testc_cbind.cpp File Reference
#include <cstdio>
#include <cstring>
#include <cstdlib>
#include "iMesh.h"
#include "iMesh_extensions.h"
#include "moab/Types.hpp"
#include "TestUtil.hpp"
+ Include dependency graph for testc_cbind.cpp:
Classes
struct  TagStruct
Defines
#define FALSE   0
#define TRUE   1
#define DEFAULT_TEST_FILE   brick.vtk
#define DEFAULT_INPUT_FILE   STRINGIFY( DEFAULT_TEST_FILE )
#define ASSERT(COND)
#define CHK(err)
#define TEST_ERROR_CODE(A, B)
Functions
void PRINT_ASSERT_FAILURE (const char *cond, const char *file, int line)
void handle_error_code (const int result, int *number_failed, int *, int *number_successful)
int load_mesh_test (const char *filename, iMesh_Instance mesh)
int error_code_test (iMesh_Instance)
int topology_dimension_test (iMesh_Instance mesh)
int topology_adjacency_test (iMesh_Instance mesh)
int qsort_comp_handles (const void *h1, const void *h2)
int entity_connectivity_test (iMesh_Instance mesh)
int check_esets (iMesh_Instance mesh, const int num_sets)
int entity_sets_subtest (iMesh_Instance mesh, int is_list, int)
int entity_sets_test (iMesh_Instance mesh)
int vertex_coordinates_test (iMesh_Instance mesh)
int tag_info_test (iMesh_Instance mesh)
int vertex_int_tag_test (iMesh_Instance mesh, iBase_EntityHandle *verts, int, iBase_TagHandle *int_tag)
int vertex_double_tag_test (iMesh_Instance mesh, iBase_EntityHandle *verts, int, iBase_TagHandle *double_tag)
int vertex_struct_tag_test (iMesh_Instance mesh, iBase_EntityHandle *verts, int, iBase_TagHandle *struct_tag)
int vertex_tag_delete_test (iMesh_Instance mesh, iBase_EntityHandle *verts, int)
int vertex_tag_test (iMesh_Instance mesh)
int entityset_int_tag_test (iMesh_Instance mesh, iBase_EntitySetHandle *sets, int sets_size, iBase_TagHandle *int_tag)
int entityset_double_tag_test (iMesh_Instance mesh, iBase_EntitySetHandle *sets, int sets_size, iBase_TagHandle *double_tag)
int entityset_struct_tag_test (iMesh_Instance mesh, iBase_EntitySetHandle *, int, iBase_TagHandle *struct_tag)
int entityset_tag_delete_test (iMesh_Instance mesh, iBase_EntitySetHandle *sets, int sets_size)
int entityset_tag_test (iMesh_Instance mesh)
int mesh_int_tag_test (iMesh_Instance mesh, iBase_TagHandle *int_tag)
int mesh_double_tag_test (iMesh_Instance mesh, iBase_TagHandle *double_tag)
int mesh_struct_tag_test (iMesh_Instance mesh, iBase_TagHandle *struct_tag)
int mesh_tag_delete_test (iMesh_Instance mesh)
int mesh_tag_test (iMesh_Instance mesh)
int set_remove_contained_regression (iMesh_Instance mesh)
int all_adjacency_regression (iMesh_Instance mesh)
static int ordered_set_regression (iMesh_Instance mesh)
int array_allocation (iMesh_Instance mesh)
int compare_single_iter (const char *info, iMesh_Instance mesh, iBase_EntitySetHandle set, iBase_EntityHandle *contents, int contents_size, enum iBase_EntityType type, enum iMesh_EntityTopology topo)
int compare_array_iter (const char *info, iMesh_Instance mesh, iBase_EntitySetHandle set, iBase_EntityHandle *contents, int contents_size, int array_size, enum iBase_EntityType type, enum iMesh_EntityTopology topo)
int test_iterator_common (const char *info, iMesh_Instance mesh, iBase_EntitySetHandle set, int array_size, enum iBase_EntityType type, enum iMesh_EntityTopology topo)
int test_iterator (iMesh_Instance mesh)
int main (int argc, char *argv[])
Variables
enum iBase_ErrorType iBase_ERROR_MAP [MB_FAILURE+1]
static bool assert_pass
static iBase_EntitySetHandle root_set
Define Documentation
#define ASSERT (   COND)
Value:
assert_pass = true;                                    \
    if( !( COND ) )                                        \
        PRINT_ASSERT_FAILURE( #COND, __FILE__, __LINE__ ); \
        assert_pass = false;                               \
Definition at line 82 of file testc_cbind.cpp.
Referenced by entity_connectivity_test().
#define CHK (   err)
Value:
if( (err) != iBase_SUCCESS ) do                                        \
            printf( "%s:%d ITAPS error %d\n", __FILE__, __LINE__, err ); \
            return 0;                                                    \
    } while( 0 )
Definition at line 96 of file testc_cbind.cpp.
Referenced by array_allocation(), ordered_set_regression(), test_iterator(), and test_iterator_common().
Definition at line 78 of file testc_cbind.cpp.
Referenced by main().
Definition at line 71 of file testc_cbind.cpp.
#define TEST_ERROR_CODE (   A,
  B
Value:
if( iBase_ERROR_MAP[( A )] != ( B ) )                                                        \
        printf( "ERROR: Invalid mapping for MOAB error code %s\n", #A );                         \
        printf( "       Expected %d, actual is %d\n", (int)iBase_ERROR_MAP[( A )], (int)( B ) ); \
        return FALSE;        \
Definition at line 143 of file testc_cbind.cpp.
Referenced by error_code_test().
Function Documentation
Definition at line 2659 of file testc_cbind.cpp.
References iBase_ALL_TYPES, iBase_INTERLEAVED, iBase_NEW, iBase_SUCCESS, iMesh_createEnt, iMesh_createVtxArr, iMesh_dtor, iMesh_getEntAdj, iMesh_LINE_SEGMENT, and iMesh_newMesh.
    int err;
    double coords[] = { 0, 0, 0, 1, 1, 1 };
    iBase_EntityHandle* verts = NULL;
    int verts_alloc           = 0, verts_size;
    iBase_EntityHandle line;
    int status;
    iBase_EntityHandle* adj = NULL;
    int adj_alloc           = 0, adj_size;
    iMesh_newMesh( "", &mesh, &err, 0 );
    if( iBase_SUCCESS != err ) return 0;
    iMesh_createVtxArr( mesh, 2, iBase_INTERLEAVED, coords, 6, &verts, &verts_alloc, &verts_size, &err );
    iMesh_createEnt( mesh, iMesh_LINE_SEGMENT, verts, 2, &line, &status, &err );
    if( iBase_SUCCESS != err || status != iBase_NEW ) return 0;
    iMesh_getEntAdj( mesh, verts[0], iBase_ALL_TYPES, &adj, &adj_alloc, &adj_size, &err );
    if( adj_size != 1 || adj[0] != line )
        printf( "Bad: couldn't find adjacency for vertex\n" );
        return 0;
    free( adj );
    adj_alloc = 0;
    adj       = NULL;
    iMesh_getEntAdj( mesh, line, iBase_ALL_TYPES, &adj, &adj_alloc, &adj_size, &err );
    if( adj_size != 2 ||
        ( ( adj[0] != verts[0] || adj[1] != verts[1] ) && ( adj[0] != verts[1] || adj[1] != verts[0] ) ) )
        printf( "Bad: couldn't find adjacencies for line\n" );
        free( adj );
        free( verts );
        return 0;
    free( adj );
    free( verts );
    iMesh_dtor( mesh, &err );
    return 1;
Definition at line 2749 of file testc_cbind.cpp.
References CHK, iBase_ALL_TYPES, iBase_BAD_ARRAY_DIMENSION, iBase_BAD_ARRAY_SIZE, iBase_FAILURE, iBase_INTERLEAVED, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_createVtxArr, iMesh_dtor, iMesh_getEntities, iMesh_getRootSet, iMesh_newMesh, and root_set.
    int err;
    double coords[] = { 0, 0, 0, 1, 1, 1, 2, 2, 2, 3, 3, 3 };
    iBase_EntityHandle* ents;
    int ents_alloc, ents_size;
    iMesh_getRootSet( mesh, &root_set, &err );
        printf( "Failed to return a root set.\n" );
        return 0;
    iMesh_createVtxArr( mesh, 4, iBase_INTERLEAVED, coords, 12, &verts, &verts_alloc, &verts_size, &err );
    free( verts );
    /* test for proper allocation when array pointer passed in null but alloc'd size not */
    ents_alloc = 3;
    ents       = NULL;
    iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &ents, &ents_alloc, &ents_size, &err );
    CHK( err );
    free( ents );
    /* test for proper allocation when array pointer passed in non-null but alloc'd size 0 */
    ents_alloc = 0;
    CHK( err );
    free( ents );
    /* test for failure when passed in alloc'd size is smaller than it should be */
    ents_alloc -= 1;
    if( iBase_BAD_ARRAY_SIZE != err && iBase_BAD_ARRAY_DIMENSION != err )
        err = iBase_FAILURE;
        CHK( err );
    CHK( err );
    return 1;
int check_esets ( iMesh_Instance  mesh,
const int  num_sets
Test:
TSTT entity sets sub test
  • Check entity sets
Definition at line 1623 of file testc_cbind.cpp.
References FALSE, iBase_SUCCESS, iMesh_getNumEntSets, root_set, and TRUE.
Referenced by entity_sets_subtest(), and mb_mesh_sets_test().
    int entity_sets_size;
    int result;
    iMesh_getNumEntSets( mesh, root_set, 1, &entity_sets_size, &result );
    if( iBase_SUCCESS != result )
        printf( "Problem to get all entity sets in mesh.\n" );
        return FALSE;
    if( entity_sets_size != num_sets )
        printf( "the number of entity sets in whole mesh should be %d"
                ", actual number is %d.\n",
                num_sets, entity_sets_size );
        return FALSE;
    return TRUE;
int compare_array_iter ( const char *  info,
iBase_EntityHandle *  contents,
int  contents_size,
int  array_size,
Definition at line 2893 of file testc_cbind.cpp.
