Test_MBMeshSet.cpp File Reference
#include "MeshSet.hpp"
#include "AEntityFactory.hpp"
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/SetIterator.hpp"
#include <iostream>
+ Include dependency graph for Test_MBMeshSet.cpp:
Enumerations
enum  BoolOp { UNITE, INTERSECT, SUBTRACT }
Functions
void test_add_entities (unsigned flags)
 test add_entities, get_entities, num_entities
void test_remove_entities (unsigned flags)
 test remove_entities, get_entities, num_entities
void test_entities_by_type (unsigned flags)
 test get_entities_by_type, num_entities_by_type
void test_entities_by_dimension (unsigned flags)
 test get_entities_by_dimension, num_entities_by_dimension
void test_subtract (unsigned flags1, unsigned flags2)
 test subtract_meshset
void test_intersect (unsigned flags1, unsigned flags2)
 test intersect_meshset
void test_unite (unsigned flags1, unsigned flags2)
 test unite_meshset
void test_contains_entities (unsigned flags)
 test MeshSet::contains_entities
void test_clear (unsigned flags)
 test clear_meshset
void make_mesh (Interface &iface)
 Create 10x10x10 hex mesh.
void make_mesh (Interface &iface, EntityHandle &vstart, EntityHandle &vend, EntityHandle &hstart, EntityHandle &hend)
 Create 10x10x10 hex mesh, return ranges of handles.
void print_handle_vect (const char *prefix, const std::vector< EntityHandle > &vect)
 Print std::vector<EntityHandle>
void print_mbrange (const char *prefix, const Range &range)
 Print Range.
bool check_set_contents (Core &mb, EntityHandle set, const std::vector< EntityHandle > &expected)
 Compare set contents against passed vector, and if MESHSET_TRACK_OWNER then check adjacencies.
bool check_set_contents (Core &mb, EntityType type, EntityHandle set, unsigned flags)
 Compare result of get_entities_by_type to result of get_entities_by_handle.
bool check_set_contents (Core &mb, int dim, EntityHandle set, unsigned flags)
 Compare result of get_entities_by_dimension to result of get_entities_by_handle.
void remove_from_back (std::vector< EntityHandle > &vect, const Range &range)
 For each entry in range, if one or more occurances in vect, remove last occurance from vect.
bool test_boolean (Core &mb, BoolOp op, unsigned flags1, const Range &set1_ents, unsigned flags2, const Range &set2_ents)
 Perform boolean op on two entity sets and verify result.
void test_iterator (Interface &moab, SetIterator *iter, EntityHandle set, EntityType etype, int dim)
void test_iterators (unsigned int flags, bool type, bool dim)
void test_all_iterators ()
void test_add_entities_ordered ()
void test_add_entities_set ()
void test_add_entities_ordered_tracking ()
void test_add_entities_set_tracking ()
void test_remove_entities_ordered ()
void test_remove_entities_set ()
void test_remove_entities_ordered_tracking ()
void test_remove_entities_set_tracking ()
void test_entities_by_type_ordered ()
void test_entities_by_type_set ()
void test_entities_by_dim_ordered ()
void test_entities_by_dim_set ()
void test_subtract_set_set ()
void test_subtract_set_ordered ()
void test_subtract_ordered_set ()
void test_subtract_ordered_ordered ()
void test_subtract_set_set_tracking ()
void test_subtract_set_ordered_tracking ()
void test_subtract_ordered_set_tracking ()
void test_subtract_ordered_ordered_tracking ()
void test_itersect_set_set ()
void test_itersect_set_ordered ()
void test_itersect_ordered_set ()
void test_itersect_ordered_ordered ()
void test_itersect_set_set_tracking ()
void test_itersect_set_ordered_tracking ()
void test_itersect_ordered_set_tracking ()
void test_itersect_ordered_ordered_tracking ()
void test_unite_set_set ()
void test_unite_set_ordered ()
void test_unite_ordered_set ()
void test_unite_ordered_ordered ()
void test_unite_set_set_tracking ()
void test_unite_set_ordered_tracking ()
void test_unite_ordered_set_tracking ()
void test_unite_ordered_ordered_tracking ()
void test_contains_entities_ordered ()
void test_contains_entities_set ()
void test_clear_ordered ()
void test_clear_set ()
void test_clear_ordered_tracking ()
void test_clear_set_tracking ()
void regression_insert_set_1 ()
int main ()
template<typename iter_type >
void print_handles (std::ostream &str, const char *prefix, iter_type begin, iter_type end)
bool compare_set_contents (unsigned flags, const std::vector< EntityHandle > &expected, int set_count, std::vector< EntityHandle > &vect, const Range &range)
Enumeration Type Documentation
enum BoolOp
Enumerator:
UNITE
INTERSECT
SUBTRACT
Definition at line 46 of file Test_MBMeshSet.cpp.
Function Documentation
bool check_set_contents ( Core &  mb,
EntityHandle  set,
const std::vector< EntityHandle > &  expected
Definition at line 479 of file Test_MBMeshSet.cpp.
References moab::Core::a_entity_factory(), moab::Range::begin(), CHECK_ERR, compare_set_contents(), moab::Range::end(), ErrorCode, moab::AEntityFactory::get_adjacencies(), moab::Core::get_entities_by_handle(), moab::Core::get_meshset_options(), moab::Core::get_number_entities_by_handle(), moab::Range::insert(), MESHSET_TRACK_OWNER, and print_mbrange().
Referenced by test_add_entities(), test_boolean(), test_clear(), test_entities_by_dimension(), test_entities_by_type(), and test_remove_entities().
    unsigned flags;
    ErrorCode rval = mb.get_meshset_options( set, flags );CHECK_ERR( rval );
    int count;
    std::vector< EntityHandle > vect;
    Range range;
    rval = mb.get_entities_by_handle( set, vect, false );CHECK_ERR( rval );
    rval = mb.get_entities_by_handle( set, range, false );CHECK_ERR( rval );
    rval = mb.get_number_entities_by_handle( set, count, false );CHECK_ERR( rval );
    if( !compare_set_contents( flags, expected, count, vect, range ) ) return false;
    if( !( flags & MESHSET_TRACK_OWNER ) ) return true;
    // get all entitites with an adjacency to the set
    std::vector< EntityHandle > adj;
    Range all, adjacent;
    Range::iterator in = adjacent.begin();
    mb.get_entities_by_handle( 0, all );
    for( Range::iterator i = all.begin(); i != all.end(); ++i )
        adj.clear();
        rval = mb.a_entity_factory()->get_adjacencies( *i, adj );CHECK_ERR( rval );
        std::vector< EntityHandle >::iterator j = std::lower_bound( adj.begin(), adj.end(), set );
        if( j != adj.end() && *j == set ) in = adjacent.insert( in, *i, *i );
    if( range != adjacent )
        std::cout << "Incorrect adjacent entities for tracking set" << std::endl;
        print_mbrange( "Expected", range );
        print_mbrange( "Actual", adjacent );
        return false;
    return true;
EntityType  type,
EntityHandle  set,
unsigned  flags
Definition at line 519 of file Test_MBMeshSet.cpp.
