MOAB: Mesh Oriented datABase
(version 5.4.1)
Defines | |
| #define | MATERIAL_SET_TAG_NAME "MATERIAL_SET" |
| Conventional tag names used for some often-used sets. | |
| #define | DIRICHLET_SET_TAG_NAME "DIRICHLET_SET" |
| #define | NEUMANN_SET_TAG_NAME "NEUMANN_SET" |
| #define | HAS_MID_NODES_TAG_NAME "HAS_MID_NODES" |
| #define | GEOM_DIMENSION_TAG_NAME "GEOM_DIMENSION" |
| #define | MESH_TRANSFORM_TAG_NAME "MESH_TRANSFORM" |
| #define | GLOBAL_ID_TAG_NAME "GLOBAL_ID" |
| #define | CATEGORY_TAG_NAME "CATEGORY" |
| #define | CATEGORY_TAG_SIZE 32 |
| #define | NAME_TAG_NAME "NAME" |
| #define | NAME_TAG_SIZE 32 |
| #define | BLOCK_HEADER "BLOCK_HEADER" |
| #define | BLOCK_ATTRIBUTES "BLOCK_ATTRIBUTES" |
| #define BLOCK_ATTRIBUTES "BLOCK_ATTRIBUTES" |
Definition at line 121 of file MBTagConventions.hpp.
Referenced by moab::Tqdcfr::read_block().
| #define BLOCK_HEADER "BLOCK_HEADER" |
Definition at line 115 of file MBTagConventions.hpp.
Referenced by moab::Tqdcfr::BlockHeader::read_info_header().
| #define CATEGORY_TAG_NAME "CATEGORY" |
Definition at line 99 of file MBTagConventions.hpp.
Referenced by moab::DualTool::DualTool(), get_all_handles(), main(), read_cylcube_groups_test(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::ReadCGM::ReadCGM(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), and moab::GeomTopoTool::setup_implicit_complement().
| #define CATEGORY_TAG_SIZE 32 |
Definition at line 100 of file MBTagConventions.hpp.
Referenced by build_new_surface(), moab::DualTool::construct_new_hyperplane(), moab::ReadCGM::create_entity_sets(), moab::ReadRTT::create_group(), moab::ReadCGM::create_group_entsets(), moab::DualTool::DualTool(), moab::ReadRTT::generate_topology(), get_all_handles(), main(), read_cylcube_groups_test(), moab::Tqdcfr::GeomHeader::read_info_header(), moab::Tqdcfr::GroupHeader::read_info_header(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::Tqdcfr::NodesetHeader::read_info_header(), moab::Tqdcfr::SidesetHeader::read_info_header(), moab::ReadCGM::ReadCGM(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::GeomTopoTool::setup_implicit_complement(), and summarize_cell_volume_change().
| #define DIRICHLET_SET_TAG_NAME "DIRICHLET_SET" |
Definition at line 39 of file MBTagConventions.hpp.
Referenced by moab::ParallelComm::augment_default_sets_with_ghosts(), moab::Tqdcfr::convert_nodesets_sidesets(), create_input_file(), moab::Core::dirichletBC_tag(), iMOAB_Initialize(), main(), mb_write_mesh_test(), moab::WriteHDF5Parallel::print_shared_sets(), moab::print_type_sets(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::read_nodeset(), moab::ReadNCDF::read_tag_values(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadNCDF::ReadNCDF(), report_sets(), moab::ParallelComm::resolve_shared_sets(), test_node_sets(), test_read_bc_sets(), test_read_nodeset_ids(), moab::Tqdcfr::Tqdcfr(), moab::NestedRefine::update_special_tags(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteGMV::WriteGMV(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
| #define GEOM_DIMENSION_TAG_NAME "GEOM_DIMENSION" |
Definition at line 70 of file MBTagConventions.hpp.
Referenced by moab::GeomTopoTool::add_geo_set(), moab::GeomTopoTool::check_geom_tag(), moab::ReadGmsh::create_sets(), moab::GeomTopoTool::dimension(), do_file(), moab::GeomTopoTool::duplicate_model(), FBiGeom_getEntSets(), FBiGeom_getNumEntSets(), moab::Skinner::find_geometric_skin(), moab::GeomTopoTool::find_geomsets(), moab::FBEngine::find_vertex_set_for_node(), moab::Core::geom_dimension_tag(), moab::GeomTopoTool::GeomTopoTool(), get_all_handles(), get_expected_ghosts(), moab::FBEngine::getNumOfType(), moab::FBEngine::initializeSmoothing(), moab::ReadSms::load_file_impl(), main(), mb_write_mesh_test(), overlap_write_geometry(), print_partitioned_entities(), moab::WriteHDF5Parallel::print_shared_sets(), moab::print_type_sets(), quads_to_tris(), read_cube_curves_test(), read_cube_surfs_test(), read_cube_vols_test(), read_cylcube_curve_senses_test(), read_cylcube_surf_senses_test(), moab::ReadTetGen::read_elem_file(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::ReadCGM::ReadCGM(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::ParallelComm::resolve_shared_sets(), test_check_meshsets(), test_elements_on_several_procs(), test_ghost_elements(), test_meshset_tags_1(), test_meshset_tags_2(), test_read_geom_set(), test_read_partial_ids(), test_root_sets_resize(), moab::TreeNodePrinter::TreeNodePrinter(), moab::WriteGmsh::write_file(), write_geometry(), and write_id_test_file().
| #define GLOBAL_ID_TAG_NAME "GLOBAL_ID" |
Definition at line 89 of file MBTagConventions.hpp.