References iBase_FAILURE, iBase_SUCCESS, iMesh_endEntArrIter, iMesh_getNextEntArrIter, iMesh_initEntArrIter, and iMesh_resetEntArrIter.
Referenced by test_iterator_common().
    iBase_EntityArrIterator iter = 0;
    int i, j, twice, has_data, result = iBase_SUCCESS, result2;
    iBase_EntityHandle* values;
    int values_size, values_alloc = array_size;
    values = (iBase_EntityHandle*)malloc( array_size * sizeof( iBase_EntityHandle ) );
    iMesh_initEntArrIter( mesh, set, type, topo, array_size, 0, &iter, &result );
        printf( "%s:%d: Error %d initializing %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
                info, (int)type, (int)topo );
        free( values );
        return result;
    for( twice = 0; twice < 2; ++twice )
        i = 0;
        while( i < contents_size )
            iMesh_getNextEntArrIter( mesh, iter, &values, &values_alloc, &values_size, &has_data, &result );
                printf( "%s:%d: Error %d stepping %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
                goto end_arr_iter;
            if( !has_data || !values_size )
                printf( "%s:%d: %s array iterator for type %d/topo %d ended prematurely at %d of %d\n", __FILE__,
                        __LINE__, info, (int)type, (int)topo, i, contents_size );
                result = iBase_FAILURE;
                goto end_arr_iter;
            if( i + values_size > contents_size )
                printf( "%s:%d: %s array iterator for type %d/topo %d returned more than %d handles\n", __FILE__,
                        __LINE__, info, (int)type, (int)topo, contents_size );
                goto end_arr_iter;
            if( contents_size - i >= array_size && values_size < array_size )
                printf( "%s:%d: %s array iterator for type %d/topo %d returned fewer than %d handles\n", __FILE__,
                        __LINE__, info, (int)type, (int)topo, array_size );
                goto end_arr_iter;
            for( j = 0; j < values_size; ++j, ++i )
                if( values[j] != contents[i] )
                    printf( "%s:%d: %s array iterator for type %d/topo %d returned incorrect value "
                            "at %d of %d\n",
                            __FILE__, __LINE__, info, (int)type, (int)topo, i, contents_size );
                    goto end_arr_iter;
            goto end_arr_iter;
        if( has_data || values_size )
            printf( "%s:%d: %s array iterator for type %d/topo %d did not end after %d values\n", __FILE__, __LINE__,
            goto end_arr_iter;
        iMesh_resetEntArrIter( mesh, iter, &result );
            printf( "%s:%d: Error %d resetting %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result,
            goto end_arr_iter;
end_arr_iter:
    free( values );
    iMesh_endEntArrIter( mesh, iter, &result2 );
    if( iBase_SUCCESS != result2 )
        printf( "%s:%d: Error %d releasing %s array iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
        if( iBase_SUCCESS == result ) result = result2;
    return result;
int compare_single_iter ( const char *  info,
int  contents_size,
Definition at line 2806 of file testc_cbind.cpp.
References iBase_FAILURE, iBase_SUCCESS, iMesh_endEntIter, iMesh_getNextEntIter, iMesh_initEntIter, and iMesh_resetEntIter.
    iBase_EntityIterator iter = 0;
    int i, twice, has_data, result = iBase_SUCCESS, result2;
    iBase_EntityHandle value;
    iMesh_initEntIter( mesh, set, type, topo, 0, &iter, &result );
        printf( "%s:%d: Error %d initializing %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
        return result;
        for( i = 0; i < contents_size; ++i )
            iMesh_getNextEntIter( mesh, iter, &value, &has_data, &result );
                printf( "%s:%d: Error %d stepping %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
                goto end_single_iter;
            if( !has_data )
                printf( "%s:%d: %s iterator for type %d/topo %d ended prematurely at %d of %d\n", __FILE__, __LINE__,
            if( value != contents[i] )
                printf( "%s:%d: %s iterator for type %d/topo %d returned incorrect value at %d of %d\n", __FILE__,
        if( has_data )
            printf( "%s:%d: %s iterator for type %d/topo %d did not end after %d values\n", __FILE__, __LINE__, info,
        iMesh_resetEntIter( mesh, iter, &result );
            printf( "%s:%d: Error %d resetting %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
end_single_iter:
    iMesh_endEntIter( mesh, iter, &result2 );
        printf( "%s:%d: Error %d releasing %s iterator for type %d/topo %d\n", __FILE__, __LINE__, result, info,
    return result;
Test:
TSTT EntityType Connectivity Test
  • Get coordinates for all type enities
Definition at line 514 of file testc_cbind.cpp.
References ASSERT, assert_pass, entities, FALSE, iBase_ALL_TYPES, iBase_EDGE, iBase_SUCCESS, iBase_VERTEX, iMesh_ALL_TOPOLOGIES, iMesh_getAdjEntIndices, iMesh_getEntAdj, iMesh_getEntities, qsort_comp_handles(), root_set, size, and TRUE.
    int type, result;
    int *offsets, offsets_alloc, offsets_size;
    int *indices, indices_alloc, indices_size;
    iBase_EntityHandle *entities, *adj_ents, *entities2, *sorted;
    int entities_alloc, entities_size, adj_ents_alloc, adj_ents_size;
    int entities2_alloc, entities2_size;
    iBase_EntityHandle adj_ents2[27], *adj_ents2_ptr = adj_ents2;
    int adj_ents2_alloc = 27, adj_ents2_size, i, size;
    for( type = iBase_EDGE; type < iBase_ALL_TYPES; type++ )
        entities       = NULL;
        entities_alloc = 0;
        adj_ents       = NULL;
        adj_ents_alloc = 0;
        indices        = NULL;
        indices_alloc  = 0;
        offsets        = NULL;
        offsets_alloc  = 0;
        iMesh_getAdjEntIndices( mesh, root_set, type, iMesh_ALL_TOPOLOGIES, iBase_VERTEX, &entities, &entities_alloc,
                                &entities_size, &adj_ents, &adj_ents_alloc, &adj_ents_size, &indices, &indices_alloc,
                                &indices_size, &offsets, &offsets_alloc, &offsets_size, &result );
            printf( "Failed to get indices of vertices in connectivity_test, type=%d.\n", type );
            return FALSE;
        if( entities_alloc != entities_size )
            printf( "Number of entities didn't agree with array size in connectivity_test.\n" );
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        if( offsets_alloc != offsets_size )
            printf( "Number of offsets didn't agree with array size in connectivity_test.\n" );
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        if( indices_alloc != indices_size )
            printf( "Number of indices didn't agree with array size in connectivity_test.\n" );
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        if( adj_ents_alloc != adj_ents_size )
            printf( "Number of adjacent entities didn't agree with array size in "
                    "connectivity_test.\n" );
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        if( offsets_size != entities_size + 1 )
            printf( "Invalid/inconsistent offset size from iMesh_getAdjEntIndices.\n" );
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        /* check that results are valid */
        for( i = 0; i < entities_size; ++i )
            ASSERT( offsets[i] < offsets[i + 1] && offsets[i] < indices_size );
            if( !assert_pass )
                free( entities );
                free( adj_ents );
                free( indices );
                free( offsets );
                return FALSE;
        for( i = 0; i < indices_size; ++i )
            ASSERT( indices[i] >= 0 && indices[i] < adj_ents_size );
            if( !assert_pass )
                free( entities );
                free( adj_ents );
                free( indices );
                free( offsets );
                return FALSE;
        /* compare initial entity list against result of iMesh_getEntities */
        entities2       = NULL;
        entities2_alloc = 0;
        iMesh_getEntities( mesh, root_set, type, iMesh_ALL_TOPOLOGIES, &entities2, &entities2_alloc, &entities2_size,
                           &result );
        ASSERT( iBase_SUCCESS == result );
        if( !assert_pass )
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            return FALSE;
        size   = sizeof( iBase_EntityHandle ) * entities_size;
        sorted = (iBase_EntityHandle*)malloc( size );
        memcpy( sorted, entities, size );
        qsort( sorted, entities_size, sizeof( iBase_EntityHandle ), &qsort_comp_handles );
        qsort( entities2, entities2_size, sizeof( iBase_EntityHandle ), &qsort_comp_handles );
        ASSERT( entities_size == entities2_size && !memcmp( sorted, entities2, size ) );
        if( !assert_pass )
            free( entities );
            free( adj_ents );
            free( indices );
            free( offsets );
            free( entities2 );
            free( sorted );
            return FALSE;
        free( entities2 );
        free( sorted );
        /* compare results against output of iMesh_getEntAdj */
            iMesh_getEntAdj( mesh, entities[i], iBase_VERTEX, &adj_ents2_ptr, &adj_ents2_alloc, &adj_ents2_size,
                             &result );
            if( !assert_pass )
                free( entities );
                free( adj_ents );
                free( indices );
                free( offsets );
                return FALSE;
            ASSERT( adj_ents2_ptr == adj_ents2 ); /* shouldn't change */
            if( !assert_pass )
                free( entities );
                free( adj_ents );
                free( indices );
                free( offsets );
                return FALSE;
            ASSERT( adj_ents2_alloc == 27 ); /* shouldn't change */
            if( !assert_pass )
                free( entities );
                free( adj_ents );
                free( indices );
                free( offsets );
                return FALSE;
            /* compare results */
            size = offsets[i + 1] - offsets[i];
            ASSERT( size == adj_ents2_size );
            while( --size >= 0 )
                ASSERT( adj_ents2[size] == adj_ents[indices[offsets[i] + size]] );
                if( !assert_pass )
                    free( entities );
                    free( adj_ents );
                    free( indices );
                    free( offsets );
                    return FALSE;
        free( entities );
        free( adj_ents );
        free( indices );
        free( offsets );
            offsets = NULL;
            offsets_alloc = 0;
            entities = NULL;
            entities_alloc = 0;
            iMesh_getAdjEntities(mesh, root_set, type,
                                 &entities, &entities_alloc, &entities_size,
                                 &result);
            if (iBase_SUCCESS != result) {
              printf("Failed to get indices of adjacent entity vertices in connectivity_test.\n");
              return FALSE;
            if (entities_alloc != entities_size ||
                offsets_alloc != offsets_size) {
              printf("Number of elements didn't agree with array size for an array in
           connectivity_test.\n"); return FALSE;
            free(offsets);
            free(entities);
    return TRUE;
int entity_sets_subtest ( iMesh_Instance  mesh,
int  is_list,
int
Definition at line 754 of file testc_cbind.cpp.
