MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /* 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 /**\file Geometry.hpp 00017 *\author Jason Kraftcheck ([email protected]) 00018 *\date 2006-07-27 00019 */ 00020 00021 #ifndef MB_GEOM_UTIL_HPP 00022 #define MB_GEOM_UTIL_HPP 00023 00024 #include "moab/CartVect.hpp" 00025 #include <cmath> 00026 00027 namespace moab 00028 { 00029 00030 /** \class GeomUtil 00031 * \brief Functions for computational geometry on triangles, rays, and boxes 00032 */ 00033 namespace GeomUtil 00034 { 00035 00036 /** Given a line segment and an axis-aligned box, 00037 * return the sub-segment of the line segment that 00038 * itersects the box. 00039 * 00040 * Can be used to intersect ray with box by passing seg_end 00041 * as HUGE_VAL or std::numeric_limits<double>::maximum(). 00042 * 00043 *\param box_min Minimum corner of axis-aligned box 00044 *\param box_max Maximum corner of axis-aligned box 00045 *\param seg_pt A point in the line containing the segement 00046 *\param seg_unit_dir A unit vector in the direction of the line 00047 * containing the semgent. 00048 *\param seg_start The distance from seg_pt in the direction of 00049 * seg_unit_dir at which the segment begins. 00050 * As input, the start of the original segment, as output, the 00051 * start of the sub-segment intersecting the box. 00052 * Note: seg_start must be less than seg_end 00053 *\param seg_end The distance from seg_pt in the direction of 00054 * seg_unit_dir at which the segment ends. 00055 * As input, the end of the original segment, as output, the 00056 * end of the sub-segment intersecting the box. 00057 * Note: seg_start must be less than seg_end 00058 *\return true if line semgent intersects box, false otherwise. 00059 */ 00060 bool segment_box_intersect( CartVect box_min, 00061 CartVect box_max, 00062 const CartVect& seg_pt, 00063 const CartVect& seg_unit_dir, 00064 double& seg_start, 00065 double& seg_end ); 00066 00067 /**\brief Test for intersection between a ray and a triangle. 00068 *\param ray_point The start point of the ray. 00069 *\param ray_unit_direciton The direction of the ray. Must be a unit vector. 00070 *\param t_out Output: The distance along the ray from ray_point in the 00071 * direction of ray_unit_direction at which the ray 00072 * itersected the triangle. 00073 *\param ray_length Optional: If non-null, a pointer a maximum length 00074 * for the ray, converting this function to a segment-tri- 00075 * intersect test. 00076 *\return true if intersection, false otherwise. 00077 */ 00078 bool ray_tri_intersect( const CartVect vertices[3], 00079 const CartVect& ray_point, 00080 const CartVect& ray_unit_direction, 00081 double& t_out, 00082 const double* ray_length = 0 ); 00083 00084 /**\brief Plücker test for intersection between a ray and a triangle. 00085 *\param vertices Nodes of the triangle. 00086 *\param ray_point The start point of the ray. 00087 *\param ray_unit_direction The direction of the ray. Must be a unit vector. 00088 *\param t_out Output: The distance along the ray from ray_point in the 00089 * direction of ray_unit_direction at which the ray 00090 * intersected the triangle. 00091 *\param nonneg_ray_length Optional: If non-null, a maximum length for the ray, 00092 * converting this function to a segment-tri-intersect 00093 * test. 00094 *\param neg_ray_length Optional: If non-null, a maximum length for the ray 00095 * behind the origin, converting this function to a 00096 * segment-tri-intersect test. 00097 *\param orientation Optional: Reject intersections without the specified 00098 * orientation of ray with respect to triangle normal 00099 * vector. Indicate desired orientation by passing 00100 * 1 (forward), -1 (reverse), or 0 (no preference). 00101 *\param int_type Optional Output: The type of intersection; used to 00102 * identify edge/node intersections. 