MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example QuadTriConv.cpp \n 00002 * \brief Merge vertices in 2d cell, if they are repeated \n 00003 * <b>To run</b>: QuadTriConv input_file output_file \n 00004 * 00005 * In this example, a mesh that has vertices repeated due to south or north pole, for 00006 * example in an rll mesh, need to be converted to triangles, preserving GLOBAL_ID tag 00007 */ 00008 00009 #include <iostream> 00010 #include <vector> 00011 //#include <string> 00012 00013 // Include header for MOAB instance and tag conventions for 00014 #include "moab/Core.hpp" 00015 #include "MBTagConventions.hpp" 00016 00017 using namespace moab; 00018 using namespace std; 00019 00020 int main( int argc, char** argv ) 00021 { 00022 // Get MOAB instance 00023 Interface* mb = new( std::nothrow ) Core; 00024 if( NULL == mb ) return 1; 00025 00026 std::string filename, outfile; 00027 outfile = string( "out.h5m" ); 00028 if( argc == 1 ) return 0; 00029 if( argc > 1 ) filename = string( argv[1] ); 00030 if( argc > 2 ) outfile = string( argv[2] ); 00031 00032 // This file is in the mesh files directory 00033 ErrorCode rval = mb->load_file( filename.c_str() );MB_CHK_SET_ERR( rval, "Failed to read" ); 00034 00035 // get all cells of dimension 2; 00036 Range cells; 00037 rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "Failed to get cells" ); 00038 00039 cout << " number of cells : " << cells.size() << "\n"; 00040 00041 Tag gid; // global id tag 00042 rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "Failed to get Global ID tag" ); 00043 00044 Range modifiedCells; // will be deleted at the end; keep the gid 00045 00046 for( Range::iterator cit = cells.begin(); cit != cells.end(); cit++ ) 00047 { 00048 EntityHandle cell = *cit; 00049 const EntityHandle* connec = NULL; 00050 int num_verts = 0; 00051 rval = mb->get_connectivity( cell, connec, num_verts );MB_CHK_SET_ERR( rval, "Failed to get connectivity" ); 00052 00053 vector< EntityHandle > newConnec; 00054 newConnec.push_back( connec[0] ); // at least one vertex 00055 int index = 0; 00056 int new_size = 1; 00057 while( index < num_verts - 2 ) 00058 { 00059 int next_index = ( index + 1 ); 00060 if( connec[next_index] != newConnec[new_size - 1] ) 00061 { 00062 newConnec.push_back( connec[next_index] ); 00063 new_size++; 00064 } 00065 index++; 00066 } 00067 // add the last one only if different from previous and first node 00068 if( ( connec[num_verts - 1] != connec[num_verts - 2] ) && ( connec[num_verts - 1] != connec[0] ) ) 00069 { 00070 newConnec.push_back( connec[num_verts - 1] ); 00071 new_size++; 00072 } 00073 if( new_size < num_verts ) 00074 { 00075 // cout << "new cell from " << cell << " has only " << new_size << " vertices \n"; 00076 modifiedCells.insert( cell ); 00077 // create a new cell with type triangle, quad or polygon 00078 EntityType type = MBTRI; 00079 if( new_size == 3 ) 00080 type = MBTRI; 00081 else if( new_size == 4 ) 00082 type = MBQUAD; 00083 else if( new_size > 4 ) 00084 type = MBPOLYGON; 00085 00086 // create new cell 00087 EntityHandle newCell; 00088 rval = mb->create_element( type, &newConnec[0], new_size, newCell );MB_CHK_SET_ERR( rval, "Failed to create new cell" ); 00089 // set the old id to the new element 00090 int id; 00091 rval = mb->tag_get_data( gid, &cell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to get global id" ); 00092 rval = mb->tag_set_data( gid, &newCell, 1, &id );MB_CHK_SET_ERR( rval, "Failed to set global id on new cell" ); 00093 } 00094 } 00095 00096 mb->delete_entities( modifiedCells ); 00097 // in case global ids are not set for vertices, set them, in order; 00098 // they are needed for migrating later on 00099 // 00100 Range verts; 00101 rval = mb->get_entities_by_dimension( 0, 0, verts );MB_CHK_SET_ERR( rval, "Failed to get vertices" ); 00102 00103 vector< int > gids; 00104 gids.resize( verts.size() ); 00105 rval = mb->tag_get_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to get gids on vertices" ); 00106 if( gids[0] <= 0 ) 00107 { 00108 // gids were never set, assign them 00109 for( size_t i = 1; i <= verts.size(); i++ ) 00110 gids[i - 1] = (int)i; 00111 rval = mb->tag_set_data( gid, verts, &gids[0] );MB_CHK_SET_ERR( rval, "Failed to set gids on vertices" ); 00112 } 00113 rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "Failed to write new file" ); 00114 00115 cout << " wrote file " << outfile << " with " << modifiedCells.size() << " modified cells\n"; 00116 00117 delete mb; 00118 return 0; 00119 }
