MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /*! 00017 \brief Stores contiguous or partially contiguous values in an optimized 00018 fashion. Partially contiguous accessing patterns is also optimized. 00019 00020 \author Clinton Stimpson 00021 00022 \date 15 April 2002 00023 00024 ************* Range FAQ and tips ******************** 00025 00026 The purpose of this FAQ is to familiarize a user with 00027 the appropriate use of the Range template. 00028 00029 ******* A few points about Range: ******* 00030 1. Range is not the be all of generic containers. 00031 2. Range has its strengths and weaknesses as any other 00032 STL container has. 00033 3. Strengths: 00034 a. For contiguous values, storage is extremely minimal. 00035 b. Searching through contiguous values, at best, is 00036 a constant time operation. 00037 b. Fairly compatible with most STL algorithms. 00038 c. Insertions of data from high value to low value 00039 is a linear operation (constant for each insertion). 00040 d. Removal of a value using an iterator is constant time. 00041 00042 4. Weaknesses: 00043 a. For non-contiguous values, storage is not minimal and is 00044 on the order of 4x the storage space as using a vector. 00045 b. Searching through non-contiguous values is linear 00046 time operation. 00047 c. Insertions of random data is VERY slow. 00048 00049 Given the above characteristics of Ranges, you can now 00050 decide between Range and another STL container for your 00051 particular needs. 00052 00053 00054 ******* Tips ******* 00055 1. Be aware of what iterators are available. Currently, there are 00056 three. Range<T>::iterator, Range<T>::const_iterator, 00057 and Range<T>::RangeListIterator. 00058 iterator is derived from const_iterator. const_iterator 00059 is derived from RangeListIterator. RangeListIterator is a 00060 std::list<std::pair<T,T> >::const_iterator. 00061 If a particular algorithm could be more efficient by using 00062 RangeListIterator, do so. 00063 00064 ie. 00065 00066 Range<char> range1; 00067 ... put some stuff in range1 00068 Range<char> range2; 00069 00070 // the SLOW way. 00071 std::copy(range1.begin(), range1.end(), range_inserter<...>(range2)); 00072 00073 // the FAST way. 00074 for(Range<char>::RangeListIterator iter = range1.begin(), 00075 iter != range1.end(); ++iter) 00076 { 00077 range2.insert(iter->first, iter->second); 00078 } 00079 00080 2. Prefer insert(val1, val2) over insert(val) where possible. 00081 00082 3. insert(val) and insert(val1, val2) have to perform searching 00083 to find out where to insert an item. Searches are started 00084 from the beginning of the values. Inserting larger values 00085 before smaller values will increase efficiency. 00086 00087 ie. 00088 std::set<int> my_set; 00089 Range<int> my_range; 00090 .. perform some operations which set does efficiently. 00091 00092 // now copy the results from the set into the range. 00093 // copy from the end of the set to the beginning of the set 00094 std::copy(my_set.rbegin(), my_set.rend(), 00095 range_inserter< Range<int> > ( my_range ); 00096 00097 4. Use empty() instead of size() if you only need to find out 00098 if there is anything in the list. 00099 00100 5. Know what swap() does. Sometimes it is useful. It'll replace 00101 the contents of one list with another. 00102 00103 void compute_and_get_some_set( 00104 Range<char> range1, 00105 Range<char> range2, 00106 Range<char>& results 00107 ); 00108 { 00109 Range<char> tmp_results; 00110 .. perform some computation on range1 and range2 00111 and put results in tmp_results; 00112 .. filter tmp_results out for some special type. 00113 .. etc.... 00114 // return results 00115 results.swap(tmp_results); 00116 } 00117 00118 00119 ******* FAQ ******* 00120 1. Why won't this code compile? 