MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/Core.hpp" 00002 #include "moab/CartVect.hpp" 00003 #include "moab/Range.hpp" 00004 #include "moab/verdict/VerdictWrapper.hpp" 00005 #include <iostream> 00006 #include <iomanip> 00007 #include <cstdio> 00008 #include "TestUtil.hpp" 00009 00010 std::string filename = TestDir + "unittest/mbtest1.vtk"; 00011 00012 using namespace moab; 00013 00014 void verdict_test1(); 00015 void verdict_unit_tests(); 00016 00017 int main( int argc, char* argv[] ) 00018 { 00019 if( argc > 1 ) 00020 if( argc > 1 ) filename = std::string( argv[1] ); 00021 00022 int result = 0; 00023 00024 result += RUN_TEST( verdict_test1 ); 00025 result += RUN_TEST( verdict_unit_tests ); 00026 00027 return result; 00028 } 00029 void verdict_test1() 00030 { 00031 ErrorCode rval; 00032 Core moab_core; 00033 Interface* mb = &moab_core; 00034 rval = mb->load_mesh( filename.c_str() );CHECK_ERR( rval ); 00035 00036 Range entities; 00037 rval = mb->get_entities_by_handle( 0, entities ); // all entities from the model 00038 CHECK_ERR( rval ); 00039 00040 VerdictWrapper vw( mb ); 00041 // for size methods/quality, we need a size, to compute relative sizes and stuff 00042 rval = vw.set_size( 1.0 );CHECK_ERR( rval ); 00043 for( Range::iterator eit = entities.begin(); eit != entities.end(); ++eit ) 00044 { 00045 EntityHandle eh = *eit; 00046 EntityType etype = TYPE_FROM_HANDLE( eh ); 00047 if( etype == MBVERTEX || etype > MBHEX ) continue; 00048 for( int quality = 0; quality < MB_QUALITY_COUNT; quality++ ) 00049 { 00050 QualityType q = (QualityType)quality; 00051 double qm; 00052 rval = vw.quality_measure( eh, q, qm ); 00053 if( MB_NOT_IMPLEMENTED == rval ) continue; 00054 if( MB_FAILURE == rval ) 00055 { 00056 std::cerr << " failure for entity " << mb->list_entity( eh ) << " quality " << vw.quality_name( q ) 00057 << "\n"; 00058 } 00059 if( MB_SUCCESS == rval ) 00060 { 00061 std::cout << "Entity type " << (EntityType)mb->type_from_handle( eh ) 00062 << " id:" << mb->id_from_handle( eh ) << " quality:" << vw.quality_name( q ) << " : " << qm 00063 << "\n"; 00064 } 00065 } 00066 // now compute all qualities for each entity handle 00067 std::map< QualityType, double > qualities; 00068 00069 rval = vw.all_quality_measures( eh, qualities ); 00070 if( MB_SUCCESS == rval ) 00071 { 00072 mb->list_entity( eh ); 00073 for( std::map< QualityType, double >::iterator mit = qualities.begin(); mit != qualities.end(); ++mit ) 00074 { 00075 std::cout << " " << vw.quality_name( mit->first ) << " " << mit->second << " \n"; 00076 } 00077 } 00078 } 00079 00080 return; 00081 } 00082 00083 #define MAX_NODES_PER_ELEMENT 27 00084 #define MAX_TESTS_PER_ELEMENT 20 00085 00086 #ifdef VERDICT_USE_FLOAT 00087 #define VERDICT_SIGNIFICANT_FIG 7 // 7 significant figures for floats 00088 #else 00089 #define VERDICT_SIGNIFICANT_FIG 15 // 15 significant figures for doubles 00090 #endif 00091 00092 struct test_case 00093 { 00094 const char* testname; 00095 EntityType etype; 00096 // VerdictFunction function[MAX_TESTS_PER_ELEMENT]; 00097 QualityType function[MAX_TESTS_PER_ELEMENT]; 00098 int num_nodes; 00099 // note: the 1st dim. of coords must bigger than the maximum num_nodes 00100 // for any one element being tested 00101 // double coords[MAX_NODES_PER_ELEMENT][3]; 00102 double coords[MAX_NODES_PER_ELEMENT * 3]; 00103 double answer[MAX_TESTS_PER_ELEMENT]; 00104 }; 00105 using namespace std; 00106 00107 void verdict_unit_tests() 00108 { 00109 // all test cases go here 00110 test_case testcases[] = { 00111 { "edge calc 1", 00112 MBEDGE, 00113 { MB_LENGTH, MB_UNDEFINED_QUALITY }, 00114 2, 00115 { 0.0, 0.0, 0.0, 1.0, 1.0, 1.0 }, 00116 { 1.732050807568877, 0.0 } }, 00117 00118 { "edge calc 2", 00119 MBEDGE, 00120 { MB_LENGTH, MB_UNDEFINED_QUALITY }, 00121 2, 00122 { 0.0, 0.0, 0.0, 1.0, 0.0, 0.0 }, 00123 { 1.0, 0.0 } }, 00124 00125 { "edge calc 3", 00126 MBEDGE, 00127 { MB_LENGTH, MB_UNDEFINED_QUALITY }, 00128 2, 00129 { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }, 00130 { 0.0, 0.0 } }, 00131 00132 { "simple wedge", 00133 MBPRISM, 00134 { MB_VOLUME, MB_UNDEFINED_QUALITY }, 00135 6, 00136 { 0.0, 0.0, 0.0, -1.0, 1.0, 0.0, -1.0, 0.0, 0.0, 0.0, 0.0, 1.0, -1.0, 1.0, 1.0, -1.0, 0.0, 1.0 }, 00137 { 0.5, 0.0 } }, 00138 00139 { "singularity wedge", 00140 MBPRISM, 00141 { MB_VOLUME, MB_UNDEFINED_QUALITY }, 00142 6, 00143 { 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0 }, 00144 { 0.0, 0.0 } }, 00145 00146 { "simple tri", 00147 MBTRI, 00148 { MB_AREA, MB_MINIMUM_ANGLE, MB_MAXIMUM_ANGLE, MB_CONDITION, MB_SCALED_JACOBIAN, MB_SHAPE, 00149 MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY }, 00150 3, 00151 { 00152 0.0, 00153 0.0, 00154 0.0, 00155 5, 00156 0.0, 00157 0.0, 00158 2.5, 00159 4.330127, 00160 0.0, 00161 }, 00162 { 10.825317499999997, 5.999999989158383329e+01, 6.000000021683238316e+01, 1.000000000000000000e+00, 00163 9.999999989075266660e-01, 1.000000000000000000e+00, 8.533333407912848181e-03, 8.533333407912848181e-03, 00164 1.000000000000000000e+00, 0.0 } }, 00165 00166 /* 00167 { 00168 "singular tri", 00169 MBTRI, 00170 { v_tri_area, v_tri_aspect_ratio, v_tri_condition, 00171 v_tri_distortion, v_tri_minimum_angle, v_tri_maximum_angle, 00172 v_tri_relative_size_squared, v_tri_shape, v_tri_shape_and_size, 00173 MB_UNDEFINED_QUALITY 00174 }, 00175 3, 00176 { 00177 {0,0,0}, 00178 {0.5,0.8660254037,0}, 00179 {1,0,0} 00180 }, 00181 { 123, 1234, 1234, 1234, 1234, 1234, 1234, 1234, 1234,0} 00182 }, 00183 */ 00184 00185 /* 00186 { 00187 "simple quad", 00188 MBQUAD, 00189 { v_quad_skew, MB_UNDEFINED_QUALITY}, 00190 4, 00191 { 00192 {0,0,0}, 00193 {1,0,0}, 00194 {1,7,0}, 00195 {0,7,0 } 00196 }, 00197 { 1.3333333333333333333, 0 } 00198 }, 00199 */ 00200 00201 { "simple quad", 00202 MBQUAD, 00203 { MB_ASPECT_RATIO, MB_SKEW, MB_TAPER, MB_WARPAGE, MB_AREA, MB_STRETCH, MB_MAXIMUM_ANGLE, MB_MINIMUM_ANGLE, 00204 MB_CONDITION, MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, 00205 MB_SHAPE_AND_SIZE, MB_SHEAR_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY }, 00206 4, 00207 { 00208 2.0, 0.0, 0.0, // 1 00209 1.0, 1.0, 2.0, // 2 00210 0.0, 1.0, 0.0, // 3 00211 0.0, 0.0, 0.0, // 0 00212 00213 }, 00214 { 1.429964171762364344e+00, 9.245003270420482089e-02, 7.453559924999298980e-01, 7.999999999999998432e-03, 00215 2.692582403567252314e+00, 5.773502691896258421e-01, 9.000000000000000000e+01, 5.678908923910092454e+01, 00216 2.307927774486215888e+00, 1.114172029062311164e+00, 5.570860145311555822e-01, 5.570860145311555822e-01, 00217 4.332891224131210084e-01, 9.999999999999995559e-01, 4.332891224131208419e-01, 5.570860145311553602e-01, 00218 5.626795729450876360e-01, 0.0 } }, 00219 00220 { "tet test", 00221 MBTET, 00222 { /*MB_SHEAR,*/ MB_VOLUME, MB_CONDITION, MB_JACOBIAN, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHAPE_AND_SIZE, 00223 MB_DISTORTION, MB_UNDEFINED_QUALITY }, 00224 4, 00225 { 00226 -5.0, 00227 -5.0, 00228 -5.0, 00229 -5.0, 00230 5.0, 00231 -5.0, 00232 -5.0, 00233 -5.0, 00234 5.0, 00235 5.0, 00236 -5.0, 00237 -5.0, 00238 00239 }, 00240 { 1.666666666666666572e+02, 1.224744871391589385e+00, 1.000000000000000000e+03, 8.399473665965818681e-01, 00241 3.599999999998462557e-05, 