MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include <iostream> 00002 #include <cstdlib> 00003 #include "moab/Range.hpp" 00004 #include "moab/Core.hpp" 00005 #include "MBTagConventions.hpp" 00006 #include "moab/GeomTopoTool.hpp" 00007 00008 using namespace moab; 00009 00010 Tag geomTag = 0; 00011 Tag blockTag = 0; 00012 Tag sideTag = 0; 00013 Tag nodeTag = 0; 00014 Tag nameTag = 0; 00015 Tag idTag = 0; 00016 bool printAnonSets = false; 00017 bool printSVSense = false; 00018 00019 Core mb; 00020 GeomTopoTool geomTool( &mb ); 00021 00022 static void usage( const char* name, bool brief = true ) 00023 { 00024 std::ostream& str = brief ? std::cerr : std::cout; 00025 if( !brief ) 00026 str << name << ": A tool to export entity set parent/child relations" << std::endl 00027 << " for use as input to graphviz" << std::endl; 00028 str << "Usage: " << name << " [-a | [-g] [-m] [-n] ] <input_file>" << std::endl 00029 << " " << name << " -h" << std::endl; 00030 if( brief ) exit( 1 ); 00031 str << " The default behavior is equivalent to \"-gmn\"." << std::endl 00032 << " If any of the following options are used to specify which " << std::endl 00033 << " sets to output, then there are no defaults. Only the " << std::endl 00034 << " indicated sets will be output." << std::endl 00035 << " -a : write all sets (default is only geom, mesh, and named)" << std::endl 00036 << " -g : write geometric topology sets" << std::endl 00037 << " -m : write material sets and boundary condition sets" << std::endl 00038 << " -n : write named sets" << std::endl 00039 << " -s : label surface-volume links with sense" << std::endl 00040 << " The default link behavior is to both child links" << std::endl 00041 << " and containment with solid lines." << std::endl 00042 << " -P : do not write child links" << std::endl 00043 << " -p : write child links with dashed lines" << std::endl 00044 << " -C : do not write containment links" << std::endl 00045 << " -c : write containment links with dashed lines" << std::endl; 00046 exit( 0 ); 00047 } 00048 00049 enum Link 00050 { 00051 NONE = 0, 00052 SOLID, 00053 DASHED 00054 }; 00055 static void write_dot( Link contained, Link children ); 00056 static void dot_nodes( std::ostream& s, Range& sets_out ); 00057 static void dot_children( std::ostream& s, const Range& sets, bool dashed ); 00058 static void dot_contained( std::ostream& s, const Range& sets, bool dashed ); 00059 00060 int main( int argc, char* argv[] ) 00061 { 00062 Link children = SOLID, contained = SOLID; 00063 bool printGeomSets = true; 00064 bool printMeshSets = true; 00065 bool printNamedSets = true; 00066 const char* input_file = 0; 00067 bool geom_flag = false, mesh_flag = false, name_flag = false, all_flag = false; 00068 bool no_more_flags = false; 00069 for( int i = 1; i < argc; ++i ) 00070 { 00071 if( no_more_flags || argv[i][0] != '-' ) 00072 { 00073 if( input_file ) usage( argv[0] ); 00074 input_file = argv[i]; 00075 continue; 00076 } 00077 for( int j = 1; argv[i][j]; ++j ) 00078 { 00079 switch( argv[i][j] ) 00080 { 00081 case 'a': 00082 all_flag = true; 00083 break; 00084 case 'g': 00085 geom_flag = true; 00086 break; 00087 case 'm': 00088 mesh_flag = true; 00089 break; 00090 case 'n': 00091 name_flag = true; 00092 break; 00093 case 's': 00094 printSVSense = true; 00095 break; 00096 case 'P': 00097 children = NONE; 00098 break; 