MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "MeshSet.hpp" 00002 #include "AEntityFactory.hpp" 00003 #include "TestUtil.hpp" 00004 #include "moab/Core.hpp" 00005 #include "moab/SetIterator.hpp" 00006 00007 using namespace moab; 00008 00009 #include <iostream> 00010 00011 //! test add_entities, get_entities, num_entities 00012 void test_add_entities( unsigned flags ); 00013 //! test remove_entities, get_entities, num_entities 00014 void test_remove_entities( unsigned flags ); 00015 //! test get_entities_by_type, num_entities_by_type 00016 void test_entities_by_type( unsigned flags ); 00017 //! test get_entities_by_dimension, num_entities_by_dimension 00018 void test_entities_by_dimension( unsigned flags ); 00019 //! test subtract_meshset 00020 void test_subtract( unsigned flags1, unsigned flags2 ); 00021 //! test intersect_meshset 00022 void test_intersect( unsigned flags1, unsigned flags2 ); 00023 //! test unite_meshset 00024 void test_unite( unsigned flags1, unsigned flags2 ); 00025 //! test MeshSet::contains_entities 00026 void test_contains_entities( unsigned flags ); 00027 //! test clear_meshset 00028 void test_clear( unsigned flags ); 00029 00030 //! Create 10x10x10 hex mesh 00031 void make_mesh( Interface& iface ); 00032 //! Create 10x10x10 hex mesh, return ranges of handles 00033 void make_mesh( Interface& iface, EntityHandle& vstart, EntityHandle& vend, EntityHandle& hstart, EntityHandle& hend ); 00034 //! Print std::vector<EntityHandle> 00035 void print_handle_vect( const char* prefix, const std::vector< EntityHandle >& vect ); 00036 //! Print Range 00037 void print_mbrange( const char* prefix, const Range& range ); 00038 //! Compare set contents against passed vector, and if MESHSET_TRACK_OWNER then check adjacencies 00039 bool check_set_contents( Core& mb, EntityHandle set, const std::vector< EntityHandle >& expected ); 00040 //! Compare result of get_entities_by_type to result of get_entities_by_handle 00041 bool check_set_contents( Core& mb, EntityType type, EntityHandle set, unsigned flags ); 00042 //! Compare result of get_entities_by_dimension to result of get_entities_by_handle 00043 bool check_set_contents( Core& mb, int dim, EntityHandle set, unsigned flags ); 00044 //! For each entry in range, if one or more occurances in vect, remove last occurance from vect. 00045 void remove_from_back( std::vector< EntityHandle >& vect, const Range& range ); 00046 enum BoolOp 00047 { 00048 UNITE, 00049 INTERSECT, 00050 SUBTRACT 00051 }; 00052 //! Perform boolean op on two entity sets and verify result 00053 bool test_boolean( Core& mb, 00054 BoolOp op, 00055 unsigned flags1, 00056 const Range& set1_ents, 00057 unsigned flags2, 00058 const Range& set2_ents ); 00059 void test_iterator( Interface& moab, SetIterator* iter, EntityHandle set, EntityType etype, int dim ); 00060 void test_iterators( unsigned int flags, bool type, bool dim ); 00061 void test_all_iterators(); 00062 00063 void test_add_entities_ordered() 00064 { 00065 test_add_entities( MESHSET_ORDERED ); 00066 } 00067 void test_add_entities_set() 00068 { 00069 test_add_entities( MESHSET_SET ); 00070 } 00071 void test_add_entities_ordered_tracking() 00072 { 00073 test_add_entities( MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00074 } 00075 void test_add_entities_set_tracking() 00076 { 00077 test_add_entities( MESHSET_TRACK_OWNER | MESHSET_SET ); 00078 } 00079 00080 void test_remove_entities_ordered() 00081 { 00082 test_remove_entities( MESHSET_ORDERED ); 00083 } 00084 void test_remove_entities_set() 00085 { 00086 test_remove_entities( MESHSET_SET ); 00087 } 00088 void test_remove_entities_ordered_tracking() 00089 { 00090 test_remove_entities( MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00091 } 00092 void test_remove_entities_set_tracking() 00093 { 00094 test_remove_entities( MESHSET_TRACK_OWNER | MESHSET_SET ); 00095 } 00096 00097 void test_entities_by_type_ordered() 00098 { 00099 test_entities_by_type( MESHSET_ORDERED ); 00100 } 00101 void test_entities_by_type_set() 00102 { 00103 test_entities_by_type( MESHSET_SET ); 00104 } 00105 void test_entities_by_dim_ordered() 00106 { 00107 test_entities_by_dimension( MESHSET_ORDERED ); 00108 } 00109 void test_entities_by_dim_set() 00110 { 00111 test_entities_by_dimension( MESHSET_SET ); 00112 } 00113 00114 void test_subtract_set_set() 00115 { 00116 test_subtract( MESHSET_SET, MESHSET_SET ); 00117 } 00118 void test_subtract_set_ordered() 00119 { 00120 test_subtract( MESHSET_SET, MESHSET_ORDERED ); 00121 } 00122 void test_subtract_ordered_set() 00123 { 00124 test_subtract( MESHSET_ORDERED, MESHSET_SET ); 00125 } 00126 void test_subtract_ordered_ordered() 00127 { 00128 test_subtract( MESHSET_ORDERED, MESHSET_ORDERED ); 00129 } 00130 void test_subtract_set_set_tracking() 00131 { 00132 test_subtract( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_SET ); 00133 } 00134 void test_subtract_set_ordered_tracking() 00135 { 00136 test_subtract( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00137 } 00138 void test_subtract_ordered_set_tracking() 00139 { 00140 test_subtract( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_SET ); 00141 } 00142 void test_subtract_ordered_ordered_tracking() 00143 { 00144 test_subtract( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00145 } 00146 00147 void test_itersect_set_set() 00148 { 00149 test_intersect( MESHSET_SET, MESHSET_SET ); 00150 } 00151 void test_itersect_set_ordered() 00152 { 00153 test_intersect( MESHSET_SET, MESHSET_ORDERED ); 00154 } 00155 void test_itersect_ordered_set() 00156 { 00157 test_intersect( MESHSET_ORDERED, MESHSET_SET ); 00158 } 00159 void test_itersect_ordered_ordered() 00160 { 00161 test_intersect( MESHSET_ORDERED, MESHSET_ORDERED ); 00162 } 00163 void test_itersect_set_set_tracking() 00164 { 00165 test_intersect( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_SET ); 00166 } 00167 void test_itersect_set_ordered_tracking() 00168 { 00169 test_intersect( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00170 } 00171 void test_itersect_ordered_set_tracking() 00172 { 00173 test_intersect( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_SET ); 00174 } 00175 void test_itersect_ordered_ordered_tracking() 00176 { 00177 test_intersect( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00178 } 00179 00180 void test_unite_set_set() 00181 { 00182 test_unite( MESHSET_SET, MESHSET_SET ); 00183 } 00184 void test_unite_set_ordered() 00185 { 00186 test_unite( MESHSET_SET, MESHSET_ORDERED ); 