References moab::Range::begin(), CHECK_ERR, compare_set_contents(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_handle(), moab::Core::get_entities_by_type(), moab::Core::get_number_entities_by_type(), and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    int count;
    std::vector< EntityHandle > vect, expected;
    Range range;
    rval = mb.get_entities_by_handle( set, expected, false );CHECK_ERR( rval );
    std::vector< EntityHandle >::iterator i = expected.begin();
    while( i != expected.end() )
        if( TYPE_FROM_HANDLE( *i ) != type )
            i = expected.erase( i );
        else
            ++i;
    rval = mb.get_entities_by_type( set, type, range, false );CHECK_ERR( rval );
    rval = mb.get_number_entities_by_type( set, type, count, false );CHECK_ERR( rval );
    std::copy( range.begin(), range.end(), std::back_inserter( vect ) );
    return compare_set_contents( flags, expected, count, vect, range );
int  dim,
EntityHandle  set,
unsigned  flags
Definition at line 543 of file Test_MBMeshSet.cpp.
References moab::Range::begin(), CHECK_ERR, compare_set_contents(), dim, moab::CN::Dimension(), moab::Range::end(), ErrorCode, moab::Core::get_entities_by_dimension(), moab::Core::get_entities_by_handle(), moab::Core::get_number_entities_by_dimension(), and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    int count;
    Range range;
        if( CN::Dimension( TYPE_FROM_HANDLE( *i ) ) != dim )
        else
            ++i;
    rval = mb.get_entities_by_dimension( set, dim, range, false );CHECK_ERR( rval );
    rval = mb.get_number_entities_by_dimension( set, dim, count, false );CHECK_ERR( rval );
bool compare_set_contents ( unsigned  flags,
const std::vector< EntityHandle > &  expected,
int  set_count,
std::vector< EntityHandle > &  vect,
const Range &  range
Definition at line 422 of file Test_MBMeshSet.cpp.
References moab::Range::begin(), moab::Range::end(), print_handle_vect(), print_mbrange(), and moab::Range::size().
Referenced by check_set_contents().
    std::vector< EntityHandle > sorted( expected );
    std::sort( sorted.begin(), sorted.end() );
    sorted.erase( std::unique( sorted.begin(), sorted.end() ), sorted.end() );
    int expected_size = 0;
    if( flags & MESHSET_ORDERED )
        if( expected != vect )
            std::cout << "Incorrect set contents from vector-based query" << std::endl;
            print_handle_vect( "Expected", expected );
            print_handle_vect( "Actual", vect );
            return false;
        expected_size = expected.size();
    else
        if( sorted != vect )
            print_handle_vect( "Expected", sorted );
            return false;
        expected_size = sorted.size();
    if( expected_size != set_count )
        std::cout << "Incorrect size for entity set" << std::endl;
        std::cout << "Expected: " << expected_size << std::endl;
        std::cout << "Actual:   " << set_count << std::endl;
        return false;
    vect.clear();
    vect.resize( range.size() );
    std::copy( range.begin(), range.end(), vect.begin() );
        std::cout << "Incorrect set contents from mbrange-based query" << std::endl;
        print_handle_vect( "Expected", vect );
        print_mbrange( "Actual", range );
        return false;
    return true;
int main ( )
Definition at line 244 of file Test_MBMeshSet.cpp.
References regression_insert_set_1(), RUN_TEST, test_add_entities_ordered(), test_add_entities_ordered_tracking(), test_add_entities_set(), test_add_entities_set_tracking(), test_all_iterators(), test_clear_ordered(), test_clear_ordered_tracking(), test_clear_set(), test_clear_set_tracking(), test_contains_entities_ordered(), test_contains_entities_set(), test_entities_by_dim_ordered(), test_entities_by_dim_set(), test_entities_by_type_ordered(), test_entities_by_type_set(), test_itersect_ordered_ordered(), test_itersect_ordered_ordered_tracking(), test_itersect_ordered_set(), test_itersect_ordered_set_tracking(), test_itersect_set_ordered(), test_itersect_set_ordered_tracking(), test_itersect_set_set(), test_itersect_set_set_tracking(), test_remove_entities_ordered(), test_remove_entities_ordered_tracking(), test_remove_entities_set(), test_remove_entities_set_tracking(), test_subtract_ordered_ordered(), test_subtract_ordered_ordered_tracking(), test_subtract_ordered_set(), test_subtract_ordered_set_tracking(), test_subtract_set_ordered(), test_subtract_set_ordered_tracking(), test_subtract_set_set(), test_subtract_set_set_tracking(), test_unite_ordered_ordered(), test_unite_ordered_ordered_tracking(), test_unite_ordered_set(), test_unite_ordered_set_tracking(), test_unite_set_ordered(), test_unite_set_ordered_tracking(), test_unite_set_set(), and test_unite_set_set_tracking().
