MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"#include "MBParallelConventions.h"#include "ReadParallel.hpp"#include "moab/FileOptions.hpp"#include "MBTagConventions.hpp"#include "moab/Core.hpp"#include "moab_mpi.h"#include "TestUtil.hpp"#include <iostream>#include <algorithm>#include <sstream>#include <cassert>#include <unistd.h>
Include dependency graph for uber_parallel_test.cpp:Go to the source code of this file.
Defines | |
| #define | CHKERR(a) |
| #define | PCHECK(A) if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ ) |
| #define | RUN_TEST_ARG3(A, B, C) run_test( &( A ), #A, B, C ) |
Functions | |
| ErrorCode | report_error (const char *file, int line) |
| ErrorCode | test_read (const char *filename, const char *option) |
| int | is_any_proc_error (int is_my_error) |
| int | run_test (ErrorCode(*func)(const char *, const char *), const char *func_name, const std::string &file_name, const char *option) |
| int | main (int argc, char *argv[]) |
| #define CHKERR | ( | a | ) |
do \ { \ ErrorCode val = ( a ); \ if( MB_SUCCESS != val ) \ { \ std::cerr << "Error code " << val << " at " << __FILE__ << ":" << __LINE__ << std::endl; \ return val; \ } \ } while( false )
Definition at line 20 of file uber_parallel_test.cpp.
Referenced by test_read().
| #define PCHECK | ( | A | ) | if( is_any_proc_error( !( A ) ) ) return report_error( __FILE__, __LINE__ ) |
Definition at line 31 of file uber_parallel_test.cpp.
| #define RUN_TEST_ARG3 | ( | A, | |
| B, | |||
| C | |||
| ) | run_test( &( A ), #A, B, C ) |
Definition at line 42 of file uber_parallel_test.cpp.
Referenced by main().
| int is_any_proc_error | ( | int | is_my_error | ) |
Definition at line 44 of file uber_parallel_test.cpp.
References MPI_COMM_WORLD.
int result = 0;
int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
return err || result;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 71 of file uber_parallel_test.cpp.
References filename, MPI_COMM_WORLD, rank, RUN_TEST_ARG3, size, and test_read().
int rank, size;
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
MPI_Comm_size( MPI_COMM_WORLD, &size );
int num_errors = 0;
const char* option;
std::string vtk_test_filename = TestDir + "unittest/hex_2048.vtk";
#ifdef MOAB_HAVE_HDF5
std::string filename;
if( 1 < argc )
filename = std::string( argv[1] );
else
filename = TestDir + "unittest/64bricks_512hex.h5m";
//=========== read_delete, geom_dimension, resolve_shared
option = "PARALLEL=READ_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;"
"PARALLEL_RESOLVE_SHARED_ENTS;";
num_errors += RUN_TEST_ARG3( test_read, filename, option );
//=========== read_delete, material_set, resolve_shared
option = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
"SHARED_ENTS;";
//=========== bcast_delete, geom_dimension, resolve_shared
option = "PARALLEL=BCAST_DELETE;PARTITION=GEOM_DIMENSION;PARTITION_VAL=3;PARTITION_DISTRIBUTE;"
//=========== bcast_delete, material_set, resolve_shared
option = "PARALLEL=BCAST_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
"SHARED_ENTS;";
//=========== read_delete, geom_dimension, resolve_shared, exch ghost
"PARALLEL_RESOLVE_SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
//=========== read_delete, material_set, resolve_shared, exch ghost
"SHARED_ENTS;PARALLEL_GHOSTS=3.0.1;";
//=========== bcast_delete, geom_dimension, resolve_shared, exch ghost
//=========== bcast_delete, material_set, resolve_shared, exch ghost
#endif
if( vtk_test_filename.size() )
//=========== bcast_delete, trivial, resolve_shared
option = "PARALLEL=BCAST_DELETE;PARTITION=TRIVIAL;PARTITION_DISTRIBUTE;PARALLEL_RESOLVE_"
"SHARED_ENTS;";
num_errors += RUN_TEST_ARG3( test_read, vtk_test_filename, option );
//=========== bcast_delete, trivial, resolve_shared + ghosting
MPI_Finalize();
return num_errors;
| ErrorCode report_error | ( | const char * | file, |
| int | line | ||
Definition at line 34 of file uber_parallel_test.cpp.
std::cerr << "Failure at " << file << ':' << line << std::endl;
return MB_FAILURE;
| int run_test | ( | ErrorCode(*)(const char *, const char *) | func, |
| const char * | func_name, | ||
| const std::string & | file_name, | ||
| const char * | option | ||
Definition at line 51 of file uber_parallel_test.cpp.
References ErrorCode, is_any_proc_error(), MB_SUCCESS, MPI_COMM_WORLD, and rank.
ErrorCode result = ( *func )( file_name.c_str(), option );
int is_err = is_any_proc_error( ( MB_SUCCESS != result ) );
int rank;
if( rank == 0 )
if( is_err )
std::cout << func_name << " : FAILED!!" << std::endl;
else
std::cout << func_name << " : success" << std::endl;
return is_err;
Definition at line 145 of file uber_parallel_test.cpp.
References moab::ParallelComm::check_all_shared_handles(), CHKERR, ErrorCode, moab::ParallelComm::get_pcomm(), moab::Interface::load_file(), mb_instance(), and MB_SUCCESS.
Core mb_instance;
Interface& moab = mb_instance;
ErrorCode rval;
rval = moab.load_file( filename, 0, option );CHKERR( rval );
ParallelComm* pcomm = ParallelComm::get_pcomm( &moab, 0 );
rval = pcomm->check_all_shared_handles();CHKERR( rval );
return MB_SUCCESS;