00099 case 'p': 00100 children = DASHED; 00101 break; 00102 case 'C': 00103 contained = NONE; 00104 break; 00105 case 'c': 00106 contained = DASHED; 00107 break; 00108 case '-': 00109 no_more_flags = true; 00110 break; 00111 case 'h': 00112 usage( argv[0], false ); 00113 break; 00114 default: 00115 std::cerr << "Unknown flag: '" << argv[i][j] << "'" << std::endl; 00116 usage( argv[0] ); 00117 } 00118 } 00119 } 00120 00121 if( !input_file ) 00122 { 00123 std::cerr << "No input file specified." << std::endl; 00124 usage( argv[0] ); 00125 } 00126 00127 if( all_flag ) 00128 { 00129 printGeomSets = printMeshSets = printNamedSets = printAnonSets = true; 00130 } 00131 else if( geom_flag || mesh_flag || name_flag ) 00132 { 00133 printGeomSets = geom_flag; 00134 printMeshSets = mesh_flag; 00135 printNamedSets = name_flag; 00136 } 00137 00138 if( MB_SUCCESS != mb.load_mesh( input_file ) ) 00139 { 00140 std::cerr << input_file << ": file read failed." << std::endl; 00141 return 1; 00142 } 00143 00144 Tag t; 00145 if( printGeomSets ) 00146 { 00147 if( MB_SUCCESS == mb.tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, t ) ) 00148 { 00149 geomTag = t; 00150 } 00151 } 00152 if( printMeshSets ) 00153 { 00154 if( MB_SUCCESS == mb.tag_get_handle( MATERIAL_SET_TAG_NAME, 1, MB_TYPE_INTEGER, t ) ) 00155 { 00156 blockTag = t; 00157 } 00158 if( MB_SUCCESS == mb.tag_get_handle( DIRICHLET_SET_TAG_NAME, 1, MB_TYPE_INTEGER, t ) ) 00159 { 00160 nodeTag = t; 00161 } 00162 if( MB_SUCCESS == mb.tag_get_handle( NEUMANN_SET_TAG_NAME, 1, MB_TYPE_INTEGER, t ) ) 00163 { 00164 sideTag = t; 00165 } 00166 } 00167 if( printNamedSets ) 00168 { 00169 if( MB_SUCCESS == mb.tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t ) ) 00170 { 00171 nameTag = t; 00172 } 00173 } 00174 idTag = mb.globalId_tag(); 00175 00176 write_dot( contained, children ); 00177 return 0; 00178 } 00179 00180 void write_dot( Link contained, Link children ) 00181 { 00182 Range sets; 00183 std::cout << "digraph {" << std::endl; 00184 dot_nodes( std::cout, sets ); 00185 std::cout << std::endl; 00186 if( contained ) dot_contained( std::cout, sets, contained == DASHED ); 00187 if( children ) dot_children( std::cout, sets, children == DASHED ); 00188 std::cout << "}" << std::endl; 00189 } 00190 00191 static void dot_get_sets( Range& curr_sets, Range& result_sets, Tag tag, void* tag_val = 0 ) 00192 { 00193 if( !tag ) return; 00194 00195 result_sets.clear(); 00196 mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &tag, &tag_val, 1, result_sets ); 00197 result_sets = subtract( result_sets, curr_sets ); 00198 curr_sets.merge( result_sets ); 00199 } 00200 00201 static void dot_write_node( std::ostream& s, EntityHandle h, const char* label, int* id = 0 ) 00202 { 00203 s << 's' << mb.id_from_handle( h ) << " [label = \"" << label; 00204 if( id ) s << ' ' << *id; 00205 s << "\"];" << std::endl; 00206 } 00207 00208 static void dot_write_id_nodes( std::ostream& s, const Range& entites, Tag id_tag, const char* type_name ) 00209 { 00210 int id; 00211 for( Range::iterator i = entites.begin(); i != entites.end(); ++i ) 00212 if( MB_SUCCESS == mb.tag_get_data( id_tag, &*i, 1, &id ) ) dot_write_node( s, *i, type_name, &id ); 00213 } 00214 00215 void dot_nodes( std::ostream& s, Range& sets ) 00216 { 00217 Range vol_sets, surf_sets, curv_sets, vert_sets; 00218 Range block_sets, side_sets, node_sets; 