    int err = 0;
    err += RUN_TEST( test_add_entities_ordered );
    err += RUN_TEST( test_add_entities_set );
    err += RUN_TEST( test_add_entities_ordered_tracking );
    err += RUN_TEST( test_add_entities_set_tracking );
    err += RUN_TEST( test_remove_entities_ordered );
    err += RUN_TEST( test_remove_entities_set );
    err += RUN_TEST( test_remove_entities_ordered_tracking );
    err += RUN_TEST( test_remove_entities_set_tracking );
    err += RUN_TEST( test_entities_by_type_ordered );
    err += RUN_TEST( test_entities_by_type_set );
    err += RUN_TEST( test_entities_by_dim_ordered );
    err += RUN_TEST( test_entities_by_dim_set );
    err += RUN_TEST( test_subtract_set_set );
    err += RUN_TEST( test_subtract_set_ordered );
    err += RUN_TEST( test_subtract_ordered_set );
    err += RUN_TEST( test_subtract_ordered_ordered );
    err += RUN_TEST( test_subtract_set_set_tracking );
    err += RUN_TEST( test_subtract_set_ordered_tracking );
    err += RUN_TEST( test_subtract_ordered_set_tracking );
    err += RUN_TEST( test_subtract_ordered_ordered_tracking );
    err += RUN_TEST( test_itersect_set_set );
    err += RUN_TEST( test_itersect_set_ordered );
    err += RUN_TEST( test_itersect_ordered_set );
    err += RUN_TEST( test_itersect_ordered_ordered );
    err += RUN_TEST( test_itersect_set_set_tracking );
    err += RUN_TEST( test_itersect_set_ordered_tracking );
    err += RUN_TEST( test_itersect_ordered_set_tracking );
    err += RUN_TEST( test_itersect_ordered_ordered_tracking );
    err += RUN_TEST( test_unite_set_set );
    err += RUN_TEST( test_unite_set_ordered );
    err += RUN_TEST( test_unite_ordered_set );
    err += RUN_TEST( test_unite_ordered_ordered );
    err += RUN_TEST( test_unite_set_set_tracking );
    err += RUN_TEST( test_unite_set_ordered_tracking );
    err += RUN_TEST( test_unite_ordered_set_tracking );
    err += RUN_TEST( test_unite_ordered_ordered_tracking );
    err += RUN_TEST( test_contains_entities_ordered );
    err += RUN_TEST( test_contains_entities_set );
    err += RUN_TEST( test_clear_ordered );
    err += RUN_TEST( test_clear_set );
    err += RUN_TEST( test_clear_ordered_tracking );
    err += RUN_TEST( test_clear_set_tracking );
    err += RUN_TEST( regression_insert_set_1 );
    err += RUN_TEST( test_all_iterators );
    if( !err )
        printf( "ALL TESTS PASSED\n" );
    else
        printf( "%d TESTS FAILED\n", err );
    return err;
void make_mesh ( Interface &  iface)
Definition at line 311 of file Test_MBMeshSet.cpp.
References CHECK_EQUAL, CHECK_ERR, PointInVol::coords, moab::Interface::create_element(), moab::Interface::create_vertex(), dim, ErrorCode, moab::FIRST_HANDLE(), and MBHEX.
Referenced by make_mesh(), test_add_entities(), test_clear(), test_entities_by_dimension(), test_entities_by_type(), test_intersect(), test_iterators(), test_remove_entities(), test_subtract(), and test_unite().
    const int dim = 10;
    // create vertices
    EntityHandle prev_handle = 0;
    for( int z = 0; z <= dim; ++z )
        for( int y = 0; y <= dim; ++y )
            for( int x = 0; x <= dim; ++x )
                const double coords[]   = { static_cast< double >( x ), static_cast< double >( y ),
                                          static_cast< double >( z ) };
                EntityHandle new_handle = 0;
                ErrorCode rval          = iface.create_vertex( coords, new_handle );CHECK_ERR( rval );
                CHECK_EQUAL( ++prev_handle, new_handle );
    // create hexes
    const int dim1 = dim + 1;
    const int dimq = dim1 * dim1;
    prev_handle    = FIRST_HANDLE( MBHEX );
    for( int z = 0; z < dim; ++z )
        for( int y = 0; y < dim; ++y )
            for( int x = 0; x < dim; ++x )
                const EntityHandle off    = 1 + x + dim1 * y + dimq * z;
                const EntityHandle conn[] = { off,        off + 1,        off + 1 + dim1,        off + dim1,
                                              off + dimq, off + 1 + dimq, off + 1 + dim1 + dimq, off + dim1 + dimq };
                ErrorCode rval            = iface.create_element( MBHEX, conn, 8, new_handle );CHECK_ERR( rval );
                CHECK_EQUAL( prev_handle++, new_handle );
void make_mesh ( Interface &  iface,
EntityHandle &  vstart,
EntityHandle &  vend,
EntityHandle &  hstart,
EntityHandle &  hend
Definition at line 353 of file Test_MBMeshSet.cpp.
References moab::Range::back(), CHECK_EQUAL, CHECK_ERR, moab::Range::clear(), ErrorCode, moab::Range::front(), moab::Interface::get_entities_by_type(), make_mesh(), MBHEX, and MBVERTEX.
    make_mesh( mb );
    // Get handle ranges, and validate assumption that handles
    // are contiguous.
    Range range;
    ErrorCode rval = mb.get_entities_by_type( 0, MBVERTEX, range );CHECK_ERR( rval );
    first_vert = range.front();
    last_vert  = range.back();
    CHECK_EQUAL( (EntityHandle)1331, last_vert - first_vert + 1 );
    range.clear();
    rval = mb.get_entities_by_type( 0, MBHEX, range );CHECK_ERR( rval );
    first_hex = range.front();
    last_hex  = range.back();
    CHECK_EQUAL( (EntityHandle)1000, last_hex - first_hex + 1 );
void print_handle_vect ( const char *  prefix,
const std::vector< EntityHandle > &  vect
Definition at line 412 of file Test_MBMeshSet.cpp.
References print_handles().
Referenced by compare_set_contents().
    print_handles( std::cout, prefix, vect.begin(), vect.end() );
void print_handles ( std::ostream &  str,
iter_type  begin,
iter_type  end
Definition at line 376 of file Test_MBMeshSet.cpp.
References moab::CN::EntityTypeName(), moab::ID_FROM_HANDLE(), and moab::TYPE_FROM_HANDLE().
Referenced by print_handle_vect(), and print_mbrange().
    if( prefix ) str << prefix << ':';
    if( begin == end )
        str << " (empty)" << std::endl;
        return;
    iter_type i           = begin;
    EntityType prev_type  = TYPE_FROM_HANDLE( *i );
    EntityHandle prev_ent = *i;
    str << ' ' << CN::EntityTypeName( prev_type ) << ' ' << ID_FROM_HANDLE( *i );
    for( ;; )
        iter_type j = i;
        for( ++j, ++prev_ent; j != end && *j == prev_ent; ++j, ++prev_ent )
        --prev_ent;
        if( prev_ent - *i > 1 )
            str << "-" << ID_FROM_HANDLE( prev_ent );
        else if( prev_ent - *i == 1 )
            str << ", " << ID_FROM_HANDLE( prev_ent );
        i = j;
        if( i == end ) break;
        str << ',';
        if( TYPE_FROM_HANDLE( *i ) != prev_type )
            str << ' ' << CN::EntityTypeName( prev_type = TYPE_FROM_HANDLE( *i ) );
        str << ' ' << ID_FROM_HANDLE( *i );
        prev_ent = *i;
    str << std::endl;
void print_mbrange ( const char *  prefix,
const Range &  range
Print Range.
