MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 #ifdef WIN32 00016 #pragma warning( disable : 4786 ) 00017 #endif 00018 00019 #include "CGMConfig.h" 00020 #include "GeometryQueryTool.hpp" 00021 #include "ModelQueryEngine.hpp" 00022 #include "RefEntityName.hpp" 00023 #include "GMem.hpp" 00024 00025 #include "RefGroup.hpp" 00026 #include "RefVolume.hpp" 00027 #include "RefFace.hpp" 00028 #include "RefEdge.hpp" 00029 #include "RefVertex.hpp" 00030 00031 #include "SenseEntity.hpp" 00032 #include "Surface.hpp" 00033 #include "Curve.hpp" 00034 #include "Body.hpp" 00035 #include "InitCGMA.hpp" 00036 00037 #include "moab/Core.hpp" 00038 #include "moab/Interface.hpp" 00039 #include "moab/Range.hpp" 00040 #include "MBTagConventions.hpp" 00041 #include "moab/FileOptions.hpp" 00042 00043 #include "moab/GeomTopoTool.hpp" 00044 00045 #include "CubitCompat.hpp" 00046 00047 #include <cstdio> 00048 #include <algorithm> 00049 #include <cassert> 00050 #include <iostream> 00051 00052 #include "ReadCGM.hpp" 00053 #include "moab/ReadUtilIface.hpp" 00054 00055 namespace moab 00056 { 00057 00058 #define GF_CUBIT_FILE_TYPE "CUBIT" 00059 #define GF_STEP_FILE_TYPE "STEP" 00060 #define GF_IGES_FILE_TYPE "IGES" 00061 #define GF_OCC_BREP_FILE_TYPE "OCC" 00062 #define GF_FACET_FILE_TYPE "FACET" 00063 00064 ReaderIface* ReadCGM::factory( Interface* iface ) 00065 { 00066 return new ReadCGM( iface ); 00067 } 00068 00069 ReadCGM::ReadCGM( Interface* impl ) 00070 : geom_tag( 0 ), id_tag( 0 ), name_tag( 0 ), category_tag( 0 ), faceting_tol_tag( 0 ), geometry_resabs_tag( 0 ) 00071 { 00072 assert( NULL != impl ); 00073 mdbImpl = impl; 00074 myGeomTool = new GeomTopoTool( impl ); 00075 impl->query_interface( readUtilIface ); 00076 assert( NULL != readUtilIface ); 00077 00078 // initialise counters 00079 failed_curve_count = 0; 00080 failed_surface_count = 0; 00081 00082 ErrorCode rval; 00083 00084 // get some tag handles 00085 int negone = -1, zero = 0 /*, negonearr[] = {-1, -1, -1, -1}*/; 00086 rval = mdbImpl->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, MB_TYPE_INTEGER, geom_tag, MB_TAG_SPARSE | MB_TAG_CREAT, 00087 &negone ); 00088 assert( !rval ); 00089 id_tag = mdbImpl->globalId_tag(); 00090 00091 rval = 00092 mdbImpl->tag_get_handle( NAME_TAG_NAME, NAME_TAG_SIZE, MB_TYPE_OPAQUE, name_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00093 assert( !rval ); 00094 00095 rval = mdbImpl->tag_get_handle( CATEGORY_TAG_NAME, CATEGORY_TAG_SIZE, MB_TYPE_OPAQUE, category_tag, 00096 MB_TAG_SPARSE | MB_TAG_CREAT ); 00097 assert( !rval ); 00098 rval = mdbImpl->tag_get_handle( "FACETING_TOL", 1, MB_TYPE_DOUBLE, faceting_tol_tag, MB_TAG_SPARSE | MB_TAG_CREAT ); 00099 assert( !rval ); 00100 rval = mdbImpl->tag_get_handle( "GEOMETRY_RESABS", 1, MB_TYPE_DOUBLE, geometry_resabs_tag, 00101 MB_TAG_SPARSE | MB_TAG_CREAT ); 00102 assert( !rval ); 00103 #ifdef NDEBUG 00104 if( !rval ) 00105 { 00106 }; // Line to avoid compiler warning about variable set but not used 00107 #endif 00108 } 00109 00110 ReadCGM::~ReadCGM() 00111 { 00112 mdbImpl->release_interface( readUtilIface ); 00113 delete myGeomTool; 00114 } 00115 00116 ErrorCode ReadCGM::read_tag_values( const char* /* file_name */, 00117 const char* /* tag_name */, 00118 const FileOptions& /* opts */, 00119 std::vector< int >& /* tag_values_out */, 00120 const SubsetList* /* subset_list */ ) 00121 { 00122 return MB_NOT_IMPLEMENTED; 00123 } 00124 00125 // Sets options passed into ReadCGM::load_file 00126 ErrorCode ReadCGM::set_options( const FileOptions& opts, 00127 int& norm_tol, 00128 double& faceting_tol, 00129 double& len_tol, 00130 bool& act_att, 00131 bool& verbose_warnings, 00132 bool& fatal_on_curves ) 00133 { 00134 ErrorCode rval; 00135 00136 // Default Values 00137 int DEFAULT_NORM = 5; 00138 double DEFAULT_FACET_TOL = 0.001; 00139 double DEFAULT_LEN_TOL = 0.0; 00140 act_att = true; 00141 00142 // Check for the options. 