bsp_tree_poly_test.cpp File Reference
#include "moab/BSPTreePoly.hpp"
#include "TestUtil.hpp"
#include "moab/CartVect.hpp"
+ Include dependency graph for bsp_tree_poly_test.cpp:
Functions
void test_construct_from_hex ()
void test_cut_with_plane ()
void test_volume ()
int main ()
static void get_corners (CartVect corners[8])
const BSPTreePoly::Face * find_face (const BSPTreePoly &poly, const CartVect *coords, int num_corners, const int *face_indices=0)
Variables
const int hex_faces [6][4]
Function Documentation
const BSPTreePoly::Face* find_face ( const BSPTreePoly &  poly,
const CartVect *  coords,
int  num_corners,
const int *  face_indices = 0
Definition at line 35 of file bsp_tree_poly_test.cpp.
References moab::BSPTreePoly::get_faces(), moab::BSPTreePoly::get_vertices(), and length_squared().
Referenced by test_construct_from_hex(), and test_cut_with_plane().
    std::vector< const BSPTreePoly::Face* >::iterator i;
    std::vector< const BSPTreePoly::Face* > faces;
    std::vector< CartVect > corners;
    poly.get_faces( faces );
    for( i = faces.begin(); i != faces.end(); ++i )
        corners.clear();
        poly.get_vertices( *i, corners );
        if( corners.size() != (unsigned)num_corners ) continue;
        int j;
        for( j = 0; j < num_corners; ++j )
            int corner = face_indices ? face_indices[j] : j;
            if( ( coords[corner] - corners.front() ).length_squared() < 1e-12 ) break;
        if( j == num_corners ) continue;
        int k;
        for( k = 1; k < num_corners; ++k )
            int corner = face_indices ? face_indices[( j + k ) % num_corners] : ( j + k ) % num_corners;
            if( ( coords[corner] - corners[k] ).length_squared() > 1e-12 ) break;
        if( k == num_corners ) return *i;
    return 0;
static void get_corners ( CartVect  corners[8]) [static]
Definition at line 23 of file bsp_tree_poly_test.cpp.
Referenced by test_construct_from_hex(), test_cut_with_plane(), and test_volume().
    corners[0] = CartVect( 1, 1, 0 );
    corners[1] = CartVect( 6, 1, 0 );
    corners[2] = CartVect( 6, 3, 0 );
    corners[3] = CartVect( 1, 3, 0 );
    corners[4] = CartVect( 1, 1, 2 );
    corners[5] = CartVect( 4, 1, 2 );
    corners[6] = CartVect( 4, 3, 2 );
    corners[7] = CartVect( 1, 3, 2 );
int main ( )
Definition at line 11 of file bsp_tree_poly_test.cpp.
References error_count, RUN_TEST, test_construct_from_hex(), test_cut_with_plane(), and test_volume().
    int error_count = 0;
    error_count += RUN_TEST( test_construct_from_hex );
    error_count += RUN_TEST( test_cut_with_plane );
    error_count += RUN_TEST( test_volume );
    return error_count;
Definition at line 70 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_EQUAL, find_face(), get_corners(), moab::BSPTreePoly::get_faces(), hex_faces, moab::BSPTreePoly::is_valid(), and moab::BSPTreePoly::reset_debug_ids().
Referenced by main().
    BSPTreePoly::reset_debug_ids();
    CartVect corners[8];
    get_corners( corners );
    BSPTreePoly poly( corners );
    CHECK( poly.is_valid() );
    CHECK_EQUAL( (size_t)6, faces.size() );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[0] ) );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[1] ) );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[2] ) );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[3] ) );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[4] ) );
    CHECK( 0 != find_face( poly, corners, 4, hex_faces[5] ) );
Definition at line 91 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_EQUAL, moab::BSPTreePoly::cut_polyhedron(), find_face(), get_corners(), moab::BSPTreePoly::get_faces(), hex_faces, moab::BSPTreePoly::is_valid(), moab::BSPTreePoly::reset_debug_ids(), and moab::BSPTreePoly::set().
    // create a hexahedron
    // check that a plane entirely above the
    // polyhedron (coincident with one face)
    // doesn't modify the polyhedron
    bool r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -2 );
    CHECK( !r );
    // cut in half with Z=1 plane
    r = poly.cut_polyhedron( CartVect( 0, 0, 1 ), -1 );
    CHECK( r );
    for( int i = 0; i < 8; ++i )
        if( fabs( corners[i][2] - 2 ) < 1e-6 ) corners[i][2] = 1;
        if( fabs( corners[i][0] - 4 ) < 1e-6 ) corners[i][0] = 5;
    poly.set( corners );
    // cut off two corners using X=5 plane
    r = poly.cut_polyhedron( CartVect( 1, 0, 0 ), -5 );
    CHECK( r );
    faces.clear();
    CHECK_EQUAL( (size_t)7, faces.size() );
    CartVect new_vtx1( 5, 1, 1 );
    CartVect new_vtx2( 5, 1, 0 );
    CartVect new_vtx3( 5, 3, 0 );
    CartVect new_vtx4( 5, 3, 1 );
    CartVect face1[5] = { corners[0], new_vtx2, new_vtx1, corners[5], corners[4] };
    CartVect face2[4] = { new_vtx1, new_vtx4, corners[6], corners[5] };
    CartVect face3[5] = { new_vtx4, new_vtx3, corners[3], corners[7], corners[6] };
    CartVect face5[4] = { corners[3], new_vtx3, new_vtx2, corners[0] };
    CartVect face7[4] = { new_vtx1, new_vtx2, new_vtx3, new_vtx4 };
    CHECK( 0 != find_face( poly, face1, 5 ) );
    CHECK( 0 != find_face( poly, face2, 4 ) );
    CHECK( 0 != find_face( poly, face3, 5 ) );
    CHECK( 0 != find_face( poly, face5, 4 ) );
    CHECK( 0 != find_face( poly, face7, 4 ) );
void test_volume ( )
Definition at line 163 of file bsp_tree_poly_test.cpp.
References CHECK, CHECK_REAL_EQUAL, get_corners(), moab::BSPTreePoly::is_valid(), and moab::BSPTreePoly::volume().
    CHECK_REAL_EQUAL( 16.0, poly.volume(), 1e-6 );
Variable Documentation
const int hex_faces[6][4]
Initial value:
 { { 0, 1, 5, 4 }, { 1, 2, 6, 5 }, { 2, 3, 7, 6 },
                              { 3, 0, 4, 7 }, { 3, 2, 1, 0 }, { 4, 5, 6, 7 } }
Definition at line 20 of file bsp_tree_poly_test.cpp.