Definition at line 417 of file Test_MBMeshSet.cpp.
References moab::Range::begin(), moab::Range::end(), and print_handles().
Referenced by check_set_contents(), and compare_set_contents().
    print_handles( std::cout, prefix, range.begin(), range.end() );
Definition at line 1209 of file Test_MBMeshSet.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::CREATE_HANDLE(), moab::Interface::create_meshset(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_handle(), init(), moab::Range::insert(), mb, MBEDGE, MBQUAD, moab::Range::merge(), and MESHSET_SET.
Referenced by main().
    EntityHandle e                      = CREATE_HANDLE( MBEDGE, 0 );
    EntityHandle q                      = CREATE_HANDLE( MBQUAD, 0 );
    const EntityHandle initial_ranges[] = {
        0x7fe,      0x7fe,      0x802,      0x80b,      0xb3a,      0xb3c,      0xb6b,      0xb6b,      0xbed,
        0xbee,      0x19ff,     0x19ff,     0x1a0b,     0x1a0b,     0x1a16,     0x1a17,     0x1a56,     0x1a57,
        0x2554,     0x255c,     e + 0x0099, e + 0x009b, e + 0x00c0, e + 0x00c2, e + 0x0729, e + 0x0732, e + 0x0a3b,
        e + 0x0a3d, e + 0x0ba9, e + 0x0bab, e + 0x2322, e + 0x232b, q + 0x00c,  q + 0x017,  q + 0x0e9,  q + 0x112,
        q + 0x2f2,  q + 0x303,  q + 0x67e,  q + 0x6a5,  q + 0x866,  q + 0x871,  q + 0x8f5,  q + 0x900,  q + 0xc06,
        q + 0xc17,  q + 0xc7e,  q + 0xc9b,  q + 0xce0,  q + 0xd07 };
    const EntityHandle new_ranges[] = { 0x7e1,  0x829,  0xb37,  0xb63,  0xb6b,  0xb6b,  0xb73,  0xb75,  0xbed,
                                        0xbee,  0xc0b,  0xc10,  0x19fd, 0x19fd, 0x19ff, 0x19ff, 0x1a02, 0x1a04,
                                        0x1a0b, 0x1a0b, 0x1a11, 0x1a17, 0x1a1b, 0x1a23, 0x1a56, 0x1a57, 0x1a7c,
                                        0x1a96, 0x1bb5, 0x1bba, 0x254b, 0x2565, 0x25a5, 0x25bf };
    Core moab;
    Interface& mb = moab;
    ErrorCode rval;
    EntityHandle set;
    rval = mb.create_meshset( MESHSET_SET, set );CHECK_ERR( rval );
    Range init, add;
    for( size_t i = 0; i < sizeof( initial_ranges ) / sizeof( initial_ranges[0] ); i += 2 )
        init.insert( initial_ranges[i], initial_ranges[i + 1] );
    for( size_t i = 0; i < sizeof( new_ranges ) / sizeof( new_ranges[0] ); i += 2 )
        add.insert( new_ranges[i], new_ranges[i + 1] );
    rval = mb.add_entities( set, init );CHECK_ERR( rval );
    rval = mb.add_entities( set, add );CHECK_ERR( rval );
    std::vector< EntityHandle > contents;
    rval = mb.get_entities_by_handle( set, contents );CHECK_ERR( rval );
    init.merge( add );
    Range::iterator r                       = init.begin();
    std::vector< EntityHandle >::iterator v = contents.begin();
    for( ;; )
        if( r == init.end() || v == contents.end() )
            CHECK( r == init.end() );
            CHECK( v == contents.end() );
            break;
        CHECK_EQUAL( *r, *v );
        ++r;
        ++v;
void remove_from_back ( std::vector< EntityHandle > &  vect,
const Range &  range
Definition at line 744 of file Test_MBMeshSet.cpp.
References moab::Range::begin(), and moab::Range::end().
Referenced by test_remove_entities().
    for( Range::const_iterator r = range.begin(); r != range.end(); ++r )
        std::vector< EntityHandle >::reverse_iterator i = find( vect.rbegin(), vect.rend(), *r );
        if( i != vect.rend() ) *i = 0;
    std::vector< EntityHandle >::iterator j = vect.begin();
    while( j != vect.end() )
        if( *j == 0 )
            j = vect.erase( j );
        else
            ++j;
void test_add_entities ( unsigned  flags)
Definition at line 567 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), moab::Range::begin(), CHECK, CHECK_ERR, check_set_contents(), moab::Range::clear(), moab::Core::create_meshset(), moab::Range::end(), ErrorCode, moab::Range::insert(), make_mesh(), and mb.
Referenced by test_add_entities_ordered(), test_add_entities_ordered_tracking(), test_add_entities_set(), and test_add_entities_set_tracking().
