MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 /** 00002 * MOAB, a Mesh-Oriented datABase, is a software component for creating, 00003 * storing and accessing finite element mesh data. 00004 * 00005 * Copyright 2004 Sandia Corporation. Under the terms of Contract 00006 * DE-AC04-94AL85000 with Sandia Corporation, the U.S. Government 00007 * retains certain rights in this software. 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 */ 00015 00016 #ifndef MOAB_PARALLEL_COMM_HPP 00017 #define MOAB_PARALLEL_COMM_HPP 00018 00019 #include "moab/Forward.hpp" 00020 #include "moab/Interface.hpp" 00021 #include "moab/Range.hpp" 00022 #include "moab/ProcConfig.hpp" 00023 #include <map> 00024 #include <set> 00025 #include <vector> 00026 #include <iostream> 00027 #include <fstream> 00028 #include <cassert> 00029 #include <cstdlib> 00030 #include <cmath> 00031 #include "moab/TupleList.hpp" 00032 00033 namespace moab 00034 { 00035 00036 class SequenceManager; 00037 class Error; 00038 template < typename KeyType, typename ValType, ValType NullVal > 00039 class RangeMap; 00040 typedef RangeMap< EntityHandle, EntityHandle, 0 > HandleMap; 00041 class ParallelMergeMesh; 00042 class DebugOutput; 00043 class SharedSetData; 00044 00045 #define MAX_SHARING_PROCS 64 00046 00047 /** 00048 * \brief Parallel communications in MOAB 00049 * \author Tim Tautges 00050 * 00051 * This class implements methods to communicate mesh between processors 00052 * 00053 */ 00054 class ParallelComm 00055 { 00056 public: 00057 friend class ParallelMergeMesh; 00058 00059 // ================================== 00060 // \section CONSTRUCTORS/DESTRUCTORS/PCOMM MANAGEMENT 00061 // ================================== 00062 00063 //! constructor 00064 ParallelComm( Interface* impl, MPI_Comm comm, int* pcomm_id_out = 0 ); 00065 00066 //! constructor taking packed buffer, for testing 00067 ParallelComm( Interface* impl, std::vector< unsigned char >& tmp_buff, MPI_Comm comm, int* pcomm_id_out = 0 ); 00068 00069 //! Get ID used to reference this PCOMM instance 00070 int get_id() const 00071 { 00072 return pcommID; 00073 } 00074 00075 //! get the indexed pcomm object from the interface 00076 static ParallelComm* get_pcomm( Interface* impl, const int index ); 00077 00078 //! Get ParallelComm instance associated with partition handle 00079 //! Will create ParallelComm instance if a) one does not already 00080 //! exist and b) a valid value for MPI_Comm is passed. 00081 static ParallelComm* get_pcomm( Interface* impl, EntityHandle partitioning, const MPI_Comm* comm = 0 ); 00082 00083 static ErrorCode get_all_pcomm( Interface* impl, std::vector< ParallelComm* >& list ); 00084 00085 //! destructor 00086 ~ParallelComm(); 00087 00088 static unsigned char PROC_SHARED, PROC_OWNER; 00089 00090 // ================================== 00091 // \section GLOBAL IDS 00092 // ================================== 00093 00094 //! assign a global id space, for largest-dimension or all entities (and 00095 //! in either case for vertices too) 00096 //!\param owned_only If true, do not get global IDs for non-owned entities 00097 //! from remote processors. 00098 ErrorCode assign_global_ids( EntityHandle this_set, 00099 const int dimension, 00100 const int start_id = 1, 00101 const bool largest_dim_only = true, 00102 const bool parallel = true, 00103 const bool owned_only = false ); 00104 00105 //! assign a global id space, for largest-dimension or all entities (and 00106 //! in either case for vertices too) 00107 ErrorCode assign_global_ids( Range entities[], 00108 const int dimension, 00109 const int start_id, 00110 const bool parallel, 00111 const bool owned_only ); 00112 00113 //! check for global ids; based only on tag handle being there or not; 00114 //! if it's not there, create them for the specified dimensions 00115 //!\param owned_only If true, do not get global IDs for non-owned entities 00116 //! from remote processors. 00117 ErrorCode check_global_ids( EntityHandle this_set, 00118 const int dimension, 00119 const int start_id = 1, 00120 const bool largest_dim_only = true, 00121 const bool parallel = true, 00122 const bool owned_only = false ); 00123 00124 // ================================== 00125 // \section HIGH-LEVEL COMMUNICATION (send/recv/bcast/scatter ents, exchange tags) 00126 // ================================== 00127 00128 /** \brief send entities to another processor, optionally waiting until it's done 00129 * 00130 * Send entities to another processor, with adjs, sets, and tags. 00131 * If store_remote_handles is true, this call receives back handles assigned to 00132 * entities sent to destination processor and stores them in sharedh_tag or 00133 * sharedhs_tag. 00134 * \param to_proc Destination processor 00135 * \param orig_ents Entities requested to send 00136 * \param adjs If true, send adjacencies for equiv entities (currently unsupported) 00137 * \param tags If true, send tag values for all tags assigned to entities 00138 * \param store_remote_handles If true, also recv message with handles on destination processor 00139 * (currently unsupported) \param final_ents Range containing all entities sent \param incoming 00140 * keep track if any messages are coming to this processor (newly added) \param wait_all If 00141 * true, wait until all messages received/sent complete 00142 */ 00143 ErrorCode send_entities( const int to_proc, 00144 Range& orig_ents, 00145 const bool adjs, 00146 const bool tags, 00147 const bool store_remote_handles, 00148 const bool is_iface, 00149 Range& final_ents, 00150 int& incoming1, 00151 int& incoming2, // newly added 00152 TupleList& entprocs, // newly added 00153 std::vector< MPI_Request >& recv_remoteh_reqs, // newly added 00154 bool wait_all = true ); 00155 00156 ErrorCode send_entities( std::vector< unsigned int >& send_procs, 00157 std::vector< Range* >& send_ents, 00158 int& incoming1, 00159 int& incoming2, 00160 const bool store_remote_handles ); 00161 00162 /** \brief Receive entities from another processor, optionally waiting until it's done 00163 * 00164 * Receive entities from another processor, with adjs, sets, and tags. 00165 * If store_remote_handles is true, this call sends back handles assigned to 00166 * the entities received. 