References check_esets(), entities, FALSE, iBase_ALL_TYPES, iBase_EDGE, iBase_FACE, iBase_REGION, iBase_SUCCESS, iBase_VERTEX, iMesh_addEntArrToSet, iMesh_addEntSet, iMesh_addPrntChld, iMesh_ALL_TOPOLOGIES, iMesh_createEntSet, iMesh_destroyEntSet, iMesh_getEntArrAdj, iMesh_getEntArrType, iMesh_getEntities, iMesh_getEntSets, iMesh_getNumChld, iMesh_getNumEntSets, iMesh_getNumOfType, iMesh_getPrnts, iMesh_HEXAHEDRON, iMesh_intersect, iMesh_isChildOf, iMesh_rmvEntArrFromSet, iMesh_subtract, iMesh_unite, root_set, and TRUE.
Referenced by entity_sets_test().
    int i, num_type = iBase_ALL_TYPES - iBase_VERTEX;
    // int num_all_entities_super = 0;
    iBase_EntitySetHandle es_array[iBase_ALL_TYPES - iBase_VERTEX];
    int number_array[iBase_ALL_TYPES - iBase_VERTEX];
    int ent_type                 = iBase_VERTEX;
    iBase_EntityHandle* entities = NULL;
    int entities_alloc           = 0, entities_size;
    iBase_EntitySetHandle parent_child, super_set = NULL;
    iBase_EntitySetHandle temp_es1, temp_es2, temp_es3;
    iBase_EntityHandle *edges = NULL, *faces = NULL, *temp_entities1 = NULL, *temp_entities2 = NULL;
    int edges_alloc = 0, faces_alloc = 0, temp_entities1_alloc = 0, temp_entities2_alloc = 0;
    int edges_size, faces_size, temp_entities1_size, temp_entities2_size;
    int* types      = NULL;
    int types_alloc = 0, types_size;
    int num_rest, num_regions;
    iBase_EntityHandle* regions      = NULL;
    int regions_alloc                = 0, regions_size;
    iBase_EntitySetHandle* parents   = NULL;
    int parents_alloc                = 0, parents_size, temp_numb, is_child;
    iBase_EntitySetHandle* es_array1 = NULL;
    int es_array1_alloc              = 0, es_array1_size, num_super;
    iBase_EntityHandle* all_entities = NULL;
    int all_entities_alloc           = 0, all_entities_size, k, l;
    iBase_EntityHandle* adj_faces    = NULL;
    int adj_faces_alloc              = 0, adj_faces_size;
    int* face_offsets                = NULL;
    int face_offsets_alloc           = 0, face_offsets_size;
    iBase_EntityHandle* hexes        = NULL;
    int hexes_alloc                  = 0, hexes_size;
    iBase_EntitySetHandle hex_set;
    /* get the number of whole mesh */
    int n_whole_mesh = 0;
    int result;
    iMesh_getNumEntSets( mesh, root_set, 1, &n_whole_mesh, &result );
        printf( "Problem to get the number of all entity sets in whole mesh.\n" );
        return FALSE;
    /* add entities to entitysets by type */
    for( ; ent_type < num_type; ent_type++ )
        /* initialize the entityset */
        iMesh_createEntSet( mesh, is_list, &es_array[ent_type], &result );
            printf( "Problem creating entityset.\n" );
            return FALSE;
        /* get entities by type in total "mesh" */
        entities       = NULL;
        entities_alloc = 0;
        iMesh_getEntities( mesh, root_set, ent_type, iMesh_ALL_TOPOLOGIES, &entities, &entities_alloc, &entities_size,
                           &result );
            printf( "Failed to get entities by type in entity_sets_test.\n" );
            return FALSE;
            printf( "Number of entities didn't agree with array size in entity_sets_subtest.\n" );
            free( entities );
            return FALSE;
        /* add entities into entity set */
        if( 0 != entities_size )
            iMesh_addEntArrToSet( mesh, entities, entities_size, es_array[ent_type], &result );
                printf( "Failed to add entities in entity_sets_test.\n" );
                free( entities );
                return FALSE;
        /* Check to make sure entity set really has correct number of entities in it */
        iMesh_getNumOfType( mesh, es_array[ent_type], ent_type, number_array + ent_type, &result );
            printf( "Failed to get number of entities by type in entity_sets_test.\n" );
            free( entities );
            return FALSE;
        /* compare the number of entities by type */
        if( number_array[ent_type] != entities_size )
            printf( "Number of entities by type is not correct\n" );
            free( entities );
            return FALSE;
        /* add to number of all entities in super set */
        // num_all_entities_super += entities_size;
        free( entities );
    if( !check_esets( mesh, n_whole_mesh + num_type ) ) return FALSE;
    /* make a super set having all entitysets */
    super_set = NULL;
    iMesh_createEntSet( mesh, is_list, &super_set, &result );
        printf( "Failed to create a super set in entity_sets_test.\n" );
        return FALSE;
    for( i = 0; i < num_type; i++ )
        iMesh_addEntSet( mesh, es_array[i], super_set, &result );
            printf( "Failed to add a set to a super set in entity_sets_test.\n" );
            return FALSE;
    if( !check_esets( mesh, n_whole_mesh + num_type + 1 ) ) return FALSE;
    /*----------TEST intEAN OPERATIONS----------------*/
    iMesh_createEntSet( mesh, is_list, &temp_es1, &result );
        return FALSE;
    if( !check_esets( mesh, n_whole_mesh + num_type + 2 ) )
        return FALSE;
    /* Subtract */
    /* add all EDGEs and FACEs to temp_es1 */
    /* get all EDGE entities */
    edges       = NULL;
    edges_alloc = 0;
    iMesh_getEntities( mesh, es_array[iBase_EDGE], iBase_EDGE, iMesh_ALL_TOPOLOGIES, &edges, &edges_alloc, &edges_size,
                       &result );
        printf( "Failed to get edge entities in entity_sets_test.\n" );
        return FALSE;
    /* add EDGEs to es1 */
    iMesh_addEntArrToSet( mesh, edges, edges_size, temp_es1, &result );
        printf( "Failed to add edge entities in entity_sets_test.\n" );
        free( edges );
        return FALSE;
    /* get all FACE entities */
    faces       = NULL;
    faces_alloc = 0;
    iMesh_getEntities( mesh, es_array[iBase_FACE], iBase_FACE, iMesh_ALL_TOPOLOGIES, &faces, &faces_alloc, &faces_size,
                       &result );
        printf( "Failed to get face entities in entity_sets_test.\n" );
        free( edges );
        return FALSE;
    /* add FACEs to es1 */
    iMesh_addEntArrToSet( mesh, faces, faces_size, temp_es1, &result );
        printf( "Failed to add face entities in entity_sets_test.\n" );
        free( edges );
        free( faces );
        return FALSE;
    /* subtract EDGEs */
    iMesh_subtract( mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result );
        printf( "Failed to subtract entitysets in entity_sets_test.\n" );
        free( edges );
        free( faces );
        return FALSE;
    temp_entities1       = NULL;
    temp_entities1_alloc = 0;
    iMesh_getEntities( mesh, temp_es2, iBase_FACE, iMesh_ALL_TOPOLOGIES, &temp_entities1, &temp_entities1_alloc,
                       &temp_entities1_size, &result );
        free( edges );
        free( faces );
        return FALSE;
    if( faces_size != temp_entities1_size )
        printf( "not match number of entitysets after subtraction "
                "in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( temp_entities1 );
        return FALSE;
    /* check there's nothing but faces in face_es */
    types       = NULL;
    types_alloc = 0;
    iMesh_getEntArrType( mesh, temp_entities1, temp_entities1_size, &types, &types_alloc, &types_size, &result );
        printf( "Failed to get types of entities in entity_sets_test.\n" );
        free( edges );
        free( faces );
        return FALSE;
    for( i = 0; i < types_size; i++ )
        if( types[i] != iBase_FACE )
            printf( "wrong entity type for face test in entity_sets_test.\n" );
            free( edges );
            free( faces );
            free( types );
            return FALSE;
    iMesh_destroyEntSet( mesh, temp_es2, &result );
        printf( "Failed to destroy temp es2.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /*------------Intersect------------ */
    /* clean out the temp_ms1 */
    iMesh_rmvEntArrFromSet( mesh, faces, faces_size, temp_es1, &result );
        printf( "Failed to remove face entities in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* check if it is really cleaned out */
    iMesh_getNumOfType( mesh, temp_es1, iBase_FACE, &num_rest, &result );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    if( num_rest != 0 )
        printf( "failed to remove correctly.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* add EDGEs to temp es1 */
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* add FACEs to temp es1 */
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* intersect temp_es1 with edges meshset  */
    /* temp_ms1 entityset is altered */
    iMesh_intersect( mesh, temp_es1, es_array[iBase_EDGE], &temp_es2, &result );
        printf( "Failed to intersect in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    iMesh_getEntities( mesh, temp_es2, iBase_FACE, iMesh_ALL_TOPOLOGIES, &temp_entities2, &temp_entities2_alloc,
                       &temp_entities2_size, &result );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    if( temp_entities2_size != 0 )
        printf( "wrong number of faces.\n" );
        free( edges );
        free( faces );
        free( temp_entities2 );
        free( types );
        return FALSE;
        free( edges );
        free( faces );
        free( types );
        return FALSE;
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /*-------------Unite-------------- */
    iMesh_createEntSet( mesh, is_list, &temp_es2, &result );
        printf( "Failed to create a temp entityset in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* get all regions */
    regions       = NULL;
    regions_alloc = 0;
    iMesh_getEntities( mesh, es_array[iBase_REGION], iBase_REGION, iMesh_ALL_TOPOLOGIES, &regions, &regions_alloc,
                       &regions_size, &result );
        printf( "Failed to get region entities in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        return FALSE;
    /* add REGIONs to temp es2 */
    iMesh_addEntArrToSet( mesh, regions, regions_size, temp_es2, &result );
        printf( "Failed to add region entities in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    /* unite temp_es1 and temp_es2 */
    iMesh_unite( mesh, temp_es1, temp_es2, &temp_es3, &result );
        printf( "Failed to unite in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    /* perform the check */
    iMesh_getNumOfType( mesh, temp_es3, iBase_REGION, &num_regions, &result );
        printf( "Failed to get number of region entities by type in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    if( num_regions != number_array[iBase_REGION] )
        printf( "different number of regions in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    if( !check_esets( mesh, n_whole_mesh + num_type + 4 ) )
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    /*--------Test parent/child stuff in entiysets----------- */
    /* Add 2 meshsets as children to another */
    iMesh_createEntSet( mesh, is_list, &parent_child, &result );
