MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <cmath> 00002 #include "moab/ReadUtilIface.hpp" 00003 #include "IntxUtilsCSLAM.hpp" 00004 00005 using namespace moab; 00006 00007 #ifndef CORRTAGNAME 00008 #define CORRTAGNAME "__correspondent" 00009 #endif 00010 00011 // page 4 Nair Lauritzen paper 00012 // param will be: (la1, te1), (la2, te2), b, c; hmax=1, r=1/2 00013 double IntxUtilsCSLAM::quasi_smooth_field( double lam, double tet, double* params ) 00014 { 00015 double la1 = params[0]; 00016 double te1 = params[1]; 00017 double la2 = params[2]; 00018 double te2 = params[3]; 00019 double b = params[4]; 00020 double c = params[5]; 00021 double hmax = params[6]; // 1; 00022 double r = params[7]; // 0.5; 00023 double r1 = moab::IntxUtils::distance_on_sphere( lam, tet, la1, te1 ); 00024 double r2 = moab::IntxUtils::distance_on_sphere( lam, tet, la2, te2 ); 00025 double value = b; 00026 if( r1 < r ) 00027 { 00028 value += c * hmax / 2 * ( 1 + cos( M_PI * r1 / r ) ); 00029 } 00030 if( r2 < r ) 00031 { 00032 value += c * hmax / 2 * ( 1 + cos( M_PI * r2 / r ) ); 00033 } 00034 return value; 00035 } 00036 00037 // page 4 00038 // params are now x1, y1, ..., y2, z2 (6 params) 00039 // plus h max and b0 (total of 8 params); radius is 1 00040 double IntxUtilsCSLAM::smooth_field( double lam, double tet, double* params ) 00041 { 00042 moab::IntxUtils::SphereCoords sc; 00043 sc.R = 1.; 00044 sc.lat = tet; 00045 sc.lon = lam; 00046 double hmax = params[6]; 00047 double b0 = params[7]; 00048 CartVect xyz = moab::IntxUtils::spherical_to_cart( sc ); 00049 CartVect c1( params ); 00050 CartVect c2( params + 3 ); 00051 double expo1 = -b0 * ( xyz - c1 ).length_squared(); 00052 double expo2 = -b0 * ( xyz - c2 ).length_squared(); 00053 return hmax * ( exp( expo1 ) + exp( expo2 ) ); 00054 } 00055 00056 // page 5 00057 double IntxUtilsCSLAM::slotted_cylinder_field( double lam, double tet, double* params ) 00058 { 00059 double la1 = params[0]; 00060 double te1 = params[1]; 00061 double la2 = params[2]; 00062 double te2 = params[3]; 00063 double b = params[4]; 00064 double c = params[5]; 00065 // double hmax = params[6]; // 1; 00066 double r = params[6]; // 0.5; 00067 double r1 = moab::IntxUtils::distance_on_sphere( lam, tet, la1, te1 ); 00068 double r2 = moab::IntxUtils::distance_on_sphere( lam, tet, la2, te2 ); 00069 double value = b; 00070 double d1 = fabs( lam - la1 ); 00071 double d2 = fabs( lam - la2 ); 00072 double rp6 = r / 6; 00073 double rt5p12 = r * 5 / 12; 00074 00075 if( r1 <= r && d1 >= rp6 ) value = c; 00076 if( r2 <= r && d2 >= rp6 ) value = c; 00077 if( r1 <= r && d1 < rp6 && tet - te1 < -rt5p12 ) value = c; 00078 if( r2 <= r && d2 < rp6 && tet - te2 > rt5p12 ) value = c; 00079 00080 return value; 00081 } 00082 00083 /* 00084 * based on paper A class of deformational flow test cases for linear transport problems on the 00085 * sphere longitude lambda [0.. 2*pi) and latitude theta (-pi/2, pi/2) lambda: -> lon (0, 2*pi) 00086 * theta : -> lat (-pi/2, po/2) 00087 * Radius of the sphere is 1 (if not, everything gets multiplied by 1) 00088 * 00089 * cosine bell: center lambda0, theta0: 00090 */ 00091 void IntxUtilsCSLAM::departure_point_case1( CartVect& arrival_point, 00092 double t, 00093 double delta_t, 00094 CartVect& departure_point ) 00095 { 00096 // always assume radius is 1 here? 00097 moab::IntxUtils::SphereCoords sph = moab::IntxUtils::cart_to_spherical( arrival_point ); 00098 double T = 5; // duration of integration (5 units) 00099 double k = 2.4; // flow