MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "MBTagConventions.hpp" 00004 #define IS_BUILDING_MB 00005 #include "moab/Range.hpp" 00006 #include <cmath> 00007 #include <algorithm> 00008 00009 using namespace moab; 00010 00011 #ifdef MESHDIR 00012 static const char example[] = STRINGIFY( MESHDIR ) "/io/test.nas"; 00013 #else 00014 static const char example[] = "test.nas"; 00015 #endif 00016 00017 void read_file( Interface& moab, const char* input_file ); 00018 void test_read_nodes(); 00019 void test_read_tets(); 00020 void test_read_prisms(); 00021 void test_read_hexes(); 00022 void test_read_material_set1(); 00023 void test_read_material_set2(); 00024 00025 int main() 00026 { 00027 int result = 0; 00028 00029 result += RUN_TEST( test_read_nodes ); 00030 result += RUN_TEST( test_read_tets ); 00031 result += RUN_TEST( test_read_prisms ); 00032 result += RUN_TEST( test_read_hexes ); 00033 result += RUN_TEST( test_read_material_set1 ); 00034 result += RUN_TEST( test_read_material_set2 ); 00035 00036 return result; 00037 } 00038 00039 void read_file( Interface& moab, const char* input_file ) 00040 { 00041 ErrorCode rval = moab.load_file( input_file );CHECK_ERR( rval ); 00042 } 00043 00044 void test_read_nodes() 00045 { 00046 const double eps = 1e-100; 00047 ErrorCode rval; 00048 Core moab; 00049 Interface& mb = moab; 00050 read_file( moab, example ); 00051 00052 std::vector< EntityHandle > nodes; 00053 rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );CHECK_ERR( rval ); 00054 CHECK_EQUAL( (size_t)19, nodes.size() ); 00055 00056 Tag id_tag = mb.globalId_tag(); 00057 00058 std::vector< int > ids( nodes.size() ); 00059 rval = mb.tag_get_data( id_tag, &nodes[0], nodes.size(), &ids[0] );CHECK_ERR( rval ); 00060 00061 std::vector< int > sorted_ids( ids ); 00062 std::sort( sorted_ids.begin(), sorted_ids.end() ); 00063 00064 std::vector< double > coords( 3 * nodes.size() ); 00065 rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );CHECK_ERR( rval ); 00066 00067 int idx, pos = 0; 00068 // shared between 2 tets and 2 prisms 00069 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00070 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00071 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00072 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00073 CHECK_REAL_EQUAL( coords[3 * idx + 2], -2.0, eps ); 00074 00075 ++pos; 00076 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00077 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00078 CHECK_REAL_EQUAL( coords[3 * idx + 0], -1.0, eps ); 00079 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00080 CHECK_REAL_EQUAL( coords[3 * idx + 2], -1.0, eps ); 00081 00082 ++pos; 00083 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00084 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00085 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00086 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00087 CHECK_REAL_EQUAL( coords[3 * idx + 2], -1.0, eps ); 00088 00089 ++pos; 00090 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00091 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00092 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00093 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00094 CHECK_REAL_EQUAL( coords[3 * idx + 2], -1.0, eps ); 00095 00096 ++pos; 00097 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00098 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00099 CHECK_REAL_EQUAL( coords[3 * idx + 0], -1.0, eps ); 00100 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00101 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00102 00103 ++pos; 00104 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00105 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00106 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00107 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00108 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00109 00110 ++pos; 00111 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00112 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00113 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00114 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00115 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00116 00117 ++pos; 00118 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00119 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00120 CHECK_REAL_EQUAL( coords[3 * idx + 0], -1.0, eps ); 00121 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00122 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00123 