockInfo(), iMOAB_GetElementID(), iMOAB_GetElementOwnership(), iMOAB_UpdateMeshInfo(), ZoltanPartitioner::include_closure(), moab::NestedRefine::initialize(), moab::HiReconstruction::initialize(), moab::Coupler::initialize_spectral_elements(), moab::Coupler::initialize_tree(), moab::ReadHDF5::insert_in_id_map(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), intersect_test(), moab::DualTool::is_blind(), moab::OrientedBoxTreeTool::join_trees(), moab::DebugOutput::list_ints_real(), moab::DebugOutput::list_range_real(), load_file(), moab::ReadParallel::load_file(), moab::ReadHDF5::load_file_partial(), moab::SpatialLocator::locate_points(), main(), moab::WriteDamsel::map_sparse_tags(), mb_adjacent_vertex_test(), mb_common_tag_test(), mb_mesh_set_flag_test(), mb_skin_higher_order_regions_common(), mb_skin_verts_common(), moab::DualTool::next_loop_vertex(), moab::DualTool::order_chord(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_sets(), pack_unpack_noremoteh(), ZoltanPartitioner::partition_mesh_and_geometry(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::ParallelMergeMesh::PopulateMySkinEnts(), moab::Core::print(), moab::TreeNodePrinter::print_contents(), print_partitioned_entities(), process_partition_file(), moab::ReadHDF5::read_elems(), DeformMeshRemap::read_file(), moab::ReadHDF5::read_nodes(), moab::Tqdcfr::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sets(), moab::ReadHDF5::read_sparse_tag_indices(), smoab::DataSetConverter::readProperties(), moab::ParCommGraph::receive_mesh(), moab::FBEngine::redistribute_boundary_edges_to_faces(), moab::ParallelComm::reduce_tags(), refine_entities(), moab::MeshTag::remove_data(), remove_entities_from_sets(), moab::ReorderTool::reorder_tag_data(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::DualTool::rev_face_shrink(), sanity_check(), moab::ScdBox::ScdBox(), moab::ParallelComm::send_entities(), moab::WriteHDF5::serial_create_file(), moab::MeshTag::set_data(), moab::GeomTopoTool::setup_implicit_complement(), moab::Core::side_element(), skin_common(), moab::SpatialLocator::SpatialLocator(), moab::OrientedBoxTreeTool::sphere_intersect_triangles(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), moab::ReadCGM::store_group_content(), str_rep(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), swap_test(), tag_depth(), tag_elements(), tag_vertices(), test_adjacencies(), test_clear_bit(), test_delete_bit_data(), test_delete_type_tag(), test_elements_on_several_procs(), test_geometric_sets(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_set(), test_get_set_bit(), test_get_set_variable_length(), test_ghost_elements(), test_ho_elements(), test_multiple_files(), test_pack_bit_tag_data(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), test_read_double_tag(), test_read_handle_tag_common(), test_read_nodes_common(), test_read_opaque_tag(), test_spectral_hex(), test_tree_delete(), moab::ParallelComm::unpack_sets(), moab::ReorderTool::update_set_contents(), TreeValidator::visit(), moab::RayIntersectSets::visit(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), moab::WriteDamsel::write_file(), moab::WriteNCDF::write_file(), moab::WriteHDF5::write_file_impl(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteCCMIO::write_problem_description(), moab::WriteVtk::write_tags(), write_tree_blocks(), and moab::IODebugTrack::~IODebugTrack().
| Range::const_iterator moab::Range::end | ( | ) | const [inline] |
Definition at line 872 of file Range.hpp.
References mHead.
Referenced by add_dead_elems_to_impl_compl(), add_field_value(), adj_perf(), ahf_test(), moab::SmoothFace::area(), moab::IntxAreaUtils::area_on_sphere(), moab::WriteSTL::ascii_write_triangles(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedents_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ParallelComm::assign_global_ids(), moab::WriteUtil::assign_ids(), moab::WriteSTL::binary_write_triangles(), moab::FBEngine::boundary_mesh_edges_on_face(), moab::FBEngine::boundary_nodes_on_face(), moab::box_from_axes(), moab::MeshGeneration::BrickInstance(), SphereDecomp::build_hexes(), moab::BVHTree::build_tree(), build_tree(), moab::FBEngine::chain_able_edge(), moab::FBEngine::chain_two_edges(), moab::Core::check_adjacencies(), check_answers(), check_big_meshset(), check_children(), moab::DualTool::check_dual_adjs(), moab::DualTool::check_dual_equiv_edges(), moab::AEntityFactory::check_equiv_entities(), moab::NCHelperMPAS::check_existing_mesh(), check_handle_tag(), check_handle_tag_type(), check_ho_elements(), check_identical_mesh(), check_mesh_is_tet(), check_meshset_common(), moab::GeomTopoTool::check_model(), moab::ParallelComm::check_my_shared_handles(), check_order_by_sets_and_adj(), check_parallel_read(), moab::ParallelComm::check_sent_ents(), check_set_contents(), check_shared_ents(), check_tree(), moab::Skinner::classify_2d_boundary(), moab::Intx2Mesh::clean(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), moab::Core::clear_meshset(), closedsurface_uref_hirec_convergence_study(), closest_point_in_triangles(), moab::OrientedBoxTreeTool::closest_to_location(), moab::closest_to_triangles(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), compare_set_contents(), moab::HiReconstruction::compute_average_vertex_normals_surf(), moab::HiReconstruction::compute_average_vertex_tangents_curve(), moab::SmoothFace::compute_control_points_on_edges(), compute_dual_mesh(), moab::SmoothFace::compute_internal_control_points_on_facets(), moab::FBEngine::compute_intersection_points(), compute_lagrange_mesh_on_sphere(), SphereDecomp::compute_nodes(), moab::ParCommGraph::compute_partition(), moab::SmoothFace::compute_tangents_for_each_edge(), compute_tracer_case1(), compute_velocity_case1(), moab::TempestRemapper::ComputeOverlapMesh(), moab::DualTool::construct_dual(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::BVHTree::construct_element_vec(), moab::DualTool::construct_hex_dual(), moab::DualTool::construct_hp_parent_child(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::construct_vertex_ranges(), smoab::CellSet::contains(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::HigherOrderFactory::convert_sequence(), moab::SpectralMeshTool::convert_to_coarse(), moab::WriteHDF5::count_set_size(), EntityCount::create_adjacencies(), moab::AEntityFactory::create_explicit_adjs(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_lagr_mesh(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperMPAS::create_local_vertices(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ReadGmsh::create_sets(), IntxUtilsCSLAM::create_span_quads(), moab::SpectralMeshTool::create_spectral_elems(), moab::AEntityFactory::create_vert_elem_adjacencies(), vtkMoabReader::CreateSubBlocks(), moab::Intx2Mesh::createTags(), cube_tri_curve_coincidence_test(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::GeomTopoTool::delete_all_obb_trees(), moab::DualTool::delete_dual_entities(), moab::ParallelComm::delete_entities(), delete_existing_tree(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::HalfFacetRep::determine_border_vertices(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_incident_halffaces(), moab::HalfFacetRep::determine_incident_halfverts(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), moab::Intx2Mesh::DetermineOrderedNeighbors(), do_file(), do_linear_test(), do_ray_fire_test(), do_test_mode(), dot_children(), dot_contained(), dot_nodes(), dot_write_id_nodes(), moab::SmoothFace::DumpModelControlPoints(), moab::GeomTopoTool::duplicate_model(), moab::IntxUtils::enforce_convexity(), equal_range(), erase(), erase_test(), moab::ParallelComm::estimate_sets_buffer_size(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::DualTool::face_shrink(), smoab::faceIdsPerCell(), FBiGeom_getEnt2ndAdj(), smoab::DataSetConverter::fill(), fill_coord_on_edges(), moab::ParallelComm::filter_pstatus(), find(), find_block(), moab::ScdInterface::find_boxes(), find_coincident_edges(), find_coincident_elements(), find_coincident_nodes(), moab::ElemEvaluator::find_containing_entity(), moab::VarLenSparseTag::find_entities_with_value(), moab::SparseTag::find_entities_with_value(), moab::Skinner::find_geometric_skin(), moab::Skinner::find_inferred_edges(), moab::BVHTree::find_point(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::FBEngine::find_vertex_set_for_node(), moab::GeomQueryTool::find_volume_slow(), smoab::Interface::findDetachedEntities(), smoab::Interface::findEntitiesWithDimension(), smoab::Interface::findEntitiesWithMultipleParents(), smoab::Interface::findEntitiesWithTag(), smoab::Interface::findEntityRootParents(), moab::Intx2Mesh::FindMaxEdgesInSet(), smoab::ExtractShell::findSkins(), moab::IntxUtils::fix_degenerate_quads(), fix_surface_senses(), moab::DualTool::foc_delete_dual(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), moab::ParallelComm::gather_data(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), gather_set_stats(), moab::GeomTopoTool::generate_implicit_complement(), generate_random_points(), moab::TempestRemapper::GenerateMeshMetadata(), moab::GeomTopoTool::geometrize_surface_set(), geometry_evaluation_test(), moab::Core::get_adjacencies(), moab::get_adjacencies_intersection(), moab::MeshTopoUtil::get_average_position(), get_barycenters(), get_boundary_entities(), get_by_all_types_and_tag(), get_children_by_dimension(), moab::Core::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::Core::get_coords(), moab::GeomTopoTool::get_ct_children_by_dimension(), moab::SparseTag::get_data(), moab::VarLenSparseTag::get_data(), get_departure_grid(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::WriteUtil::get_element_connect(), moab::Core::get_entities_by_handle(), get_ents_from_geometric_sets(), get_ghost_entities(), moab::ParallelComm::get_ghosted_entities(), moab::Coupler::get_gl_points_on_elements(), get_gnomonic_plane(), moab::DualTool::get_graphics_points(), moab::ParallelComm::get_iface_entities(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), moab::ParallelComm::get_interface_sets(), get_intersection_weights(), get_linear_reconstruction(), moab::ParallelComm::get_local_handles(), moab::MeshTopoUtil::get_manifold(), get_max_volume(), moab::AEntityFactory::get_memory_use(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::HiReconstruction::get_normals_surf(), get_owner_handles(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_part_neighbor_ids(), moab::ReadHDF5::get_partition(), moab::ParallelComm::get_proc_nvecs(), moab::ParallelComm::get_pstatus_entities(), moab::ParallelComm::get_remote_handles(), moab::ReorderTool::get_reordered_handles(), moab::ParallelComm::get_sent_ents(), moab::ReadABAQUS::get_set_by_name(), moab::WriteCCMIO::get_sets(), moab::ParallelComm::get_sharing_data(), moab::WriteNCDF::get_sideset_elems(), get_signed_volume(), moab::WriteHDF5::get_tag_data_length(), moab::BitTag::get_tagged(), moab::get_tagged(), moab::HiReconstruction::get_tangents_curve(), moab::MeshSetSequence::get_type(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::Core::get_vertex_coordinates(), moab::Core::get_vertices(), moab::FBEngine::getAdjacentEntities(), smoab::getAllCells(), moab::FBEngine::getEntType(), moab::IntxUtils::global_gnomonic_projection(), moab::ReorderTool::handle_order_from_int_tag(), hcFilter(), identify_set(), iMesh_createStructuredMesh(), iMesh_getEntArr2ndAdj(), iMesh_getEntsByTagsRec(), iMesh_getEntSetsByTagsRec(), iMeshP_getAdjEntities(), iMOAB_GetElementOwnership(), iMOAB_GetMeshInfo(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), iMOAB_SetDoubleTagStorageWithGid(), ZoltanPartitioner::include_closure(), moab::ReadHDF5Dataset::init(), moab::HalfFacetRep::init_curve(), moab::SmoothFace::init_gradient(), moab::HalfFacetRep::init_surface(), moab::HalfFacetRep::init_volume(), moab::Skinner::initialize(), moab::WriteNCDF::initialize_exodus_file(), moab::FBEngine::