00167 * \param from_proc Source processor 00168 * \param store_remote_handles If true, send message with new entity handles to source processor 00169 * (currently unsupported) \param final_ents Range containing all entities received \param 00170 * incoming keep track if any messages are coming to this processor (newly added) \param 00171 * wait_all If true, wait until all messages received/sent complete 00172 */ 00173 ErrorCode recv_entities( const int from_proc, 00174 const bool store_remote_handles, 00175 const bool is_iface, 00176 Range& final_ents, 00177 int& incomming1, 00178 int& incoming2, 00179 std::vector< std::vector< EntityHandle > >& L1hloc, 00180 std::vector< std::vector< EntityHandle > >& L1hrem, 00181 std::vector< std::vector< int > >& L1p, 00182 std::vector< EntityHandle >& L2hloc, 00183 std::vector< EntityHandle >& L2hrem, 00184 std::vector< unsigned int >& L2p, 00185 std::vector< MPI_Request >& recv_remoteh_reqs, 00186 bool wait_all = true ); 00187 00188 ErrorCode recv_entities( std::set< unsigned int >& recv_procs, 00189 int incoming1, 00190 int incoming2, 00191 const bool store_remote_handles, 00192 const bool migrate = false ); 00193 00194 /** \brief Receive messages from another processor in while loop 00195 * 00196 * Receive messages from another processor. 00197 * \param from_proc Source processor 00198 * \param store_remote_handles If true, send message with new entity handles to source processor 00199 * (currently unsupported) \param final_ents Range containing all entities received \param 00200 * incoming keep track if any messages are coming to this processor (newly added) 00201 */ 00202 ErrorCode recv_messages( const int from_proc, 00203 const bool store_remote_handles, 00204 const bool is_iface, 00205 Range& final_ents, 00206 int& incoming1, 00207 int& incoming2, 00208 std::vector< std::vector< EntityHandle > >& L1hloc, 00209 std::vector< std::vector< EntityHandle > >& L1hrem, 00210 std::vector< std::vector< int > >& L1p, 00211 std::vector< EntityHandle >& L2hloc, 00212 std::vector< EntityHandle >& L2hrem, 00213 std::vector< unsigned int >& L2p, 00214 std::vector< MPI_Request >& recv_remoteh_reqs ); 00215 00216 ErrorCode recv_remote_handle_messages( const int from_proc, 00217 int& incoming2, 00218 std::vector< EntityHandle >& L2hloc, 00219 std::vector< EntityHandle >& L2hrem, 00220 std::vector< unsigned int >& L2p, 00221 std::vector< MPI_Request >& recv_remoteh_reqs ); 00222 00223 /** \brief Exchange ghost cells with neighboring procs 00224 * Neighboring processors are those sharing an interface 00225 * with this processor. All entities of dimension ghost_dim 00226 * within num_layers of interface, measured going through bridge_dim, 00227 * are exchanged. See MeshTopoUtil::get_bridge_adjacencies for description 00228 * of bridge adjacencies. If wait_all is false and store_remote_handles 00229 * is true, MPI_Request objects are available in the sendReqs[2*MAX_SHARING_PROCS] 00230 * member array, with inactive requests marked as MPI_REQUEST_NULL. If 00231 * store_remote_handles or wait_all is false, this function returns after 00232 * all entities have been received and processed. 00233 * \param ghost_dim Dimension of ghost entities to be exchanged 00234 * \param bridge_dim Dimension of entities used to measure layers from interface 00235 * \param num_layers Number of layers of ghosts requested 00236 * \param addl_ents Dimension of additional adjacent entities to exchange with ghosts, 0 if none 00237 * \param store_remote_handles If true, send message with new entity handles to source processor 00238 * \param wait_all If true, function does not return until all send buffers 00239 * are cleared. 00240 */ 00241 00242 ErrorCode exchange_ghost_cells( int ghost_dim, 00243 int bridge_dim, 00244 int num_layers, 00245 int addl_ents, 00246 bool store_remote_handles, 00247 bool wait_all = true, 00248 EntityHandle* file_set = NULL ); 00249 00250 /** \brief Static version of exchange_ghost_cells, exchanging info through 00251 * buffers rather than messages 00252 */ 00253 static ErrorCode exchange_ghost_cells( ParallelComm** pc, 00254 unsigned int num_procs, 00255 int ghost_dim, 00256 int bridge_dim, 00257 int num_layers, 00258 int addl_ents, 00259 bool store_remote_handles, 00260 EntityHandle* file_sets = NULL ); 00261 00262 /** \brief Post "MPI_Irecv" before meshing 00263 * \param exchange_procs processor vector exchanged 00264 */ 00265 ErrorCode post_irecv( std::vector< unsigned int >& exchange_procs ); 00266 00267 ErrorCode post_irecv( std::vector< unsigned int >& shared_procs, std::set< unsigned int >& recv_procs ); 00268 00269 /** \brief Exchange owned mesh for input mesh entities and sets 00270 * This function should be called collectively over the communicator for this ParallelComm. 