MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/MOABConfig.h"#include "moab_mpi.h"#include "moab/iMOAB.h"#include <cstdio>#include <cstring>#include <vector>
Include dependency graph for imoab_ptest2.cpp:Go to the source code of this file.
Defines | |
| #define | ERROR(rc, msg) |
Functions | |
| int | main (int argc, char **argv) |
| #define ERROR | ( | rc, | |
| msg | |||
if( 0 != ( rc ) ) \ { \ printf( "error %s", msg ); \ return 1; \ }
Definition at line 72 of file imoab_ptest2.cpp.
Referenced by main().
| int main | ( | int | argc, |
| char ** | argv | ||
Definition at line 79 of file imoab_ptest2.cpp.
References DENSE_DOUBLE, DENSE_INTEGER, ErrCode, ERROR, iMOAB_AppID, iMOAB_CreateElements(), iMOAB_CreateVertices(), iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_DetermineGhostEntities(), iMOAB_Finalize(), iMOAB_Initialize(), iMOAB_ReduceTagsMax(), iMOAB_RegisterApplication(), iMOAB_ResolveSharedEntities(), iMOAB_SetDoubleTagStorage(), iMOAB_SetIntTagStorage(), iMOAB_WriteMesh(), MPI_COMM_WORLD, and outfile.
int my_id, num_procs, ix, iy, numv, nume;
int dime, lco, mbtype, blockid, npe;
char appname[10] = "IMTEST";
/* coordinates for 9 vertices */
double coordinates[27], deltax, deltay;
int ids[9] = { 1, 2, 3, 6, 7, 8, 11, 12, 13 };
int connec[16] = { 1, 2, 5, 4, 2, 3, 6, 5, 4, 5, 8, 7, 5, 6, 9, 8 };
/* used for ghosting */
int dimgh, bridge, num_layers;
double coords_core[27] = { 0., 0., 0., 0., 1., 0., 0., 2., 0., 1., 0., 0., 1., 1.,
0., 1., 2., 0., 2., 0., 0., 2., 1., 0., 2., 2., 0. };
int appID, compid;
iMOAB_AppID pid = &appID;
MPI_Init( &argc, &argv );
MPI_Comm comm = MPI_COMM_WORLD;
MPI_Comm_size( comm, &num_procs );
MPI_Comm_rank( comm, &my_id );
ErrCode rc = iMOAB_Initialize( argc, argv );
ERROR( rc, "can't initialize" );
if( !my_id ) printf( " I'm process %d out of %d\n", my_id, num_procs );
appname[7] = 0; // make sure it is NULL
compid = 8; // given number, external application number
rc = iMOAB_RegisterApplication( appname, &comm, &compid, pid );
ERROR( rc, " can't register app" );
/* create first 9 vertices, in a square 3x3; */
deltax = ( my_id / 2 ) * 2.;
deltay = ( my_id % 2 ) * 2.;
ix = ( my_id / 2 ) * 10;
iy = my_id % 2 * 2;
for( int i = 0; i < 9; i++ )
coordinates[3 * i] = coords_core[3 * i] + deltax;
coordinates[3 * i + 1] = coords_core[3 * i + 1] + deltay;
coordinates[3 * i + 2] = coords_core[3 * i + 2];
/* translate the ids too, by multiples of 10 or add 2, depending on my_id*/
ids[i] = ids[i] + ix + iy;
numv = 9;
nume = 4;
lco = numv * 3;
dime = 3;
rc = iMOAB_CreateVertices( pid, &lco, &dime, coordinates );
ERROR( rc, "can't create vertices" );
/* create now 4 quads with those 9 vertices*/
mbtype = 3;
blockid = 100;
npe = 4;
rc = iMOAB_CreateElements( pid, &nume, &mbtype, &npe, connec, &blockid );
ERROR( rc, "can't create elements" );
rc = iMOAB_ResolveSharedEntities( pid, &numv, ids );
ERROR( rc, "can't resolve shared ents" );
// test iMOAB_ReduceTagsMax on a tag
int tagType = DENSE_DOUBLE;
int num_components = 1;
int tagIndex = 0; // output
rc = iMOAB_DefineTagStorage( pid, "afrac:ifrac", &tagType, &num_components, &tagIndex );
ERROR( rc, "failed to create tags afrac:ifrac " );
double af[4] = {1.,1.,1.,1.};
int entType = 1; // cells
rc = iMOAB_SetDoubleTagStorage( pid, "afrac", &nume, &entType, af);
ERROR( rc, "failed to set tag afrac " );
/* write out the mesh file to disk, in parallel, if h5m*/
#ifdef MOAB_HAVE_HDF5_PARALLEL
char wopts[100] = "PARALLEL=WRITE_PART";
char outfile[32] = "whole.h5m";
rc = iMOAB_WriteMesh( pid, outfile, wopts );
ERROR( rc, "can't write mesh" );
#endif
// define repeat tags
rc = iMOAB_DefineTagStorage( pid, "ofrac:afrac:ofrad", &tagType, &num_components, &tagIndex );
ERROR( rc, "failed to create tags ofrac:afrac:ofrad " );
// write again
ERROR( rc, "can't write mesh 3\n" );
#endif
tagType = DENSE_INTEGER;
rc = iMOAB_DefineTagStorage( pid, "INTFIELD", &tagType, &num_components, &tagIndex );
ERROR( rc, "failed to get tag INTFIELD " );
// set some values
std::vector< int > valstest( numv );
for( int k = 0; k < numv; k++ )
valstest[k] = my_id + k;
int num_tag_storage_length = numv * num_components;
entType = 0; // vertex
// create an integer tag
rc = iMOAB_SetIntTagStorage( pid, "INTFIELD", &num_tag_storage_length, &entType, &valstest[0] );
ERROR( rc, "failed to set tag INTFIELD " );
rc = iMOAB_ReduceTagsMax( pid, &tagIndex, &entType );
ERROR( rc, "failed reduce tags max " );
/* see ghost elements */
dimgh = 2; /* will ghost quads, topological dim 2 */
bridge = 0; /* use vertex as bridge */
num_layers = 1; /* so far, one layer only */
rc = iMOAB_DetermineGhostEntities( pid, &dimgh, &num_layers, &bridge );
ERROR( rc, "can't determine ghosts" );
#endif
/* all done. de-register and finalize */
rc = iMOAB_DeregisterApplication( pid );
ERROR( rc, "can't de-register app" );
rc = iMOAB_Finalize();
ERROR( rc, "can't finalize" );
MPI_Finalize();
return 0;
