MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <sys/resource.h>#include <cstdlib>#include <cstdio>#include <cassert>#include <iostream>#include "moab/Core.hpp"#include "moab/ReadUtilIface.hpp"#include "VertexSequence.hpp"#include "StructuredElementSeq.hpp"#include "EntitySequence.hpp"#include "SequenceManager.hpp"#include "moab/HomXform.hpp"#include "moab/SetIterator.hpp"
Include dependency graph for perf.cpp:Go to the source code of this file.
Defines | |
| #define | IS_BUILDING_MB |
| #define | RC(msg) |
| #define | RR(msg) |
| #define | VINDEX(i, j, k) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) ) |
Functions | |
| void | testA (const int nelem, const double *coords) |
| void | testB (const int nelem, const double *coords, int *connect) |
| void | testC (const int nelem, const double *coords) |
| void | testD (const int nelem, const double *coords, int ver) |
| void | testE (const int nelem, const double *coords, int *connect) |
| void | print_time (const bool print_em, double &tot_time, double &utime, double &stime, long &imem, long &rmem) |
| void | query_vert_to_elem () |
| void | query_elem_to_vert () |
| void | query_struct_elem_to_vert () |
| void | query_elem_to_vert_direct () |
| void | query_vert_to_elem_direct () |
| ErrorCode | normalize_elems (double *coords) |
| void | check_answers (const char *) |
| void | compute_edge (double *start, const int nelem, const double xint, const int stride) |
| void | compute_face (double *a, const int nelem, const double xint, const int stride1, const int stride2) |
| void | build_coords (const int nelem, double *&coords) |
| void | build_connect (const int nelem, const EntityHandle, int *&connect) |
| void | init () |
| int | main (int argc, char *argv[]) |
| void | query_elem_to_vert_iters (int chunk_size, bool check_valid, std::vector< EntityHandle > &connect, double *dum_coords, double *dum_pos) |
| void | query_vert_to_elem_iters (int chunk_size, bool check_valid, std::vector< EntityHandle > &, double *dum_coords, double *dum_pos) |
Variables | |
| double | LENGTH = 1.0 |
| Interface * | gMB |
| Tag | pos_tag |
| Tag | pos2_tag |
| #define IS_BUILDING_MB |
MOAB, a Mesh-Oriented datABase, is a software component for creating, storing and accessing finite element mesh data.
Copyright 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government retains certain rights in this software.
This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
| #define RC | ( | msg | ) |
if( MB_SUCCESS != result ) do \ { \ std::cout << "FAIL in " << ( msg ) << std::endl; \ return; \ } while( true )
Definition at line 67 of file perf.cpp.
Referenced by check_answers(), query_elem_to_vert(), query_elem_to_vert_direct(), query_elem_to_vert_iters(), query_struct_elem_to_vert(), query_vert_to_elem(), query_vert_to_elem_iters(), testA(), testB(), testC(), testD(), and testE().
| #define RR | ( | msg | ) |
if( MB_SUCCESS != result ) do \ { \ std::cout << "FAIL in " << ( msg ) << std::endl; \ return result; \ } while( true )
Definition at line 73 of file perf.cpp.
Referenced by normalize_elems().
| #define VINDEX | ( | i, | |
| j, | |||
| k | |||
| ) | ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) ) |
| void build_connect | ( | const int | nelem, |
| const EntityHandle | , | ||
| int *& | connect | ||
Definition at line 268 of file perf.cpp.
References VINDEX.
// allocate the memory
int nume_tot = nelem * nelem * nelem;
connect = new int[8 * nume_tot];
EntityHandle vijk;
int numv = nelem + 1;
int numv_sq = numv * numv;
int idx = 0;
for( int i = 0; i < nelem; i++ )
for( int j = 0; j < nelem; j++ )
for( int k = 0; k < nelem; k++ )
vijk = VINDEX( i, j, k );
connect[idx++] = vijk;
connect[idx++] = vijk + 1;
connect[idx++] = vijk + 1 + numv;
connect[idx++] = vijk + numv;
connect[idx++] = vijk + numv * numv;
connect[idx++] = vijk + 1 + numv * numv;
connect[idx++] = vijk + 1 + numv + numv * numv;
connect[idx++] = vijk + numv + numv * numv;
assert( i <= numv * numv * numv );
| void build_coords | ( | const int | nelem, |
| double *& | coords | ||
Definition at line 125 of file perf.cpp.
References compute_edge(), compute_face(), LENGTH, print_time(), and VINDEX.
