MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/MOABConfig.h"#include "moab/ErrorHandler.hpp"#include <iostream>#include <cstdlib>
Include dependency graph for ErrorHandlingSimulation.cpp:Go to the source code of this file.
Functions | |
| ErrorCode | FunctionC (int test_case_num, int rank) |
| ErrorCode | FunctionB (int test_case_num, int rank) |
| ErrorCode | FunctionA (int test_case_num, int rank) |
| int | main (int argc, char **argv) |
Definition at line 68 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionB(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by main().
ErrorCode err_code = FunctionB( test_case_num, rank );MB_CHK_ERR( err_code );
return MB_SUCCESS;
Definition at line 61 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionC(), MB_CHK_ERR, and MB_SUCCESS.
Referenced by FunctionA().
ErrorCode err_code = FunctionC( test_case_num, rank );MB_CHK_ERR( err_code );
return MB_SUCCESS;
Definition at line 24 of file ErrorHandlingSimulation.cpp.
References MB_INDEX_OUT_OF_RANGE, MB_NOT_IMPLEMENTED, MB_SET_ERR, MB_SET_GLB_ERR, MB_SUCCESS, and MB_TYPE_OUT_OF_RANGE.
Referenced by FunctionB().
switch( test_case_num )
case 1:
// Simulate a global fatal error MB_NOT_IMPLEMENTED on all processors
// Note, it is printed by root processor 0 only
MB_SET_GLB_ERR( MB_NOT_IMPLEMENTED, "A contrived global error MB_NOT_IMPLEMENTED" );
break;
case 2:
// Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on all processors
// Note, it is printed by all processors
MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor " << rank );
break;
case 3:
// Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on all processors except
// root Note, it is printed by all non-root processors
if( 0 != rank )
MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor " << rank );
break;
case 4:
// Simulate a per-processor relevant error MB_INDEX_OUT_OF_RANGE on processor 1
// Note, it is printed by processor 1 only
if( 1 == rank )
MB_SET_ERR( MB_INDEX_OUT_OF_RANGE, "A contrived error MB_INDEX_OUT_OF_RANGE on processor 1" );
// Simulate a per-processor relevant error MB_TYPE_OUT_OF_RANGE on processor 3
// Note, it is printed by processor 3 only
if( 3 == rank ) MB_SET_ERR( MB_TYPE_OUT_OF_RANGE, "A contrived error MB_TYPE_OUT_OF_RANGE on processor 3" );
break;
default:
break;
return MB_SUCCESS;
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 75 of file ErrorHandlingSimulation.cpp.
References ErrorCode, FunctionA(), MB_CHK_ERR, moab::MBErrorHandler_Finalize(), moab::MBErrorHandler_Init(), MPI_COMM_WORLD, and rank.
if( argc < 2 )
cout << "Usage: " << argv[0] << " <test_case_num(1 to 4)>" << endl;
return 0;
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
#endif
// Initialize error handler, required for this example (not using a moab instance)
MBErrorHandler_Init();
int test_case_num = atoi( argv[1] );
int rank = 0;
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#endif
ErrorCode rval = FunctionA( test_case_num, rank );MB_CHK_ERR( rval );
// Finalize error handler, required for this example (not using a moab instance)
MBErrorHandler_Finalize();
MPI_Finalize();
#endif
return 0;