00121 ------------------------ 00122 class SomeClass 00123 { 00124 public: 00125 Range<int> range; 00126 }; 00127 .... 00128 void some_function( const SomeClass& some_class ) 00129 { 00130 Range<int>::iterator = some_class.range.begin(); 00131 } 00132 --------------------- 00133 Solution: you need to use 00134 Range<int>::const_iterator instead. 00135 00136 2. Why doesn't this work right when I try to change the 00137 contents of an Range? 00138 00139 // make a range that has the letters A,B,C in it. 00140 Range<char> my_chars('A', 'C'); 00141 // make an iterator that points to 'A'. 00142 Range<char>::iterator iter = my_chars.begin(); 00143 // change A to D 00144 *iter = 'D'; 00145 // print contents of my_chars to stdout 00146 std::copy(my_chars.begin(), my_chars.end(), 00147 std::ostream_iterator(std::cout, " ")); 00148 00149 result is 00150 A B C 00151 instead of 00152 B C D 00153 00154 When one calls *iter, which returns 'A', the actual storage of the value 'A' 00155 which is returned is in the iterator and not in the Range. This allows 00156 for multiple iterators on a single Range and the Range does not have 00157 to keep track of which iterator is referencing which value. 00158 00159 00160 00161 */ 00162 00163 #ifndef MOAB_RANGE_HPP 00164 #define MOAB_RANGE_HPP 00165 00166 #include <string> 00167 #include <iterator> 00168 #include <iosfwd> 00169 #include <algorithm> 00170 #include <string> 00171 00172 #include "moab/Types.hpp" 00173 00174 namespace moab 00175 { 00176 00177 struct range_iter_tag : public std::bidirectional_iterator_tag 00178 { 00179 }; 00180 00181 struct range_base_iter 00182 { 00183 typedef range_iter_tag iterator_category; 00184 typedef EntityID difference_type; 00185 typedef EntityHandle value_type; 00186 typedef EntityHandle* pointer; 00187 typedef EntityHandle& reference; 00188 }; 00189 00190 //! the class Range 00191 class MOAB_EXPORT Range 00192 { 00193 public: 00194 // forward declare the iterators 00195 class const_iterator; 00196 class const_reverse_iterator; 00197 typedef const_iterator iterator; 00198 typedef const_reverse_iterator reverse_iterator; 00199 00200 friend Range intersect( const Range&, const Range& ); 00201 friend Range subtract( const Range&, const Range& ); 00202 00203 //! just like subtract, but as an operator 00204 Range& operator-=( const Range& rhs ); 00205 00206 //! for short hand notation, lets typedef the 00207 //! container class that holds the ranges 00208 typedef EntityHandle value_type; 00209 00210 //! default constructor 00211 Range(); 00212 00213 //! copy constructor 00214 Range( const Range& copy ); 00215 00216 //! another constructor that takes an initial range 00217 Range( EntityHandle val1, EntityHandle val2 ); 00218 00219 //! operator= 00220 Range& operator=( const Range& copy ); 00221 00222 //! destructor 00223 inline ~Range(); 00224 00225 //! return the beginning const iterator of this range 00226 inline const_iterator begin() const; 00227 00228 //! return the beginning const reverse iterator of this range 00229 inline const_reverse_iterator rbegin() const; 00230 00231 //! return the ending const iterator for this range 00232 inline const_iterator end() const; 00233 00234 //! return the ending const reverse iterator for this range 00235 inline const_reverse_iterator rend() const; 00236 00237 //! return the number of values this Ranges represents 00238 size_t size() const; 00239 00240 //! return the number of range pairs in the list 00241 size_t psize() const; 00242 00243 //! return whether empty or not 00244 //! always use "if(!Ranges::empty())" instead of "if(Ranges::size())" 00245 inline bool empty() const; 00246 00247 iterator insert( iterator hint, EntityHandle val ); 00248 00249 //! insert an item into the list and return the iterator for the inserted item 00250 iterator insert( EntityHandle val ) 00251 { 00252 return insert( begin(), val ); 00253 } 00254 00255 //! insert a range of items into this list and return the iterator for the first 00256 //! inserted item 00257 iterator insert( iterator hint, EntityHandle first, EntityHandle last ); 00258 00259 //! insert a range of items into this list and return the iterator for the first 00260 //! inserted item 00261 iterator insert( EntityHandle val1, EntityHandle val2 ) 00262 { 00263 return insert( begin(), val1, val2 ); 00264 } 00265 00266 template < typename T > 00267 iterator insert_list( T begin_iter, T end_iter ); 00268 00269 template < class T > 00270 iterator insert( typename T::const_iterator begin_iter, typename T::const_iterator end_iter ) 00271 { 00272 return insert_list( begin_iter, end_iter ); 00273 } 00274 00275 template < typename T > 00276 iterator insert( const T* begin_iter, const T* end_iter ) 00277 { 00278 return insert_list( begin_iter, end_iter ); 00279 } 00280 00281 //! remove an item from this list and return an iterator to the next item 00282 iterator erase( iterator iter ); 00283 00284 //! remove a range of items from the list 00285 iterator erase( iterator iter1, iterator iter2 ); 00286 00287 //! erases a value from this container 00288 inline iterator erase( EntityHandle val ); 00289 00290 //! get first entity in range 00291 inline const EntityHandle& front() const; 00292 //! get last entity in range 00293 inline const EntityHandle& back() const; 00294 //! remove first entity from range 00295 EntityHandle pop_front(); 00296 //! remove last entity from range 00297 EntityHandle pop_back(); 00298 00299 //! find an item int the list and return an iterator at that value 00300 const_iterator find( EntityHandle val ) const; 00301 00302 //! return an iterator to the first value >= val 00303 static const_iterator lower_bound( const_iterator first, const_iterator last, EntityHandle val ); 00304 static const_iterator upper_bound( const_iterator first, const_iterator last, EntityHandle val ); 00305 00306 const_iterator lower_bound( EntityHandle val ) const 00307 { 00308 return lower_bound( begin(), end(), val ); 00309 } 00310 const_iterator upper_bound( EntityHandle val ) const 00311 { 00312 return upper_bound( begin(), end(), val ); 00313 } 00314 const_iterator lower_bound( EntityType type ) const; 00315 const_iterator upper_bound( EntityType type ) const; 00316 std::pair< const_iterator, const_iterator > equal_range( EntityType type ) const; 00317 const_iterator lower_bound( EntityType type, const_iterator first ) const; 00318 const_iterator upper_bound( EntityType type, const_iterator first ) const; 00319 00320 //! True if all entities in range are of passed type 00321 //! (also true if range is empty) 00322 bool all_of_type( EntityType type ) const; 00323 //! True if all entities in range are of passed dimension 00324 //! (also true if range is empty) 00325 bool all_of_dimension( int dimension ) const; 00326 00327 unsigned num_of_type( EntityType type ) const; 00328 unsigned num_of_dimension( int dim ) const; 00329 00330 //! clears the contents of the list 00331 void clear(); 00332 00333 //! for debugging 00334 const std::string str_rep( const char* indent_prefix = NULL ) const; 00335 00336 void print( const char* indent_prefix = NULL ) const; 00337 void print( std::ostream& s, const char* indent_prefix = NULL ) const; 00338 00339 unsigned long