00143 if( MB_SUCCESS != opts.get_int_option( "FACET_NORMAL_TOLERANCE", norm_tol ) ) norm_tol = DEFAULT_NORM; 00144 00145 if( MB_SUCCESS != opts.get_real_option( "FACET_DISTANCE_TOLERANCE", faceting_tol ) ) 00146 faceting_tol = DEFAULT_FACET_TOL; 00147 00148 if( MB_SUCCESS != opts.get_real_option( "MAX_FACET_EDGE_LENGTH", len_tol ) ) len_tol = DEFAULT_LEN_TOL; 00149 00150 if( MB_SUCCESS == opts.get_null_option( "VERBOSE_CGM_WARNINGS" ) ) verbose_warnings = true; 00151 00152 if( MB_SUCCESS == opts.get_null_option( "FATAL_ON_CURVES" ) ) fatal_on_curves = true; 00153 00154 const char* name = "CGM_ATTRIBS"; 00155 const char* value = "no"; 00156 rval = opts.match_option( name, value ); 00157 if( MB_SUCCESS == rval ) act_att = false; 00158 00159 return MB_SUCCESS; 00160 } 00161 00162 ErrorCode ReadCGM::create_entity_sets( std::map< RefEntity*, EntityHandle > ( &entmap )[5] ) 00163 { 00164 ErrorCode rval; 00165 const char geom_categories[][CATEGORY_TAG_SIZE] = { "Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0" }; 00166 const char* const names[] = { "Vertex", "Curve", "Surface", "Volume" }; 00167 DLIList< RefEntity* > entlist; 00168 00169 for( int dim = 0; dim < 4; dim++ ) 00170 { 00171 entlist.clean_out(); 00172 GeometryQueryTool::instance()->ref_entity_list( names[dim], entlist, true ); 00173 entlist.reset(); 00174 00175 for( int i = entlist.size(); i--; ) 00176 { 00177 RefEntity* ent = entlist.get_and_step(); 00178 EntityHandle handle; 00179 // Create the new meshset 00180 rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle ); 00181 if( MB_SUCCESS != rval ) return rval; 00182 00183 // Map the geom reference entity to the corresponding moab meshset 00184 entmap[dim][ent] = handle; 00185 00186 // Create tags for the new meshset 00187 rval = mdbImpl->tag_set_data( geom_tag, &handle, 1, &dim ); 00188 if( MB_SUCCESS != rval ) return rval; 00189 00190 int id = ent->id(); 00191 rval = mdbImpl->tag_set_data( id_tag, &handle, 1, &id ); 00192 if( MB_SUCCESS != rval ) return rval; 00193 00194 rval = mdbImpl->tag_set_data( category_tag, &handle, 1, &geom_categories[dim] ); 00195 if( MB_SUCCESS != rval ) return rval; 00196 } 00197 } 00198 00199 return MB_SUCCESS; 00200 } 00201 00202 ErrorCode ReadCGM::create_topology( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] ) 00203 { 00204 ErrorCode rval; 00205 DLIList< RefEntity* > entitylist; 00206 std::map< RefEntity*, EntityHandle >::iterator ci; 00207 00208 for( int dim = 1; dim < 4; ++dim ) 00209 { 00210 for( ci = entitymap[dim].begin(); ci != entitymap[dim].end(); ++ci ) 00211 { 00212 entitylist.clean_out(); 00213 ci->first->get_child_ref_entities( entitylist ); 00214 00215 entitylist.reset(); 00216 for( int i = entitylist.size(); i--; ) 00217 { 00218 RefEntity* ent = entitylist.get_and_step(); 00219 EntityHandle h = entitymap[dim - 1][ent]; 00220 rval = mdbImpl->add_parent_child( ci->second, h ); 00221 if( MB_SUCCESS != rval ) return rval; 00222 } 00223 } 00224 } 00225 00226 return MB_SUCCESS; 00227 } 00228 00229 ErrorCode ReadCGM::store_surface_senses( std::map< RefEntity*, EntityHandle >& surface_map, 00230 std::map< RefEntity*, EntityHandle >& volume_map ) 00231 { 00232 ErrorCode rval; 00233 std::map< RefEntity*, EntityHandle >::iterator ci; 00234 00235 for( ci = surface_map.begin(); ci != surface_map.end(); ++ci ) 00236 { 00237 RefFace* face = (RefFace*)( ci->first ); 00238 BasicTopologyEntity *forward = 0, *reverse = 0; 00239 for( SenseEntity* cf = face->get_first_sense_entity_ptr(); cf; cf = cf->next_on_bte() ) 00240 { 00241 BasicTopologyEntity* vol = cf->get_parent_basic_topology_entity_ptr(); 00242 // Allocate vol to the proper topology entity (forward or reverse) 00243 if( cf->get_sense() == CUBIT_UNKNOWN || cf->get_sense() != face->get_surface_ptr()->bridge_sense() ) 00244 { 00245 // Check that each surface has a sense for only one volume 00246 if( reverse ) 00247 { 00248 std::cout << "Surface " << face->id() << " has reverse sense " 00249 << "with multiple volume " << reverse->id() << " and " 00250 << "volume " << vol->id() << std::endl; 00251 return MB_FAILURE; 00252 } 00253 reverse = vol; 00254 } 00255 if( cf->get_sense() == CUBIT_UNKNOWN || cf->get_sense() == face->get_surface_ptr()->bridge_sense() ) 00256 { 00257 // Check that each surface has a sense for only one volume 00258 if( forward ) 00259 { 00260 std::cout << "Surface " << face->id() << " has forward sense " 00261 << "with multiple volume " << forward->id() << " and " 00262 << "volume " << vol->id() << std::endl; 00263 return MB_FAILURE; 00264 } 00265 forward = vol; 00266 } 00267 } 00268 00269 if( forward ) 00270 { 00271 rval = myGeomTool->set_sense( ci->second, volume_map[forward], SENSE_FORWARD ); 00272 if( MB_SUCCESS != rval ) return rval; 00273 } 00274 if( reverse ) 