00187 } 00188 void test_unite_ordered_set() 00189 { 00190 test_unite( MESHSET_ORDERED, MESHSET_SET ); 00191 } 00192 void test_unite_ordered_ordered() 00193 { 00194 test_unite( MESHSET_ORDERED, MESHSET_ORDERED ); 00195 } 00196 void test_unite_set_set_tracking() 00197 { 00198 test_unite( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_SET ); 00199 } 00200 void test_unite_set_ordered_tracking() 00201 { 00202 test_unite( MESHSET_TRACK_OWNER | MESHSET_SET, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00203 } 00204 void test_unite_ordered_set_tracking() 00205 { 00206 test_unite( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_SET ); 00207 } 00208 void test_unite_ordered_ordered_tracking() 00209 { 00210 test_unite( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00211 } 00212 00213 void test_contains_entities_ordered() 00214 { 00215 test_contains_entities( MESHSET_ORDERED ); 00216 } 00217 void test_contains_entities_set() 00218 { 00219 test_contains_entities( MESHSET_SET ); 00220 } 00221 00222 void test_clear_ordered() 00223 { 00224 test_clear( MESHSET_ORDERED ); 00225 } 00226 void test_clear_set() 00227 { 00228 test_clear( MESHSET_SET ); 00229 } 00230 void test_clear_ordered_tracking() 00231 { 00232 test_clear( MESHSET_TRACK_OWNER | MESHSET_ORDERED ); 00233 } 00234 void test_clear_set_tracking() 00235 { 00236 test_clear( MESHSET_TRACK_OWNER | MESHSET_SET ); 00237 } 00238 00239 // Reproduce contitions that resulted in bug reported to 00240 // mailing list: 00241 // http://lists.mcs.anl.gov/pipermail/moab-dev/2010/002714.html 00242 void regression_insert_set_1(); 00243 00244 int main() 00245 { 00246 int err = 0; 00247 00248 err += RUN_TEST( test_add_entities_ordered ); 00249 err += RUN_TEST( test_add_entities_set ); 00250 err += RUN_TEST( test_add_entities_ordered_tracking ); 00251 err += RUN_TEST( test_add_entities_set_tracking ); 00252 00253 err += RUN_TEST( test_remove_entities_ordered ); 00254 err += RUN_TEST( test_remove_entities_set ); 00255 err += RUN_TEST( test_remove_entities_ordered_tracking ); 00256 err += RUN_TEST( test_remove_entities_set_tracking ); 00257 00258 err += RUN_TEST( test_entities_by_type_ordered ); 00259 err += RUN_TEST( test_entities_by_type_set ); 00260 err += RUN_TEST( test_entities_by_dim_ordered ); 00261 err += RUN_TEST( test_entities_by_dim_set ); 00262 00263 err += RUN_TEST( test_subtract_set_set ); 00264 err += RUN_TEST( test_subtract_set_ordered ); 00265 err += RUN_TEST( test_subtract_ordered_set ); 00266 err += RUN_TEST( test_subtract_ordered_ordered ); 00267 err += RUN_TEST( test_subtract_set_set_tracking ); 00268 err += RUN_TEST( test_subtract_set_ordered_tracking ); 00269 err += RUN_TEST( test_subtract_ordered_set_tracking ); 00270 err += RUN_TEST( test_subtract_ordered_ordered_tracking ); 00271 00272 err += RUN_TEST( test_itersect_set_set ); 00273 err += RUN_TEST( test_itersect_set_ordered ); 00274 err += RUN_TEST( test_itersect_ordered_set ); 00275 err += RUN_TEST( test_itersect_ordered_ordered ); 00276 err += RUN_TEST( test_itersect_set_set_tracking ); 00277 err += RUN_TEST( test_itersect_set_ordered_tracking ); 00278 err += RUN_TEST( test_itersect_ordered_set_tracking ); 00279 err += RUN_TEST( test_itersect_ordered_ordered_tracking ); 00280 00281 err += RUN_TEST( test_unite_set_set ); 00282 err += RUN_TEST( test_unite_set_ordered ); 00283 err += RUN_TEST( test_unite_ordered_set ); 00284 err += RUN_TEST( test_unite_ordered_ordered ); 00285 err += RUN_TEST( test_unite_set_set_tracking ); 00286 err += RUN_TEST( test_unite_set_ordered_tracking ); 00287 err += RUN_TEST( test_unite_ordered_set_tracking ); 00288 err += RUN_TEST( test_unite_ordered_ordered_tracking ); 00289 00290 err += RUN_TEST( test_contains_entities_ordered ); 00291 err += RUN_TEST( test_contains_entities_set ); 00292 00293 err += RUN_TEST( test_clear_ordered ); 00294 err += RUN_TEST( test_clear_set ); 00295 err += RUN_TEST( test_clear_ordered_tracking ); 00296 err += RUN_TEST( test_clear_set_tracking ); 00297 00298 err += RUN_TEST( regression_insert_set_1 ); 00299 00300 err += RUN_TEST( test_all_iterators ); 00301 00302 if( !err ) 00303 printf( "ALL TESTS PASSED\n" ); 00304 else 00305 printf( "%d TESTS FAILED\n", err ); 00306 00307 return err; 00308 } 00309 00310 // Create 100x100x100 hex mesh 00311 void make_mesh( Interface& iface ) 00312 { 00313 const int dim = 10; 00314 00315 // create vertices 00316 EntityHandle prev_handle = 0; 00317 for( int z = 0; z <= dim; ++z ) 00318 { 00319 for( int y = 0; y <= dim; ++y ) 00320 { 00321 for( int x = 0; x <= dim; ++x ) 00322 { 00323 const double coords[] = { static_cast< double >( x ), static_cast< double >( y ), 00324 static_cast< double >( z ) }; 00325 EntityHandle new_handle = 0; 00326 ErrorCode rval = iface.create_vertex( coords, new_handle );CHECK_ERR( rval ); 00327 CHECK_EQUAL( ++prev_handle, new_handle ); 00328 } 00329 } 00330 } 00331 00332 // create hexes 00333 const int dim1 = dim + 1; 00334 const int dimq = dim1 * dim1; 00335 prev_handle = FIRST_HANDLE( MBHEX ); 00336 for( int z = 0; z < dim; ++z ) 00337 { 00338 for( int y = 0; y < dim; ++y ) 00339 { 00340 for( int x = 0; x < dim; ++x ) 00341 { 00342 const EntityHandle off = 1 + x + dim1 * y + dimq * z; 00343 const EntityHandle conn[] = { off, off + 1, off + 1 + dim1, off + dim1, 00344 off + dimq, off + 1 + dimq, off + 1 + dim1 + dimq, off + dim1 + dimq }; 00345 EntityHandle new_handle = 0; 00346 ErrorCode rval = iface.create_element( MBHEX, conn, 8, new_handle );CHECK_ERR( rval ); 00347 CHECK_EQUAL( prev_handle++, new_handle ); 00348 } 00349 } 00350 } 00351 } 00352 00353 void make_mesh( Interface& mb, 00354 EntityHandle& first_vert, 00355 EntityHandle& last_vert, 00356 EntityHandle& first_hex, 00357 EntityHandle& last_hex ) 00358 { 00359 make_mesh( mb ); 00360 00361 // Get handle ranges, and validate assumption that handles 00362 // are contiguous. 