initializeSmoothing(), insert(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::DualTool::is_blind(), moab::GeomTopoTool::is_owned_set(), moab::FBEngine::isEntAdj(), moab::OrientedBoxTreeTool::join_trees(), laplacianFilter(), smoab::detail::LinearCellConnectivity::LinearCellConnectivity(), moab::DualTool::list_entities(), moab::Core::list_entities(), moab::ParallelComm::list_entities(), moab::ReadABAQUS::load_file(), moab::WriteGMV::local_write_mesh(), lower_bound(), main(), make_tris_from_quads(), manufacture_lagrange_mesh_on_sphere(), moab::WriteDamsel::map_sparse_tags(), match_tri_edges_w_curve(), match_vertices_and_elements(), mb_adjacencies_create_delete_test(), mb_adjacent_vertex_test(), mb_bit_tags_test(), mb_common_tag_test(), mb_mesh_set_appends(), mb_mesh_set_list_replace_test(), mb_mesh_set_set_replace_test(), mb_range_seq_intersect_test(), mb_skin_adjacent_surf_patches(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_pyramids(), mb_skin_higher_order_regions_common(), mb_skin_subset_common(), mb_skin_verts_common(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), moab::FBEngine::measure(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), merge(), moab::AEntityFactory::merge_adjust_adjacencies(), merge_duplicate_vertices(), moab::MergeMesh::merge_higher_dimensions(), merge_input_surfs(), merge_test(), moab::MergeMesh::merge_using_integer_tag(), min_edge_length(), smoab::detail::MixedCellConnectivity::MixedCellConnectivity(), smoab::detail::ReadSparseTag::multiSetRead(), moab::Coupler::nat_param(), normalize_elems(), normals_test(), nothing_but_type(), obbstat_write(), obbvis_create(), moab::HiReconstruction::obtain_nring_ngbvs(), operator-=(), moab::DualTool::order_chord(), orient_faces_outward(), overlap_test_ray_fire(), overlap_test_surface_sense(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_tags(), pack_unpack_noremoteh(), parallel_create_mesh(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::GeomQueryTool::point_in_volume_slow(), moab::IntxAreaUtils::positive_orientation(), moab::AdaptiveKDTree::print(), moab::Core::print(), moab::TreeNodePrinter::print_contents(), print_mbrange(), print_output(), print_partitioned_entities(), moab::WriteHDF5Parallel::print_set_sharing_data(), print_stats(), moab::HalfFacetRep::print_tags(), moab::print_type_sets(), smoab::Interface::printRange(), moab::ReadDamsel::process_entity_tags(), quads_to_tris(), query_elem_to_vert(), query_elem_to_vert_direct(), query_struct_elem_to_vert(), query_vert_to_elem(), query_vert_to_elem_direct(), smoab::RangeToVector(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::OrientedBoxTreeTool::ray_intersect_triangles(), read_cylcube_groups_test(), moab::ReadHDF5VarLen::read_data(), DeformMeshRemap::read_file(), moab::Tqdcfr::read_nodes(), moab::ReadNCDF::read_nodesets(), moab::ReadHDF5VarLen::read_offsets(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_set_ids_recursive(), read_sets(), moab::ReadNCDF::read_sidesets(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag_values_partial(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), moab::MeshSetSequence::recursive_get_sets(), moab::FBEngine::redistribute_boundary_edges_to_faces(), moab::MeshRefiner::refine(), refine_entities(), regression_insert_set_1(), moab::VarLenSparseTag::remove_data(), moab::SparseTag::remove_data(), remove_empty_cgm_surfs_and_vols(), remove_entities_from_sets(), remove_from_back(), remove_from_vector(), moab::IntxUtils::remove_padded_vertices(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::WriteHDF5Parallel::remove_remote_sets(), moab::ReorderTool::reorder_entities(), moab::ReorderTool::reorder_tag_data(), replace_faceted_cgm_surfs(), report_sets(), moab::HalfFacetRep::resize_hf_maps(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_obb_index(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), moab::DualTool::rev_atomic_pillow(), moab::DualTool::rev_face_shrink(), moab::IntxUtils::ScaleToRadius(), moab::ParCommGraph::send_tag_values(), moab::FBEngine::separate(), moab::GeomTopoTool::separate_by_dimension(), moab::Core::set_coords(), moab::SparseTag::set_data(), moab::VarLenSparseTag::set_data(), set_density(), moab::ReadHDF5Dataset::set_file_ids(), moab::ParallelComm::settle_intersection_points(), moab::FBEngine::smooth_new_intx_points(), moab::AdaptiveKDTree::sphere_intersect_triangles(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_boundary(), moab::FBEngine::split_edge_at_mesh_node(), moab::MeshTopoUtil::split_entities_manifold(), moab::MeshTopoUtil::split_entity_nonmanifold(), moab::FBEngine::split_internal_edge(), moab::DualTool::split_pair_nonmanifold(), moab::FBEngine::split_quads(), moab::FBEngine::split_surface_with_direction(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), subset_by_dimension(), moab::subtract(), subtract_test(), summarize_cell_volume_change(), swap_test(), moab::ParallelComm::tag_iface_entities(), moab::ScdInterface::tag_shared_vertices(), moab::ParallelComm::tag_shared_verts(), tag_time(), moab::ParallelMergeMesh::TagSharedElements(), test_add_entities(), test_adjacencies(), test_assign_global_ids(), test_bc_sets(), test_bit_tag_big(), test_boolean(), test_check_meshsets(), test_clear_bit(), test_closedsurface_mesh(), test_coords_connect_iterate(), test_delete_entities(), test_delete_obb_tree(), test_delete_tag_data(), test_elements(), test_elements_on_several_procs(), test_file_set(), test_gather_sets_ranged(), test_geometric_sets(), test_get_ents_with_default_value(), test_get_set_bit(), test_ghost_elements(), test_ghost_tag_exchange(), test_ho_elements(), test_iterates(), test_linear_hex(), test_linear_quad(), test_linear_reconstruction(), test_mesh(), test_moab_v3_poly_format(), test_pack_bit_tag_data(), test_pack_poly(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_pack_tag_data_dense(), test_pack_tag_data_sparse(), test_pack_tag_handle_data(), test_pack_variable_length_tag(), test_quadratic_hex(), test_ray_fire(), test_read_double_tag(), test_read_handle_tag(), test_read_handle_tag_common(), test_read_int_tag(), test_read_nodes_common(), test_read_nothing_common(), test_read_opaque_tag(), test_read_real_tag(), test_read_set_contents(), test_read_set_sets(), test_read_sets_common(), test_read_side(), test_read_sides(), test_read_tags(), test_read_two_sets_elems(), test_read_vertices(), test_remove_entities(), test_restore_obb_trees(), test_root_sets_resize(), test_scd_invalid(), test_sequences_after_ghosting(), test_sets_fileids(), test_spectral_hex(), test_spectral_quad(), test_surface_sense(), test_tag_iterate_common(), test_tag_iterate_invalid(), test_unitcircle(), test_unitsphere(), test_var_length_big_data(), test_var_length_data_common(), test_var_length_handle_tag(), test_var_length_parallel(), test_write_different_element_types(), test_write_shared_sets(), TestErrorHandling_4(), time_forward_eval(), time_integrate(), time_jacobian(), time_reverse_eval(), moab::DualTool::traverse_hyperplane(), tri_in_set(), umr_perf_test(), moab::unite(), moab::ParallelComm::unpack_sets(), moab::BoundBox::update(), moab::ReadNCDF::update(), update_density(), moab::ParallelComm::update_remote_data(), moab::ReorderTool::update_set_contents(), moab::NestedRefine::update_special_tags(), moab::Intx2MeshOnSphere::update_tracer_data(), upper_bound(), moab::vector_remove_range(), verdict_test1(), TreeValidator::visit(), moab::FBEngine::weave_lateral_face_from_edges(), moab::WriteHDF5::write_adjacencies(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteVtk::write_bit_tag(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteGmsh::write_file(), moab::WriteAns::write_file(), moab::WriteTemplate::write_file(), moab::WriteDamsel::write_file(), moab::WriteSLAC::write_file(), moab::WriteNCDF::write_file(), moab::Core::write_file(), write_file(), moab::WriteNCDF::write_global_node_order_map(), moab::WriteTemplate::write_matsets(), moab::WriteSLAC::write_matsets(), moab::WriteVtk::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::ScdNCWriteHelper::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteHDF5::write_set_data(), moab::WriteHDF5::write_sets(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_var_len_data(), and moab::Tqdcfr::~Tqdcfr().
| std::pair< Range::const_iterator, Range::const_iterator > moab::Range::equal_range | ( | EntityType | type | ) | const |
Definition at line 867 of file Range.cpp.
References begin(), moab::CREATE_HANDLE(), end(), and lower_bound().
Referenced by moab::ParallelComm::add_verts(), moab::VarLenSparseTag::find_entities_with_value(), moab::SparseTag::find_entities_with_value(), moab::ReadUtil::gather_related_ents(), generate_random_points(), moab::BitTag::get_entities_with_bits(), moab::BitTag::get_tagged(), moab::get_tagged(), moab::WriteHDF5::initialize_mesh(), subset_by_type(), and test_ghost_elements().
std::pair< Range::const_iterator, Range::const_iterator > result;
int err;
EntityHandle handle = CREATE_HANDLE( type, 0, err );
result.first = err ? end() : lower_bound( begin(), end(), handle );
// if (type+1) overflows, err will be true and we return end().
handle = CREATE_HANDLE( type + 1, 0, err );
result.second = err ? end() : lower_bound( result.first, end(), handle );
return result;
remove an item from this list and return an iterator to the next item
erases an item from this list and returns an iterator to the next item
Definition at line 364 of file Range.cpp.
References alloc_pair(), end(), free_pair(), moab::Range::PairNode::mNext, moab::Range::const_iterator::mNode, moab::Range::PairNode::mPrev, and moab::Range::const_iterator::mValue.
Referenced by MetisPartitioner::assemble_taggedsets_graph(), check_children(), moab::ParallelComm::check_clean_iface(), moab::DualTool::check_dual_equiv_edges(), check_identical_mesh(), moab::ParallelComm::check_my_shared_handles(), moab::Skinner::classify_2d_boundary(), contains_test(), moab::ReadCCMIO::create_cell_from_faces(), moab::ReadHDF5::delete_non_side_elements(), moab::GeomTopoTool::delete_obb_tree(), moab::ParallelComm::destroy_part(), moab::MeshTopoUtil::equivalent_entities(), erase(), erase_test(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_3D(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_addl_ents(), moab::DualTool::foc_get_ents(), moab::DualTool::fsr_get_fourth_quad(), moab::WriteVtk::gather_mesh(), generate_random_points(), moab::GeomTopoTool::geometrize_surface_set(), moab::get_adjacencies_intersection(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::ParallelComm::get_interface_sets(), moab::WriteTemplate::get_neuset_elems(), moab::WriteSLAC::get_neuset_elems(), moab::WriteCCMIO::get_neuset_elems(), moab::ReorderTool::get_new_handles(), moab::ReadHDF5::get_partition(), moab::WriteNCDF::get_sideset_elems(), moab::Core::get_vertices(), moab::ReorderTool::handle_order_from_int_tag(), hcFilter(), identify_set(), moab::Intx2Mesh::intersect_meshes(), laplacianFilter(), mb_range_seq_intersect_test(), mb_topo_util_test(), merge_duplicate_vertices(), moab::MergeMesh::merge_higher_dimensions(), min_edge_length(), moab::DualTool::next_loop_vertex(), operator-=(), moab::DualTool::order_chord(), print_stats(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReorderTool::reorder_tag_data(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::DualTool::rev_face_shrink(), moab::Core::serial_load_file(), moab::MeshTopoUtil::star_entities(), moab::MeshTopoUtil::star_entities_nonmanifold(), moab::MeshTopoUtil::star_next_entity(), moab::subtract(), moab::ParallelMergeMesh::TagSharedElements(), test_coords_connect_iterate(), test_get_by_tag_value_dense(), test_get_set(), test_get_set_variable_length(), test_ghost_elements(), test_ghost_tag_exchange(), test_read_nodes_common(), test_read_set_sets(), test_read_two_sets_elems(), test_tag_iterate_common(), moab::ReadNCDF::update(), and TreeValidator::visit().
