poly.c File Reference
#include <stdio.h>
#include <stdlib.h>
#include <stdarg.h>
#include <math.h>
#include <string.h>
#include <float.h>
#include "moab/FindPtFuncs.h"
+ Include dependency graph for poly.c:
Functions
void legendre_matrix (const realType *x, int m, realType *P, int n)
static void legendre_row_even (realType x, realType *P, int n)
static void legendre_row_odd (realType x, realType *P, int n)
void legendre_row (realType x, realType *P, int n)
void legendre_matrix_t (const realType *x, int m, realType *P, int n)
static realType legendre (int n, realType x)
static realType legendre_d1 (int n, realType x)
static realType legendre_d2 (int n, realType x)
void gauss_nodes (realType *z, int n)
static void lobatto_nodes_aux (realType *z, int n)
void lobatto_nodes (realType *z, int n)
void gauss_weights (const realType *z, realType *w, int n)
void lobatto_weights (const realType *z, realType *w, int n)
void gauss_to_legendre (const realType *z, const realType *w, int n, realType *J)
void gauss_to_legendre_t (const realType *z, const realType *w, int n, realType *J)
void lobatto_to_legendre (const realType *z, const realType *w, int n, realType *J)
void lagrange_weights (const realType *z, unsigned n, const realType *x, unsigned m, realType *J, realType *work)
void lagrange_weights_deriv (const realType *z, unsigned n, const realType *x, unsigned m, realType *J, realType *D, realType *work)
void lagrange_0 (lagrange_data *p, realType x)
void lagrange_1 (lagrange_data *p, realType x)
void lagrange_2 (lagrange_data *p, realType x)
void lagrange_2u (lagrange_data *p)
void lagrange_setup (lagrange_data *p, const realType *z, unsigned n)
void lagrange_free (lagrange_data *p)
Function Documentation
void gauss_nodes ( realType *  z,
int  n
Definition at line 155 of file poly.c.
References legendre(), legendre_d1(), mbabs, mbcos, MOAB_POLY_EPS, and MOAB_POLY_PI.
    int i, j;
    for( i = 0; i <= n / 2 - 1; ++i )
        realType ox, x = mbcos( ( 2 * n - 2 * i - 1 ) * ( MOAB_POLY_PI / 2 ) / n );
        do
            ox = x;
            x -= legendre( n, x ) / legendre_d1( n, x );
        } while( mbabs( x - ox ) > -x * MOAB_POLY_EPS );
        z[i] = x - legendre( n, x ) / legendre_d1( n, x );
    if( n & 1 ) z[n / 2] = 0;
    for( j = ( n + 1 ) / 2, i = n / 2 - 1; j < n; ++j, --i )
        z[j] = -z[i];
void gauss_to_legendre ( const realType *  z,
const realType *  w,
int  n,
realType *  J
Definition at line 239 of file poly.c.
References legendre_matrix_t().
    int i, j;
    legendre_matrix_t( z, n, J, n - 1 );
    for( j = 0; j < n; ++j )
        realType ww = w[j];
        for( i = 0; i < n; ++i )
            *J++ *= ( 2 * i + 1 ) * ww / 2;
void gauss_to_legendre_t ( const realType *  z,
const realType *  w,
int  n,
realType *  J
Definition at line 255 of file poly.c.
References legendre_matrix().
    int i, j;
    legendre_matrix( z, n, J, n - 1 );
        realType ii = (realType)( 2 * i + 1 ) / 2;
            *J++ *= ii * w[j];
void gauss_weights ( const realType *  z,
realType *  w,
int  n
Definition at line 199 of file poly.c.
References legendre().
    int i, j;
    for( i = 0; i <= ( n - 1 ) / 2; ++i )
        realType d = ( n + 1 ) * legendre( n + 1, z[i] );
        w[i]       = 2 * ( 1 - z[i] * z[i] ) / ( d * d );
        w[j] = w[i];
void lagrange_1 ( lagrange_data *  p,
realType  x
Definition at line 427 of file poly.c.
References lagrange_data::D, lagrange_data::d, lagrange_data::J, lagrange_data::n, lagrange_data::u0, lagrange_data::u1, lagrange_data::v0, lagrange_data::v1, lagrange_data::w, and lagrange_data::z.