00275 { 00276 rval = myGeomTool->set_sense( ci->second, volume_map[reverse], SENSE_REVERSE ); 00277 if( MB_SUCCESS != rval ) return rval; 00278 } 00279 } 00280 00281 return MB_SUCCESS; 00282 } 00283 00284 ErrorCode ReadCGM::store_curve_senses( std::map< RefEntity*, EntityHandle >& curve_map, 00285 std::map< RefEntity*, EntityHandle >& surface_map ) 00286 { 00287 ErrorCode rval; 00288 std::vector< EntityHandle > ents; 00289 std::vector< int > senses; 00290 std::map< RefEntity*, EntityHandle >::iterator ci; 00291 for( ci = curve_map.begin(); ci != curve_map.end(); ++ci ) 00292 { 00293 RefEdge* edge = (RefEdge*)( ci->first ); 00294 ents.clear(); 00295 senses.clear(); 00296 for( SenseEntity* ce = edge->get_first_sense_entity_ptr(); ce; ce = ce->next_on_bte() ) 00297 { 00298 BasicTopologyEntity* fac = ce->get_parent_basic_topology_entity_ptr(); 00299 EntityHandle face = surface_map[fac]; 00300 if( ce->get_sense() == CUBIT_UNKNOWN || ce->get_sense() != edge->get_curve_ptr()->bridge_sense() ) 00301 { 00302 ents.push_back( face ); 00303 senses.push_back( SENSE_REVERSE ); 00304 } 00305 if( ce->get_sense() == CUBIT_UNKNOWN || ce->get_sense() == edge->get_curve_ptr()->bridge_sense() ) 00306 { 00307 ents.push_back( face ); 00308 senses.push_back( SENSE_FORWARD ); 00309 } 00310 } 00311 00312 rval = myGeomTool->set_senses( ci->second, ents, senses ); 00313 if( MB_SUCCESS != rval ) return rval; 00314 } 00315 return MB_SUCCESS; 00316 } 00317 00318 ErrorCode ReadCGM::store_groups( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] ) 00319 { 00320 ErrorCode rval; 00321 00322 // Create entity sets for all ref groups 00323 rval = create_group_entsets( entitymap[4] ); 00324 if( rval != MB_SUCCESS ) return rval; 00325 00326 // Store group names and entities in the mesh 00327 rval = store_group_content( entitymap ); 00328 if( rval != MB_SUCCESS ) return rval; 00329 00330 return MB_SUCCESS; 00331 } 00332 00333 ErrorCode ReadCGM::create_group_entsets( std::map< RefEntity*, EntityHandle >& group_map ) 00334 { 00335 ErrorCode rval; 00336 const char geom_categories[][CATEGORY_TAG_SIZE] = { "Vertex\0", "Curve\0", "Surface\0", "Volume\0", "Group\0" }; 00337 DLIList< RefEntity* > entitylist; 00338 // Create entity sets for all ref groups 00339 std::vector< Tag > extra_name_tags; 00340 #if CGM_MAJOR_VERSION > 13 00341 DLIList< CubitString > name_list; 00342 #else 00343 DLIList< CubitString* > name_list; 00344 #endif 00345 entitylist.clean_out(); 00346 // Get all entity groups from the CGM model 00347 GeometryQueryTool::instance()->ref_entity_list( "group", entitylist ); 00348 entitylist.reset(); 00349 // Loop over all groups 00350 for( int i = entitylist.size(); i--; ) 00351 { 00352 // Take the next group 00353 RefEntity* grp = entitylist.get_and_step(); 00354 name_list.clean_out(); 00355 // Get the names of all entities in this group from the solid model 00356 #if CGM_MAJOR_VERSION > 13 00357 RefEntityName::instance()->get_refentity_name( grp, name_list ); 00358 #else 00359 // True argument is optional, but for large multi-names situation, it should save 00360 // some cpu time 00361 RefEntityName::instance()->get_refentity_name( grp, name_list, true ); 00362 #endif 00363 if( name_list.size() == 0 ) continue; 00364 // Set pointer to first name of the group and set the first name to name1 00365 name_list.reset(); 00366 #if CGM_MAJOR_VERSION > 13 00367 CubitString name1 = name_list.get(); 00368 #else 00369 CubitString name1 = *name_list.get(); 00370 #endif 00371 // Create entity handle for the group 00372 EntityHandle h; 00373 rval = mdbImpl->create_meshset( MESHSET_SET, h ); 00374 if( MB_SUCCESS != rval ) return rval; 00375 // Set tag data for the group 00376 char namebuf[NAME_TAG_SIZE]; 00377 memset( namebuf, '\0', NAME_TAG_SIZE ); 00378 strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 ); 00379 if( name1.length() >= (unsigned)NAME_TAG_SIZE ) 00380 std::cout << "WARNING: group name '" << name1.c_str() << "' truncated to '" << namebuf << "'" << std::endl; 00381 rval = mdbImpl->tag_set_data( name_tag, &h, 1, namebuf ); 00382 if( MB_SUCCESS != rval ) return MB_FAILURE; 00383 00384 int id = grp->id(); 00385 rval = mdbImpl->tag_set_data( id_tag, &h, 1, &id ); 00386 if( MB_SUCCESS != rval ) return MB_FAILURE; 00387 00388 rval = mdbImpl->tag_set_data( category_tag, &h, 1, &geom_categories[4] ); 