double ttime0 = 0.0, ttime1 = 0.0, utime1 = 0.0, stime1 = 0.0;
long imem = 0, rmem = 0;
print_time( false, ttime0, utime1, stime1, imem, rmem );
int tot_numv = numv * numv * numv;
coords = new double[3 * tot_numv];
// use FORTRAN-like indexing
#define VINDEX( i, j, k ) ( ( i ) + ( (j)*numv ) + ( (k)*numv_sq ) )
int idx;
double scale1, scale2, scale3;
// use these to prevent optimization on 1-scale, etc (real map wouldn't have
// all these equal)
scale1 = LENGTH / nelem;
scale2 = LENGTH / nelem;
scale3 = LENGTH / nelem;
#ifdef REALTFI
// use a real TFI xform to compute coordinates
// compute edges
// i (stride=1)
compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1 );
compute_edge( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, 1 );
compute_edge( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, 1 );
compute_edge( &coords[VINDEX( 0, nelem, nelem )], nelem, scale1, 1 );
// j (stride=numv)
compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv );
compute_edge( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv );
compute_edge( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, numv );
compute_edge( &coords[VINDEX( nelem, 0, nelem )], nelem, scale1, numv );
// k (stride=numv^2)
compute_edge( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv_sq );
compute_edge( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv_sq );
compute_edge( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, numv_sq );
compute_edge( &coords[VINDEX( nelem, nelem, 0 )], nelem, scale1, numv_sq );
// compute faces
// i=0, nelem
compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, numv, numv_sq );
compute_face( &coords[VINDEX( nelem, 0, 0 )], nelem, scale1, numv, numv_sq );
// j=0, nelem
compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv_sq );
compute_face( &coords[VINDEX( 0, nelem, 0 )], nelem, scale1, 1, numv_sq );
// k=0, nelem
compute_face( &coords[VINDEX( 0, 0, 0 )], nelem, scale1, 1, numv );
compute_face( &coords[VINDEX( 0, 0, nelem )], nelem, scale1, 1, numv );
// initialize corner indices
int i000 = VINDEX( 0, 0, 0 );
int ia00 = VINDEX( nelem, 0, 0 );
int i0t0 = VINDEX( 0, nelem, 0 );
int iat0 = VINDEX( nelem, nelem, 0 );
int i00g = VINDEX( 0, 0, nelem );
int ia0g = VINDEX( nelem, 0, nelem );
int i0tg = VINDEX( 0, nelem, nelem );
int iatg = VINDEX( nelem, nelem, nelem );
double cX, cY, cZ;
int adaInts = nelem;
int tseInts = nelem;
int gammaInts = nelem;
for( int i = 1; i < nelem; i++ )
for( int j = 1; j < nelem; j++ )
for( int k = 1; k < nelem; k++ )
// idx = VINDEX(i,j,k);
double tse = i * scale1;
double ada = j * scale2;
double gamma = k * scale3;
double tm1 = 1.0 - tse;
double am1 = 1.0 - ada;
double gm1 = 1.0 - gamma;
cX = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) +
ada * ( tm1 * coords[ia00] + tse * coords[iat0] ) ) +
gamma * ( am1 * ( tm1 * coords[i00g] + tse * coords[i0tg] ) +
ada * ( tm1 * coords[ia0g] + tse * coords[iatg] ) );
cY = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) +
cZ = gm1 * ( am1 * ( tm1 * coords[i000] + tse * coords[i0t0] ) +
double* ai0k = &coords[VINDEX( k, 0, i )];
double* aiak = &coords[VINDEX( k, adaInts, i )];
double* a0jk = &coords[VINDEX( k, j, 0 )];
double* atjk = &coords[VINDEX( k, j, tseInts )];
double* aij0 = &coords[VINDEX( 0, j, i )];
double* aijg = &coords[VINDEX( gammaInts, j, i )];
coords[VINDEX( i, j, k )] = ( am1 * ai0k[0] + ada * aiak[0] + tm1 * a0jk[0] + tse * atjk[0] +
gm1 * aij0[0] + gamma * aijg[0] ) /
2.0 -
cX / 2.0;
coords[nelem + 1 + VINDEX( i, j, k )] =
( am1 * ai0k[nelem + 1] + ada * aiak[nelem + 1] + tm1 * a0jk[nelem + 1] + tse * atjk[nelem + 1] +
gm1 * aij0[nelem + 1] + gamma * aijg[nelem + 1] ) /
2.0 -
cY / 2.0;
coords[2 * ( nelem + 1 ) + VINDEX( i, j, k )] =
( am1 * ai0k[2 * ( nelem + 1 )] + ada * aiak[2 * ( nelem + 1 )] + tm1 * a0jk[2 * ( nelem + 1 )] +
tse * atjk[2 * ( nelem + 1 )] + gm1 * aij0[2 * ( nelem + 1 )] +
gamma * aijg[2 * ( nelem + 1 )] ) /
2.0 -
cZ / 2.0;
#else
for( int i = 0; i < numv; i++ )
for( int j = 0; j < numv; j++ )
for( int k = 0; k < numv; k++ )
idx = VINDEX( i, j, k );
// blocked coordinate ordering
coords[idx] = i * scale1;
coords[tot_numv + idx] = j * scale2;
coords[2 * tot_numv + idx] = k * scale3;
#endif
print_time( false, ttime1, utime1, stime1, imem, rmem );
// std::cout << "MOAB: TFI time = " << ttime1-ttime0 << " sec"
// << std::endl;
| void check_answers | ( | const char * | ) |
Definition at line 1230 of file perf.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type(), gMB, MBHEX, pos2_tag, pos_tag, RC, and moab::Interface::tag_get_data().
Referenced by testA(), testB(), testC(), testD(), and testE().
Range elems;
ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, elems );
RC( "check_answers" );
double coords1[3], coords2[3], del[3];
double diff = 0.0;
for( Range::iterator vit = elems.begin(); vit != elems.end(); ++vit )
result = gMB->tag_get_data( pos_tag, &( *vit ), 1, coords1 );
result = gMB->tag_get_data( pos2_tag, &( *vit ), 1, coords2 );
for( int i = 0; i < 3; i++ )
del[i] = fabs( coords1[i] - coords2[i] );
if( del[0] || del[1] || del[2] )
double len2 = std::max( coords1[0] * coords1[0] + coords1[1] * coords1[1] + coords1[2] * coords1[2],
coords2[0] * coords2[0] + coords2[1] * coords2[1] + coords2[2] * coords2[2] ),
num = del[0] * del[0] + del[1] * del[1] + del[2] * del[2];
if( len2 > 0.0 )
diff = std::max( diff, num / sqrt( len2 ) );
else if( num > 0.0 )
diff = sqrt( num );
if( diff > 0.0 ) std::cout << "Max relative difference = " << diff << std::endl;
| void compute_edge | ( | double * | start, |
| const int | nelem, | ||
| const double | xint, | ||
| const int | stride | ||
Definition at line 80 of file perf.cpp.