Referenced by opt_area_set_2(), opt_edge_set_2(), opt_edge_set_3(), opt_face_set_3(), and opt_vol_set_3().
    unsigned i, n = p->n;
        p->d[i] = x - p->z[i];
    for( i = 0; i < n - 1; ++i )
        p->u0[i + 1] = p->d[i] * p->u0[i], p->u1[i + 1] = p->d[i] * p->u1[i] + p->u0[i];
    for( i = n - 1; i; --i )
        p->v0[i - 1] = p->d[i] * p->v0[i], p->v1[i - 1] = p->d[i] * p->v1[i] + p->v0[i];
        p->J[i] = p->w[i] * p->u0[i] * p->v0[i], p->D[i] = p->w[i] * ( p->u1[i] * p->v0[i] + p->u0[i] * p->v1[i] );
void lagrange_2 ( lagrange_data *  p,
realType  x
Definition at line 440 of file poly.c.
References lagrange_data::D, lagrange_data::d, lagrange_data::D2, lagrange_data::J, lagrange_data::n, lagrange_data::u0, lagrange_data::u1, lagrange_data::u2, lagrange_data::v0, lagrange_data::v1, lagrange_data::v2, lagrange_data::w, and lagrange_data::z.
Referenced by lagrange_setup().
        p->u0[i + 1] = p->d[i] * p->u0[i], p->u1[i + 1] = p->d[i] * p->u1[i] + p->u0[i],
                  p->u2[i + 1] = p->d[i] * p->u2[i] + 2 * p->u1[i];
        p->v0[i - 1] = p->d[i] * p->v0[i], p->v1[i - 1] = p->d[i] * p->v1[i] + p->v0[i],
                  p->v2[i - 1] = p->d[i] * p->v2[i] + 2 * p->v1[i];
        p->J[i] = p->w[i] * p->u0[i] * p->v0[i], p->D[i] = p->w[i] * ( p->u1[i] * p->v0[i] + p->u0[i] * p->v1[i] ),
        p->D2[i] = p->w[i] * ( p->u2[i] * p->v0[i] + 2 * p->u1[i] * p->v1[i] + p->u0[i] * p->v2[i] );
void lagrange_2u ( lagrange_data *  p)
Definition at line 456 of file poly.c.
References lagrange_data::d, lagrange_data::D2, lagrange_data::n, lagrange_data::u0, lagrange_data::u1, lagrange_data::u2, lagrange_data::v0, lagrange_data::v1, lagrange_data::v2, and lagrange_data::w.
Referenced by opt_edge_hess_2(), opt_edge_hess_3(), and opt_face_hess_3().
void lagrange_setup ( lagrange_data *  p,
const realType *  z,
unsigned  n
Definition at line 467 of file poly.c.
References lagrange_data::D, lagrange_data::d, lagrange_data::D2, lagrange_data::D2_z0, lagrange_data::D2_zn, lagrange_data::D_z0, lagrange_data::D_zn, lagrange_data::J, lagrange_data::J_z0, lagrange_data::J_zn, lagrange_2(), lagrange_data::n, tmalloc, lagrange_data::u0, lagrange_data::u1, lagrange_data::u2, lagrange_data::v0, lagrange_data::v1, lagrange_data::v2, lagrange_data::w, and lagrange_data::z.
Referenced by findpt_setup_2(), findpt_setup_3(), moab::ElemUtil::hex_eval(), moab::ElemUtil::hex_findpt(), moab::Element::SpectralHex::Init(), moab::Element::SpectralQuad::Init(), moab::SpectralHex::initFcn(), and moab::element_utility::Spectral_hex_map< moab::Matrix3 >::initialize_spectral_hex().