00271 * If this version is called, all shared exchanged entities should have a value for this 00272 * tag (or the tag should have a default value). 00273 * \param exchange_procs processor vector exchanged 00274 * \param exchange_ents exchanged entities for each processors 00275 * \param migrate if the owner if entities are changed or not 00276 */ 00277 ErrorCode exchange_owned_meshs( std::vector< unsigned int >& exchange_procs, 00278 std::vector< Range* >& exchange_ents, 00279 std::vector< MPI_Request >& recv_ent_reqs, 00280 std::vector< MPI_Request >& recv_remoteh_reqs, 00281 bool store_remote_handles, 00282 bool wait_all = true, 00283 bool migrate = false, 00284 int dim = 0 ); 00285 00286 /** \brief Exchange owned mesh for input mesh entities and sets 00287 * This function is called twice by exchange_owned_meshs to exchange entities before sets 00288 * \param migrate if the owner if entities are changed or not 00289 */ 00290 ErrorCode exchange_owned_mesh( std::vector< unsigned int >& exchange_procs, 00291 std::vector< Range* >& exchange_ents, 00292 std::vector< MPI_Request >& recv_ent_reqs, 00293 std::vector< MPI_Request >& recv_remoteh_reqs, 00294 const bool recv_posted, 00295 bool store_remote_handles, 00296 bool wait_all, 00297 bool migrate = false ); 00298 00299 /** \brief Exchange tags for all shared and ghosted entities 00300 * This function should be called collectively over the communicator for this ParallelComm. 00301 * If this version is called, all ghosted/shared entities should have a value for this 00302 * tag (or the tag should have a default value). If the entities vector is empty, all shared 00303 * entities participate in the exchange. If a proc has no owned entities this function must 00304 * still be called since it is collective. \param src_tags Vector of tag handles to be exchanged 00305 * \param dst_tags Tag handles to store the tags on the non-owning procs 00306 * \param entities Entities for which tags are exchanged 00307 */ 00308 ErrorCode exchange_tags( const std::vector< Tag >& src_tags, 00309 const std::vector< Tag >& dst_tags, 00310 const Range& entities ); 00311 00312 /** \brief Exchange tags for all shared and ghosted entities 00313 * This function should be called collectively over the communicator for this ParallelComm. 00314 * If the entities vector is empty, all shared entities 00315 * participate in the exchange. If a proc has no owned entities this function must still be 00316 * called since it is collective. \param tag_name Name of tag to be exchanged \param entities 00317 * Entities for which tags are exchanged 00318 */ 00319 ErrorCode exchange_tags( const char* tag_name, const Range& entities ); 00320 00321 /** \brief Exchange tags for all shared and ghosted entities 00322 * This function should be called collectively over the communicator for this ParallelComm. 00323 * If the entities vector is empty, all shared entities 00324 * participate in the exchange. If a proc has no owned entities this function must still be 00325 * called since it is collective. \param tagh Handle of tag to be exchanged \param entities 00326 * Entities for which tags are exchanged 00327 */ 00328 ErrorCode exchange_tags( Tag tagh, const Range& entities ); 00329 00330 /** \brief Perform data reduction operation for all shared and ghosted entities 00331 * This function should be called collectively over the communicator for this ParallelComm. 00332 * If this version is called, all ghosted/shared entities should have a value for this 00333 * tag (or the tag should have a default value). Operation is any MPI_Op, with result stored 00334 * in destination tag. 00335 * \param src_tags Vector of tag handles to be reduced 00336 * \param dst_tags Vector of tag handles in which the answer will be stored 00337 * \param mpi_op Operation type 00338 * \param entities Entities on which reduction will be made; if empty, operates on all shared 00339 * entities 00340 */ 00341 ErrorCode reduce_tags( const std::vector< Tag >& src_tags, 00342 const std::vector< Tag >& dst_tags, 00343 const MPI_Op mpi_op, 00344 const Range& entities ); 00345 00346 /** \brief Perform data reduction operation for all shared and ghosted entities 00347 * Same as std::vector variant except for one tag specified by name 00348 * \param tag_name Name of tag to be reduced 00349 * \param mpi_op Operation type 00350 * \param entities Entities on which reduction will be made; if empty, operates on all shared 00351 * entities 00352 */ 00353 ErrorCode reduce_tags( const char* tag_name, const MPI_Op mpi_op, const Range& entities ); 00354 00355 /** \brief Perform data reduction operation for all shared and ghosted entities 00356 * Same as std::vector variant except for one tag specified by handle 00357 * \param tag_name Name of tag to be reduced 00358 * \param mpi_op Operation type 00359 * \param entities Entities on which reduction will be made; if empty, operates on all shared 00360 * entities 00361 */ 00362 ErrorCode reduce_tags( Tag tag_handle, const MPI_Op mpi_op, const Range& entities ); 00363 00364 /** \brief Broadcast all entities resident on from_proc to other processors 00365 * This function assumes remote handles are *not* being stored, since (usually) 00366 * every processor will know about the whole mesh. 00367 * \param from_proc Processor having the mesh to be broadcast 00368 * \param entities On return, the entities sent or received in this call 00369 * \param adjacencies If true, adjacencies