// one of a few things could happen
// 1. shrink a range
// 2. split a range
// 3. remove a range
if( iter == end() ) return end();
// the iterator most likely to be returned
iterator new_iter = iter;
++new_iter;
PairNode* kter = iter.mNode;
// just remove the range
if( kter->first == kter->second )
kter->mNext->mPrev = kter->mPrev;
kter->mPrev->mNext = kter->mNext;
free_pair( kter );
return new_iter;
// shrink it
else if( kter->first == iter.mValue )
kter->first++;
return new_iter;
// shrink it the other way
else if( kter->second == iter.mValue )
kter->second--;
return new_iter;
// split the range
else
PairNode* new_node = alloc_pair( iter.mNode->mNext, iter.mNode, iter.mValue + 1, kter->second );
new_node->mPrev->mNext = new_node->mNext->mPrev = new_node;
iter.mNode->second = iter.mValue - 1;
new_iter = const_iterator( new_node, new_node->first );
return new_iter;
| Range::iterator moab::Range::erase | ( | iterator | iter1, |
| iterator | iter2 | ||
remove a range of items from the list
Definition at line 411 of file Range.cpp.
References alloc_pair(), delete_pair_node(), mHead, moab::Range::PairNode::mNext, moab::Range::const_iterator::mNode, moab::Range::PairNode::mPrev, and moab::Range::const_iterator::mValue.
iterator result;
if( iter1.mNode == iter2.mNode )
if( iter2.mValue <= iter1.mValue )
// empty range OK, otherwise invalid input
return iter2;
// If both iterators reference the same pair node, then
// we're either removing values from the front of the
// node or splitting the node. We can never be removing
// the last value in the node in this case because iter2
// points *after* the last entry to be removed.
PairNode* node = iter1.mNode;
if( iter1.mValue == node->first )
node->first = iter2.mValue;
result = iter2;
else
PairNode* new_node = alloc_pair( node->mNext, node, iter2.mValue, node->second );
new_node->mPrev->mNext = new_node;
node->second = iter1.mValue - 1;
result = iterator( new_node, new_node->first );
else
if( iter1.mNode == &mHead ) return iter1;
PairNode* dn = iter1.mNode;
if( iter1.mValue > dn->first )
dn->second = iter1.mValue - 1;
dn = dn->mNext;
if( iter2.mNode != &mHead ) iter2.mNode->first = iter2.mValue;
while( dn != iter2.mNode )
PairNode* dead = dn;
dn = dn->mNext;
dead->mPrev->mNext = dead->mNext;
dead->mNext->mPrev = dead->mPrev;
// dead->mPrev = dead->mNext = 0;
delete_pair_node( dead );
result = iter2;
return result;
| Range::iterator moab::Range::erase | ( | EntityHandle | val | ) | [inline] |
| Range::const_iterator moab::Range::find | ( | EntityHandle | val | ) | const |
find an item int the list and return an iterator at that value
finds a value in the list. this method is preferred over other algorithms because it can be found faster this way.
Definition at line 510 of file Range.cpp.
References end(), mHead, and moab::Range::PairNode::mNext.
Referenced by moab::Core::check_adjacencies(), check_children(), moab::DualTool::check_dual_adjs(), moab::AEntityFactory::check_equiv_entities(), moab::Skinner::classify_2d_boundary(), moab::FBEngine::compute_intersection_points(), smoab::CellSet::contains(), moab::GeomTopoTool::duplicate_model(), erase(), FBiGeom_getEnt2ndAdj(), moab::Skinner::find_skin_noadj(), moab::ReadUtil::gather_related_ents(), moab::GeomTopoTool::geometrize_surface_set(), moab::FBEngine::getAdjacentEntities(), moab::FBEngine::getEntType(), ZoltanPartitioner::include_closure(), moab::Intx2Mesh::intersect_meshes(), moab::GeomTopoTool::is_owned_set(), moab::FBEngine::isEntAdj(), merge_duplicate_vertices(), moab::HiReconstruction::obtain_nring_ngbvs(), moab::ParallelComm::pack_entities(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::WriteHDF5Parallel::remove_remote_sets(), moab::FBEngine::separate(), moab::ParallelComm::settle_intersection_points(), moab::FBEngine::split_boundary(), moab::DualTool::split_pair_nonmanifold(), subtract_test(), swap_test(), test_read_nodes_common(), test_read_nothing_common(), test_read_set_sets(), test_read_two_sets_elems(), moab::DualTool::traverse_hyperplane(), tri_in_set(), moab::vector_remove_range(), moab::FBEngine::weave_lateral_face_from_edges(), and moab::WriteSLAC::write_matsets().
| const EntityHandle & moab::Range::front | ( | ) | const [inline] |
get first entity in range
Definition at line 907 of file Range.hpp.
References mHead, and moab::Range::PairNode::mNext.
Referenced by add_dead_elems_to_impl_compl(), all_of_dimension(), all_of_type(), moab::ReadMCNP5::average_with_existing_tally(), check_children(), check_geometric_set(), check_num_verts(), moab::MeshTag::clear_data(), moab::OrientedBoxTreeTool::closest_to_location(), moab::ReadIDEAS::create_elements(), moab::ReadHDF5::delete_non_side_elements(), moab::GeomTopoTool::entity_by_id(), erase_test(), find_sideset(), moab::Skinner::find_skin_vertices(), fix_surface_senses(), moab::WriteNCDF::gather_mesh_information(), moab::WriteUtil::gather_nodes_from_elements(), moab::MeshTag::get_data(), moab::ParallelComm::get_part_handle(), moab::ReadHDF5::get_partition(), moab::ReadHDF5::insert_in_id_map(), moab::Intx2Mesh::intersect_meshes(), main(), make_mesh(), mb_common_tag_test(), mb_merge_update_test(), mb_mesh_set_appends(), mb_mesh_set_flag_test(), mb_skin_curve_test_common(), mb_skin_poly_test(), mb_skin_reversed_common(), mb_skin_surface_test_common(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), orient_faces_outward(), overlap_test_measure_volume(), overlap_test_point_in_volume(), overlap_test_ray_fire(), overlap_test_surface_sense(), overlap_test_tracking(), pop_front(), moab::ReadHDF5::read_elems(), moab::ReadHDF5VarLen::read_offsets(), read_sets(), smoab::DataSetConverter::readProperties(), regression_one_entity_by_var_tag(), moab::MeshTag::remove_data(), replace_faceted_cgm_surfs(), moab::GeomTopoTool::resize_rootSets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::MeshTag::set_data(), moab::GeomTopoTool::setup_implicit_complement(), moab::OrientedBoxTreeTool::sphere_intersect_triangles(), subset_by_dimension_test(), test_bc_sets(), test_blocks(), test_closest_to_location(), test_delete_bit_data(), test_delete_obb_tree(), test_delete_tag_data(), test_delete_type_tag(), test_get_by_tag_value_dense(), test_get_ents_with_default_value(), test_iterates(), test_list_set_with_stale_handles(), test_measure_volume(), test_moab_v3_poly_format(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_default_value(), test_point_in_volume(), test_ranged_set_with_stale_handles(), test_ray_fire(), test_read_adjacencies(), test_read_alternate_coord_format(), test_read_elements_common(), test_read_geom_set(), test_read_material_on_nodes(), test_read_material_set(), test_read_material_set1(), test_read_material_set2(), test_read_physical_set(), test_read_set_sets(), test_read_two_sets_elems(), test_restore_obb_trees(), test_set_flags(), test_surface_sense(), test_tree(), test_tree_readwrite(), test_var_length_big_data(), test_write_shared_sets(), and test_write_unbalanced().
| unsigned long moab::Range::get_memory_use | ( | ) | const |
Definition at line 997 of file Range.cpp.
Referenced by compactness().
| int moab::Range::index | ( | EntityHandle | handle | ) | const [inline] |
Definition at line 936 of file Range.hpp.
References begin(), const_pair_begin(), const_pair_end(), and rbegin().
Referenced by MetisPartitioner::assemble_graph(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), create_fine_mesh(), moab::NCHelperMPAS::create_local_cells(), moab::ParallelComm::create_part(), moab::ParallelComm::delete_entities(), moab::ParallelComm::destroy_part(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), fill_coord_on_edges(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), moab::HiReconstruction::get_fittings_data(), moab::HiReconstruction::get_normals_surf(), moab::HiReconstruction::get_tangents_curve(), hcFilter(), moab::HiReconstruction::hiproj_walf_around_vertex(), moab::HiReconstruction::hiproj_walf_in_element(), iMOAB_GetBlockElementConnectivities(), iMOAB_GetElementConnectivity(), iMOAB_GetElementID(), iMOAB_GetNeighborElements(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVisibleElementsInfo(), laplacianFilter(), main(), moab::HalfFacetRep::mark_halfedges(), moab::NestedRefine::parent_to_child(), moab::HiReconstruction::polyfit3d_walf_curve_vertex(), moab::HiReconstruction::polyfit3d_walf_surf_vertex(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), update_density(), moab::NestedRefine::update_global_ahf_3D(), moab::Intx2MeshOnSphere::update_tracer_data(), moab::WriteNCDF::write_elementblocks(), and moab::WriteVtk::write_elems().
if( handle < *begin() || handle > *rbegin() ) return -1;
unsigned int i = 0;
Range::const_pair_iterator pit = const_pair_begin();
while( handle > ( *pit ).second && pit != const_pair_end() )
i += ( *pit ).second - ( *pit ).first + 1;
++pit;
if( handle < ( *pit ).first || pit == const_pair_end() ) return -1;
return i + handle - ( *pit ).first;
| Range::iterator moab::Range::insert | ( | Range::iterator | hint, |
| EntityHandle | val | ||
inserts a single value into this range
Definition at line 229 of file Range.cpp.
References alloc_pair(), end(), free_pair(), mHead, moab::Range::PairNode::mNext, moab::Range::const_iterator::mNode, and moab::Range::PairNode::mPrev.