        printf( "Problem creating entityset in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    iMesh_addPrntChld( mesh, es_array[iBase_VERTEX], parent_child, &result );
        printf( "Problem add parent in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    /* check if parent is really added */
    parents       = NULL;
    parents_alloc = 0;
    iMesh_getPrnts( mesh, parent_child, 0, &parents, &parents_alloc, &parents_size, &result );
        printf( "Problem getting parents in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        return FALSE;
    if( parents_size != 1 )
        printf( "number of parents is not correct in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    /* get the number of child entitysets */
    iMesh_getNumChld( mesh, es_array[iBase_VERTEX], 0, &temp_numb, &result );
        printf( "Problem getting number of children in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    if( temp_numb != 1 )
        printf( "number of children is not correct in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    /* parent_child and es_array[iBase_VERTEX] should be related */
    is_child = 0;
    iMesh_isChildOf( mesh, es_array[iBase_VERTEX], parent_child, &is_child, &result );
        printf( "Problem checking relation in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    if( !is_child )
        printf( "parent_child and es_array[iBase_VERTEX] should be related\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    /* es_array[iBase_FACE] and es_array[iBase_REGION] are not related */
    is_child = FALSE;
    iMesh_isChildOf( mesh, es_array[iBase_FACE], es_array[iBase_REGION], &is_child, &result );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    if( is_child )
        printf( "es_array[iBase_REGION] and es_array[iBase_FACE] should not be related\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    if( !check_esets( mesh, n_whole_mesh + num_type + 5 ) )
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    /*--------test modify and query functions----------------------------- */
    /* get all entity sets in super set */
    es_array1       = NULL;
    es_array1_alloc = 0;
    iMesh_getEntSets( mesh, super_set, 0, &es_array1, &es_array1_alloc, &es_array1_size, &result );
        printf( "Problem to get entity sets in super set.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        return FALSE;
    /* get the number of entity sets in super set */
    iMesh_getNumEntSets( mesh, super_set, 0, &num_super, &result );
        printf( "Problem to get the number of all entity sets in super set.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        return FALSE;
    /* the number of entity sets in super set should be same */
    if( num_super != es_array1_size )
        printf( "the number of entity sets in super set should be same.\n" );
        return FALSE;
    /* get all entities in super set */
    all_entities_alloc = 0;
    iMesh_getEntities( mesh, super_set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &all_entities, &all_entities_alloc,
                       &all_entities_size, &result );
        printf( "Problem to get all entities in super set.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        return FALSE;
    /* compare the number of all entities in super set */
    /* NOTE: TEST COMMENTED OUT UNTIL RESOLUTION OF WHETHER GETENTITIES */
    /* SHOULD GET A NUM_HOPS ARGUMENT */
    /*  if (num_all_entities_super != all_entities_size) { */
    /*    printf("number of all entities in super set should be same.\n"); */
    /*    return FALSE; */
    /* test add, remove and get all entity sets using super set */
    /* check GetAllEntitySets works recursively and dosen't return */
    /* multi sets */
    for( k = 0; k < num_super; k++ )
        /* add entity sets of super set to each entity set of super set */
        /* make multiple child super sets */
        iBase_EntitySetHandle es_k = es_array1[k];
        for( l = 0; l < es_array1_size; l++ )
            iMesh_addEntSet( mesh, es_array1[l], es_k, &result );
                printf( "Problem to add entity set to entityset.\n" );
                free( edges );
                free( faces );
                free( types );
                free( regions );
                free( parents );
                free( es_array1 );
                free( all_entities );
                return FALSE;
        /* add super set to each entity set */
        iMesh_addEntSet( mesh, super_set, es_k, &result );
            printf( "Problem to add super set to entitysets.\n" );
            free( edges );
            free( faces );
            free( types );
            free( regions );
            free( parents );
            free( es_array1 );
            return FALSE;
        /* add one entity sets multiple times */
        for( l = 0; l < 3; l++ )
            iMesh_addEntSet( mesh, temp_es1, es_k, &result );
                printf( "Problem to add temp set to entitysets.\n" );
                free( edges );
                free( faces );
                free( types );
                free( regions );
                free( parents );
                free( es_array1 );
                return FALSE;
    /* get all hexes and get faces of that hexes */
    hexes       = NULL;
    hexes_alloc = 0;
    iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_HEXAHEDRON, &hexes, &hexes_alloc, &hexes_size, &result );
        printf( "Failed to get hexes in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        return FALSE;
    /* get adjacent face of hexes */
    adj_faces          = NULL;
    adj_faces_alloc    = 0;
    face_offsets_alloc = 0;
    iMesh_getEntArrAdj( mesh, hexes, hexes_size, iBase_FACE, &adj_faces, &adj_faces_alloc, &adj_faces_size,
                        &face_offsets, &face_offsets_alloc, &face_offsets_size, &result );
        printf( "Problem to get adjacent entities in entitysets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        free( hexes );
        return FALSE;
    iMesh_createEntSet( mesh, FALSE, &hex_set, &result );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        free( hexes );
        free( adj_faces );
        free( face_offsets );
        return FALSE;
    iMesh_addEntArrToSet( mesh, hexes, hexes_size, hex_set, &result );
        printf( "Failed to add hexes in entity_sets_test.\n" );
        free( edges );
        free( faces );
        free( types );
        free( regions );
        free( parents );
        free( es_array1 );
        free( hexes );
        free( adj_faces );
        return FALSE;
    free( edges );
    free( faces );
    free( types );
    free( regions );
    free( parents );
    free( es_array1 );
    free( hexes );
    free( adj_faces );
    return TRUE;
Test:
TSTT entity sets Test
  • Check entity sets
Definition at line 1650 of file testc_cbind.cpp.
References entity_sets_subtest(), and TRUE.
    int iter_num = 0, result;
    /* check  */
    int i;
    for( i = 0; i < 2; i++ )
        iter_num++;
        result = entity_sets_subtest( mesh, i, iter_num );
        if( !result ) return result;
    return TRUE;
int entityset_double_tag_test ( iMesh_Instance  mesh,
iBase_EntitySetHandle *  sets,
int  sets_size,
iBase_TagHandle *  double_tag
Definition at line 2156 of file testc_cbind.cpp.
References FALSE, iBase_DOUBLE, iBase_SUCCESS, iMesh_createTag, iMesh_getEntSetData, iMesh_setEntSetData, and TRUE.
Referenced by entityset_tag_test().
    int result;
    double dum_val     = 1.0e6, dum_val2;
    void* dum_val2_ptr = &dum_val2;
    int dum_val2_alloc = sizeof( double ), dum_val2_size;
    /* create a tag */
    const char* tag_name = "set_double_tag";
    iMesh_createTag( mesh, tag_name, 1, iBase_DOUBLE, double_tag, &result, 15 );
        printf( "Failed to create tag double_tag in entityset_double_tag_test.\n" );
        return FALSE;
    /* put a value in the first set and retrieve */
    iMesh_setEntSetData( mesh, sets[0], *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
        printf( "Failed to set double tag (val=11) in entityset_double_tag_test.\n" );
        return FALSE;
    dum_val2 = 0;
    iMesh_getEntSetData( mesh, sets[0], *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get double tag (val=1.0e6) in entityset_double_tag_test." );
        return FALSE;
    if( dum_val2 != 1.0e6 )
        printf( "Value of entityset tag (val=11) wrong.\n" );
        return FALSE;
    /* put a value in the last faces and retrieve */
    dum_val = 2.0e9;
    iMesh_setEntSetData( mesh, sets[sets_size - 1], *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
        printf( "Failed to set double tag (val=2.0e9) in entityset_double_tag_test." );
        return FALSE;
    iMesh_getEntSetData( mesh, sets[sets_size - 1], *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size,
                         &result );
        printf( "Failed to get double tag (val=2.0e9) in entityset_double_tag_test." );
        return FALSE;
    if( dum_val2 != 2.0e9 )
        printf( "Value of entityset tag (val=2.0e9) wrong.\n" );
        return FALSE;
    /* ok, the double tag test worked */
    return TRUE;
int entityset_int_tag_test ( iMesh_Instance  mesh,
int  sets_size,
iBase_TagHandle *  int_tag
Definition at line 2091 of file testc_cbind.cpp.
References FALSE, iBase_INTEGER, iBase_SUCCESS, iMesh_createTag, iMesh_getEntSetData, iMesh_setEntSetData, and TRUE.
    int result;
    int dum_val        = 11, dum_val2;
    int dum_val2_alloc = sizeof( int ), dum_val2_size;
    /* create a tag */
    const char* tag_name = "set_int_tag";
    iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, int_tag, &result, 12 );
        printf( "Failed to create tag int_tag in entityset_int_tag_test.\n" );
        return FALSE;
    iMesh_setEntSetData( mesh, sets[0], *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
        printf( "Failed to set int tag (val=11) in entityset_int_tag_test.\n" );
        return FALSE;
    dum_val2 = 0;
    iMesh_getEntSetData( mesh, sets[0], *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get int tag (val=11) in entityset_int_tag_test." );
        return FALSE;
    if( dum_val2 != 11 )
        return FALSE;
    dum_val = 12;
    iMesh_setEntSetData( mesh, sets[sets_size - 1], *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
        printf( "Failed to set int tag (val=12) in entityset_int_tag_test." );
        return FALSE;
    iMesh_getEntSetData( mesh, sets[sets_size - 1], *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get int tag (val=12) in entityset_int_tag_test." );
        return FALSE;
    if( dum_val2 != 12 )
        printf( "Value of entityset tag (val=12) wrong.\n" );
        return FALSE;
    /* ok, the int tag test worked */
    return TRUE;
int entityset_struct_tag_test ( iMesh_Instance  mesh,
iBase_EntitySetHandle *  ,
int  ,
iBase_TagHandle *  struct_tag
Definition at line 2225 of file testc_cbind.cpp.
