read_cgm_senses_test.cpp File Reference
#include <iostream>
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "Internals.hpp"
#include "moab/Core.hpp"
#include "MBTagConventions.hpp"
#include "moab/GeomTopoTool.hpp"
#include "InitCGMA.hpp"
#include "GeometryQueryTool.hpp"
#include "CGMConfig.h"
+ Include dependency graph for read_cgm_senses_test.cpp:
Defines
#define IS_BUILDING_MB
#define SENSE_FORWARD   1
#define SENSE_REVERSE   ( -1 )
#define SENSE_UNKNOWN   0
#define CHKERR(A)
Functions
void read_file (Interface *moab, const char *input_file)
ErrorCode load_sat_curve_sense_data (Interface *moab, EntityHandle curve, std::vector< int > &surf_ids_out, std::vector< int > &senses_out)
ErrorCode load_stp_curve_sense_data (Interface *moab, EntityHandle curve, std::vector< int > &surf_ids_out, std::vector< int > &senses_out)
ErrorCode load_precgm14_stp_curve_sense_data (Interface *moab, EntityHandle curve, std::vector< int > &surf_ids_out, std::vector< int > &senses_out)
ErrorCode load_sat_surf_sense_data (Interface *moab, EntityHandle surf, std::vector< int > &vol_ids_out, std::vector< int > &senses_out)
ErrorCode load_stp_surf_sense_data (Interface *moab, EntityHandle surf, std::vector< int > &vol_ids_out, std::vector< int > &senses_out)
ErrorCode load_precgm14_stp_surf_sense_data (Interface *moab, EntityHandle surf, std::vector< int > &vol_ids_out, std::vector< int > &senses_out)
void check_sense_data (Interface *moab, std::vector< EntityHandle > wrt_ents, std::vector< int > senses, std::vector< int > known_wrt_ids, std::vector< int > known_senses)
int geom_id_by_handle (Interface *moab, const EntityHandle set)
void read_cylcube_curve_senses_test ()
void read_cylcube_surf_senses_test ()
void delete_mesh_test ()
int main (int, char **)
Variables
std::string input_cylcube = "unittest/io/cylcube.sat"
Define Documentation
#define CHKERR (   A)
Value:
do        \
        if( MB_SUCCESS != ( A ) )        \
            std::cerr << "Failure (error code " << ( A ) << ") at " __FILE__ ":" << __LINE__ << std::endl; \
            return A;        \
    } while( false )
Definition at line 20 of file read_cgm_senses_test.cpp.
Definition at line 4 of file read_cgm_senses_test.cpp.
Definition at line 17 of file read_cgm_senses_test.cpp.
Function Documentation
void check_sense_data ( Interface *  moab,
Definition at line 186 of file read_cgm_senses_test.cpp.
References CHECK_EQUAL, and geom_id_by_handle().
Referenced by read_cylcube_curve_senses_test(), and read_cylcube_surf_senses_test().
    // Get ID's of the wrt entities
    std::vector< int > wrt_ent_ids;
    for( unsigned int i = 0; i < wrt_ents.size(); i++ )
        wrt_ent_ids.push_back( geom_id_by_handle( moab, wrt_ents[i] ) );
    for( unsigned int i = 0; i < wrt_ent_ids.size(); i++ )
        for( unsigned int j = 0; j < known_wrt_ids.size(); j++ )
            if( wrt_ent_ids[i] == known_wrt_ids[j] )
                // Make sure the senses of the matching wrt entities
                // are correct
                CHECK_EQUAL( senses[i], known_senses[j] );
                // Once a wrt entity is matched with a known entity,
                // remove it from the list
                wrt_ent_ids.erase( wrt_ent_ids.begin() + i );
                senses.erase( senses.begin() + i );
                --i;
                break;
    // After both loops are complete, known_wrt_ents should be empty
    int leftovers = wrt_ent_ids.size();
    CHECK_EQUAL( leftovers, 0 );
void delete_mesh_test ( )
int geom_id_by_handle ( Interface *  moab,
ErrorCode load_precgm14_stp_curve_sense_data ( Interface *  moab,
EntityHandle  curve,
std::vector< int > &  surf_ids_out,
std::vector< int > &  senses_out
Definition at line 474 of file read_cgm_senses_test.cpp.
References geom_id_by_handle(), MB_SUCCESS, SENSE_FORWARD, and SENSE_REVERSE.