00363 Range range; 00364 ErrorCode rval = mb.get_entities_by_type( 0, MBVERTEX, range );CHECK_ERR( rval ); 00365 first_vert = range.front(); 00366 last_vert = range.back(); 00367 CHECK_EQUAL( (EntityHandle)1331, last_vert - first_vert + 1 ); 00368 range.clear(); 00369 rval = mb.get_entities_by_type( 0, MBHEX, range );CHECK_ERR( rval ); 00370 first_hex = range.front(); 00371 last_hex = range.back(); 00372 CHECK_EQUAL( (EntityHandle)1000, last_hex - first_hex + 1 ); 00373 } 00374 00375 template < typename iter_type > 00376 void print_handles( std::ostream& str, const char* prefix, iter_type begin, iter_type end ) 00377 { 00378 if( prefix ) str << prefix << ':'; 00379 if( begin == end ) 00380 { 00381 str << " (empty)" << std::endl; 00382 return; 00383 } 00384 00385 iter_type i = begin; 00386 EntityType prev_type = TYPE_FROM_HANDLE( *i ); 00387 EntityHandle prev_ent = *i; 00388 str << ' ' << CN::EntityTypeName( prev_type ) << ' ' << ID_FROM_HANDLE( *i ); 00389 for( ;; ) 00390 { 00391 iter_type j = i; 00392 for( ++j, ++prev_ent; j != end && *j == prev_ent; ++j, ++prev_ent ) 00393 ; 00394 --prev_ent; 00395 if( prev_ent - *i > 1 ) 00396 str << "-" << ID_FROM_HANDLE( prev_ent ); 00397 else if( prev_ent - *i == 1 ) 00398 str << ", " << ID_FROM_HANDLE( prev_ent ); 00399 00400 i = j; 00401 if( i == end ) break; 00402 00403 str << ','; 00404 if( TYPE_FROM_HANDLE( *i ) != prev_type ) 00405 str << ' ' << CN::EntityTypeName( prev_type = TYPE_FROM_HANDLE( *i ) ); 00406 str << ' ' << ID_FROM_HANDLE( *i ); 00407 prev_ent = *i; 00408 } 00409 str << std::endl; 00410 } 00411 00412 void print_handle_vect( const char* prefix, const std::vector< EntityHandle >& vect ) 00413 { 00414 print_handles( std::cout, prefix, vect.begin(), vect.end() ); 00415 } 00416 00417 void print_mbrange( const char* prefix, const Range& range ) 00418 { 00419 print_handles( std::cout, prefix, range.begin(), range.end() ); 00420 } 00421 00422 bool compare_set_contents( unsigned flags, 00423 const std::vector< EntityHandle >& expected, 00424 int set_count, 00425 std::vector< EntityHandle >& vect, 00426 const Range& range ) 00427 { 00428 00429 std::vector< EntityHandle > sorted( expected ); 00430 std::sort( sorted.begin(), sorted.end() ); 00431 sorted.erase( std::unique( sorted.begin(), sorted.end() ), sorted.end() ); 00432 00433 int expected_size = 0; 00434 if( flags & MESHSET_ORDERED ) 00435 { 00436 if( expected != vect ) 00437 { 00438 std::cout << "Incorrect set contents from vector-based query" << std::endl; 00439 print_handle_vect( "Expected", expected ); 00440 print_handle_vect( "Actual", vect ); 00441 return false; 00442 } 00443 expected_size = expected.size(); 00444 } 00445 else 00446 { 00447 if( sorted != vect ) 00448 { 00449 std::cout << "Incorrect set contents from vector-based query" << std::endl; 00450 print_handle_vect( "Expected", sorted ); 00451 print_handle_vect( "Actual", vect ); 00452 return false; 00453 } 00454 expected_size = sorted.size(); 00455 } 00456 00457 if( expected_size != set_count ) 00458 { 00459 std::cout << "Incorrect size for entity set" << std::endl; 00460 std::cout << "Expected: " << expected_size << std::endl; 00461 std::cout << "Actual: " << set_count << std::endl; 00462 return false; 00463 } 00464 00465 vect.clear(); 00466 vect.resize( range.size() ); 00467 std::copy( range.begin(), range.end(), vect.begin() ); 00468 if( sorted != vect ) 00469 { 00470 std::cout << "Incorrect set contents from mbrange-based query" << std::endl; 00471 print_handle_vect( "Expected", vect ); 00472 print_mbrange( "Actual", range ); 00473 return false; 00474 } 00475 00476 return true; 00477 } 00478 00479 bool check_set_contents( Core& mb, EntityHandle set, const std::vector< EntityHandle >& expected ) 00480 { 00481 unsigned flags; 00482 ErrorCode rval = mb.get_meshset_options( set, flags );CHECK_ERR( rval ); 00483 00484 int count; 00485 std::vector< EntityHandle > vect; 00486 Range range; 00487 rval = mb.get_entities_by_handle( set, vect, false );CHECK_ERR( rval ); 00488 rval = mb.get_entities_by_handle( set, range, false );CHECK_ERR( rval ); 00489 rval = mb.get_number_entities_by_handle( set, count, false );CHECK_ERR( rval ); 00490 00491 if( !compare_set_contents( flags, expected, count, vect, range ) ) return false; 00492 00493 if( !( flags & MESHSET_TRACK_OWNER ) ) return true; 00494 00495 // get all entitites with an adjacency to the set 00496 std::vector< EntityHandle > adj; 00497 Range all, adjacent; 00498 Range::iterator in = adjacent.begin(); 00499 mb.get_entities_by_handle( 0, all ); 00500 for( Range::iterator i = all.begin(); i != all.end(); ++i ) 00501 { 00502 adj.clear(); 00503 rval = mb.a_entity_factory()->get_adjacencies( *i, adj );CHECK_ERR( rval ); 00504 std::vector< EntityHandle >::iterator j = std::lower_bound( adj.begin(), adj.end(), set ); 00505 if( j != adj.end() && *j == set ) in = adjacent.insert( in, *i, *i ); 00506 } 00507 00508 if( range != adjacent ) 00509 { 00510 std::cout << "Incorrect adjacent entities for tracking set" << std::endl; 00511 print_mbrange( "Expected", range ); 00512 print_mbrange( "Actual", adjacent ); 00513 return false; 00514 } 00515 00516 return true; 00517 } 00518 00519 bool check_set_contents( Core& mb, EntityType type, EntityHandle set, unsigned flags ) 00520 { 00521 ErrorCode rval; 00522 int count; 00523 std::vector< EntityHandle > vect, expected; 00524 Range range; 00525 00526 rval = mb.get_entities_by_handle( set, expected, false );CHECK_ERR( rval ); 00527 std::vector< EntityHandle >::iterator i = expected.begin(); 00528 while( i != expected.end() ) 00529 { 00530 if( TYPE_FROM_HANDLE( *i ) != type ) 00531 i = expected.erase( i ); 00532 else 00533 ++i; 00534 } 00535 00536 rval = mb.get_entities_by_type( set, type, range, false );CHECK_ERR( rval ); 00537 rval = mb.get_number_entities_by_type( set, type, count, false );CHECK_ERR( rval ); 00538 00539 std::copy( range.begin(), range.end(), std::back_inserter( vect ) ); 00540 return compare_set_contents( flags, expected, count, vect, range ); 00541 } 00542 00543 bool check_set_contents( Core& mb, int dim, EntityHandle set, unsigned flags ) 00544 { 00545 ErrorCode rval; 00546 int count; 00547 std::vector< EntityHandle > vect, expected; 00548 Range range; 00549 00550 rval = mb.get_entities_by_handle( set, expected, false );CHECK_ERR( rval ); 00551 std::vector< EntityHandle >::iterator i = expected.begin(); 00552 while( i != expected.end() ) 00553 { 00554 if( CN::Dimension( TYPE_FROM_HANDLE( *i ) ) != dim ) 00555 i = expected.erase( i ); 00556 else 00557 ++i; 00558 } 00559 00560 rval = mb.get_entities_by_dimension( set, dim, range, false );CHECK_ERR( rval ); 00561 rval = mb.get_number_entities_by_dimension( set, dim, count, false );CHECK_ERR( rval ); 00562 00563 std::copy( range.begin(), range.end(), std::back_inserter( vect ) ); 00564 return compare_set_contents( flags, expected, count, vect, range ); 00565 } 00566 00567 void test_add_entities( unsigned flags ) 00568 { 00569 Core mb; 00570 make_mesh( mb ); 00571 00572 EntityHandle set; 00573 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 00574 00575 std::vector< EntityHandle > contents, vect; 00576 