    Core mb;
    make_mesh( mb );
    EntityHandle set;
    ErrorCode rval = mb.create_meshset( flags, set );CHECK_ERR( rval );
    std::vector< EntityHandle > contents, vect;
    Range range;
    range.clear();
    range.insert( 11, 20 );
    std::copy( range.begin(), range.end(), std::back_inserter( contents ) );
    rval = mb.add_entities( set, range );CHECK_ERR( rval );
    // [11,20]
    CHECK( check_set_contents( mb, set, contents ) );
    range.clear();
    range.insert( 31, 40 );
    // [11,20],[31,40]
    range.clear();
    range.insert( 51, 60 );
    // [11,20],[31,40],[51,60]
    range.clear();
    range.insert( 71, 80 );
    // [11,20],[31,40],[51,60],[71,80]
    range.clear();
    range.insert( 91, 100 );
    // [11,20],[31,40],[51,60],[71,80],[91,100]
    range.clear();
    range.insert( 111, 120 );
    // [11,20],[31,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 6, 12 );
    // [6,20],[31,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 1, 3 );
    // [1,3],[6,20],[31,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 25, 25 );
    // [1,3],[6,20],[25,25],[31,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 30, 30 );
    // [1,3],[6,20],[25,25],[30,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 29, 31 );
    // [1,3],[6,20],[25,25],[29,40],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 41, 41 );
    // [1,3],[6,20],[25,25],[29,41],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 41, 45 );
    // [1,3],[6,20],[25,25],[29,45],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 47, 47 );
    // [1,3],[6,20],[25,25],[29,45],[47,47],[51,60],[71,80],[91,100],[111,120]
    range.clear();
    range.insert( 51, 80 );
    // [1,3],[6,20],[25,25],[29,45],[47,47],[51,80],[91,100],[111,120]
    range.clear();
    range.insert( 49, 105 );
    // [1,3],[6,20],[25,25],[29,45],[47,47],[49,105],[111,120]
    vect.clear();
    for( EntityHandle h = 1; h < 100; ++h )
        vect.push_back( h );
        contents.push_back( h );
    rval = mb.add_entities( set, &vect[0], vect.size() );CHECK_ERR( rval );
    // [1,105],[111,120]
    vect.clear();
    vect.push_back( 106 );
    vect.push_back( 108 );
    vect.push_back( 110 );
    std::copy( vect.begin(), vect.end(), std::back_inserter( contents ) );
    // [1,106],[108,108],[110,120]
    range.clear();
    range.insert( 107, 200 );
    // [1,200]
    range.clear();
    range.insert( 1, 1 );
    range.insert( 5, 6 );
    range.insert( 199, 200 );
    range.insert( 201, 202 );
    // [1,202]
    range.clear();
    range.insert( 300, 301 );
    // [1,202],[300,301]
    range.clear();
    range.insert( 203, 203 );
    range.insert( 205, 205 );
    range.insert( 207, 207 );
    range.insert( 299, 299 );
    // [1,203],[205,205],[207,207],[299,301]
Definition at line 63 of file Test_MBMeshSet.cpp.
References test_add_entities().
    test_add_entities( MESHSET_ORDERED );
Definition at line 71 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_add_entities().
    test_add_entities( MESHSET_TRACK_OWNER | MESHSET_ORDERED );
Definition at line 67 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_add_entities().
Definition at line 1262 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_iterators().
    test_iterators( MESHSET_SET, true, false );
    test_iterators( MESHSET_SET, false, true );
    test_iterators( MESHSET_ORDERED, true, false );
    test_iterators( MESHSET_ORDERED, false, true );
bool test_boolean ( Core &  mb,
BoolOp  op,
unsigned  flags1,
const Range &  set1_ents,
unsigned  flags2,
const Range &  set2_ents
Definition at line 1028 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), moab::Range::begin(), CHECK_ERR, check_set_contents(), moab::Core::create_meshset(), moab::Range::end(), ErrorCode, INTERSECT, moab::intersect(), moab::Core::intersect_meshset(), MB_INDEX_OUT_OF_RANGE, moab::Range::merge(), MESHSET_SET, moab::Range::size(), SUBTRACT, moab::subtract(), moab::Core::subtract_meshset(), UNITE, and moab::Core::unite_meshset().
Referenced by test_intersect(), test_subtract(), and test_unite().
    ErrorCode rval;
    // make sets
    EntityHandle set1, set2;
    rval = mb.create_meshset( flags1, set1 );CHECK_ERR( rval );
    rval = mb.create_meshset( flags2, set2 );CHECK_ERR( rval );
    rval = mb.add_entities( set1, set1_ents );CHECK_ERR( rval );
    rval = mb.add_entities( set2, set2_ents );CHECK_ERR( rval );
    Range tmp_range;
    std::vector< EntityHandle > expected;
    rval = MB_INDEX_OUT_OF_RANGE;
    switch( op )
        case UNITE:
            if( flags1 & MESHSET_SET )
                tmp_range = set1_ents;
                tmp_range.merge( set2_ents );
                expected.resize( tmp_range.size() );
                std::copy( tmp_range.begin(), tmp_range.end(), expected.begin() );
            else
                expected.clear();
                std::copy( set1_ents.begin(), set1_ents.end(), std::back_inserter( expected ) );
                std::copy( set2_ents.begin(), set2_ents.end(), std::back_inserter( expected ) );
            rval = mb.unite_meshset( set1, set2 );
            break;
        case INTERSECT:
            tmp_range = intersect( set1_ents, set2_ents );
            rval = mb.intersect_meshset( set1, set2 );
            break;
        case SUBTRACT:
            tmp_range = subtract( set1_ents, set2_ents );
            rval = mb.subtract_meshset( set1, set2 );
            break;
    CHECK_ERR( rval );
    return check_set_contents( mb, set1, expected );
void test_clear ( unsigned  flags)
test clear_meshset
Definition at line 1195 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), CHECK, CHECK_ERR, check_set_contents(), moab::Core::clear_meshset(), moab::Core::create_meshset(), ErrorCode, make_mesh(), and mb.
Referenced by test_clear_ordered(), test_clear_ordered_tracking(), test_clear_set(), and test_clear_set_tracking().
    std::vector< EntityHandle > contents( 4 );
    Core mb;
    make_mesh( mb, contents[0], contents[1], contents[2], contents[3] );
    EntityHandle set;
    rval = mb.add_entities( set, &contents[0], contents.size() );CHECK_ERR( rval );
    rval = mb.clear_meshset( &set, 1 );CHECK_ERR( rval );
    contents.clear();
Definition at line 222 of file Test_MBMeshSet.cpp.
References test_clear().
    test_clear( MESHSET_ORDERED );
Definition at line 230 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_clear().
    test_clear( MESHSET_TRACK_OWNER | MESHSET_ORDERED );
void test_clear_set ( )
Definition at line 226 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_clear().
Definition at line 234 of file Test_MBMeshSet.cpp.
References MESHSET_SET, MESHSET_TRACK_OWNER, and test_clear().
void test_contains_entities ( unsigned  flags)
Definition at line 1167 of file Test_MBMeshSet.cpp.
References CHECK, CHECK_ERR, entities, ErrorCode, moab::Interface::INTERSECT, MESHSET_TRACK_OWNER, PointInVol::result, and moab::Interface::UNION.
