kd_tree_tool.cpp File Reference
#include "moab/Core.hpp"
#include "moab/CartVect.hpp"
#include "moab/AdaptiveKDTree.hpp"
#include "moab/GeomUtil.hpp"
#include "Internals.hpp"
#include "moab/Range.hpp"
#include "moab/FileOptions.hpp"
#include <iostream>
#include <iomanip>
#include <cstdio>
#include <limits>
#include <sstream>
#include <cstdlib>
#include <ctime>
#include <unistd.h>
#include <sys/stat.h>
#include <fcntl.h>
+ Include dependency graph for kd_tree_tool.cpp:
Functions
std::string clock_to_string (clock_t t)
std::string mem_to_string (unsigned long mem)
void build_tree (Interface *interface, const Range &elems, FileOptions &opts)
void build_grid (Interface *iface, const double dims[3])
void delete_existing_tree (Interface *interface)
void print_stats (Interface *interface)
void tag_elements (Interface *interface)
void tag_vertices (Interface *interface)
void write_tree_blocks (Interface *interface, const char *file)
static void usage (bool err=true)
static int parseint (int &i, int argc, char *argv[])
static void parsedims (int &i, int argc, char *argv[], double dims[3])
int main (int argc, char *argv[])
static int hash_handle (EntityHandle handle)
Variables
const int MAX_TAG_VALUE = 32
const char * TAG_NAME = "TREE_CELL"
Function Documentation
void build_grid ( Interface *  iface,
Definition at line 386 of file kd_tree_tool.cpp.
References moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::AdaptiveKDTree::Plane::coord, moab::Tree::create_root(), moab::AdaptiveKDTreeIter::depth(), ErrorCode, moab::Tree::get_max_depth(), moab::AdaptiveKDTree::get_tree_iterator(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::AdaptiveKDTree::Plane::norm, moab::AdaptiveKDTree::split_leaf(), and moab::AdaptiveKDTreeIter::step().
Referenced by main().
    ErrorCode rval;
    EntityHandle root = 0;
    AdaptiveKDTree tool( interface );
    AdaptiveKDTreeIter iter;
    AdaptiveKDTree::Plane plane;
    double min[3] = { -0.5 * dims[0], -0.5 * dims[1], -0.5 * dims[2] };
    double max[3] = { 0.5 * dims[0], 0.5 * dims[1], 0.5 * dims[2] };
    rval          = tool.create_root( min, max, root );
    if( MB_SUCCESS != rval || !root )
        std::cerr << "Failed to create tree root." << std::endl;
        exit( 4 );
    rval = tool.get_tree_iterator( root, iter );
    if( MB_SUCCESS != rval )
        std::cerr << "Failed to get tree iterator." << std::endl;
    do
        while( iter.depth() < tool.get_max_depth() )
            plane.norm  = iter.depth() % 3;
            plane.coord = 0.5 * ( iter.box_min()[plane.norm] + iter.box_max()[plane.norm] );
            rval        = tool.split_leaf( iter, plane );
                std::cerr << "Failed to split tree leaf at depth " << iter.depth() << std::endl;
                exit( 4 );
    } while( ( rval = iter.step() ) == MB_SUCCESS );
    if( rval != MB_ENTITY_NOT_FOUND )
        std::cerr << "Error stepping KDTree iterator." << std::endl;
        exit( 4 );
void build_tree ( Interface *  interface,
const Range &  elems,
FileOptions &  opts
Definition at line 373 of file kd_tree_tool.cpp.
References moab::Range::empty().
    if( elems.empty() )
        std::cerr << "No elements from which to build tree." << std::endl;
        exit( 4 );
    AdaptiveKDTree tool( interface, elems, &root, &opts );
std::string clock_to_string ( clock_t  t)
Definition at line 431 of file kd_tree_tool.cpp.
References buffer, and moab::unit().
    char unit[5] = "s";
    char buffer[256];
    double dt = t / (double)CLOCKS_PER_SEC;
    // if (dt > 300) {
    //  dt /= 60;
    //  strcpy( unit, "min" );
    // if (dt > 300) {
    //  dt /= 60;
    //  strcpy( unit, "hr" );
    // if (dt > 100) {
    //  dt /= 24;
    //  strcpy( unit, "days" );
    sprintf( buffer, "%0.2f%s", dt, unit );
    return buffer;
void delete_existing_tree ( Interface *  interface)
Definition at line 354 of file kd_tree_tool.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::empty(), moab::Range::end(), moab::Tree::find_all_trees(), and moab::AdaptiveKDTree::reset_tree().
