MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "TestUtil.hpp" 00002 #include "moab/Core.hpp" 00003 #include "moab/Range.hpp" 00004 #include "MBTagConventions.hpp" 00005 #include <cmath> 00006 #include <algorithm> 00007 00008 using namespace moab; 00009 00010 /* Input test file: gmsh2.msh 00011 * 00012 * Example version 2.0 ASCII input file from Gmsh 2.4 manual. 00013 */ 00014 #ifdef MESHDIR 00015 static const char example[] = STRINGIFY( MESHDIR ) "/io/gmsh2.msh"; 00016 static const char example2[] = STRINGIFY( MESHDIR ) "/io/airfoil_exterior.msh"; 00017 static const char example3[] = STRINGIFY( MESHDIR ) "/io/t1.msh"; 00018 static const char example4[] = STRINGIFY( MESHDIR ) "/io/ghosts.msh"; 00019 static const char example5[] = STRINGIFY( MESHDIR ) "/io/gmsh3.msh"; 00020 #else 00021 static const char example[] = "gmsh2.msh"; 00022 static const char example2[] = "airfoil_exterior.msh"; 00023 static const char example3[] = "t1.msh"; 00024 static const char example4[] = "ghosts.msh"; 00025 static const char example5[] = "gmsh3.msh"; 00026 #endif 00027 00028 void test_read_nodes(); 00029 void test_read_quads(); 00030 void test_read_material_set(); 00031 void test_read_material_on_nodes(); 00032 void test_read_geom_set(); 00033 void test_read_airfoil(); 00034 void test_read_t1(); 00035 void test_read_fgh(); // file with ghosts id for partition 00036 00037 void read_file( Interface& moab, const char* input_file ); 00038 00039 int main() 00040 { 00041 int result = 0; 00042 00043 result += RUN_TEST( test_read_nodes ); 00044 result += RUN_TEST( test_read_quads ); 00045 result += RUN_TEST( test_read_material_set ); 00046 result += RUN_TEST( test_read_material_on_nodes ); 00047 result += RUN_TEST( test_read_geom_set ); 00048 00049 result += RUN_TEST( test_read_airfoil ); 00050 result += RUN_TEST( test_read_t1 ); 00051 result += RUN_TEST( test_read_fgh ); 00052 return result; 00053 } 00054 00055 void read_file( Interface& moab, const char* input_file ) 00056 { 00057 ErrorCode rval; 00058 rval = moab.load_file( input_file );CHECK_ERR( rval ); 00059 } 00060 00061 void test_read_nodes() 00062 { 00063 const double eps = 1e-100; 00064 ErrorCode rval; 00065 Core moab; 00066 Interface& mb = moab; 00067 read_file( moab, example ); 00068 00069 std::vector< EntityHandle > nodes; 00070 rval = mb.get_entities_by_type( 0, MBVERTEX, nodes );CHECK_ERR( rval ); 00071 CHECK_EQUAL( (size_t)6, nodes.size() ); 00072 00073 Tag id_tag = mb.globalId_tag(); 00074 00075 std::vector< int > ids( nodes.size() ); 00076 rval = mb.tag_get_data( id_tag, &nodes[0], nodes.size(), &ids[0] );CHECK_ERR( rval ); 00077 00078 std::vector< int > sorted_ids( ids ); 00079 std::sort( sorted_ids.begin(), sorted_ids.end() ); 00080 00081 std::vector< double > coords( 3 * nodes.size() ); 00082 rval = mb.get_coords( &nodes[0], nodes.size(), &coords[0] );CHECK_ERR( rval ); 00083 00084 int idx, pos = 0; 00085 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00086 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00087 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00088 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00089 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00090 00091 ++pos; 00092 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00093 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00094 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00095 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00096 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00097 00098 ++pos; 00099 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00100 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00101 CHECK_REAL_EQUAL( coords[3 * idx + 0], 1.0, eps ); 00102 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00103 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00104 00105 ++pos; 00106 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00107 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00108 CHECK_REAL_EQUAL( coords[3 * idx + 0], 0.0, eps ); 00109 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00110 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00111 00112 ++pos; 00113 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00114 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00115 CHECK_REAL_EQUAL( coords[3 * idx + 0], 2.0, eps ); 00116 CHECK_REAL_EQUAL( coords[3 * idx + 1], 0.0, eps ); 00117 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00118 00119 ++pos; 00120 CHECK_EQUAL( pos + 1, sorted_ids[pos] ); 00121 idx = std::find( ids.begin(), ids.end(), pos + 1 ) - ids.begin(); 00122 CHECK_REAL_EQUAL( coords[3 * idx + 0], 2.0, eps ); 00123 CHECK_REAL_EQUAL( coords[3 * idx + 1], 1.0, eps ); 00124 CHECK_REAL_EQUAL( coords[3 * idx + 2], 0.0, eps ); 00125 } 00126 00127 void test_read_quads() 00128 { 00129 ErrorCode rval; 00130 Core moab; 00131 Interface& mb = moab; 