MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/ParallelComm.hpp"#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/iMOAB.h"#include "TestUtil.hpp"
Include dependency graph for migrate_test.cpp:Go to the source code of this file.
Defines | |
| #define | RUN_TEST_ARG2(A, B) run_test( &( A ), #A, B ) |
| #define | CHECKRC(rc, message) |
Functions | |
| int | is_any_proc_error (int is_my_error) |
| int | run_test (ErrorCode(*func)(const char *), const char *func_name, const char *file_name) |
| ErrorCode | migrate_1_1 (const char *filename) |
| ErrorCode | migrate_1_2 (const char *filename) |
| ErrorCode | migrate_2_1 (const char *filename) |
| ErrorCode | migrate_2_2 (const char *filename) |
| ErrorCode | migrate_4_2 (const char *filename) |
| ErrorCode | migrate_2_4 (const char *filename) |
| ErrorCode | migrate_4_3 (const char *filename) |
| ErrorCode | migrate_overlap (const char *filename) |
| int | main (int argc, char *argv[]) |
| ErrorCode | migrate (const char *filename, const char *outfile) |
Variables | |
| int | rank |
| int | size |
| int | ierr |
| int | compid1 |
| int | compid2 |
| int | nghlay |
| int | groupTasks [4] |
| int | startG1 |
| int | startG2 |
| int | endG1 |
| int | endG2 |
| MPI_Comm | jcomm |
| MPI_Group | jgroup |
| #define CHECKRC | ( | rc, | |
| message | |||
if( 0 != ( rc ) ) \ { \ printf( "Error: %s\n", message ); \ return MB_FAILURE; \ }
Definition at line 20 of file migrate_test.cpp.
Referenced by migrate().
| #define RUN_TEST_ARG2 | ( | A, | |
| B | |||
| ) | run_test( &( A ), #A, B ) |
Definition at line 16 of file migrate_test.cpp.
Referenced by main().
| int is_any_proc_error | ( | int | is_my_error | ) |
Definition at line 27 of file migrate_test.cpp.
References MPI_COMM_WORLD.
int result = 0;
int err = MPI_Allreduce( &is_my_error, &result, 1, MPI_INT, MPI_MAX, MPI_COMM_WORLD );
return err || result;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 71 of file migrate_test.cpp.
References filename, jcomm, jgroup, migrate_1_1(), migrate_1_2(), migrate_2_1(), migrate_2_2(), migrate_2_4(), migrate_4_2(), migrate_4_3(), migrate_overlap(), MPI_COMM_WORLD, rank, RUN_TEST_ARG2, and size.
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
MPI_Comm_size( MPI_COMM_WORLD, &size );
MPI_Comm_dup( MPI_COMM_WORLD, &jcomm );
MPI_Comm_group( jcomm, &jgroup );
std::string filename;
filename = TestDir + "unittest/field1.h5m";
if( argc > 1 )
filename = argv[1];
int num_errors = 0;
num_errors += RUN_TEST_ARG2( migrate_1_1, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_1_2, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_2_1, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_2_2, filename.c_str() );
if( size >= 4 )
num_errors += RUN_TEST_ARG2( migrate_4_2, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_2_4, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_4_3, filename.c_str() );
num_errors += RUN_TEST_ARG2( migrate_overlap, filename.c_str() );
if( rank == 0 )
if( !num_errors )
std::cout << "All tests passed" << std::endl;
else
std::cout << num_errors << " TESTS FAILED!" << std::endl;
MPI_Group_free( &jgroup );
MPI_Comm_free( &jcomm );
MPI_Finalize();
return num_errors;
Definition at line 112 of file migrate_test.cpp.
References CHECKRC, compid1, compid2, DENSE_DOUBLE, endG1, endG2, groupTasks, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_Initialize(), iMOAB_LoadMesh(), iMOAB_RegisterApplication(), iMOAB_WriteMesh(), jcomm, jgroup, MB_SUCCESS, nghlay, readopts(), startG1, and startG2.
Referenced by migrate_1_1(), migrate_1_2(), migrate_2_1(), migrate_2_2(), migrate_2_4(), migrate_4_2(), migrate_4_3(), and migrate_overlap().
