MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for ErrorHandler.hpp:
This graph shows which files directly or indirectly include this file:Go to the source code of this file.
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Defines | |
| #define | __FILENAME__ ( strrchr( __FILE__, '/' ) ? strrchr( __FILE__, '/' ) + 1 : __FILE__ ) |
| #define | MBSTRINGIFY_(X) #X |
| #define | MBSTRINGIFY(X) MBSTRINGIFY_( X ) |
| #define | __MBSDIR__ "" |
| #define | MB_SET_ERR(err_code, err_msg) |
| #define | MB_SET_ERR_RET(err_msg) |
| #define | MB_SET_ERR_RET_VAL(err_msg, ret_val) |
| #define | MB_SET_ERR_CONT(err_msg) |
| #define | MB_SET_GLB_ERR(err_code, err_msg) |
| Similar to MB_SET_ERR except that the error is considered globally fatal. | |
| #define | MB_SET_GLB_ERR_RET(err_msg) |
| Similar to MB_SET_ERR_RET except that the error is considered globally fatal. | |
| #define | MB_SET_GLB_ERR_RET_VAL(err_msg, ret_val) |
| Similar to MB_SET_ERR_RET_VAL except that the error is considered globally fatal. | |
| #define | MB_SET_GLB_ERR_CONT(err_msg) |
| Similar to MB_SET_ERR_CONT except that the error is considered globally fatal. | |
| #define | MB_CHK_ERR(err_code) |
| #define | MB_CHK_ERR_RET(err_code) |
| #define | MB_CHK_ERR_RET_VAL(err_code, ret_val) |
| #define | MB_CHK_ERR_CONT(err_code) |
| #define | MB_CHK_SET_ERR(err_code, err_msg) |
| #define | MB_CHK_SET_ERR_RET(err_code, err_msg) |
| #define | MB_CHK_SET_ERR_RET_VAL(err_code, err_msg, ret_val) |
| #define | MB_CHK_SET_ERR_CONT(err_code, err_msg) |
Enumerations | |
| enum | moab::ErrorType { moab::MB_ERROR_TYPE_NEW_GLOBAL = 0, moab::MB_ERROR_TYPE_NEW_LOCAL = 1, moab::MB_ERROR_TYPE_EXISTING = 2 } |
Functions | |
| void | moab::MBErrorHandler_Init () |
| Initialize MOAB error handler (e.g. create a utility object for printing error output) | |
| void | moab::MBErrorHandler_Finalize () |
| Finalize MOAB error handler (e.g. delete the utility object for printing error output) | |
| bool | moab::MBErrorHandler_Initialized () |
| Indicates whether MBErrorHandler_Init has been called. | |
| void | moab::MBErrorHandler_GetLastError (std::string &error) |
| Get information about the last error. | |
| ErrorCode | moab::MBError (int line, const char *func, const char *file, const char *dir, ErrorCode err_code, const char *err_msg, ErrorType err_type) |
| Routine that is called to create a new error or handle an existing one. | |
| #define __FILENAME__ ( strrchr( __FILE__, '/' ) ? strrchr( __FILE__, '/' ) + 1 : __FILE__ ) |
Definition at line 48 of file ErrorHandler.hpp.
| #define __MBSDIR__ "" |
Definition at line 56 of file ErrorHandler.hpp.
| #define MB_CHK_ERR | ( | err_code | ) |
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) \ return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", \ moab::MB_ERROR_TYPE_EXISTING ); \ } while( false )
Check error code, if not MB_SUCCESS, call the error handler and return the given error code Used in functions which return ErrorCode
Definition at line 149 of file ErrorHandler.hpp.
Referenced by moab::GeomTopoTool::A_is_in_B(), moab::Skinner::add_adjacency(), moab::HalfFacetRep::add_cells_of_single_component(), add_field_value(), moab::HalfFacetRep::another_halfedge(), MetisPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::HiReconstruction::average_vertex_normal(), moab::HiReconstruction::average_vertex_tangent(), moab::box_from_axes(), moab::MeshGeneration::BrickInstance(), build_cube(), moab::Core::check_adjacencies(), check_meshset_internal(), moab::HalfFacetRep::check_mixed_entity_type(), check_model_test(), check_tree(), check_valid_connectivity(), moab::Skinner::classify_2d_boundary(), moab::MeshTag::clear_data(), moab::BitTag::clear_data(), moab::VarLenSparseTag::clear_data(), moab::SparseTag::clear_data(), moab::DenseTag::clear_data(), closedsurface_uref_hirec_convergence_study(), moab::HalfFacetRep::collect_and_compare(), moab::HiReconstruction::compute_average_vertex_normals_surf(), moab::HiReconstruction::compute_average_vertex_tangents_curve(), compute_lagrange_mesh_on_sphere(), moab::ParCommGraph::compute_partition(), compute_tracer_case1(), compute_velocity_case1(), moab::TempestRemapper::ComputeGlobalLocalMaps(), moab::Intx2MeshInPlane::computeIntersectionBetweenTgtAndSrc(), moab::IntxRllCssphere::computeIntersectionBetweenTgtAndSrc(), moab::Intx2MeshOnSphere::computeIntersectionBetweenTgtAndSrc(), moab::TempestOnlineMap::ComputeMetrics(), moab::TempestRemapper::ComputeOverlapMesh(), moab::NestedRefine::construct_hm_1D(), moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::construct_hm_3D(), moab::NestedRefine::construct_hm_entities(), moab::TempestRemapper::ConstructCoveringSet(), moab::TempestRemapper::convert_mesh_to_tempest_private(), moab::TempestRemapper::convert_overlap_mesh_sorted_by_source(), moab::NestedRefine::copy_vertices_from_prev_level(), moab::ParallelComm::correct_thin_ghost_layers(), moab::NestedRefine::count_subentities(), moab::HalfFacetRep::count_subentities(), moab::NestedRefine::create_hm_storage_single_level(), create_lagr_mesh(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::FBEngine::create_new_gedge(), moab::Core::create_scd_sequence(), moab::Core::create_set_iterator(), create_shell_test(), moab::Skinner::create_side(), create_unitsq_quads(), create_unitsq_tris(), moab::Core::create_vertices(), CreateTempestMesh(), IntxUtilsCSLAM::deep_copy_set(), moab::IntxUtils::deep_copy_set