MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for QuadTriConv.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char **argv) |
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 20 of file QuadTriConv.cpp.
References moab::Range::begin(), moab::Interface::create_element(), moab::Interface::delete_entities(), moab::Range::end(), ErrorCode, filename, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_dimension(), moab::Range::insert(), moab::Interface::load_file(), mb, MB_CHK_SET_ERR, MBPOLYGON, MBQUAD, MBTRI, outfile, moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), moab::Interface::tag_set_data(), and moab::Interface::write_file().
// Get MOAB instance
Interface* mb = new( std::nothrow ) Core;
if( NULL == mb ) return 1;
std::string filename, outfile;
outfile = string( "out.h5m" );
if( argc == 1 ) return 0;
if( argc > 1 ) filename = string( argv[1] );
if( argc > 2 ) outfile = string( argv[2] );
// This file is in the mesh files directory
ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "Failed to read" );
// get all cells of dimension 2;
Range cells;
rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" );
cout << " number of cells : " << cells.size() << "\n";
Tag gid; // global id tag
rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "Failed to get Global ID tag" );
Range modifiedCells; // will be deleted at the end; keep the gid
for( Range::iterator cit = cells.begin(); cit != cells.end(); cit++ )
EntityHandle cell = *cit;
const EntityHandle* connec = NULL;
int num_verts = 0;
rval = mb->get_connectivity( cell, connec, num_verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" );
vector< EntityHandle > newConnec;
newConnec.push_back( connec[0] ); // at least one vertex
int index = 0;
int new_size = 1;
while( index < num_verts - 2 )
int next_index = ( index + 1 );
if( connec[next_index] != newConnec[new_size - 1] )
newConnec.push_back( connec[next_index] );
new_size++;
index++;
// add the last one only if different from previous and first node
if( ( connec[num_verts - 1] != connec[num_verts - 2] ) && ( connec[num_verts - 1] != connec[0] ) )
newConnec.push_back( connec[num_verts - 1] );
new_size++;
if( new_size < num_verts )
// cout << "new cell from " << cell << " has only " << new_size << " vertices \n";
modifiedCells.insert( cell );
// create a new cell with type triangle, quad or polygon
EntityType type = MBTRI;
if( new_size == 3 )
type = MBTRI;
else if( new_size == 4 )
type = MBQUAD;
else if( new_size > 4 )
type = MBPOLYGON;
// create new cell
EntityHandle newCell;
rval = mb->create_element( type, &newConnec[0], new_size, newCell );MB_CHK_SET_ERR( rval, "Failed to create new cell" );
// set the old id to the new element
int id;
rval = mb->tag_get_data( gid, &cell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to get global id" );
rval = mb->tag_set_data( gid, &newCell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to set global id on new cell" );
mb->delete_entities( modifiedCells );
// in case global ids are not set for vertices, set them, in order;
// they are needed for migrating later on
Range verts;
rval = mb->get_entities_by_dimension( 0, 0, verts );MB_CHK_SET_ERR( rval, "Failed to get vertices" );
vector< int > gids;
gids.resize( verts.size() );
rval = mb->tag_get_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to get gids on vertices" );
if( gids[0] <= 0 )
// gids were never set, assign them
for( size_t i = 1; i <= verts.size(); i++ )
gids[i - 1] = (int)i;
rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to set gids on vertices" );
rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "Failed to write new file" );
cout << " wrote file " << outfile << " with " << modifiedCells.size() << " modified cells\n";
delete mb;
return 0;