00389 if( MB_SUCCESS != rval ) return MB_FAILURE; 00390 // Check for extra group names 00391 if( name_list.size() > 1 ) 00392 { 00393 for( int j = extra_name_tags.size(); j < name_list.size(); ++j ) 00394 { 00395 sprintf( namebuf, "EXTRA_%s%d", NAME_TAG_NAME, j ); 00396 Tag t; 00397 rval = 00398 mdbImpl->tag_get_handle( namebuf, NAME_TAG_SIZE, MB_TYPE_OPAQUE, t, MB_TAG_SPARSE | MB_TAG_CREAT ); 00399 assert( !rval ); 00400 extra_name_tags.push_back( t ); 00401 } 00402 // Add extra group names to the group handle 00403 for( int j = 0; j < name_list.size(); ++j ) 00404 { 00405 #if CGM_MAJOR_VERSION > 13 00406 name1 = name_list.get_and_step(); 00407 #else 00408 name1 = *name_list.get_and_step(); 00409 #endif 00410 memset( namebuf, '\0', NAME_TAG_SIZE ); 00411 strncpy( namebuf, name1.c_str(), NAME_TAG_SIZE - 1 ); 00412 if( name1.length() >= (unsigned)NAME_TAG_SIZE ) 00413 std::cout << "WARNING: group name '" << name1.c_str() << "' truncated to '" << namebuf << "'" 00414 << std::endl; 00415 rval = mdbImpl->tag_set_data( extra_name_tags[j], &h, 1, namebuf ); 00416 if( MB_SUCCESS != rval ) return MB_FAILURE; 00417 } 00418 } 00419 // Add the group handle 00420 group_map[grp] = h; 00421 } 00422 00423 return MB_SUCCESS; 00424 } 00425 00426 ErrorCode ReadCGM::store_group_content( std::map< RefEntity*, EntityHandle > ( &entitymap )[5] ) 00427 { 00428 ErrorCode rval; 00429 DLIList< RefEntity* > entlist; 00430 std::map< RefEntity*, EntityHandle >::iterator ci; 00431 // Store contents for each group 00432 entlist.reset(); 00433 for( ci = entitymap[4].begin(); ci != entitymap[4].end(); ++ci ) 00434 { 00435 RefGroup* grp = (RefGroup*)( ci->first ); 00436 entlist.clean_out(); 00437 grp->get_child_ref_entities( entlist ); 00438 00439 Range entities; 00440 while( entlist.size() ) 00441 { 00442 RefEntity* ent = entlist.pop(); 00443 int dim = ent->dimension(); 00444 00445 if( dim < 0 ) 00446 { 00447 Body* body; 00448 if( entitymap[4].find( ent ) != entitymap[4].end() ) 00449 { 00450 // Child is another group; examine its contents 00451 entities.insert( entitymap[4][ent] ); 00452 } 00453 else if( ( body = dynamic_cast< Body* >( ent ) ) != NULL ) 00454 { 00455 // Child is a CGM Body, which presumably comprises some volumes-- 00456 // extract volumes as if they belonged to group. 00457 DLIList< RefVolume* > vols; 00458 body->ref_volumes( vols ); 00459 for( int vi = vols.size(); vi--; ) 00460 { 00461 RefVolume* vol = vols.get_and_step(); 00462 if( entitymap[3].find( vol ) != entitymap[3].end() ) 00463 { 00464 entities.insert( entitymap[3][vol] ); 00465 } 00466 else 00467 { 00468 std::cerr << "Warning: CGM Body has orphan RefVolume" << std::endl; 00469 } 00470 } 00471 } 00472 else 00473 { 00474 // Otherwise, warn user. 00475 std::cerr << "Warning: A dim<0 entity is being ignored by ReadCGM." << std::endl; 00476 } 00477 } 00478 else if( dim < 4 ) 00479 { 00480 if( entitymap[dim].find( ent ) != entitymap[dim].end() ) entities.insert( entitymap[dim][ent] ); 00481 } 00482 } 00483 00484 if( !entities.empty() ) 00485 { 00486 rval = mdbImpl->add_entities( ci->second, entities ); 00487 if( MB_SUCCESS != rval ) return MB_FAILURE; 00488 } 00489 } 00490 00491 return MB_SUCCESS; 00492 } 00493 00494 void ReadCGM::set_cgm_attributes( bool const act_attributes, bool const verbose ) 00495 { 00496 if( act_attributes ) 00497 { 00498 CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( act_attributes ); 00499 CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( act_attributes ); 00500 } 00501 00502 if( !verbose ) 00503 { 00504 CGMApp::instance()->attrib_manager()->silent_flag( true ); 00505 } 00506 } 00507 00508 ErrorCode ReadCGM::create_vertices( std::map< RefEntity*, EntityHandle >& vertex_map ) 00509 { 00510 ErrorCode rval; 00511 std::map< RefEntity*, EntityHandle >::iterator ci; 00512 for( ci = vertex_map.begin(); ci != vertex_map.end(); ++ci ) 00513 { 00514 CubitVector pos = dynamic_cast< RefVertex* >( ci->first )->coordinates(); 00515 double coords[3] = { pos.x(), pos.y(), pos.z() }; 00516 EntityHandle vh; 00517 rval = mdbImpl->create_vertex( coords, vh ); 00518 if( MB_SUCCESS != rval ) return MB_FAILURE; 00519 00520 // Add the vertex to its tagged meshset 00521 rval = mdbImpl->add_entities( ci->second, &vh, 1 ); 00522 if( MB_SUCCESS != rval ) return MB_FAILURE; 00523 00524 // Replace the meshset handle