_with_quads(), moab::TempestOnlineMap::DefineAnalyticalSolution(), DeformMeshRemap::deform_master(), moab::Skinner::deinitialize(), moab::Core::delete_mesh(), moab::ReadParallel::delete_nonlocal_entities(), moab::HalfFacetRep::determine_border_vertices(), moab::HalfFacetRep::determine_incident_halfedges(), moab::HalfFacetRep::determine_incident_halffaces(), moab::HalfFacetRep::determine_incident_halfverts(), moab::HalfFacetRep::determine_sibling_halfedges(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::HalfFacetRep::determine_sibling_halfverts(), duplicate_model_test(), moab::IntxUtils::enforce_convexity(), moab::NestedRefine::estimate_hm_storage(), moab::NestedRefine::exchange_ghosts(), DeformMeshRemap::execute(), moab::HalfFacetRep::fid_from_halfacet(), moab::DenseTag::find_entities_with_value(), moab::VarLenDenseTag::find_entities_with_value(), moab::HalfFacetRep::find_matching_halfedge(), moab::HalfFacetRep::find_matching_halfface(), moab::HalfFacetRep::find_matching_implicit_edge_in_cell(), moab::Skinner::find_skin(), moab::HalfFacetRep::find_total_edges_2d(), moab::HalfFacetRep::find_total_edges_faces_3d(), moab::Intx2Mesh::FindMaxEdgesInSet(), moab::Intx2MeshOnSphere::findNodes(), moab::IntxUtils::fix_degenerate_quads(), moab::ParCommGraph::form_mesh_from_tuples(), moab::ParCommGraph::form_tuples_to_migrate_mesh(), FunctionA(), FunctionB(), moab::HalfFacetRep::gather_halfedges(), moab::WriteNCDF::gather_mesh_information(), moab::NestedRefine::generate_hm(), moab::NestedRefine::generate_mesh_hierarchy(), moab::TempestOnlineMap::GenerateRemappingWeights(), moab::NestedRefine::get_adjacencies(), moab::HalfFacetRep::get_adjacencies(), moab::Core::get_adjacencies(), moab::get_adjacencies_intersection(), get_all_handles(), get_barycenters(), moab::Core::get_child_meshsets(), moab::NestedRefine::get_connectivity(), moab::Core::get_connectivity(), moab::Core::get_connectivity_by_type(), moab::Core::get_contained_meshsets(), moab::NestedRefine::get_coordinates(), moab::Core::get_coords(), moab::DenseTag::get_data(), moab::VarLenDenseTag::get_data(), get_degree_seq(), get_departure_grid(), moab::HalfFacetRep::get_down_adjacencies(), moab::HalfFacetRep::get_down_adjacencies_2d(), moab::HalfFacetRep::get_down_adjacencies_edg_3d(), moab::HalfFacetRep::get_down_adjacencies_face_3d(), moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type(), moab::Core::get_entities_by_type_and_tag(), moab::BitTag::get_entities_with_bits(), moab::HalfFacetRep::get_face_edges(), get_gnomonic_plane(), moab::HalfFacetRep::get_half_facet_in_comp(), get_intersection_weights(), get_linear_reconstruction(), get_max_volume(), moab::Tqdcfr::get_names(), moab::HalfFacetRep::get_neighbor_adjacencies(), moab::HalfFacetRep::get_neighbor_adjacencies_2d(), moab::HiReconstruction::get_normals_surf(), moab::Core::get_number_entities_by_dimension(), moab::Core::get_number_entities_by_handle(), moab::Core::get_number_entities_by_type(), moab::Core::get_parent_meshsets(), moab::ParallelComm::get_remote_handles(), moab::GeomTopoTool::get_senses(), moab::ReadHDF5::get_subset_ids(), moab::HiReconstruction::get_tangents_curve(), moab::HalfFacetRep::get_up_adjacencies(), moab::HalfFacetRep::get_up_adjacencies_2d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_edg_3d_comp(), moab::HalfFacetRep::get_up_adjacencies_face_3d(), moab::HalfFacetRep::get_up_adjacencies_vert_2d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), moab::Core::get_vertex_coordinates(), moab::Core::get_vertices(), moab::ParallelMergeMesh::GetGlobalBox(), moab::TempestRemapper::GetOverlapAugmentedEntities(), moab::IntxUtils::global_gnomonic_projection(), moab::Core::high_order_node(), moab::HiReconstruction::hiproj_walf_around_vertex(), moab::HiReconstruction::hiproj_walf_in_element(), iMOAB_CreateElements(), iMOAB_CreateVertices(), iMOAB_DeregisterApplication(), iMOAB_GetBlockElementConnectivities(), iMOAB_GetBlockID(), iMOAB_GetBlockInfo(), iMOAB_GetDoubleTagStorage(), iMOAB_GetElementConnectivity(), iMOAB_GetElementID(), iMOAB_GetElementOwnership(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_GetNeighborElements(), iMOAB_GetPointerToSurfaceBC(), iMOAB_GetPointerToVertexBC(), iMOAB_GetVertexOwnership(), iMOAB_GetVisibleElementsInfo(), iMOAB_GetVisibleVerticesCoordinates(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_ReduceTagsMax(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_SetDoubleTagStorageWithGid(), iMOAB_SetIntTagStorage(), iMOAB_SynchronizeTags(), iMOAB_UpdateMeshInfo(), iMOAB_WriteLocalMesh(), iMOAB_WriteMesh(), moab::HalfFacetRep::init_curve(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::HalfFacetRep::init_surface(), moab::HalfFacetRep::init_volume(), moab::NestedRefine::initialize(), moab::HiReconstruction::initialize(), moab::HalfFacetRep::initialize(), moab::Skinner::initialize(), moab::WriteNCDF::initialize_exodus_file(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_edge_on_boundary(), moab::NestedRefine::is_face_on_boundary(), moab::NestedRefine::is_vertex_on_boundary(), moab::ParallelComm::list_entities(), moab::Core::list_entity(), moab::ReadParallel::load_file(), moab::ReadDamsel::load_file(), moab::Core::load_file(), moab::ReadOBJ::load_file(), moab::ReadSms::load_file_impl(), load_meshset_hirec(), moab::Remapper::LoadNativeMesh(), main(), make_atomic_pillow(), make_chord_push(), make_face_shrink(), make_triple_chord_push(), moab::HalfFacetRep::mark_halfedges(), mb_adjacent_create_test(), mb_mesh_set_flag_test(), mb_mesh_set_list_replace_test(), mb_mesh_set_set_add_remove_test(), mb_mesh_set_set_replace_test(), mb_root_set_test(), mb_side_number_test(), mb_skin_fileset_test(), mb_type_is_maxtype_test(), mb_upward_adjacencies_test(), mb_vertex_coordinate_test(), moab::ParallelMergeMesh::merge(), moab::MergeMesh::merge_all(), moab::Core::merge_entities(), moab::AdaptiveKDTree::merge_leaf(), moab::BSPTree::merge_leaf(), moab::HiReconstruction::obtain_nring_ngbvs(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_owned_cells(), perform_laplacian_smoothing(), perform_lloyd_relaxation(), moab::ParallelMergeMesh::PerformMerge(), moab::HiReconstruction::polyfit3d_walf_curve_vertex(), moab::HiReconstruction::polyfit3d_walf_surf_vertex(), moab::ParallelMergeMesh::PopulateMySkinEnts(), moab::ParallelMergeMesh::PopulateMyTup(), moab::ReadDamsel::process_ent_info(), process_partition_file(), moab::ReadHDF5::read_elems(), moab::ReadHDF5::read_poly(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_var_len_tag(), moab::ParCommGraph::receive_mesh(), moab::ParCommGraph::receive_tag_values(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), refine_entities(), moab::Skinner::remove_adjacency(), moab::VarLenDenseTag::remove_data(), moab::IntxUtils::remove_duplicate_vertices(), moab::IntxUtils::remove_padded_vertices(), moab::NestedRefine::reorder_indices(), moab::ParallelComm::resolve_shared_ents(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), moab::ParCommGraph::send_graph_partition(), moab::ParCommGraph::send_tag_values(), moab::Core::serial_load_file(), moab::Core::set_connectivity(), moab::BitTag::set_data(), moab::DenseTag::set_data(), moab::MeshTag::set_data(), moab::SparseTag::set_data(), moab::VarLenSparseTag::set_data(), moab::VarLenDenseTag::set_data(), set_density(), moab::ReadHDF5::set_up_read(), moab::TempestOnlineMap::SetDOFmapAssociation(), moab::TempestOnlineMap::SetDOFmapTags(), moab::Core::side_element(), moab::Core::side_number(), split_test_across(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), moab::Core::tag_delete(), moab::HigherOrderFactory::tag_for_deletion(), moab::DenseTag::tag_iterate(), moab::SparseTag::tag_iterate(), test_closedsurface_mesh(), test_mesh(), test_unitcircle(), test_unitsphere(), test_unitsq_quads(), test_unitsq_tris(), TestErrorHandling_1(), TestErrorHandling_2(), TestErrorHandling_3(), TestErrorHandlingPar_1(), TestErrorHandlingPar_2(), moab::ReadNCDF::update(), moab::NestedRefine::update_ahf_1D(), update_density(), moab::HalfFacetRep::update_entity_ranges(), moab::NestedRefine::update_global_ahf(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::NestedRefine::update_local_ahf(), moab::ParallelComm::update_remote_data(), moab::ParallelComm::update_remote_data_old(), moab::NestedRefine::update_special_tags(), moab::NestedRefine::update_tracking_verts(), moab::HiReconstruction::vertex_get_incident_elements(), moab::NestedRefine::vertex_to_entities_down(), moab::NestedRefine::vertex_to_entities_up(), moab::ReadVtk::vtk_read_unstructured_grid(), MetisPartitioner::write_aggregationtag_partition(), DeformMeshRemap::write_and_save(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteDamsel::write_file(), MetisPartitioner::write_partition(), moab::WriteNCDF::write_poly_faces(), moab::WriteDamsel::write_vertices(), moab::TempestOnlineMap::WriteHDF5MapFile(), and moab::TempestOnlineMap::WriteParallelMap().
| #define MB_CHK_ERR_CONT | ( | err_code | ) |
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) \ { \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \ } \ } while( false )
Check error code, if not MB_SUCCESS, call the error handler and continue Used in functions which return any data type
Definition at line 183 of file ErrorHandler.hpp.
Referenced by moab::handle_hdf5_error().
| #define MB_CHK_ERR_RET | ( | err_code | ) |
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) \ { \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \ return; \ } \ } while( false )
Check error code, if not MB_SUCCESS, call the error handler and return Used in functions which return void types (or have no return types at all, e.g. constructors)
Definition at line 159 of file ErrorHandler.hpp.
Referenced by heappermute(), moab::ReadOBJ::ReadOBJ(), test_four_cubes(), test_intx_in_parallel_elem_based(), test_three_cubes(), and test_two_cubes().
| #define MB_CHK_ERR_RET_VAL | ( | err_code, | |
| ret_val | |||
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) \ { \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, "", moab::MB_ERROR_TYPE_EXISTING ); \ return ret_val; \ } \ } while( false )
Check error code, if not MB_SUCCESS, call the error handler and return the given value Used in functions which return any data type
Definition at line 171 of file ErrorHandler.hpp.
Referenced by moab::IntxAreaUtils::area_on_sphere(), moab::IntxAreaUtils::area_spherical_element(), moab::GQT_IntRegCtxt::edge_node_piercing_intersect(), and moab::Intx2MeshOnSphere::setup_tgt_cell().
| #define MB_CHK_SET_ERR | ( | err_code, | |
| err_msg | |||
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR( err_code, err_msg ); \ } while( false )
Check error code, if not MB_SUCCESS, set a new error with the given error message and return the given error code Used in functions which return ErrorCode
Definition at line 194 of file ErrorHandler.hpp.