get_memory_use() const; 00340 00341 double compactness() const; 00342 00343 void insert( Range::const_iterator begin, Range::const_iterator end ); 00344 00345 //! merges this Range with another range 00346 void merge( const Range& range ) 00347 { 00348 insert( range.begin(), range.end() ); 00349 } 00350 00351 //! merge a subset of some other range 00352 void merge( Range::const_iterator beginr, Range::const_iterator endr ) 00353 { 00354 insert( beginr, endr ); 00355 } 00356 00357 //! swap the contents of this range with another one 00358 void swap( Range& range ); 00359 00360 //! check for internal consistency 00361 void sanity_check() const; 00362 00363 //! Check if this range is a non-strict superset of some other range 00364 bool contains( const Range& other ) const; 00365 00366 //! return a subset of this range, by type 00367 Range subset_by_type( EntityType t ) const; 00368 00369 //! return a subset of this range, by dimension 00370 Range subset_by_dimension( int dim ) const; 00371 00372 struct PairNode : public std::pair< EntityHandle, EntityHandle > 00373 { 00374 00375 PairNode() : std::pair< EntityHandle, EntityHandle >( 0, 0 ), mNext( NULL ), mPrev( NULL ) {} 00376 PairNode( PairNode* next, PairNode* prev, EntityHandle _first, EntityHandle _second ) 00377 : std::pair< EntityHandle, EntityHandle >( _first, _second ), mNext( next ), mPrev( prev ) 00378 { 00379 } 00380 00381 PairNode* mNext; 00382 PairNode* mPrev; 00383 }; 00384 00385 EntityHandle operator[]( EntityID index ) const; 00386 00387 int index( EntityHandle handle ) const; 00388 00389 protected: 00390 //! the head of the list that contains pairs that represent the ranges 00391 //! this list is sorted and unique at all times 00392 PairNode mHead; 00393 00394 //! if dead_node is not mHead, remove it from the list and free it's memory. 00395 void delete_pair_node( PairNode* dead_node ); 00396 00397 public: 00398 //! used to iterate over sub-ranges of a range 00399 class MOAB_EXPORT pair_iterator : public range_base_iter 00400 { 00401 friend class Range; 00402 00403 public: 00404 pair_iterator() : mNode( NULL ) {} 00405 pair_iterator( PairNode* nodep ) : mNode( nodep ) {} 00406 pair_iterator( const pair_iterator& copy ) : mNode( copy.mNode ) {} 00407 pair_iterator( const const_iterator& copy ) : mNode( copy.mNode ) {} 00408 00409 std::pair< EntityHandle, EntityHandle >* operator->() 00410 { 00411 return mNode; 00412 } 00413 00414 pair_iterator& operator++() 00415 { 00416 mNode = mNode->mNext; 00417 return *this; 00418 } 00419 pair_iterator operator++( int ) 00420 { 00421 pair_iterator tmp( *this ); 00422 this->operator++(); 00423 return tmp; 00424 } 00425 00426 pair_iterator& operator--() 00427 { 00428 mNode = mNode->mPrev; 00429 return *this; 00430 } 00431 pair_iterator operator--( int ) 00432 { 00433 pair_iterator tmp( *this ); 00434 this->operator--(); 00435 return tmp; 00436 } 00437 bool operator==( const pair_iterator& other ) const 00438 { 00439 return mNode == other.mNode; 00440 } 00441 00442 bool operator!=( const pair_iterator& other ) const 00443 { 00444 return mNode != other.mNode; 00445 } 00446 00447 PairNode* node() 00448 { 00449 return mNode; 00450 } 00451 00452 private: 00453 PairNode* mNode; 00454 }; 00455 00456 class const_pair_iterator; 00457 00458 //! a const iterator which iterates over an Range 00459 class MOAB_EXPORT const_iterator : public range_base_iter 00460 { 00461 friend class Range; 00462 friend class pair_iterator; 00463 friend class const_pair_iterator; 00464 friend EntityID operator-( const const_iterator&, const const_iterator& ); 00465 00466 public: 00467 //! default constructor - intialize base default constructor 00468 