are sent for equiv entities (currently unsupported) 00370 * \param tags If true, all non-default-valued tags are sent for sent entities 00371 */ 00372 ErrorCode broadcast_entities( const int from_proc, 00373 Range& entities, 00374 const bool adjacencies = false, 00375 const bool tags = true ); 00376 00377 /** \brief Scatter entities on from_proc to other processors 00378 * This function assumes remote handles are *not* being stored, since (usually) 00379 * every processor will know about the whole mesh. 00380 * \param from_proc Processor having the mesh to be broadcast 00381 * \param entities On return, the entities sent or received in this call 00382 * \param adjacencies If true, adjacencies are sent for equiv entities (currently unsupported) 00383 * \param tags If true, all non-default-valued tags are sent for sent entities 00384 */ 00385 ErrorCode scatter_entities( const int from_proc, 00386 std::vector< Range >& entities, 00387 const bool adjacencies = false, 00388 const bool tags = true ); 00389 00390 ///////////////////////////////////////////////////////////////////////////////// 00391 // Send and Receive routines for a sequence of entities: use case UMR 00392 ///////////////////////////////////////////////////////////////////////////////// 00393 00394 /** \brief Send and receives data from a set of processors 00395 */ 00396 ErrorCode send_recv_entities( std::vector< int >& send_procs, 00397 std::vector< std::vector< int > >& msgsizes, 00398 std::vector< std::vector< EntityHandle > >& senddata, 00399 std::vector< std::vector< EntityHandle > >& recvdata ); 00400 00401 ErrorCode update_remote_data( EntityHandle entity, 00402 std::vector< int >& procs, 00403 std::vector< EntityHandle >& handles ); 00404 00405 ErrorCode get_remote_handles( EntityHandle* local_vec, EntityHandle* rem_vec, int num_ents, int to_proc ); 00406 00407 ///////////////////////////////////////////////////////////////////////////////// 00408 00409 // ================================== 00410 // \section INITIALIZATION OF PARALLEL DATA (resolve_shared_ents, etc.) 00411 // ================================== 00412 00413 /** \brief Resolve shared entities between processors 00414 * 00415 * Resolve shared entities between processors for entities in proc_ents, 00416 * by comparing global id tag values on vertices on skin of elements in 00417 * proc_ents. Shared entities are assigned a tag that's either 00418 * PARALLEL_SHARED_PROC_TAG_NAME, which is 1 integer in length, or 00419 * PARALLEL_SHARED_PROCS_TAG_NAME, whose length depends on the maximum 00420 * number of sharing processors. Values in these tags denote the ranks 00421 * of sharing processors, and the list ends with the value -1. 00422 * 00423 * If shared_dim is input as -1 or not input, a value one less than the 00424 * maximum dimension of entities in proc_ents is used. 00425 * 00426 * \param proc_ents Entities for which to resolve shared entities 00427 * \param shared_dim Maximum dimension of shared entities to look for 00428 */ 00429 ErrorCode resolve_shared_ents( EntityHandle this_set, 00430 Range& proc_ents, 00431 int resolve_dim = -1, 00432 int shared_dim = -1, 00433 Range* skin_ents = NULL, 00434 const Tag* id_tag = 0 ); 00435 00436 /** \brief Resolve shared entities between processors 00437 * 00438 * Same as resolve_shared_ents(Range&), except works for 00439 * all entities in instance of dimension dim. 00440 * 00441 * If shared_dim is input as -1 or not input, a value one less than the 00442 * maximum dimension of entities is used. 00443 00444 * \param dim Dimension of entities in the partition 00445 * \param shared_dim Maximum dimension of shared entities to look for 00446 */ 00447 ErrorCode resolve_shared_ents( EntityHandle this_set, 00448 int resolve_dim = 3, 00449 int shared_dim = -1, 00450 const Tag* id_tag = 0 ); 00451 00452 static ErrorCode resolve_shared_ents( ParallelComm** pc, 00453 const unsigned int np, 00454 EntityHandle this_set, 00455 const int to_dim ); 00456 00457 /** Remove shared sets. 00458 * 00459 * Generates list of candidate sets using from those (directly) 00460 * contained in passed set and passes them to the other version 00461 * of \c resolve_shared_sets. 00462 *\param this_set Set directly containing candidate sets (e.g. file set) 00463 *\param id_tag Tag containing global IDs for entity sets. 00464 */ 00465 00466 ErrorCode resolve_shared_sets( EntityHandle this_set, const Tag* id_tag = 0 ); 00467 00468 /** Remove shared sets. 00469 * 00470 * Use values of id_tag to match sets across processes and populate 00471 * sharing data for sets. 00472 *\param candidate_sets Sets to consider as potentially shared. 00473 *\param id_tag Tag containing global IDs for entity sets. 00474 */ 00475 ErrorCode resolve_shared_sets( Range& candidate_sets, Tag id_tag ); 00476 00477 /** extend shared sets with ghost entities 00478 * After ghosting, ghost entities do not have yet information about 00479 * the material set, partition set, Neumann or Dirichlet set they could 00480 * belong to 00481 * This method will assign ghosted entities to the those special entity sets 00482 * In some case we might even have to create those sets, if they do not exist yet on 00483 * the local processor 00484 * 00485 * The special entity sets all have an unique identifier, in a form of an integer 00486 * tag to the set. 00487 * The shared sets data is not used, because we do not use the geometry sets, as they are 00488 * not uniquely identified 00489 * 00490 * 00491 * \param file_set : file set used per application 00492 * 00493 */ 00494 ErrorCode augment_default_sets_with_ghosts( EntityHandle file_set ); 00495 // ================================== 00496 // \section GET PARALLEL DATA (shared/owned/iface entities, etc.) 00497 // ================================== 00498 00499 /** \brief Get parallel status of an entity 00500 * Returns the parallel status of an entity 00501 * 00502 * \param entity The entity being queried 00503 * \param pstatus_val Parallel status of the entity 00504 */ 00505 ErrorCode get_pstatus( EntityHandle entity, unsigned char& pstatus_val ); 00506 00507 /** \brief Get entities with the given pstatus bit(s) set 00508 * Returns any entities whose pstatus tag value v satisfies (v & pstatus_val) 00509 * 00510 * \param dim Dimension of entities to be returned, or -1 if any 00511 * \param pstatus_val pstatus value of desired entities 00512 * \param pstatus_ents Entities returned from function 00513 */ 00514 ErrorCode get_pstatus_entities( int dim, unsigned char pstatus_val, Range& pstatus_ents ); 00515 00516 /** \brief Return the rank of the entity owner 00517 */ 00518 ErrorCode get_owner( EntityHandle entity, int& owner ); 00519 00520 /** \brief Return the owner processor and handle of a given entity 00521 */ 00522 ErrorCode get_owner_handle( EntityHandle entity, int& owner, EntityHandle& handle ); 00523 00524 /** \brief Get the shared processors/handles for an entity 00525 * Get the shared processors/handles for an entity. Arrays must 00526 * be large enough to receive data for all sharing procs. Does *not* include 00527 * this proc if only shared with one other proc. 00528 * \param entity Entity being queried 00529 * \param ps Pointer to sharing proc data 00530 * \param hs Pointer to shared proc handle data 00531 * \param pstat Reference to pstatus data returned from this function 00532 */ 00533 ErrorCode get_sharing_data( const EntityHandle entity, 00534 int* ps, 00535 EntityHandle* hs, 00536 unsigned char& pstat, 00537 unsigned int& num_ps ); 00538 00539 /** \brief Get the shared processors/handles for an entity 00540 * Same as other version but with int num_ps 00541 * \param entity Entity being queried 00542 * \param ps Pointer to sharing proc data 00543 * \param hs Pointer to shared proc handle data 00544 * \param pstat Reference to pstatus data returned from this function 00545 */ 00546 ErrorCode get_sharing_data( const EntityHandle entity, 00547 int* ps, 00548 EntityHandle* hs, 00549 unsigned char& pstat, 00550 int& num_ps ); 00551 00552 /** \brief Get the intersection or union of all sharing processors 00553 * Get the intersection or union of all sharing processors. Processor set 00554 * is cleared as part of this function. 00555 * \param entities Entity list ptr 00556 * \param num_entities Number of entities 00557 * \param procs Processors returned 00558 * \param op Either Interface::UNION or Interface::INTERSECT 00559 */ 00560 ErrorCode get_sharing_data( const EntityHandle* entities, 00561 int num_entities, 00562 std::set< int >& procs, 00563 int op = Interface::INTERSECT ); 00564 00565 /** \brief Get the intersection or union of all sharing processors 00566 * Same as previous variant but with range as input 00567 */ 00568 ErrorCode get_sharing_data( const Range& entities, std::set< int >& procs, int op = Interface::INTERSECT ); 00569 00570 /** \brief Get shared entities of specified dimension 00571 * If other_proc is -1, any shared entities are returned. If dim is -1, 00572 * entities of all dimensions on interface are returned. 00573 * \param other_proc Rank of processor for which interface entities are requested 00574 * \param shared_ents Entities returned from function 00575 * \param dim Dimension of interface entities requested 00576 * \param iface If true, return only entities on the interface 00577 * \param owned_filter If true, return only owned shared entities 00578 */ 00579 ErrorCode get_shared_entities( int other_proc, 00580 Range& shared_ents, 00581 int dim = -1, 00582 const bool iface = false, 00583 const bool owned_filter = false ); 00584 /* 00585 //! return partition sets; if tag_name is input, gets sets with 00586 //! that tag name, otherwise uses PARALLEL_PARTITION tag 00587 ErrorCode get_partition_sets(EntityHandle this_set, 00588 Range &part_sets, 00589 const char *tag_name = NULL); 00590 */ 00591 //! get processors with which this processor shares an interface 00592 ErrorCode get_interface_procs( std::set< unsigned int >& iface_procs, const bool get_buffs = false ); 00593 00594 //! get processors with which this processor communicates 00595 ErrorCode get_comm_procs( std::set< unsigned int >& procs ); 00596 00597 // ================================== 00598 // \section SHARED SETS 00599 // ================================== 00600 00601 //! Get array of process IDs sharing a set. Returns zero 00602 //! and passes back NULL if set is not shared. 00603 ErrorCode get_entityset_procs( EntityHandle entity_set, std::vector< unsigned >& ranks ) const; 00604 00605 //! Get rank of the owner of a shared set. 00606 //! Returns this proc if set is not shared. 