with the vertex handle 00525 // This makes adding the vertex to higher dim sets easier 00526 ci->second = vh; 00527 } 00528 00529 return MB_SUCCESS; 00530 } 00531 00532 ErrorCode ReadCGM::create_curve_facets( std::map< RefEntity*, EntityHandle >& curve_map, 00533 std::map< RefEntity*, EntityHandle >& vertex_map, 00534 #if CGM_MAJOR_VERSION > 12 00535 int norm_tol, 00536 #else 00537 int /* norm_tol */, 00538 #endif 00539 double faceting_tol, 00540 bool verbose_warn, 00541 bool fatal_on_curves ) 00542 { 00543 ErrorCode rval; 00544 CubitStatus s; 00545 // Maximum allowable curve-endpoint proximity warnings 00546 // If this integer becomes negative, then abs(curve_warnings) is the 00547 // number of warnings that were suppressed. 00548 int curve_warnings = 0; 00549 00550 // Map iterator 00551 std::map< RefEntity*, EntityHandle >::iterator ci; 00552 00553 // Create geometry for all curves 00554 GMem data; 00555 for( ci = curve_map.begin(); ci != curve_map.end(); ++ci ) 00556 { 00557 // Get the start and end points of the curve in the form of a reference edge 00558 RefEdge* edge = dynamic_cast< RefEdge* >( ci->first ); 00559 // Get the edge's curve information 00560 Curve* curve = edge->get_curve_ptr(); 00561 // Clean out previous curve information 00562 data.clean_out(); 00563 // Facet curve according to parameters and CGM version 00564 #if CGM_MAJOR_VERSION > 12 00565 s = edge->get_graphics( data, norm_tol, faceting_tol ); 00566 #else 00567 s = edge->get_graphics( data, faceting_tol ); 00568 #endif 00569 00570 if( s != CUBIT_SUCCESS ) 00571 { 00572 // if we fatal on curves 00573 if( fatal_on_curves ) 00574 { 00575 std::cout << "Failed to facet the curve " << edge->id() << std::endl; 00576 return MB_FAILURE; 00577 } 00578 // otherwise record them 00579 else 00580 { 00581 failed_curve_count++; 00582 failed_curves.push_back( edge->id() ); 00583 } 00584 continue; 00585 } 00586 00587 std::vector< CubitVector > points; 00588 for( int i = 0; i < data.pointListCount; ++i ) 00589 // Add Cubit vertext points to a list 00590 points.push_back( CubitVector( data.point_list()[i].x, data.point_list()[i].y, data.point_list()[i].z ) ); 00591 00592 // Need to reverse data? 00593 if( curve->bridge_sense() == CUBIT_REVERSED ) std::reverse( points.begin(), points.end() ); 00594 00595 // Check for closed curve 00596 RefVertex *start_vtx, *end_vtx; 00597 start_vtx = edge->start_vertex(); 00598 end_vtx = edge->end_vertex(); 00599 00600 // Special case for point curve 00601 if( points.size() < 2 ) 00602 { 00603 if( start_vtx != end_vtx || curve->measure() > GEOMETRY_RESABS ) 00604 { 00605 std::cerr << "Warning: No facetting for curve " << edge->id() << std::endl; 00606 continue; 00607 } 00608 EntityHandle h = vertex_map[start_vtx]; 00609 rval = mdbImpl->add_entities( ci->second, &h, 1 ); 00610 if( MB_SUCCESS != rval ) return MB_FAILURE; 00611 continue; 00612 } 00613 // Check to see if the first and last interior vertices are considered to be 00614 // coincident by CUBIT 00615 const bool closed = ( points.front() - points.back() ).length() < GEOMETRY_RESABS; 00616 if( closed != ( start_vtx == end_vtx ) ) 00617 { 00618 std::cerr << "Warning: topology and geometry inconsistant for possibly closed curve " << edge->id() 00619 << std::endl; 00620 } 00621 00622 // Check proximity of vertices to end coordinates 00623 if( ( start_vtx->coordinates() - points.front() ).length() > GEOMETRY_RESABS || 00624 ( end_vtx->coordinates() - points.back() ).length() > GEOMETRY_RESABS ) 00625 { 00626 00627 curve_warnings--; 00628 if( curve_warnings >= 0 || verbose_warn ) 00629 { 00630 std::cerr << "Warning: vertices not at ends of curve " << edge->id() << std::endl; 00631 if( curve_warnings == 0 && !verbose_warn ) 00632 { 00633 std::cerr << " further instances of this warning will be suppressed..." << std::endl; 00634 } 00635 } 00636 } 00637 // Create interior points 00638 std::vector< EntityHandle > verts, edges; 00639 verts.push_back( vertex_map[start_vtx] ); 00640 for( size_t i = 1; i < points.size() - 1; ++i ) 00641 { 00642 double coords[] = { points[i].x(), points[i].y(), points[i].z() }; 00643 EntityHandle h; 00644 // Create vertex entity 00645 rval = mdbImpl->create_vertex( coords, h ); 00646 if( MB_SUCCESS != rval ) return MB_FAILURE; 00647 verts.push_back( h ); 00648 } 00649 verts.push_back( vertex_map[end_vtx] ); 