    Range trees;
    tool.find_all_trees( trees );
    if( !trees.empty() ) std::cout << "Destroying existing tree(s) contained in file" << std::endl;
    for( Range::iterator i = trees.begin(); i != trees.end(); ++i )
        tool.reset_tree();
    trees.clear();
        std::cerr << "Failed to destroy existing trees. Aborting" << std::endl;
        exit( 5 );
static int hash_handle ( EntityHandle  handle) [static]
Definition at line 452 of file kd_tree_tool.cpp.
References moab::ID_FROM_HANDLE(), and MAX_TAG_VALUE.
Referenced by tag_elements(), tag_vertices(), and write_tree_blocks().
    EntityID h = ID_FROM_HANDLE( handle );
    return (int)( ( h * 13 + 7 ) % MAX_TAG_VALUE ) + 1;
int main ( int  argc,
char *  argv[]
Definition at line 155 of file kd_tree_tool.cpp.
References build_grid(), build_time, build_tree(), clock_to_string(), delete_existing_tree(), moab::Range::empty(), ErrorCode, moab::Tree::find_all_trees(), input_file, load_time, MB_SUCCESS, moab::Range::merge(), parsedims(), parseint(), moab::AdaptiveKDTree::print(), moab::Range::size(), moab::AdaptiveKDTree::SUBDIVISION, moab::AdaptiveKDTree::SUBDIVISION_SNAP, tag_elements(), tag_time(), tag_vertices(), usage, moab::AdaptiveKDTree::VERTEX_MEDIAN, moab::AdaptiveKDTree::VERTEX_SAMPLE, and write_tree_blocks().
    bool surf_elems = false, vol_elems = false;
    const char* input_file  = 0;
    const char* output_file = 0;
    const char* tree_file   = 0;
    std::ostringstream options;
    bool tag_elems = false;
    clock_t load_time, build_time, stat_time, tag_time, write_time, block_time;
    bool make_grid = false;
    double dims[3];
    for( int i = 1; i < argc; ++i )
        if( argv[i][0] != '-' )
            if( !input_file )
                input_file = argv[i];
            else if( !output_file )
                output_file = argv[i];
            else
                usage();
            continue;
        if( !argv[i][1] || argv[i][2] ) usage();
        switch( argv[i][1] )
            case '2':
                surf_elems = true;
                break;
            case '3':
                vol_elems = true;
                break;
            case 'S':
                options << "MESHSET_FLAGS=" << MESHSET_ORDERED << ";";
                break;
            case 's':
                break;
            case 'd':
                options << "MAX_DEPTH=" << parseint( i, argc, argv ) << ";";
                break;
            case 'n':
                options << "MAX_PER_LEAF=" << parseint( i, argc, argv ) << ";";
                break;
            case 'u':
                options << "CANDIDATE_PLANE_SET=" << AdaptiveKDTree::SUBDIVISION << ";";
                break;
            case 'p':
                options << "CANDIDATE_PLANE_SET=" << AdaptiveKDTree::SUBDIVISION_SNAP << ";";
                break;
            case 'm':
                options << "CANDIDATE_PLANE_SET=" << AdaptiveKDTree::VERTEX_MEDIAN << ";";
                break;
            case 'v':
                options << "CANDIDATE_PLANE_SET=" << AdaptiveKDTree::VERTEX_SAMPLE << ";";
                break;
            case 'N':
                options << "SPLITS_PER_DIR=" << parseint( i, argc, argv ) << ";";
                break;
            case 't':
                tag_elems = true;
                break;
            case 'T':
                tree_file = argv[++i];
                break;
            case 'G':
                make_grid = true;
                parsedims( i, argc, argv, dims );
                break;
            case 'h':
                usage( false );
                break;
            default:
                usage();
    // this test relies on not cleaning up trees
    options << "CLEAN_UP=false;";
    if( make_grid != !output_file ) usage();
    // default to both
    if( !surf_elems && !vol_elems ) surf_elems = vol_elems = true;
    ErrorCode rval;
    Core moab_core;
    Interface* interface = &moab_core;
    FileOptions opts( options.str().c_str() );
    if( make_grid )
        load_time   = 0;
        output_file = input_file;
        input_file  = 0;
        build_time  = clock();
        build_grid( interface, dims );
        build_time = clock() - build_time;