const_iterator() : mNode( NULL ), mValue( 0 ) {} 00469 00470 //! constructor used by Range 00471 const_iterator( const PairNode* iter, const EntityHandle val ) 00472 : mNode( const_cast< PairNode* >( iter ) ), mValue( val ) 00473 { 00474 } 00475 00476 //! dereference that value this iterator points to 00477 //! returns a const reference 00478 const EntityHandle& operator*() const 00479 { 00480 return mValue; 00481 } 00482 00483 //! prefix incrementer 00484 const_iterator& operator++() 00485 { 00486 // see if we need to increment the base iterator 00487 if( mValue == mNode->second ) 00488 { 00489 mNode = mNode->mNext; 00490 mValue = mNode->first; 00491 } 00492 // if not, just increment the value in the range 00493 else 00494 ++mValue; 00495 return *this; 00496 } 00497 00498 //! postfix incrementer 00499 const_iterator operator++( int ) 00500 { 00501 // make a temporary copy 00502 const_iterator tmp( *this ); 00503 // increment self 00504 this->operator++(); 00505 // return the copy 00506 return tmp; 00507 } 00508 00509 //! prefix decrementer 00510 const_iterator& operator--() 00511 { 00512 // see if we need to decrement the base iterator 00513 if( mValue == mNode->first ) 00514 { 00515 mNode = mNode->mPrev; 00516 ; 00517 mValue = mNode->second; 00518 } 00519 // if not, just decrement the value 00520 else 00521 --mValue; 00522 return *this; 00523 } 00524 00525 //! postfix decrementer 00526 const_iterator operator--( int ) 00527 { 00528 // make a copy of this 00529 const_iterator tmp( *this ); 00530 // decrement self 00531 this->operator--(); 00532 // return the copy 00533 return tmp; 00534 } 00535 00536 //! Advance iterator specified amount. 00537 //! Potentially O(n), but typically better. Always 00538 //! more efficient than calling operator++ step times. 00539 const_iterator& operator+=( EntityID step ); 00540 00541 //! Regress iterator specified amount. 00542 //! Potentially O(n), but typically better. Always 00543 //! more efficient than calling operator-- step times. 00544 const_iterator& operator-=( EntityID step ); 00545 00546 //! equals operator 00547 bool operator==( const const_iterator& other ) const 00548 { 00549 // see if the base iterator is the same and the 00550 // value of this iterator is the same 00551 return ( mNode == other.mNode ) && ( mValue == other.mValue ); 00552 } 00553 00554 //! not equals operator 00555 bool operator!=( const const_iterator& other ) const 00556 { 00557 // call == operator and not it. 00558 return ( mNode != other.mNode ) || ( mValue != other.mValue ); 00559 } 00560 00561 /**\brief get an iterator at the end of the block 00562 * 00563 * Get an iterator at the end of the block of consecutive 00564 * handles that this iterator is currently contained in. 00565 * That is, if the range contains blocks of consecutive 00566 * handles of the form { [1,5], [7,100], ... } and this 00567 * iterator is at any handle in the range [7,100], return 00568 * an iterator at the '100' handle. 00569 * 00570 * Never returns begin() or end() unless this iterator is 00571 * at begin() or end(). May return the same location as 00572 * this iterator. 00573 */ 00574 inline const_iterator end_of_block() const; 00575 00576 /**\brief get an iterator at the start of the block 00577 * 00578 * Get an iterator at the start of the block of consecutive 00579 * handles that this iterator is currently contained in. 00580 * That is, if the range contains blocks of consecutive 00581 * handles of the form { [1,5], [7,100], ... } and this 00582 * iterator is at any handle in the range [7,100], return 00583 * an iterator at the '7' handle. 00584 * 00585 * Never returns end() unless this iterator is 00586 * at end(). May return the same location as 00587 * this iterator. 