MOAB: Mesh Oriented datABase
(version 5.4.1)
Include dependency graph for ExtrudePoly.cpp:Go to the source code of this file.
Defines | |
| #define | MESH_DIR "." |
| #define | MAXEDGES 20 |
Functions | |
| int | main (int argc, char **argv) |
Variables | |
| string | test_file_name = string( MESH_DIR ) + string( "/io/poly8-10.vtk" ) |
| string | output = string( "polyhedra.vtk" ) |
| int | layers = 1 |
| double | layer_thick = 1.0 |
| #define MAXEDGES 20 |
Definition at line 19 of file ExtrudePoly.cpp.
Referenced by main().
| #define MESH_DIR "." |
Definition at line 15 of file ExtrudePoly.cpp.
Referenced by get_file_options(), main(), TestErrorHandling_1(), TestErrorHandling_2(), TestErrorHandling_3(), TestErrorHandlingPar_1(), and TestErrorHandlingPar_2().
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 26 of file ExtrudePoly.cpp.
References moab::Interface::create_element(), moab::Interface::create_vertices(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::ReadUtilIface::get_element_connect(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), moab::Range::index(), layer_thick, layers, moab::Interface::load_mesh(), MAXEDGES, mb, MB_CHK_ERR, MB_CHK_SET_ERR, MBPOLYGON, MBPOLYHEDRON, MBQUAD, MBVERTEX, output, polyg, moab::Interface::query_interface(), moab::Range::size(), test_file_name, moab::Interface::UNION, and moab::Interface::write_file().
// Get MOAB instance
Interface* mb = new( std::nothrow ) Core;
if( NULL == mb ) return 1;
// Need option handling here for input filename
if( argc > 1 )
// User has input a mesh file
test_file_name = argv[1];
if( argc > 2 ) output = argv[2];
if( argc > 3 ) layers = atoi( argv[3] );
if( argc > 4 ) layer_thick = atof( argv[4] );
std::cout << "Run: " << argv[0] << " " << test_file_name << " " << output << " " << layers << " " << layer_thick
<< "\n";
// Load the mesh from vtk file
ErrorCode rval = mb->load_mesh( test_file_name.c_str() );MB_CHK_ERR( rval );
// Get verts entities, by type
Range verts;
rval = mb->get_entities_by_type( 0, MBVERTEX, verts );MB_CHK_ERR( rval );
// Get faces, by dimension, so we stay generic to entity type
Range faces;
rval = mb->get_entities_by_dimension( 0, 2, faces );MB_CHK_ERR( rval );
cout << "Number of vertices is " << verts.size() << endl;
cout << "Number of faces is " << faces.size() << endl;
Range edges;
// create all edges
rval = mb->get_adjacencies( faces, 1, true, edges, Interface::UNION );MB_CHK_ERR( rval );
cout << "Number of edges is " << edges.size() << endl;
std::vector< double > coords;
int nvPerLayer = (int)verts.size();
coords.resize( 3 * nvPerLayer );
rval = mb->get_coords( verts, &coords[0] );MB_CHK_ERR( rval );
// create first vertices
Range* newVerts = new Range[layers + 1];
newVerts[0] = verts; // just for convenience
for( int ii = 0; ii < layers; ii++ )
for( int i = 0; i < nvPerLayer; i++ )
coords[3 * i + 2] += layer_thick;
rval = mb->create_vertices( &coords[0], nvPerLayer, newVerts[ii + 1] );MB_CHK_ERR( rval );
// for each edge, we will create layers quads
int nquads = edges.size() * layers;
ReadUtilIface* read_iface;
rval = mb->query_interface( read_iface );MB_CHK_SET_ERR( rval, "Error in query_interface" );
EntityHandle start_elem, *connect;
// Create quads
rval = read_iface->get_element_connect( nquads, 4, MBQUAD, 0, start_elem, connect );MB_CHK_SET_ERR( rval, "Error in get_element_connect" );