    else
        load_time = clock();
        rval      = interface->load_mesh( input_file );
            std::cerr << "Error reading file: " << input_file << std::endl;
            exit( 2 );
        load_time = clock() - load_time;
        delete_existing_tree( interface );
        std::cout << "Building tree..." << std::endl;
        Range elems;
        if( !surf_elems )
            interface->get_entities_by_dimension( 0, 3, elems );
        else
            interface->get_entities_by_dimension( 0, 2, elems );
            if( vol_elems )
                Range tmp;
                interface->get_entities_by_dimension( 0, 3, tmp );
                elems.merge( tmp );
        build_tree( interface, elems, opts );
    std::cout << "Calculating stats..." << std::endl;
    Range range;
    tool.find_all_trees( range );
    if( range.size() != 1 )
        if( range.empty() )
            std::cerr << "Internal error: Failed to retreive tree." << std::endl;
        else
            std::cerr << "Internal error: Multiple tree roots." << std::endl;
        exit( 5 );
    tool.print();
    stat_time = clock() - build_time;
    if( tag_elems )
        std::cout << "Tagging tree..." << std::endl;
        tag_elements( interface );
        tag_vertices( interface );
    tag_time = clock() - stat_time;
    std::cout << "Writing file... ";
    std::cout.flush();
    rval = interface->write_mesh( output_file );
        std::cerr << "Error writing file: " << output_file << std::endl;
        exit( 3 );
    write_time = clock() - tag_time;
    std::cout << "Wrote " << output_file << std::endl;
    if( tree_file )
        std::cout << "Writing tree block rep...";
        std::cout.flush();
        write_tree_blocks( interface, tree_file );
        std::cout << "Wrote " << tree_file << std::endl;
    block_time = clock() - write_time;
    std::cout << "Times:  "
              << "    Load"
              << "   Build"
              << "   Stats"
              << "   Write";
    if( tag_elems ) std::cout << "Tag Sets";
    if( tree_file ) std::cout << "Block   ";
    std::cout << std::endl;
    std::cout << "        " << std::setw( 8 ) << clock_to_string( load_time ) << std::setw( 8 )
              << clock_to_string( build_time ) << std::setw( 8 ) << clock_to_string( stat_time ) << std::setw( 8 )
              << clock_to_string( write_time );
    if( tag_elems ) std::cout << std::setw( 8 ) << clock_to_string( tag_time );
    if( tree_file ) std::cout << std::setw( 8 ) << clock_to_string( block_time );
    return 0;
std::string mem_to_string ( unsigned long  mem)
Definition at line 360 of file obb_tree_tool.cpp.
    char unit[3] = "B";
    if( mem > 9 * 1024 )
        mem = ( mem + 512 ) / 1024;
        strcpy( unit, "kB" );
        strcpy( unit, "MB" );
        strcpy( unit, "GB" );
    char buffer[256];
    sprintf( buffer, "%lu %s", mem, unit );
    return buffer;
static void parsedims ( int &  i,
int  argc,
char *  argv[],
double  dims[3]
) [static]
Definition at line 116 of file kd_tree_tool.cpp.
References moab::error(), and usage.
    char* end;
    ++i;
    if( i == argc )
        std::cerr << "Expected value following '" << argv[i - 1] << "'" << std::endl;
        usage();
    dims[0] = strtod( argv[i], &end );
    if( *end == '\0' )
        dims[2] = dims[1] = dims[0];
        return;
    else if( *end != 'x' && *end != 'X' )
        goto error;
    ++end;
    dims[1] = strtod( end, &end );
    if( *end == '\0' )
        dims[2] = dims[1];
        return;
        goto error;
    ++end;
    dims[2] = strtod( end, &end );
    if( *end != '\0' ) goto error;
    return;
error:
    std::cerr << "Invaild dimension specification." << std::endl;
    usage();
static int parseint ( int &  i,
int  argc,
char *  argv[]
) [static]
Definition at line 96 of file kd_tree_tool.cpp.
References usage.
    char* end;
    ++i;
    if( i == argc )
        usage();
    int result = strtol( argv[i], &end, 0 );
    if( result < 0 || *end )
        std::cerr << "Expected positive integer following '" << argv[i - 1] << "'" << std::endl;
        usage();
    return result;
void print_stats ( Interface *  interface)
Definition at line 410 of file obb_tree_tool.cpp.
