MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/LocalDiscretization/SpectralQuad.hpp" 00002 #include "moab/Forward.hpp" 00003 00004 namespace moab 00005 { 00006 00007 // filescope for static member data that is cached 00008 int SpectralQuad::_n; 00009 real* SpectralQuad::_z[2]; 00010 lagrange_data SpectralQuad::_ld[2]; 00011 opt_data_2 SpectralQuad::_data; 00012 real* SpectralQuad::_odwork; 00013 real* SpectralQuad::_glpoints; 00014 bool SpectralQuad::_init = false; 00015 00016 SpectralQuad::SpectralQuad() : Map( 0 ) {} 00017 // the preferred constructor takes pointers to GL blocked positions 00018 SpectralQuad::SpectralQuad( int order, double* x, double* y, double* z ) : Map( 0 ) 00019 { 00020 Init( order ); 00021 _xyz[0] = x; 00022 _xyz[1] = y; 00023 _xyz[2] = z; 00024 } 00025 SpectralQuad::SpectralQuad( int order ) : Map( 4 ) 00026 { 00027 Init( order ); 00028 _xyz[0] = _xyz[1] = _xyz[2] = NULL; 00029 } 00030 SpectralQuad::~SpectralQuad() 00031 { 00032 if( _init ) freedata(); 00033 _init = false; 00034 } 00035 void SpectralQuad::Init( int order ) 00036 { 00037 if( _init && _n == order ) return; 00038 if( _init && _n != order ) 00039 { 00040 // TODO: free data cached 00041 freedata(); 00042 } 00043 // compute stuff that depends only on order 00044 _init = true; 00045 _n = order; 00046 // duplicates! n is the same in all directions !!! 00047 for( int d = 0; d < 2; d++ ) 00048 { 00049 _z[d] = tmalloc( double, _n ); 00050 lobatto_nodes( _z[d], _n ); 00051 lagrange_setup( &_ld[d], _z[d], _n ); 00052 } 00053 opt_alloc_2( &_data, _ld ); 00054 00055 unsigned int nf = _n * _n, ne = _n, nw = 2 * _n * _n + 3 * _n; 00056 _odwork = tmalloc( double, 6 * nf + 9 * ne + nw ); 00057 _glpoints = tmalloc( double, 3 * nf ); 00058 } 00059 00060 void SpectralQuad::freedata() 00061 { 00062 for( int d = 0; d < 2; d++ ) 00063 { 00064 free( _z[d] ); 00065 lagrange_free( &_ld[d] ); 00066 } 00067 opt_free_2( &_data ); 00068 free( _odwork ); 00069 free( _glpoints ); 00070 } 00071 00072 void SpectralQuad::set_gl_points( double* x, double* y, double* z ) 00073 { 00074 _xyz[0] = x; 00075 _xyz[1] = y; 00076 _xyz[2] = z; 00077 } 00078 CartVect SpectralQuad::evalFcn( const double* params, 00079 const double* field, 00080 const int ndim, 00081 const int num_tuples, 00082 double* work, 00083 double* result ) 00084 { 00085 // piece that we shouldn't want to cache 00086 int d = 0; 00087 for( d = 0; d < 2; d++ ) 00088 { 00089 lagrange_0( &_ld[d], params[d] ); 00090 } 00091 CartVect result; 00092 for( d = 0; d < 3; d++ ) 00093 { 00094 result[d] = tensor_i2( _ld[0].J, _ld[0].n, _ld[1].J, _ld[1].n, _xyz[d], _odwork ); 00095 } 00096 return result; 00097 } 00098 // replicate the functionality of hex_findpt 00099 bool SpectralQuad::reverseEvalFcn( const double* posn, 00100 const double* verts, 00101 const int nverts, 00102 const int ndim, 00103 const double iter_tol, 00104 const double inside_tol, 00105 double* work, 00106 double* params, 00107 int* is_inside ) 00108 { 00109 params = init; 00110 00111 // find nearest point 00112 double x_star[3]; 00113 xyz.get( x_star ); 00114 00115 double r[2] = { 0, 0 }; // initial guess for parametric coords 00116 unsigned c = opt_no_constraints_3; 00117 double dist = opt_findpt_2( &_data, (const double**)_xyz, x_star, r, &c ); 00118 // if it did not converge, get out with throw... 