00607 //! Optionally returns handle on owning process for shared set. 00608 ErrorCode get_entityset_owner( EntityHandle entity_set, 00609 unsigned& owner_rank, 00610 EntityHandle* remote_handle = 0 ) const; 00611 00612 //! Given set owner and handle on owner, find local set handle 00613 ErrorCode get_entityset_local_handle( unsigned owning_rank, 00614 EntityHandle remote_handle, 00615 EntityHandle& local_handle ) const; 00616 00617 //! Get all shared sets 00618 ErrorCode get_shared_sets( Range& result ) const; 00619 00620 //! Get ranks of all processes that own at least one set that is 00621 //! shared with this process. Will include the rank of this process 00622 //! if this process owns any shared set. 00623 ErrorCode get_entityset_owners( std::vector< unsigned >& ranks ) const; 00624 00625 //! Get shared sets owned by process with specified rank. 00626 ErrorCode get_owned_sets( unsigned owning_rank, Range& sets_out ) const; 00627 00628 // ================================== 00629 // \section LOW-LEVEL DATA (tags, sets on interface/partition, etc.) 00630 // ================================== 00631 00632 //! Get proc config for this communication object 00633 const ProcConfig& proc_config() const 00634 { 00635 return procConfig; 00636 } 00637 00638 //! Get proc config for this communication object 00639 ProcConfig& proc_config() 00640 { 00641 return procConfig; 00642 } 00643 00644 unsigned rank() const 00645 { 00646 return proc_config().proc_rank(); 00647 } 00648 unsigned size() const 00649 { 00650 return proc_config().proc_size(); 00651 } 00652 MPI_Comm comm() const 00653 { 00654 return proc_config().proc_comm(); 00655 } 00656 00657 //! return the tags used to indicate shared procs and handles 00658 ErrorCode get_shared_proc_tags( Tag& sharedp_tag, 00659 Tag& sharedps_tag, 00660 Tag& sharedh_tag, 00661 Tag& sharedhs_tag, 00662 Tag& pstatus_tag ); 00663 00664 //! return partition, interface set ranges 00665 Range& partition_sets() 00666 { 00667 return partitionSets; 00668 } 00669 const Range& partition_sets() const 00670 { 00671 return partitionSets; 00672 } 00673 Range& interface_sets() 00674 { 00675 return interfaceSets; 00676 } 00677 const Range& interface_sets() const 00678 { 00679 return interfaceSets; 00680 } 00681 00682 //! return sharedp tag 00683 Tag sharedp_tag(); 00684 00685 //! return sharedps tag 00686 Tag sharedps_tag(); 00687 00688 //! return sharedh tag 00689 Tag sharedh_tag(); 00690 00691 //! return sharedhs tag 00692 Tag sharedhs_tag(); 00693 00694 //! return pstatus tag 00695 Tag pstatus_tag(); 00696 00697 //! return pcomm tag; static because might not have a pcomm before going 00698 //! to look for one on the interface 00699 static Tag pcomm_tag( Interface* impl, bool create_if_missing = true ); 00700 00701 //! return partitions set tag 00702 Tag partition_tag(); 00703 Tag part_tag() 00704 { 00705 return partition_tag(); 00706 } 00707 00708 // ================================== 00709 // \section DEBUGGING AIDS 00710 // ================================== 00711 00712 //! print contents of pstatus value in human-readable form 00713 void print_pstatus( unsigned char pstat, std::string& ostr ); 00714 00715 //! print contents of pstatus value in human-readable form to std::cut 00716 void print_pstatus( unsigned char pstat ); 00717 00718 // ================================== 00719 // \section IMESHP-RELATED FUNCTIONS 00720 // ================================== 00721 00722 //! return all the entities in parts owned locally 00723 ErrorCode get_part_entities( Range& ents, int dim = -1 ); 00724 00725 EntityHandle get_partitioning() const 00726 { 00727 return partitioningSet; 00728 } 00729 ErrorCode set_partitioning( EntityHandle h ); 00730 ErrorCode get_global_part_count( int& count_out ) const; 00731 ErrorCode get_part_owner( int part_id, int& owner_out ) const; 00732 ErrorCode get_part_id( EntityHandle part, int& id_out ) const; 00733 ErrorCode get_part_handle( int id, EntityHandle& handle_out ) const; 00734 ErrorCode create_part( EntityHandle& part_out ); 00735 ErrorCode destroy_part( EntityHandle part ); 00736 ErrorCode collective_sync_partition(); 00737 ErrorCode get_part_neighbor_ids( EntityHandle part, int neighbors_out[MAX_SHARING_PROCS], int& num_neighbors_out ); 00738 ErrorCode get_interface_sets( EntityHandle part, Range& iface_sets_out, int* adj_part_id = 0 ); 00739 ErrorCode get_owning_part( EntityHandle entity, int& owning_part_id_out, EntityHandle* owning_handle = 0 ); 00740 ErrorCode get_sharing_parts( EntityHandle entity, 00741 int part_ids_out[MAX_SHARING_PROCS], 00742 int& num_part_ids_out, 00743 EntityHandle remote_handles[MAX_SHARING_PROCS] = 0 ); 00744 00745 /** Filter the entities by pstatus tag. 00746 * op is one of PSTATUS_ AND, OR, NOT; an entity is output if: 00747 * AND: all bits set in pstatus_val are also set on entity 00748 * OR: any bits set in pstatus_val also set on entity 00749 * NOT: any bits set in pstatus_val are not set on entity 00750 * 00751 * Results returned in input list, unless result_ents is passed in non-null, 00752 * in which case results are returned in result_ents. 00753 * 00754 * If ents is passed in empty, filter is done on shared entities in this 00755 * pcomm instance, i.e. contents of sharedEnts. 