MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "EdgeSizeSimpleImplicit.hpp"#include "SimplexTemplateRefiner.hpp"#include "MeshRefiner.hpp"#include "moab/Interface.hpp"#include "MBParallelConventions.h"#include "TestUtil.hpp"#include <iostream>#include <sstream>#include <map>#include <ctime>
Include dependency graph for test_mesh_refiner.cpp:Go to the source code of this file.
Functions | |
| int | TestMeshRefiner (int argc, char *argv[]) |
| int | main (int argc, char *argv[]) |
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 174 of file test_mesh_refiner.cpp.
References TestMeshRefiner().
return TestMeshRefiner( argc, argv );
| int TestMeshRefiner | ( | int | argc, |
Definition at line 27 of file test_mesh_refiner.cpp.
References moab::Interface::create_meshset(), ErrorCode, moab::Interface::get_entities_by_type(), moab::Interface::list_entities(), moab::Interface::load_file(), MB_SUCCESS, MBTET, MESHSET_SET, MPI_COMM_WORLD, output_filename, rank, moab::MeshRefiner::refine(), moab::EntityRefiner::set_edge_size_evaluator(), moab::MeshRefiner::set_entity_refiner(), moab::EdgeSizeSimpleImplicit::set_ratio(), and moab::Interface::write_file().
Referenced by main().
int nprocs, rank;
#ifdef MOAB_HAVE_MPI
MPI_Init( &argc, &argv );
MPI_Comm_size( MPI_COMM_WORLD, &nprocs );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
#else // MOAB_HAVE_MPI
nprocs = 1;
rank = 0;
#endif // MOAB_HAVE_MPI
// sleep(20);
// Create the input mesh and, if -new-mesh is specified, an output mesh
std::string ifname = argc > 1 ? argv[1] : TestDir + "fourVolsBare.cub";
bool input_is_output = false, do_output = false;
std::string output_filename;
if( argc > 2 )
if( !strcmp( argv[2], "-new-mesh" ) )
input_is_output = true;
else
do_output = true;
output_filename = std::string( argv[2] );
Interface* imesh = new Core; // ( rank, nprocs );
Interface* omesh = input_is_output ? imesh : new Core; // ( rank, nprocs );
// Use an ParallelComm object to help set up the input mesh
ParallelComm* ipcomm = new ParallelComm( imesh, MPI_COMM_WORLD );
// ReadParallel* readpar = new ReadParallel( imesh, ipcomm );
EntityHandle set_handle;
std::ostringstream parallel_options;
if( nprocs > 1 )
parallel_options << "PARALLEL=READ_DELETE"
<< ";" // NB: You can use BCAST_DELETE or READ_DELETE here.
//<< "PARALLEL=BCAST_DELETE" << ";" // NB: You can use BCAST_DELETE or READ_DELETE here.
<< "PARTITION=MATERIAL_SET"
<< "PARTITION_DISTRIBUTE"
<< "PARALLEL_RESOLVE_SHARED_ENTS"
<< "CPUTIME";
#endif
ErrorCode rval = imesh->create_meshset( MESHSET_SET, set_handle );
if( MB_SUCCESS != rval )
std::cout << "Trouble creating set, exiting." << std::endl;
return 1;
rval = imesh->load_file( ifname.c_str(), &set_handle, parallel_options.str().c_str() );
std::cout << "Trouble reading mesh file " << ifname << ", exiting." << std::endl;
return 1;
// Print out what we have so far, one process at a time
for( int i = 0; i < nprocs; ++i )
MPI_Barrier( MPI_COMM_WORLD );
if( i == rank )
std::cout << "\n************** Rank: " << ( rank ) << " of: " << nprocs << "\n";
imesh->list_entities( 0, 0 );
std::cout << "**************\n\n";
// The refiner will need an implicit function to be used as an indicator function for
// subdivision:
EdgeSizeSimpleImplicit* eval = new EdgeSizeSimpleImplicit();
eval->set_ratio( 2. );
// Refine the mesh
MeshRefiner* mref = new MeshRefiner( imesh, omesh );
SimplexTemplateRefiner* eref = new SimplexTemplateRefiner;
mref->set_entity_refiner( eref );
// mref->add_vertex_tag( tag_floatular );
// mref->add_vertex_tag( tag_intular );
// (We don't add tag_gid to the refiner's tag manager because it is special)
eref->set_edge_size_evaluator( eval );
Range ents_to_refine;
imesh->get_entities_by_type( set_handle, MBTET, ents_to_refine ); // refine just the tets
// ents_to_refine.insert( set_handle ); // refine everything multiple times (because subsets are
// not disjoint)
#ifdef _WIN32
struct timeval tic, toc;
gettimeofday( &tic, 0 );
mref->refine( ents_to_refine );
gettimeofday( &toc, 0 );
std::cout << "\nTime: " << ( ( toc.tv_sec - tic.tv_sec ) * 1000 + ( toc.tv_usec - tic.tv_usec ) / 1000. )
<< " ms\n\n";
#endif
if( do_output )
parallel_options.clear();
if( nprocs > 1 ) parallel_options << "PARALLEL=WRITE_PART";
omesh->write_file( output_filename.c_str(), NULL, parallel_options.str().c_str() );
// Print out the results, one process at a time
if( i == rank )
omesh->list_entities( 0, 0 );
omesh->list_entities( 0, 1 );
// Clean up
// delete readpar;
delete ipcomm;
if( omesh != imesh ) delete omesh;
delete imesh;
delete mref; // mref will delete eref
MPI_Finalize();
return 0;