Range range; 00577 00578 range.clear(); 00579 range.insert( 11, 20 ); 00580 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00581 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00582 // [11,20] 00583 CHECK( check_set_contents( mb, set, contents ) ); 00584 00585 range.clear(); 00586 range.insert( 31, 40 ); 00587 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00588 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00589 // [11,20],[31,40] 00590 CHECK( check_set_contents( mb, set, contents ) ); 00591 00592 range.clear(); 00593 range.insert( 51, 60 ); 00594 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00595 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00596 // [11,20],[31,40],[51,60] 00597 CHECK( check_set_contents( mb, set, contents ) ); 00598 00599 range.clear(); 00600 range.insert( 71, 80 ); 00601 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00602 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00603 // [11,20],[31,40],[51,60],[71,80] 00604 CHECK( check_set_contents( mb, set, contents ) ); 00605 00606 range.clear(); 00607 range.insert( 91, 100 ); 00608 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00609 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00610 // [11,20],[31,40],[51,60],[71,80],[91,100] 00611 CHECK( check_set_contents( mb, set, contents ) ); 00612 00613 range.clear(); 00614 range.insert( 111, 120 ); 00615 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00616 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00617 // [11,20],[31,40],[51,60],[71,80],[91,100],[111,120] 00618 CHECK( check_set_contents( mb, set, contents ) ); 00619 00620 range.clear(); 00621 range.insert( 6, 12 ); 00622 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00623 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00624 // [6,20],[31,40],[51,60],[71,80],[91,100],[111,120] 00625 CHECK( check_set_contents( mb, set, contents ) ); 00626 00627 range.clear(); 00628 range.insert( 1, 3 ); 00629 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00630 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00631 // [1,3],[6,20],[31,40],[51,60],[71,80],[91,100],[111,120] 00632 CHECK( check_set_contents( mb, set, contents ) ); 00633 00634 range.clear(); 00635 range.insert( 25, 25 ); 00636 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00637 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00638 // [1,3],[6,20],[25,25],[31,40],[51,60],[71,80],[91,100],[111,120] 00639 CHECK( check_set_contents( mb, set, contents ) ); 00640 00641 range.clear(); 00642 range.insert( 30, 30 ); 00643 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00644 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00645 // [1,3],[6,20],[25,25],[30,40],[51,60],[71,80],[91,100],[111,120] 00646 CHECK( check_set_contents( mb, set, contents ) ); 00647 00648 range.clear(); 00649 range.insert( 29, 31 ); 00650 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00651 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00652 // [1,3],[6,20],[25,25],[29,40],[51,60],[71,80],[91,100],[111,120] 00653 CHECK( check_set_contents( mb, set, contents ) ); 00654 00655 range.clear(); 00656 range.insert( 41, 41 ); 00657 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00658 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00659 // [1,3],[6,20],[25,25],[29,41],[51,60],[71,80],[91,100],[111,120] 00660 CHECK( check_set_contents( mb, set, contents ) ); 00661 00662 range.clear(); 00663 range.insert( 41, 45 ); 00664 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00665 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00666 // [1,3],[6,20],[25,25],[29,45],[51,60],[71,80],[91,100],[111,120] 00667 CHECK( check_set_contents( mb, set, contents ) ); 00668 00669 range.clear(); 00670 range.insert( 47, 47 ); 00671 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00672 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00673 // [1,3],[6,20],[25,25],[29,45],[47,47],[51,60],[71,80],[91,100],[111,120] 00674 CHECK( check_set_contents( mb, set, contents ) ); 00675 00676 range.clear(); 00677 range.insert( 51, 80 ); 00678 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00679 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00680 // [1,3],[6,20],[25,25],[29,45],[47,47],[51,80],[91,100],[111,120] 00681 CHECK( check_set_contents( mb, set, contents ) ); 00682 00683 range.clear(); 00684 range.insert( 49, 105 ); 00685 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00686 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00687 // [1,3],[6,20],[25,25],[29,45],[47,47],[49,105],[111,120] 00688 CHECK( check_set_contents( mb, set, contents ) ); 00689 00690 vect.clear(); 00691 for( EntityHandle h = 1; h < 100; ++h ) 00692 { 00693 vect.push_back( h ); 00694 contents.push_back( h ); 00695 } 00696 rval = mb.add_entities( set, &vect[0], vect.size() );CHECK_ERR( rval ); 00697 // [1,105],[111,120] 00698 CHECK( check_set_contents( mb, set, contents ) ); 00699 00700 vect.clear(); 00701 vect.push_back( 106 ); 00702 vect.push_back( 108 ); 00703 vect.push_back( 110 ); 00704 std::copy( vect.begin(), vect.end(), std::back_inserter( contents ) ); 00705 rval = mb.add_entities( set, &vect[0], vect.size() );CHECK_ERR( rval ); 00706 // [1,106],[108,108],[110,120] 00707 CHECK( check_set_contents( mb, set, contents ) ); 00708 00709 range.clear(); 00710 range.insert( 107, 200 ); 00711 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00712 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00713 // [1,200] 00714 CHECK( check_set_contents( mb, set, contents ) ); 00715 00716 range.clear(); 00717 range.insert( 1, 1 ); 00718 range.insert( 5, 6 ); 00719 range.insert( 199, 200 ); 00720 range.insert( 201, 202 ); 00721 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00722 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00723 // [1,202] 00724 CHECK( check_set_contents( mb, set, contents ) ); 00725 00726 range.clear(); 00727 range.insert( 300, 301 ); 00728 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00729 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00730 // [1,202],[300,301] 00731 CHECK( check_set_contents( mb, set, contents ) ); 00732 00733 range.clear(); 00734 range.insert( 203, 203 ); 00735 range.insert( 205, 205 ); 00736 range.insert( 207, 207 ); 00737 range.insert( 299, 299 ); 00738 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00739 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00740 // [1,203],[205,205],[207,207],[299,301] 00741 CHECK( check_set_contents( mb, set, contents ) ); 00742 } 00743 00744 void remove_from_back( std::vector< EntityHandle >& vect, const Range& range ) 00745 { 00746 for( Range::const_iterator r = range.begin(); r != range.end(); ++r ) 00747 { 00748 std::vector< EntityHandle >::reverse_iterator i = find( vect.rbegin(), vect.rend(), *r ); 00749 if( i != vect.rend() ) *i = 0; 00750 } 00751 std::vector< EntityHandle >::iterator j = vect.begin(); 00752 while( j != vect.end() ) 00753 { 00754 if( *j == 0 ) 00755 j = vect.erase( j ); 00756 else 00757 ++j; 00758 } 00759 } 00760 00761 void test_remove_entities( unsigned flags ) 00762 { 00763 Core mb; 00764 make_mesh( mb ); 00765 00766 EntityHandle set; 00767 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 00768 00769 std::vector< EntityHandle > contents; 00770 Range range; 00771 00772 range.clear(); 00773 range.insert( 1, 1000 ); 00774 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00775 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00776 // [1,1000] 00777 CHECK( check_set_contents( mb, set, contents ) ); 00778 00779 range.clear(); 00780 range.insert( 1, 5 ); 00781 remove_from_back( contents, range ); 00782 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00783 // [6,1000] 00784 CHECK( check_set_contents( mb, set, contents ) ); 00785 00786 range.clear(); 00787 range.insert( 6, 6 ); 00788 remove_from_back( contents, range ); 00789 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00790 // [7,1000] 00791 CHECK( check_set_contents( mb, set, contents ) ); 00792 00793 range.clear(); 00794 range.insert( 7, 10 ); 00795 remove_from_back( contents, range ); 00796 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00797 // [11,1000] 00798 CHECK( check_set_contents( mb, set, contents ) ); 00799 00800 range.clear(); 00801 range.insert( 1, 20 ); 00802 remove_from_back( contents, range ); 00803 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00804 // [21,1000] 00805 CHECK( check_set_contents( mb, set, contents ) ); 00806 00807 range.clear(); 00808 range.insert( 1, 5 ); 00809 remove_from_back( contents, range ); 00810 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00811 // [21,1000] 00812 CHECK( check_set_contents( mb, set, contents ) ); 00813 00814 range.clear(); 00815 range.insert( 22, 30 ); 00816 remove_from_back( contents, range ); 00817 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00818 // [21,21],[31,1000] 00819 CHECK( check_set_contents( mb, set, contents ) ); 00820 00821 range.clear(); 00822 range.insert( 1000, 1000 ); 00823 remove_from_back( contents, range ); 00824 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00825 // [21,21],[31,999] 00826 CHECK( check_set_contents( mb, set, contents ) ); 00827 00828 range.clear(); 00829 range.insert( 901, 999 ); 00830 remove_from_back( contents, range ); 00831 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00832 // [21,21],[31,900] 00833 CHECK( check_set_contents( mb, set, contents ) ); 00834 00835 range.clear(); 00836 range.insert( 900, 999 ); 00837 remove_from_back( contents, range ); 00838 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00839 // [21,21],[31,899] 00840 CHECK( check_set_contents( mb, set, contents ) ); 00841 00842 range.clear(); 00843 range.insert( 1000, 1001 ); 00844 remove_from_back( contents, range ); 00845 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00846 // [21,21],[31,899] 00847 CHECK( check_set_contents( mb, set, contents ) ); 00848 00849 range.clear(); 00850 range.insert( 890, 898 ); 00851 remove_from_back( contents, range ); 00852 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00853 // [21,21],[31,889],[899,899] 00854 CHECK( check_set_contents( mb, set, contents ) ); 00855 00856 range.clear(); 00857 range.insert( 100, 149 ); 00858 remove_from_back( contents, range ); 00859 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00860 // [21,21],[31,99],[150,889],[899,899] 00861 CHECK( check_set_contents( mb, set, contents ) ); 00862 00863 range.clear(); 00864 range.insert( 31, 99 ); 00865 remove_from_back( contents, range ); 00866 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00867 // [21,21],[150,889],[899,899] 00868 CHECK( check_set_contents( mb, set, contents ) ); 00869 00870 range.clear(); 00871 range.insert( 200, 249 ); 00872 remove_from_back( contents, range ); 00873 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00874 // [21,21],[150,199],[250,889],[899,899] 00875 CHECK( check_set_contents( mb, set, contents ) ); 00876 00877 range.clear(); 00878 range.insert( 300, 349 ); 00879 remove_from_back( contents, range ); 00880 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00881 // [21,21],[150,199],[250,299],[350,889],[899,899] 00882 CHECK( check_set_contents( mb, set, contents ) ); 00883 00884 range.clear(); 00885 range.insert( 159, 399 ); 00886 remove_from_back( contents, range ); 00887 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00888 // [21,21],[150,158],[400,889],[899,899] 00889 CHECK( check_set_contents( mb, set, contents ) ); 00890 00891 range.clear(); 00892 range.insert( 450, 499 ); 00893 remove_from_back( contents, range ); 00894 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00895 // [21,21],[150,158],[400,449],[500,889],[899,899] 00896 CHECK( check_set_contents( mb, set, contents ) ); 00897 00898 range.clear(); 00899 range.insert( 550, 599 ); 00900 remove_from_back( contents, range ); 00901 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00902 // [21,21],[150,158],[400,449],[500,549],[600,889],[899,899] 00903 CHECK( check_set_contents( mb, set, contents ) ); 00904 00905 range.clear(); 00906 range.insert( 150, 549 ); 00907 remove_from_back( contents, range ); 00908 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00909 // [21,21],[600,889],[899,899] 00910 CHECK( check_set_contents( mb, set, contents ) ); 00911 00912 range.clear(); 00913 range.insert( 650, 699 ); 00914 remove_from_back( contents, range ); 00915 rval = mb.remove_entities( set, range );CHECK_ERR( rval ); 00916 // [21,21],[600,649],[700,889],[899,899] 00917 CHECK( check_set_contents( mb, set, contents ) ); 00918 00919 // test vector-based remove 00920 assert( contents.size() == 242 ); 00921 std::vector< EntityHandle > remlist( 5 ); 00922 remlist[0] = contents[240]; 00923 contents.erase( contents.begin() + 240 ); 00924 remlist[1] = contents[200]; 00925 contents.erase( contents.begin() + 200 ); 00926 remlist[2] = contents[100]; 00927 contents.erase( contents.begin() + 100 ); 00928 remlist[3] = contents[25]; 00929 contents.erase( contents.begin() + 