Referenced by build_coords().
start[i * stride] = start[0] + i * xint;
start[nelem + 1 + i * stride] = start[nelem + 1] + i * xint;
start[2 * ( nelem + 1 ) + i * stride] = start[2 * ( nelem + 1 )] + i * xint;
| void compute_face | ( | double * | a, |
| const int | stride1, | ||
| const int | stride2 | ||
Definition at line 90 of file perf.cpp.
// 2D TFI on a face starting at a, with strides stride1 in ada and stride2 in tse
double tse = j * xint;
double ada = i * xint;
a[i * stride1 + j * stride2] =
( 1.0 - ada ) * a[i * stride1] + ada * a[i * stride1 + nelem * stride2] +
( 1.0 - tse ) * a[j * stride2] + tse * a[j * stride2 + nelem * stride1] -
( 1.0 - tse ) * ( 1.0 - ada ) * a[0] - ( 1.0 - tse ) * ada * a[nelem * stride1] -
tse * ( 1.0 - ada ) * a[nelem * stride2] - tse * ada * a[nelem * ( stride1 + stride2 )];
a[nelem + 1 + i * stride1 + j * stride2] =
( 1.0 - ada ) * a[nelem + 1 + i * stride1] + ada * a[nelem + 1 + i * stride1 + nelem * stride2] +
( 1.0 - tse ) * a[nelem + 1 + j * stride2] + tse * a[nelem + 1 + j * stride2 + nelem * stride1] -
( 1.0 - tse ) * ( 1.0 - ada ) * a[nelem + 1 + 0] -
( 1.0 - tse ) * ada * a[nelem + 1 + nelem * stride1] -
tse * ( 1.0 - ada ) * a[nelem + 1 + nelem * stride2] -
tse * ada * a[nelem + 1 + nelem * ( stride1 + stride2 )];
a[2 * ( nelem + 1 ) + i * stride1 + j * stride2] =
( 1.0 - ada ) * a[2 * ( nelem + 1 ) + i * stride1] +
ada * a[2 * ( nelem + 1 ) + i * stride1 + nelem * stride2] +
( 1.0 - tse ) * a[2 * ( nelem + 1 ) + j * stride2] +
tse * a[2 * ( nelem + 1 ) + j * stride2 + nelem * stride1] -
( 1.0 - tse ) * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + 0] -
( 1.0 - tse ) * ada * a[2 * ( nelem + 1 ) + nelem * stride1] -
tse * ( 1.0 - ada ) * a[2 * ( nelem + 1 ) + nelem * stride2] -
tse * ada * a[2 * ( nelem + 1 ) + nelem * ( stride1 + stride2 )];
| void init | ( | ) |
Definition at line 302 of file perf.cpp.
References ErrorCode, gMB, MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, pos2_tag, pos_tag, and moab::Interface::tag_get_handle().
Referenced by do_kdtree_test(), do_linear_test(), FBiGeom_getArrBoundBox(), main(), regression_insert_set_1(), moab::SpectralQuad::reverseEvalFcn(), moab::Core::tag_iterate(), test_optional_arg(), testA(), testB(), testC(), testD(), and testE().
gMB = new Core();
double def_val[3] = { 0.0, 0.0, 0.0 };
ErrorCode rval =
gMB->tag_get_handle( "position_tag", 3, MB_TYPE_DOUBLE, pos_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val );
assert( MB_SUCCESS == rval );
if( rval )
} // empty line to remove compiler warning
rval = gMB->tag_get_handle( "position2_tag", 3, MB_TYPE_DOUBLE, pos2_tag, MB_TAG_DENSE | MB_TAG_CREAT, def_val );
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 316 of file perf.cpp.
References build_connect(), build_coords(), testA(), testB(), testC(), testD(), and testE().
int nelem = 20;
if( argc < 3 )
std::cout << "Usage: " << argv[0] << " <ints_per_side> [A|B|C|D [1|2|3|4]|E]" << std::endl;
return 1;
char which_test = '\0';
int ver = 0;
sscanf( argv[1], "%d", &nelem );
if( argc >= 3 ) sscanf( argv[2], "%c", &which_test );
if( argc >= 4 ) sscanf( argv[3], "%d", &ver );
if( 3 <= argc && which_test != 'A' && which_test != 'B' && which_test != 'C' && which_test != 'D' &&
which_test != 'E' )
std::cout << "Must indicate A or B, C, D or E for test." << std::endl;
return 1;
if( 4 <= argc && which_test == 'D' && ( ver < 1 || ver > 4 ) )
std::cout << "Must indicate version 1, 2, 3, or 4 for test D." << std::endl;
return 1;
// std::cout << "number of elements: " << nelem << "; test "
// << which_test << std::endl;
// pre-build the coords array
double* coords = NULL;
build_coords( nelem, coords );
assert( NULL != coords );
int* connect = NULL;
// test A: create structured mesh
if( '\0' == which_test || 'A' == which_test ) testA( nelem, coords );
build_connect( nelem, 1, connect );
// test B: create mesh using bulk interface
if( '\0' == which_test || 'B' == which_test ) testB( nelem, coords, connect );
// test C: create mesh using individual interface
if( '\0' == which_test || 'C' == which_test ) testC( nelem, coords );
// test D: query mesh using iterators
if( '\0' == which_test || 'D' == which_test ) testD( nelem, coords, ver );
// test E: query mesh using direct access
if( '\0' == which_test || 'E' == which_test ) testE( nelem, coords, connect );
return 0;
| ErrorCode normalize_elems | ( | double * | coords | ) |
Definition at line 526 of file perf.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type(), gMB, MBHEX, pos2_tag, RR, moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by query_vert_to_elem(), and query_vert_to_elem_iters().