Referenced by moab::ReadSms::add_entities(), moab::GeomTopoTool::add_geo_set(), moab::SharedSetData::append_local_handles(), moab::ParallelComm::assign_global_ids(), moab::ReadUtil::assign_ids(), moab::DualTool::atomic_pillow(), moab::FBEngine::BreakTriangle2(), moab::MeshGeneration::BrickInstance(), moab::ReadRTT::build_moab(), build_triangles(), moab::ParallelComm::check_clean_iface(), moab::DualTool::check_dual_equiv_edges(), moab::ParallelComm::check_my_shared_handles(), check_order_by_sets_and_adj(), moab::ParallelComm::check_sent_ents(), check_set_contents(), moab::Skinner::classify_2d_boundary(), moab::MeshTopoUtil::common_entity(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::TempestRemapper::ComputeOverlapMesh(), const_pair_iterator_test(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::DualTool::construct_hp_parent_child(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_obb_trees(), moab::TempestRemapper::ConstructCoveringSet(), moab::DamselUtil::container_to_range(), contains_test(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::ReadHDF5::convert_range_to_handle(), moab::convert_to_ranged_ids(), moab::BVHTree::convert_tree(), moab::copy_set_contents(), moab::copy_sorted_file_ids(), moab::ReadGmsh::create_elements(), moab::NCHelperMPAS::create_gather_set_cells(), moab::ReadABAQUS::create_instance_of_part(), moab::ParallelComm::create_interface_sets(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::ScdNCHelper::create_mesh(), moab::FBEngine::create_new_gedge(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ParallelComm::create_part(), create_patch(), moab::ScdInterface::create_scd_sequence(), moab::ReadGmsh::create_sets(), moab::ReadTemplate::create_sets(), create_shared_grid_3d(), moab::SpectralMeshTool::create_spectral_elems(), moab::ReadCGM::create_surface_facets(), moab::ReadOBJ::create_tri_faces(), moab::ReadIDEAS::create_vertices(), moab::Core::create_vertices(), moab::DualTool::delete_dual_entities(), moab::Core::delete_entities(), moab::ParallelComm::delete_entities(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::FBEngine::divide_triangle(), do_file(), moab::GeomTopoTool::duplicate_model(), erase_test(), moab::Core::estimated_memory_use(), moab::DualTool::face_shrink(), FBiGeom_getEnt2ndAdj(), moab::ParallelComm::filter_pstatus(), moab::ScdInterface::find_boxes(), moab::Skinner::find_geometric_skin(), moab::Skinner::find_inferred_edges(), moab::find_map_values(), moab::ReadHDF5::find_sets_containing(), moab::Skinner::find_skin_noadj(), moab::Skinner::find_skin_vertices_1D(), moab::Skinner::find_skin_vertices_2D(), moab::Skinner::find_skin_vertices_3D(), moab::find_tag_values(), smoab::Interface::findDetachedEntities(), smoab::Interface::findEntitiesWithMultipleParents(), smoab::Interface::findEntitiesWithTag(), smoab::Interface::findEntityRootParents(), smoab::ExtractShell::findSkins(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_ents(), moab::ParCommGraph::form_mesh_from_tuples(), moab::DualTool::fs_get_quad_loops(), moab::DualTool::fsr_get_fourth_quad(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::WriteUtil::gather_nodes_from_elements(), moab::ReadUtil::gather_related_ents(), gather_related_test(), moab::TempestRemapper::GenerateMeshMetadata(), moab::GeomTopoTool::geometrize_surface_set(), moab::get_adjacencies_union(), moab::MeshTopoUtil::get_bridge_adjacencies(), get_by_all_types_and_tag(), moab::DualTool::get_cell_points(), get_children_by_dimension(), moab::Core::get_connectivity(), moab::ReadDamsel::get_contents(), moab::GeomTopoTool::get_ct_children_by_dimension(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::ReadABAQUS::get_elements_by_id(), moab::MeshSet::get_entities(), moab::ReorderTool::get_entities(), moab::TypeSequenceManager::get_entities(), moab::MeshSet::get_entities_by_dimension(), moab::MeshSet::get_entities_by_type(), get_ghost_entities(), moab::DualTool::get_graphics_points(), moab::MeshTopoUtil::get_manifold(), moab::ReadABAQUS::get_nodes_by_id(), moab::MeshSet::get_non_set_entities(), moab::ParallelComm::get_pstatus_entities(), moab::DenseTag::get_tagged_entities(), moab::ReadHDF5::get_tagged_entities(), smoab::getAllCells(), moab::TempestRemapper::GetOverlapAugmentedEntities(), smoab::getParents(), moab::IntxUtils::global_gnomonic_projection(), heappermute(), iMesh_createEnt(), iMesh_createStructuredMesh(), iMOAB_DeregisterApplication(), insert(), insert_hint_test(), insert_list(), moab::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), intersect_test(), moab::ReadParallel::load_file(), moab::ReadHDF5::load_file_impl(), main(), make_tris_from_quads(), mb_adjacent_vertex_test(), mb_memory_use_test(), mb_mesh_set_appends(), mb_mesh_set_set_replace_test(), mb_poly_test(), mb_range_seq_intersect_test(), mb_root_set_test(), mb_skin_curve_test_common(), mb_skin_full_common(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_pyramids(), mb_skin_higher_order_regions_common(), mb_skin_poly_test(), mb_skin_reversed_common(), mb_skin_subset_common(), mb_skin_verts_common(), mb_skin_volume_test_common(), mb_split_test(), mb_topo_util_test(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), moab::MergeMesh::merge_entities(), moab::MergeMesh::merge_higher_dimensions(), moab::merge_ranged_ids(), merge_test(), moab::DualTool::next_loop_vertex(), moab::HiReconstruction::obtain_nring_ngbvs(), smoab::detail::internal::key_inserter::operator=(), parallel_create_mesh(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::AdaptiveKDTree::print(), print_stats(), moab::print_type_sets(), moab::ReadDamsel::process_ent_info(), process_partition_file(), moab::ReadHDF5::read_dense_tag(), moab::ReadTetGen::read_elem_file(), moab::ReadTemplate::read_elements(), moab::ReadNCDF::read_elements(), moab::ReadHDF5::read_elems(), McnpData::read_mcnpfile(), moab::ReadHDF5::read_node_adj_elems(), moab::ReadTetGen::read_node_file(), moab::ReadNCDF::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag_values_partial(), moab::ReadTemplate::read_vertices(), moab::MeshSetSequence::recursive_get_sets(), regression_insert_set_1(), regression_mmiller_8_2010(), regression_tag_on_nonexistent_entity(), remove_entities_from_sets(), moab::IntxUtils::remove_padded_vertices(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::WriteHDF5Parallel::remove_remote_sets(), moab::ParallelComm::resolve_shared_sets(), moab::DualTool::rev_atomic_pillow(), moab::DualTool::rev_face_shrink(), moab::BitPage::search(), moab::GeomTopoTool::separate_by_dimension(), moab::ReadHDF5Dataset::set_all_file_ids(), moab::Core::side_element(), moab::Skinner::skin_box(), moab::split_box(), moab::MeshTopoUtil::split_entities_manifold(), moab::MeshTopoUtil::split_entity_nonmanifold(), moab::FBEngine::split_internal_edge(), moab::ParCommGraph::split_owned_range(), moab::DualTool::split_pair_nonmanifold(), moab::FBEngine::split_surface_with_direction(), moab::MeshTopoUtil::star_next_entity(), moab::ReadHDF5::store_file_ids(), moab::ReadCGM::store_group_content(), moab::ReadHDF5::store_sets_file_ids(), subset_by_dimension(), subset_by_dimension_test(), subset_by_type(), subtract_test(), swap_test(), tag_depth(), moab::ParallelComm::tag_iface_entities(), moab::ScdInterface::tag_shared_vertices(), test_add_entities(), test_bit_tag_big(), test_build_from_pts(), test_build_from_tri(), test_coords_connect_iterate(), test_delete_tag_data(), test_elements_on_several_procs(), test_entities_by_dimension(), test_entities_by_type(), test_filter_pstatus(), test_get_ents_with_default_value(), test_get_set(), test_get_set_variable_length(), test_ghost_elements(), test_ghost_tag_exchange(), test_intersect(), test_iterates(), test_iterators(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_packing(), test_remove_entities(), test_shared_sets(), test_subtract(), test_tag_iterate_common(), test_unite(), test_write_unbalanced(), moab::DualTool::traverse_hyperplane(), moab::unite(), moab::UNPACK_RANGE(), moab::ParallelComm::unpack_sets(), moab::ReadNCDF::update(), moab::ReorderTool::update_set_contents(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_unstructured_grid(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteGmsh::write_file(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteHDF5::write_set_data(), and moab::IODebugTrack::~IODebugTrack().
// don't allow zero-valued handles in Range
if( val == 0 ) return end();
// if this is empty, just add it and return an iterator to it
if( &mHead == mHead.mNext )
mHead.mNext = mHead.mPrev = alloc_pair( &mHead, &mHead, val, val );
return iterator( mHead.mNext, val );
// find the location in the list where we can safely insert
// new items and keep it ordered
PairNode* hter = hint.mNode;
PairNode* jter = hter->first <= val ? hter : mHead.mNext;
for( ; ( jter != &mHead ) && ( jter->second < val ); jter = jter->mNext )
PairNode* iter = jter;
jter = jter->mPrev;
// if this val is already in the list
if( ( iter->first <= val && iter->second >= val ) && ( iter != &mHead ) )
// return an iterator pointing to this location
return iterator( iter, val );
// one of a few things can happen at this point
// 1. this range needs to be backwardly extended
// 2. the previous range needs to be forwardly extended
// 3. a new range needs to be added
// extend this range back a bit
else if( ( iter->first == ( val + 1 ) ) && ( iter != &mHead ) )
iter->first = val;
// see if we need to merge two ranges
if( ( iter != mHead.mNext ) && ( jter->second == ( val - 1 ) ) )
jter->second = iter->second;
iter->mPrev->mNext = iter->mNext;
iter->mNext->mPrev = iter->mPrev;
free_pair( iter );
return iterator( jter, val );
else
// extend the previous range forward a bit
else if( ( jter->second == ( val - 1 ) ) && ( iter != mHead.mNext ) )
jter->second = val;
// make a new range
else
PairNode* new_node = alloc_pair( iter, iter->mPrev, val, val );
iter->mPrev = new_node->mPrev->mNext = new_node;
return iterator( new_node, val );
| iterator moab::Range::insert | ( | EntityHandle | val | ) | [inline] |
| Range::iterator moab::Range::insert | ( | Range::iterator | prev, |
| EntityHandle | first, | ||
| EntityHandle | last | ||
insert a range of items into this list and return the iterator for the first inserted item
Definition at line 295 of file Range.cpp.
References alloc_pair(), end(), moab::GeomUtil::first(), free_pair(), mHead, moab::Range::PairNode::mNext, moab::Range::const_iterator::mNode, and moab::Range::PairNode::mPrev.
if( val1 == 0 || val1 > val2 ) return end();
// Empty
if( mHead.mNext == &mHead )
assert( prev == end() );
PairNode* new_node = alloc_pair( &mHead, &mHead, val1, val2 );
mHead.mNext = mHead.mPrev = new_node;
return iterator( mHead.mNext, val1 );
PairNode* iter = prev.mNode;
// If iterator is at end, set it to last.
// Thus if the hint was to append, we start searching
// at the end of the list.
if( iter == &mHead ) iter = mHead.mPrev;
// if hint (prev) is past insert position, reset it to the beginning.
if( iter != &mHead && iter->first > val2 + 1 ) iter = mHead.mNext;
// If hint is bogus then search backwards
while( iter != mHead.mNext && iter->mPrev->second >= val1 - 1 )
iter = iter->mPrev;
// Input range is before beginning?
if( iter->mPrev == &mHead && val2 < iter->first - 1 )
PairNode* new_node = alloc_pair( iter, &mHead, val1, val2 );
mHead.mNext = iter->mPrev = new_node;
// Find first intersecting list entry, or the next entry
// if none intersects.
while( iter != &mHead && iter->second + 1 < val1 )
iter = iter->mNext;
// Need to insert new pair (don't intersect any existing pair)?
if( iter == &mHead || iter->first - 1 > val2 )
PairNode* new_node = alloc_pair( iter, iter->mPrev, val1, val2 );
iter->mPrev = iter->mPrev->mNext = new_node;
return iterator( iter->mPrev, val1 );
// Make the first intersecting pair the union of itself with [val1,val2]
if( iter->first > val1 ) iter->first = val1;
if( iter->second >= val2 ) return iterator( iter, val1 );
iter->second = val2;
// Merge any remaining pairs that intersect [val1,val2]
while( iter->mNext != &mHead && iter->mNext->first <= val2 + 1 )
PairNode* dead = iter->mNext;
iter->mNext = dead->mNext;
dead->mNext->mPrev = iter;
if( dead->second > val2 ) iter->second = dead->second;
free_pair( dead );
| iterator moab::Range::insert | ( | EntityHandle | val1, |
| EntityHandle | val2 | ||
| ) | [inline] |
| iterator moab::Range::insert | ( | typename T::const_iterator | begin_iter, |
| typename T::const_iterator | end_iter | ||
| ) | [inline] |
Definition at line 270 of file Range.hpp.
return insert_list( begin_iter, end_iter );
| iterator moab::Range::insert | ( | const T * | begin_iter, |
| const T * | end_iter | ||
| ) | [inline] |
Definition at line 276 of file Range.hpp.
| void moab::Range::insert | ( | Range::const_iterator | begini, |
| Range::const_iterator | endi | ||
merges another Range with this one
Definition at line 523 of file Range.cpp.