Referenced by moab::GeomTopoTool::check_gid_tag(), compare(), moab::NestedRefine::create_hm_storage_single_level(), moab::NestedRefine::exchange_ghosts(), moab::NestedRefine::generate_hm(), moab::Core::globalId_tag(), iMOAB_Initialize(), moab::RefinerTagManager::RefinerTagManager(), moab::ParallelComm::resolve_shared_ents(), test_read_partial_ids(), and test_write_unbalanced().
| #define HAS_MID_NODES_TAG_NAME "HAS_MID_NODES" |
Definition at line 61 of file MBTagConventions.hpp.
Referenced by find_block(), moab::Tqdcfr::BlockHeader::read_info_header(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadNCDF::ReadNCDF(), test_ho_elements(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteGMV::WriteGMV(), and moab::WriteNCDF::WriteNCDF().
| #define MATERIAL_SET_TAG_NAME "MATERIAL_SET" |
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
Definition at line 29 of file MBTagConventions.hpp.
Referenced by moab::ParallelComm::augment_default_sets_with_ghosts(), create_input_file(), moab::ReadNASTRAN::create_materials(), moab::ReadGmsh::create_sets(), moab::FBEngine::create_volume_with_direction(), find_block(), DeformMeshRemap::find_other_sets(), iMOAB_Initialize(), moab::ReadCGNS::load_file(), moab::ReadGmsh::load_file(), moab::ReadNCDF::load_file(), moab::Core::load_mesh(), main(), moab::Core::material_tag(), mb_write_mesh_test(), moab::WriteHDF5Parallel::print_shared_sets(), moab::print_type_sets(), DeformMeshRemap::read_file(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::ReadNCDF::read_tag_values(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadNCDF::ReadNCDF(), report_sets(), resolve_and_exchange(), moab::ParallelComm::resolve_shared_sets(), test_blocks(), test_ho_elements(), test_read_bc_sets(), test_read_block_ids(), test_read_material_on_nodes(), test_read_material_set(), test_read_material_set1(), test_read_material_set2(), test_write_shared_sets(), moab::Tqdcfr::Tqdcfr(), moab::NestedRefine::update_special_tags(), moab::WriteGmsh::write_file(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteGMV::WriteGMV(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
| #define MESH_TRANSFORM_TAG_NAME "MESH_TRANSFORM" |
Definition at line 79 of file MBTagConventions.hpp.
Referenced by moab::WriteCCMIO::transform_coords(), moab::WriteTemplate::write_nodes(), moab::WriteSLAC::write_nodes(), and moab::WriteNCDF::write_nodes().
| #define NAME_TAG_NAME "NAME" |
Definition at line 108 of file MBTagConventions.hpp.
Referenced by moab::ReadCGM::create_group_entsets(), moab::GeomTopoTool::GeomTopoTool(), get_all_handles(), moab::Tqdcfr::get_names(), moab::ReadCCMIO::load_neuset_data(), main(), smoab::Interface::name(), moab::Tqdcfr::parse_acis_attribs(), read_cylcube_groups_test(), moab::Tqdcfr::read_group(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::Tqdcfr::Tqdcfr(), and moab::WriteCCMIO::WriteCCMIO().
| #define NAME_TAG_SIZE 32 |
Definition at line 109 of file MBTagConventions.hpp.
Referenced by moab::ReadCGM::create_group_entsets(), dot_nodes(), moab::WriteCCMIO::gather_matset_info(), moab::WriteCCMIO::gather_neuset_info(), moab::GeomTopoTool::GeomTopoTool(), get_all_handles(), get_group_names(), moab::Tqdcfr::get_names(), moab::ReadCCMIO::get_str_option(), moab::ReadCCMIO::load_matset_data(), main(), smoab::Interface::name(), moab::Tqdcfr::parse_acis_attribs(), moab::Core::print_entity_tags(), read_cylcube_groups_test(), moab::Tqdcfr::read_group(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadCGM::ReadCGM(), moab::ReadOBJ::ReadOBJ(), moab::ReadRTT::ReadRTT(), moab::Tqdcfr::Tqdcfr(), moab::WriteCCMIO::write_problem_description(), and moab::WriteCCMIO::WriteCCMIO().
| #define NEUMANN_SET_TAG_NAME "NEUMANN_SET" |
Definition at line 50 of file MBTagConventions.hpp.
Referenced by moab::ParallelComm::augment_default_sets_with_ghosts(), moab::Tqdcfr::convert_nodesets_sidesets(), create_input_file(), find_sideset(), iMOAB_Initialize(), main(), mb_write_mesh_test(), moab::Core::neumannBC_tag(), moab::WriteHDF5Parallel::print_shared_sets(), moab::print_type_sets(), moab::Tqdcfr::ModelEntry::read_header_info(), moab::Tqdcfr::read_sideset(), moab::ReadNCDF::read_tag_values(), moab::ReadABAQUS::ReadABAQUS(), moab::ReadCCMIO::ReadCCMIO(), moab::ReadNCDF::ReadNCDF(), report_sets(), moab::ParallelComm::resolve_shared_sets(), moab::FBEngine::set_default_neumann_tags(), moab::FBEngine::set_neumann_tags(), test_read_bc_sets(), test_read_sideset_ids(), test_side_sets(), moab::Tqdcfr::Tqdcfr(), moab::NestedRefine::update_special_tags(), moab::WriteAns::WriteAns(), moab::WriteCCMIO::WriteCCMIO(), moab::WriteGMV::WriteGMV(), moab::WriteNCDF::WriteNCDF(), moab::WriteSLAC::WriteSLAC(), and moab::WriteTemplate::WriteTemplate().
