read_obj_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "moab/Types.hpp"
#include "moab/GeomTopoTool.hpp"
+ Include dependency graph for read_obj_test.cpp:
Defines
#define CHKERR(A)
Functions
void read_file (Interface &moab, const char *input_file)
void test_check_num_entities ()
void test_check_meshsets ()
void test_check_groups ()
int main ()
Variables
std::string test = "unittest/io/test.obj"
std::string shuttle = "unittest/io/shuttle.obj"
GeomTopoTool * myGeomTool
Tag geom_tag
Tag name_tag
Tag id_tag
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 12 of file read_obj_test.cpp.
Function Documentation
int main ( )
Definition at line 36 of file read_obj_test.cpp.
References RUN_TEST, test_check_groups(), test_check_meshsets(), and test_check_num_entities().
    int result = 0;
    result += RUN_TEST( test_check_num_entities );
    result += RUN_TEST( test_check_meshsets );
    result += RUN_TEST( test_check_groups );
    return result;
void read_file ( Interface &  moab,
const char *  input_file
Definition at line 125 of file read_obj_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::globalId_tag(), id_tag, MBENTITYSET, read_file(), and shuttle.
Referenced by main().
    ErrorCode rval;
    Core core;
    Interface* mbi = &core;
    read_file( core, shuttle.c_str() );
    // check that number of tris created is 616
    //  170 tris + 223 quads split into 2 tris = 616
    Range tris;
    int tri_dim = 2;
    rval        = mbi->get_entities_by_dimension( 0, tri_dim, tris );CHECK_ERR( rval );
    CHECK_EQUAL( 616, (int)tris.size() );
    // check that 11 mesh sets are created
    // 1 for global vert set + 1 for each of 10 groups
    Range ent_sets, mesh_sets;
    id_tag = mbi->globalId_tag();
    rval   = mbi->get_entities_by_type_and_tag( 0, MBENTITYSET, &id_tag, NULL, 1, ent_sets );
    CHECK_EQUAL( 11, (int)ent_sets.size() );
Definition at line 72 of file read_obj_test.cpp.
References moab::Range::begin(), CHECK_EQUAL, CHECK_ERR, children, moab::Range::clear(), dim, moab::Range::end(), ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_child_meshsets(), moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_parent_meshsets(), MB_TYPE_INTEGER, MBENTITYSET, myGeomTool, read_file(), moab::Range::size(), moab::Interface::tag_get_data(), moab::Interface::tag_get_handle(), and test.
    ErrorCode rval;
    Core core;
    read_file( core, test.c_str() );
    myGeomTool = new GeomTopoTool( mbi );
    Range ent_sets;
    rval = mbi->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag );CHECK_ERR( rval );
    rval = mbi->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, NULL, 1, ent_sets );CHECK_ERR( rval );
    Range::iterator it;
    Range parents, children;
    int sense;
    int dim, num_surfs = 0, num_vols = 0;
    for( it = ent_sets.begin(); it != ent_sets.end(); ++it )
        rval = mbi->tag_get_data( geom_tag, &( *it ), 1, &dim );
        if( dim == 2 )
            num_surfs++;
            // check that one parent is created for each surface
            parents.clear();
            rval = mbi->get_parent_meshsets( *it, parents );CHECK_ERR( rval );
            CHECK_EQUAL( 1, (int)parents.size() );
            // check that sense of surface wrt parent is FORWARD = 1
            rval = myGeomTool->get_sense( *it, *parents.begin(), sense );CHECK_ERR( rval );
            CHECK_EQUAL( 1, sense );
        else if( dim == 3 )
            num_vols++;
            // check that one child is created for each volume
            children.clear();
            rval = mbi->get_child_meshsets( *it, children );CHECK_ERR( rval );
            CHECK_EQUAL( 1, (int)children.size() );
    // check that two surfaces and two volumes are created
    CHECK_EQUAL( 2, num_surfs );
    CHECK_EQUAL( 2, num_vols );
    delete myGeomTool;
Definition at line 52 of file read_obj_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, moab::Interface::get_entities_by_dimension(), read_file(), and test.
    ErrorCode rval;
    Core core;
    // check that number of verts created is 7
    Range verts;
    int vert_dim = 0;
    rval         = mbi->get_entities_by_dimension( 0, vert_dim, verts );CHECK_ERR( rval );
    CHECK_EQUAL( 7, (int)verts.size() );
    // check that number of tris created is 3
    Range tris;
    int tri_dim = 2;
    CHECK_EQUAL( 3, (int)tris.size() );
Variable Documentation
Definition at line 29 of file read_obj_test.cpp.
Definition at line 25 of file read_obj_test.cpp.
Referenced by test_check_meshsets().
Definition at line 23 of file read_obj_test.cpp.
Referenced by test_check_groups().