References FALSE, iBase_BYTES, iBase_SUCCESS, iMesh_createTag, iMesh_getEntSetData, iMesh_setEntSetData, root_set, and TRUE.
    int result;
    struct TagStruct dum_struct = { 3.0e12, 2, 3 }, dum_struct2;
    void* dum_struct2_ptr       = &dum_struct2;
    int dum_struct_alloc        = sizeof( struct TagStruct ), dum_struct_size;
    /* create a tag */
    const char* tag_name = "set_struct_tag";
    iMesh_createTag( mesh, tag_name, sizeof( struct TagStruct ), iBase_BYTES, struct_tag, &result, 11 );
        printf( "Failed to create tag struct_tag in entityset_struct_tag_test.\n" );
        return FALSE;
    /* put a value in the first vertex and retrieve */
    /* careful setting the value, since tags are opaque */
    iMesh_setEntSetData( mesh, root_set, *struct_tag, (const char*)&dum_struct, sizeof( struct TagStruct ), &result );
        printf( "Failed to set struct tag in entityset_struct_tag_test.\n" );
        return FALSE;
    iMesh_getEntSetData( mesh, root_set, *struct_tag, &dum_struct2_ptr, &dum_struct_alloc, &dum_struct_size, &result );
        printf( "Failed to get struct tag in entityset_struct_tag_test.\n" );
        return FALSE;
    if( dum_struct_size != sizeof( struct TagStruct ) )
        printf( "Size of entityset struct tag wrong.\n" );
        return FALSE;
    if( dum_struct2.test_int1 != dum_struct.test_int1 || dum_struct2.test_int2 != dum_struct.test_int2 ||
        dum_struct2.test_double != dum_struct.test_double )
        printf( "Value of entityset struct tag wrong.\n" );
        return FALSE;
    return TRUE;
int entityset_tag_delete_test ( iMesh_Instance  mesh,
int  sets_size
Definition at line 2277 of file testc_cbind.cpp.
References FALSE, iBase_SUCCESS, iMesh_destroyTag, iMesh_getAllEntSetTags, iMesh_rmvEntSetTag, and TRUE.
    /* test forced, unforced deletion of tags from entities */
    int result;
    int delete_err = FALSE;
    /* test getAlliBase_TagHandles for first entity */
    iBase_TagHandle* all_tags = NULL;
    if( sets_size < 1 )
        printf( "no sets.\n" );
        return FALSE;
    iBase_EntitySetHandle dum_entity = sets[0];
    int all_tags_alloc               = 0, all_tags_size;
    iMesh_getAllEntSetTags( mesh, sets[0], &all_tags, &all_tags_alloc, &all_tags_size, &result );
        printf( "Couldn't get all tag handles from entityset.\n" );
        free( all_tags );
        return FALSE;
    iMesh_rmvEntSetTag( mesh, dum_entity, all_tags[0], &result );
        printf( "Couldn't remove tag from entityset.\n" );
        free( all_tags );
        return FALSE;
    iMesh_destroyTag( mesh, all_tags[1], FALSE, &result );
        delete_err = TRUE;
    if( !delete_err )
        printf( "Error when unforced-deleting tag in use on a entityset.\n" );
        free( all_tags );
        return FALSE;
    iMesh_destroyTag( mesh, all_tags[1], TRUE, &result );
        printf( "Couldn't force-delete a tag in use on a entityset.\n" );
        free( all_tags );
        return FALSE;
    free( all_tags );
    /* ok, we're done */
    return TRUE;
Test:
TSTT entityset tag Test
  • Check entityset tags
Definition at line 2339 of file testc_cbind.cpp.
References entityset_double_tag_test(), entityset_int_tag_test(), entityset_struct_tag_test(), entityset_tag_delete_test(), FALSE, iBase_SUCCESS, iMesh_getEntSets, and root_set.
    int result;
    iBase_TagHandle int_tag, double_tag, struct_tag;
    int int_success, double_success, struct_success, tag_delete_success;
    /* get the sets */
    iBase_EntitySetHandle* esets = NULL;
    int esets_alloc              = 0, esets_size;
    iMesh_getEntSets( mesh, root_set, 1, &esets, &esets_alloc, &esets_size, &result );
        printf( "entitysetGetEntities failed in entityset_tag_test.\n" );
        free( esets );
        return FALSE;
    /* entityset int tag */
    int_success = entityset_int_tag_test( mesh, esets, esets_size, &int_tag );
    /* entityeset double tag */
    double_success = entityset_double_tag_test( mesh, esets, esets_size, &double_tag );
    /* entityset struct tag */
    struct_success = entityset_struct_tag_test( mesh, esets, esets_size, &struct_tag );
    tag_delete_success = entityset_tag_delete_test( mesh, esets, esets_size );
    free( esets );
    return ( int_success && double_success && struct_success && tag_delete_success );
void handle_error_code ( const int  result,
int *  number_failed,
int *  ,
int *  number_successful
prints out a result string based on the value of error_code
Definition at line 110 of file testc_cbind.cpp.
    if( result )
        printf( "Success\n" );
        ( *number_successful )++;
    else
        printf( "Failure\n" );
        ( *number_failed )++;
int load_mesh_test ( const char *  filename,
iMesh_Instance  mesh
Test:
Load Mesh
  • Load a mesh file
Definition at line 129 of file testc_cbind.cpp.
References FALSE, iBase_SUCCESS, iMesh_load, root_set, and TRUE.
    /* load a mesh */
    int result;
    iMesh_load( mesh, root_set, filename, NULL, &result, strlen( filename ), 0 );
        printf( "ERROR : can not load a mesh from file %s\n", filename );
        return FALSE;
    return TRUE;
int main ( int  argc,
char *  argv[]
Definition at line 3093 of file testc_cbind.cpp.
References all_adjacency_regression(), array_allocation(), DEFAULT_INPUT_FILE, entity_connectivity_test(), entity_sets_test(), entityset_tag_test(), error_code_test(), filename, handle_error_code(), iBase_SUCCESS, iMesh_dtor, iMesh_getRootSet, iMesh_newMesh, load_mesh_test(), mesh, mesh_tag_test(), number_tests, number_tests_failed, number_tests_successful, ordered_set_regression(), root_set, set_remove_contained_regression(), test_iterator(), topology_adjacency_test(), topology_dimension_test(), vertex_coordinates_test(), and vertex_tag_test().
    /* Check command line arg */
    const char* filename;
    int number_tests                 = 0;
    int number_tests_successful      = 0;
    int number_tests_not_implemented = 0;
    int number_tests_failed          = 0;
    int result;
    iMesh_Instance mesh = NULL;
    if( argc == 2 )
        filename = argv[1];
    else
        printf( "Usage: %s <mesh_filename>\n", argv[0] );
        if( argc != 1 ) return 1;
        printf( "  No file specified.  Defaulting to: %s\n", DEFAULT_INPUT_FILE );
        filename = DEFAULT_INPUT_FILE;
    /* initialize the Mesh */
    iMesh_newMesh( NULL, &mesh, &result, 0 );
        printf( "Failed to create a mesh instance.\n" );
        return 1;
    iMesh_getRootSet( mesh, &root_set, &result );
        return 1;
    /* Print out Header information */
    printf( "\n\nTSTT TEST PROGRAM:\n\n" );
    /* load_mesh test */
    printf( "   load_mesh: " );
    result = load_mesh_test( filename, mesh );
    handle_error_code( result, &number_tests_failed, &number_tests_not_implemented, &number_tests_successful );
    number_tests++;
    printf( "\n" );
    /* topology_adjacency_test */
    printf( "   topology_adjacency_test: " );
    result = topology_adjacency_test( mesh );
    number_tests++;
    printf( "\n" );
    /* entity connectivity test */
    printf( "   entity_connectivity_test: " );
    result = entity_connectivity_test( mesh );
    number_tests++;
    printf( "\n" );
    /* vertex_coordinates_test */
    printf( "   vertex_coordinates_test: " );
    result = vertex_coordinates_test( mesh );
    number_tests++;
    printf( "\n" );
    /* topology dimension test */
    printf( "   topology_dimension_test: " );
    result = topology_dimension_test( mesh );
    number_tests++;
    printf( "\n" );
    /* entity sets test */
    printf( "   entity_sets_test: " );
    result = entity_sets_test( mesh );
    number_tests++;
    printf( "\n" );
    /* vertex tag test */
    printf( "   vertex_tag_test: " );
    result = vertex_tag_test( mesh );
    number_tests++;
    printf( "\n" );
    /* entityset tag test */
    printf( "   entityset_tag_test: " );
    result = entityset_tag_test( mesh );
    number_tests++;
    printf( "\n" );
    /* mesh tag test */
    printf( "   mesh_tag_test: " );
    result = mesh_tag_test( mesh );
    number_tests++;
    printf( "\n" );
    /* iterator test */
    printf( "   test_iterator: " );
    result = test_iterator( mesh );
    number_tests++;
    printf( "\n" );
    /* regression test for remove/contained bug */
    printf( "   set_remove_contained_regression: " );
    result = set_remove_contained_regression( mesh );
    number_tests++;
    printf( "\n" );
    /* regression test for adjacencies with iBase_ALL_TYPES bug */
    printf( "   all_adjacency_regression: " );
    result = all_adjacency_regression( mesh );
    number_tests++;
    printf( "\n" );
    /* test for error codes */
    printf( "   error_code_test: " );
    result = error_code_test( mesh );
    number_tests++;
    printf( "\n" );
    /* regression test for ordered sets not preserving order */
    printf( "   ordered_set_regression: " );
    result = ordered_set_regression( mesh );
    number_tests++;
    printf( "\n" );
    /* test for array allocation behavior */
    printf( "   array_allocation_regression: " );
    result = array_allocation( mesh );
    number_tests++;
    printf( "\n" );
    /* summary */
    printf( "\nTSTT TEST SUMMARY: \n" );
    printf( "   Number Tests:           %d\n", number_tests );
    printf( "   Number Successful:      %d\n", number_tests_successful );
    printf( "   Number Not Implemented: %d\n", number_tests_not_implemented );
    printf( "   Number Failed:          %d\n", number_tests_failed );
    printf( "\n\n\n" );
    /* delete the mesh */
    iMesh_dtor( mesh, &result );
        printf( "Failed to destruct the mesh instance.\n" );
        return 1;
    return number_tests_failed;
int mesh_double_tag_test ( iMesh_Instance  mesh,
Definition at line 2437 of file testc_cbind.cpp.