References insert(), moab::Range::PairNode::mNext, and moab::Range::const_iterator::mNode.
if( begini == endi ) return;
PairNode* node = begini.mNode;
if( endi.mNode == node )
insert( *begini, ( *endi ) - 1 );
return;
Range::iterator hint = insert( *begini, node->second );
node = node->mNext;
while( node != endi.mNode )
hint = insert( hint, node->first, node->second );
node = node->mNext;
if( *endi > node->first )
if( *endi <= node->second )
insert( hint, node->first, *(endi)-1 );
else
| iterator moab::Range::insert_list | ( | T | begin_iter, |
| T | end_iter | ||
Referenced by moab::GeomTopoTool::delete_obb_tree(), and test_restore_obb_trees().
| Range::iterator moab::Range::insert_list | ( | Iterator | begin_iter, |
| Iterator | end_iter | ||
Definition at line 959 of file Range.hpp.
References begin(), and insert().
size_t n = std::distance( begin_iter, end_iter );
EntityHandle* sorted = new EntityHandle[n];
std::copy( begin_iter, end_iter, sorted );
std::sort( sorted, sorted + n );
iterator hint = begin();
size_t i = 0;
while( i < n )
size_t j = i + 1;
while( j < n && sorted[j] == 1 + sorted[j - 1] )
++j;
hint = insert( hint, sorted[i], sorted[i] + ( ( j - i ) - 1 ) );
i = j;
delete[] sorted;
return hint;
| Range::const_iterator moab::Range::lower_bound | ( | Range::const_iterator | first, |
| Range::const_iterator | last, | ||
| ) | [static] |
return an iterator to the first value >= val
Definition at line 809 of file Range.cpp.
References moab::Range::PairNode::mNext, and moab::Range::const_iterator::mNode.
Referenced by MetisPartitioner::assemble_taggedsets_graph(), moab::AxisBox::calculate(), moab::OrientedBox::compute_from_vertices(), moab::OrientedBox::covariance_data_from_tris(), moab::ReadHDF5::delete_non_side_elements(), equal_range(), moab::ParallelComm::estimate_ents_buffer_size(), moab::ParallelComm::estimate_sets_buffer_size(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::WriteVtk::gather_mesh(), moab::ReadHDF5::get_partition(), moab::ParallelComm::get_shared_entities(), identify_set(), iMesh_createStructuredMesh(), moab::intersect(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::ReadHDF5::load_file_partial(), moab::WriteGMV::local_write_mesh(), lower_bound(), main(), mb_range_seq_intersect_test(), min_edge_length(), moab::ParallelComm::pack_entities(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_tag_values_partial(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), subset_by_dimension(), moab::ParallelMergeMesh::TagSharedElements(), moab::BoundBox::update(), upper_bound(), and TreeValidator::visit().
// Find the first pair whose end is >= val
PairNode* iter;
for( iter = first.mNode; iter != last.mNode; iter = iter->mNext )
if( iter->second >= val )
// This is the correct pair. Either 'val' is in the range, or
// the range starts before 'val' and iter->first IS the lower_bound.
if( iter->first > val ) return const_iterator( iter, iter->first );
return const_iterator( iter, val );
if( iter->first >= val )
else if( *last > val )
else
return last;
| const_iterator moab::Range::lower_bound | ( | EntityHandle | val | ) | const [inline] |
Definition at line 306 of file Range.hpp.
return lower_bound( begin(), end(), val );
| Range::const_iterator moab::Range::lower_bound | ( | EntityType | type | ) | const |
Definition at line 839 of file Range.cpp.
int err;
return err ? end() : lower_bound( begin(), end(), handle );
| Range::const_iterator moab::Range::lower_bound | ( | EntityType | type, |
| const_iterator | first | ||
| ) | const |
Definition at line 845 of file Range.cpp.
References moab::CREATE_HANDLE(), end(), and lower_bound().
int err;
return err ? end() : lower_bound( first, end(), handle );
| void moab::Range::merge | ( | const Range & | range | ) | [inline] |
merges this Range with another range
Definition at line 346 of file Range.hpp.
References begin(), and end().
Referenced by moab::DualTool::atomic_pillow(), moab::MeshGeneration::BrickInstance(), moab::AdaptiveKDTree::build_tree(), moab::AxisBox::calculate(), moab::ParallelComm::check_my_shared_handles(), moab::WriteHDF5Parallel::communicate_shared_set_data(), compute_dual_mesh(), moab::DualTool::construct_dual_faces(), moab::TempestRemapper::convert_tempest_mesh_private(), create_int_ents(), moab::NCHelperHOMME::create_mesh(), DeformMeshRemap::deform_master(), do_file(), dot_get_sets(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_owned_mesh(), DeformMeshRemap::execute(), FBiGeom_getArrAdj(), moab::Skinner::find_skin(), moab::Skinner::find_skin_scd(), moab::Skinner::find_skin_vertices_3D(), moab::DualTool::foc_delete_dual(), moab::DualTool::foc_get_addl_ents(), moab::WriteHDF5Parallel::gather_interface_meshes(), moab::WriteVtk::gather_mesh(), moab::WriteHDF5::gather_mesh_info(), moab::ReadUtil::gather_related_ents(), moab::MeshTopoUtil::get_bridge_adjacencies(), moab::Core::get_connectivity(), get_entities(), moab::Core::get_entities_by_type_and_tag(), get_ents_from_geometric_sets(), moab::ParallelComm::get_ghosted_entities(), moab::MeshTopoUtil::get_manifold(), moab::ParallelComm::get_part_entities(), moab::ParallelComm::get_sent_ents(), moab::ReadABAQUS::get_set_elements(), moab::ReadABAQUS::get_set_nodes(), moab::ParallelComm::get_shared_entities(), moab::WriteHDF5::get_sparse_tagged_entities(), moab::WriteHDF5::get_tag_data_length(), moab::WriteSTL::get_triangles(), moab::Core::get_vertices(), moab::WriteHDF5::get_write_entities(), moab::FBEngine::getEntities(), moab::TempestRemapper::GetOverlapAugmentedEntities(), identify_set(), iMesh_getEntsByTagsRec(), iMOAB_CreateElements(), iMOAB_CreateVertices(), moab::ReorderTool::int_order_from_sets_and_adj(), moab::intersect(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::ReadHDF5::load_file_partial(), main(), mb_mesh_set_appends(), mb_skin_poly_test(), merge_duplicate_vertices(), merge_test(), obbvis_create(), pack_unpack_noremoteh(), moab::AdaptiveKDTree::print(), print_stats(), moab::Tqdcfr::read_block(), moab::ReadABAQUS::read_element_set(), DeformMeshRemap::read_file(), moab::ReadABAQUS::read_node_set(), moab::Tqdcfr::read_nodes(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_tag_values_partial(), moab::ReadCCMIO::read_vertices(), moab::ParCommGraph::receive_mesh(), regression_insert_set_1(), moab::WriteHDF5Parallel::remove_remote_entities(), report_iface_ents(), moab::GeomTopoTool::resize_rootSets(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::ParallelComm::send_entities(), moab::ParCommGraph::send_mesh_parts(), set_intersection_query(), moab::Skinner::skin_box(), skin_common(), moab::MeshTopoUtil::split_entities_manifold(), tag_time(), moab::ParallelMergeMesh::TagSharedElements(), test_boolean(), test_elements_on_several_procs(), test_ghost_elements(), test_pack_sets_simple(), test_valid_tree(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteVtk::write_elems(), moab::WriteGmsh::write_file(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_tag_values(), moab::WriteVtk::write_tags(), and moab::WriteHDF5::write_var_len_indices().
insert( range.begin(), range.end() );
| void moab::Range::merge | ( | Range::const_iterator | beginr, |
| Range::const_iterator | endr | ||
| ) | [inline] |
| unsigned moab::Range::num_of_dimension | ( | int | dim | ) | const |
Definition at line 911 of file Range.cpp.
References const_pair_begin(), const_pair_end(), moab::CREATE_HANDLE(), moab::CN::Dimension(), moab::GeomUtil::first(), MB_END_ID, moab::TYPE_FROM_HANDLE(), and moab::CN::TypeDimensionMap.
Referenced by main().
const_pair_iterator iter = const_pair_begin();
while( iter != const_pair_end() && CN::Dimension( TYPE_FROM_HANDLE( ( *iter ).second ) ) < dim )
++iter;
int junk;
unsigned count = 0;
for( ; iter != const_pair_end(); ++iter )
int start_dim = CN::Dimension( TYPE_FROM_HANDLE( ( *iter ).first ) );
int end_dim = CN::Dimension( TYPE_FROM_HANDLE( ( *iter ).second ) );
if( start_dim > dim ) break;
EntityHandle sh = start_dim < dim ? CREATE_HANDLE( CN::TypeDimensionMap[dim].first, 1, junk ) : ( *iter ).first;
EntityHandle eh =
end_dim > dim ? CREATE_HANDLE( CN::TypeDimensionMap[dim].second, MB_END_ID, junk ) : ( *iter ).second;
count += eh - sh + 1;
return count;
| unsigned moab::Range::num_of_type | ( | EntityType | type | ) | const |
Definition at line 890 of file Range.cpp.
References const_pair_begin(), const_pair_end(), moab::ID_FROM_HANDLE(), MB_END_ID, and moab::TYPE_FROM_HANDLE().
Referenced by moab::ParallelComm::estimate_ents_buffer_size(), and test_pack_sets_simple().
while( iter != const_pair_end() && TYPE_FROM_HANDLE( ( *iter ).second ) < type )
++iter;
unsigned count = 0;
EntityType start_type = TYPE_FROM_HANDLE( ( *iter ).first );
EntityType end_type = TYPE_FROM_HANDLE( ( *iter ).second );
if( start_type > type ) break;
EntityID sid = start_type < type ? 1 : ID_FROM_HANDLE( ( *iter ).first );
EntityID eid = end_type > type ? MB_END_ID : ID_FROM_HANDLE( ( *iter ).second );
count += eid - sid + 1;
return count;
just like subtract, but as an operator
Definition at line 730 of file Range.cpp.