Referenced by read_cylcube_curve_senses_test().
    int curve_id = geom_id_by_handle( moab, curve );
    switch( curve_id )
        case 1:
            surf_ids_out.push_back( 1 );
            surf_ids_out.push_back( 6 );
            senses_out.push_back( SENSE_FORWARD );
            senses_out.push_back( SENSE_REVERSE );
            break;
        case 2:
            surf_ids_out.push_back( 5 );
            break;
        case 3:
            surf_ids_out.push_back( 4 );
            break;
        case 4:
            surf_ids_out.push_back( 3 );
            break;
        case 5:
            surf_ids_out.push_back( 2 );
            break;
        case 6:
            break;
        case 7:
            break;
        case 8:
            break;
        case 9:
            break;
        case 10:
            break;
        case 11:
            break;
        case 12:
            break;
        case 13:
            surf_ids_out.push_back( 7 );
            surf_ids_out.push_back( 8 );
            break;
        case 14:
            surf_ids_out.push_back( 9 );
            break;
        case 15:
            break;
        case 16:
            surf_ids_out.push_back( 10 );
            break;
        case 17:
            break;
        case 18:
            break;
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode load_precgm14_stp_surf_sense_data ( Interface *  moab,
EntityHandle  surf,
std::vector< int > &  vol_ids_out,
Definition at line 810 of file read_cgm_senses_test.cpp.
References geom_id_by_handle(), MB_SUCCESS, and SENSE_FORWARD.
Referenced by read_cylcube_surf_senses_test().
    int surf_id = geom_id_by_handle( moab, surf );
    switch( surf_id )
        case 1:
        case 2:
        case 3:
        case 4:
        case 5:
        case 6:
            vol_ids_out.push_back( 1 );
            break;
        case 7:
        case 8:
        case 9:
        case 10:
            vol_ids_out.push_back( 2 );
            break;
        default:
            std::cout << "Failure to find surface sense reference data. Returning failure..." << std::endl;
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode load_sat_curve_sense_data ( Interface *  moab,
EntityHandle  curve,
Definition at line 225 of file read_cgm_senses_test.cpp.
    switch( curve_id )
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
        case 4:
            break;
        case 5:
            break;
        case 6:
            break;
        case 7:
            break;
        case 8:
            break;
        case 9:
            break;
        case 10:
            break;
        case 11:
            break;
        case 12:
            break;
        case 13:
            break;
        case 14:
            break;
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode load_sat_surf_sense_data ( Interface *  moab,
EntityHandle  surf,
Definition at line 684 of file read_cgm_senses_test.cpp.
    switch( surf_id )
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
        case 4:
            break;
        case 5:
            break;
        case 6:
            break;
        case 7:
            break;
        case 8:
            break;
        case 9:
            break;
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode load_stp_curve_sense_data ( Interface *  moab,
EntityHandle  curve,
Definition at line 338 of file read_cgm_senses_test.cpp.
    switch( curve_id )
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
        case 4:
            break;
        case 5:
            break;
        case 6:
            break;
        case 7:
            break;
        case 8:
            break;
        case 9:
            break;
        case 10:
            break;
        case 11:
            break;
        case 12:
            break;
        case 13:
            break;
        case 14:
            break;
        case 15:
            break;
        case 16:
            break;
        case 17:
            break;
        case 18:
            break;
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode load_stp_surf_sense_data ( Interface *  moab,
EntityHandle  surf,
Definition at line 744 of file read_cgm_senses_test.cpp.
    switch( surf_id )
        case 1:
            break;
        case 2:
            break;
        case 3:
            break;
        case 4:
            break;
        case 5:
            break;
        case 6:
            break;
        case 7:
            break;
        case 8:
            break;
        case 9:
            break;
        case 10:
            break;
        default:
            return MB_FAILURE;
    return MB_SUCCESS;
int main ( int  ,
char **
Definition at line 81 of file read_cgm_senses_test.cpp.
References read_cylcube_curve_senses_test(), read_cylcube_surf_senses_test(), and RUN_TEST.
    int result = 0;
    result += RUN_TEST( read_cylcube_surf_senses_test );
    result += RUN_TEST( read_cylcube_curve_senses_test );
    return result;
Definition at line 103 of file read_cgm_senses_test.cpp.
References CHECK_EQUAL, CHECK_ERR, check_sense_data(), dim, ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type_and_tag(), moab::GeomTopoTool::get_senses(), input_cylcube, load_precgm14_stp_curve_sense_data(), load_sat_curve_sense_data(), load_stp_curve_sense_data(), mb, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBENTITYSET, read_file(), moab::Range::size(), and moab::Interface::tag_get_handle().
Referenced by main().
