MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ProgOptions.hpp"#include "moab/Core.hpp"#include <cmath>#include <sstream>#include <iostream>#include <iomanip>#include <fstream>
Include dependency graph for mbaddchunk.cpp:Go to the source code of this file.
Functions | |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 31 of file mbaddchunk.cpp.
References ProgOptions::addOpt(), moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::load_file(), mb, MB_CHK_SET_ERR, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, outfile, ProgOptions::parseCommandLine(), moab::Range::size(), moab::Core::tag_get_data(), moab::Core::tag_get_handle(), moab::Core::tag_set_data(), and moab::Core::write_file().
ProgOptions opts;
std::string inputfile( "penta3d.h5m" ), outfile( "penta3d_ch.h5m" ), chunkfile_name, gsmapfile;
opts.addOpt< std::string >( "input,i", "input mesh filename", &inputfile );
opts.addOpt< std::string >( "chunkFile,n", "chunk file from cam run", &chunkfile_name );
opts.addOpt< std::string >( "gsMAPfile,g", "gsmap file", &gsmapfile );
opts.addOpt< std::string >( "output,o", "output mesh filename", &outfile );
opts.parseCommandLine( argc, argv );
ErrorCode rval;
Core* mb = new Core();
rval = mb->load_file( inputfile.c_str() );MB_CHK_SET_ERR( rval, "can't load input file" );
std::cout << " opened " << inputfile << " with initial h5m data.\n";
// open the netcdf file, and see if it has that variable we are looking for
Range nodes;
rval = mb->get_entities_by_dimension( 0, 0, nodes );MB_CHK_SET_ERR( rval, "can't get nodes" );
Range edges;
rval = mb->get_entities_by_dimension( 0, 1, edges );MB_CHK_SET_ERR( rval, "can't get edges" );
Range cells;
rval = mb->get_entities_by_dimension( 0, 2, cells );MB_CHK_SET_ERR( rval, "can't get cells" );
std::cout << " it has " << nodes.size() << " vertices " << edges.size() << " edges " << cells.size() << " cells\n";
// construct maps between global id and handles
std::map< int, EntityHandle > vGidHandle;
std::map< int, EntityHandle > eGidHandle;
std::map< int, EntityHandle > cGidHandle;
std::vector< int > gids;
Tag gid;
rval = mb->tag_get_handle( "GLOBAL_ID", gid );MB_CHK_SET_ERR( rval, "can't get global id tag" );
gids.resize( nodes.size() );
rval = mb->tag_get_data( gid, nodes, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on vertices" );
int i = 0;
for( Range::iterator vit = nodes.begin(); vit != nodes.end(); vit++ )
vGidHandle[gids[i++]] = *vit;
gids.resize( edges.size() );
rval = mb->tag_get_data( gid, edges, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on edges" );
i = 0;
for( Range::iterator vit = edges.begin(); vit != edges.end(); vit++ )
eGidHandle[gids[i++]] = *vit;
gids.resize( cells.size() );
rval = mb->tag_get_data( gid, cells, &gids[0] );MB_CHK_SET_ERR( rval, "can't get global id on cells" );
i = 0;
for( Range::iterator vit = cells.begin(); vit != cells.end(); vit++ )
cGidHandle[gids[i++]] = *vit;
if( chunkfile_name.length() > 0 )
// Open chunk file
ifstream inFile;
inFile.open( chunkfile_name.c_str() );
if( !inFile )
cout << "Unable to open chunk file";
exit( 1 ); // terminate with error
Tag pTag, cTag;
int def_val = -1;
rval = mb->tag_get_handle( "ProcID", 1, MB_TYPE_INTEGER, pTag, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't define processor tag" );
rval = mb->tag_get_handle( "ChunkID", 1, MB_TYPE_INTEGER, cTag, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't define chunk tag" );
int proc, lcid, ncols;
while( inFile >> proc )
inFile >> lcid >> ncols;
int Gid;
for( i = 0; i < ncols; i++ )
inFile >> Gid;
EntityHandle cell = cGidHandle[Gid];
rval = mb->tag_set_data( pTag, &cell, 1, &proc );MB_CHK_SET_ERR( rval, "can't set proc tag" );
rval = mb->tag_set_data( cTag, &cell, 1, &lcid );MB_CHK_SET_ERR( rval, "can't set chunk tag" );
inFile.close();
if( gsmapfile.length() > 0 )
// Open chunk file
ifstream inFile;
inFile.open( gsmapfile.c_str() );
if( !inFile )
cout << "Unable to open gsmap file";
Tag pTag, cTag;
int def_val = -1;
std::string procTagName = gsmapfile + "_proc";
rval =
mb->tag_get_handle( procTagName.c_str(), 1, MB_TYPE_INTEGER, pTag, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't define processor tag" );
std::string segTagName = gsmapfile + "_seg";
rval =
mb->tag_get_handle( segTagName.c_str(), 1, MB_TYPE_INTEGER, cTag, MB_TAG_CREAT | MB_TAG_DENSE, &def_val );MB_CHK_SET_ERR( rval, "can't define segment tag" );
int compid, ngseg, gsize;
inFile >> compid >> ngseg >> gsize;
for( i = 1; i <= ngseg; i++ )
int start, len, pe;
inFile >> start >> len >> pe;
int Gid;
for( int j = 0; j < len; j++ )
Gid = start + j;
rval = mb->tag_set_data( pTag, &cell, 1, &pe );MB_CHK_SET_ERR( rval, "can't set proc tag" );
rval = mb->tag_set_data( cTag, &cell, 1, &i );MB_CHK_SET_ERR( rval, "can't set segment tag" );
inFile.close();
rval = mb->write_file( outfile.c_str() );MB_CHK_SET_ERR( rval, "can't write file" );
std::cout << " wrote file " << outfile << "\n";
return 0;