    unsigned i, j;
    p->n = n, p->z = z;
    p->w = tmalloc( realType, 17 * n );
    p->d = p->w + n;
    p->J = p->d + n, p->D = p->J + n, p->D2 = p->D + n;
    p->u0 = p->D2 + n, p->v0 = p->u0 + n;
    p->u1 = p->v0 + n, p->v1 = p->u1 + n;
    p->u2 = p->v1 + n, p->v2 = p->u2 + n;
    p->J_z0 = p->v2 + n, p->D_z0 = p->J_z0 + n, p->D2_z0 = p->D_z0 + n;
    p->J_zn = p->D2_z0 + n, p->D_zn = p->J_zn + n, p->D2_zn = p->D_zn + n;
        realType ww = 1, zi = z[i];
        for( j = 0; j < i; ++j )
            ww *= zi - z[j];
        for( ++j; j < n; ++j )
            ww *= zi - z[j];
        p->w[i] = 1 / ww;
    p->u0[0] = p->v0[n - 1] = 1;
    p->u1[0] = p->v1[n - 1] = 0;
    p->u2[0] = p->v2[n - 1] = 0;
    lagrange_2( p, z[0] );
    memcpy( p->J_z0, p->J, 3 * n * sizeof( realType ) );
    lagrange_2( p, z[n - 1] );
    memcpy( p->J_zn, p->J, 3 * n * sizeof( realType ) );
void lagrange_weights ( const realType *  z,
unsigned  n,
const realType *  x,
unsigned  m,
realType *  J,
realType *  work
Definition at line 320 of file poly.c.
    unsigned i, j;
    realType *w = work, *d = w + n, *u = d + n, *v = u + n;
            ww *= zi - z[j];
            ww *= zi - z[j];
        w[i] = 1 / ww;
    u[0] = v[n - 1] = 1;
    for( i = 0; i < m; ++i )
        realType xi = x[i];
            d[j] = xi - z[j];
        for( j = 0; j < n - 1; ++j )
            u[j + 1] = d[j] * u[j];
        for( j = n - 1; j; --j )
            v[j - 1] = d[j] * v[j];
            *J++ = w[j] * u[j] * v[j];
void lagrange_weights_deriv ( const realType *  z,
unsigned  n,
const realType *  x,
unsigned  m,
realType *  J,
realType *  D,
realType *  work
Definition at line 354 of file poly.c.
Referenced by lob_bnd_base_setup(), obbox_setup_2(), and obbox_setup_3().
    unsigned i, j;
    realType *w = work, *d = w + n, *u = d + n, *v = u + n, *up = v + n, *vp = up + n;
            ww *= zi - z[j];
            ww *= zi - z[j];
        w[i] = 1 / ww;
    up[0] = vp[n - 1] = 0;
        realType xi = x[i];
            d[j] = xi - z[j];
            u[j + 1] = d[j] * u[j], up[j + 1] = d[j] * up[j] + u[j];
            v[j - 1] = d[j] * v[j], vp[j - 1] = d[j] * vp[j] + v[j];
            *J++ = w[j] * u[j] * v[j], *D++ = w[j] * ( up[j] * v[j] + u[j] * vp[j] );
static realType legendre ( int  n,
realType  x
) [static]
Definition at line 104 of file poly.c.
Referenced by gauss_nodes(), gauss_weights(), and lobatto_weights().
    realType p[2];
    int i;
    p[0] = 1;
    p[1] = x;
    for( i = 1; i < n; i += 2 )
        p[0] = ( ( 2 * i + 1 ) * x * p[1] - i * p[0] ) / ( i + 1 );
        p[1] = ( ( 2 * i + 3 ) * x * p[0] - ( i + 1 ) * p[1] ) / ( i + 2 );
    return p[n & 1];
static realType legendre_d1 ( int  n,
realType  x
) [static]
Definition at line 119 of file poly.c.
Referenced by gauss_nodes(), and lobatto_nodes_aux().
    realType p[2];
    int i;
    p[0] = 3 * x;
    p[1] = 1;
    for( i = 2; i < n; i += 2 )
        p[1] = ( ( 2 * i + 1 ) * x * p[0] - ( i + 1 ) * p[1] ) / i;
        p[0] = ( ( 2 * i + 3 ) * x * p[1] - ( i + 2 ) * p[0] ) / ( i + 1 );
    return p[n & 1];
static realType legendre_d2 ( int  n,
realType  x
) [static]
Definition at line 134 of file poly.c.
Referenced by lobatto_nodes_aux().
    realType p[2];
    int i;
    p[0] = 3;
    p[1] = 15 * x;
    for( i = 3; i < n; i += 2 )
        p[0] = ( ( 2 * i + 1 ) * x * p[1] - ( i + 2 ) * p[0] ) / ( i - 1 );
        p[1] = ( ( 2 * i + 3 ) * x * p[0] - ( i + 3 ) * p[1] ) / i;
    return p[n & 1];
void legendre_matrix ( const realType *  x,
int  m,
realType *  P,
int  n
Definition at line 30 of file poly.c.
