MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/MergeMesh.hpp"#include <iostream>#include "TestUtil.hpp"
Include dependency graph for mergemesh_test.cpp:Go to the source code of this file.
Functions | |
| void | mergesimple_test () |
| void | merge_with_tag_test () |
| void | merge_all_test () |
| int | main () |
Variables | |
| std::string | meshfile = "unittest/16_unmerged_hex.h5m" |
| std::string | meshfile2 = "unittest/merge_with_tag.h5m" |
| std::string | meshfile3 = "unittest/triangles.h5m" |
| std::string | outfile = "mm_out.h5m" |
| int main | ( | ) |
Definition at line 29 of file mergemesh_test.cpp.
References merge_all_test(), merge_with_tag_test(), mergesimple_test(), and RUN_TEST.
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
#endif
int result = 0;
result += RUN_TEST( mergesimple_test );
result += RUN_TEST( merge_with_tag_test );
result += RUN_TEST( merge_all_test );
MPI_Finalize();
#endif
return result;
| void merge_all_test | ( | ) |
Definition at line 96 of file mergemesh_test.cpp.
References CHECK_ERR, ErrorCode, iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_all(), meshfile3, outfile, and moab::Interface::write_file().
Referenced by main().
ErrorCode rval;
Core mb;
Interface* iface = &mb;
rval = iface->load_mesh( meshfile3.c_str() );CHECK_ERR( rval );
MergeMesh mm( iface );
double merge_tol = 1e-3;
rval = mm.merge_all( 0, merge_tol ); // root set
CHECK_ERR( rval );
rval = iface->write_file( outfile.c_str() );CHECK_ERR( rval );
return;
| void merge_with_tag_test | ( | ) |
Definition at line 71 of file mergemesh_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), dim, ErrorCode, moab::Interface::get_entities_by_dimension(), iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_using_integer_tag(), meshfile2, outfile, moab::Range::size(), moab::Interface::tag_get_handle(), and moab::Interface::write_file().
ErrorCode rval;
Core mb;
// can be generalized to load user defined input/output file
rval = iface->load_mesh( meshfile2.c_str() );CHECK_ERR( rval );
int dim = 0;
moab::Range verts;
iface->get_entities_by_dimension( 0, dim, verts );
Tag tag_for_merge;
rval = iface->tag_get_handle( "IDFTAG", tag_for_merge );CHECK_ERR( rval );
rval = mm.merge_using_integer_tag( verts, tag_for_merge );CHECK_ERR( rval );
verts.clear();
CHECK_EQUAL( 405, (int)verts.size() );
return;
| void mergesimple_test | ( | ) |
Definition at line 47 of file mergemesh_test.cpp.
References CHECK_ERR, dim, ErrorCode, moab::Interface::get_entities_by_dimension(), iface, moab::Interface::load_mesh(), mb, moab::MergeMesh::merge_entities(), meshfile, outfile, and moab::Interface::write_file().
ErrorCode rval;
Core mb;
rval = iface->load_mesh( meshfile.c_str() );CHECK_ERR( rval );
int dim = 3;
moab::Range ents;
iface->get_entities_by_dimension( 0, dim, ents );
rval = mm.merge_entities( ents, merge_tol );CHECK_ERR( rval );
// Fixed for now
return;
| std::string meshfile = "unittest/16_unmerged_hex.h5m" |
Definition at line 17 of file mergemesh_test.cpp.
Referenced by mergesimple_test().
| std::string meshfile2 = "unittest/merge_with_tag.h5m" |
Definition at line 18 of file mergemesh_test.cpp.
Referenced by merge_with_tag_test().
| std::string meshfile3 = "unittest/triangles.h5m" |
Definition at line 19 of file mergemesh_test.cpp.
Referenced by merge_all_test().
| std::string outfile = "mm_out.h5m" |
Definition at line 20 of file mergemesh_test.cpp.
Referenced by iMOAB_LoadMesh(), main(), merge_all_test(), merge_with_tag_test(), mergesimple_test(), test_correct_ghost(), test_read_and_ghost_after(), test_read_with_ghost(), test_read_with_ghost_no_augment(), and test_read_with_thin_ghost_layer().