References alloc_pair(), begin(), const_pair_begin(), delete_pair_node(), end(), erase(), moab::Range::PairNode::mNext, moab::Range::PairNode::mPrev, moab::Range::pair_iterator::node(), and pair_begin().
const bool braindead = false;
if( braindead )
// brain-dead implementation right now
Range res( *this );
for( Range::const_iterator rit = range2.begin(); rit != range2.end(); ++rit )
res.erase( *rit );
return *this;
else
Range::pair_iterator r_it0 = this->pair_begin();
Range::const_pair_iterator r_it1 = range2.const_pair_begin();
// terminate the while loop when at least one "start" iterator is at the
// end of the list
while( r_it0 != this->end() && r_it1 != range2.end() )
// case a: pair wholly within subtracted pair
if( r_it0->first >= r_it1->first && r_it0->second <= r_it1->second )
Range::PairNode* rtmp = r_it0.node();
++r_it0;
this->delete_pair_node( rtmp );
// case b: pair overlaps upper part of subtracted pair
else if( r_it0->first <= r_it1->second && r_it0->first >= r_it1->first )
r_it0->first = r_it1->second + 1;
++r_it1;
// case c: pair overlaps lower part of subtracted pair
else if( r_it0->second >= r_it1->first && r_it0->second <= r_it1->second )
r_it0->second = r_it1->first - 1;
++r_it0;
// case d: pair completely surrounds subtracted pair
else if( r_it0->first < r_it1->first && r_it0->second > r_it1->second )
Range::PairNode* new_node =
alloc_pair( r_it0.node(), r_it0.node()->mPrev, r_it0->first, r_it1->first - 1 );
r_it0.node()->first = r_it1->second + 1;
++r_it1;
else
while( r_it0->second < r_it1->first && r_it0 != this->end() )
++r_it0;
if( r_it0 == this->end() ) break;
while( r_it1->second < r_it0->first && r_it1 != range2.end() )
++r_it1;
return *this;
operator=
Definition at line 210 of file Range.cpp.
References alloc_pair(), clear(), mHead, moab::Range::PairNode::mNext, and moab::Range::PairNode::mPrev.
clear();
const PairNode* copy_node = copy.mHead.mNext;
PairNode* new_node = &mHead;
for( ; copy_node != &( copy.mHead ); copy_node = copy_node->mNext )
PairNode* tmp_node = alloc_pair( new_node->mNext, new_node, copy_node->first, copy_node->second );
new_node->mNext->mPrev = tmp_node;
new_node->mNext = tmp_node;
new_node = tmp_node;
return *this;
| EntityHandle moab::Range::operator[] | ( | EntityID | index | ) | const [inline] |
| pair_iterator moab::Range::pair_begin | ( | ) | [inline] |
Definition at line 739 of file Range.hpp.
Referenced by moab::ReadUtil::assign_ids(), moab::NCHelperScrip::create_mesh(), moab::DataCoupler::DataCoupler(), moab::UcdNCWriteHelper::jik_to_kji_stride(), moab::UcdNCHelper::kji_to_jik_stride(), operator-=(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::subtract(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteHOMME::write_nonset_variables(), and moab::NCWriteMPAS::write_nonset_variables().
| const_pair_iterator moab::Range::pair_begin | ( | ) | const [inline] |
| pair_iterator moab::Range::pair_end | ( | ) | [inline] |
Definition at line 743 of file Range.hpp.
Referenced by moab::ReadUtil::assign_ids(), moab::NCHelperScrip::create_mesh(), moab::DataCoupler::DataCoupler(), moab::UcdNCWriteHelper::jik_to_kji_stride(), moab::UcdNCHelper::kji_to_jik_stride(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), and moab::NCWriteMPAS::write_nonset_variables().
return pair_iterator( &mHead );
| const_pair_iterator moab::Range::pair_end | ( | ) | const [inline] |
remove last entity from range
Definition at line 494 of file Range.cpp.
References back(), delete_pair_node(), mHead, and moab::Range::PairNode::mPrev.
Referenced by moab::DualTool::delete_dual_entities(), MetisPartitioner::write_aggregationtag_partition(), MetisPartitioner::write_partition(), and ZoltanPartitioner::write_partition().
remove first entity from range
Definition at line 482 of file Range.cpp.
References delete_pair_node(), front(), mHead, and moab::Range::PairNode::mNext.
Referenced by moab::GeomTopoTool::insert_in_tree(), and test_read_nodes_common().
| void moab::Range::print | ( | const char * | indent_prefix = NULL | ) | const |
Definition at line 618 of file Range.cpp.
Referenced by moab::MeshGeneration::BrickInstance(), moab::ParallelComm::list_entities(), main(), moab::operator<<(), moab::ParallelComm::pack_tag(), moab::Core::print(), report_nsets(), and test_adjacencies().
print( std::cout, indent_prefix );
| void moab::Range::print | ( | std::ostream & | s, |
| ) | const |
| size_t moab::Range::psize | ( | ) | const [inline] |
return the number of range pairs in the list
Definition at line 979 of file Range.hpp.
References const_pair_begin(), and const_pair_end().
Referenced by moab::RangeSetIterator::build_pair_vec(), moab::SpectralMeshTool::convert_to_coarse(), moab::convert_to_ranged_ids(), moab::NCHelperScrip::create_mesh(), moab::ParallelComm::gather_data(), gather_one_cell_var(), moab::ReadHDF5::load_file_partial(), moab::merge_ranged_ids(), multiple_loads_of_same_file(), moab::PACK_RANGE(), moab::ReadDamsel::process_ent_info(), moab::RANGE_SIZE(), moab::ReadHDF5::read_elems(), read_mesh_parallel(), read_one_cell_var(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), test_gather_onevar(), test_iterates(), test_read_all(), test_read_no_mixed_elements(), test_read_novars(), test_read_onevar(), test_sequences_after_ghosting(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteHOMME::write_nonset_variables(), and moab::NCWriteMPAS::write_nonset_variables().
size_t i = 0;
Range::const_pair_iterator pit;
for( pit = const_pair_begin(), i = 0; pit != const_pair_end(); ++pit, i++ )
return i;
| Range::const_reverse_iterator moab::Range::rbegin | ( | ) | const [inline] |
return the beginning const reverse iterator of this range
Definition at line 866 of file Range.hpp.
References mHead, and moab::Range::PairNode::mPrev.
Referenced by moab::SpatialLocator::add_elems(), MetisPartitioner::assemble_taggedsets_graph(), moab::DualTool::atomic_pillow(), moab::ParallelComm::check_clean_iface(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), SphereDecomp::compute_nodes(), moab::ParCommGraph::compute_partition(), moab::DualTool::construct_dual_cells(), moab::DualTool::construct_dual_edges(), moab::DualTool::construct_dual_faces(), moab::DualTool::construct_dual_vertices(), moab::ParallelComm::create_iface_pc_links(), moab::SpatialLocator::create_tree(), moab::DataCoupler::DataCoupler(), moab::Core::delete_entities(), moab::DualTool::delete_whole_dual(), DeformMeshRemap::find_other_sets(), moab::DualTool::foc_get_ents(), get_ents(), index(), moab::OrientedBoxTreeTool::join_trees(), moab::WriteGMV::local_write_mesh(), moab::SpatialLocator::locate_points(), moab::DualTool::next_loop_vertex(), moab::GeomTopoTool::other_entity(), moab::ParallelComm::pack_entities(), ZoltanPartitioner::partition_owned_cells(), moab::LloydSmoother::perform_smooth(), moab::ReadTemplate::read_elements(), DeformMeshRemap::read_file(), moab::Tqdcfr::read_nodes(), moab::ParallelComm::resolve_shared_ents(), moab::DualTool::rev_atomic_pillow(), moab::ParallelComm::set_pstatus_entities(), moab::SpatialLocator::SpatialLocator(), moab::split_box(), moab::MeshTopoUtil::split_entities_manifold(), tag_depth(), moab::ParallelMergeMesh::TagSharedElements(), test_bit_tag_big(), test_filter_pstatus(), test_root_sets_resize(), moab::ParallelComm::unpack_sets(), moab::WriteCCMIO::write_external_faces(), and moab::WriteGmsh::write_file().
| Range::const_reverse_iterator moab::Range::rend | ( | ) | const [inline] |
return the ending const reverse iterator for this range
Definition at line 878 of file Range.hpp.
References mHead.
Referenced by moab::ParallelComm::check_clean_iface(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::Core::delete_entities(), moab::DualTool::delete_whole_dual(), moab::OrientedBoxTreeTool::join_trees(), moab::split_box(), moab::DualTool::split_pair_nonmanifold(), tag_depth(), test_bit_tag_big(), test_root_sets_resize(), and moab::WriteGmsh::write_file().
| void moab::Range::sanity_check | ( | ) | const |
check for internal consistency
Definition at line 554 of file Range.cpp.
References empty(), mHead, moab::Range::PairNode::mNext, and moab::Range::PairNode::mPrev.
if( empty() ) return;
const PairNode* node = mHead.mNext;
std::vector< const PairNode* > seen_before;
bool stop_it = false;
for( ; stop_it == false; node = node->mNext )
// have we seen this node before?
assert( std::find( seen_before.begin(), seen_before.end(), node ) == seen_before.end() );
seen_before.push_back( node );
// is the connection correct?
assert( node->mNext->mPrev == node );
// are the values right?
assert( node->first <= node->second );
if( node != &mHead && node->mPrev != &mHead ) assert( node->mPrev->second < node->first );
if( node == &mHead ) stop_it = true;
| size_t moab::Range::size | ( | ) | const |
return the number of values this Ranges represents
returns the number of values this list represents
Definition at line 77 of file Range.cpp.