00756 * 00757 *\param ents Input entities to filter 00758 *\param pstatus_val pstatus value to which entities are compared 00759 *\param op Bitwise operation performed between pstatus values 00760 *\param to_proc If non-negative and PSTATUS_SHARED is set on pstatus_val, 00761 * only entities shared with to_proc are returned 00762 *\param result_ents If non-null, results of filter are put in the 00763 * pointed-to range 00764 */ 00765 ErrorCode filter_pstatus( Range& ents, 00766 const unsigned char pstatus_val, 00767 const unsigned char op, 00768 int to_proc = -1, 00769 Range* returned_ents = NULL ); 00770 00771 /** \brief Get entities on interfaces shared with another proc 00772 * 00773 * \param other_proc Other proc sharing the interface 00774 * \param dim Dimension of entities to return, -1 if all dims 00775 * \param iface_ents Returned entities 00776 */ 00777 ErrorCode get_iface_entities( int other_proc, int dim, Range& iface_ents ); 00778 00779 Interface* get_moab() const 00780 { 00781 return mbImpl; 00782 } 00783 00784 ErrorCode clean_shared_tags( std::vector< Range* >& exchange_ents ); 00785 00786 class Buffer 00787 { 00788 public: 00789 unsigned char* mem_ptr; 00790 unsigned char* buff_ptr; 00791 unsigned int alloc_size; 00792 00793 Buffer( unsigned int sz = 0 ); 00794 Buffer( const Buffer& ); 00795 ~Buffer(); 00796 void reset_buffer( size_t buff_pos = 0 ) 00797 { 00798 reset_ptr( buff_pos ); 00799 reserve( INITIAL_BUFF_SIZE ); 00800 } 00801 void reset_ptr( size_t buff_pos = 0 ) 00802 { 00803 assert( ( !mem_ptr && !buff_pos ) || ( alloc_size >= buff_pos ) ); 00804 buff_ptr = mem_ptr + buff_pos; 00805 } 00806 inline void reserve( unsigned int new_size ); 00807 void set_stored_size() 00808 { 00809 *( (int*)mem_ptr ) = (int)( buff_ptr - mem_ptr ); 00810 } 00811 int get_stored_size() 00812 { 00813 return *( (int*)mem_ptr ); 00814 } 00815 int get_current_size() 00816 { 00817 return (int)( buff_ptr - mem_ptr ); 00818 } 00819 00820 void check_space( unsigned int addl_space ); 00821 }; 00822 00823 //! public 'cuz we want to unit test these externally 00824 ErrorCode pack_buffer( Range& orig_ents, 00825 const bool adjacencies, 00826 const bool tags, 00827 const bool store_remote_handles, 00828 const int to_proc, 00829 Buffer* buff, 00830 TupleList* entprocs = NULL, 00831 Range* allsent = NULL ); 00832 00833 ErrorCode unpack_buffer( unsigned char* buff_ptr, 00834 const bool store_remote_handles, 00835 const int from_proc, 00836 const int ind, 00837 std::vector< std::vector< EntityHandle > >& L1hloc, 00838 std::vector< std::vector< EntityHandle > >& L1hrem, 00839 std::vector< std::vector< int > >& L1p, 00840 std::vector< EntityHandle >& L2hloc, 00841 std::vector< EntityHandle >& L2hrem, 00842 std::vector< unsigned int >& L2p, 00843 std::vector< EntityHandle >& new_ents, 00844 const bool created_iface = false ); 00845 00846 ErrorCode pack_entities( Range& entities, 00847 Buffer* buff, 00848 const bool store_remote_handles, 00849 const int to_proc, 00850 const bool is_iface, 00851 TupleList* entprocs = NULL, 00852 Range* allsent = NULL ); 00853 00854 //! unpack entities in buff_ptr 00855 ErrorCode unpack_entities( unsigned char*& buff_ptr, 00856 const bool store_remote_handles, 00857 const int from_ind, 00858 const bool is_iface, 00859 std::vector< std::vector< EntityHandle > >& L1hloc, 00860 std::vector< std::vector< EntityHandle > >& L1hrem, 00861 std::vector< std::vector< int > >& L1p, 00862 std::vector< EntityHandle >& L2hloc, 00863 std::vector< EntityHandle >& L2hrem, 00864 std::vector< unsigned int >& L2p, 00865 std::vector< EntityHandle >& new_ents, 00866 const bool created_iface = false ); 00867 00868 //! Call exchange_all_shared_handles, then compare the results with tag data 00869 //! on local shared entities. 00870 ErrorCode check_all_shared_handles( bool print_em = false ); 00871 00872 static ErrorCode check_all_shared_handles( ParallelComm** pcs, int num_pcs ); 00873 00874 struct SharedEntityData 00875 { 00876 EntityHandle local; 00877 EntityHandle remote; 00878 EntityID owner; 00879 }; 00880 00881 ErrorCode pack_shared_handles( std::vector< std::vector< SharedEntityData > >& send_data ); 00882 00883 // check consistency of sharedEnts against their tags and their 00884 // vertices' tags 00885 ErrorCode check_local_shared(); 00886 00887 // check contents of communicated shared entity data against tags 00888 ErrorCode check_my_shared_handles( std::vector< std::vector< SharedEntityData > >& shents, 00889 const char* prefix = NULL ); 00890 00891 //! set rank for this pcomm; USED FOR TESTING ONLY! 00892 void set_rank( unsigned int r ); 00893 00894 //! set rank for this pcomm; USED FOR TESTING ONLY! 00895 void set_size( unsigned int r ); 00896 00897 //! get (and possibly allocate) buffers for messages to/from to_proc; returns 00898 //! index of to_proc in buffProcs vector; if is_new is non-NULL, sets to 00899 //! whether new buffer was allocated 00900 //! PUBLIC ONLY FOR TESTING! 00901 int get_buffers( int to_proc, bool* is_new = NULL ); 00902 00903 //! get buff processor vector 00904 const std::vector< unsigned int >& buff_procs() const; 00905 00906 /* \brief Unpack message with remote handles 00907 * PUBLIC ONLY FOR TESTING! 00908 */ 00909 ErrorCode unpack_remote_handles( unsigned int from_proc, 00910 unsigned char*& buff_ptr, 00911 std::vector< EntityHandle >& L2hloc, 00912 std::vector< EntityHandle >& L2hrem, 00913 std::vector< unsigned int >& L2p ); 00914 00915 /* \brief Pack message with remote handles 00916 * PUBLIC ONLY FOR TESTING! 