MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "TestUtil.hpp"#include "moab/Core.hpp"#include "MBTagConventions.hpp"#include "moab/Range.hpp"#include <cmath>#include <algorithm>
Include dependency graph for nastran_test.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
Functions | |
| void | read_file (Interface &moab, const char *input_file) |
| void | test_read_nodes () |
| void | test_read_tets () |
| void | test_read_prisms () |
| void | test_read_hexes () |
| void | test_read_material_set1 () |
| void | test_read_material_set2 () |
| int | main () |
Variables | |
| static const char | example [] = "test.nas" |
| #define IS_BUILDING_MB |
Definition at line 4 of file nastran_test.cpp.
| int main | ( | ) |
Definition at line 25 of file nastran_test.cpp.
References RUN_TEST, test_read_hexes(), test_read_material_set1(), test_read_material_set2(), test_read_nodes(), test_read_prisms(), and test_read_tets().
int result = 0;
result += RUN_TEST( test_read_nodes );
result += RUN_TEST( test_read_tets );
result += RUN_TEST( test_read_prisms );
result += RUN_TEST( test_read_hexes );
result += RUN_TEST( test_read_material_set1 );
result += RUN_TEST( test_read_material_set2 );
return result;
| void test_read_hexes | ( | ) |
| void test_read_material_set1 | ( | ) |
Definition at line 321 of file nastran_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, MBTET, read_file(), moab::Range::size(), and moab::Interface::tag_get_handle().
Referenced by main().
ErrorCode rval;
Core moab;
Interface& mb = moab;
read_file( moab, example );
Tag mat_tag;
rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval );
Range mat_set_one;
const int one = 1;
const void* const one_val[] = { &one };
rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, one_val, 1, mat_set_one );CHECK_ERR( rval );
CHECK_EQUAL( 1, (int)mat_set_one.size() );
std::vector< EntityHandle > tets, contents;
rval = mb.get_entities_by_type( 0, MBTET, tets );CHECK_ERR( rval );
rval = mb.get_entities_by_handle( mat_set_one.front(), contents );CHECK_ERR( rval );
std::sort( tets.begin(), tets.end() );
std::sort( contents.begin(), contents.end() );
CHECK_EQUAL( tets, contents );
| void test_read_material_set2 | ( | ) |
Definition at line 346 of file nastran_test.cpp.
References CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::Range::front(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::Interface::get_entities_by_type_and_tag(), MATERIAL_SET_TAG_NAME, MB_TYPE_INTEGER, MBENTITYSET, MBPRISM, read_file(), moab::Range::size(), and moab::Interface::tag_get_handle().
ErrorCode rval;
Core moab;
Tag mat_tag;
Range mat_set_two;
const int two = 2;
const void* const two_val[] = { &two };
rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, two_val, 1, mat_set_two );CHECK_ERR( rval );
CHECK_EQUAL( 1, (int)mat_set_two.size() );
std::vector< EntityHandle > prisms, contents;
rval = mb.get_entities_by_type( 0, MBPRISM, prisms );CHECK_ERR( rval );
rval = mb.get_entities_by_handle( mat_set_two.front(), contents );CHECK_ERR( rval );
std::sort( prisms.begin(), prisms.end() );
CHECK_EQUAL( prisms, contents );
| void test_read_nodes | ( | ) |
| void test_read_prisms | ( | ) |
Definition at line 245 of file nastran_test.cpp.
References CHECK_ARRAYS_EQUAL, CHECK_EQUAL, CHECK_ERR, ErrorCode, example, moab::Interface::get_connectivity(), moab::Interface::get_entities_by_type(), moab::Interface::globalId_tag(), MBPRISM, read_file(), swap(), and moab::Interface::tag_get_data().
ErrorCode rval;
Core moab;
std::vector< EntityHandle > prisms;
CHECK_EQUAL( (size_t)2, prisms.size() );
Tag id_tag = mb.globalId_tag();
std::vector< int > ids( prisms.size() );
rval = mb.tag_get_data( id_tag, &prisms[0], prisms.size(), &ids[0] );CHECK_ERR( rval );
if( ids[0] != 3 )
std::swap( ids[0], ids[1] );
std::swap( prisms[0], prisms[1] );
int vtx_ids[6];
const EntityHandle* conn;
int len;
const int conn1[] = { 2, 3, 4, 5, 6, 7 };
int pos = 0;
// Element ids 1 and 2 are the two tet elements.
// Element ids 3 and 4 are the two prism elements.
CHECK_EQUAL( pos + 3, ids[pos] );
rval = mb.get_connectivity( prisms[pos], conn, len );CHECK_ERR( rval );
CHECK_EQUAL( 6, len );
rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval );
CHECK_ARRAYS_EQUAL( conn1, 6, vtx_ids, len );
const int conn2[] = { 5, 6, 7, 8, 9, 10 };
++pos;
CHECK_ARRAYS_EQUAL( conn2, 6, vtx_ids, len );
| void test_read_tets | ( | ) |
const char example[] = "test.nas" [static] |
Definition at line 14 of file nastran_test.cpp.
