MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "ReadABAQUS.hpp"#include <algorithm>#include <ctime>#include <string>#include <cassert>#include <cstdio>#include <cmath>#include "moab/Range.hpp"#include "moab/Interface.hpp"#include "MBTagConventions.hpp"#include "Internals.hpp"#include "moab/ReadUtilIface.hpp"#include "AffineXform.hpp"#include "moab/FileOptions.hpp"
Include dependency graph for ReadABAQUS.cpp:Go to the source code of this file.
Namespaces | |
| namespace | moab |
Class representing axis-aligned bounding box. | |
Defines | |
| #define | ABQ_AMBIGUOUS "AMBIGUOUS" |
| #define | ABQ_UNDEFINED "UNDEFINED" |
| #define | DEG2RAD 0.017453292519943295769236907684886 |
| #define | MB_RETURN_IF_FAIL if( MB_SUCCESS != status ) return status |
| #define ABQ_AMBIGUOUS "AMBIGUOUS" |
Definition at line 41 of file ReadABAQUS.cpp.
Referenced by moab::ReadABAQUS::get_keyword(), moab::ReadABAQUS::match(), moab::ReadABAQUS::read_assembly(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadABAQUS::read_instance(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadABAQUS::read_part(), and moab::ReadABAQUS::read_solid_section().
| #define ABQ_UNDEFINED "UNDEFINED" |
Definition at line 42 of file ReadABAQUS.cpp.
Referenced by moab::ReadABAQUS::match().
| #define DEG2RAD 0.017453292519943295769236907684886 |
Definition at line 43 of file ReadABAQUS.cpp.
Referenced by moab::ReadABAQUS::create_instance_of_part(), moab::ReadABAQUS::cyl2rect(), and moab::ReadABAQUS::sph2rect().
| #define MB_RETURN_IF_FAIL if( MB_SUCCESS != status ) return status |
Definition at line 45 of file ReadABAQUS.cpp.
Referenced by moab::ReadABAQUS::add_entity_set(), moab::ReadABAQUS::create_instance_of_part(), moab::ReadABAQUS::get_elements_by_id(), moab::ReadABAQUS::get_nodes_by_id(), moab::ReadABAQUS::get_set_elements(), moab::ReadABAQUS::get_set_elements_by_name(), moab::ReadABAQUS::get_set_nodes(), moab::ReadABAQUS::load_file(), moab::ReadABAQUS::read_assembly(), moab::ReadABAQUS::read_element_list(), moab::ReadABAQUS::read_element_set(), moab::ReadABAQUS::read_instance(), moab::ReadABAQUS::read_node_list(), moab::ReadABAQUS::read_node_set(), moab::ReadABAQUS::read_part(), and moab::ReadABAQUS::read_solid_section().
