MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/ParallelComm.hpp"#include "MBParallelConventions.h"#include "moab/iMOAB.h"#include "TestUtil.hpp"#include "moab/CpuTimer.hpp"#include "moab/ProgOptions.hpp"#include <iostream>#include <sstream>#include "imoab_coupler_utils.hpp"
Include dependency graph for imoab_scrip.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 26 of file imoab_scrip.cpp.
References ProgOptions::addOpt(), atmFilename, CHECKIERR, create_group_and_comm(), create_joint_comm_group(), endG1, endG2, filename, fileWriteOptions(), ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_WriteMesh(), jgroup, MPI_COMM_WORLD, nghlay, numProcesses, ProgOptions::parseCommandLine(), rankInGlobalComm, readopts(), setup_component_coupler_meshes(), startG1, startG2, typeA, and typeB.
int ierr;
int rankInGlobalComm, numProcesses;
MPI_Group jgroup;
std::string readopts2( "PARALLEL=READ_PART;PARTITION_METHOD=RCBZOLTAN" );
std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
std::string readoptsLnd("PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION");
std::string filename=TestDir + "unittest/SCRIPgrid_2x2_nomask_c210211.nc";
std::string atmFilename=TestDir + "unittest/wholeATM_T.h5m";
std::string rofInp=TestDir + "unittest/wholeRof_06.h5m";
std::string seq_flds_r2x_fields("Forr_rofl:Forr_rofi:Firr_rofi:Flrr_flood:Flrr_volr:Flrr_volrmch:Flrr_supply:Flrr_deficit");
int cmpAtm = 5, cmpRof = 21, cplRof=22;
int cplatm = 6; // component ids are unique over all pes, and established in advance;
int nghlay = 0;// no ghost layers
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm );
MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup
int startG1 = 0, startG2 = 0, startG4 = 0;
int endG1, endG2, endG4;
endG1 = endG2 = endG4 = numProcesses-1;
ProgOptions opts;
opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename ", &atmFilename );
opts.addOpt< std::string >( "mosart,m", " mosart with data", &rofInp );
opts.addOpt< std::string >( "scrip,s", "scrip mesh file", &filename );
opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 );
opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 );
opts.addOpt< int >( "startOcn,c", "start task for mosart layout", &startG2 );
opts.addOpt< int >( "endOcn,d", "end task for mosart layout", &endG2 );
opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 );
opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 );
opts.parseCommandLine( argc, argv );
if( !rankInGlobalComm )
std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 <<
"\n mosart input file file: " << rofInp << "\n on tasks : " << startG2 << ":" << endG2 <<
"\n scrip file on coupler: " << filename <<
"\n coupler on tasks : " << startG4 << ":" << endG4 << "\n";
// load files on 2 different communicators, groups
// coupler will be on group 4
MPI_Group atmPEGroup;
MPI_Comm atmComm;
ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm );
CHECKIERR( ierr, "Cannot create atm MPI group and communicator " )
MPI_Group rofPEGroup;
MPI_Comm rofComm;
ierr = create_group_and_comm( startG2, endG2, jgroup, &rofPEGroup, &rofComm );
CHECKIERR( ierr, "Cannot create rof MPI group and communicator " )
// we will always have a coupler
MPI_Group couPEGroup;
MPI_Comm couComm;
ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm );
CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " )
// atm_coupler
MPI_Group joinAtmCouGroup;
MPI_Comm atmCouComm;
ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm );
CHECKIERR( ierr, "Cannot create joint atm cou communicator" )
// rof_coupler
MPI_Group joinRofCouGroup;
MPI_Comm rofCouComm;
ierr = create_joint_comm_group( rofPEGroup, couPEGroup, &joinRofCouGroup, &rofCouComm );
CHECKIERR( ierr, "Cannot create joint rof cou communicator" )
ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should
CHECKIERR( ierr, "Cannot initialize iMOAB" )
int cmpRofID = -1;
iMOAB_AppID rofPID = &cmpRofID;
if (rofComm != MPI_COMM_NULL ) {
ierr = iMOAB_RegisterApplication( "ROF", &rofComm, &cmpRof, rofPID );
CHECKIERR( ierr, "Cannot register Rof App" )
int cmpAtmAppID = -1;
iMOAB_AppID cmpAtmPID = &cmpAtmAppID;
if (atmComm != MPI_COMM_NULL) {
ierr = iMOAB_RegisterApplication( "ATM", &atmComm, &cmpAtm, cmpAtmPID );
CHECKIERR( ierr, "Cannot register Atm App" )
int cplAtmAppID = -1;
iMOAB_AppID cplAtmPID = &cplAtmAppID;
int cplRofAppID = -1;
iMOAB_AppID cplRofPID = &cplRofAppID;
int rankInCouComm = -1;
if( couComm != MPI_COMM_NULL )
MPI_Comm_rank( couComm, &rankInCouComm );
// Register all the applications on the coupler PEs
ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm,
cplAtmPID ); // atm on coupler pes
CHECKIERR( ierr, "Cannot register ATM over coupler PEs" )
ierr = iMOAB_RegisterApplication( "ROFX", &couComm, &cplRof,
cplRofPID ); // ocn on coupler pes
CHECKIERR( ierr, "Cannot register ROFX over coupler PEs" )
int repartitioner_scheme = 0;
#ifdef MOAB_HAVE_ZOLTAN
repartitioner_scheme = 2; // zoltan is used
#endif
if( atmCouComm != MPI_COMM_NULL )
ierr = setup_component_coupler_meshes( cmpAtmPID, cmpAtm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm,
&couPEGroup, &atmCouComm, atmFilename, readopts, nghlay,
repartitioner_scheme );
CHECKIERR( ierr, "Cannot load and migrate atm mesh " )
int tagtype = 1, numco = 1, tagIndex = 0;
if( cmpRofID >= 0 ) {
// load rof mesh with data on it
ierr = iMOAB_LoadMesh( rofPID, rofInp.c_str(), readoptsLnd.c_str(), &nghlay );
CHECKIERR( ierr, "Cannot load mosart data mesh" )
ierr = iMOAB_DefineTagStorage( rofPID, seq_flds_r2x_fields.c_str(), &tagtype, &numco, &tagIndex );
CHECKIERR( ierr, "failed to define the fields on mosart point cloud" )
// load rof scrip file on coupler only
ierr = iMOAB_LoadMesh( cplRofPID, filename.c_str(), readopts2.c_str(), &nghlay );
CHECKIERR( ierr, "Cannot load scrip mesh on coupler" )
// define tags on receiving end
ierr = iMOAB_DefineTagStorage( cplRofPID, seq_flds_r2x_fields.c_str(), &tagtype, &numco, &tagIndex );
CHECKIERR( ierr, "failed to define the fields on mosart coupler mesh " )
// test what we read from scrip file
char outputFileTgt[] = "readCplRof.h5m";
char fileWriteOptions[] = "PARALLEL=WRITE_PART";
ierr = iMOAB_WriteMesh( cplRofPID, outputFileTgt, fileWriteOptions);
CHECKIERR( ierr, "cannot write Rof mesh on coupler" )
// compute comm graph between coupler and wholeRof
if (MPI_COMM_NULL != rofCouComm)
// compute the comm graph between point cloud rof and coupler version of rof (full mesh)
// we are now on joint pes, compute comm graph between rof and coupler model
int typeA = 2; // point cloud on component PEs
int typeB = 3; // full mesh on coupler pes, we just read it
ierr = iMOAB_ComputeCommGraph( rofPID, cplRofPID, &rofCouComm, &rofPEGroup, &couPEGroup,
&typeA, &typeB, &cmpRof, &cplRof) ;
CHECKIERR( ierr, "cannot compute comm graph for mosart " )
// now send / receive some tags
if( cmpRofID >= 0 )
{ // send
// basically, use the initial partitioning
ierr = iMOAB_SendElementTag( rofPID, seq_flds_r2x_fields.c_str(), &rofCouComm, &cplRof );
CHECKIERR( ierr, "cannot send tags " )
if( cplRofAppID >= 0 )
{ // we are on receiving end
ierr = iMOAB_ReceiveElementTag( cplRofPID, seq_flds_r2x_fields.c_str(), &rofCouComm, &cmpRof );
CHECKIERR( ierr, "cannot receive tags " )
char outputFileTgt[] = "afterSend.h5m";
ierr = iMOAB_WriteMesh( cplRofPID, outputFileTgt, fileWriteOptions );
CHECKIERR( ierr, "cannot write Rof mesh with data on coupler" )
if( cmpRofID >= 0 )
{ // send
ierr = iMOAB_FreeSenderBuffers( rofPID, &cplRof );
CHECKIERR( ierr, "cannot free buffers " )
MPI_Finalize();
return 0;