References moab::Range::begin(), moab::Range::end(), moab::Range::erase(), ErrorCode, moab::Interface::estimated_memory_use(), moab::Interface::get_entities_by_type(), moab::Interface::get_number_entities_by_type(), get_root(), moab::Range::insert(), MB_SUCCESS, MBENTITYSET, MBTRI, MBVERTEX, moab::mem_to_string(), memory_use(), moab::Range::merge(), and moab::OrientedBoxTreeTool::stats().
    EntityHandle root;
    Range range;
    ErrorCode rval;
    rval = get_root( interface, root );
        std::cerr << "Internal error: Failed to retrieve root." << std::endl;
        exit( 5 );
    OrientedBoxTreeTool tool( interface );
    Range tree_sets, triangles, verts;
    // interface->get_child_meshsets( root, tree_sets, 0 );
    interface->get_entities_by_type( 0, MBENTITYSET, tree_sets );
    tree_sets.erase( tree_sets.begin(), Range::lower_bound( tree_sets.begin(), tree_sets.end(), root ) );
    interface->get_entities_by_type( 0, MBTRI, triangles );
    interface->get_entities_by_type( 0, MBVERTEX, verts );
    triangles.merge( verts );
    tree_sets.insert( root );
    unsigned long long set_used, set_amortized, set_store_used, set_store_amortized, set_tag_used, set_tag_amortized,
        tri_used, tri_amortized;
    interface->estimated_memory_use( tree_sets, &set_used, &set_amortized, &set_store_used, &set_store_amortized, 0, 0,
                                     0, 0, &set_tag_used, &set_tag_amortized );
    interface->estimated_memory_use( triangles, &tri_used, &tri_amortized );
    int num_tri = 0;
    interface->get_number_entities_by_type( 0, MBTRI, num_tri );
    tool.stats( root, std::cout );
    unsigned long long real_rss, real_vsize;
    memory_use( real_vsize, real_rss );
    printf( "------------------------------------------------------------------\n" );
    printf( "\nmemory:           used  amortized\n" );
    printf( "            ---------- ----------\n" );
    printf( "triangles   %10s %10s\n", mem_to_string( tri_used ).c_str(), mem_to_string( tri_amortized ).c_str() );
    printf( "sets (total)%10s %10s\n", mem_to_string( set_used ).c_str(), mem_to_string( set_amortized ).c_str() );
    printf( "sets        %10s %10s\n", mem_to_string( set_store_used ).c_str(),
            mem_to_string( set_store_amortized ).c_str() );
    printf( "set tags    %10s %10s\n", mem_to_string( set_tag_used ).c_str(),
            mem_to_string( set_tag_amortized ).c_str() );
    printf( "total real  %10s %10s\n", mem_to_string( real_rss ).c_str(), mem_to_string( real_vsize ).c_str() );
void tag_elements ( Interface *  interface)
Definition at line 458 of file kd_tree_tool.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::empty(), moab::Tree::find_all_trees(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), hash_handle(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, moab::Range::size(), moab::AdaptiveKDTreeIter::step(), moab::Interface::tag_get_handle(), TAG_NAME, and moab::Interface::tag_set_data().
    EntityHandle root;
    Range range;
    AdaptiveKDTree tool( moab );
        if( range.empty() )
        else
        exit( 5 );
    root = *range.begin();
    range.clear();
    Tag tag;
    int zero = 0;
    moab->tag_get_handle( TAG_NAME, 1, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_CREAT, &zero );
    std::vector< int > tag_vals;
    do
        range.clear();
        moab->get_entities_by_handle( iter.handle(), range );
        tag_vals.clear();
        tag_vals.resize( range.size(), hash_handle( iter.handle() ) );
        moab->tag_set_data( tag, range, &tag_vals[0] );
    } while( MB_SUCCESS == iter.step() );
void tag_vertices ( Interface *  interface)
Definition at line 495 of file kd_tree_tool.cpp.
References moab::CartVect::array(), moab::Range::begin(), moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::GeomUtil::box_point_overlap(), moab::Range::clear(), moab::Range::empty(), moab::Tree::find_all_trees(), moab::Interface::get_adjacencies(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), hash_handle(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, moab::Range::size(), moab::AdaptiveKDTreeIter::step(), moab::Interface::tag_get_handle(), TAG_NAME, moab::Interface::tag_set_data(), and moab::Interface::UNION.