Referenced by test_contains_entities_ordered(), and test_contains_entities_set().
    CHECK( !( flags & MESHSET_TRACK_OWNER ) );
    MeshSet set( flags );
    bool result;
    const EntityHandle entities[] = { 1, 2, 3, 6, 10, 11, 25, 100 };
    const int num_ents            = sizeof( entities ) / sizeof( EntityHandle );
    ErrorCode rval                = set.add_entities( entities, num_ents, 0, 0 );CHECK_ERR( rval );
    result = set.contains_entities( entities, num_ents, Interface::UNION );
    CHECK( result );
    result = set.contains_entities( entities, num_ents, Interface::INTERSECT );
    CHECK( result );
    result = set.contains_entities( entities, 1, Interface::UNION );
    CHECK( result );
    result = set.contains_entities( entities, 1, Interface::INTERSECT );
    CHECK( result );
    const EntityHandle entities2[] = { 3, 4, 5 };
    const int num_ents2            = sizeof( entities2 ) / sizeof( EntityHandle );
    result                         = set.contains_entities( entities2, num_ents2, Interface::UNION );
    CHECK( result );
    result = set.contains_entities( entities2, num_ents2, Interface::INTERSECT );
    CHECK( !result );
Definition at line 213 of file Test_MBMeshSet.cpp.
References test_contains_entities().
    test_contains_entities( MESHSET_ORDERED );
Definition at line 217 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_contains_entities().
Definition at line 105 of file Test_MBMeshSet.cpp.
References test_entities_by_dimension().
    test_entities_by_dimension( MESHSET_ORDERED );
Definition at line 109 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_entities_by_dimension().
void test_entities_by_dimension ( unsigned  flags)
Definition at line 997 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), CHECK, CHECK_ERR, check_set_contents(), moab::Core::create_meshset(), ErrorCode, moab::Range::insert(), make_mesh(), and mb.
Referenced by test_entities_by_dim_ordered(), and test_entities_by_dim_set().
    EntityHandle first_vert, last_vert, first_hex, last_hex;
    Core mb;
    make_mesh( mb, first_vert, last_vert, first_hex, last_hex );
    // Create an entity set
    EntityHandle set;
    // Test empty set
    CHECK( check_set_contents( mb, 0, set, flags ) );
    CHECK( check_set_contents( mb, 1, set, flags ) );
    CHECK( check_set_contents( mb, 2, set, flags ) );
    CHECK( check_set_contents( mb, 3, set, flags ) );
    // Add stuff to set
    Range range;
    range.insert( first_vert, first_vert + 10 );
    range.insert( first_vert + 100, first_vert + 110 );
    range.insert( first_hex + 200, first_hex + 299 );
    range.insert( last_hex, last_hex - 99 );
    // Test
void test_entities_by_type ( unsigned  flags)
Definition at line 968 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), CHECK, CHECK_ERR, check_set_contents(), moab::Core::create_meshset(), ErrorCode, moab::Range::insert(), make_mesh(), mb, MBEDGE, MBHEX, and MBVERTEX.
Referenced by test_entities_by_type_ordered(), and test_entities_by_type_set().
    Core mb;
    EntityHandle set;
    // Test empty set
    CHECK( check_set_contents( mb, MBVERTEX, set, flags ) );
    CHECK( check_set_contents( mb, MBEDGE, set, flags ) );
    CHECK( check_set_contents( mb, MBHEX, set, flags ) );
    // Add stuff to set
    Range range;
    // Test
Definition at line 97 of file Test_MBMeshSet.cpp.
References test_entities_by_type().
    test_entities_by_type( MESHSET_ORDERED );
Definition at line 101 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_entities_by_type().
void test_intersect ( unsigned  flags1,
unsigned  flags2
Definition at line 1083 of file Test_MBMeshSet.cpp.
References CHECK, moab::Range::insert(), INTERSECT, make_mesh(), mb, and test_boolean().
Referenced by test_itersect_ordered_ordered(), test_itersect_ordered_ordered_tracking(), test_itersect_ordered_set(), test_itersect_ordered_set_tracking(), test_itersect_set_ordered(), test_itersect_set_ordered_tracking(), test_itersect_set_set(), and test_itersect_set_set_tracking().
    Range empty, set1_ents, set2_ents;
    Core mb;
    // define contents of first set
    set1_ents.insert( first_vert, first_vert + 10 );
    set1_ents.insert( first_vert + 100, first_vert + 199 );
    set1_ents.insert( first_hex + 100, first_hex + 200 );
    // define contents of second set
    set2_ents.insert( first_vert, first_vert );
    set2_ents.insert( first_vert + 10, first_vert + 10 );
    set2_ents.insert( first_vert + 90, first_vert + 209 );
    set2_ents.insert( first_hex + 50, first_hex + 300 );
    // check empty sets
    CHECK( test_boolean( mb, INTERSECT, flags1, empty, flags2, empty ) );
    // check intersection with 1 empty
    CHECK( test_boolean( mb, INTERSECT, flags1, empty, flags2, set2_ents ) );
    CHECK( test_boolean( mb, INTERSECT, flags1, set1_ents, flags2, empty ) );
    // check intersection of non-empty sets
    CHECK( test_boolean( mb, INTERSECT, flags1, set1_ents, flags2, set2_ents ) );
void test_iterator ( Interface &  moab,
SetIterator *  iter,
EntityHandle  set,
EntityType  etype,
int  dim
Definition at line 1449 of file Test_MBMeshSet.cpp.
References CHECK_EQUAL, CHECK_ERR, entities, ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), moab::SetIterator::get_next_arr(), and MBMAXTYPE.
    // iterate over the set, adding to contents
    std::vector< EntityHandle > entities, entities2;
    bool atend = false;
    ErrorCode rval;
    while( !atend )
        rval = iter->get_next_arr( entities, atend );CHECK_ERR( rval );
    // check contents against what's in the set
    if( MBMAXTYPE != etype )
        rval = moab.get_entities_by_type( set, etype, entities2 );CHECK_ERR( rval );
    else if( MBMAXTYPE == etype && -1 == dim )
        rval = moab.get_entities_by_handle( set, entities2 );CHECK_ERR( rval );
    else if( -1 != dim )
        rval = moab.get_entities_by_dimension( set, dim, entities2 );CHECK_ERR( rval );
    else
        // error, one of those needs to be true
        CHECK_ERR( MB_FAILURE );
    CHECK_EQUAL( entities.size(), entities2.size() );
void test_iterators ( unsigned int  flags,
bool  type,
bool  dim
Definition at line 1271 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), CHECK_ERR, moab::Core::create_meshset(), moab::Core::create_set_iterator(), ErrorCode, moab::Range::insert(), make_mesh(), mb, MBEDGE, MBHEX, MBMAXTYPE, MBVERTEX, and test_iterator().