00103 *\return true if intersection, false otherwise. 00104 */ 00105 enum intersection_type 00106 { 00107 NONE = 0, 00108 INTERIOR, 00109 NODE0, 00110 NODE1, 00111 NODE2, 00112 EDGE0, 00113 EDGE1, 00114 EDGE2 00115 }; 00116 /* intersection type is determined by which of the intermediate values are == 0. There 00117 are three such values that can therefore be encoded in a 3 bit integer. 00118 0 = none are == 0 -> interior type 00119 1 = pip0 == 0 -> EDGE0 00120 2 = pip1 == 1 -> EDGE1 00121 4 = pip2 == 2 -> EDGE2 00122 5 = pip2 = pip0 == 0 -> NOEE0 00123 3 = pip0 = pip1 == 0 -> NODE1 00124 6 = pip1 = pip2 == 0 -> NODE2 */ 00125 const intersection_type type_list[] = { INTERIOR, EDGE0, EDGE1, NODE1, EDGE2, NODE0, NODE2 }; 00126 00127 bool plucker_ray_tri_intersect( const CartVect vertices[3], 00128 const CartVect& ray_point, 00129 const CartVect& ray_unit_direction, 00130 double& dist_out, 00131 const double* nonneg_ray_length = 0, 00132 const double* neg_ray_length = 0, 00133 const int* orientation = 0, 00134 intersection_type* int_type = 0 ); 00135 double plucker_edge_test( const CartVect& vertexa, 00136 const CartVect& vertexb, 00137 const CartVect& ray, 00138 const CartVect& ray_normal ); 00139 00140 //! Find range of overlap between ray and axis-aligned box. 00141 //! 00142 //!\param box_min Box corner with minimum coordinate values 00143 //!\param box_max Box corner with minimum coordinate values 00144 //!\param ray_pt Coordinates of start point of ray 00145 //!\param ray_dir Directionion vector for ray such that 00146 //! the ray is defined by r(t) = ray_point + t * ray_vect 00147 //! for t > 0. 00148 //!\param t_enter Output: if return value is true, this value 00149 //! is the parameter location along the ray at which 00150 //! the ray entered the leaf. If return value is false, 00151 //! then this value is undefined. 00152 //!\param t_exit Output: if return value is true, this value 00153 //! is the parameter location along the ray at which 00154 //! the ray exited the leaf. If return value is false, 00155 //! then this value is undefined. 00156 //!\return true if ray intersects leaf, false otherwise. 00157 bool ray_box_intersect( const CartVect& box_min, 00158 const CartVect& box_max, 00159 const CartVect& ray_pt, 00160 const CartVect& ray_dir, 00161 double& t_enter, 00162 double& t_exit ); 00163 00164 /**\brief Test if plane intersects axis-aligned box 00165 * 00166 * Test for intersection between an unbounded plane and 00167 * an axis-aligned box. 00168 *\param plane_normal Vector in plane normal direction (need *not* 00169 * be a unit vector). The N in 00170 * the plane equation: N . X + D = 0 00171 *\param plane_coeff The scalar 'D' term in the plane equation: 00172 * N . X + D = 0 00173 *\param box_min_corner The smallest coordinates of the box along each 00174 * axis. The corner of the box for which all three 00175 * coordinate values are smaller than those of any 00176 * other corner. The X, Y, Z values for the planes 00177 * normal to those axes and bounding the box on the 00178 * -X, -Y, and -Z sides respectively. 00179 *\param box_max_corner The largest coordinates of the box along each 00180 * axis. The corner of the box for which all three 00181 * coordinate values are larger than those of any 00182 * other corner. The X, Y, Z values for the planes 00183 * normal to those axes and bounding the box on the 00184 * +X, +Y, and +Z sides respectively. 00185 *\return true if overlap, false otherwise. 00186 */ 00187 bool box_plane_overlap( const CartVect& plane_normal, 00188 double plane_coeff, 00189 CartVect box_min_corner, 00190 CartVect box_max_corner ); 00191 00192 /**\brief Test if triangle intersects axis-aligned box 00193 * 00194 * Test if a triangle intersects an axis-aligned box. 00195 *\param triangle_corners The corners of the triangle. 