// get all hexes and divide pos_tag by 8
Range elems;
RR( "normalize" );
result = gMB->tag_get_data( pos2_tag, &( *vit ), 1, coords );
RR( "normalize" );
coords[0] *= 0.125;
coords[1] *= 0.125;
coords[2] *= 0.125;
result = gMB->tag_set_data( pos2_tag, &( *vit ), 1, coords );
RR( "normalize" );
return result;
| void print_time | ( | const bool | print_em, |
| double & | tot_time, | ||
| double & | utime, | ||
| double & | stime, | ||
| long & | imem, | ||
| long & | rmem | ||
Definition at line 586 of file perf.cpp.
struct rusage r_usage;
getrusage( RUSAGE_SELF, &r_usage );
utime = (double)r_usage.ru_utime.tv_sec + ( (double)r_usage.ru_utime.tv_usec / 1.e6 );
stime = (double)r_usage.ru_stime.tv_sec + ( (double)r_usage.ru_stime.tv_usec / 1.e6 );
tot_time = utime + stime;
if( print_em )
std::cout << "User, system, total time = " << utime << ", " << stime << ", " << tot_time << std::endl;
#ifndef LINUX
if( print_em )
std::cout << "Max resident set size = " << r_usage.ru_maxrss << " kbytes" << std::endl;
std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl;
imem = r_usage.ru_idrss;
rmem = r_usage.ru_maxrss;
#else
system( "ps o args,drs,rss | grep perf | grep -v grep" ); // RedHat 9.0 doesnt fill in actual
// memory data
imem = rmem = 0;
#endif
| void query_elem_to_vert | ( | ) |
Definition at line 375 of file perf.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), gMB, MBHEX, pos_tag, RC, and moab::Interface::tag_set_data().
Referenced by testB(), and testC().
Range all_hexes;
ErrorCode result = gMB->get_entities_by_type( 0, MBHEX, all_hexes );
RC( "query_elem_to_vert" );
const EntityHandle* connect;
int num_connect;
double dum_coords[24];
for( Range::iterator eit = all_hexes.begin(); eit != all_hexes.end(); ++eit )
result = gMB->get_connectivity( *eit, connect, num_connect );
result = gMB->get_coords( connect, num_connect, dum_coords );
// compute the centroid
double centroid[3] = { 0.0, 0.0, 0.0 };
for( int j = 0; j < 8; j++ )
centroid[0] += dum_coords[3 * j + 0];
centroid[1] += dum_coords[3 * j + 1];
centroid[2] += dum_coords[3 * j + 2];
centroid[0] *= 0.125;
centroid[1] *= 0.125;
centroid[2] *= 0.125;
result = gMB->tag_set_data( pos_tag, &( *eit ), 1, centroid );
| void query_elem_to_vert_direct | ( | ) |
Definition at line 1115 of file perf.cpp.
References moab::Range::begin(), moab::Interface::connect_iterate(), moab::Interface::coords_iterate(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_type(), gMB, MB_SUCCESS, MBHEX, MBVERTEX, pos_tag, RC, moab::Range::size(), and moab::Interface::tag_iterate().
Referenced by testE().
Range all_hexes, all_verts;
assert( MB_SUCCESS == result );
result = gMB->get_entities_by_type( 0, MBVERTEX, all_verts );
RC( "query_elem_to_vert_direct" );
int ecount, vcount, vpere;
double* coords[3];
result = gMB->connect_iterate( all_hexes.begin(), all_hexes.end(), connect, vpere, ecount );
if( MB_SUCCESS != result || ecount != (int)all_hexes.size() )
std::cout << "FAILED in connect_iterate!" << std::endl;
return;
result = gMB->coords_iterate( all_verts.begin(), all_verts.end(), coords[0], coords[1], coords[2], vcount );
if( MB_SUCCESS != result || vcount != (int)all_verts.size() )
std::cout << "FAILED in coords_iterate!" << std::endl;
return;
double* centroid;
result = gMB->tag_iterate( pos_tag, all_hexes.begin(), all_hexes.end(), ecount, (void*&)centroid );
return;
EntityHandle vstart = *all_verts.begin();
for( int i = 0; i < ecount; i++ )
for( int j = 0; j < vpere; j++ )
int vind = *connect - vstart;
connect++;
centroid[3 * i + 0] += coords[0][vind];
centroid[3 * i + 1] += coords[1][vind];
centroid[3 * i + 2] += coords[2][vind];
// now normalize
centroid[3 * i + 0] *= 0.125;
centroid[3 * i + 1] *= 0.125;
centroid[3 * i + 2] *= 0.125;
| void query_elem_to_vert_iters | ( | int | chunk_size, |
| bool | check_valid, | ||
| std::vector< EntityHandle > & | connect, | ||
| double * | dum_coords, | ||
| double * | dum_pos | ||
Definition at line 441 of file perf.cpp.