00132 read_file( moab, example ); 00133 00134 std::vector< EntityHandle > quads; 00135 rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval ); 00136 CHECK_EQUAL( (size_t)2, quads.size() ); 00137 00138 Tag id_tag = mb.globalId_tag(); 00139 00140 std::vector< int > ids( quads.size() ); 00141 rval = mb.tag_get_data( id_tag, &quads[0], quads.size(), &ids[0] );CHECK_ERR( rval ); 00142 00143 if( ids[0] != 1 ) 00144 { 00145 std::swap( ids[0], ids[1] ); 00146 std::swap( quads[0], quads[1] ); 00147 } 00148 00149 int vtx_ids[4]; 00150 const EntityHandle* conn; 00151 int len; 00152 00153 const int conn1[] = { 1, 2, 3, 4 }; 00154 int pos = 0; 00155 CHECK_EQUAL( pos + 1, ids[pos] ); 00156 rval = mb.get_connectivity( quads[pos], conn, len );CHECK_ERR( rval ); 00157 CHECK_EQUAL( 4, len ); 00158 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00159 CHECK_ARRAYS_EQUAL( conn1, 4, vtx_ids, len ); 00160 00161 const int conn2[] = { 2, 5, 6, 3 }; 00162 ++pos; 00163 CHECK_EQUAL( pos + 1, ids[pos] ); 00164 rval = mb.get_connectivity( quads[pos], conn, len );CHECK_ERR( rval ); 00165 CHECK_EQUAL( 4, len ); 00166 rval = mb.tag_get_data( id_tag, conn, len, vtx_ids );CHECK_ERR( rval ); 00167 CHECK_ARRAYS_EQUAL( conn2, 4, vtx_ids, len ); 00168 } 00169 00170 void test_read_material_set() 00171 { 00172 ErrorCode rval; 00173 Core moab; 00174 Interface& mb = moab; 00175 read_file( moab, example ); 00176 00177 Tag mat_tag; 00178 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00179 00180 Range sets; 00181 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, 0, 1, sets );CHECK_ERR( rval ); 00182 CHECK_EQUAL( 1, (int)sets.size() ); 00183 EntityHandle set = sets.front(); 00184 00185 int id; 00186 rval = mb.tag_get_data( mat_tag, &set, 1, &id );CHECK_ERR( rval ); 00187 CHECK_EQUAL( 99, id ); 00188 00189 std::vector< EntityHandle > quads, contents; 00190 rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval ); 00191 rval = mb.get_entities_by_handle( set, contents );CHECK_ERR( rval ); 00192 std::sort( quads.begin(), quads.end() ); 00193 std::sort( contents.begin(), contents.end() ); 00194 CHECK_EQUAL( quads, contents ); 00195 } 00196 00197 void test_read_material_on_nodes() 00198 { 00199 ErrorCode rval; 00200 Core moab; 00201 Interface& mb = moab; 00202 read_file( moab, example5 ); 00203 00204 Tag mat_tag; 00205 rval = mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, mat_tag );CHECK_ERR( rval ); 00206 00207 Range sets; 00208 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &mat_tag, 0, 1, sets );CHECK_ERR( rval ); 00209 CHECK_EQUAL( 2, (int)sets.size() ); 00210 00211 EntityHandle set_101 = sets.front(); 00212 EntityHandle set_102 = sets.back(); 00213 00214 int id; 00215 rval = mb.tag_get_data( mat_tag, &set_101, 1, &id );CHECK_ERR( rval ); 00216 CHECK_EQUAL( 101, id ); 00217 00218 rval = mb.tag_get_data( mat_tag, &set_102, 1, &id );CHECK_ERR( rval ); 00219 CHECK_EQUAL( 102, id ); 00220 } 00221 00222 void test_read_geom_set() 00223 { 00224 ErrorCode rval; 00225 Core moab; 00226 Interface& mb = moab; 00227 read_file( moab, example ); 00228 00229 Tag dim_tag, id_tag; 00230 rval = mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, dim_tag );CHECK_ERR( rval ); 00231 id_tag = mb.globalId_tag(); 00232 00233 Range sets; 00234 rval = mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &dim_tag, 0, 1, sets );CHECK_ERR( rval ); 00235 CHECK_EQUAL( 1, (int)sets.size() ); 00236 EntityHandle set = sets.front(); 00237 00238 int dim; 00239 rval = mb.tag_get_data( dim_tag, &set, 1, &dim );CHECK_ERR( rval ); 00240 CHECK_EQUAL( 2, dim ); 00241 00242 int id; 00243 rval = mb.tag_get_data( id_tag, &set, 1, &id );CHECK_ERR( rval ); 00244 CHECK_EQUAL( 3, id ); 00245 00246 std::vector< EntityHandle > quads, contents; 00247 rval = mb.get_entities_by_type( 0, MBQUAD, quads );CHECK_ERR( rval ); 00248 rval = mb.get_entities_by_handle( set, contents );CHECK_ERR( rval ); 00249 std::sort( quads.begin(), quads.end() ); 00250 std::sort( contents.begin(), contents.end() ); 00251 CHECK_EQUAL( quads, contents ); 00252 } 00253 00254 void test_read_airfoil() 00255 { 00256 Core moab; 00257 read_file( moab, example2 ); 00258 } 00259 00260 void test_read_t1() 00261 { 00262 Core moab; 00263 read_file( moab, example3 ); 00264 } 00265 00266 void test_read_fgh() 00267 { 00268 Core moab; 00269 read_file( moab, example4 ); // it should find 3 partitions 00270 // read partition sets 00271 Tag ptag; 00272 ErrorCode rval = moab.tag_get_handle( "PARALLEL_PARTITION", ptag );CHECK_ERR( rval ); 00273 Range psets; 00274 rval = moab.get_entities_by_type_and_tag( 0, MBENTITYSET, &ptag, 0, 1, psets );CHECK_ERR( rval ); 00275 CHECK_EQUAL( 3, (int)psets.size() ); 00276 Range ents_first_set; 00277 rval = moab.get_entities_by_handle( psets[0], ents_first_set );CHECK_ERR( rval ); 00278 CHECK_EQUAL( (int)ents_first_set.size(), 98 ); 00279 }
