MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** @example TestErrorHandlingPar.cpp \n 00002 * Description: This example tests MOAB's trace back error handler in parallel.\n 00003 * 00004 * <b>To run</b>: mpiexec -np <n> ./TestErrorHandlingPar <test_case_num(1 to 2)> \n 00005 */ 00006 00007 #include "moab/Core.hpp" 00008 #ifdef MOAB_HAVE_MPI 00009 #include "moab_mpi.h" 00010 #endif 00011 00012 #include <iostream> 00013 00014 using namespace moab; 00015 using namespace std; 00016 00017 // In this test case, a global fatal error MB_NOT_IMPLEMENTED is returned by MOAB 00018 // Note, it is printed by root processor 0 only 00019 ErrorCode TestErrorHandlingPar_1() 00020 { 00021 Core moab; 00022 Interface& mb = moab; 00023 00024 string opts = ";;"; 00025 #ifdef MOAB_HAVE_MPI 00026 // Use parallel options 00027 opts += "PARALLEL=READ_PART;PARTITION_METHOD=SQIJ"; 00028 #endif 00029 00030 // Load a CAM-FV file and read a variable on edges (not supported yet) 00031 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); 00032 opts += ";VARIABLE=US"; 00033 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, opts.c_str() );MB_CHK_ERR( rval ); 00034 00035 return MB_SUCCESS; 00036 } 00037 00038 // In this test case, a per-processor relevant error MB_FAILURE is returned by MOAB 00039 // Note, it is printed by all processors 00040 ErrorCode TestErrorHandlingPar_2() 00041 { 00042 Core moab; 00043 Interface& mb = moab; 00044 00045 string opts = ";;"; 00046 #ifdef MOAB_HAVE_MPI 00047 // Use parallel options 00048 opts += "PARALLEL=READ_PART;PARTITION_METHOD=UNKNOWN"; 00049 #endif 00050 00051 // Load a CAM-FV file with an unknown partition method specified 00052 string test_file = string( MESH_DIR ) + string( "/io/fv3x46x72.t.3.nc" ); 00053 opts += ";VARIABLE=T"; 00054 ErrorCode rval = mb.load_file( test_file.c_str(), NULL, opts.c_str() );MB_CHK_ERR( rval ); 00055 00056 return MB_SUCCESS; 00057 } 00058 00059 int main( int argc, char** argv ) 00060 { 00061 if( argc < 2 ) 00062 { 00063 cout << "Usage: " << argv[0] << " <test_case_num(1 to 2>" << endl; 00064 return 0; 00065 } 00066 00067 #ifdef MOAB_HAVE_MPI 00068 MPI_Init( &argc, &argv ); 00069 #endif 00070 00071 // Initialize error handler, optional for this example (using moab instances) 00072 MBErrorHandler_Init(); 00073 00074 ErrorCode rval = MB_SUCCESS; 00075 00076 int test_case_num = atoi( argv[1] ); 00077 switch( test_case_num ) 00078 { 00079 case 1: 00080 rval = TestErrorHandlingPar_1();MB_CHK_ERR( rval ); 00081 break; 00082 case 2: 00083 rval = TestErrorHandlingPar_2();MB_CHK_ERR( rval ); 00084 break; 00085 default: 00086 break; 00087 } 00088 00089 // Finalize error handler, optional for this example (using moab instances) 00090 MBErrorHandler_Finalize(); 00091 00092 #ifdef MOAB_HAVE_MPI 00093 MPI_Finalize(); 00094 #endif 00095 00096 return 0; 00097 }