Referenced by test_all_iterators().
    if( test_type && test_dim ) CHECK_ERR( MB_FAILURE );
    Core mb;
    EntityHandle set;
    // Test iteration over empty set
    SetIterator* iter = NULL;
    rval              = mb.create_set_iterator( set, MBMAXTYPE, -1, 1, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        test_iterator( mb, iter, set, MBMAXTYPE, -1 );
        delete iter;
        iter = NULL;
    rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 100, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        delete iter;
        iter = NULL;
    rval = mb.create_set_iterator( set, MBMAXTYPE, 0, 1, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        test_iterator( mb, iter, set, MBMAXTYPE, 0 );
        delete iter;
        iter = NULL;
    rval = mb.create_set_iterator( set, MBMAXTYPE, 3, 1, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        test_iterator( mb, iter, set, MBMAXTYPE, 3 );
        delete iter;
        iter = NULL;
    // Add stuff to set
    Range range;
    EntityType etype = MBVERTEX;
    int edim         = -1;
    if( test_dim && !test_type )
        edim  = 0;
        etype = MBMAXTYPE;
    // Test
    // chunk size 1
    rval = mb.create_set_iterator( set, etype, edim, 1, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        test_iterator( mb, iter, set, etype, edim );
        delete iter;
        iter = NULL;
    // chunk size 3
    rval = mb.create_set_iterator( set, etype, edim, 3, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        delete iter;
        iter = NULL;
    // chunk size 11
    rval = mb.create_set_iterator( set, etype, edim, 11, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        delete iter;
        iter = NULL;
    // chunk size 100
    rval = mb.create_set_iterator( set, etype, edim, 100, false, iter );CHECK_ERR( rval );
    if( NULL != iter )
        delete iter;
        iter = NULL;
    if( test_type )
        // chunk size 1, all ents
        if( NULL != iter )
            delete iter;
            iter = NULL;
        // chunk size 3, all ents
        rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 3, false, iter );CHECK_ERR( rval );
        if( NULL != iter )
            delete iter;
            iter = NULL;
        // chunk size large, all ents
        rval = mb.create_set_iterator( set, MBMAXTYPE, -1, 100000, false, iter );CHECK_ERR( rval );
        if( NULL != iter )
            delete iter;
            iter = NULL;
        etype = MBEDGE;
        // edges, chunk size 1
        if( NULL != iter )
            delete iter;
            iter = NULL;
        // edges, chunk size 100
        if( NULL != iter )
            delete iter;
            iter = NULL;
        etype = MBHEX;
        // hexes, chunk size 1
        if( NULL != iter )
            delete iter;
            iter = NULL;
        // hexes, chunk size 3
        if( NULL != iter )
            delete iter;
            iter = NULL;
        // hexes, chunk size 1000
        rval = mb.create_set_iterator( set, etype, edim, 1000, false, iter );CHECK_ERR( rval );
        if( NULL != iter )
            delete iter;
            iter = NULL;
Definition at line 159 of file Test_MBMeshSet.cpp.
References test_intersect().
    test_intersect( MESHSET_ORDERED, MESHSET_ORDERED );
Definition at line 175 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_intersect().
    test_intersect( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED );
Definition at line 155 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_intersect().
    test_intersect( MESHSET_ORDERED, MESHSET_SET );
Definition at line 151 of file Test_MBMeshSet.cpp.
    test_intersect( MESHSET_SET, MESHSET_ORDERED );
Definition at line 147 of file Test_MBMeshSet.cpp.
void test_remove_entities ( unsigned  flags)
Definition at line 761 of file Test_MBMeshSet.cpp.
References moab::Core::add_entities(), moab::Range::begin(), CHECK, CHECK_ERR, check_set_contents(), moab::Range::clear(), moab::Core::create_meshset(), moab::Range::end(), ErrorCode, moab::Range::insert(), make_mesh(), mb, moab::Core::remove_entities(), remove_from_back(), and moab::subtract().
Referenced by test_remove_entities_ordered(), test_remove_entities_ordered_tracking(), test_remove_entities_set(), and test_remove_entities_set_tracking().