00650 00651 // Create edges 00652 for( size_t i = 0; i < verts.size() - 1; ++i ) 00653 { 00654 EntityHandle h; 00655 rval = mdbImpl->create_element( MBEDGE, &verts[i], 2, h ); 00656 if( MB_SUCCESS != rval ) return MB_FAILURE; 00657 edges.push_back( h ); 00658 } 00659 00660 // If closed, remove duplicate 00661 if( verts.front() == verts.back() ) verts.pop_back(); 00662 // Add entities to the curve meshset from entitymap 00663 rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() ); 00664 if( MB_SUCCESS != rval ) return MB_FAILURE; 00665 rval = mdbImpl->add_entities( ci->second, &edges[0], edges.size() ); 00666 if( MB_SUCCESS != rval ) return MB_FAILURE; 00667 } 00668 00669 if( !verbose_warn && curve_warnings < 0 ) 00670 { 00671 std::cerr << "Suppressed " << -curve_warnings << " 'vertices not at ends of curve' warnings." << std::endl; 00672 std::cerr << "To see all warnings, use reader param VERBOSE_CGM_WARNINGS." << std::endl; 00673 } 00674 00675 return MB_SUCCESS; 00676 } 00677 00678 ErrorCode ReadCGM::create_surface_facets( std::map< RefEntity*, EntityHandle >& surface_map, 00679 std::map< RefEntity*, EntityHandle >& vertex_map, 00680 int norm_tol, 00681 double facet_tol, 00682 double length_tol ) 00683 { 00684 ErrorCode rval; 00685 std::map< RefEntity*, EntityHandle >::iterator ci; 00686 CubitStatus s; 00687 #if( ( CGM_MAJOR_VERSION == 14 && CGM_MINOR_VERSION > 2 ) || CGM_MAJOR_VERSION >= 15 ) 00688 DLIList< TopologyEntity* > me_list; 00689 #else 00690 DLIList< ModelEntity* > me_list; 00691 #endif 00692 00693 GMem data; 00694 // Create geometry for all surfaces 00695 for( ci = surface_map.begin(); ci != surface_map.end(); ++ci ) 00696 { 00697 RefFace* face = dynamic_cast< RefFace* >( ci->first ); 00698 00699 data.clean_out(); 00700 s = face->get_graphics( data, norm_tol, facet_tol, length_tol ); 00701 00702 if( CUBIT_SUCCESS != s ) return MB_FAILURE; 00703 00704 // Declare array of all vertex handles 00705 std::vector< EntityHandle > verts( data.pointListCount, 0 ); 00706 00707 // Get list of geometric vertices in surface 00708 me_list.clean_out(); 00709 ModelQueryEngine::instance()->query_model( *face, DagType::ref_vertex_type(), me_list ); 00710 00711 // For each geometric vertex, find a single coincident point in facets 00712 // Otherwise, print a warning 00713 for( int i = me_list.size(); i--; ) 00714 { 00715 // Assign geometric vertex 00716 RefVertex* vtx = dynamic_cast< RefVertex* >( me_list.get_and_step() ); 00717 CubitVector pos = vtx->coordinates(); 00718 00719 for( int j = 0; j < data.pointListCount; ++j ) 00720 { 00721 // Assign facet vertex 00722 CubitVector vpos( data.point_list()[j].x, data.point_list()[j].y, data.point_list()[j].z ); 00723 // Check to see if they are considered coincident 00724 if( ( pos - vpos ).length_squared() < GEOMETRY_RESABS * GEOMETRY_RESABS ) 00725 { 00726 // If this facet vertex has already been found coincident, print warning 00727 if( verts[j] ) std::cerr << "Warning: Coincident vertices in surface " << face->id() << std::endl; 00728 // If a coincidence is found, keep track of it in the verts vector 00729 verts[j] = vertex_map[vtx]; 00730 break; 00731 } 00732 } 00733 } 00734 00735 // Now create vertices for the remaining points in the facetting 00736 for( int i = 0; i < data.pointListCount; ++i ) 00737 { 00738 if( verts[i] ) // If a geometric vertex 00739 continue; 00740 double coords[] = { data.point_list()[i].x, data.point_list()[i].y, data.point_list()[i].z }; 00741 // Return vertex handle to verts to fill in all remaining facet 00742 // vertices 00743 rval = mdbImpl->create_vertex( coords, verts[i] ); 00744 if( MB_SUCCESS != rval ) return rval; 00745 } 00746 00747 // record the failures for information 00748 if( data.fListCount == 0 ) 00749 { 00750 failed_surface_count++; 00751 failed_surfaces.push_back( face->id() ); 00752 } 00753 00754 // Now create facets 00755 Range facets; 00756 std::vector< EntityHandle > corners; 00757 for( int i = 0; i < data.fListCount; i += data.facet_list()[i] + 1 ) 00758 { 00759 // Get number of facet verts 00760 int* facet = data.facet_list() + i; 00761 corners.resize( *facet ); 00762 for( int j = 1; j <= *facet; ++j ) 00763 { 00764 if( facet[j] >= (int)verts.size() ) 00765 { 00766 std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl; 00767 return MB_FAILURE; 00768 } 00769 