00119 if( dist > 0.9e+30 ) 00120 { 00121 std::vector< CartVect > dummy; 00122 throw Map::EvaluationError( CartVect( x_star ), dummy ); 00123 } 00124 // c tells us if we landed inside the element or exactly on a face, edge, or node 00125 // also, dist shows the distance to the computed point. 00126 // copy parametric coords back 00127 params = r; 00128 00129 return insideFcn( params, 2, inside_tol ); 00130 } 00131 00132 Matrix3 SpectralQuad::jacobian( const double* params, 00133 const double* verts, 00134 const int nverts, 00135 const int ndim, 00136 double* work, 00137 double* result ) 00138 { 00139 // not implemented 00140 Matrix3 J( 0. ); 00141 return J; 00142 } 00143 00144 void SpectralQuad::evaluate_vector( const CartVect& params, const double* field, int num_tuples, double* eval ) const 00145 { 00146 // piece that we shouldn't want to cache 00147 int d; 00148 for( d = 0; d < 2; d++ ) 00149 { 00150 lagrange_0( &_ld[d], params[d] ); 00151 } 00152 00153 *eval = tensor_i2( _ld[0].J, _ld[0].n, _ld[1].J, _ld[1].n, field, _odwork ); 00154 } 00155 void SpectralQuad::integrate_vector( const double* field, 00156 const double* verts, 00157 const int nverts, 00158 const int ndim, 00159 const int num_tuples, 00160 double* work, 00161 double* result ) 00162 { 00163 // not implemented 00164 } 00165 00166 int SpectralQuad::insideFcn( const double* params, const int ndim, const double tol ) 00167 { 00168 return EvalSet::inside( params, ndim, tol ); 00169 } 00170 00171 // something we don't do for spectral hex; we do it here because 00172 // we do not store the position of gl points in a tag yet 00173 void SpectralQuad::compute_gl_positions() 00174 { 00175 // will need to use shape functions on a simple linear quad to compute gl points 00176 // so we know the position of gl points in parametric space, we will just compute those 00177 // from the 3d vertex position (corner nodes of the quad), using simple mapping 00178 assert( this->vertex.size() == 4 ); 00179 static double corner_params[4][2] = { { -1., -1. }, { 1., -1. }, { 1., 1. }, { -1., 1. } }; 00180 // we will use the cached lobatto nodes in parametric space _z[d] (the same in both directions) 00181 int indexGL = 0; 00182 int n2 = _n * _n; 00183 for( int i = 0; i < _n; i++ ) 00184 { 00185 double csi = _z[0][i]; 00186 for( int j = 0; j < _n; j++ ) 00187 { 00188 double eta = _z[1][j]; // we could really use the same _z[0] array of lobatto nodes 00189 CartVect pos( 0.0 ); 00190 for( int k = 0; k < 4; k++ ) 00191 { 00192 const double N_k = ( 1 + csi * corner_params[k][0] ) * ( 1 + eta * corner_params[k][1] ); 00193 pos += N_k * vertex[k]; 00194 } 00195 pos *= 0.25; // these are x, y, z of gl points; reorder them 00196 _glpoints[indexGL] = pos[0]; // x 00197 _glpoints[indexGL + n2] = pos[1]; // y 00198 _glpoints[indexGL + 2 * n2] = pos[2]; // z 00199 indexGL++; 00200 } 00201 } 00202 // now, we can set the _xyz pointers to internal memory allocated to these! 00203 _xyz[0] = &( _glpoints[0] ); 00204 _xyz[1] = &( _glpoints[n2] ); 00205 _xyz[2] = &( _glpoints[2 * n2] ); 00206 } 00207 void SpectralQuad::get_gl_points( double*& x, double*& y, double*& z, int& size ) 00208 { 00209 x = (double*)_xyz[0]; 00210 y = (double*)_xyz[1]; 00211 z = (double*)_xyz[2]; 00212 size = _n * _n; 00213 } 00214 00215 } // namespace moab
