MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "iMesh.h"#include "MBiMesh.hpp"#include "moab/Core.hpp"#include "moab/Range.hpp"#include "moab/IntxMesh/Intx2MeshOnSphere.hpp"#include "moab/IntxMesh/IntxUtils.hpp"#include "IntxUtilsCSLAM.hpp"
Include dependency graph for update_tracer.cpp:Go to the source code of this file.
Functions | |
| void | update_tracer (iMesh_Instance instance, iBase_EntitySetHandle imesh_euler_set, int *ierr) |
| void update_tracer | ( | iMesh_Instance | instance, |
| iBase_EntitySetHandle | imesh_euler_set, | ||
| int * | ierr | ||
Definition at line 9 of file update_tracer.cpp.
References moab::Intx2Mesh::create_departure_mesh_2nd_alg(), moab::Core::create_meshset(), moab::debug, moab::IntxUtils::enforce_convexity(), ErrorCode, ERRORV, gtol, moab::Intx2Mesh::intersect_meshes(), mb, MB_CHK_SET_ERR_RET, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MESHSET_SET, MOABI, radius, moab::Intx2Mesh::set_error_tolerance(), moab::Intx2MeshOnSphere::set_radius_destination_mesh(), moab::Intx2MeshOnSphere::set_radius_source_mesh(), moab::Core::tag_get_handle(), moab::Intx2MeshOnSphere::update_tracer_data(), and moab::Core::write_file().
using namespace moab;
const double radius = 1.;
const double gtol = 1.e-9;
const bool debug = false;
Range ents;
moab::Interface* mb = MOABI;
*ierr = 1;
EntityHandle euler_set = (EntityHandle)imesh_euler_set;
Intx2MeshOnSphere worker( mb );
worker.set_radius_source_mesh( radius );
worker.set_radius_destination_mesh( radius );
worker.set_error_tolerance( gtol );
EntityHandle covering_lagr_set;
ErrorCode rval = mb->create_meshset( MESHSET_SET, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't create covering set " );
// we need to update the correlation tag and remote tuples
rval = worker.create_departure_mesh_2nd_alg( euler_set, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't populate covering set " );
if( debug )
rval = mb->write_file( "lagr.h5m", 0, 0, &covering_lagr_set, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
// enforce convexity for the set
rval = moab::IntxUtils::enforce_convexity( mb, covering_lagr_set );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
EntityHandle outputSet;
rval = mb->create_meshset( MESHSET_SET, outputSet );MB_CHK_SET_ERR_RET( rval, "can't create output set " );
rval = worker.intersect_meshes( covering_lagr_set, euler_set, outputSet );MB_CHK_SET_ERR_RET( rval, "can't intersect " );
if( debug )
rval = mb->write_file( "output.vtk", 0, 0, &outputSet, 1 );MB_CHK_SET_ERR_RET( rval, "can't write covering set " );
// tagElem is the average computed at each element, from nodal values
Tag tagElem = 0;
std::string tag_name2( "TracerAverage" );
rval = mb->tag_get_handle( tag_name2.c_str(), 1, MB_TYPE_DOUBLE, tagElem, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get tracer tag " );
// area of the euler element is fixed, store it; it is used to recompute the averages at each
// time step
Tag tagArea = 0;
std::string tag_name4( "Area" );
rval = mb->tag_get_handle( tag_name4.c_str(), 1, MB_TYPE_DOUBLE, tagArea, MB_TAG_DENSE | MB_TAG_CREAT );MB_CHK_SET_ERR_RET( rval, "can't get area tag" );
rval = worker.update_tracer_data( outputSet, tagElem, tagArea );MB_CHK_SET_ERR_RET( rval, "can't update tracer " );
// everything can be deleted now from intx data; polygons, etc.
*ierr = 0;
return;