corners[j - 1] = verts[facet[j]]; 00770 } 00771 EntityType type; 00772 if( *facet == 3 ) 00773 type = MBTRI; 00774 else 00775 { 00776 std::cerr << "Warning: non-triangle facet in surface " << face->id() << std::endl; 00777 std::cerr << " entity has " << *facet << " edges" << std::endl; 00778 if( *facet == 4 ) 00779 type = MBQUAD; 00780 else 00781 type = MBPOLYGON; 00782 } 00783 00784 // if (surf->bridge_sense() == CUBIT_REVERSED) 00785 // std::reverse(corners.begin(), corners.end()); 00786 00787 EntityHandle h; 00788 rval = mdbImpl->create_element( type, &corners[0], corners.size(), h ); 00789 if( MB_SUCCESS != rval ) return MB_FAILURE; 00790 00791 facets.insert( h ); 00792 } 00793 00794 // Add vertices and facets to surface set 00795 rval = mdbImpl->add_entities( ci->second, &verts[0], verts.size() ); 00796 if( MB_SUCCESS != rval ) return MB_FAILURE; 00797 rval = mdbImpl->add_entities( ci->second, facets ); 00798 if( MB_SUCCESS != rval ) return MB_FAILURE; 00799 } 00800 00801 return MB_SUCCESS; 00802 } 00803 00804 // Copy geometry into mesh database 00805 ErrorCode ReadCGM::load_file( const char* cgm_file_name, 00806 const EntityHandle* file_set, 00807 const FileOptions& opts, 00808 const ReaderIface::SubsetList* subset_list, 00809 const Tag* /*file_id_tag*/ ) 00810 { 00811 // Blocks_to_load and num_blocks are ignored. 00812 ErrorCode rval; 00813 00814 if( subset_list ) 00815 { 00816 MB_SET_ERR( MB_UNSUPPORTED_OPERATION, "Reading subset of files not supported for CGM data" ); 00817 } 00818 00819 int norm_tol; 00820 double faceting_tol; 00821 double len_tol; 00822 bool act_att = true; 00823 bool verbose_warnings = false; 00824 bool fatal_on_curves = false; 00825 00826 rval = set_options( opts, norm_tol, faceting_tol, len_tol, act_att, verbose_warnings, fatal_on_curves ); 00827 if( MB_SUCCESS != rval ) return rval; 00828 00829 // Always tag with the faceting_tol and geometry absolute resolution 00830 // If file_set is defined, use that, otherwise (file_set == NULL) tag the interface 00831 EntityHandle set = file_set ? *file_set : 0; 00832 rval = mdbImpl->tag_set_data( faceting_tol_tag, &set, 1, &faceting_tol ); 00833 if( MB_SUCCESS != rval ) return rval; 00834 00835 rval = mdbImpl->tag_set_data( geometry_resabs_tag, &set, 1, &GEOMETRY_RESABS ); 00836 if( MB_SUCCESS != rval ) return rval; 00837 00838 // Initialize CGM 00839 InitCGMA::initialize_cgma(); 00840 00841 // Determine CGM settings and amount of output 00842 set_cgm_attributes( act_att, verbose_warnings ); 00843 00844 CubitStatus s; 00845 00846 // Get CGM file type 00847 const char* file_type = 0; 00848 file_type = get_geom_file_type( cgm_file_name ); 00849 if( !file_type || !strcmp( file_type, "CUBIT" ) ) return MB_FAILURE; 00850 00851 s = CubitCompat_import_solid_model( cgm_file_name, file_type ); 00852 if( CUBIT_SUCCESS != s ) 00853 { 00854 MB_SET_ERR( MB_FAILURE, cgm_file_name << ": Failed to read file of type \"" << file_type << "\"" ); 00855 } 00856 00857 // Create entity sets for all geometric entities 00858 std::map< RefEntity*, EntityHandle > entmap[5]; // One for each dim, and one for groups 00859 00860 rval = create_entity_sets( entmap ); 00861 if( rval != MB_SUCCESS ) return rval; 00862 00863 // Create topology for all geometric entities 00864 rval = create_topology( entmap ); 00865 if( rval != MB_SUCCESS ) return rval; 00866 00867 // Store CoFace senses 00868 rval = store_surface_senses( entmap[2], entmap[3] ); 00869 if( rval != MB_SUCCESS ) return rval; 00870 00871 // Store CoEdge senses 00872 rval = store_curve_senses( entmap[1], entmap[2] ); 00873 if( rval != MB_SUCCESS ) return rval; 00874 00875 // Get group information and store it in the mesh 00876 rval = store_groups( entmap ); 00877 if( rval != MB_SUCCESS ) return rval; 00878 00879 // Done with volumes and groups 00880 entmap[3].clear(); 00881 entmap[4].clear(); 00882 00883 // Create geometry for all vertices and replace 00884 rval = create_vertices( entmap[0] ); 00885 if( rval != MB_SUCCESS ) return rval; 00886 00887 // Create facets for all curves 00888 rval = create_curve_facets( entmap[1], entmap[0], norm_tol, faceting_tol, verbose_warnings, fatal_on_curves ); 00889 if( rval != MB_SUCCESS ) return rval; 00890 00891 // Create facets for surfaces 00892 rval = create_surface_facets( entmap[2], entmap[0], norm_tol, faceting_tol, len_tol ); 00893 