25 ); 00930 remlist[4] = contents[0]; 00931 contents.erase( contents.begin() + 0 ); 00932 rval = mb.remove_entities( set, &remlist[0], remlist.size() );CHECK_ERR( rval ); 00933 // [600,623],[625,649],[700,748],[750,848],[850,888],[899,899] 00934 CHECK( check_set_contents( mb, set, contents ) ); 00935 00936 // remove everything 00937 std::reverse( contents.begin(), contents.begin() + contents.size() / 2 ); // mix up a bit 00938 rval = mb.remove_entities( set, &contents[0], contents.size() );CHECK_ERR( rval ); 00939 contents.clear(); 00940 CHECK( check_set_contents( mb, set, contents ) ); 00941 00942 // try complicated range-based remove 00943 range.clear(); 00944 contents.clear(); 00945 range.insert( 100, 200 ); 00946 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00947 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00948 // [1000,2000] 00949 CHECK( check_set_contents( mb, set, contents ) ); 00950 00951 Range remove; 00952 remove.insert( 1, 3 ); 00953 remove.insert( 10, 100 ); 00954 remove.insert( 110, 120 ); 00955 remove.insert( 130, 140 ); 00956 remove.insert( 150, 160 ); 00957 remove.insert( 190, 200 ); 00958 remove.insert( 210, 220 ); 00959 remove.insert( 230, 240 ); 00960 range = subtract( range, remove ); 00961 00962 contents.clear(); 00963 std::copy( range.begin(), range.end(), std::back_inserter( contents ) ); 00964 rval = mb.remove_entities( set, remove );CHECK_ERR( rval ); 00965 CHECK( check_set_contents( mb, set, contents ) ); 00966 } 00967 00968 void test_entities_by_type( unsigned flags ) 00969 { 00970 EntityHandle first_vert, last_vert, first_hex, last_hex; 00971 Core mb; 00972 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 00973 00974 // Create an entity set 00975 EntityHandle set; 00976 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 00977 00978 // Test empty set 00979 CHECK( check_set_contents( mb, MBVERTEX, set, flags ) ); 00980 CHECK( check_set_contents( mb, MBEDGE, set, flags ) ); 00981 CHECK( check_set_contents( mb, MBHEX, set, flags ) ); 00982 00983 // Add stuff to set 00984 Range range; 00985 range.insert( first_vert, first_vert + 10 ); 00986 range.insert( first_vert + 100, first_vert + 110 ); 00987 range.insert( first_hex + 200, first_hex + 299 ); 00988 range.insert( last_hex, last_hex - 99 ); 00989 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 00990 00991 // Test 00992 CHECK( check_set_contents( mb, MBVERTEX, set, flags ) ); 00993 CHECK( check_set_contents( mb, MBEDGE, set, flags ) ); 00994 CHECK( check_set_contents( mb, MBHEX, set, flags ) ); 00995 } 00996 00997 void test_entities_by_dimension( unsigned flags ) 00998 { 00999 EntityHandle first_vert, last_vert, first_hex, last_hex; 01000 Core mb; 01001 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 01002 01003 // Create an entity set 01004 EntityHandle set; 01005 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 01006 01007 // Test empty set 01008 CHECK( check_set_contents( mb, 0, set, flags ) ); 01009 CHECK( check_set_contents( mb, 1, set, flags ) ); 01010 CHECK( check_set_contents( mb, 2, set, flags ) ); 01011 CHECK( check_set_contents( mb, 3, set, flags ) ); 01012 01013 // Add stuff to set 01014 Range range; 01015 range.insert( first_vert, first_vert + 10 ); 01016 range.insert( first_vert + 100, first_vert + 110 ); 01017 range.insert( first_hex + 200, first_hex + 299 ); 01018 range.insert( last_hex, last_hex - 99 ); 01019 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 01020 01021 // Test 01022 CHECK( check_set_contents( mb, 0, set, flags ) ); 01023 CHECK( check_set_contents( mb, 1, set, flags ) ); 01024 CHECK( check_set_contents( mb, 2, set, flags ) ); 01025 CHECK( check_set_contents( mb, 3, set, flags ) ); 01026 } 01027 01028 bool test_boolean( Core& mb, 01029 BoolOp op, 01030 unsigned flags1, 01031 const Range& set1_ents, 01032 unsigned flags2, 01033 const Range& set2_ents ) 01034 { 01035 ErrorCode rval; 01036 01037 // make sets 01038 EntityHandle set1, set2; 01039 rval = mb.create_meshset( flags1, set1 );CHECK_ERR( rval ); 01040 rval = mb.create_meshset( flags2, set2 );CHECK_ERR( rval ); 01041 rval = mb.add_entities( set1, set1_ents );CHECK_ERR( rval ); 01042 rval = mb.add_entities( set2, set2_ents );CHECK_ERR( rval ); 01043 01044 Range tmp_range; 01045 std::vector< EntityHandle > expected; 01046 rval = MB_INDEX_OUT_OF_RANGE; 01047 switch( op ) 01048 { 01049 case UNITE: 01050 if( flags1 & MESHSET_SET ) 01051 { 01052 tmp_range = set1_ents; 01053 tmp_range.merge( set2_ents ); 01054 expected.resize( tmp_range.size() ); 01055 std::copy( tmp_range.begin(), tmp_range.end(), expected.begin() ); 01056 } 01057 else 01058 { 01059 expected.clear(); 01060 std::copy( set1_ents.begin(), set1_ents.end(), std::back_inserter( expected ) ); 01061 std::copy( set2_ents.begin(), set2_ents.end(), std::back_inserter( expected ) ); 01062 } 01063 rval = mb.unite_meshset( set1, set2 ); 01064 break; 01065 case INTERSECT: 01066 tmp_range = intersect( set1_ents, set2_ents ); 01067 expected.resize( tmp_range.size() ); 01068 std::copy( tmp_range.begin(), tmp_range.end(), expected.begin() ); 01069 rval = mb.intersect_meshset( set1, set2 ); 01070 break; 01071 case SUBTRACT: 01072 tmp_range = subtract( set1_ents, set2_ents ); 01073 expected.resize( tmp_range.size() ); 01074 std::copy( tmp_range.begin(), tmp_range.end(), expected.begin() ); 01075 rval = mb.subtract_meshset( set1, set2 ); 01076 break; 01077 } 01078 CHECK_ERR( rval ); 01079 01080 return check_set_contents( mb, set1, expected ); 01081 } 01082 01083 void test_intersect( unsigned flags1, unsigned flags2 ) 01084 { 01085 Range empty, set1_ents, set2_ents; 01086 EntityHandle first_vert, last_vert, first_hex, last_hex; 01087 Core mb; 01088 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 01089 01090 // define contents of first set 01091 set1_ents.insert( first_vert, first_vert + 10 ); 01092 set1_ents.insert( first_vert + 100, first_vert + 199 ); 01093 set1_ents.insert( first_hex + 100, first_hex + 200 ); 01094 01095 // define contents of second set 01096 set2_ents.insert( first_vert, first_vert ); 01097 set2_ents.insert( first_vert + 10, first_vert + 10 ); 01098 set2_ents.insert( first_vert + 90, first_vert + 209 ); 01099 set2_ents.insert( first_hex + 50, first_hex + 300 ); 01100 01101 // check empty sets 01102 CHECK( test_boolean( mb, INTERSECT, flags1, empty, flags2, empty ) ); 01103 // check intersection with 1 empty 01104 CHECK( test_boolean( mb, INTERSECT, flags1, empty, flags2, set2_ents ) ); 01105 