Referenced by moab::GeomTopoTool::A_is_in_B(), moab::GeomTopoTool::add_geo_set(), moab::ParallelComm::add_verts(), moab::TempestOnlineMap::ApplyWeights(), moab::ParallelComm::assign_entities_part(), moab::ParallelComm::assign_global_ids(), moab::TempestRemapper::assign_vertex_element_IDs(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::GeomQueryTool::boundary_case(), moab::MeshGeneration::BrickInstance(), moab::ParallelComm::broadcast_entities(), moab::ParallelComm::build_sharedhps_list(), moab::ParallelComm::check_clean_iface(), moab::GeomTopoTool::check_edge_sense_tags(), moab::NCHelperHOMME::check_existing_mesh(), moab::NCHelperMPAS::check_existing_mesh(), moab::NCHelperGCRM::check_existing_mesh(), moab::ScdNCHelper::check_existing_mesh(), moab::GeomTopoTool::check_face_sense_tag(), moab::GeomTopoTool::check_geom_tag(), moab::GeomTopoTool::check_gid_tag(), moab::ParallelComm::check_global_ids(), check_model_test(), moab::ParallelComm::check_sent_ents(), check_split(), moab::ParallelComm::clean_shared_tags(), moab::GeomQueryTool::closest_to_location(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteHelper::collect_variable_data(), compute_dual_mesh(), moab::TempestRemapper::ComputeGlobalLocalMaps(), moab::TempestRemapper::ComputeOverlapMesh(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_obb_trees(), moab::GeomTopoTool::construct_vertex_ranges(), moab::TempestRemapper::ConstructCoveringSet(), moab::TempestRemapper::convert_tempest_mesh_private(), moab::TempestRemapper::ConvertMeshToTempest(), moab::TempestRemapper::ConvertTempestMesh(), moab::ParallelComm::correct_thin_ghost_layers(), moab::ReadCCMIO::create_cell_from_faces(), moab::NCHelper::create_conventional_tags(), moab::NCHelper::create_dummy_variables(), moab::ReadIDEAS::create_elements(), moab::ReadCGNS::create_elements(), moab::NCHelperMPAS::create_gather_set_cells(), moab::NCHelperGCRM::create_gather_set_edges(), moab::NCHelperMPAS::create_gather_set_edges(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::NestedRefine::create_hm_storage_single_level(), moab::ParallelComm::create_iface_pc_links(), moab::ParallelComm::create_interface_sets(), moab::NCHelperMPAS::create_local_cells(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_vertices(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::ScdNCHelper::create_mesh(), create_mesh_no_holes(), create_mesh_with_holes(), moab::ReadOBJ::create_new_face(), moab::ReadOBJ::create_new_group(), moab::ReadOBJ::create_new_object(), moab::ReadOBJ::create_new_vertex(), moab::NCHelperGCRM::create_padded_gather_set_cells(), moab::NCHelperMPAS::create_padded_gather_set_cells(), moab::NCHelperGCRM::create_padded_local_cells(), moab::NCHelperMPAS::create_padded_local_cells(), moab::ReadParallel::create_partition_sets(), moab::ScdNCHelper::create_quad_coordinate_tag(), moab::ReadCGNS::create_sets(), moab::ReadTemplate::create_sets(), create_shell_test(), moab::SpectralMeshTool::create_spectral_elems(), moab::ReadIDEAS::create_vertices(), moab::Intx2Mesh::createTags(), DeformMeshRemap::deform_master(), moab::GeomTopoTool::delete_all_obb_trees(), moab::ParallelComm::delete_entities(), moab::ReadParallel::delete_nonlocal_entities(), moab::GeomTopoTool::delete_obb_tree(), moab::Intx2Mesh::DetermineOrderedNeighbors(), moab::GeomTopoTool::dimension(), moab::GeomTopoTool::duplicate_model(), duplicate_model_test(), moab::Matrix3::eigen_decomposition(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_owned_meshs(), moab::ParallelComm::exchange_tags(), DeformMeshRemap::execute(), moab::ParallelComm::filter_pstatus(), moab::ParallelComm::find_existing_entity(), moab::GeomTopoTool::find_geomsets(), DeformMeshRemap::find_other_sets(), moab::GeomQueryTool::find_volume(), moab::GeomQueryTool::find_volume_slow(), moab::Intx2Mesh::FindMaxEdges(), moab::Intx2Mesh::FindMaxEdgesInSet(), moab::Intx2MeshInPlane::findNodes(), moab::IntxRllCssphere::findNodes(), moab::Intx2MeshOnSphere::findNodes(), moab::ParCommGraph::form_mesh_from_tuples(), moab::WriteCCMIO::gather_matset_info(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::WriteCCMIO::gather_neuset_info(), moab::GeomTopoTool::generate_implicit_complement(), moab::TempestRemapper::GenerateCSMeshMetadata(), moab::TempestRemapper::GenerateMeshMetadata(), moab::TempestOnlineMap::GenerateRemappingWeights(), gentityset_test(), moab::GeomTopoTool::geometrize_surface_set(), geometrize_test(), geometry_evaluation_test(), moab::GeomTopoTool::get_bounding_coords(), moab::ReadCCMIO::get_dbl_option(), moab::ParallelComm::get_ghosted_entities(), moab::WriteCCMIO::get_gids(), moab::GeomTopoTool::get_gsets_by_dimension(), moab::ParallelComm::get_iface_entities(), get_imesh_mesh(), moab::ReadCCMIO::get_int_option(), moab::ParallelComm::get_interface_procs(), moab::GeomQueryTool::get_normal(), moab::GeomTopoTool::get_obb(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_owning_part(), moab::ParallelComm::get_proc_nvecs(), moab::ParallelComm::get_pstatus(), moab::ParallelComm::get_pstatus_entities(), moab::ParallelComm::get_remote_handles(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::ParallelComm::get_sent_ents(), moab::ReadABAQUS::get_set_by_name(), moab::ParallelComm::get_shared_entities(), moab::ParallelComm::get_sharing_data(), moab::ParallelComm::get_sharing_parts(), moab::ReadCCMIO::get_str_option(), moab::GeomTopoTool::get_surface_senses(), moab::WriteUtil::get_tag_list(), moab::ParallelComm::get_tag_send_list(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::WriteNCDF::get_valid_sides(), moab::ReadNC::get_variables(), get_vartag_data(), moab::TempestRemapper::GetIMasks(), moab::TempestRemapper::GetOverlapAugmentedEntities(), id_lookup(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::WriteDamsel::init_tag_info(), moab::TempestRemapper::initialize(), moab::GeomQueryTool::initialize(), moab::LloydSmoother::initialize(), moab::GeomTopoTool::insert_in_tree(), integrate_scalar_field_test(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), moab::Intx2Mesh::intersect_meshes(), moab::Intx2Mesh::intersect_meshes_kdtree(), moab::GeomTopoTool::is_owned_set(), moab::ParallelComm::list_entities(), moab::ReadCGNS::load_file(), moab::ReadTemplate::load_file(), moab::ReadIDEAS::load_file(), moab::ReadCCMIO::load_file(), moab::ReadDamsel::load_file(), moab::ReadParallel::load_file(), moab::ReadNC::load_file(), moab::ReadOBJ::load_file(), moab::Tqdcfr::load_file(), moab::ReadCCMIO::load_matset_data(), moab::ReadCCMIO::load_metadata(), moab::ReadCCMIO::load_neuset_data(), moab::TempestRemapper::LoadMesh(), main(), moab::WriteDamsel::map_dense_tags(), moab::WriteDamsel::map_sparse_tags(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), normals_test(), moab::GeomTopoTool::other_entity(), moab::ParallelComm::pack_buffer(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_entity_seq(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_tag(), moab::ParallelComm::packed_tag_size(), moab::LloydSmoother::perform_smooth(), moab::GeomQueryTool::point_in_box(), moab::GeomQueryTool::point_in_volume(), moab::GeomQueryTool::point_in_volume_slow(), moab::GeomQueryTool::poly_solid_angle(), moab::WriteNC::process_conventional_tags(), moab::ReadDamsel::process_ent_info(), moab::ReadDamsel::process_entity_tags(), moab::GeomQueryTool::ray_fire(), ray_test(), moab::ReadCCMIO::read_all_faces(), moab::ReadCCMIO::read_cells(), moab::ReadTemplate::read_elements(), moab::ReadCCMIO::read_faces(), DeformMeshRemap::read_file(), moab::ReadCCMIO::read_gids_and_types(), moab::ReadNC::read_header(), moab::ReadCCMIO::read_processor(), moab::ScdNCHelper::read_scd_variables_to_nonset(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::ReadHDF5::read_var_len_tag(), moab::ScdNCHelper::read_variables(), moab::UcdNCHelper::read_variables(), moab::NCHelper::read_variables_to_set(), moab::NCHelper::read_variables_to_set_allocate(), moab::ReadTemplate::read_vertices(), moab::ReadCCMIO::read_vertices(), moab::ParCommGraph::receive_mesh(), moab::ParallelComm::recv_entities(), moab::ParallelComm::recv_messages(), moab::ParallelComm::recv_remote_handle_messages(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::remove_entities_part(), moab::IntxUtils::remove_padded_vertices(), moab::GeomTopoTool::remove_root(), moab::GeomTopoTool::resize_rootSets(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), root_set_test(), run_local_smoother(), moab::ParallelComm::scatter_entities(), moab::ParallelComm::send_entities(), moab::ParallelComm::send_recv_entities(), moab::GeomTopoTool::separate_by_dimension(), moab::ParallelComm::set_pstatus_entities(), moab::GeomTopoTool::set_root_set(), moab::GeomTopoTool::set_sense(), moab::GeomTopoTool::set_senses(), moab::ParallelComm::set_sharing_data(), moab::GeomTopoTool::set_surface_senses(), moab::TempestOnlineMap::SetDOFmapTags(), moab::ParallelComm::settle_intersection_points(), moab::GeomTopoTool::setup_implicit_complement(), moab::ReadOBJ::split_quad(), split_quads_test(), split_test(), split_test_across(), moab::ParallelComm::tag_iface_entities(), moab::ParallelComm::tag_shared_verts(), test_delete_obb_tree(), test_restore_obb_trees(), test_root_sets_resize(), moab::GeomQueryTool::test_volume_boundary(), TestErrorHandling_4(), moab::WriteCCMIO::transform_coords(), moab::ParallelComm::unpack_buffer(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::unpack_remote_handles(), moab::ParallelComm::unpack_sets(), moab::ParallelComm::unpack_tags(), moab::ParallelComm::update_remote_data(), moab::ParallelComm::update_remote_data_old(), moab::NCHelper::update_time_tag_vals(), moab::Intx2MeshOnSphere::update_tracer_data(), verify_split(), volume_test(), moab::ReadVtk::vtk_read_field_attrib(), moab::ReadVtk::vtk_read_tag_data(), moab::WriteNCDF::write_BCs(), moab::WriteCCMIO::write_cells_and_faces(), moab::WriteDamsel::write_entities(), moab::WriteCCMIO::write_external_faces(), moab::WriteDamsel::write_file(), moab::WriteCCMIO::write_file(), moab::WriteNC::write_file(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), moab::WriteCCMIO::write_nodes(), moab::WriteNCDF::write_nodes(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), moab::WriteCCMIO::write_problem_description(), moab::WriteDamsel::write_sets(), DeformMeshRemap::write_to_coords(), moab::WriteDamsel::write_vertices(), moab::TempestOnlineMap::WriteHDF5MapFile(), and moab::TempestOnlineMap::WriteSCRIPMapFile().
| #define MB_CHK_SET_ERR_CONT | ( | err_code, | |
| err_msg | |||
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_CONT( err_msg ); \ } while( false )
Check error code, if not MB_SUCCESS, set a new error with the given error message and continue Used in functions which return any data type
Definition at line 218 of file ErrorHandler.hpp.
Referenced by moab::GeomTopoTool::entity_by_id(), find_volume_tests(), moab::GeomTopoTool::GeomTopoTool(), run_overlap_tests(), run_regular_tests(), test_delete_obb_tree(), test_restore_obb_trees(), and moab::WriteDamsel::WriteDamsel().
| #define MB_CHK_SET_ERR_RET | ( | err_code, | |
| err_msg | |||
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_RET( err_msg ); \ } while( false )
Check error code, if not MB_SUCCESS, set a new error with the given error message and return Used in functions which return void types (or have no return types at all, e.g. constructors)
Definition at line 202 of file ErrorHandler.hpp.
Referenced by moab::Util::centroid(), moab::Util::normal(), moab::ReadCCMIO::ReadCCMIO(), moab::Tqdcfr::Tqdcfr(), update_tracer(), and moab::LloydSmoother::~LloydSmoother().
| #define MB_CHK_SET_ERR_RET_VAL | ( | err_code, | |
| err_msg, | |||
| ret_val | |||
do \ { \ if( moab::MB_SUCCESS != ( err_code ) ) MB_SET_ERR_RET_VAL( err_msg, ret_val ); \ } while( false )
Check error code, if not MB_SUCCESS, set a new error with the given error message and return the given value Used in functions which return any data type
Definition at line 210 of file ErrorHandler.hpp.
Referenced by moab::ParallelComm::estimate_ents_buffer_size(), moab::ParallelComm::estimate_sets_buffer_size(), get_children_by_dimension(), and moab::WriteNCDF::write_BCs().
| #define MB_SET_ERR | ( | err_code, | |
| err_msg | |||
do \ { \ std::ostringstream err_ostr; \ err_ostr << err_msg; \ return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_LOCAL ); \ } while( false )
Set a new error with the given error message (a string or a stream) and return the given error code Used in functions which return ErrorCode
Definition at line 61 of file ErrorHandler.hpp.