if( rval != MB_SUCCESS ) return rval; 00894 00895 // print the fail information 00896 dump_fail_counts(); 00897 00898 return MB_SUCCESS; 00899 } 00900 00901 // return the number of curves that failed to facet 00902 int ReadCGM::get_failed_curve_count() 00903 { 00904 return failed_curve_count; 00905 } 00906 00907 // return the number of surfaces that failed to facet 00908 int ReadCGM::get_failed_surface_count() 00909 { 00910 return failed_surface_count; 00911 } 00912 00913 void ReadCGM::dump_fail_counts() 00914 { 00915 std::cout << "***** Faceting Summary Information *****" << std::endl; 00916 std::cout << "----- Curve Fail Information -----" << std::endl; 00917 std::cout << "There were " << failed_curve_count << " curves that could not be faceted." << std::endl; 00918 00919 if( failed_curve_count > 0 ) 00920 { 00921 std::cout << "The curves were "; 00922 for( int i = 0; i < failed_curve_count; i++ ) 00923 { 00924 std::cout << failed_curves[i] << " "; 00925 if( ( i % 10 == 0 ) & ( i > 0 ) ) std::cout << std::endl; 00926 } 00927 } 00928 std::cout << std::endl; 00929 std::cout << "----- Facet Fail Information -----" << std::endl; 00930 std::cout << "There were " << failed_surface_count << " surfaces that could not be faceted." << std::endl; 00931 if( failed_surface_count > 0 ) 00932 { 00933 std::cout << "The surfaces were "; 00934 for( int i = 0; i < failed_surface_count; i++ ) 00935 { 00936 std::cout << failed_surfaces[i] << " "; 00937 if( ( i % 10 == 0 ) & ( i > 0 ) ) std::cout << std::endl; 00938 } 00939 } 00940 std::cout << std::endl; 00941 std::cout << "***** End of Faceting Summary Information *****" << std::endl; 00942 return; 00943 } 00944 00945 const char* ReadCGM::get_geom_file_type( const char* name ) 00946 { 00947 FILE* file; 00948 const char* result = 0; 00949 00950 file = fopen( name, "r" ); 00951 if( file ) 00952 { 00953 result = get_geom_fptr_type( file ); 00954 fclose( file ); 00955 } 00956 00957 return result; 00958 } 00959 00960 const char* ReadCGM::get_geom_fptr_type( FILE* file ) 00961 { 00962 static const char* CUBIT_NAME = GF_CUBIT_FILE_TYPE; 00963 static const char* STEP_NAME = GF_STEP_FILE_TYPE; 00964 static const char* IGES_NAME = GF_IGES_FILE_TYPE; 00965 static const char* BREP_NAME = GF_OCC_BREP_FILE_TYPE; 00966 static const char* FACET_NAME = GF_FACET_FILE_TYPE; 00967 00968 if( is_cubit_file( file ) ) 00969 return CUBIT_NAME; 00970 else if( is_step_file( file ) ) 00971 return STEP_NAME; 00972 else if( is_iges_file( file ) ) 00973 return IGES_NAME; 00974 else if( is_occ_brep_file( file ) ) 00975 return BREP_NAME; 00976 else if( is_facet_file( file ) ) 00977 return FACET_NAME; 00978 else 00979 return NULL; 00980 } 00981 00982 int ReadCGM::is_cubit_file( FILE* file ) 00983 { 00984 unsigned char buffer[4]; 00985 return !fseek( file, 0, SEEK_SET ) && fread( buffer, 4, 1, file ) && !memcmp( buffer, "CUBE", 4 ); 00986 } 00987 00988 int ReadCGM::is_step_file( FILE* file ) 00989 { 00990 unsigned char buffer[9]; 00991 return !fseek( file, 0, SEEK_SET ) && fread( buffer, 9, 1, file ) && !memcmp( buffer, "ISO-10303", 9 ); 00992 } 00993 00994 int ReadCGM::is_iges_file( FILE* file ) 00995 { 00996 unsigned char buffer[10]; 00997 return !fseek( file, 72, SEEK_SET ) && fread( buffer, 10, 1, file ) && !memcmp( buffer, "S 1", 8 ); 00998 } 00999 01000 int ReadCGM::is_occ_brep_file( FILE* file ) 01001 { 01002 unsigned char buffer[6]; 01003 return !fseek( file, 0, SEEK_SET ) && fread( buffer, 6, 1, file ) && !memcmp( buffer, "DBRep_", 6 ); 01004 } 01005 int ReadCGM::is_facet_file( FILE* file ) 01006 { 01007 unsigned char buffer[10]; 01008 return !fseek( file, 0, SEEK_SET ) && fread( buffer, 10, 1, file ) && !memcmp( buffer, "MESH_BASED", 10 ); 01009 } 01010 01011 void ReadCGM::tokenize( const std::string& str, std::vector< std::string >& tokens, const char* delimiters ) 01012 { 01013 std::string::size_type last = str.find_first_not_of( delimiters, 0 ); 01014 std::string::size_type pos = str.find_first_of( delimiters, last ); 01015 while( std::string::npos != pos && std::string::npos != last ) 01016 { 01017 tokens.push_back( str.substr( last, pos - last ) ); 01018 last = str.find_first_not_of( delimiters, pos ); 01019 pos = str.find_first_of( delimiters, last ); 01020 if( std::string::npos == pos ) pos = str.size(); 01021 } 01022 } 01023 01024 } // namespace moab
