MOAB: Mesh Oriented datABase
(version 5.4.1)
#include <H5Tpublic.h>#include <H5Dpublic.h>#include <H5Gpublic.h>#include <H5Ppublic.h>#include "mhdf.h"#include "util.h"#include "file-handle.h"#include "status.h"#include "names-and-paths.h"
Include dependency graph for connectivity.c:Go to the source code of this file.
Functions | |
| hid_t | mhdf_createConnectivity (mhdf_FileHandle file_handle, const char *elem_handle, int nodes_per_elem, long count, long *first_id_out, mhdf_Status *status) |
| Create connectivity table for an element group. | |
| hid_t | mhdf_openConnectivity (mhdf_FileHandle file_handle, const char *elem_handle, int *num_nodes_per_elem_out, long *num_elements_out, long *first_elem_id_out, mhdf_Status *status) |
| Open connectivity table for an element group. | |
| hid_t | mhdf_openConnectivitySimple (mhdf_FileHandle file_handle, const char *elem_handle, mhdf_Status *status) |
| void | mhdf_writeConnectivity (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *nodes, mhdf_Status *status) |
| Write element coordinate data. | |
| void | mhdf_writeConnectivityWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *nodes, hid_t prop, mhdf_Status *status) |
| void | mhdf_readConnectivity (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *nodes, mhdf_Status *status) |
| Read element coordinate data. | |
| void | mhdf_readConnectivityWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *nodes, hid_t prop, mhdf_Status *status) |
| void | mhdf_createPolyConnectivity (mhdf_FileHandle file_handle, const char *elem_type, long num_poly, long data_list_length, long *first_id_out, hid_t handles_out[2], mhdf_Status *status) |
| Create a new table for polygon or polyhedron connectivity data. | |
| void | mhdf_openPolyConnectivity (mhdf_FileHandle file_handle, const char *element_handle, long *num_poly_out, long *data_list_length_out, long *first_poly_id_out, hid_t handles_out[2], mhdf_Status *status) |
| Open a table of polygon or polyhedron connectivity data. | |
| void | mhdf_writePolyConnIndices (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *index_list, mhdf_Status *status) |
| Write polygon or polyhedron index data. | |
| void | mhdf_writePolyConnIndicesWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *index_list, hid_t prop, mhdf_Status *status) |
| void | mhdf_readPolyConnIndices (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *index_list, mhdf_Status *status) |
| Read polygon or polyhedron index data. | |
| void | mhdf_readPolyConnIndicesWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *index_list, hid_t prop, mhdf_Status *status) |
| void | mhdf_writePolyConnIDs (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *id_list, mhdf_Status *status) |
| Write polygon or polyhedron connectivity data. | |
| void | mhdf_writePolyConnIDsWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, const void *id_list, hid_t prop, mhdf_Status *status) |
| void | mhdf_readPolyConnIDs (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *id_list, mhdf_Status *status) |
| Read polygon or polyhedron connectivity data. | |
| void | mhdf_readPolyConnIDsWithOpt (hid_t table_id, long offset, long count, hid_t hdf_integer_type, void *id_list, hid_t prop, mhdf_Status *status) |