Referenced by gauss_to_legendre_t().
    int i, j;
    realType *Pjm1 = P, *Pj = Pjm1 + m, *Pjp1 = Pj + m;
        Pjm1[i] = 1;
        Pj[i] = x[i];
    for( j = 1; j < n; ++j )
        realType c = 1 / (realType)( j + 1 ), a = c * ( 2 * j + 1 ), b = c * j;
            Pjp1[i] = a * x[i] * Pj[i] - b * Pjm1[i];
        Pjp1 += m, Pj += m, Pjm1 += m;
void legendre_matrix_t ( const realType *  x,
int  m,
realType *  P,
int  n
Definition at line 87 of file poly.c.
References legendre_row_even(), and legendre_row_odd().
Referenced by gauss_to_legendre().
    int i;
    if( n & 1 )
        for( i = 0; i < m; ++i, P += n + 1 )
            legendre_row_odd( x[i], P, n );
    else
            legendre_row_even( x[i], P, n );
void legendre_row ( realType  x,
realType *  P,
int  n
Definition at line 75 of file poly.c.
    if( n & 1 )
        legendre_row_odd( x, P, n );
    else
        legendre_row_even( x, P, n );
static void legendre_row_even ( realType  x,
realType *  P,
int  n
) [static]
Definition at line 48 of file poly.c.
Referenced by legendre_matrix_t(), legendre_row(), and lobatto_to_legendre().
    int i;
    P[0] = 1, P[1] = x;
    for( i = 1; i <= n - 2; i += 2 )
        P[i + 1] = ( ( 2 * i + 1 ) * x * P[i] - i * P[i - 1] ) / ( i + 1 );
        P[i + 2] = ( ( 2 * i + 3 ) * x * P[i - 1] - ( i + 1 ) * P[i] ) / ( i + 2 );
    P[n] = ( ( 2 * n - 1 ) * x * P[n - 1] - ( n - 1 ) * P[n - 2] ) / n;
static void legendre_row_odd ( realType  x,
realType *  P,
int  n
) [static]
Definition at line 61 of file poly.c.
    int i;
    P[0] = 1, P[1] = x;
static void lobatto_nodes_aux ( realType *  z,
int  n
) [static]
Definition at line 174 of file poly.c.
References legendre_d1(), legendre_d2(), mbabs, mbcos, MOAB_POLY_EPS, MOAB_POLY_PI, and np.
Referenced by lobatto_nodes().
    int i, j, np = n + 1;
        realType ox, x = mbcos( ( n - i ) * MOAB_POLY_PI / np );
        do
            ox = x;
            x -= legendre_d1( np, x ) / legendre_d2( np, x );
        z[i] = x - legendre_d1( np, x ) / legendre_d2( np, x );
        z[j] = -z[i];
void lobatto_to_legendre ( const realType *  z,
const realType *  w,
int  n,
realType *  J
Definition at line 275 of file poly.c.
References legendre_row_even(), legendre_row_odd(), and moab::sum().
    int i, j, m = ( n + 1 ) / 2;
    realType *p = J, *q;
    realType ww, sum;
    if( n & 1 )
        for( j = 0; j < m; ++j, p += n )
            legendre_row_odd( z[j], p, n - 2 );
    else
            legendre_row_even( z[j], p, n - 2 );
    p = J;
    for( j = 0; j < m; ++j )
        ww = w[j], sum = 0;
            *p *= ( 2 * i + 1 ) * ww / 2, sum += *p++;
        *p++ = -sum;
    q = J + ( n / 2 - 1 ) * n;
    if( n & 1 )
        for( ; j < n; ++j, p += n, q -= n )
            for( i = 0; i < n - 1; i += 2 )
                p[i] = q[i], p[i + 1] = -q[i + 1];
            p[i] = q[i];
    else
void lobatto_weights ( const realType *  z,
realType *  w,
int  n
Definition at line 211 of file poly.c.
Referenced by hash_getbb_2(), and hash_getbb_3().
    int i, j;
        realType d = legendre( n - 1, z[i] );
        w[i]       = 2 / ( ( n - 1 ) * n * d * d );
        w[j] = w[i];