References moab::Interface::create_set_iterator(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::SetIterator::get_next_arr(), gMB, MBHEX, pos_tag, RC, moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by testD().
std::vector< EntityHandle > hexes;
SetIterator* iter;
ErrorCode result = gMB->create_set_iterator( 0, MBHEX, -1, chunk_size, check_valid, iter );
RC( "query_elem_to_vert_iters" );
bool atend = false;
while( !atend )
hexes.clear();
result = iter->get_next_arr( hexes, atend );
result = gMB->get_connectivity( &hexes[0], hexes.size(), connect );
result = gMB->get_coords( &connect[0], connect.size(), dum_coords );
result = gMB->tag_get_data( pos_tag, &hexes[0], hexes.size(), dum_pos );
for( unsigned int i = 0; i < hexes.size(); i++ )
dum_pos[3 * i + 0] += dum_coords[24 * i + 3 * j];
dum_pos[3 * i + 1] += dum_coords[24 * i + 3 * j + 1];
dum_pos[3 * i + 2] += dum_coords[24 * i + 3 * j + 2];
dum_pos[3 * i + 0] *= 0.125;
dum_pos[3 * i + 1] *= 0.125;
dum_pos[3 * i + 2] *= 0.125;
result = gMB->tag_set_data( pos_tag, &hexes[0], hexes.size(), dum_pos );
delete iter;
| void query_struct_elem_to_vert | ( | ) |
Definition at line 547 of file perf.cpp.
Referenced by testA().
// assumes brick mapped mesh with handles starting at zero
Range all_hexes;
RC( "query_struct_elem_to_vert" );
std::vector< EntityHandle > connect;
result = gMB->get_connectivity( &( *eit ), 1, connect );
| void query_vert_to_elem | ( | ) |
Definition at line 406 of file perf.cpp.
References moab::Range::begin(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_type(), gMB, MBVERTEX, normalize_elems(), pos2_tag, RC, moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
Referenced by testA(), testB(), and testC().
Range all_verts;
std::vector< EntityHandle > neighbor_hexes;
std::vector< double > neighbor_pos;
double coords[3];
neighbor_pos.resize( 3 * 8 ); // average vertex will have 8 adjacent hexes
ErrorCode result = gMB->get_entities_by_type( 0, MBVERTEX, all_verts );
RC( "query_vert_to_elem" );
for( Range::iterator vit = all_verts.begin(); vit != all_verts.end(); ++vit )
neighbor_hexes.clear();
result = gMB->get_coords( &( *vit ), 1, coords );
result = gMB->get_adjacencies( &( *vit ), 1, 3, false, neighbor_hexes );
assert( neighbor_pos.size() >= 3 * neighbor_hexes.size() );
result = gMB->tag_get_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), &neighbor_pos[0] );
for( unsigned int i = 0; i < neighbor_hexes.size(); i++ )
neighbor_pos[3 * i] += coords[0];
neighbor_pos[3 * i + 1] += coords[1];
neighbor_pos[3 * i + 2] += coords[2];
result = gMB->tag_set_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), &neighbor_pos[0] );
// get all hexes and divide pos_tag by 8; reuse all_verts
result = normalize_elems( coords );
| void query_vert_to_elem_direct | ( | ) |
Definition at line 1166 of file perf.cpp.
References moab::Interface::adjacencies_iterate(), moab::Range::begin(), moab::Range::clear(), moab::Interface::coords_iterate(), moab::Range::end(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_type(), gMB, MB_SUCCESS, MBHEX, MBVERTEX, pos2_tag, moab::Range::size(), and moab::Interface::tag_iterate().
Range all_verts, tmp_ents;
// make sure vertex-element adjacencies are created
result = gMB->get_adjacencies( &( *all_verts.begin() ), 1, 3, false, tmp_ents );
const std::vector< EntityHandle >** adjs;
int count;
result = gMB->adjacencies_iterate( all_verts.begin(), all_verts.end(), adjs, count );
if( MB_SUCCESS != result && count != (int)all_verts.size() )
std::cout << "FAILED:adjacencies_iterate." << std::endl;
return;
double* coords[3];
result = gMB->coords_iterate( all_verts.begin(), all_verts.end(), coords[0], coords[1], coords[2], count );
if( MB_SUCCESS != result || count != (int)all_verts.size() )
return;
// get all hexes, then iterator over pos2_tag
double* centroid;
int ecount;
tmp_ents.clear();
result = gMB->get_entities_by_type( 0, MBHEX, tmp_ents );
result = gMB->tag_iterate( pos2_tag, tmp_ents.begin(), tmp_ents.end(), ecount, (void*&)centroid );
if( MB_SUCCESS != result || ecount != (int)tmp_ents.size() )
std::cout << "FAILED in tag_iterate!" << std::endl;
return;
int i;
Range::iterator vit;
EntityHandle estart = *tmp_ents.begin();
for( vit = all_verts.begin(), i = 0; vit != all_verts.end(); ++vit, i++ )
assert( adjs[i] );
for( std::vector< EntityHandle >::const_iterator vit2 = adjs[i]->begin(); vit2 != adjs[i]->end(); ++vit2 )
if( *vit >= estart )
int eind = *vit2 - estart;
centroid[3 * eind + 0] += coords[0][i];
centroid[3 * eind + 1] += coords[1][i];
centroid[3 * eind + 2] += coords[2][i];
// now normalize
for( i = 0; i < (int)tmp_ents.size(); i++ )
| void query_vert_to_elem_iters | ( | int | chunk_size, |
| std::vector< EntityHandle > & | , | ||
Definition at line 483 of file perf.cpp.