00124 ++pos; 00125 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00126 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00127 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00128 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00129 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00130 00131 ++pos; 00132 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00133 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00134 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00135 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00136 CHECK_REAL_EQUAL( coords[3 * idx + 2], 1.0, eps ); 00137 00138 ++pos; 00139 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00140 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00141 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00142 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00143 CHECK_REAL_EQUAL( coords[3 * idx + 2], 2.0, eps ); 00144 // hex element 00145 ++pos; 00146 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00147 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00148 CHECK_REAL_EQUAL( coords[3 * idx + 0], 5.0, eps ); 00149 CHECK_REAL_EQUAL( coords[3 * idx + 1], 5.0, eps ); 00150 CHECK_REAL_EQUAL( coords[3 * idx + 2], 5.0, eps ); 00151 00152 ++pos; 00153 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00154 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00155 CHECK_REAL_EQUAL( coords[3 * idx + 0], 10.0, eps ); 00156 CHECK_REAL_EQUAL( coords[3 * idx + 1], 5.0, eps ); 00157 CHECK_REAL_EQUAL( coords[3 * idx + 2], 5.0, eps ); 00158 00159 ++pos; 00160 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00161 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00162 CHECK_REAL_EQUAL( coords[3 * idx + 0], 10.0, eps ); 00163 CHECK_REAL_EQUAL( coords[3 * idx + 1], 10.0, eps ); 00164 CHECK_REAL_EQUAL( coords[3 * idx + 2], 5.0, eps ); 00165 00166 ++pos; 00167 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00168 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00169 CHECK_REAL_EQUAL( coords[3 * idx + 0], 5.0, eps ); 00170 CHECK_REAL_EQUAL( coords[3 * idx + 1], 10.0, eps ); 00171 CHECK_REAL_EQUAL( coords[3 * idx + 2], 5.0, eps ); 00172 00173 ++pos; 00174 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00175 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00176 CHECK_REAL_EQUAL( coords[3 * idx + 0], 5.0, eps ); 00177 CHECK_REAL_EQUAL( coords[3 * idx + 1], 5.0, eps ); 00178 CHECK_REAL_EQUAL( coords[3 * idx + 2], 10.0, eps ); 00179 00180 ++pos; 00181 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00182 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00183 CHECK_REAL_EQUAL( coords[3 * idx + 0], 10.0, eps ); 00184 CHECK_REAL_EQUAL( coords[3 * idx + 1], 5.0, eps ); 00185 CHECK_REAL_EQUAL( coords[3 * idx + 2], 10.0, eps ); 00186 00187 ++pos; 00188 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00189 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00190 CHECK_REAL_EQUAL( coords[3 * idx + 0], 10.0, eps ); 00191 CHECK_REAL_EQUAL( coords[3 * idx + 1], 10.0, eps ); 00192 CHECK_REAL_EQUAL( coords[3 * idx + 2], 10.0, eps ); 00193 00194 ++pos; 00195 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00196 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00197 CHECK_REAL_EQUAL( coords[3 * idx + 0], 5.0, eps ); 00198 CHECK_REAL_EQUAL( coords[3 * idx + 1], 10.0, eps ); 00199 CHECK_REAL_EQUAL( coords[3 * idx + 2], 10.0, eps ); 00200 } 00201 00202 void test_read_tets() 00203 { 00204 ErrorCode rval; 00205 Core moab; 00206 Interface& mb = moab; 00207 read_file( moab, example ); 00208 00209 std::vector< EntityHandle > tets; 00210 rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval ); 00211 CHECK_EQUAL( (size_t)2, tets.size() ); 00212 00213 Tag id_tag = mb.globalId_tag(); 00214 00215 std::vector< int > ids( tets.size() ); 00216 rval = mb.tag_get_data( id_tag, &tets[0], tets.size(), &ids[0] );CHECK_ERR( rval ); 00217 00218 if( ids[0] != 1 ) 00219 { 00220 std::swap( ids[0], ids[1] ); 00221 std::swap( tets[0], tets[1] ); 00222 } 00223 00224 int vtx_ids[4]; 00225 const EntityHandle* conn; 00226 int len; 00227 00228 const int conn1[] = { 8, 9, 10, 11 }; 00229 int pos = 0; 00230 CHECK_EQUAL( pos + 1, ids[pos] ); 00231 rval = mb.get_connectivity( tets[pos], conn, len );CHECK_ERR( rval ); 00232 CHECK_EQUAL( 4, len ); 00233 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00234 CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len ); 00235 00236 const int conn2[] = { 4, 3, 2, 1 }; 00237 ++pos; 00238 CHECK_EQUAL( pos + 1, ids[pos] ); 00239 rval = mb.get_connectivity( tets[pos], conn, len );CHECK_ERR( rval ); 00240 CHECK_EQUAL( 4, len ); 00241 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00242 CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len ); 00243 } 00244 00245 void test_read_prisms() 00246 { 00247 ErrorCode rval; 00248 Core moab; 00249 Interface& mb = moab; 00250 read_file( moab, example ); 00251 00252 std::vector< EntityHandle > prisms; 00253 rval = mb.get_entities_by_type( 0, MBPRISM, prisms );CHECK_ERR( rval ); 00254 CHECK_EQUAL( (size_t)2, prisms.size() ); 00255 00256 Tag id_tag = mb.globalId_tag(); 00257 00258 std::vector< int > ids( prisms.size() ); 00259 rval = mb.tag_get_data( id_tag, &prisms[0], prisms.size(), &ids[0] );CHECK_ERR( rval ); 00260 00261 if( ids[0] != 3 ) 00262 { 00263 std::swap( ids[0], ids[1] ); 00264 std::swap( prisms[0], prisms[1] ); 00265 } 00266 00267 int vtx_ids[6]; 00268 const EntityHandle* conn; 00269 int len; 00270 00271 const int conn1[] = { 2, 3, 4, 5, 6, 7 }; 00272 int pos = 0; 00273 // Element ids 1 and 2 are the two tet elements. 00274 // Element ids 3 and 4 are the two prism elements. 00275 CHECK_EQUAL( pos + 3, ids[pos] ); 00276 rval = mb.get_connectivity( prisms[pos], conn, len );CHECK_ERR( rval ); 00277 CHECK_EQUAL( 6, len ); 00278 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00279 CHECK_ARRAYS_EQUAL( conn1, 6, vtx_ids, len ); 00280 00281 const int conn2[] = { 5, 6, 7, 8, 9, 10 }; 00282 ++pos; 00283 CHECK_EQUAL( pos + 3, ids[pos] ); 00284 rval = mb.get_connectivity( prisms[pos], conn, len );CHECK_ERR( rval ); 00285 CHECK_EQUAL( 6, len ); 00286 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00287 CHECK_ARRAYS_EQUAL( conn2, 6, vtx_ids, len ); 00288 } 00289 00290 void test_read_hexes() 00291 { 00292 ErrorCode rval; 00293 Core moab; 00294 Interface& mb = moab; 00295 read_file( moab, example ); 00296 00297 std::vector< EntityHandle > hexes; 00298 rval = mb.get_entities_by_type( 0, MBHEX, hexes );CHECK_ERR( rval ); 00299 CHECK_EQUAL( (size_t)1, hexes.size() ); 00300 00301 Tag id_tag = mb.globalId_tag(); 00302 00303 std::vector< int > ids( hexes.size() ); 00304 rval = mb.tag_get_data( id_tag, &hexes[0], hexes.size(), &ids[0] );CHECK_ERR( rval ); 00305 00306 int vtx_ids[8]; 00307 const EntityHandle* conn; 00308 int len; 00309 00310 const int conn1[] = { 12, 13, 14, 15, 16, 17, 18, 19 }; 00311 int pos = 0; 00312 // Element id 5 is the hex 00313 CHECK_EQUAL( pos + 5, ids[pos] ); 00314 rval = mb.get_connectivity( hexes[pos], conn, len );CHECK_ERR( rval ); 00315 CHECK_EQUAL( 8, len ); 00316 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00317 CHECK_ARRAYS_EQUAL( conn1, 8, vtx_ids, len ); 00318 } 00319 00320 // The tets are in material set 1. 00321 void test_read_material_set1() 00322 { 00323 ErrorCode rval; 00324 Core moab; 00325 Interface& mb = moab; 00326 read_file( moab, example ); 00327 00328 Tag mat_tag; 00329 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00330 00331 Range mat_set_one; 00332 const int one = 1; 00333 const void* const one_val[] = { &one }; 00334 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, one_val, 1, mat_set_one );CHECK_ERR( rval ); 00335 CHECK_EQUAL( 1, (int)mat_set_one.size() ); 00336 00337 std::vector< EntityHandle > tets, contents; 00338 rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval ); 00339 rval = mb.get_entities_by_handle( mat_set_one.front(), contents );CHECK_ERR( rval ); 00340 std::sort( tets.begin(), tets.end() ); 00341 std::sort( contents.begin(), contents.end() ); 00342 CHECK_EQUAL( tets, contents ); 00343 } 00344 00345 // The prisms are in material set 2. 00346 void test_read_material_set2() 00347 { 00348 ErrorCode rval; 00349 Core moab; 00350 Interface& mb = moab; 00351 read_file( moab, example ); 00352 00353 Tag mat_tag; 00354 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00355 00356 Range mat_set_two; 00357 const int two = 2; 00358 const void* const two_val[] = { &two }; 00359 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, two_val, 1, mat_set_two );CHECK_ERR( rval ); 00360 CHECK_EQUAL( 1, (int)mat_set_two.size() ); 00361 00362 std::vector< EntityHandle > prisms, contents; 00363 rval = mb.get_entities_by_type( 0, MBPRISM, prisms );CHECK_ERR( rval ); 00364 rval = mb.get_entities_by_handle( mat_set_two.front(), contents );CHECK_ERR( rval ); 00365 std::sort( prisms.begin(), prisms.end() ); 00366 std::sort( contents.begin(), contents.end() ); 00367 CHECK_EQUAL( prisms, contents ); 00368 }