References FALSE, iBase_DOUBLE, iBase_SUCCESS, iMesh_createTag, iMesh_getEntSetData, iMesh_setEntSetData, root_set, and TRUE.
Referenced by mesh_tag_test().
    int result;
    /* create a tag */
    const char* tag_name = "mesh_double_tag";
        printf( "Failed to create tag double_tag in mesh_double_tag_test.\n" );
        return FALSE;
    iMesh_setEntSetData( mesh, root_set, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
        printf( "Failed to set double tag (val=11) in mesh_double_tag_test.\n" );
        return FALSE;
    dum_val2 = 0;
    iMesh_getEntSetData( mesh, root_set, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get double tag (val=1.0e6) in mesh_double_tag_test." );
        return FALSE;
        return FALSE;
    dum_val = 2.0e9;
        printf( "Failed to set double tag (val=2.0e9) in mesh_double_tag_test." );
        return FALSE;
        printf( "Failed to get double tag (val=2.0e9) in mesh_double_tag_test." );
        return FALSE;
        return FALSE;
    return TRUE;
int mesh_int_tag_test ( iMesh_Instance  mesh,
Definition at line 2372 of file testc_cbind.cpp.
References FALSE, iBase_INTEGER, iBase_SUCCESS, iMesh_createTag, iMesh_getEntSetData, iMesh_setEntSetData, root_set, and TRUE.
    int result;
    /* create a tag */
    const char* tag_name = "mesh_int_tag";
        printf( "Failed to create tag int_tag in mesh_int_tag_test.\n" );
        return FALSE;
    iMesh_setEntSetData( mesh, root_set, *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
        printf( "Failed to set int tag (val=11) in mesh_int_tag_test.\n" );
        return FALSE;
    dum_val2 = 0;
    iMesh_getEntSetData( mesh, root_set, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get int tag (val=11) in mesh_int_tag_test." );
        return FALSE;
        return FALSE;
    dum_val = 12;
        printf( "Failed to set int tag (val=12) in mesh_int_tag_test." );
        return FALSE;
        printf( "Failed to get int tag (val=12) in mesh_int_tag_test." );
        return FALSE;
        return FALSE;
    return TRUE;
int mesh_struct_tag_test ( iMesh_Instance  mesh,
Definition at line 2502 of file testc_cbind.cpp.
    int result;
    /* create a tag */
    const char* tag_name = "mesh_struct_tag";
        printf( "Failed to create tag struct_tag in vertex_struct_tag_test.\n" );
        return FALSE;
        printf( "Failed to set struct tag in mesh_struct_tag_test.\n" );
        return FALSE;
        printf( "Failed to get struct tag in mesh_struct_tag_test.\n" );
        return FALSE;
        return FALSE;
        return FALSE;
    return TRUE;
Definition at line 2551 of file testc_cbind.cpp.
References FALSE, iBase_SUCCESS, iMesh_destroyTag, iMesh_getAllEntSetTags, iMesh_rmvEntSetTag, root_set, and TRUE.
    int result;
    iMesh_getAllEntSetTags( mesh, root_set, &all_tags, &all_tags_alloc, &all_tags_size, &result );
        return FALSE;
    iMesh_rmvEntSetTag( mesh, root_set, all_tags[0], &result );
        free( all_tags );
        return FALSE;
        delete_err = TRUE;
    if( !delete_err )
        free( all_tags );
        return FALSE;
        free( all_tags );
        return FALSE;
    free( all_tags );
    return TRUE;
Test:
Definition at line 2606 of file testc_cbind.cpp.
References mesh_double_tag_test(), mesh_int_tag_test(), mesh_struct_tag_test(), and mesh_tag_delete_test().
    int int_success = mesh_int_tag_test( mesh, &int_tag );
    int double_success = mesh_double_tag_test( mesh, &double_tag );
    int struct_success = mesh_struct_tag_test( mesh, &struct_tag );
    int tag_delete_success = mesh_tag_delete_test( mesh );
static int ordered_set_regression ( iMesh_Instance  mesh) [static]
Definition at line 2711 of file testc_cbind.cpp.
References CHK, iBase_ALL_TYPES, iBase_INTERLEAVED, iBase_NEW, iMesh_addEntArrToSet, iMesh_ALL_TOPOLOGIES, iMesh_createEnt, iMesh_createEntSet, iMesh_createVtxArr, iMesh_dtor, iMesh_getEntities, iMesh_LINE_SEGMENT, and iMesh_newMesh.
    iBase_EntityHandle line, *p, verts[2], ents_in[3], ents_out[3];
    iBase_EntitySetHandle set;
    int i, err, status, two = 2, three = 3;
    CHK( err );
    p = verts;
    iMesh_createVtxArr( mesh, 2, iBase_INTERLEAVED, coords, 6, &p, &two, &two, &err );
    CHK( err );
    CHK( err );
    if( status != iBase_NEW ) return 0;
    iMesh_createEntSet( mesh, 1, &set, &err );
    CHK( err );
    ents_in[0] = verts[1];
    ents_in[1] = line;
    ents_in[2] = verts[0];
    iMesh_addEntArrToSet( mesh, ents_in, three, set, &err );
    CHK( err );
    p = ents_out;
    iMesh_getEntities( mesh, set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &p, &three, &three, &err );
    CHK( err );
    for( i = 0; i < three; i++ )
        if( ents_in[i] != ents_out[i] )
            printf( "Ordered set does not preserve order\n" );
            return 0;
    CHK( err );
    return 1;
void PRINT_ASSERT_FAILURE ( const char *  cond,
const char *  file,
int  line
Definition at line 90 of file testc_cbind.cpp.
    printf( "Condition: %s\n", cond );
    printf( " failed at %s line %d\n", file, line );
int qsort_comp_handles ( const void *  h1,
const void *  h2
Definition at line 503 of file testc_cbind.cpp.
    return *(char**)h1 - *(char**)h2;
Definition at line 2624 of file testc_cbind.cpp.
References contained(), iBase_SUCCESS, iMesh_addEntSet, iMesh_createEntSet, iMesh_isEntSetContained, and iMesh_rmvEntSet.
    int err, contained;
    iBase_EntitySetHandle set, sub;
    iMesh_createEntSet( mesh, 0, &set, &err );
    iMesh_createEntSet( mesh, 1, &sub, &err );
    iMesh_addEntSet( mesh, sub, set, &err );
    iMesh_isEntSetContained( mesh, set, sub, &contained, &err );
    if( !contained )
        fprintf( stderr, "isEntSetContained returned false for contained set\n" );
        return 0;
    iMesh_rmvEntSet( mesh, sub, set, &err );
    if( contained )
        fprintf( stderr, "isEntSetContained returned true for removed set\n" );
        return 0;
    return 1;
Test:
TSTT Tag Info test
  • Tests tagCreate, tagDelete, tagGetName, tagGetSize, tagGetHandle
Definition at line 1724 of file testc_cbind.cpp.
References moab::error(), FALSE, iBase_INTEGER, iBase_SUCCESS, iMesh_createTag, iMesh_destroyTag, iMesh_getTagHandle, iMesh_getTagName, iMesh_getTagSizeBytes, and TRUE.
    char dum_name[120];
    int dum_name_size = 120;
    int dum_size;
    int error = FALSE;
    iBase_TagHandle dum_handle;
    /* Create a tag */
    int result;
    iBase_TagHandle tag_handle = NULL;
    const char* tag_name       = "int_tag";
    int tag_name_size          = 8;
    iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, &tag_handle, &result, tag_name_size );
        printf( "Failed to create tag int_tag in vertex_tag_test." );
        return FALSE;
    /* check tag info functions */
    iMesh_getTagName( mesh, tag_handle, dum_name, &result, dum_name_size );
        printf( "Couldn't get name of tag just created.\n" );
        return FALSE;
    if( strcmp( dum_name, "int_tag" ) != 0 )
        printf( "Tag names didn't match.\n" );
        return FALSE;
    iMesh_getTagSizeBytes( mesh, tag_handle, &dum_size, &result );
        printf( "Couldn't get size of tag just created.\n" );
        return FALSE;
    if( dum_size != sizeof( int ) )
        printf( "Tag sizes didn't match.\n" );
        return FALSE;
    iMesh_getTagHandle( mesh, tag_name, &dum_handle, &result, tag_name_size );
        printf( "Couldn't get handle of tag just created.\n" );
        return FALSE;
    if( dum_handle != tag_handle )
        printf( "Tag handles didn't match.\n" );
        return FALSE;
    /* test non-forced version of tagDelete; forced version tested later, */
    /* when we have entities around */
    iMesh_destroyTag( mesh, tag_handle, FALSE, &result );
        printf( "Couldn't delete tag just created.\n" );
        return FALSE;
    /* look for that tag, to make sure it got deleted */
    iMesh_getTagHandle( mesh, tag_name, &tag_handle, &result, tag_name_size );
        error = TRUE;
    if( !error )
        printf( "tagGetHandle was able to find handle for deleted tag.\n" );
        return FALSE;
    return TRUE;
Definition at line 3027 of file testc_cbind.cpp.
References CHK, iBase_ALL_TYPES, iBase_SUCCESS, iMesh_addEntArrToSet, iMesh_ALL_TOPOLOGIES, iMesh_createEntSet, iMesh_getEntities, iMesh_getRootSet, and test_iterator_common().