References moab::Interface::create_set_iterator(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::SetIterator::get_next_arr(), gMB, MB_SUCCESS, MBVERTEX, normalize_elems(), pos2_tag, RC, moab::Interface::tag_get_data(), and moab::Interface::tag_set_data().
std::vector< EntityHandle > verts, neighbor_hexes;
SetIterator* iter;
ErrorCode result = gMB->create_set_iterator( 0, MBVERTEX, -1, chunk_size, check_valid, iter );
RC( "query_vert_to_elem_iters" );
bool atend = false;
while( !atend )
verts.clear();
result = iter->get_next_arr( verts, atend );
result = gMB->get_coords( &verts[0], verts.size(), dum_coords );
chunk_size = std::min( (int)verts.size(), chunk_size );
for( int i = 0; i < chunk_size; i++ )
result = gMB->get_adjacencies( &verts[i], 1, 3, false, neighbor_hexes );
result = gMB->tag_get_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), dum_pos );
for( unsigned int j = 0; j < neighbor_hexes.size(); j++ )
dum_pos[3 * j + 0] += dum_coords[3 * i + 0];
dum_pos[3 * j + 1] += dum_coords[3 * i + 1];
dum_pos[3 * j + 2] += dum_coords[3 * i + 2];
result = gMB->tag_set_data( pos2_tag, &neighbor_hexes[0], neighbor_hexes.size(), dum_pos );
result = normalize_elems( dum_coords );
| void testA | ( | const int | nelem, |
| const double * | coords | ||
Definition at line 611 of file perf.cpp.
References moab::ScdElementData::add_vsequence(), check_answers(), moab::SequenceManager::create_scd_sequence(), moab::EntitySequence::data(), ErrorCode, gMB, init(), MB_SUCCESS, mbcore, MBHEX, MBVERTEX, print_time(), query_struct_elem_to_vert(), query_vert_to_elem(), RC, moab::StructuredElementSeq::sdata(), moab::Core::sequence_manager(), and moab::Interface::set_coords().
Referenced by main().
double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, utime = 0.0, stime = 0.0;
long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0;
print_time( false, ttime0, utime, stime, imem0, rmem0 );
// make a 3d block of vertices
EntitySequence* dum_seq = NULL;
ScdVertexData* vseq = NULL;
StructuredElementSeq* eseq = NULL;
init();
Core* mbcore = dynamic_cast< Core* >( gMB );
assert( mbcore != NULL );
SequenceManager* seq_mgr = mbcore->sequence_manager();
HomCoord vseq_minmax[2] = { HomCoord( 0, 0, 0 ), HomCoord( nelem, nelem, nelem ) };
EntityHandle vstart, estart;
ErrorCode result = seq_mgr->create_scd_sequence( vseq_minmax[0], vseq_minmax[1], MBVERTEX, 1, vstart, dum_seq );
RC( "testA" );
if( NULL != dum_seq ) vseq = dynamic_cast< ScdVertexData* >( dum_seq->data() );
assert( MB_FAILURE != result && vstart != 0 && dum_seq != NULL && vseq != NULL );
// now the element sequence
result = seq_mgr->create_scd_sequence( vseq_minmax[0], vseq_minmax[1], MBHEX, 1, estart, dum_seq );
if( NULL != dum_seq ) eseq = dynamic_cast< StructuredElementSeq* >( dum_seq );
assert( MB_FAILURE != result && estart != 0 && dum_seq != NULL && eseq != NULL );
// only need to add one vseq to this, unity transform
// trick: if I know it's going to be unity, just input 3 sets of equivalent points
result = eseq->sdata()->add_vsequence( vseq, vseq_minmax[0], vseq_minmax[0], vseq_minmax[0], vseq_minmax[0],
vseq_minmax[0], vseq_minmax[0] );
// set the coordinates of the vertices
EntityHandle handle;
int i;
double dumv[3];
int num_verts = ( nelem + 1 ) * ( nelem + 1 ) * ( nelem + 1 );
for( i = 0, handle = vstart; i < num_verts; i++, handle++ )
dumv[0] = coords[i];
dumv[1] = coords[num_verts + i];
dumv[2] = coords[2 * num_verts + i];
result = gMB->set_coords( &handle, 1, dumv );
print_time( false, ttime1, utime, stime, imem1, rmem1 );
// query the mesh 2 ways
query_struct_elem_to_vert();
print_time( false, ttime2, utime, stime, imem2, rmem2 );
query_vert_to_elem();
print_time( false, ttime3, utime, stime, imem3, rmem3 );
#ifndef NDEBUG
check_answers( "A" );
#endif
delete gMB;
print_time( false, ttime4, utime, stime, imem4, rmem4 );
std::cout << "MOAB_scd:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0 << " "
<< ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime4 - ttime3 << " " << ttime4 - ttime0
<< " seconds" << std::endl;
std::cout << "MOAB_scd_memory(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1 << " "
<< rmem2 << " " << rmem3 << " " << rmem4 << " kb" << std::endl;
| void testB | ( | const int | nelem, |
| const double * | coords, | ||
| int * | connect | ||
Definition at line 684 of file perf.cpp.
References check_answers(), ErrorCode, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), gMB, init(), MB_SUCCESS, MBHEX, print_time(), query_elem_to_vert(), moab::Interface::query_interface(), query_vert_to_elem(), RC, and moab::ReadUtilIface::update_adjacencies().
int num_elems = nelem * nelem * nelem;
// get the read interface
ReadUtilIface* readMeshIface;
init();
gMB->query_interface( readMeshIface );
// create a sequence to hold the node coordinates
// get the current number of entities and start at the next slot
std::vector< double* > coord_arrays;
ErrorCode result = readMeshIface->get_node_coords( 3, num_verts, 1, vstart, coord_arrays );
RC( "testB" );
assert( MB_SUCCESS == result && 1 == vstart && coord_arrays[0] && coord_arrays[1] && coord_arrays[2] );
// memcpy the coordinate data into place
memcpy( coord_arrays[0], coords, sizeof( double ) * num_verts );
memcpy( coord_arrays[1], &coords[num_verts], sizeof( double ) * num_verts );
memcpy( coord_arrays[2], &coords[2 * num_verts], sizeof( double ) * num_verts );
EntityHandle* conn = 0;
result = readMeshIface->get_element_connect( num_elems, 8, MBHEX, 1, estart, conn );
for( int i = 0; i < num_elems * 8; i++ )
conn[i] = vstart + connect[i];
delete[] connect;
result = readMeshIface->update_adjacencies( estart, num_elems, 8, conn );
query_elem_to_vert();
#ifndef NDEBUG
check_answers( "B" );
#endif
delete gMB;
std::cout << "MOAB_ucd_blocked:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0
<< " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime4 - ttime3 << " " << ttime4 - ttime0
std::cout << "MOAB_ucdblocked_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1
<< " " << rmem2 << " " << rmem3 << " " << rmem4 << " kb" << std::endl;
| void testC | ( | const int | nelem, |
Definition at line 748 of file perf.cpp.