parameter 00100 /* radius needs to be within some range */ 00101 double sl2 = sin( sph.lon / 2 ); 00102 double pit = M_PI * t / T; 00103 double omega = M_PI / T; 00104 double costetha = cos( sph.lat ); 00105 // double u = k * sl2*sl2 * sin(2*sph.lat) * cos(pit); 00106 double v = k * sin( sph.lon ) * costetha * cos( pit ); 00107 // double psi = k * sl2 * sl2 *costetha * costetha * cos(pit); 00108 double u_tilda = 2 * k * sl2 * sl2 * sin( sph.lat ) * cos( pit ); 00109 00110 // formula 35, page 8 00111 // this will approximate dep point using a Taylor series with up to second derivative 00112 // this will be O(delta_t^3) exact. 00113 double lon_dep = 00114 sph.lon - delta_t * u_tilda - 00115 delta_t * delta_t * k * sl2 * 00116 ( sl2 * sin( sph.lat ) * sin( pit ) * omega - u_tilda * sin( sph.lat ) * cos( pit ) * cos( sph.lon / 2 ) - 00117 v * sl2 * costetha * cos( pit ) ); 00118 // formula 36, page 8 again 00119 double lat_dep = sph.lat - delta_t * v - 00120 delta_t * delta_t / 4 * k * 00121 ( sin( sph.lon ) * cos( sph.lat ) * sin( pit ) * omega - 00122 u_tilda * cos( sph.lon ) * cos( sph.lat ) * cos( pit ) + 00123 v * sin( sph.lon ) * sin( sph.lat ) * cos( pit ) ); 00124 00125 moab::IntxUtils::SphereCoords sph_dep; 00126 sph_dep.R = 1.; // radius 00127 sph_dep.lat = lat_dep; 00128 sph_dep.lon = lon_dep; 00129 00130 departure_point = moab::IntxUtils::spherical_to_cart( sph_dep ); 00131 return; 00132 } 00133 00134 void IntxUtilsCSLAM::velocity_case1( CartVect& arrival_point, double t, CartVect& velo ) 00135 { 00136 // always assume radius is 1 here? 00137 moab::IntxUtils::SphereCoords sph = moab::IntxUtils::cart_to_spherical( arrival_point ); 00138 double T = 5; // duration of integration (5 units) 00139 double k = 2.4; // flow parameter 00140 /* radius needs to be within some range */ 00141 double sl2 = sin( sph.lon / 2 ); 00142 double pit = M_PI * t / T; 00143 // double omega = M_PI/T; 00144 double coslat = cos( sph.lat ); 00145 double sinlat = sin( sph.lat ); 00146 double sinlon = sin( sph.lon ); 00147 double coslon = cos( sph.lon ); 00148 double u = k * sl2 * sl2 * sin( 2 * sph.lat ) * cos( pit ); 00149 double v = k / 2 * sinlon * coslat * cos( pit ); 00150 velo[0] = -u * sinlon - v * sinlat * coslon; 00151 velo[1] = u * coslon - v * sinlat * sinlon; 00152 velo[2] = v * coslat; 00153 } 00154 00155 ErrorCode IntxUtilsCSLAM::create_span_quads( Interface* mb, EntityHandle euler_set, int rank ) 00156 { 00157 // first get all edges adjacent to polygons 00158 Tag dpTag = 0; 00159 std::string tag_name( "DP" ); 00160 ErrorCode rval = mb->tag_get_handle( tag_name.c_str(), 3, MB_TYPE_DOUBLE, dpTag, MB_TAG_DENSE ); 00161 // if the tag does not exist, get out early 00162 if( rval != MB_SUCCESS ) return rval; 00163 Range polygons; 00164 rval = mb->get_entities_by_dimension( euler_set, 2, polygons ); 00165 if( MB_SUCCESS != rval ) return rval; 00166 Range iniEdges; 00167 rval = mb->get_adjacencies( polygons, 1, false, iniEdges, Interface::UNION ); 00168 if( MB_SUCCESS != rval ) return rval; 00169 // now create some if missing 00170 Range allEdges; 00171 rval = mb->get_adjacencies( polygons, 1, true, allEdges, Interface::UNION ); 00172 if( MB_SUCCESS != rval ) return rval; 00173 // create the vertices at the DP points, and the quads after that 00174 Range verts; 00175 rval = mb->get_connectivity( polygons, verts ); 00176 if( MB_SUCCESS != rval ) return rval; 00177 int num_verts = (int)verts.size(); 00178 // now see the departure points; to what boxes should we send