Referenced by moab::HalfFacetRep::add_cells_of_single_component(), moab::GeomTopoTool::add_geo_set(), moab::ReadSmf::annotation(), moab::HiReconstruction::average_vertex_normal(), moab::HiReconstruction::average_vertex_tangent(), moab::GeomQueryTool::boundary_case(), moab::ParallelComm::broadcast_entities(), moab::WriteUtil::check_doesnt_exist(), moab::ReadSmf::check_length(), moab::HalfFacetRep::check_nonmanifold_vertices(), moab::ParallelComm::check_sent_ents(), moab::WriteHDF5Parallel::check_serial_tag_data(), moab::NestedRefine::child_to_parent(), moab::SparseTag::clear_data(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::NCWriteGCRM::collect_variable_data(), moab::NCWriteHOMME::collect_variable_data(), moab::NCWriteMPAS::collect_variable_data(), moab::NCWriteHelper::collect_variable_data(), moab::ScdNCWriteHelper::collect_variable_data(), moab::Core::connect_iterate(), moab::GeomTopoTool::construct_obb_tree(), moab::GeomTopoTool::construct_vertex_ranges(), moab::SpectralMeshTool::convert_to_coarse(), moab::Core::coords_iterate(), moab::NCHelper::create_attrib_string(), moab::ReadCCMIO::create_cell_from_faces(), moab::NCHelper::create_conventional_tags(), moab::NCHelperMPAS::create_gather_set_cells(), moab::NCHelperGCRM::create_gather_set_edges(), moab::NCHelperMPAS::create_gather_set_edges(), moab::NCHelperGCRM::create_gather_set_vertices(), moab::NCHelperMPAS::create_gather_set_vertices(), moab::NCHelperGCRM::create_local_edges(), moab::NCHelperMPAS::create_local_edges(), moab::NCHelperGCRM::create_local_vertices(), moab::NCHelperMPAS::create_local_vertices(), moab::NCHelperDomain::create_mesh(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::NCHelperGCRM::create_padded_gather_set_cells(), moab::NCHelperMPAS::create_padded_gather_set_cells(), moab::ReadNCDF::create_ss_elements(), moab::ReadHDF5::create_tag(), create_unitsq_quads(), create_unitsq_tris(), moab::ReadIDEAS::create_vertices(), moab::ReadHDF5::delete_non_side_elements(), moab::ReadParallel::delete_nonlocal_entities(), moab::HalfFacetRep::determine_sibling_halffaces(), moab::ReadSmf::end(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_ghost_cells(), moab::NestedRefine::exchange_ghosts(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::ReadSmf::face(), moab::BitTag::find_entities_with_value(), moab::DenseTag::find_entities_with_value(), moab::SparseTag::find_entities_with_value(), moab::ReadHDF5::find_int_tag(), moab::HalfFacetRep::find_matching_halfface(), moab::HalfFacetRep::find_matching_implicit_edge_in_cell(), DeformMeshRemap::find_other_sets(), moab::ReadHDF5::find_sets_containing(), moab::NestedRefine::find_shortest_diagonal_octahedron(), FunctionC(), moab::WriteCCMIO::gather_matset_info(), moab::WriteVtk::gather_mesh(), moab::WriteTemplate::gather_mesh_information(), moab::WriteSLAC::gather_mesh_information(), moab::WriteNCDF::gather_mesh_information(), moab::GeomTopoTool::generate_implicit_complement(), moab::GeomTopoTool::geometrize_surface_set(), moab::VarLenDenseTag::get_array(), moab::DenseTag::get_array_private(), moab::ReadNC::get_attributes(), moab::NestedRefine::get_connectivity(), moab::MeshTag::get_data(), moab::VarLenDenseTag::get_data(), moab::VarLenSparseTag::get_data(), moab::BitTag::get_data(), moab::ReadNC::get_dimensions(), moab::NestedRefine::get_local_vid(), moab::Tqdcfr::get_mesh_entities(), moab::RangeSetIterator::get_next_by_dimension(), moab::GeomQueryTool::get_normal(), moab::ParallelComm::get_remote_handles(), moab::GeomTopoTool::get_sense(), moab::GeomTopoTool::get_senses(), moab::ReadABAQUS::get_set_by_name(), moab::ReadHDF5::get_set_contents(), moab::HalfFacetRep::get_sibling_map(), moab::ReadHDF5::get_subset_ids(), moab::GeomTopoTool::get_surface_senses(), moab::WriteUtil::get_tag_list(), moab::NCHelper::get_tag_to_nonset(), moab::NCHelper::get_tag_to_set(), moab::ReadHDF5::get_tagged_entities(), moab::HalfFacetRep::get_up_adjacencies_edg_3d(), moab::HalfFacetRep::get_up_adjacencies_vert_3d(), moab::WriteTemplate::get_valid_sides(), moab::WriteSLAC::get_valid_sides(), moab::ReadNC::get_variables(), moab::NestedRefine::get_vertex_duplicates(), moab::HiReconstruction::hiproj_walf_around_vertex(), moab::HiReconstruction::hiproj_walf_in_element(), iMOAB_SetDoubleTagStorageWithGid(), moab::ReadHDF5::init(), moab::NCWriteHelper::init_file(), moab::NCHelperHOMME::init_mesh_vals(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperMPAS::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperGCRM::init_mesh_vals(), moab::NCHelperScrip::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::NestedRefine::initialize(), moab::HiReconstruction::initialize(), moab::WriteNCDF::initialize_exodus_file(), moab::WriteSLAC::initialize_file(), moab::ReadHDF5::insert_in_id_map(), moab::NestedRefine::is_cell_on_boundary(), moab::NestedRefine::is_entity_on_boundary(), moab::NestedRefine::is_face_on_boundary(), moab::GeomTopoTool::is_owned_set(), moab::NestedRefine::is_vertex_on_boundary(), moab::ReadSms::load_file(), moab::ReadCGNS::load_file(), moab::ReadTemplate::load_file(), moab::ReadIDEAS::load_file(), moab::ReadParallel::load_file(), moab::ReadVtk::load_file(), moab::ReadGmsh::load_file(), moab::ReadCCMIO::load_file(), moab::ReadDamsel::load_file(), moab::ReadTetGen::load_file(), moab::ReadSmf::load_file(), moab::ReadNASTRAN::load_file(), moab::ReadMCNP5::load_file(), moab::ReadCGM::load_file(), moab::ReadSTL::load_file(), moab::ReadNC::load_file(), moab::ReadNCDF::load_file(), moab::Core::load_file(), moab::ReadOBJ::load_file(), moab::Tqdcfr::load_file(), moab::ReadABAQUS::load_file(), moab::ReadHDF5::load_file_impl(), moab::ReadHDF5::load_file_partial(), load_meshset_hirec(), main(), moab::WriteDamsel::map_sparse_tags(), moab::GeomQueryTool::measure_area(), moab::GeomQueryTool::measure_volume(), moab::LinearTri::normalFcn(), moab::LinearHex::normalFcn(), moab::LinearQuad::normalFcn(), moab::LinearTet::normalFcn(), moab::not_root_set(), moab::ReadTetGen::open_file(), moab::WriteTemplate::open_file(), moab::WriteSLAC::open_file(), moab::WriteNCDF::open_file(), moab::ParallelComm::pack_entities(), moab::ParallelComm::pack_sets(), moab::ParallelComm::pack_tag(), moab::WriteHDF5Parallel::parallel_create_file(), moab::WriteHDF5::parallel_create_file(), moab::NestedRefine::parent_to_child(), moab::ReadSmf::parse_doubles(), moab::ReadSmf::parse_line(), moab::ReadDamsel::parse_options(), moab::ReadNC::parse_options(), moab::WriteNC::parse_options(), MetisPartitioner::partition_mesh(), moab::LloydSmoother::perform_smooth(), moab::GeomQueryTool::point_in_volume(), moab::ParallelComm::post_irecv(), moab::WriteNC::process_concatenated_attribute(), moab::WriteNC::process_conventional_tags(), moab::ReadDamsel::process_entity_tags(), moab::GeomQueryTool::ray_fire(), moab::ReadHDF5::read_adjacencies(), moab::ReadHDF5::read_all_set_meta(), moab::ReadNCDF::read_block_headers(), moab::NCHelper::read_coordinate(), moab::ReadHDF5::read_dense_tag(), moab::ReadTetGen::read_elem_file(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadNCDF::read_elements(), moab::ReadHDF5::read_elems(), moab::ReadNCDF::read_exodus_header(), moab::ReadNCDF::read_face_blocks_headers(), moab::ReadCCMIO::read_faces(), DeformMeshRemap::read_file(), moab::ReadCCMIO::read_gids_and_types(), moab::ReadNCDF::read_global_ids(), moab::ReadNC::read_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::ReadABAQUS::read_instance(), moab::ReadTetGen::read_line(), moab::ReadHDF5::read_node_adj_elems(), moab::ReadTetGen::read_node_file(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadNCDF::read_nodes(), moab::ReadHDF5::read_nodes(), moab::ReadNCDF::read_nodesets(), moab::ReadABAQUS::read_part(), moab::ReadHDF5::read_poly(), moab::ReadNCDF::read_polyhedra_faces(), moab::ReadHDF5::read_qa(), moab::ReadNCDF::read_qa_string(), moab::ScdNCHelper::read_scd_variables_to_nonset(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::ReadHDF5::read_set_data(), moab::ReadHDF5::read_set_ids_recursive(), moab::ReadHDF5::read_sets(), moab::ReadNCDF::read_sidesets(), moab::ReadABAQUS::read_solid_section(), moab::ReadHDF5::read_sparse_tag(), moab::ReadHDF5::read_sparse_tag_indices(), moab::ReadHDF5::read_tag(), moab::ReadHDF5::read_tag_values(), moab::ReadNCDF::read_tag_values(), moab::ReadHDF5::read_tag_values_all(), moab::ReadHDF5::read_tag_values_partial(), moab::NCHelperHOMME::read_ucd_variables_to_nonset(), moab::NCHelperMPAS::read_ucd_variables_to_nonset(), moab::NCHelperGCRM::read_ucd_variables_to_nonset(), moab::NCHelperHOMME::read_ucd_variables_to_nonset_allocate(), moab::NCHelperMPAS::read_ucd_variables_to_nonset_allocate(), moab::NCHelperGCRM::read_ucd_variables_to_nonset_allocate(), moab::ReadHDF5::read_var_len_tag(), moab::NCHelper::read_variables_setup(), moab::NCHelper::read_variables_to_set(), moab::NCHelper::read_variables_to_set_allocate(), moab::HiReconstruction::reconstruct3D_curve_geom(), moab::HiReconstruction::reconstruct3D_surf_geom(), moab::ParallelComm::recv_buffer(), moab::ParallelComm::recv_entities(), moab::ParallelComm::recv_messages(), moab::ParallelComm::recv_remote_handle_messages(), moab::ParallelComm::reduce_tags(), moab::ReaderWriterSet::register_factory(), moab::Core::remove_set_iterator(), moab::NestedRefine::reorder_indices(), moab::SequenceManager::reserve_tag_array(), moab::HalfFacetRep::resize_hf_maps(), moab::ParallelComm::resolve_shared_ents(), moab::GeomTopoTool::restore_topology_from_adjacency(), moab::ReadSmf::rot(), moab::ParallelComm::scatter_entities(), moab::ReadHDF5::search_tag_values(), moab::ParallelComm::send_buffer(), moab::ParallelComm::send_recv_entities(), moab::ParCommGraph::send_tag_values(), moab::Core::serial_load_file(), moab::ReadSmf::set(), moab::MeshTag::set_data(), moab::VarLenDenseTag::set_data(), moab::VarLenSparseTag::set_data(), moab::BitTag::set_data(), moab::GeomTopoTool::set_sense(), moab::HalfFacetRep::set_sibling_map(), moab::GeomTopoTool::set_surface_senses(), moab::ReadHDF5::set_up_read(), moab::ParallelComm::settle_intersection_points(), moab::BitTag::tag_iterate(), moab::VarLenDenseTag::tag_iterate(), moab::VarLenSparseTag::tag_iterate(), moab::ScdInterface::tag_shared_vertices(), moab::ReadNCDF::update(), moab::ReadHDF5::update_connectivity(), moab::NestedRefine::update_global_ahf(), moab::NestedRefine::update_global_ahf_1D(), moab::NestedRefine::update_global_ahf_1D_sub(), moab::NestedRefine::update_global_ahf_2D(), moab::NestedRefine::update_global_ahf_2D_sub(), moab::NestedRefine::update_global_ahf_3D(), moab::ParallelComm::update_remote_data(), moab::TagInfo::validate_lengths(), moab::ReadVtk::vtk_create_structured_elems(), moab::ReadVtk::vtk_read_polydata(), moab::ReadVtk::vtk_read_rectilinear_grid(), moab::ReadVtk::vtk_read_scalar_attrib(), moab::ReadVtk::vtk_read_structured_grid(), moab::ReadVtk::vtk_read_structured_points(), moab::ReadVtk::vtk_read_texture_attrib(), moab::ReadVtk::vtk_read_unstructured_grid(), moab::WriteNCDF::write_BCs(), moab::WriteVtk::write_bit_tag(), moab::WriteNCDF::write_element_order_map(), moab::WriteNCDF::write_elementblocks(), moab::WriteVtk::write_elems(), moab::WriteDamsel::write_entities(), moab::WriteNCDF::write_exodus_integer_variable(), moab::WriteCCMIO::write_external_faces(), moab::WriteSmf::write_file(), moab::WriteVtk::write_file(), moab::WriteGmsh::write_file(), moab::WriteSTL::write_file(), moab::WriteCCMIO::write_file(), moab::WriteNC::write_file(), moab::WriteNCDF::write_file(), moab::Core::write_file(), moab::WriteNCDF::write_global_element_order_map(), moab::WriteNCDF::write_global_node_order_map(), moab::WriteCCMIO::write_nodes(), moab::WriteNCDF::write_nodes(), moab::NCWriteHOMME::write_nonset_variables(), moab::NCWriteGCRM::write_nonset_variables(), moab::NCWriteMPAS::write_nonset_variables(), moab::ScdNCWriteHelper::write_nonset_variables(), moab::WriteNCDF::write_poly_faces(), moab::WriteNCDF::write_qa_string(), moab::NCWriteHelper::write_set_variables(), moab::NCWriteHelper::write_values(), and moab::WriteDamsel::write_vertices().