References check_answers(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, gMB, init(), MB_SUCCESS, MBHEX, print_time(), query_elem_to_vert(), query_vert_to_elem(), RC, and VINDEX.
// create the vertices; assume we don't need to keep a list of vertex handles, since they'll
// be created in sequence
int num_verts = numv * numv * numv;
double dum_coords[3] = { coords[0], coords[num_verts], coords[2 * num_verts] };
EntityHandle vstart;
init();
ErrorCode result = gMB->create_vertex( dum_coords, vstart );
RC( "testC" );
assert( MB_SUCCESS == result && 1 == vstart );
EntityHandle dum_vert, vijk;
int i;
for( i = 1; i < num_verts; i++ )
dum_coords[0] = coords[i];
dum_coords[1] = coords[num_verts + i];
dum_coords[2] = coords[2 * num_verts + i];
result = gMB->create_vertex( dum_coords, dum_vert );
EntityHandle dum_conn[8];
for( i = 0; i < nelem; i++ )
vijk = vstart + VINDEX( i, j, k );
dum_conn[0] = vijk;
dum_conn[1] = vijk + 1;
dum_conn[2] = vijk + 1 + numv;
dum_conn[3] = vijk + numv;
dum_conn[4] = vijk + numv * numv;
dum_conn[5] = vijk + 1 + numv * numv;
dum_conn[6] = vijk + 1 + numv + numv * numv;
dum_conn[7] = vijk + numv + numv * numv;
result = gMB->create_element( MBHEX, dum_conn, 8, dum_vert );
#ifndef NDEBUG
check_answers( "C" );
#endif
delete gMB;
std::cout << "MOAB_ucd_indiv:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0
std::cout << "MOAB_ucd_indiv_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1
| void testD | ( | const int | nelem, |
| int | ver | ||
Definition at line 827 of file perf.cpp.
References check_answers(), moab::Interface::create_element(), moab::Interface::create_vertex(), ErrorCode, gMB, init(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, MBHEX, pos2_tag, pos_tag, print_time(), query_elem_to_vert_iters(), query_vert_to_elem_iters(), RC, moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), and VINDEX.
double ttime0 = 0.0, ttime1 = 0.0, ttime2 = 0.0, ttime3 = 0.0, ttime4 = 0.0, ttime5 = 0.0, ttime6 = 0.0,
ttime7 = 0.0, ttime8 = 0.0, ttime9 = 0.0, ttime10 = 0.0, utime = 0.0, stime = 0.0;
long imem0 = 0, rmem0 = 0, imem1 = 0, rmem1 = 0, imem2 = 0, rmem2 = 0, imem3 = 0, rmem3 = 0, imem4 = 0, rmem4 = 0,
imem5 = 0, rmem5 = 0, imem6 = 0, rmem6 = 0, imem7 = 0, rmem7 = 0, imem8 = 0, rmem8 = 0, imem9 = 0, rmem9 = 0,
imem10 = 0, rmem10 = 0;
std::vector< double > dum_coords( 24 ), dum_pos( 24 );
dum_coords[0] = coords[0];
dum_coords[1] = coords[num_verts];
dum_coords[2] = coords[2 * num_verts];
init();
ErrorCode result = gMB->create_vertex( &dum_coords[0], vstart );
RC( "testD" );
int i;
result = gMB->create_vertex( &dum_coords[0], dum_vert );
dum_conn[0] = vijk;
// query the mesh 2 ways with !check_valid
std::vector< EntityHandle > connect( 8 );
#ifndef NDEBUG
// used only in debug mode
#endif
if( ver == 0 || ver == 1 )
query_elem_to_vert_iters( 1, false, connect, &dum_coords[0], &dum_pos[0] );
query_vert_to_elem_iters( 1, false, connect, &dum_coords[0], &dum_pos[0] );
#ifndef NDEBUG
check_answers( "D" );
result = gMB->tag_delete( pos_tag );
result =
result = gMB->tag_delete( pos2_tag );
result =
#endif
if( ver == 0 || ver == 2 )
if( ver != 0 ) print_time( false, ttime3, utime, stime, imem3, rmem3 );
query_elem_to_vert_iters( 1, true, connect, &dum_coords[0], &dum_pos[0] );
query_vert_to_elem_iters( 1, true, connect, &dum_coords[0], &dum_pos[0] );
print_time( false, ttime5, utime, stime, imem5, rmem5 );
#ifndef NDEBUG
result =
result =
#endif
if( ver == 0 || ver >= 3 )
dum_coords.resize( 2400 );
dum_pos.resize( 300 );
if( ver == 0 || ver == 3 )
if( ver != 0 ) print_time( false, ttime5, utime, stime, imem3, rmem3 );
query_elem_to_vert_iters( 100, false, connect, &dum_coords[0], &dum_pos[0] );
print_time( false, ttime6, utime, stime, imem6, rmem6 );
query_vert_to_elem_iters( 100, false, connect, &dum_coords[0], &dum_pos[0] );
print_time( false, ttime7, utime, stime, imem7, rmem7 );
#ifndef NDEBUG
result =
result =
#endif
if( ver == 0 || ver == 4 )
if( ver != 0 ) print_time( false, ttime7, utime, stime, imem3, rmem3 );
query_elem_to_vert_iters( 100, true, connect, &dum_coords[0], &dum_pos[0] );