Referenced by add_dead_elems_to_impl_compl(), add_field_value(), smoab::detail::LoadPoly::addCoordinates(), smoab::detail::LoadGeometry::addCoordinates(), adj_perf(), ahf_test(), moab::TempestOnlineMap::ApplyWeights(), moab::IntxAreaUtils::area_on_sphere(), MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::ParallelComm::assign_global_ids(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::DualTool::atomic_pillow(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ReadMCNP5::average_with_existing_tally(), moab::AdaptiveKDTree::best_subdivision_plane(), moab::AdaptiveKDTree::best_subdivision_snap_plane(), moab::AdaptiveKDTree::best_vertex_median_plane(), moab::AdaptiveKDTree::best_vertex_sample_plane(), moab::WriteSTL::binary_write_triangles(), moab::FBEngine::boundary_nodes_on_face(), moab::MeshGeneration::BrickInstance(), moab::BVHTree::build_tree(), moab::OrientedBoxTreeTool::build_tree(), moab::AxisBox::calculate(), check_bit_tag(), check_children(), moab::WriteHDF5::check_dense_format_tag(), moab::DualTool::check_dual_adjs(), moab::DualTool::check_dual_equiv_edges(), moab::AEntityFactory::check_equiv_entities(), moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperGCRM::check_existing_mesh(), moab::NCHelperMPAS::check_existing_mesh(), check_geometric_set(), check_identical_mesh(), check_mesh_is_tet(), moab::HalfFacetRep::check_mixed_entity_type(), moab::GeomTopoTool::check_model(), check_node_coords(), check_num_verts(), check_order(), check_order_by_sets_and_adj(), moab::ParallelComm::check_sent_ents(), check_shared_ents(), check_tree(), check_varlen_tag(), moab::Skinner::classify_2d_boundary(), moab::FBEngine::clean(), moab::ParallelComm::clean_shared_tags(), closedsurface_uref_hirec_convergence_study(), moab::OrientedBoxTreeTool::closest_to_location(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteHOMME::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::ParallelComm::collective_sync_partition(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), compactness(), compare(), compare_set_contents(), compare_sets(), compute_dual_mesh(), compute_lagrange_mesh_on_sphere(), compute_normals(), moab::ParCommGraph::compute_partition(), compute_velocity_case1(), moab::TempestRemapper::ComputeGlobalLocalMaps(), moab::TempestOnlineMap::ComputeMetrics(), moab::TempestRemapper::ComputeOverlapMesh(), moab::DualTool::construct_dual(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::DualTool::construct_hp_parent_child(), moab::DualTool::construct_new_hyperplane(), moab::TempestRemapper::ConstructCoveringSet(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::Tqdcfr::convert_nodesets_sidesets(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::SpectralMeshTool::convert_to_coarse(), moab::TempestRemapper::ConvertMeshToTempest(), moab::NestedRefine::copy_vertices_from_prev_level(), count_owned(), count_owned_entities(), moab::HalfFacetRep::count_subentities(), moab::ReadCCMIO::create_cell_from_faces(), create_coarse_mesh(), moab::ReadIDEAS::create_elements(), moab::ReadMCNP5::create_elements(), create_fine_mesh(), moab::NCHelperMPAS::create_gather_set_cells(), moab::ParallelComm::create_iface_pc_links(), moab::ReadABAQUS::create_instance_of_part(), create_int_ents(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::WriteHDF5Parallel::create_meshset_tables(), moab::FBEngine::create_new_gedge(), moab::WriteHDF5Parallel::create_node_table(), moab::ReadParallel::create_partition_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), IntxUtilsCSLAM::create_span_quads(), moab::WriteHDF5Parallel::create_tag_tables(), moab::Coupler::create_tuples(), moab::ReadMCNP5::create_vertices(), moab::Intx2Mesh::createTags(), cube_edge_adjacencies_test(), cube_tri_curve_coincidence_test(), cube_tri_vertex_test(), cube_tris_connectivity_test(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::Skinner::deinitialize(), moab::ParallelComm::delete_entities(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), do_file(), do_ray_fire_test(), do_test_mode(), moab::ParCommGraph::dump_comm_information(), moab::GeomTopoTool::duplicate_model(), erase_test(), moab::NestedRefine::estimate_hm_storage(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), DeformMeshRemap::execute(), FBiGeom_getArrAdj(), FBiGeom_getEnt2ndAdj(), FBiGeom_getEntAdj(), FBiGeom_getEntities(), FBiGeom_getEntSets(), FBiGeom_getNumEntSets(), smoab::detail::ReadSparseTag::fill(), moab::ParallelComm::filter_pstatus(), moab::Tree::find_all_trees(), moab::ScdInterface::find_boxes(), moab::Skinner::find_geometric_skin(), moab::MergeMesh::find_merged_to(), find_sideset(), moab::Skinner::find_skin_scd(), moab::Skinner::find_skin_vertices(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), smoab::findFaceSets(), fix_surface_senses(), moab::DualTool::foc_get_ents(), moab::ParCommGraph::form_mesh_from_tuples(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), moab::DualTool::fs_get_quad_loops(), moab::DualTool::fs_get_quads(), moab::DualTool::fsr_get_fourth_quad(), moab::ParallelComm::gather_data(), moab::WriteSLAC::gather_interior_exterior(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), gather_one_cell_var(), moab::ReadUtil::gather_related_ents(), gather_related_test(), generate_random_points(), moab::TempestRemapper::GenerateMeshMetadata(), gentityset_test(), moab::GeomTopoTool::geometrize_surface_set(), geometry_evaluation_test(), moab::ScdBox::get_adj_edge_or_face(), moab::MeshTopoUtil::get_average_position(), moab::Core::get_connectivity(), moab::Core::get_connectivity_by_type(), EntityCount::get_counts(), moab::DenseTag::get_data(), moab::SparseTag::get_data(), moab::AEntityFactory::get_down_adjacency_elements_poly(), moab::DualTool::get_dual_entities(), moab::ReadABAQUS::get_elements_by_id(), get_entities(), moab::Core::get_entities_by_handle(), get_expected_ghosts(), get_ghost_entities(), moab::WriteCCMIO::get_gids(), moab::Coupler::get_gl_points_on_elements(), moab::DualTool::get_graphics_points(), get_imesh_mesh(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), get_intersection_weights(), get_linear_reconstruction(), moab::ParallelComm::get_local_handles(), moab::MeshTopoUtil::get_manifold(), moab::Coupler::get_matching_entities(), moab::Tqdcfr::get_mesh_entities(), moab::ReorderTool::get_new_handles(), moab::WriteUtil::get_node_coords(), moab::ReadABAQUS::get_nodes_by_id(), moab::WriteHDF5::get_num_sparse_tagged_entities(), moab::Core::get_number_entities_by_type_and_tag(), moab::DualTool::get_opposite_verts(), moab::ReadHDF5::get_partition(), moab::ParallelComm::get_pstatus_entities(), moab::ParallelComm::get_remote_handles(), moab::ReorderTool::get_reordered_handles(), moab::ReadABAQUS::get_set_elements_by_name(), moab::ReadABAQUS::get_set_nodes(), moab::WriteHDF5::get_tag_data_length(), get_vartag_data(), moab::FBEngine::get_vert_edges(), moab::Core::get_vertex_coordinates(), moab::NestedRefine::get_vertex_duplicates(), moab::FBEngine::getEgVtxSense(), moab::TempestRemapper::GetIMasks(), moab::FBEngine::getNumOfType(), moab::TempestRemapper::GetOverlapAugmentedEntities(), moab::FBEngine::getPntRayIntsct(), moab::FBEngine::getVtxCoord(), moab::ReorderTool::handle_order_from_int_tag(), hcFilter(), identify_set(), iMesh_getEntArr2ndAdj(), iMesh_getEntsByTagsRec(), iMesh_getEntSetsByTagsRec(), iMeshP_getAdjEntities(), iMeshP_getNumLocalParts(), iMeshP_getNumOfTopo(), iMeshP_getNumOfType(), iMeshP_getNumPartBdryEnts(), iMOAB_GetBlockID(), iMOAB_GetBlockInfo(), iMOAB_GetDoubleTagStorage(), iMOAB_GetElementConnectivity(), iMOAB_GetElementID(), iMOAB_GetElementOwnership(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_GetNeighborElements(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexID(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleVerticesCoordinates(), iMOAB_SetDoubleTagStorage(), iMOAB_SetDoubleTagStorageWithGid(), iMOAB_SetIntTagStorage(), iMOAB_UpdateMeshInfo(), ZoltanPartitioner::include_closure(), moab::SmoothFace::init_gradient(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::LloydSmoother::initialize(), initialize_area_and_tracer(), moab::WriteNCDF::initialize_exodus_file(), moab::WriteSLAC::initialize_file(), moab::FBEngine::initializeSmoothing(), moab::GeomTopoTool::insert_in_tree(), moab::DataCoupler::interpolate(), moab::AdaptiveKDTree::intersect_children_with_elems(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), intersect_test(), moab::SmoothCurve::is_periodic(), laplacianFilter(), TriStats::leaf(), smoab::detail::LinearCellConnectivity::LinearCellConnectivity(), moab::ReadVtk::load_file(), moab::ReadParallel::load_file(), moab::ReadSms::load_file_impl(), moab::ReadHDF5::load_file_partial(), moab::ReadMCNP5::load_one_file(), moab::WriteGMV::local_write_mesh(), moab::SpatialLocator::locate_points(), moab::Coupler::locate_points(), main(), manufacture_lagrange_mesh_on_sphere(), moab::WriteDamsel::map_sparse_tags(), match_tri_edges_w_curve(), match_vertices_and_elements(), mb_adjacencies_create_delete_test(), mb_bit_tags_test(), mb_common_tag_test(), mb_merge_update_test(), mb_mesh_set_flag_test(), mb_mesh_set_list_replace_test(), mb_mesh_set_set_replace_test(), mb_mesh_sets_test(), mb_poly_test(), mb_root_set_test(), mb_skin_curve_test_common(), mb_skin_fileset_test(), mb_skin_full_common(), mb_skin_higher_order_faces_common(), mb_skin_higher_order_regions_common(), mb_skin_poly_test(), mb_skin_reversed_common(), mb_skin_subset_common(), mb_skin_surface_test_common(), mb_skin_volume_test_common(), mb_split_test(), mb_topo_util_test(), mb_type_is_maxtype_test(), mb_vertex_coordinate_test(), mb_write_mesh_test(), moab::MergeMesh::merge_higher_dimensions(), merge_input_surfs(), merge_test(), moab::MergeMesh::merge_using_integer_tag(), merge_with_tag_test(), smoab::detail::MixedCellConnectivity::MixedCellConnectivity(), multiple_loads_of_same_file(), normals_test(), moab::MeshSetSequence::num_dimension(), moab::MeshSetSequence::num_entities(), moab::GeomTopoTool::num_ents_of_dim(), moab::DenseTag::num_tagged_entities(), moab::MeshSetSequence::num_type(), obbstat_write(), obbvis_create(), moab::HiReconstruction::obtain_nring_ngbvs(), moab::DualTool::order_chord(), orient_faces_outward(), moab::GeomTopoTool::other_entity(), overlap_test_measure_area(), overlap_test_measure_volume(), overlap_test_point_in_volume(), overlap_test_ray_fire(), overlap_test_surface_sense(), overlap_test_tracking(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_tag(), moab::ParallelComm::pack_tags(), pack_unpack_noremoteh(), moab::ParallelComm::packed_tag_size(), parallel_create_mesh(), ZoltanPartitioner::partition_inferred_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::LloydSmoother::perform_smooth(), moab::HiReconstruction::polyfit3d_walf_curve_vertex(), moab::HiReconstruction::polyfit3d_walf_surf_vertex(), moab::AdaptiveKDTree::print(), moab::TreeNodePrinter::print_contents(), print_file_stats(), print_partitioned_entities(), moab::print_type_sets(), moab::ReadDamsel::process_ent_info(), moab::ReadDamsel::process_entity_tags(), process_partition_file(), project_exact_torus(), put_random_field(), moab::putElementField(), moab::putSpectralElementField(), moab::putVertexField(), quads_to_tris(), query_elem_to_vert_direct(), query_vert_to_elem_direct(), smoab::RangeToVector(), read_cylcube_curve_senses_test(), read_cylcube_groups_test(), read_cylcube_surf_senses_test(), moab::ReadHDF5VarLen::read_data(), moab::ReadABAQUS::read_element_list(), moab::ReadHDF5::read_elems(), DeformMeshRemap::read_file(), McnpData::read_mcnpfile(), read_mesh_parallel(), moab::ReadABAQUS::read_node_list(), moab::ReadHDF5::read_nodes(), moab::ReadHDF5VarLen::read_offsets(), read_one_cell_var(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadHDF5::read_set_data(), read_sets(), moab::ReadHDF5::read_sets(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag_values_partial(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), smoab::DataSetConverter::readDenseTags(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), recursive_check_tree(), moab::ParallelComm::reduce_tags(), refine_entities(), regression_mmiller_8_2010(), regression_one_entity_by_var_tag(), moab::ReorderTool::reorder_entities(), moab::ReorderTool::reorder_tag_data(), replace_faceted_cgm_surfs(), replace_surface(), report_iface_ents(), report_nsets(), report_sets(), moab::ParallelComm::resolve_shared_ents(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), moab::DualTool::rev_atomic_pillow(), moab::ParallelComm::send_entities(), moab::ParCommGraph::send_tag_values(), moab::FBEngine::separate(), moab::GeomTopoTool::separate_by_dimension(), moab::WriteHDF5::serial_create_file(), moab::VarLenSparseTag::set_data(), moab::SparseTag::set_data(), moab::VarLenDenseTag::set_data(), set_density(), set_departure_points_position(), moab::ParallelComm::set_pstatus_entities(), moab::ParCommGraph::set_split_ranges(), moab::ParallelComm::settle_intersection_points(), moab::GeomTopoTool::setup_implicit_complement(), setup_mesh(), skin_common(), moab::FBEngine::smooth_new_intx_points(), moab::FBEngine::split_bedge_at_new_mesh_node(), moab::FBEngine::split_edge_at_mesh_node(), moab::FBEngine::split_internal_edge(), split_quads_test(), moab::FBEngine::split_surface_with_direction(), split_test_across(), moab::MeshTopoUtil::star_next_entity(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), subset_by_dimension_test(), subtract_test(), swap_test(), tag_depth(), tag_elements(), moab::Core::tag_get_by_ptr(), moab::ParallelComm::tag_iface_entities(), moab::Core::tag_set_by_ptr(), moab::ScdInterface::tag_shared_vertices(), tag_time(), tag_vertices(), test_adjacencies(), test_assign_global_ids(), test_bc_sets(), test_bit_tag_big(), test_blocks(), test_boolean(), test_check_meshsets(), test_closedsurface_mesh(), test_closest_to_location(), test_coords_connect_iterate(), test_delete_entities(), test_delete_tag_data(), test_element(), test_elements(), test_file_set(), test_filter_pstatus(), test_gather_onevar(), test_gather_sets_ranged(), test_geometric_sets(), test_get_by_tag(), test_get_by_tag_value(), test_get_by_tag_value_dense(), test_get_entity_tags(), test_get_ents_with_default_value(), test_get_set(), test_get_set_bit(), test_get_set_variable_length(), test_ghost_elements(), test_ghost_tag_exchange(), test_global_value_common(), test_linear_tet(), test_list_set_with_stale_handles(), test_measure_area(), test_measure_volume(), test_mesh(), test_moab_v3_poly_format(), test_multiple_files(), test_pack_elements(), test_pack_higher_order(), test_pack_poly(), test_pack_set_contents(), test_pack_set_parent_child(), test_pack_sets_of_sets(), test_pack_sets_simple(), test_pack_tag_data_sparse(), test_pack_vertices(), test_point_in_volume(), test_polyhedra(), test_ranged_set_with_stale_handles(), test_ray_fire(), test_read_adjacencies(), test_read_all(), test_read_alternate_coord_format(), test_read_bc_sets(), test_read_conn(), test_read_elements_common(), test_read_eul_onevar(), test_read_fgh(), test_read_fv_onevar(), test_read_geom_set(), test_read_material_on_nodes(), test_read_material_set(), test_read_material_set1(), test_read_material_set2(), test_read_no_edges(), test_read_no_mixed_elements(), test_read_nodes_common(), test_read_nothing_common(), test_read_novars(), test_read_one_set_polyhedra(), test_read_onevar(), test_read_parallel(), test_read_physical_set(), test_read_set_contents(), test_read_set_sets(), test_read_sets_common(), test_read_side(), test_read_sides(), test_read_two_sets_elems(), test_read_vertices(), test_reduce_tag_explicit_dest(), test_reduce_tags(), test_scd_invalid(), test_sequences_after_ghosting(), test_set_flags(), test_sets_fileids(), test_spectral_hex(), test_spectral_quad(), test_subset(), test_surface_sense(), test_tag_iterate_common(), test_tree(), test_tree_readwrite(), test_trivial_partition(), test_var_length_big_data(), test_var_length_handle_tag(), test_vertices(), test_write_dense_tags(), test_write_shared_sets(), test_write_unbalanced(), moab::DualTool::traverse_hyperplane(), umr_perf_test(), moab::ParallelComm::unpack_sets(), moab::ReadNCDF::update(), update_density(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::ReorderTool::update_set_contents(), moab::Intx2MeshOnSphere::update_tracer_data(), update_tracer_test(), TreeValidator::visit(), moab::RayIntersectSets::visit(), moab::TreeNodePrinter::visit(), volume_test(), moab::ReadVtk::vtk_read_unstructured_grid(), MetisPartitioner::write_aggregationtag_partition(), moab::WriteVtk::write_bit_tag(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteHDF5::write_dense_tag(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteHDF5::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteGmsh::write_file(), moab::Core::write_file(), moab::WriteHDF5::write_file_impl(), moab::WriteSLAC::write_matsets(), moab::WriteVtk::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::WriteHDF5::write_nodes(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), MetisPartitioner::write_partition(), ZoltanPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteHDF5::write_sets(), moab::WriteHDF5::write_sparse_ids(), moab::WriteHDF5::write_sparse_tag(), moab::WriteVtk::write_tag(), moab::WriteHDF5::write_tag_values(), moab::WriteVtk::write_tags(), DeformMeshRemap::write_to_coords(), write_tree_blocks(), moab::WriteHDF5::write_var_len_indices(), and moab::WriteHDF5::write_var_len_tag().
| const std::string moab::Range::str_rep | ( | const char * | indent_prefix = NULL | ) | const |
for debugging
Definition at line 579 of file Range.cpp.
References const_pair_begin(), const_pair_end(), empty(), moab::CN::EntityTypeName(), moab::ID_FROM_HANDLE(), and moab::TYPE_FROM_HANDLE().
Referenced by print().
std::stringstream str_stream;
std::string indent_prefix_str;
if( NULL != indent_prefix )
indent_prefix_str += indent_prefix;
if( empty() )
str_stream << indent_prefix_str << "\tempty" << std::endl;
return str_stream.str().c_str();
for( const_pair_iterator i = const_pair_begin(); i != const_pair_end(); ++i )
EntityType t1 = TYPE_FROM_HANDLE( i->first );
EntityType t2 = TYPE_FROM_HANDLE( i->second );
str_stream << indent_prefix_str << "\t" << CN::EntityTypeName( t1 ) << " " << ID_FROM_HANDLE( i->first );
if( i->first != i->second )
str_stream << " - ";
if( t1 != t2 ) str_stream << CN::EntityTypeName( t2 ) << " ";
str_stream << ID_FROM_HANDLE( i->second );
str_stream << std::endl;
return str_stream.str();
| Range moab::Range::subset_by_dimension | ( | int | dim | ) | const |
return a subset of this range, by dimension
return a subset of this range, by type
Definition at line 966 of file Range.cpp.
References begin(), moab::CREATE_HANDLE(), end(), moab::GeomUtil::first(), insert(), lower_bound(), and moab::CN::TypeDimensionMap.
Referenced by moab::ParCommGraph::compute_partition(), moab::SpectralMeshTool::convert_to_coarse(), DeformMeshRemap::find_other_sets(), moab::WriteNCDF::gather_mesh_information(), moab::ParallelComm::get_ghosted_entities(), get_max_volume(), moab::ReadParallel::load_file(), main(), DeformMeshRemap::read_file(), moab::ParCommGraph::receive_mesh(), refine_entities(), subset_by_dimension_test(), and test_adjacencies().
EntityHandle handle1 = CREATE_HANDLE( CN::TypeDimensionMap[d].first, 0 );
iterator st = lower_bound( begin(), end(), handle1 );
iterator en;
if( d < 4 )
{ // dimension 4 is MBENTITYSET
EntityHandle handle2 = CREATE_HANDLE( CN::TypeDimensionMap[d + 1].first, 0 );
en = lower_bound( st, end(), handle2 );
else
en = end();
Range result;
result.insert( st, en );
return result;
| Range moab::Range::subset_by_type | ( | EntityType | t | ) | const |
Definition at line 957 of file Range.cpp.
References equal_range(), and insert().
Referenced by moab::ParallelComm::add_verts(), moab::HalfFacetRep::check_mixed_entity_type(), cube_tris_connectivity_test(), moab::ReadParallel::delete_nonlocal_entities(), moab::ParallelComm::exchange_owned_meshs(), iMOAB_DeregisterApplication(), moab::Coupler::locate_points(), main(), mb_range_seq_intersect_test(), mb_skin_higher_order_pyramids(), moab::MergeMesh::merge_all(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_sets(), pack_unpack_noremoteh(), moab::Tqdcfr::read_nodes(), moab::ParCommGraph::receive_mesh(), and moab::WriteVtk::write_elems().
Range result;
std::pair< const_iterator, const_iterator > iters = equal_range( t );
result.insert( iters.first, iters.second );
return result;
| void moab::Range::swap | ( | Range & | range | ) |
swap the contents of this range with another one
swap the contents of this range with another one THIS FUNCTION MUST NOT BE INLINED, THAT WILL ELIMINATE RANGE_EMPTY AND THIS_EMPTY BY SUBSTITUTION AND THE FUNCTION WON'T WORK RIGHT!
Definition at line 937 of file Range.cpp.
References mHead, moab::Range::PairNode::mNext, and moab::Range::PairNode::mPrev.
Referenced by moab::AdaptiveKDTree::best_subdivision_plane(), moab::AdaptiveKDTree::best_subdivision_snap_plane(), moab::AdaptiveKDTree::best_vertex_median_plane(), moab::AdaptiveKDTree::best_vertex_sample_plane(), moab::OrientedBoxTreeTool::build_tree(), moab::ReadParallel::delete_nonlocal_entities(), dot_nodes(), moab::MeshTopoUtil::equivalent_entities(), moab::ParallelComm::filter_pstatus(), moab::Skinner::find_skin(), moab::Core::get_entities_by_type_and_tag(), moab::ReadHDF5::get_subset_ids(), moab::Core::get_vertices(), moab::DualTool::next_loop_vertex(), print_partitioned_entities(), moab::WriteHDF5Parallel::remove_remote_entities(), moab::WriteHDF5Parallel::remove_remote_sets(), moab::ParallelComm::resolve_shared_sets(), swap_test(), test_ghost_elements(), MetisPartitioner::write_aggregationtag_partition(), MetisPartitioner::write_partition(), and ZoltanPartitioner::write_partition().
// update next/prev nodes of head of both ranges
bool range_empty = ( range.mHead.mNext == &( range.mHead ) );
bool this_empty = ( mHead.mNext == &mHead );
range.mHead.mNext->mPrev = ( range_empty ? &( range.mHead ) : &mHead );
range.mHead.mPrev->mNext = ( range_empty ? &( range.mHead ) : &mHead );
mHead.mNext->mPrev = ( this_empty ? &mHead : &( range.mHead ) );
mHead.mPrev->mNext = ( this_empty ? &mHead : &( range.mHead ) );
// switch data in head nodes of both ranges
PairNode *range_next = range.mHead.mNext, *range_prev = range.mHead.mPrev;
range.mHead.mNext = ( this_empty ? &( range.mHead ) : mHead.mNext );
range.mHead.mPrev = ( this_empty ? &( range.mHead ) : mHead.mPrev );
mHead.mNext = ( range_empty ? &mHead : range_next );
mHead.mPrev = ( range_empty ? &mHead : range_prev );
| Range::const_iterator moab::Range::upper_bound | ( | Range::const_iterator | first, |
| ) | [static] |
Definition at line 832 of file Range.cpp.
References lower_bound().
Referenced by MetisPartitioner::assemble_taggedsets_graph(), moab::AxisBox::calculate(), moab::ParallelComm::check_my_shared_handles(), moab::OrientedBox::compute_from_vertices(), moab::Skinner::find_skin_vertices_3D(), moab::ReadHDF5::get_partition(), moab::ParallelComm::get_shared_entities(), moab::Core::get_vertices(), identify_set(), iMesh_createStructuredMesh(), mb_mesh_set_appends(), min_edge_length(), moab::ParallelComm::resolve_shared_ents(), and moab::ParallelMergeMesh::TagSharedElements().
Range::const_iterator result = lower_bound( first, last, val );
if( result != last && *result == val ) ++result;
return result;
| const_iterator moab::Range::upper_bound | ( | EntityHandle | val | ) | const [inline] |
Definition at line 310 of file Range.hpp.
return upper_bound( begin(), end(), val );
| Range::const_iterator moab::Range::upper_bound | ( | EntityType | type | ) | const |
Definition at line 852 of file Range.cpp.
References begin(), moab::CREATE_HANDLE(), end(), and lower_bound().
// if (type+1) overflows, err will be true and we return end().
int err;
EntityHandle handle = CREATE_HANDLE( type + 1, 0, err );
| Range::const_iterator moab::Range::upper_bound | ( | EntityType | type, |
| ) | const |
Definition at line 859 of file Range.cpp.
int err;
intersect two ranges, placing the results in the return range
subtract range2 from this, placing the results in the return range
PairNode moab::Range::mHead [protected] |
the head of the list that contains pairs that represent the ranges this list is sorted and unique at all times
Definition at line 392 of file Range.hpp.
Referenced by back(), begin(), clear(), contains(), delete_pair_node(), empty(), end(), erase(), find(), front(), get_memory_use(), insert(), operator=(), pop_back(), pop_front(), Range(), rbegin(), rend(), sanity_check(), size(), and swap().