CHECK( test_boolean( mb, INTERSECT, flags1, set1_ents, flags2, empty ) ); 01106 // check intersection of non-empty sets 01107 CHECK( test_boolean( mb, INTERSECT, flags1, set1_ents, flags2, set2_ents ) ); 01108 } 01109 01110 void test_unite( unsigned flags1, unsigned flags2 ) 01111 { 01112 Range empty, set1_ents, set2_ents; 01113 EntityHandle first_vert, last_vert, first_hex, last_hex; 01114 Core mb; 01115 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 01116 01117 // define contents of first set 01118 set1_ents.insert( first_vert, first_vert + 10 ); 01119 set1_ents.insert( first_vert + 100, first_vert + 199 ); 01120 set1_ents.insert( first_hex + 100, first_hex + 200 ); 01121 01122 // define contents of second set 01123 set2_ents.insert( first_vert, first_vert ); 01124 set2_ents.insert( first_vert + 11, first_vert + 99 ); 01125 set2_ents.insert( first_vert + 150, first_vert + 209 ); 01126 set2_ents.insert( first_vert + 211, first_vert + 211 ); 01127 set2_ents.insert( first_hex + 50, first_hex + 99 ); 01128 01129 // check empty sets 01130 CHECK( test_boolean( mb, UNITE, flags1, empty, flags2, empty ) ); 01131 // check union with 1 empty 01132 CHECK( test_boolean( mb, UNITE, flags1, empty, flags2, set2_ents ) ); 01133 CHECK( test_boolean( mb, UNITE, flags1, set1_ents, flags2, empty ) ); 01134 // check union of non-empty sets 01135 CHECK( test_boolean( mb, UNITE, flags1, set1_ents, flags2, set2_ents ) ); 01136 } 01137 01138 void test_subtract( unsigned flags1, unsigned flags2 ) 01139 { 01140 Range empty, set1_ents, set2_ents; 01141 EntityHandle first_vert, last_vert, first_hex, last_hex; 01142 Core mb; 01143 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 01144 01145 // define contents of first set 01146 set1_ents.insert( first_vert, first_vert + 10 ); 01147 set1_ents.insert( first_vert + 100, first_vert + 199 ); 01148 set1_ents.insert( first_hex + 100, first_hex + 200 ); 01149 01150 // define contents of second set 01151 set2_ents.insert( first_vert, first_vert ); 01152 set2_ents.insert( first_vert + 9, first_vert + 9 ); 01153 set2_ents.insert( first_vert + 11, first_vert + 99 ); 01154 set2_ents.insert( first_vert + 150, first_vert + 199 ); 01155 set2_ents.insert( first_hex + 50, first_hex + 60 ); 01156 set2_ents.insert( first_hex + 90, first_hex + 220 ); 01157 01158 // check empty sets 01159 CHECK( test_boolean( mb, SUBTRACT, flags1, empty, flags2, empty ) ); 01160 // check union with 1 empty 01161 CHECK( test_boolean( mb, SUBTRACT, flags1, empty, flags2, set2_ents ) ); 01162 CHECK( test_boolean( mb, SUBTRACT, flags1, set1_ents, flags2, empty ) ); 01163 // check union of non-empty sets 01164 CHECK( test_boolean( mb, SUBTRACT, flags1, set1_ents, flags2, set2_ents ) ); 01165 } 01166 01167 void test_contains_entities( unsigned flags ) 01168 { 01169 CHECK( !( flags & MESHSET_TRACK_OWNER ) ); 01170 MeshSet set( flags ); 01171 bool result; 01172 01173 const EntityHandle entities[] = { 1, 2, 3, 6, 10, 11, 25, 100 }; 01174 const int num_ents = sizeof( entities ) / sizeof( EntityHandle ); 01175 ErrorCode rval = set.add_entities( entities, num_ents, 0, 0 );CHECK_ERR( rval ); 01176 01177 result = set.contains_entities( entities, num_ents, Interface::UNION ); 01178 CHECK( result ); 01179 result = set.contains_entities( entities, num_ents, Interface::INTERSECT ); 01180 CHECK( result ); 01181 01182 result = set.contains_entities( entities, 1, Interface::UNION ); 01183 CHECK( result ); 01184 result = set.contains_entities( entities, 1, Interface::INTERSECT ); 01185 CHECK( result ); 01186 01187 const EntityHandle entities2[] = { 3, 4, 5 }; 01188 const int num_ents2 = sizeof( entities2 ) / sizeof( EntityHandle ); 01189 result = set.contains_entities( entities2, num_ents2, Interface::UNION ); 01190 CHECK( result ); 01191 result = set.contains_entities( entities2, num_ents2, Interface::INTERSECT ); 01192 CHECK( !result ); 01193 } 01194 01195 void test_clear( unsigned flags ) 01196 { 01197 std::vector< EntityHandle > contents( 4 ); 01198 Core mb; 01199 make_mesh( mb, contents[0], contents[1], contents[2], contents[3] ); 01200 EntityHandle set; 01201 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 01202 rval = mb.add_entities( set, &contents[0], contents.size() );CHECK_ERR( rval ); 01203 CHECK( check_set_contents( mb, set, contents ) ); 01204 rval = mb.clear_meshset( &set, 1 );CHECK_ERR( rval ); 01205 contents.clear(); 01206 CHECK( check_set_contents( mb, set, contents ) ); 01207 } 01208 01209 void regression_insert_set_1() 01210 { 01211 EntityHandle e = CREATE_HANDLE( MBEDGE, 0 ); 01212 EntityHandle q = CREATE_HANDLE( MBQUAD, 0 ); 01213 const EntityHandle initial_ranges[] = { 01214 0x7fe, 0x7fe, 0x802, 0x80b, 0xb3a, 0xb3c, 0xb6b, 0xb6b, 0xbed, 01215 0xbee, 0x19ff, 0x19ff, 0x1a0b, 0x1a0b, 0x1a16, 0x1a17, 0x1a56, 0x1a57, 01216 0x2554, 0x255c, e + 0x0099, e + 0x009b, e + 0x00c0, e + 0x00c2, e + 0x0729, e + 0x0732, e + 0x0a3b, 01217 e + 0x0a3d, e + 0x0ba9, e + 0x0bab, e + 0x2322, e + 0x232b, q + 0x00c, q + 0x017, q + 0x0e9, q + 0x112, 01218 q + 0x2f2, q + 0x303, q + 0x67e, q + 0x6a5, q + 0x866, q + 0x871, q + 0x8f5, q + 0x900, q + 0xc06, 01219 q + 0xc17, q + 0xc7e, q + 0xc9b, q + 0xce0, q + 0xd07 }; 01220 01221 const EntityHandle new_ranges[] = { 0x7e1, 0x829, 0xb37, 0xb63, 0xb6b, 0xb6b, 0xb73, 0xb75, 0xbed, 01222 0xbee, 0xc0b, 0xc10, 0x19fd, 0x19fd, 0x19ff, 0x19ff, 0x1a02, 0x1a04, 01223 0x1a0b, 0x1a0b, 0x1a11, 0x1a17, 0x1a1b, 0x1a23, 0x1a56, 0x1a57, 0x1a7c, 01224 0x1a96, 0x1bb5, 0x1bba, 0x254b, 0x2565, 0x25a5, 0x25bf }; 01225 01226 Core moab; 01227 Interface& mb = moab; 01228 ErrorCode rval; 01229 01230 EntityHandle set; 01231 rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval ); 01232 01233 Range init, add; 01234 for( size_t i = 0; i < sizeof( initial_ranges ) / sizeof( initial_ranges[0] ); i += 2 ) 01235 init.insert( initial_ranges[i], initial_ranges[i + 1] ); 01236 for( size_t i = 0; i < sizeof( new_ranges ) / sizeof( new_ranges[0] ); i += 2 ) 01237 add.insert( new_ranges[i], new_ranges[i + 1] ); 01238 01239 rval = mb.add_entities( set, init );CHECK_ERR( rval ); 01240 rval = mb.add_entities( set, add );CHECK_ERR( rval ); 01241 01242 std::vector< EntityHandle > contents; 01243 rval = mb.get_entities_by_handle( set, contents );CHECK_ERR( rval ); 01244 01245 init.merge( add ); 01246 Range::iterator r = init.begin(); 01247 std::vector< EntityHandle >::iterator v = contents.begin(); 01248 for( ;; ) 01249 { 01250 if( r == init.end() || v == contents.end() ) 01251 { 01252 CHECK( r == init.end() ); 01253 CHECK( v == contents.end() ); 01254 break; 01255 } 01256 CHECK_EQUAL( *r, *v ); 01257 ++r; 01258 ++v; 01259 } 01260 } 01261 01262 void test_all_iterators() 01263 { 01264 test_iterators( MESHSET_SET, true, false ); 01265 test_iterators( MESHSET_SET, false, true ); 01266 01267 test_iterators( MESHSET_ORDERED, true, false ); 01268 test_iterators( MESHSET_ORDERED, false, true ); 01269 } 01270 01271 void test_iterators( unsigned int flags, bool test_type, bool test_dim ) 01272 { 01273 if( test_type && test_dim ) CHECK_ERR( MB_FAILURE ); 01274 01275 EntityHandle first_vert, last_vert, first_hex, last_hex; 01276 Core mb; 01277 make_mesh( mb, first_vert, last_vert, first_hex, last_hex ); 01278 01279 // Create an entity set 01280 EntityHandle set; 01281 ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval ); 01282 01283 // Test iteration over empty set 01284 SetIterator* iter = NULL; 01285 rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 1, false, iter );CHECK_ERR( rval ); 01286 if( NULL != iter ) 01287 { 01288 test_iterator( mb, iter, set, MBMAXTYPE, -1 ); 01289 delete iter; 01290 iter = NULL; 01291 } 01292 01293 rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 100, false, iter );CHECK_ERR( rval ); 01294 if( NULL != iter ) 01295 { 01296 test_iterator( mb, iter, set, MBMAXTYPE, -1 ); 01297 delete iter; 01298 iter = NULL; 01299 } 01300 01301 rval = mb.create_set_iterator( set, MBMAXTYPE, 0, 1, false, iter );CHECK_ERR( rval ); 01302 if( NULL != iter ) 01303 { 01304 test_iterator( mb, iter, set, MBMAXTYPE, 0 ); 01305 delete iter; 01306 iter = NULL; 01307 } 01308 01309 rval = mb.create_set_iterator( set, MBMAXTYPE, 3, 1, false, iter );CHECK_ERR( rval ); 01310 if( NULL != iter ) 01311 { 01312 test_iterator( mb, iter, set, MBMAXTYPE, 3 ); 01313 delete iter; 01314 iter = NULL; 01315 } 01316 01317 // Add stuff to set 01318 Range range; 01319 range.insert( first_vert, first_vert + 10 ); 01320 range.insert( first_vert + 100, first_vert + 110 ); 01321 range.insert( first_hex + 200, first_hex + 299 ); 01322 range.insert( last_hex, last_hex - 99 ); 01323 rval = mb.add_entities( set, range );CHECK_ERR( rval ); 01324 01325 EntityType etype = MBVERTEX; 01326 int edim = -1; 01327 if( test_dim && !test_type ) 01328 { 01329 edim = 0; 01330 etype = MBMAXTYPE; 01331 } 01332 01333 // Test 01334 // chunk size 1 01335 rval = mb.create_set_iterator( set, etype, edim, 1, false, iter );CHECK_ERR( rval ); 01336 if( NULL != iter ) 01337 { 01338 test_iterator( mb, iter, set, etype, edim ); 01339 delete iter; 01340 iter = NULL; 01341 } 01342 01343 // chunk size 3 01344 rval = mb.create_set_iterator( set, etype, edim, 3, false, iter );CHECK_ERR( rval ); 01345 if( NULL != iter ) 01346 { 01347 test_iterator( mb, iter, set, etype, edim ); 01348 delete iter; 01349 iter = NULL; 01350 } 01351 01352 // chunk size 11 01353 rval = mb.create_set_iterator( set, etype, edim, 11, false, iter );CHECK_ERR( rval ); 01354 if( NULL != iter ) 01355 { 01356 test_iterator( mb, iter, set, etype, edim ); 01357 delete iter; 01358 iter = NULL; 01359 } 01360 01361 // chunk size 100 01362 rval = mb.create_set_iterator( set, etype, edim, 100, false, iter );CHECK_ERR( rval ); 01363 if( NULL != iter ) 01364 { 01365 test_iterator( mb, iter, set, etype, edim ); 01366 delete iter; 01367 iter = NULL; 01368 } 01369 01370 if( test_type ) 01371 { 01372 // chunk size 1, all ents 01373 rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 1, false, iter );CHECK_ERR( rval ); 01374 if( NULL != iter ) 01375 { 01376 test_iterator( mb, iter, set, MBMAXTYPE, -1 ); 01377 delete iter; 01378 iter = NULL; 01379 } 01380 01381 // chunk size 3, all ents 01382 rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 3, false, iter );CHECK_ERR( rval ); 01383 if( NULL != iter ) 01384 { 01385 test_iterator( mb, iter, set, MBMAXTYPE, -1 ); 01386 delete iter; 01387 iter = NULL; 01388 } 01389 01390 // chunk size large, all ents 01391 rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 100000, false, iter );CHECK_ERR( rval ); 01392 if( NULL != iter ) 01393 { 01394 test_iterator( mb, iter, set, MBMAXTYPE, -1 ); 01395 delete iter; 01396 iter = NULL; 01397 } 01398 01399 etype = MBEDGE; 01400 // edges, chunk size 1 01401 rval = mb.create_set_iterator( set, etype, edim, 1, false, iter );CHECK_ERR( rval ); 01402 if( NULL != iter ) 01403 { 01404 test_iterator( mb, iter, set, etype, edim ); 01405 delete iter; 01406 iter = NULL; 01407 } 01408 01409 // edges, chunk size 100 01410 rval = mb.create_set_iterator( set, etype, edim, 100, false, iter );CHECK_ERR( rval ); 01411 if( NULL != iter ) 01412 { 01413 test_iterator( mb, iter, set, etype, edim ); 01414 delete iter; 01415 iter = NULL; 01416 } 01417 01418 etype = MBHEX; 01419 01420 // hexes, chunk size 1 01421 rval = mb.create_set_iterator( set, etype, edim, 1, false, iter );CHECK_ERR( rval ); 01422 if( NULL != iter ) 01423 { 01424 test_iterator( mb, iter, set, etype, edim ); 01425 delete iter; 01426 iter = NULL; 01427 } 01428 01429 // hexes, chunk size 3 01430 rval = mb.create_set_iterator( set, etype, edim, 3, false, iter );CHECK_ERR( rval ); 01431 if( NULL != iter ) 01432 { 01433 test_iterator( mb, iter, set, etype, edim ); 01434 delete iter; 01435 iter = NULL; 01436 } 01437 01438 // hexes, chunk size 1000 01439 rval = mb.create_set_iterator( set, etype, edim, 1000, false, iter );CHECK_ERR( rval ); 01440 if( NULL != iter ) 01441 { 01442 test_iterator( mb, iter, set, etype, edim ); 01443 delete iter; 01444 iter = NULL; 01445 } 01446 } 01447 } 01448 01449 void test_iterator( Interface& moab, SetIterator* iter, EntityHandle set, EntityType etype, int dim ) 01450 { 01451 // iterate over the set, adding to contents 01452 std::vector< EntityHandle > entities, entities2; 01453 bool atend = false; 01454 ErrorCode rval; 01455 01456 while( !atend ) 01457 { 01458 rval = iter->get_next_arr( entities, atend );CHECK_ERR( rval ); 01459 } 01460 01461 // check contents against what's in the set 01462 if( MBMAXTYPE != etype ) 01463 { 01464 rval = moab.get_entities_by_type( set, etype, entities2 );CHECK_ERR( rval ); 01465 } 01466 else if( MBMAXTYPE == etype && -1 == dim ) 01467 { 01468 rval = moab.get_entities_by_handle( set, entities2 );CHECK_ERR( rval ); 01469 } 01470 else if( -1 != dim ) 01471 { 01472 rval = moab.get_entities_by_dimension( set, dim, entities2 );CHECK_ERR( rval ); 01473 } 01474 else 01475 { 01476 // error, one of those needs to be true 01477 CHECK_ERR( MB_FAILURE ); 01478 } 01479 01480 CHECK_EQUAL( entities.size(), entities2.size() ); 01481 }