00588 */ 00589 inline const_iterator start_of_block() const; 00590 00591 protected: 00592 //! the node we are pointing at 00593 PairNode* mNode; 00594 //! the value in the range 00595 EntityHandle mValue; 00596 }; 00597 00598 //! a const reverse iterator which iterates over an Range 00599 class MOAB_EXPORT const_reverse_iterator : public range_base_iter 00600 { 00601 friend class Range; 00602 friend class pair_iterator; 00603 00604 public: 00605 //! default constructor - intialize base default constructor 00606 const_reverse_iterator() {} 00607 00608 const_reverse_iterator( const_iterator fwd_iter ) : myIter( fwd_iter ) {} 00609 00610 //! constructor used by Range 00611 const_reverse_iterator( const PairNode* iter, const EntityHandle val ) : myIter( iter, val ) {} 00612 00613 //! dereference that value this iterator points to 00614 //! returns a const reference 00615 const EntityHandle& operator*() const 00616 { 00617 return *myIter; 00618 } 00619 00620 //! prefix incrementer 00621 const_reverse_iterator& operator++() 00622 { 00623 --myIter; 00624 return *this; 00625 } 00626 00627 //! postfix incrementer 00628 const_reverse_iterator operator++( int ) 00629 { 00630 return const_reverse_iterator( myIter-- ); 00631 } 00632 00633 //! prefix decrementer 00634 const_reverse_iterator& operator--() 00635 { 00636 ++myIter; 00637 return *this; 00638 } 00639 00640 //! postfix decrementer 00641 const_reverse_iterator operator--( int ) 00642 { 00643 return const_reverse_iterator( myIter++ ); 00644 } 00645 00646 //! Advance iterator specified amount. 00647 //! Potentially O(n), but typically better. Always 00648 //! more efficient than calling operator++ step times. 00649 const_reverse_iterator& operator+=( EntityID step ) 00650 { 00651 myIter -= step; 00652 return *this; 00653 } 00654 00655 //! Regress iterator specified amount. 00656 //! Potentially O(n), but typically better. Always 00657 //! more efficient than calling operator-- step times. 00658 const_reverse_iterator& operator-=( EntityID step ) 00659 { 00660 myIter += step; 00661 return *this; 00662 } 00663 00664 //! equals operator 00665 bool operator==( const const_reverse_iterator& other ) const 00666 { 00667 return myIter == other.myIter; 00668 } 00669 00670 //! not equals operator 00671 bool operator!=( const const_reverse_iterator& other ) const 00672 { 00673 return myIter != other.myIter; 00674 } 00675 00676 protected: 00677 //! the node we are pointing at 00678 const_iterator myIter; 00679 }; 00680 00681 public: 00682 class MOAB_EXPORT const_pair_iterator 00683 { 00684 public: 00685 const_pair_iterator() : myNode( NULL ) {} 00686 const_pair_iterator( const PairNode* node ) : myNode( node ) {} 00687 const_pair_iterator( const const_iterator& i ) : myNode( i.mNode ) {} 00688 00689 const PairNode& operator*() const 00690 { 00691 return *myNode; 00692 } 00693 00694 const PairNode* operator->() const 00695 { 00696 return myNode; 00697 } 00698 00699 const_pair_iterator& operator--() 00700 { 00701 myNode = myNode->mPrev; 00702 return *this; 00703 } 00704 00705 const_pair_iterator& operator++() 00706 { 00707 myNode = myNode->mNext; 00708 return *this; 00709 } 00710 00711 const_pair_iterator operator--( int ) 00712 { 00713 const_pair_iterator rval( *this ); 00714 this->operator--(); 00715 return rval; 00716 } 00717 00718 const_pair_iterator operator++( int ) 00719 { 00720 const_pair_iterator rval( *this ); 00721 this->operator++(); 00722 return rval; 00723 } 00724 00725 bool operator==( const const_pair_iterator& other ) const 00726 { 00727 return other.myNode == myNode; 00728 } 00729 00730 bool operator!