// first create MPI groups
std::string filen( filename );
MPI_Group group1, group2;
for( int i = startG1; i <= endG1; i++ )
groupTasks[i - startG1] = i;
ierr = MPI_Group_incl( jgroup, endG1 - startG1 + 1, groupTasks, &group1 );
CHECKRC( ierr, "can't create group1" )
for( int i = startG2; i <= endG2; i++ )
groupTasks[i - startG2] = i;
ierr = MPI_Group_incl( jgroup, endG2 - startG2 + 1, groupTasks, &group2 );
CHECKRC( ierr, "can't create group2" )
// create 2 communicators, one for each group
int tagcomm1 = 1, tagcomm2 = 2;
MPI_Comm comm1, comm2;
ierr = MPI_Comm_create_group( jcomm, group1, tagcomm1, &comm1 );
CHECKRC( ierr, "can't create comm1" )
ierr = MPI_Comm_create_group( jcomm, group2, tagcomm2, &comm2 );
CHECKRC( ierr, "can't create comm2" )
ierr = iMOAB_Initialize( 0, 0 ); // not really needed anything from argc, argv, yet; maybe we should
CHECKRC( ierr, "can't initialize iMOAB" )
// give some dummy values to component ids, just to differentiate between them
// the par comm graph is unique between components
compid1 = 4;
compid2 = 7;
int context_id = -1; // default context; will be now set to compid1 or compid2
int appID1;
iMOAB_AppID pid1 = &appID1;
int appID2;
iMOAB_AppID pid2 = &appID2;
if( comm1 != MPI_COMM_NULL )
ierr = iMOAB_RegisterApplication( "APP1", &comm1, &compid1, pid1 );
CHECKRC( ierr, "can't register app1 " )
if( comm2 != MPI_COMM_NULL )
ierr = iMOAB_RegisterApplication( "APP2", &comm2, &compid2, pid2 );
CHECKRC( ierr, "can't register app2 " )
int method = 0; // trivial partition for sending
std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
nghlay = 0;
ierr = iMOAB_LoadMesh( pid1, filen.c_str(), readopts.c_str(), &nghlay );
CHECKRC( ierr, "can't load mesh " )
ierr = iMOAB_SendMesh( pid1, &jcomm, &group2, &compid2, &method ); // send to component 2
CHECKRC( ierr, "cannot send elements" )
ierr = iMOAB_ReceiveMesh( pid2, &jcomm, &group1, &compid1 ); // receive from component 1
CHECKRC( ierr, "cannot receive elements" )
std::string wopts;
wopts = "PARALLEL=WRITE_PART;";
ierr = iMOAB_WriteMesh( pid2, outfile, wopts.c_str() );
CHECKRC( ierr, "cannot write received mesh" )
MPI_Barrier( jcomm );
// we can now free the sender buffers
if( comm1 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid1, &context_id );
// exchange tag, from component to component
// one is receiving, one is sending the tag; the one that is sending needs to have communicator
// not null
int size_tag = 1; // a double dense tag, on elements
int tagType = DENSE_DOUBLE;
int tagIndex2 = 0, tagIndex1 = 0; // these will be tag indices on each app pid
std::string fileAfterTagMigr( outfile ); // has h5m
int sizen = fileAfterTagMigr.length();
fileAfterTagMigr.erase( sizen - 4, 4 ); // erase extension .h5m
fileAfterTagMigr = fileAfterTagMigr + "_tag.h5m";
// now send a tag from component 2, towards component 1
ierr = iMOAB_DefineTagStorage( pid2, "element_field", &tagType, &size_tag, &tagIndex2 );
CHECKRC( ierr, "failed to get tag element_field " );
// this tag is already existing in the file
// first, send from compid2 to compid1, from comm2, using common joint comm
// as always, use nonblocking sends
// contex_id should be now compid1
context_id = compid1;
ierr = iMOAB_SendElementTag( pid2, "element_field", &jcomm, &context_id );
CHECKRC( ierr, "cannot send tag values" )
// receive on component 1
ierr = iMOAB_DefineTagStorage( pid1, "element_field", &tagType, &size_tag, &tagIndex1 );
CHECKRC( ierr, "failed to get tag DFIELD " );
context_id = compid2;
ierr = iMOAB_ReceiveElementTag( pid1, "element_field", &jcomm, &context_id );
std::string wopts;
ierr = iMOAB_WriteMesh( pid1, fileAfterTagMigr.c_str(), wopts.c_str() );
if( comm2 != MPI_COMM_NULL ) ierr = iMOAB_FreeSenderBuffers( pid2, &context_id );
ierr = iMOAB_DeregisterApplication( pid2 );
CHECKRC( ierr, "cannot deregister app 2 receiver" )
ierr = iMOAB_DeregisterApplication( pid1 );
CHECKRC( ierr, "cannot deregister app 1 sender" )
ierr = iMOAB_Finalize();
CHECKRC( ierr, "did not finalize iMOAB" )
if( MPI_COMM_NULL != comm1 ) MPI_Comm_free( &comm1 );
if( MPI_COMM_NULL != comm2 ) MPI_Comm_free( &comm2 );
MPI_Group_free( &group1 );
MPI_Group_free( &group2 );
return MB_SUCCESS;
| ErrorCode migrate_1_1 | ( | const char * | filename | ) |
| ErrorCode migrate_1_2 | ( | const char * | filename | ) |
| ErrorCode migrate_2_1 | ( | const char * | filename | ) |
| ErrorCode migrate_2_2 | ( | const char * | filename | ) |
| ErrorCode migrate_2_4 | ( | const char * | filename | ) |
| ErrorCode migrate_4_2 | ( | const char * | filename | ) |
| ErrorCode migrate_4_3 | ( | const char * | filename | ) |
| ErrorCode migrate_overlap | ( | const char * | filename | ) |
Definition at line 34 of file migrate_test.cpp.
References ErrorCode, is_any_proc_error(), MB_SUCCESS, MPI_COMM_WORLD, and rank.
ErrorCode result = ( *func )( file_name );
int is_err = is_any_proc_error( ( MB_SUCCESS != result ) );
int rank;
if( rank == 0 )
if( is_err )
std::cout << func_name << " : FAILED!!" << std::endl;
else
std::cout << func_name << " : success" << std::endl;
return is_err;
| int compid1 |
Definition at line 63 of file migrate_test.cpp.
| int compid2 |
| int endG1 |
Definition at line 66 of file migrate_test.cpp.
| int endG2 |
| int groupTasks[4] |
Definition at line 65 of file migrate_test.cpp.
| int ierr |
Definition at line 61 of file migrate_test.cpp.
Definition at line 68 of file migrate_test.cpp.
| MPI_Group jgroup |
Definition at line 69 of file migrate_test.cpp.
| int nghlay |
Definition at line 64 of file migrate_test.cpp.
| int rank |
| int size |
| int startG1 |
| int startG2 |