them? 00179 std::vector< double > dep_points( 3 * num_verts ); 00180 rval = mb->tag_get_data( dpTag, verts, (void*)&dep_points[0] ); 00181 if( MB_SUCCESS != rval ) return rval; 00182 00183 // create vertices corresponding to dp locations 00184 ReadUtilIface* read_iface; 00185 rval = mb->query_interface( read_iface ); 00186 if( MB_SUCCESS != rval ) return rval; 00187 std::vector< double* > coords; 00188 EntityHandle start_vert, start_elem, *connect; 00189 // create verts, num is 2(nquads+1) because they're in a 1d row; will initialize coords in loop 00190 // over quads later 00191 rval = read_iface->get_node_coords( 3, num_verts, 0, start_vert, coords ); 00192 if( MB_SUCCESS != rval ) return rval; 00193 // fill it up 00194 // Cppcheck warning (false positive): variable coords is assigned a value that is never used 00195 for( int i = 0; i < num_verts; i++ ) 00196 { 00197 // block from interleaved 00198 coords[0][i] = dep_points[3 * i]; 00199 coords[1][i] = dep_points[3 * i + 1]; 00200 coords[2][i] = dep_points[3 * i + 2]; 00201 } 00202 // create quads; one quad for each edge 00203 rval = read_iface->get_element_connect( allEdges.size(), 4, MBQUAD, 0, start_elem, connect ); 00204 if( MB_SUCCESS != rval ) return rval; 00205 00206 const EntityHandle* edge_conn = NULL; 00207 int quad_index = 0; 00208 EntityHandle firstVertHandle = verts[0]; // assume vertices are contiguous... 00209 for( Range::iterator eit = allEdges.begin(); eit != allEdges.end(); ++eit, quad_index++ ) 00210 { 00211 EntityHandle edge = *eit; 00212 int num_nodes; 00213 rval = mb->get_connectivity( edge, edge_conn, num_nodes ); 00214 if( MB_SUCCESS != rval ) return rval; 00215 connect[quad_index * 4] = edge_conn[0]; 00216 connect[quad_index * 4 + 1] = edge_conn[1]; 00217 00218 // maybe some indexing in range? 00219 connect[quad_index * 4 + 2] = start_vert + edge_conn[1] - firstVertHandle; 00220 connect[quad_index * 4 + 3] = start_vert + edge_conn[0] - firstVertHandle; 00221 } 00222 00223 Range quads( start_elem, start_elem + allEdges.size() - 1 ); 00224 EntityHandle outSet; 00225 rval = mb->create_meshset( MESHSET_SET, outSet ); 00226 if( MB_SUCCESS != rval ) return rval; 00227 mb->add_entities( outSet, quads ); 00228 00229 Tag colTag; 00230 rval = mb->tag_get_handle( "COLOR_ID", 1, MB_TYPE_INTEGER, colTag, MB_TAG_DENSE | MB_TAG_CREAT ); 00231 if( MB_SUCCESS != rval ) return rval; 00232 int j = 1; 00233 for( Range::iterator itq = quads.begin(); itq != quads.end(); ++itq, j++ ) 00234 { 00235 EntityHandle q = *itq; 00236 rval = mb->tag_set_data( colTag, &q, 1, &j ); 00237 if( MB_SUCCESS != rval ) return rval; 00238 } 00239 std::stringstream outf; 00240 outf << "SpanQuads" << rank << ".h5m"; 00241 rval = mb->write_file( outf.str().c_str(), 0, 0, &outSet, 1 ); 00242 if( MB_SUCCESS != rval ) return rval; 00243 EntityHandle outSet2; 00244 rval = mb->create_meshset( MESHSET_SET, outSet2 ); 00245 if( MB_SUCCESS != rval ) return rval; 00246 00247 Range quadEdges; 00248 rval = mb->get_adjacencies( quads, 1, true, quadEdges, Interface::UNION ); 00249 if( MB_SUCCESS != rval ) return rval; 00250 mb->add_entities( outSet2, quadEdges ); 00251 00252 std::stringstream outf2; 00253 outf2 << "SpanEdges" << rank << ".h5m"; 00254 rval = mb->write_file( outf2.str().c_str(), 0, 0, &outSet2, 1 ); 00255 if( MB_SUCCESS != rval ) return rval; 00256 00257 // maybe some clean up 00258 mb->delete_entities( &outSet, 1 ); 00259 mb->delete_entities( &outSet2, 1 ); 00260 mb->delete_entities( quads ); 00261 Range new_edges = subtract( allEdges, iniEdges ); 00262 mb->delete_entities( new_edges ); 00263 new_edges = subtract( quadEdges, iniEdges ); 00264 mb->delete_entities( new_edges ); 00265 Range new_verts( start_vert, start_vert + num_verts ); 00266 mb->delete_entities( new_verts ); 00267 00268 return MB_SUCCESS; 00269 } 00270 00271 // this simply copies the one mesh set into another, and sets some correlation tags 00272 // for easy mapping back and forth 00273 ErrorCode IntxUtilsCSLAM::deep_copy_set( Interface* mb, EntityHandle source_set, EntityHandle dest_set ) 00274 { 00275 // create the handle tag for the corresponding element / vertex 00276 00277 EntityHandle dum = 0; 00278 Tag corrTag = 0; // it will be created here 00279 ErrorCode rval = mb->tag_get_handle( CORRTAGNAME, 1, MB_TYPE_HANDLE, corrTag, MB_TAG_DENSE | MB_TAG_CREAT, &dum );MB_CHK_ERR( rval ); 00280 00281 // give the same global id to new verts and cells created in the lagr(departure) mesh 00282 Tag gid = mb->globalId_tag(); 00283 00284 Range polys; 00285 rval = mb->get_entities_by_dimension( source_set, 2, polys );MB_CHK_ERR( rval ); 00286 00287 Range connecVerts; 00288 rval = mb->get_connectivity( polys, connecVerts );MB_CHK_ERR( rval ); 00289 00290 std::map< EntityHandle, EntityHandle > newNodes; 00291 for( Range::iterator vit = connecVerts.begin(); vit != connecVerts.end(); ++vit ) 00292 { 00293 EntityHandle oldV = *vit; 00294 CartVect posi; 00295 rval = mb->get_coords( &oldV, 1, &( posi[0] ) );MB_CHK_ERR( rval ); 00296 int global_id; 00297 rval = mb->tag_get_data( gid, &oldV, 1, &global_id );MB_CHK_ERR( rval ); 00298 00299 EntityHandle new_vert; 00300 // duplicate the position 00301 rval = mb->create_vertex( &( posi[0] ), new_vert );MB_CHK_ERR( rval ); 00302 newNodes[oldV] = new_vert; 00303 00304 // set also the correspondent tag :) 00305 rval = mb->tag_set_data( corrTag, &oldV, 1, &new_vert );MB_CHK_ERR( rval ); 00306 // also the other side 00307 // need to check if we really need this; the new vertex will never need the old vertex 00308 // we have the global id which is the same 00309 rval = mb->tag_set_data( corrTag, &new_vert, 1, &oldV );MB_CHK_ERR( rval ); 00310 // set the global id on the corresponding vertex the same as the initial vertex 00311 rval = mb->tag_set_data( gid, &new_vert, 1, &global_id );MB_CHK_ERR( rval ); 00312 } 00313 00314 for( Range::iterator it = polys.begin(); it != polys.end(); ++it ) 00315 { 00316 EntityHandle q = *it; 00317 int nnodes; 00318 const EntityHandle* conn; 00319 rval = mb->get_connectivity( q, conn, nnodes );MB_CHK_ERR( rval ); 00320 00321 int global_id; 00322 rval = mb->tag_get_data( gid, &q, 1, &global_id );MB_CHK_ERR( rval ); 00323 EntityType typeElem = mb->type_from_handle( q ); 00324 std::vector< EntityHandle > new_conn( nnodes ); 00325 for( int i = 0; i < nnodes; i++ ) 00326 { 00327 EntityHandle v1 = conn[i]; 00328 new_conn[i] = newNodes[v1]; 00329 } 00330 EntityHandle newElement; 00331 rval = mb->create_element( typeElem, &new_conn[0], nnodes, newElement );MB_CHK_ERR( rval ); 00332 00333 // set the corresponding tag; not sure we need this one, from old to new 00334 rval = mb->tag_set_data( corrTag, &q, 1, &newElement );MB_CHK_ERR( rval ); 00335 rval = mb->tag_set_data( corrTag, &newElement, 1, &q );MB_CHK_ERR( rval ); 00336 00337 // set the global id 00338 rval = mb->tag_set_data( gid, &newElement, 1, &global_id );MB_CHK_ERR( rval ); 00339 rval = mb->add_entities( dest_set, &newElement, 1 );MB_CHK_ERR( rval ); 00340 } 00341 00342 return MB_SUCCESS; 00343 }