    Core mb;
    make_mesh( mb );
    EntityHandle set;
    Range range;
    range.clear();
    range.insert( 1, 1000 );
    // [1,1000]
    range.clear();
    range.insert( 1, 5 );
    remove_from_back( contents, range );
    rval = mb.remove_entities( set, range );CHECK_ERR( rval );
    // [6,1000]
    range.clear();
    range.insert( 6, 6 );
    // [7,1000]
    range.clear();
    range.insert( 7, 10 );
    // [11,1000]
    range.clear();
    range.insert( 1, 20 );
    // [21,1000]
    range.clear();
    // [21,1000]
    range.clear();
    range.insert( 22, 30 );
    // [21,21],[31,1000]
    range.clear();
    range.insert( 1000, 1000 );
    // [21,21],[31,999]
    range.clear();
    range.insert( 901, 999 );
    // [21,21],[31,900]
    range.clear();
    range.insert( 900, 999 );
    // [21,21],[31,899]
    range.clear();
    range.insert( 1000, 1001 );
    // [21,21],[31,899]
    range.clear();
    range.insert( 890, 898 );
    // [21,21],[31,889],[899,899]
    range.clear();
    range.insert( 100, 149 );
    // [21,21],[31,99],[150,889],[899,899]
    range.clear();
    range.insert( 31, 99 );
    // [21,21],[150,889],[899,899]
    range.clear();
    range.insert( 200, 249 );
    // [21,21],[150,199],[250,889],[899,899]
    range.clear();
    range.insert( 300, 349 );
    // [21,21],[150,199],[250,299],[350,889],[899,899]
    range.clear();
    range.insert( 159, 399 );
    // [21,21],[150,158],[400,889],[899,899]
    range.clear();
    range.insert( 450, 499 );
    // [21,21],[150,158],[400,449],[500,889],[899,899]
    range.clear();
    range.insert( 550, 599 );
    // [21,21],[150,158],[400,449],[500,549],[600,889],[899,899]
    range.clear();
    range.insert( 150, 549 );
    // [21,21],[600,889],[899,899]
    range.clear();
    range.insert( 650, 699 );
    // [21,21],[600,649],[700,889],[899,899]
    // test vector-based remove
    assert( contents.size() == 242 );
    std::vector< EntityHandle > remlist( 5 );
    remlist[0] = contents[240];
    contents.erase( contents.begin() + 240 );
    remlist[1] = contents[200];
    contents.erase( contents.begin() + 200 );
    remlist[2] = contents[100];
    contents.erase( contents.begin() + 100 );
    remlist[3] = contents[25];
    contents.erase( contents.begin() + 25 );
    remlist[4] = contents[0];
    contents.erase( contents.begin() + 0 );
    rval = mb.remove_entities( set, &remlist[0], remlist.size() );CHECK_ERR( rval );
    // [600,623],[625,649],[700,748],[750,848],[850,888],[899,899]
    // remove everything
    std::reverse( contents.begin(), contents.begin() + contents.size() / 2 );  // mix up a bit
    rval = mb.remove_entities( set, &contents[0], contents.size() );CHECK_ERR( rval );
    contents.clear();
    // try complicated range-based remove
    range.clear();
    contents.clear();
    range.insert( 100, 200 );
    // [1000,2000]
    Range remove;
    remove.insert( 1, 3 );
    remove.insert( 10, 100 );
    remove.insert( 110, 120 );
    remove.insert( 130, 140 );
    remove.insert( 150, 160 );
    remove.insert( 190, 200 );
    remove.insert( 210, 220 );
    remove.insert( 230, 240 );
    range = subtract( range, remove );
    contents.clear();
    rval = mb.remove_entities( set, remove );CHECK_ERR( rval );
Definition at line 80 of file Test_MBMeshSet.cpp.
References test_remove_entities().
    test_remove_entities( MESHSET_ORDERED );
Definition at line 88 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_remove_entities().
    test_remove_entities( MESHSET_TRACK_OWNER | MESHSET_ORDERED );
Definition at line 84 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_remove_entities().
void test_subtract ( unsigned  flags1,
unsigned  flags2
Definition at line 1138 of file Test_MBMeshSet.cpp.
References CHECK, moab::Range::insert(), make_mesh(), mb, SUBTRACT, and test_boolean().
Referenced by test_subtract_ordered_ordered(), test_subtract_ordered_ordered_tracking(), test_subtract_ordered_set(), test_subtract_ordered_set_tracking(), test_subtract_set_ordered(), test_subtract_set_ordered_tracking(), test_subtract_set_set(), and test_subtract_set_set_tracking().
    Core mb;
    set2_ents.insert( first_vert + 9, first_vert + 9 );
    set2_ents.insert( first_vert + 11, first_vert + 99 );
    set2_ents.insert( first_vert + 150, first_vert + 199 );
    set2_ents.insert( first_hex + 50, first_hex + 60 );
    set2_ents.insert( first_hex + 90, first_hex + 220 );
    // check empty sets
    CHECK( test_boolean( mb, SUBTRACT, flags1, empty, flags2, empty ) );
    // check union with 1 empty
    CHECK( test_boolean( mb, SUBTRACT, flags1, empty, flags2, set2_ents ) );
    CHECK( test_boolean( mb, SUBTRACT, flags1, set1_ents, flags2, empty ) );
    // check union of non-empty sets
    CHECK( test_boolean( mb, SUBTRACT, flags1, set1_ents, flags2, set2_ents ) );
Definition at line 126 of file Test_MBMeshSet.cpp.
References test_subtract().
    test_subtract( MESHSET_ORDERED, MESHSET_ORDERED );
Definition at line 142 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_subtract().
    test_subtract( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED );
Definition at line 122 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_subtract().
    test_subtract( MESHSET_ORDERED, MESHSET_SET );
Definition at line 118 of file Test_MBMeshSet.cpp.
    test_subtract( MESHSET_SET, MESHSET_ORDERED );
Definition at line 114 of file Test_MBMeshSet.cpp.
void test_unite ( unsigned  flags1,
unsigned  flags2
test unite_meshset
Definition at line 1110 of file Test_MBMeshSet.cpp.
References CHECK, moab::Range::insert(), make_mesh(), mb, test_boolean(), and UNITE.
Referenced by test_unite_ordered_ordered(), test_unite_ordered_ordered_tracking(), test_unite_ordered_set(), test_unite_ordered_set_tracking(), test_unite_set_ordered(), test_unite_set_ordered_tracking(), test_unite_set_set(), and test_unite_set_set_tracking().
    Core mb;
    set2_ents.insert( first_vert + 150, first_vert + 209 );
    set2_ents.insert( first_vert + 211, first_vert + 211 );
    set2_ents.insert( first_hex + 50, first_hex + 99 );
    // check empty sets
    CHECK( test_boolean( mb, UNITE, flags1, empty, flags2, empty ) );
    CHECK( test_boolean( mb, UNITE, flags1, empty, flags2, set2_ents ) );
    CHECK( test_boolean( mb, UNITE, flags1, set1_ents, flags2, empty ) );
    CHECK( test_boolean( mb, UNITE, flags1, set1_ents, flags2, set2_ents ) );
Definition at line 192 of file Test_MBMeshSet.cpp.
References test_unite().
    test_unite( MESHSET_ORDERED, MESHSET_ORDERED );
Definition at line 208 of file Test_MBMeshSet.cpp.
References MESHSET_TRACK_OWNER, and test_unite().
    test_unite( MESHSET_TRACK_OWNER | MESHSET_ORDERED, MESHSET_TRACK_OWNER | MESHSET_ORDERED );
Definition at line 188 of file Test_MBMeshSet.cpp.
References MESHSET_SET, and test_unite().
    test_unite( MESHSET_ORDERED, MESHSET_SET );
Definition at line 204 of file Test_MBMeshSet.cpp.
References MESHSET_SET, MESHSET_TRACK_OWNER, and test_unite().
Definition at line 184 of file Test_MBMeshSet.cpp.
    test_unite( MESHSET_SET, MESHSET_ORDERED );
Definition at line 200 of file Test_MBMeshSet.cpp.
Definition at line 180 of file Test_MBMeshSet.cpp.