print_time( false, ttime8, utime, stime, imem8, rmem8 );
query_vert_to_elem_iters( 100, true, connect, &dum_coords[0], &dum_pos[0] );
print_time( false, ttime9, utime, stime, imem9, rmem9 );
#ifndef NDEBUG
result =
result =
#endif
if( ver > 0 && ver < 4 ) print_time( false, ttime9, utime, stime, imem9, rmem9 );
delete gMB;
print_time( false, ttime10, utime, stime, imem10, rmem10 );
std::cout << "MOAB_ucd_iters_!check_valid_1:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " "
<< ttime1 - ttime0 << " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime10 - ttime9
<< " " << ttime3 - ttime0 + ttime10 - ttime9 << std::endl;
std::cout << "MOAB_ucd_iters_memory_(rss)_!check_valid_1:initial,after_construction,e-v,v-"
"e,after_dtor= "
<< rmem0 << " " << rmem1 << " " << rmem2 << " " << rmem3 << " " << rmem10 << " kb" << std::endl;
std::cout << "MOAB_ucd_iters_check_valid_1:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " "
<< ttime1 - ttime0 << " " << ttime4 - ttime3 << " " << ttime5 - ttime4 << " " << ttime10 - ttime9
<< " " << ttime1 - ttime0 + ttime5 - ttime3 + ttime10 - ttime9 << std::endl;
std::cout << "MOAB_ucd_iters_memory_(rss)_check_valid_1:initial,after_construction,e-v,v-e,"
"after_dtor= "
std::cout << "MOAB_ucd_iters_!check_valid_100:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " "
<< ttime1 - ttime0 << " " << ttime6 - ttime5 << " " << ttime7 - ttime6 << " " << ttime10 - ttime9
<< " " << ttime1 - ttime0 + ttime7 - ttime5 + ttime10 - ttime9 << std::endl;
std::cout << "MOAB_ucd_iters_memory_(rss)_!check_valid_100:initial,after_construction,e-v,"
"v-e,after_dtor= "
<< rmem0 << " " << rmem1 << " " << rmem6 << " " << rmem7 << " " << rmem10 << " kb" << std::endl;
std::cout << "MOAB_ucd_iters_check_valid_100:nelem,construct,e-v,v-e,after_dtor,total= " << nelem << " "
<< ttime1 - ttime0 << " " << ttime8 - ttime7 << " " << ttime9 - ttime8 << " " << ttime10 - ttime9
<< " " << ttime1 - ttime0 + ttime10 - ttime7 << std::endl;
std::cout << "MOAB_ucd_iters_memory_(rss)_check_valid_100:initial,after_construction,e-v,v-"
"e,after_dtor= "
<< rmem0 << " " << rmem1 << " " << rmem8 << " " << rmem9 << " " << rmem10 << " kb" << std::endl;
| void testE | ( | const int | nelem, |
Definition at line 1029 of file perf.cpp.
References check_answers(), ErrorCode, moab::ReadUtilIface::get_element_connect(), moab::ReadUtilIface::get_node_coords(), gMB, init(), MB_SUCCESS, MBHEX, print_time(), query_elem_to_vert_direct(), moab::Interface::query_interface(), query_vert_to_elem_direct(), RC, and moab::ReadUtilIface::update_adjacencies().
imem5 = 0, rmem5 = 0, imem6 = 0, rmem6 = 0;
init();
RC( "testE" );
delete[] connect;
Range verts( vstart, vstart + num_verts - 1 ), elems( estart, estart + num_elems - 1 );
query_elem_to_vert_direct();
query_vert_to_elem_direct();
#ifndef NDEBUG
check_answers( "E" );
#endif
#ifndef NDEBUG
#endif
delete gMB;
std::cout << "MOAB_ucd_direct:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0
<< " " << ttime2 - ttime1 << " " << ttime3 - ttime2 << " " << ttime6 - ttime5 << " "
<< ttime3 - ttime0 + ttime6 - ttime5 << " seconds" << std::endl;
std::cout << "MOAB_ucd_direct_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " " << rmem1
<< " " << rmem2 << " " << rmem3 << " " << rmem6 << " kb" << std::endl;
std::cout << "MOAB_ucd_direct2:nelem,construct,e_to_v,v_to_e,after_dtor,total= " << nelem << " " << ttime1 - ttime0
<< " " << ttime4 - ttime3 << " " << ttime5 - ttime4 << " " << ttime6 - ttime5 << " "
<< ttime1 - ttime0 + ttime6 - ttime3 << " seconds" << std::endl;
std::cout << "MOAB_ucd_direct2_memory_(rss):initial,after_construction,e-v,v-e,after_dtor= " << rmem0 << " "
<< rmem1 << " " << rmem4 << " " << rmem5 << " " << rmem6 << " kb" << std::endl;
Definition at line 300 of file perf.cpp.
Referenced by check_answers(), init(), normalize_elems(), query_vert_to_elem(), query_vert_to_elem_direct(), query_vert_to_elem_iters(), and testD().
Referenced by check_answers(), init(), query_elem_to_vert(), query_elem_to_vert_direct(), query_elem_to_vert_iters(), query_struct_elem_to_vert(), and testD().