Referenced by main(), and test_iterators().
    int result, i;
    iBase_EntitySetHandle root, list, set, *setptr;
    iBase_EntityHandle* array = NULL;
    int array_len = 0, array_size = 0;
    iMesh_getRootSet( mesh, &root, &result );
    CHK( result );
    /* create some sets containing every other handle */
    iMesh_getEntities( mesh, root, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, &array, &array_size, &array_len, &result );
    CHK( result );
    for( i = 1; i < array_size; i += 2 )
        array[i] = array[i - 1];
    for( i = 0; i < 2; ++i )
        setptr = i ? &list : &set;
        iMesh_createEntSet( mesh, i, setptr, &result );
        if( iBase_SUCCESS != result ) free( array );
        CHK( result );
        iMesh_addEntArrToSet( mesh, array, array_size, *setptr, &result );
        CHK( result );
    free( array );
    /* test single iterator and array iterator for all types */
    for( i = 0; i < iBase_ALL_TYPES; ++i )
        array_size = 2 * i + 2;
        result     = test_iterator_common( "root", mesh, root, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
        result = test_iterator_common( "root", mesh, root, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
        result = test_iterator_common( "list", mesh, list, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
        result = test_iterator_common( "list", mesh, list, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
        result = test_iterator_common( "set", mesh, set, 1, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
        result = test_iterator_common( "set", mesh, set, array_size, (enum iBase_EntityType)i, iMesh_ALL_TOPOLOGIES );
        CHK( result );
    for( i = 0; i < iMesh_ALL_TOPOLOGIES; ++i )
        result     = test_iterator_common( "root", mesh, root, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
        result = test_iterator_common( "root", mesh, root, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
        result = test_iterator_common( "list", mesh, list, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
        result = test_iterator_common( "list", mesh, list, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
        result = test_iterator_common( "set", mesh, set, 1, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
        result = test_iterator_common( "set", mesh, set, array_size, iBase_ALL_TYPES, (enum iMesh_EntityTopology)i );
        CHK( result );
    return 1;
int test_iterator_common ( const char *  info,
int  array_size,
Definition at line 3006 of file testc_cbind.cpp.
References CHK, compare_array_iter(), compare_single_iter(), and iMesh_getEntities.
Referenced by test_iterator().
    iBase_EntityHandle* contents = NULL;
    int content_size = 0, content_alloc = 0;
    int result;
    iMesh_getEntities( mesh, set, type, topo, &contents, &content_alloc, &content_size, &result );
    CHK( result );
    if( array_size == 1 )
        result = compare_single_iter( info, mesh, set, contents, content_size, type, topo );
    else
        result = compare_array_iter( info, mesh, set, contents, content_size, array_size, type, topo );
    free( contents );
    return result;
Test:
TSTT topology adjacency Test
  • Check topology information
  • Check adjacency
  • Get interior and exterior elements
Definition at line 229 of file testc_cbind.cpp.
References entities, FALSE, iBase_ALL_TYPES, iBase_FACE, iBase_REGION, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_getEntArrAdj, iMesh_getEntArrTopo, iMesh_getEntities, iMesh_getNumOfTopo, iMesh_HEXAHEDRON, iMesh_POINT, iMesh_PRISM, iMesh_PYRAMID, iMesh_SEPTAHEDRON, iMesh_TETRAHEDRON, root_set, and TRUE.
    int result, i, j, entities_alloc, entities_size, *topologies;
    int topologies_alloc, topologies_size;
    iBase_EntityHandle *entities, *entity_vectors[iMesh_ALL_TOPOLOGIES] = { NULL };
    int entity_vectors_sizes[iMesh_ALL_TOPOLOGIES] = { 0 };
    int top_j, num_tops, region_type, num_region;
    int face_offsets_alloc          = 0, face_offsets_size, face_loaded;
    iBase_EntityHandle* adj_regions = NULL;
    int adj_regions_alloc           = 0, adj_regions_size;
    int* region_offsets             = NULL;
    int region_offsets_alloc        = 0, region_offsets_size;
    iBase_EntityHandle *interior, *exterior;
    int num_int = 0, num_ext = 0, found, next_offset, iter;
    int num_faces_per_region;
    /* fill the vectors of each topology entities */
    /* like lines vector, polygon vector, triangle vector, */
    /* quadrilateral, polyhedrron, tet, hex, prism, pyramid, */
    /* septahedron vectors */
    for( i = 0; i < iMesh_ALL_TOPOLOGIES; i++ )
        entities       = NULL;
        entities_alloc = 0;
        iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, i, &entities, &entities_alloc, &entities_size, &result );
            printf( "Failed to get entities in adjacencies_test.\n" );
            return FALSE;
        if( entities_alloc > 0 )
            topologies       = NULL;
            topologies_alloc = 0;
            iMesh_getEntArrTopo( mesh, entities, entities_alloc, &topologies, &topologies_alloc, &topologies_size,
                                 &result );
                printf( "Failed to get topologies in adjacencies_test.\n" );
                return FALSE;
            if( topologies_size != entities_size )
                printf( "Didn't get the right number of topologies "
                        "in topology_adjacency_test.\n" );
                free( topologies );
                free( entities );
                return FALSE;
            /* put entities into vectors of each topology */
            entity_vectors[i] = (iBase_EntityHandle*)malloc( entities_size * sizeof( iBase_EntityHandle ) );
            for( j = 0; j < entities_size; j++ )
                if( topologies[j] < iMesh_POINT || topologies[j] >= iMesh_ALL_TOPOLOGIES )
                    printf( "Didn't find entity type for this topology." );
                else
                    entity_vectors[i][entity_vectors_sizes[i]] = entities[j];
                    entity_vectors_sizes[i]++;
            free( topologies );
        free( entities );
    /* check number of entities for each topology */
    for( top_j = 0; top_j < iMesh_ALL_TOPOLOGIES; top_j++ )
        num_tops = 0;
        iMesh_getNumOfTopo( mesh, root_set, top_j, &num_tops, &result );
            printf( "Failed to get number of topologies in adjacencies_test.\n" );
                free( entity_vectors[i] );
            return FALSE;
        if( entity_vectors_sizes[top_j] != num_tops )
            printf( "Topology count mismatch.\n" );
            return FALSE;
    /* change if 3d topology entities are added or removed */
    for( region_type = iMesh_TETRAHEDRON; region_type < iMesh_ALL_TOPOLOGIES; region_type++ )
        /* get all adjacent faces of regions  */
        iBase_EntityHandle* region_vector = entity_vectors[region_type];
        num_region = entity_vectors_sizes[region_type];
        if( num_region > 0 )
            adj_faces          = NULL;
            iMesh_getEntArrAdj( mesh, region_vector, num_region, iBase_FACE, &adj_faces, &adj_faces_alloc,
                                &adj_faces_size, &face_offsets, &face_offsets_alloc, &face_offsets_size, &result );
                printf( "Failed to get adjacent faces of regions in adjacencies_test.\n" );
                return FALSE;
            if( num_region + 1 != face_offsets_size )
                printf( "Number of offsets didn't agree with number of "
                        "regions in topology_adjacency_test.\n" );
                free( adj_faces );
                return FALSE;
            face_loaded = FALSE;
            /* check # of faces really loaded */
            if( region_type == iMesh_TETRAHEDRON )
                if( adj_faces_size == 4 * num_region ) face_loaded = TRUE;
            else if( region_type == iMesh_HEXAHEDRON )
                if( adj_faces_size == 6 * num_region ) face_loaded = TRUE;
            else if( region_type == iMesh_PRISM )
                if( adj_faces_size == 5 * num_region ) face_loaded = TRUE;
            else if( region_type == iMesh_PYRAMID )
            else if( region_type == iMesh_SEPTAHEDRON )
                if( adj_faces_size == 7 * num_region ) face_loaded = TRUE;
            else
            /* get all adjacent regions of adjacent faces */
            adj_regions          = NULL;
            adj_regions_alloc    = 0;
            region_offsets_alloc = 0;
            iMesh_getEntArrAdj( mesh, adj_faces, adj_faces_size, iBase_REGION, &adj_regions, &adj_regions_alloc,
                                &adj_regions_size, &region_offsets, &region_offsets_alloc, &region_offsets_size,
                                &result );
                printf( "Failed to get regions from faces in adjacencies_test.\n" );
                free( adj_faces );
                return FALSE;
            if( adj_faces_size + 1 != region_offsets_size )
                printf( "Number of offsets didn't agree with number of faces in "
                        "topology_adjacency_test.\n" );
                free( region_offsets );
                free( adj_faces );
                free( adj_regions );
                return FALSE;
            interior = (iBase_EntityHandle*)malloc( adj_faces_size * sizeof( iBase_EntityHandle ) ),
            exterior = (iBase_EntityHandle*)malloc( adj_faces_size * sizeof( iBase_EntityHandle ) );
            num_int  = 0;
            num_ext  = 0;
            /* find the interior faces having two adjacent regions */
            for( i = 0; i < adj_faces_size; i++ )
                next_offset = 0;
                if( i == adj_faces_size - 1 )
                    next_offset = adj_regions_size;
                else
                    next_offset = region_offsets[i + 1];
                if( next_offset - region_offsets[i] == 2 )
                    found = FALSE;
                    for( iter = 0; iter < num_int; iter++ )
                        if( interior[iter] == adj_faces[i] )
                            found = TRUE;
                            break;
                    if( !found ) interior[num_int++] = adj_faces[i];
            /* now remove any interior faces from the previous adjacent faces list */
            /* and we should be left with exterior faces */
                found = FALSE;
                        found = TRUE;
                        break;
                if( !found ) exterior[num_ext++] = adj_faces[i];
            num_faces_per_region = face_offsets[1] - face_offsets[0];
            /* check # of exterior and interior faces */
            /* should be #exterior_faces + 2 * #interior_faces = #faces_per_region */
            /* * #regions */
            if( face_loaded )
                if( num_ext + 2 * num_int != num_faces_per_region * num_region )
                    printf( "exterior/interior failure: %d ext, %d int, %d regions, %d faces per\n", num_ext, num_int,
                            num_region, num_faces_per_region );
                    free( adj_faces );
                    free( interior );
                    free( exterior );
                    return FALSE;
            free( adj_faces );
            free( interior );
            free( exterior );
    return TRUE;
Test:
TSTT topology dimension Test
  • Check 2d topology dimensions
Definition at line 170 of file testc_cbind.cpp.