=( const const_pair_iterator& other ) const 00731 { 00732 return other.myNode != myNode; 00733 } 00734 00735 private: 00736 const PairNode* myNode; 00737 }; 00738 00739 pair_iterator pair_begin() 00740 { 00741 return pair_iterator( mHead.mNext ); 00742 } 00743 pair_iterator pair_end() 00744 { 00745 return pair_iterator( &mHead ); 00746 } 00747 00748 const_pair_iterator const_pair_begin() const 00749 { 00750 return const_pair_iterator( mHead.mNext ); 00751 } 00752 const_pair_iterator const_pair_end() const 00753 { 00754 return const_pair_iterator( &mHead ); 00755 } 00756 const_pair_iterator pair_begin() const 00757 { 00758 return const_pair_iterator( mHead.mNext ); 00759 } 00760 const_pair_iterator pair_end() const 00761 { 00762 return const_pair_iterator( &mHead ); 00763 } 00764 }; 00765 00766 //! intersect two ranges, placing the results in the return range 00767 Range intersect( const Range&, const Range& ); 00768 00769 //! subtract range2 from this, placing the results in the return range 00770 Range subtract( const Range& from, const Range& ); 00771 00772 //! unite two ranges, placing the results in the return range 00773 inline Range unite( const Range& r1, const Range& r2 ) 00774 { 00775 Range r( r1 ); 00776 r.insert( r2.begin(), r2.end() ); 00777 return r; 00778 } 00779 00780 inline Range::const_iterator operator+( const Range::const_iterator& it, EntityID step ) 00781 { 00782 Range::const_iterator tmp( it ); 00783 return tmp += step; 00784 } 00785 00786 inline Range::const_iterator operator+( EntityID step, const Range::const_iterator& it ) 00787 { 00788 Range::const_iterator tmp( it ); 00789 return tmp += step; 00790 } 00791 00792 inline Range::const_iterator operator-( const Range::const_iterator& it, EntityID step ) 00793 { 00794 Range::const_iterator tmp( it ); 00795 return tmp -= step; 00796 } 00797 00798 inline Range::const_iterator operator-( EntityID step, const Range::const_iterator& it ) 00799 { 00800 Range::const_iterator tmp( it ); 00801 return tmp -= step; 00802 } 00803 00804 EntityID operator-( const Range::const_iterator& it1, const Range::const_iterator& it2 ); 00805 00806 //! Use as you would an STL back_inserter 00807 /** 00808 * e.g. std::copy(list.begin(), list.end(), range_inserter(my_range); 00809 * Also, see comments/instructions at the top of this class declaration 00810 */ 00811 class MOAB_EXPORT range_inserter 00812 { 00813 00814 protected: 00815 Range* container; 00816 00817 public: 00818 // constructor 00819 explicit range_inserter( Range& x ) : container( &x ) {} 00820 range_inserter& operator=( const Range::value_type& value ) 00821 { 00822 container->insert( value ); 00823 return *this; 00824 } 00825 00826 range_inserter& operator*() 00827 { 00828 return *this; 00829 } 00830 range_inserter& operator++() 00831 { 00832 return *this; 00833 } 00834 range_inserter& operator++( int ) 00835 { 00836 return *this; 00837 } 00838 00839 typedef EntityHandle value_type; 00840 typedef EntityID difference_type; 00841 typedef std::output_iterator_tag iterator_category; 00842 typedef EntityHandle* pointer; 00843 typedef EntityHandle& reference; 00844 }; 00845 00846 inline Range::Range() 00847 { 00848 // set the head node to point to itself 00849 mHead.mNext = mHead.mPrev = &mHead; 00850 mHead.first = mHead.second = 0; 00851 } 00852 00853 //! destructor 00854 inline Range::~Range() 00855 { 00856 clear(); 00857 } 00858 00859 //! return the beginning const iterator of this range 00860 inline Range::const_iterator Range::begin() const 00861 { 00862 return const_iterator( mHead.mNext, mHead.mNext->first ); 00863 } 00864 00865 //! return the beginning const reverse iterator of this range 