    ErrorCode rval;
    // Open the test file
    Core moab;
    Interface* mb = &moab;
    read_file( mb, input_cylcube.c_str() );
    // Get all curve handles
    Tag geom_tag;
    rval = mb->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag,
                               moab::MB_TAG_DENSE | moab::MB_TAG_CREAT );CHECK_ERR( rval );
    // Check that the proper number of curves exist
    int dim     = 1;
    void* val[] = { &dim };
    int number_of_curves;
    rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_curves );CHECK_ERR( rval );
    // Step format adds a surface on the barrel of the cylinder.
    // This created 4 extra surfaces in comparison to the .sat format from Cubit.
    //(New surface breaks the barrel of the cylinder into two half-pipes)
#ifdef HAVE_OCC_STEP
    CHECK_EQUAL( 18, number_of_curves );
#else
    CHECK_EQUAL( 14, number_of_curves );
#endif
    // Get curve handles
    Range curves;
    rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, curves );CHECK_ERR( rval );
    // Establish GeomTopoTool instance needed to get curve data
    moab::GeomTopoTool gt( mb, false );
    // Initialize vectors for sense checking
    std::vector< EntityHandle > surfs;
    std::vector< int > senses;
    std::vector< int > known_surf_ids;
    std::vector< int > known_senses;
    for( unsigned int i = 0; i < curves.size(); i++ )
        // Clean data from previous curve
        surfs.clear();
        senses.clear();
        // Get sense info for the current curve
        rval = gt.get_senses( curves[i], surfs, senses );CHECK_ERR( rval );
        // Clear reference data from previous curve
        known_surf_ids.clear();
        known_senses.clear();
        // Load known curve-sense ID data
        if( CGM_MAJOR_VERSION >= 14 )
            rval = load_stp_curve_sense_data( mb, curves[i], known_surf_ids, known_senses );
        else
            rval = load_precgm14_stp_curve_sense_data( mb, curves[i], known_surf_ids, known_senses );
        CHECK_ERR( rval );
#else
        rval = load_sat_curve_sense_data( mb, curves[i], known_surf_ids, known_senses );CHECK_ERR( rval );
#endif
        // Check that each surf and sense has a match in the references
        check_sense_data( mb, surfs, senses, known_surf_ids, known_senses );
Definition at line 615 of file read_cgm_senses_test.cpp.
References CHECK_EQUAL, CHECK_ERR, check_sense_data(), dim, ErrorCode, GEOM_DIMENSION_TAG_NAME, geom_tag, moab::Interface::get_entities_by_type_and_tag(), moab::Interface::get_number_entities_by_type_and_tag(), moab::GeomTopoTool::get_senses(), input_cylcube, load_precgm14_stp_surf_sense_data(), load_sat_surf_sense_data(), load_stp_surf_sense_data(), mb, MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_INTEGER, MBENTITYSET, read_file(), moab::Range::size(), and moab::Interface::tag_get_handle().
    ErrorCode rval;
    Core moab;
    // Get geometry tag for gathering surface information from the mesh
    Tag geom_tag;
    // Check that the proper number of surfaces exist
    int dim     = 2;
    int number_of_surfs;
    rval = mb->get_number_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, number_of_surfs );CHECK_ERR( rval );
    // Step format adds a surface on barrel of the cylinder.
    // (Breaks it into two half-pipes)
    CHECK_EQUAL( 10, number_of_surfs );
#else
    CHECK_EQUAL( 9, number_of_surfs );
#endif
    // Get surface handles
    Range surfs;
    rval = mb->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, val, 1, surfs );CHECK_ERR( rval );
    // Establish GeomTopoTool instance needed to get surf data
    std::vector< EntityHandle > vols;
    std::vector< int > known_vol_ids;
    for( unsigned int i = 0; i < surfs.size(); i++ )
        // Clean data from previous surface
        vols.clear();
        senses.clear();
        // Get sense information for the current
        // surface from the mesh
        rval = gt.get_senses( surfs[i], vols, senses );CHECK_ERR( rval );
        // Clear previous reverence data
        known_vol_ids.clear();
        // Load known surface-volume data
        // for this surface and check that it's correct
            rval = load_stp_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses );
        else
            rval = load_precgm14_stp_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses );
        CHECK_ERR( rval );
#else
        rval = load_sat_surf_sense_data( mb, surfs[i], known_vol_ids, known_senses );CHECK_ERR( rval );
#endif
        // Check sense information from the loaded mesh against
        // reference sense information
        check_sense_data( mb, vols, senses, known_vol_ids, known_senses );
void read_file ( Interface *  moab,
const char *  input_file
Definition at line 57 of file read_cgm_basic_test.cpp.
    InitCGMA::initialize_cgma();
    GeometryQueryTool::instance()->delete_geometry();
    ErrorCode rval = moab->load_file( input_file );CHECK_ERR( rval );
Variable Documentation
Definition at line 33 of file read_cgm_senses_test.cpp.