00196 *\param box_min_corner The smallest coordinates of the box along each 00197 * axis. The corner of the box for which all three 00198 * coordinate values are smaller than those of any 00199 * other corner. The X, Y, Z values for the planes 00200 * normal to those axes and bounding the box on the 00201 * -X, -Y, and -Z sides respectively. 00202 *\param box_max_corner The largest coordinates of the box along each 00203 * axis. The corner of the box for which all three 00204 * coordinate values are larger than those of any 00205 * other corner. The X, Y, Z values for the planes 00206 * normal to those axes and bounding the box on the 00207 * +X, +Y, and +Z sides respectively. 00208 *\param tolerance The tolerance used in the intersection test. The box 00209 * size is increased by this amount before the intersection 00210 * test. 00211 *\return true if overlap, false otherwise. 00212 */ 00213 bool box_tri_overlap( const CartVect triangle_corners[3], 00214 const CartVect& box_min_corner, 00215 const CartVect& box_max_corner, 00216 double tolerance ); 00217 00218 /**\brief Test if triangle intersects axis-aligned box 00219 * 00220 * Test if a triangle intersects an axis-aligned box. 00221 *\param triangle_corners The corners of the triangle. 00222 *\param box_center The center of the box. 00223 *\param box_hanf_dims The distance along each axis, respectively, from the 00224 * box_center to the boundary of the box. 00225 *\return true if overlap, false otherwise. 00226 */ 00227 bool box_tri_overlap( const CartVect triangle_corners[3], 00228 const CartVect& box_center, 00229 const CartVect& box_half_dims ); 00230 00231 bool box_point_overlap( const CartVect& box_min_corner, 00232 const CartVect& box_max_corner, 00233 const CartVect& point, 00234 double tolerance ); 00235 00236 /**\brief Test if the specified element intersects an axis-aligned box. 00237 * 00238 * Test if element intersects axis-aligned box. Use element-specific 00239 * optimization if available, otherwise call box_general_elem_overlap. 00240 * 00241 *\param elem_corners The coordinates of the element vertices 00242 *\param elem_type The toplogy of the element. 00243 *\param box_center The center of the axis-aligned box 00244 *\param box_half_dims Half of the width of the box in each axial 00245 * direction. 00246 */ 00247 bool box_elem_overlap( const CartVect* elem_corners, 00248 EntityType elem_type, 00249 const CartVect& box_center, 00250 const CartVect& box_half_dims, 00251 int nodecount = 0 ); 00252 00253 /**\brief Test if the specified element intersects an axis-aligned box. 00254 * 00255 * Uses MBCN and separating axis theorem for general algorithm that 00256 * works for all fixed-size elements (not poly*). 00257 * 00258 *\param elem_corners The coordinates of the element vertices 00259 *\param elem_type The toplogy of the element. 00260 *\param box_center The center of the axis-aligned box 00261 *\param box_half_dims Half of the width of the box in each axial 00262 * direction. 00263 */ 00264 bool box_linear_elem_overlap( const CartVect* elem_corners, 00265 EntityType elem_type, 00266 const CartVect& box_center, 00267 const CartVect& box_half_dims ); 00268 00269 /**\brief Test if the specified element intersects an axis-aligned box. 00270 * 00271 * Uses MBCN and separating axis theorem for general algorithm that 00272 * works for all fixed-size elements (not poly*). Box and element 00273 * vertices must be translated such that box center is at origin. 00274 * 00275 *\param elem_corners The coordinates of the element vertices, in 00276 * local coordinate system of box. 00277 *\param elem_type The toplogy of the element. 00278 *\param box_half_dims Half of the width of the box in each axial 00279 * direction. 