00219 Range named_sets, other_sets; 00220 00221 dot_get_sets( sets, named_sets, nameTag ); 00222 00223 int dim = 3; 00224 dot_get_sets( sets, vol_sets, geomTag, &dim ); 00225 dim = 2; 00226 dot_get_sets( sets, surf_sets, geomTag, &dim ); 00227 dim = 1; 00228 dot_get_sets( sets, curv_sets, geomTag, &dim ); 00229 dim = 0; 00230 dot_get_sets( sets, vert_sets, geomTag, &dim ); 00231 00232 dot_get_sets( sets, block_sets, blockTag ); 00233 dot_get_sets( sets, side_sets, sideTag ); 00234 dot_get_sets( sets, node_sets, nodeTag ); 00235 00236 if( printAnonSets ) 00237 { 00238 mb.get_entities_by_type( 0, MBENTITYSET, other_sets ); 00239 Range xsect = subtract( other_sets, sets ); 00240 sets.swap( other_sets ); 00241 other_sets.swap( xsect ); 00242 } 00243 00244 dot_write_id_nodes( s, vol_sets, idTag, "Volume" ); 00245 dot_write_id_nodes( s, surf_sets, idTag, "Surface" ); 00246 dot_write_id_nodes( s, curv_sets, idTag, "Curve" ); 00247 dot_write_id_nodes( s, vert_sets, idTag, "Vertex" ); 00248 dot_write_id_nodes( s, block_sets, blockTag, "Block" ); 00249 dot_write_id_nodes( s, side_sets, sideTag, "Neumann Set" ); 00250 dot_write_id_nodes( s, node_sets, nodeTag, "Dirichlet Set" ); 00251 00252 Range::iterator i; 00253 char name[NAME_TAG_SIZE + 1]; 00254 for( i = named_sets.begin(); i != named_sets.end(); ++i ) 00255 { 00256 if( MB_SUCCESS == mb.tag_get_data( nameTag, &*i, 1, name ) ) 00257 { 00258 name[NAME_TAG_SIZE] = '\0'; 00259 dot_write_node( s, *i, name ); 00260 } 00261 } 00262 for( i = other_sets.begin(); i != other_sets.end(); ++i ) 00263 { 00264 int id = mb.id_from_handle( *i ); 00265 dot_write_node( s, *i, "EntitySet ", &id ); 00266 } 00267 } 00268 00269 static void dot_down_link( std::ostream& s, 00270 EntityHandle parent, 00271 EntityHandle child, 00272 bool dashed, 00273 const char* label = 0 ) 00274 { 00275 s << 's' << mb.id_from_handle( parent ) << " -> " << 's' << mb.id_from_handle( child ); 00276 if( dashed && label ) 00277 s << " [style = dashed label = \"" << label << "\"]"; 00278 else if( dashed ) 00279 s << " [style = dashed]"; 00280 else if( label ) 00281 s << " [label = \"" << label << "\"]"; 00282 s << ';' << std::endl; 00283 } 00284 00285 void dot_children( std::ostream& s, const Range& sets, bool dashed ) 00286 { 00287 int sense; 00288 const char *fstr = "forward", *rstr = "reverse"; 00289 for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) 00290 { 00291 Range parents; 00292 mb.get_parent_meshsets( *i, parents ); 00293 parents = intersect( parents, sets ); 00294 00295 for( Range::iterator j = parents.begin(); j != parents.end(); ++j ) 00296 { 00297 const char* linklabel = 0; 00298 if( printSVSense && MB_SUCCESS == geomTool.get_sense( *i, *j, sense ) ) 00299 00300 // check here only one sense, as before... 00301 linklabel = ( sense == (int)SENSE_FORWARD ) ? fstr : rstr; 00302 00303 dot_down_link( s, *j, *i, dashed, linklabel ); 00304 } 00305 } 00306 } 00307 00308 void dot_contained( std::ostream& s, const Range& sets, bool dashed ) 00309 { 00310 for( Range::iterator i = sets.begin(); i != sets.end(); ++i ) 00311 { 00312 Range contained; 00313 mb.get_entities_by_type( *i, MBENTITYSET, contained ); 00314 contained = intersect( contained, sets ); 00315 00316 for( Range::iterator j = contained.begin(); j != contained.end(); ++j ) 00317 dot_down_link( s, *i, *j, dashed ); 00318 } 00319 }