int nedges = (int)edges.size();
int indexConn = 0;
for( int j = 0; j < nedges; j++ )
EntityHandle edge = edges[j];
const EntityHandle* conn2 = NULL;
int num_nodes;
rval = mb->get_connectivity( edge, conn2, num_nodes );MB_CHK_ERR( rval );
if( 2 != num_nodes ) MB_CHK_ERR( MB_FAILURE );
int i0 = verts.index( conn2[0] );
int i1 = verts.index( conn2[1] );
connect[indexConn++] = newVerts[ii][i0];
connect[indexConn++] = newVerts[ii][i1];
connect[indexConn++] = newVerts[ii + 1][i1];
connect[indexConn++] = newVerts[ii + 1][i0];
int nfaces = (int)faces.size();
EntityHandle* allPolygons = new EntityHandle[nfaces * ( layers + 1 )];
for( int i = 0; i < nfaces; i++ )
allPolygons[i] = faces[i];
// vertices are parallel to the base vertices
int indexVerts[MAXEDGES] = { 0 }; // polygons with at most MAXEDGES edges
EntityHandle newConn[MAXEDGES] = { 0 };
EntityHandle polyhedronConn[MAXEDGES + 2] = { 0 };
// edges will be used to determine the lateral faces of polyhedra (prisms)
int indexEdges[MAXEDGES] = { 0 }; // index of edges in base polygon
for( int j = 0; j < nfaces; j++ )
EntityHandle polyg = faces[j];
const EntityHandle* connp = NULL;
int num_nodes;
rval = mb->get_connectivity( polyg, connp, num_nodes );MB_CHK_ERR( rval );
for( int i = 0; i < num_nodes; i++ )
indexVerts[i] = verts.index( connp[i] );
int i1 = ( i + 1 ) % num_nodes;
EntityHandle edgeVerts[2] = { connp[i], connp[i1] };
// get edge adjacent to these vertices
Range adjEdges;
rval = mb->get_adjacencies( edgeVerts, 2, 1, false, adjEdges );MB_CHK_ERR( rval );
if( adjEdges.size() < 1 ) MB_CHK_SET_ERR( MB_FAILURE, " did not find edge " );
indexEdges[i] = edges.index( adjEdges[0] );
if( indexEdges[i] < 0 ) MB_CHK_SET_ERR( MB_FAILURE, "did not find edge in range" );
// create a polygon on each layer
newConn[i] = newVerts[ii + 1][indexVerts[i]]; // vertices in layer ii+1
rval = mb->create_element( MBPOLYGON, newConn, num_nodes, allPolygons[nfaces * ( ii + 1 ) + j] );MB_CHK_ERR( rval );
// now create a polyhedra with top, bottom and lateral swept faces
// first face is the bottom
polyhedronConn[0] = allPolygons[nfaces * ii + j];
// second face is the top
polyhedronConn[1] = allPolygons[nfaces * ( ii + 1 ) + j];
// next add lateral quads, in order of edges, using the start_elem
// first layer of quads has EntityHandle from start_elem to start_elem+nedges-1
// second layer of quads has EntityHandle from start_elem + nedges to
// start_elem+2*nedges-1 ,etc
polyhedronConn[2 + i] = start_elem + ii + layers * indexEdges[i];
// Create polyhedron
EntityHandle polyhedron;
rval = mb->create_element( MBPOLYHEDRON, polyhedronConn, 2 + num_nodes, polyhedron );MB_CHK_ERR( rval );
rval = mb->write_file( output.c_str() );MB_CHK_ERR( rval );
delete mb;
return 0;
| double layer_thick = 1.0 |
| int layers = 1 |
Definition at line 23 of file ExtrudePoly.cpp.
| string output = string( "polyhedra.vtk" ) |
Definition at line 22 of file ExtrudePoly.cpp.
Referenced by main(), vtkMoabReader::RequestData(), test_mesh(), test_none(), test_reflection(), test_rotation(), test_scale(), test_translation(), and moab::WriteHDF5::vector_to_id_list().
| string test_file_name = string( MESH_DIR ) + string( "/io/poly8-10.vtk" ) |
Definition at line 21 of file ExtrudePoly.cpp.