References FALSE, iBase_FACE, iBase_SUCCESS, iMesh_ALL_TOPOLOGIES, iMesh_getEntArrType, iMesh_getEntities, root_set, and TRUE.
    iBase_EntityHandle* faces = NULL;
    int faces_alloc           = 0, faces_size;
    int result, i;
    int* dimensions      = NULL;
    int dimensions_alloc = 0, dimensions_size;
    /* first get 2D entities */
    iMesh_getEntities( mesh, root_set, iBase_FACE, iMesh_ALL_TOPOLOGIES, &faces, &faces_alloc, &faces_size, &result );
        printf( "Failed to get faces in entity_sets_test.\n" );
        return FALSE;
    /* get dimensions of faces */
    iMesh_getEntArrType( mesh, faces, faces_size, &dimensions, &dimensions_alloc, &dimensions_size, &result );
        printf( "Failed to get dimensions of faces in topology_test.\n" );
        free( faces );
        return FALSE;
    if( dimensions_size != faces_size )
        printf( "Didn't get the right number of types in topology_test.\n" );
        free( faces );
        free( dimensions );
        return FALSE;
    /* make sure all elements are 2D */
    for( i = 0; i < faces_size; i++ )
        if( dimensions[i] != iBase_FACE )
            free( faces );
            free( dimensions );
            return FALSE;
    free( faces );
    free( dimensions );
    return TRUE;
Test:
Vertex Coordinates
  • Get coordinates of vertices by 2 different methods then compare them
Definition at line 1671 of file testc_cbind.cpp.
References FALSE, iBase_INTERLEAVED, iBase_SUCCESS, iBase_VERTEX, iMesh_getDfltStorage, iMesh_getEntities, iMesh_getVtxArrCoords, iMesh_POINT, root_set, and TRUE.
Referenced by main().
    double* vert_coords       = NULL;
    int vert_coords_alloc     = 0, vert_coords_size;
    /* check storage order */
    int result;
    int this_order;
    iMesh_getDfltStorage( mesh, &this_order, &result );
        printf( "failed to get preferred storage order in vertex_coordinates_test.\n" );
        return FALSE;
    /* now get the vertex coordinates from a vertex array */
    /* need to get the vertices in the model */
    verts       = NULL;
    verts_alloc = 0;
    iMesh_getEntities( mesh, root_set, iBase_VERTEX, iMesh_POINT, &verts, &verts_alloc, &verts_size, &result );
        printf( "failed to get entities in vertex_coordinates_test.\n" );
        return FALSE;
    /* get the coordinates in one array */
    vert_coords       = NULL;
    vert_coords_alloc = 0;
    iMesh_getVtxArrCoords( mesh, verts, verts_size, iBase_INTERLEAVED, &vert_coords, &vert_coords_alloc,
                           &vert_coords_size, &result );
        printf( "failed to get vertex cooridinate of entities in vertex_coordinates_test.\n" );
        free( verts );
        return FALSE;
    free( verts );
    free( vert_coords );
    /* if we get here, this test was successful */
    return TRUE;
int vertex_double_tag_test ( iMesh_Instance  mesh,
iBase_EntityHandle *  verts,
int  ,
Definition at line 1873 of file testc_cbind.cpp.
References FALSE, iBase_DOUBLE, iBase_SUCCESS, iMesh_createTag, iMesh_getArrData, iMesh_setArrData, and TRUE.
Referenced by vertex_tag_test().
    int result;
    iBase_EntityHandle dum_vert = verts[0];
    /* create a tag */
    const char* tag_name = "double_tag";
    int tag_name_size    = 11;
    iMesh_createTag( mesh, tag_name, 1, iBase_DOUBLE, double_tag, &result, tag_name_size );
        printf( "Failed to create tag double_tag in vertex_double_tag_test.\n" );
        return FALSE;
    iMesh_setArrData( mesh, &dum_vert, 1, *double_tag, (char*)( &dum_val ), sizeof( double ), &result );
        printf( "Failed to set double tag (val=1.0e6) in vertex_double_tag_test.\n" );
        return FALSE;
    iMesh_getArrData( mesh, &dum_vert, 1, *double_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
        printf( "Failed to get double tag (val=1.0e6) in vertex_double_tag_test.\n" );
        return FALSE;
        printf( "Value of vertex tag (val=1.0e6) wrong.\n" );
        return FALSE;
    /* put a value in the last vertex and retrieve */
    dum_val = 2.0e9;
        printf( "Failed to set double tag (val=2.0e9) in vertex_double_tag_test.\n" );
        return FALSE;
        printf( "Failed to get double tag (val=2.0e9) in vertex_double_tag_test.\n" );
        return FALSE;
        printf( "Value of vertex tag (val=2.0e9) wrong.\n" );
        return FALSE;
    return TRUE;
int vertex_int_tag_test ( iMesh_Instance  mesh,
int  ,
Definition at line 1804 of file testc_cbind.cpp.
References FALSE, iBase_INTEGER, iBase_SUCCESS, iMesh_createTag, iMesh_getArrData, iMesh_setArrData, and TRUE.
    int result;
    /* create a tag */
    iMesh_createTag( mesh, tag_name, 1, iBase_INTEGER, int_tag, &result, tag_name_size );
        printf( "Failed to create tag int_tag in vertex_int_tag_test.\n" );
        return FALSE;
    iMesh_setArrData( mesh, &dum_vert, 1, *int_tag, (const char*)( &dum_val ), sizeof( int ), &result );
        printf( "Failed to set int tag (val=11) in vertex_int_tag_test.\n" );
        return FALSE;
    iMesh_getArrData( mesh, &dum_vert, 1, *int_tag, &dum_val2_ptr, &dum_val2_alloc, &dum_val2_size, &result );
    if( iBase_SUCCESS != result || dum_val2 != 11 )
        printf( "Failed to get int tag (val=11) in vertex_int_tag_test.\n" );
        return FALSE;
        printf( "Value of vertex tag (val=11) wrong.\n" );
        return FALSE;
    dum_val = 12;
    iMesh_setArrData( mesh, &dum_vert, 1, *int_tag, (char*)( &dum_val ), sizeof( int ), &result );
        printf( "Failed to set int tag (val=12) in vertex_int_tag_test.\n" );
        return FALSE;
        printf( "Failed to get int tag (val=12) in vertex_int_tag_test.\n" );
        return FALSE;
        printf( "Value of vertex tag (val=12) wrong.\n" );
        return FALSE;
    return TRUE;
int vertex_struct_tag_test ( iMesh_Instance  mesh,
int  ,
Definition at line 1950 of file testc_cbind.cpp.
References FALSE, iBase_BYTES, iBase_SUCCESS, iMesh_createTag, iMesh_getArrData, iMesh_setArrData, and TRUE.
    int result;
    /* create a tag */
    const char* tag_name = "struct_tag";
    iMesh_createTag( mesh, tag_name, sizeof( struct TagStruct ), iBase_BYTES, struct_tag, &result, tag_name_size );
        return FALSE;
    iMesh_setArrData( mesh, &dum_vert, 1, *struct_tag, (const char*)&dum_struct, sizeof( struct TagStruct ), &result );
        printf( "Failed to set struct tag in vertex_struct_tag_test.\n" );
        return FALSE;
    iMesh_getArrData( mesh, &dum_vert, 1, *struct_tag, &dum_struct2_ptr, &dum_struct_alloc, &dum_struct_size, &result );
        printf( "Failed to get struct tag in vertex_struct_tag_test.\n" );
        return FALSE;
        printf( "Size of vertex struct tag wrong.\n" );
        return FALSE;
        printf( "Value of vertex struct tag wrong.\n" );
        return FALSE;
    return TRUE;
int vertex_tag_delete_test ( iMesh_Instance  mesh,
int
Definition at line 2004 of file testc_cbind.cpp.
References FALSE, iBase_SUCCESS, iMesh_destroyTag, iMesh_getAllTags, iMesh_rmvArrTag, and TRUE.
    int result;
    iBase_EntityHandle dum_entity = verts[0];
    iMesh_getAllTags( mesh, verts[0], &all_tags, &all_tags_alloc, &all_tags_size, &result );
        printf( "Couldn't get all tag handles from vertex.\n" );
        return FALSE;
    iMesh_rmvArrTag( mesh, &dum_entity, 1, all_tags[0], &result );
        printf( "Couldn't remove tag from vertex.\n" );
        free( all_tags );
        return FALSE;
        delete_err = TRUE;
    if( !delete_err )
        printf( "Error when unforced-deleting tag in use on a vertex.\n" );
        free( all_tags );
        return FALSE;
        printf( "Couldn't force-delete a tag in use on a vertex.\n" );
        free( all_tags );
        return FALSE;
    free( all_tags );
    return TRUE;
Definition at line 2056 of file testc_cbind.cpp.
References FALSE, iBase_ALL_TYPES, iBase_SUCCESS, iMesh_getEntities, iMesh_POINT, root_set, tag_info_test(), vertex_double_tag_test(), vertex_int_tag_test(), vertex_struct_tag_test(), and vertex_tag_delete_test().
    int result;
    int int_err, double_err, struct_err, tag_delete_err;
    int info_err = tag_info_test( mesh );
    /* get all the vertices */
    iBase_EntityHandle* verts = NULL;
    int verts_alloc           = 0, verts_size;
    iMesh_getEntities( mesh, root_set, iBase_ALL_TYPES, iMesh_POINT, &verts, &verts_alloc, &verts_size, &result );
        printf( "entitysetGetEntities failed in vertex_tag_test.\n" );
        return FALSE;
    /* vertex int tag */
    int_err = vertex_int_tag_test( mesh, verts, verts_size, &int_tag );
    /* vertex double tag */
    double_err = vertex_double_tag_test( mesh, verts, verts_size, &double_tag );
    /* vertex struct tag */
    struct_err = vertex_struct_tag_test( mesh, verts, verts_size, &struct_tag );
    tag_delete_err = vertex_tag_delete_test( mesh, verts, verts_size );
    free( verts );
    return ( info_err && int_err && double_err && struct_err && tag_delete_err );
Variable Documentation
bool assert_pass [static]
Definition at line 81 of file testc_cbind.cpp.
Referenced by entity_connectivity_test().