    EntityHandle root;
    Range range;
        if( range.empty() )
        else
        exit( 5 );
    range.clear();
    Tag tag;
    int zero = 0;
    do
        range.clear();
        int tag_val = hash_handle( iter.handle() );
        Range verts;
        moab->get_adjacencies( range, 0, false, verts, Interface::UNION );
        for( Range::iterator i = verts.begin(); i != verts.end(); ++i )
            CartVect coords;
            moab->get_coords( &*i, 1, coords.array() );
            if( GeomUtil::box_point_overlap( CartVect( iter.box_min() ), CartVect( iter.box_max() ), coords, 1e-7 ) )
                moab->tag_set_data( tag, &*i, 1, &tag_val );
static void usage ( bool  err = true) [static]
Definition at line 37 of file kd_tree_tool.cpp.
    std::ostream& s = err ? std::cerr : std::cout;
    s << "kd_tree_tool [-d <int>] [-2|-3] [-n <int>] [-u|-p|-m|-v] [-N <int>] [-s|-S] <input file> "
         "<output file>"
      << std::endl
      << "kd_tree_tool [-d <int>] -G <dims> [-s|-S] <output file>" << std::endl
      << "kd_tree_tool [-h]" << std::endl;
    if( !err )
        s << "Tool to build adaptive kd-Tree" << std::endl;
        s << "  -d <int>  Specify maximum depth for tree. Default: 30" << std::endl
          << "  -n <int>  Specify maximum entities per leaf. Default: 6" << std::endl
          << "  -2        Build tree from surface elements. Default: yes" << std::endl
          << "  -3        Build tree from volume elements. Default: yes" << std::endl
          << "  -u        Use 'SUBDIVISION' scheme for tree construction" << std::endl
          << "  -p        Use 'SUBDIVISION_SNAP' tree construction algorithm." << std::endl
          << "  -m        Use 'VERTEX_MEDIAN' tree construction algorithm." << std::endl
          << "  -v        Use 'VERTEX_SAMPLE' tree construction algorithm." << std::endl
          << "  -N <int>  Specify candidate split planes per axis.  Default: 3" << std::endl
          << "  -t        Tag elements will tree cell number." << std::endl
          << "  -T        Write tree boxes to file." << std::endl
          << "  -G <dims> Generate grid - no input elements.  Dims must be " << std::endl
          << "            HxWxD or H." << std::endl
          << "  -s        Use range-based sets for tree nodes" << std::endl
          << "  -S        Use vector-based sets for tree nodes" << std::endl
          << std::endl;
    exit( err );
void write_tree_blocks ( Interface *  interface,
const char *  file
Definition at line 539 of file kd_tree_tool.cpp.
References moab::Range::begin(), moab::AdaptiveKDTreeIter::box_max(), moab::AdaptiveKDTreeIter::box_min(), moab::Range::clear(), moab::Core::create_element(), moab::Core::create_vertex(), moab::Range::empty(), moab::Tree::find_all_trees(), moab::AdaptiveKDTree::get_tree_iterator(), moab::AdaptiveKDTreeIter::handle(), hash_handle(), MB_SUCCESS, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBHEX, moab::Range::size(), moab::AdaptiveKDTreeIter::step(), moab::Core::tag_get_handle(), TAG_NAME, moab::Core::tag_set_data(), and moab::Core::write_mesh().
    EntityHandle root;
    Range range;
        if( range.empty() )
        else
        exit( 5 );
    range.clear();
    Core moab2;
    Tag tag;
    int zero = 0;
    moab2.tag_get_handle( TAG_NAME, 1, MB_TYPE_INTEGER, tag, MB_TAG_DENSE | MB_TAG_CREAT, &zero );
    do
        double x1         = iter.box_min()[0];
        double y1         = iter.box_min()[1];
        double z1         = iter.box_min()[2];
        double x2         = iter.box_max()[0];
        double y2         = iter.box_max()[1];
        double z2         = iter.box_max()[2];
        double coords[24] = { x1, y1, z1, x2, y1, z1, x2, y2, z1, x1, y2, z1,
                              x1, y1, z2, x2, y1, z2, x2, y2, z2, x1, y2, z2 };
        EntityHandle verts[8], elem;
        for( int i = 0; i < 8; ++i )
            moab2.create_vertex( coords + 3 * i, verts[i] );
        moab2.create_element( MBHEX, verts, 8, elem );
        moab2.tag_set_data( tag, &elem, 1, &tag_val );
    moab2.write_mesh( file );
Variable Documentation
Definition at line 23 of file kd_tree_tool.cpp.
Referenced by hash_handle().
const char* TAG_NAME = "TREE_CELL"
Definition at line 24 of file kd_tree_tool.cpp.