00280 */ 00281 bool box_linear_elem_overlap( const CartVect* elem_corners, EntityType elem_type, const CartVect& box_half_dims ); 00282 00283 void closest_location_on_box( const CartVect& box_min_corner, 00284 const CartVect& box_max_corner, 00285 const CartVect& point, 00286 CartVect& closest ); 00287 00288 /**\brief find closest location on triangle 00289 * 00290 * Find closest location on linear triangle. 00291 *\param location Input position to evaluate from 00292 *\param vertices Array of three corner vertex coordinates. 00293 *\param closest_out Result position 00294 */ 00295 void closest_location_on_tri( const CartVect& location, const CartVect* vertices, CartVect& closest_out ); 00296 00297 /**\brief find closest location on polygon 00298 * 00299 * Find closest location on polygon 00300 *\param location Input position to evaluate from 00301 *\param vertices Array of corner vertex coordinates. 00302 *\param num_vertices Length of 'vertices' array. 00303 *\param closest_out Result position 00304 */ 00305 void closest_location_on_polygon( const CartVect& location, 00306 const CartVect* vertices, 00307 int num_vertices, 00308 CartVect& closest_out ); 00309 00310 /**\brief find closest topological location on triangle 00311 * 00312 * Find closest location on linear triangle. 00313 *\param location Input position to evaluate from 00314 *\param vertices Array of three corner vertex coordinates. 00315 *\param tolerance Tolerance to use when comparing to corners and edges 00316 *\param closest_out Result position 00317 *\param closest_topo Closest topological entity 00318 * 0-2 : vertex index 00319 * 3-5 : edge beginning at closest_topo - 3 00320 * 6 : triangle interior 00321 */ 00322 void closest_location_on_tri( const CartVect& location, 00323 const CartVect* vertices, 00324 double tolerance, 00325 CartVect& closest_out, 00326 int& closest_topo ); 00327 00328 // Finds whether or not a box defined by the center and the half 00329 // width intersects a trilinear hex defined by its eight vertices. 00330 bool box_hex_overlap( const CartVect hexv[8], const CartVect& box_center, const CartVect& box_dims ); 00331 00332 // Finds whether or not a box defined by the center and the half 00333 // width intersects a linear tetrahedron defined by its four vertices. 00334 bool box_tet_overlap( const CartVect tet_corners[4], const CartVect& box_center, const CartVect& box_dims ); 00335 00336 // tests if 2 boxes overlap within a tolerance 00337 // assume that data is valid, box_min1 << box_max1, and box_min2<< box_max2 00338 // they are overlapping if they are overlapping in all directions 00339 // for example in x direction: 00340 // box_max2[0] + tolerance < box_min1[0] -- false 00341 bool boxes_overlap( const CartVect& box_min1, 00342 const CartVect& box_max1, 00343 const CartVect& box_min2, 00344 const CartVect& box_max2, 00345 double tolerance ); 00346 00347 // see if boxes formed by 2 lists of "CartVect"s overlap 00348 bool bounding_boxes_overlap( const CartVect* list1, int num1, const CartVect* list2, int num2, double tolerance ); 00349 00350 // see if boxes from vertices in 2d overlap (used in gnomonic planes right now) 00351 bool bounding_boxes_overlap_2d( const double* list1, int num1, const double* list2, int num2, double tolerance ); 00352 // point_in_trilinear_hex 00353 // Tests if a point in xyz space is within a hex element defined with 00354 // its eight vertex points forming a trilinear basis function. Computes 00355 // the natural coordinates with respect to the hex of the xyz point 00356 // and checks if each are between +/-1. If anyone is outside the range 00357 // the function returns false, otherwise it returns true. 00358 // 00359 bool point_in_trilinear_hex( const CartVect* hex, const CartVect& xyz, double etol ); 00360 00361 bool nat_coords_trilinear_hex( const CartVect* corner_coords, const CartVect& x, CartVect& xi, double tol ); 00362 } // namespace GeomUtil 00363 00364 } // namespace moab 00365 00366 #endif