00866 inline Range::const_reverse_iterator Range::rbegin() const 00867 { 00868 return const_reverse_iterator( mHead.mPrev, mHead.mPrev->second ); 00869 } 00870 00871 //! return the ending const iterator for this range 00872 inline Range::const_iterator Range::end() const 00873 { 00874 return const_iterator( &mHead, mHead.first ); 00875 } 00876 00877 //! return the ending const reverse iterator for this range 00878 inline Range::const_reverse_iterator Range::rend() const 00879 { 00880 return const_reverse_iterator( &mHead, mHead.second ); 00881 } 00882 00883 //! return whether empty or not 00884 //! always use "if(!Ranges::empty())" instead of "if(Ranges::size())" 00885 inline bool Range::empty() const 00886 { 00887 return ( mHead.mNext == &mHead ); 00888 } 00889 00890 //! erases a value from this container 00891 inline Range::iterator Range::erase( EntityHandle val ) 00892 { 00893 return erase( find( val ) ); 00894 } 00895 00896 inline Range::const_iterator Range::const_iterator::end_of_block() const 00897 { 00898 return Range::const_iterator( mNode, mNode->second ); 00899 } 00900 00901 inline Range::const_iterator Range::const_iterator::start_of_block() const 00902 { 00903 return Range::const_iterator( mNode, mNode->first ); 00904 } 00905 00906 //! get first entity in range 00907 inline const EntityHandle& Range::front() const 00908 { 00909 return mHead.mNext->first; 00910 } 00911 //! get last entity in range 00912 inline const EntityHandle& Range::back() const 00913 { 00914 return mHead.mPrev->second; 00915 } 00916 00917 inline std::ostream& operator<<( std::ostream& s, const Range& r ) 00918 { 00919 r.print( s ); 00920 return s; 00921 } 00922 00923 bool operator==( const Range& r1, const Range& r2 ); 00924 inline bool operator!=( const Range& r1, const Range& r2 ) 00925 { 00926 return !( r1 == r2 ); 00927 } 00928 00929 inline EntityHandle Range::operator[]( EntityID indexp ) const 00930 { 00931 Range::const_iterator i = begin(); 00932 i += indexp; 00933 return *i; 00934 } 00935 00936 inline int Range::index( EntityHandle handle ) const 00937 { 00938 if( handle < *begin() || handle > *rbegin() ) return -1; 00939 00940 unsigned int i = 0; 00941 Range::const_pair_iterator pit = const_pair_begin(); 00942 while( handle > ( *pit ).second && pit != const_pair_end() ) 00943 { 00944 i += ( *pit ).second - ( *pit ).first + 1; 00945 ++pit; 00946 } 00947 if( handle < ( *pit ).first || pit == const_pair_end() ) return -1; 00948 00949 return i + handle - ( *pit ).first; 00950 } 00951 00952 inline double Range::compactness() const 00953 { 00954 unsigned int num_ents = size(); 00955 return ( num_ents ? ( (double)get_memory_use() / (double)( num_ents * sizeof( EntityHandle ) ) ) : -1 ); 00956 } 00957 00958 template < typename Iterator > 00959 Range::iterator Range::insert_list( Iterator begin_iter, Iterator end_iter ) 00960 { 00961 size_t n = std::distance( begin_iter, end_iter ); 00962 EntityHandle* sorted = new EntityHandle[n]; 00963 std::copy( begin_iter, end_iter, sorted ); 00964 std::sort( sorted, sorted + n ); 00965 iterator hint = begin(); 00966 size_t i = 0; 00967 while( i < n ) 00968 { 00969 size_t j = i + 1; 00970 while( j < n && sorted[j] == 1 + sorted[j - 1] ) 00971 ++j; 00972 hint = insert( hint, sorted[i], sorted[i] + ( ( j - i ) - 1 ) ); 00973 i = j; 00974 } 00975 delete[] sorted; 00976 return hint; 00977 } 00978 00979 inline size_t Range::psize() const 00980 { 00981 size_t i = 0; 00982 Range::const_pair_iterator pit; 00983 for( pit = const_pair_begin(), i = 0; pit != const_pair_end(); ++pit, i++ ) 00984 ; 00985 00986 return i; 00987 } 00988 00989 } // namespace moab 00990 00991 #endif // MOAB_RANGE_HPP