| #define MB_SET_ERR_CONT | ( | err_msg | ) |
do \ { \ std::ostringstream err_ostr; \ err_ostr << err_msg; \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_LOCAL ); \ } while( false )
Set a new error with the given error message (a string or a stream) and continue Used in functions which return any data type
Definition at line 96 of file ErrorHandler.hpp.
Referenced by moab::WriteHDF5Parallel::create_tag_tables(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::WriteNCDF::initialize_exodus_file(), moab::ReadHDF5::is_error(), moab::FileTokenizer::match_token(), moab::ReadHDF5::read_tag_values_all(), moab::WriteNCDF::write_elementblocks(), moab::WriteHDF5::write_elems(), moab::WriteHDF5::write_file(), moab::WriteHDF5::write_file_impl(), and moab::WriteNCDF::write_poly_faces().
| #define MB_SET_ERR_RET | ( | err_msg | ) |
do \ { \ std::ostringstream err_ostr; \ err_ostr << err_msg; \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_LOCAL ); \ return; \ } while( false )
Set a new error with the given error message (a string or a stream) and return Used in functions which return void types (or have no return types at all, e.g. constructors)
Definition at line 72 of file ErrorHandler.hpp.
Referenced by moab::DGMSolver::vec_dotprod(), moab::DGMSolver::vec_linear_operation(), moab::DGMSolver::vec_projoff(), moab::DGMSolver::vec_scalarprod(), and verdict_unit_tests().
| #define MB_SET_ERR_RET_VAL | ( | err_msg, | |
| ret_val | |||
do \ { \ std::ostringstream err_ostr; \ err_ostr << err_msg; \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_LOCAL ); \ return ret_val; \ } while( false )
Set a new error with the given error message (a string or a stream) and return the given value Used in functions which return any data type
Definition at line 84 of file ErrorHandler.hpp.
Referenced by moab::FileTokenizer::get_boolean_internal(), moab::FileTokenizer::get_byte_internal(), moab::ReadRTT::get_cell_data(), moab::FileTokenizer::get_double_internal(), moab::ReadRTT::get_facet_data(), moab::FileTokenizer::get_integer_internal(), moab::FileTokenizer::get_long_int_internal(), moab::FileTokenizer::get_newline(), moab::ReadRTT::get_node_data(), moab::FileTokenizer::get_short_int_internal(), moab::ReadRTT::get_side_data(), moab::FileTokenizer::get_string(), moab::ReadRTT::get_tet_data(), moab::TempestRemapper::GetMeshEntities(), moab::TempestRemapper::GetMeshSet(), moab::TempestRemapper::GetMeshVertices(), moab::WriteSTL::open_file(), moab::ReadHDF5::read_node_adj_elems(), moab::SpectralMeshTool::spectral_vertices_tag(), moab::DGMSolver::vec_2norm(), moab::DGMSolver::vec_innerprod(), and moab::DGMSolver::vec_normalize().
| #define MB_SET_GLB_ERR | ( | err_code, | |
| err_msg | |||
do \ { \ std::ostringstream err_ostr; \ err_ostr << err_msg; \ return moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, err_code, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_GLOBAL ); \ } while( false )
Definition at line 106 of file ErrorHandler.hpp.
Referenced by FunctionC(), moab::Core::load_file(), moab::ScdNCHelper::read_scd_variables_to_nonset_allocate(), moab::Core::serial_load_file(), and moab::Core::write_file().
| #define MB_SET_GLB_ERR_CONT | ( | err_msg | ) |
do \ { \ std::ostringstream err_ostr; \ err_ostr << ( err_msg ); \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_GLOBAL ); \ } while( false )
Definition at line 138 of file ErrorHandler.hpp.
| #define MB_SET_GLB_ERR_RET | ( | err_msg | ) |
do \ { \ std::ostringstream err_ostr; \ err_ostr << ( err_msg ); \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_GLOBAL ); \ return; \ } while( false )
Definition at line 116 of file ErrorHandler.hpp.
| #define MB_SET_GLB_ERR_RET_VAL | ( | err_msg, | |
| ret_val | |||
do \ { \ std::ostringstream err_ostr; \ err_ostr << ( err_msg ); \ moab::MBError( __LINE__, __func__, __FILENAME__, __MBSDIR__, moab::MB_FAILURE, err_ostr.str().c_str(), \ moab::MB_ERROR_TYPE_NEW_GLOBAL ); \ return ret_val; \ } while( false )
Definition at line 127 of file ErrorHandler.hpp.
| #define MBSTRINGIFY | ( | X | ) | MBSTRINGIFY_( X ) |
Definition at line 51 of file ErrorHandler.hpp.
| #define MBSTRINGIFY_ | ( | X | ) | #X |
Definition at line 50 of file ErrorHandler.hpp.