3.023810519746403209e-05, 1.000000000000000000e+00, 0.0 } }, 00242 00243 { "hex test", 00244 MBHEX, 00245 { /*MB_ASPECT_RATIO,*/ MB_SKEW, MB_TAPER, MB_VOLUME, MB_STRETCH, MB_DIAGONAL, MB_DIMENSION, MB_CONDITION, 00246 MB_JACOBIAN, MB_SCALED_JACOBIAN, MB_SHEAR, MB_SHAPE, MB_RELATIVE_SIZE_SQUARED, MB_SHEAR_AND_SIZE, 00247 MB_SHAPE_AND_SIZE, MB_DISTORTION, MB_UNDEFINED_QUALITY }, 00248 8, 00249 { 00250 -0.2, -0.7, -0.3, // 1 00251 -0.7, 0.4, -0.6, // 2 00252 -0.5, 0.5, 0.3, // 3 00253 -0.3, -0.5, 0.5, // 0 00254 00255 0.5, -0.8, -0.2, // 5 00256 0.4, 0.4, -0.6, // 6 00257 0.2, 0.5, 0.2, // 7 00258 0.5, -0.3, 0.8 // 4 00259 }, 00260 { 2.458897037399689067e-01, 1.784576525620624188e-01, 8.130624999999999103e-01, 6.209702997008308412e-01, 00261 6.896219298787312768e-01, 5.245942005845132261e-01, 1.273059825673506174e+00, 4.769999999999999241e-01, 00262 7.778495101180593618e-01, 7.778495101180593618e-01, 7.897852810190353345e-01, 6.738357656250002492e-01, 00263 5.241428201914338780e-01, 5.321855695148176579e-01, 5.847977114834492784e-01, 0.0 } }, 00264 00265 // keep this one last 00266 // { 0, {MB_UNDEFINED_QUALITY} , 0, {{0}} , {0} } }; 00267 { 0, MBMAXTYPE, { MB_UNDEFINED_QUALITY }, 0, { 0.0, 0.0 }, { 0.0, 0.0 } } 00268 00269 }; 00270 00271 int i; 00272 int j = 0; 00273 double answer_from_lib; 00274 double tolerance; 00275 // double norm_answer_from_lib; 00276 00277 #define MAX_STR_LEN 30 00278 00279 char exponent[MAX_STR_LEN]; 00280 char* base_ptr; 00281 int base; 00282 bool passed = true; // have all the tests performed so far passed? 00283 00284 cout.setf( ios::scientific, ios::floatfield ); 00285 cout.precision( VERDICT_SIGNIFICANT_FIG + 3 ); 00286 00287 ErrorCode merr; 00288 Interface* iface = new Core(); 00289 VerdictWrapper* vw = new VerdictWrapper( iface ); 00290 EntityHandle dummy = 0; 00291 00292 // loop through each test 00293 for( i = 0; testcases[i].testname != 0; i++ ) 00294 { 00295 cout << endl 00296 << "[" << i << "]: " 00297 << "Test case: " << testcases[i].testname << endl; 00298 00299 for( j = 0; testcases[i].function[j] != MB_UNDEFINED_QUALITY; j++ ) 00300 { 00301 /* 00302 answer_from_lib = 00303 (testcases[i].function[j]) 00304 (testcases[i].num_nodes, testcases[i].coords); 00305 */ 00306 00307 cout << "\t #" << j + 1 << " TESTING :: " << QualityType_ToString( testcases[i].function[j] ) << endl; 00308 merr = vw->quality_measure( dummy, testcases[i].function[j], answer_from_lib, testcases[i].num_nodes, 00309 testcases[i].etype, testcases[i].coords ); 00310 if( MB_SUCCESS != merr ) 00311 { 00312 delete vw; 00313 delete iface; 00314 MB_SET_ERR_RET( "Failed to compute the quality for an element" ); 00315 } 00316 00317 sprintf( exponent, "%e", testcases[i].answer[j] ); 00318 base_ptr = strstr( exponent, "e" ); 00319 00320 base_ptr = &base_ptr[1]; 00321 00322 base = atoi( base_ptr ); 00323 00324 tolerance = pow( 10.0, -VERDICT_SIGNIFICANT_FIG ) * pow( 10.0, base ); 00325 00326 if( fabs( answer_from_lib - testcases[i].answer[j] ) > tolerance ) 00327 { 00328 cout << "\t #" << j + 1 << " FAILED :: " << QualityType_ToString( testcases[i].function[j] ) << endl; 00329 00330 cout << "\t\t calculated ( " << answer_from_lib << " ) and " 00331 << "expected ( " << testcases[i].answer[j] << ") " << endl; 00332 passed = false; 00333 } 00334 else 00335 { 00336 cout << "\t #" << j + 1 << " PASSED :: " << QualityType_ToString( testcases[i].function[j] ) << endl; 00337 } 00338 } 00339 } 00340 delete vw; 00341 delete iface; 00342 std::cout << endl << "All tests passed ? " << ( passed ? 1 : 0 ) << endl; 00343 return; 00344 }