00917 */ 00918 ErrorCode pack_remote_handles( std::vector< EntityHandle >& L1hloc, 00919 std::vector< EntityHandle >& L1hrem, 00920 std::vector< int >& procs, 00921 unsigned int to_proc, 00922 Buffer* buff ); 00923 00924 // each iterate in proc_nvecs contains a set of procs and the entities *possibly* 00925 // on the interface between those procs; this function makes sets for each, 00926 // and tags the set with the procs sharing it; interface sets are optionally 00927 // returned; NOTE: a subsequent step is used to verify entities on the interface 00928 // and remove them if they're not shared 00929 ErrorCode create_interface_sets( std::map< std::vector< int >, std::vector< EntityHandle > >& proc_nvecs ); 00930 00931 // do the same but working straight from sharedEnts 00932 ErrorCode create_interface_sets( EntityHandle this_set, int resolve_dim, int shared_dim ); 00933 00934 ErrorCode tag_shared_verts( TupleList& shared_ents, 00935 std::map< std::vector< int >, std::vector< EntityHandle > >& proc_nvecs, 00936 Range& proc_verts, 00937 unsigned int i_extra = 1 ); 00938 00939 ErrorCode list_entities( const EntityHandle* ents, int num_ents ); 00940 00941 ErrorCode list_entities( const Range& ents ); 00942 00943 void set_send_request( int n_request ); // set send request array 00944 00945 void set_recv_request( int n_request ); // set recv request array 00946 00947 //! reset message buffers to their initial state 00948 // changed to public function (HJK) 00949 void reset_all_buffers(); 00950 00951 static const unsigned int INITIAL_BUFF_SIZE; 00952 00953 //! set the verbosity level of output from this pcomm 00954 void set_debug_verbosity( int verb ); 00955 00956 //! get the verbosity level of output from this pcomm 00957 int get_debug_verbosity(); 00958 00959 /* \brief Gather tag value from entities down to a specified root proc 00960 * This function gathers data from a domain-decomposed mesh onto a global mesh 00961 * represented on the root processor. On the root, this gather mesh is distinct from 00962 * the root's domain-decomposed subdomain. Entities are matched by global id, or by 00963 * another tag if its handle is input. The dimension of all entities in gather_ents should 00964 * be the same, since this is the dimension of entities in gather_set that are queried for 00965 * matching global id tags. 00966 * \param gather_ents (Local) entities from which to gather data 00967 * \param tag_handle Tag whose values are being gathered 00968 * \param id_tag Tag to use for matching entities (global id used by default) 00969 * \param gather_set On root, set containing global mesh onto which to put data 00970 * \param root_proc_rank Rank of the specified root processor (default rank is 0) 00971 */ 00972 ErrorCode gather_data( Range& gather_ents, 00973 Tag& tag_handle, 00974 Tag id_tag = 0, 00975 EntityHandle gather_set = 0, 00976 int root_proc_rank = 0 ); 00977 00978 /* \brief communicate extra points positions on boundary 00979 * This function is called after intersection of 2 meshes, to settle the 00980 * position of the intersection points on the boundary (interface) 00981 * The initial mesh distributed on each processor is decomposed after 00982 * intersection with another mesh, such as that new points are created on the 00983 * boundary. these points should better match at the interface ! 00984 * we perform an extra caution step, to ensure the robustness of the 00985 * intersection algorithm; only shared edges extra nodes 00986 * will be actually needed to be communicated, but we just pass by reference 00987 * the whole extraNodesVec structure, we do 00988 * not need to construct another data structure 00989 * The node positions on edges that are owned will be communicated to other 00990 * processors 00991 * 00992 * \param edges total range of entities 00993 * \param shared_edges_owned edges for which to communicate data 00994 * \param extraNodesVec handles of intersection vertices on all edges; 00995 */ 00996 ErrorCode settle_intersection_points( Range& edges, 00997 Range& shared_edges_owned, 00998 std::vector< std::vector< EntityHandle >* >& extraNodesVec, 00999 double tolerance ); 01000 01001 /* \brief delete entities from moab database 01002 * will check the shared ents array, and clean it if necessary 01003 * 01004 */ 01005 ErrorCode delete_entities( Range& to_delete ); 01006 01007 /* 01008 * \brief correct multi-sharing info for thin layers 01009 * 01010 * will be used for at least 3 processes, when there are thin ghost layers 01011 * right now it is public, for allowing users to call it directly 01012 * eventually, it should become private, and be called automatically 01013 */ 01014 01015 ErrorCode correct_thin_ghost_layers(); 01016 01017 private: 01018 ErrorCode reduce_void( int tag_data_type, const MPI_Op mpi_op, int num_ents, void* old_vals, void* new_vals ); 01019 01020 template < class T > 01021 ErrorCode reduce( const MPI_Op mpi_op, int num_ents, void* old_vals, void* new_vals ); 01022 01023 void print_debug_isend( int from, int to, unsigned char* buff, int tag, int size ); 01024 01025 void print_debug_irecv( int to, int from, unsigned char* buff, int size, int tag, int incoming ); 01026 01027 void print_debug_recd( MPI_Status status ); 01028 01029 void print_debug_waitany( std::vector< MPI_Request >& reqs, int tag, int proc ); 01030 01031 // common initialization code, called from various constructors 01032 void initialize(); 01033 01034 ErrorCode set_sharing_data( EntityHandle ent, 01035 unsigned char pstatus, 01036 int old_nump, 01037 int new_nump, 01038 int* ps, 01039 EntityHandle* hs ); 01040 01041 ErrorCode check_clean_iface( Range& allsent ); 01042 01043 void define_mpe(); 01044 01045 ErrorCode get_sent_ents( const bool is_iface, 01046 const int bridge_dim, 01047 const int ghost_dim, 01048 const int num_layers, 01049 const int addl_ents, 01050 Range* sent_ents, 01051 Range& allsent, 01052 TupleList& entprocs ); 01053 01054 /** \brief Set pstatus values on entities 01055 * 01056 * \param pstatus_ents Entities to be set 01057 * \param pstatus_val Pstatus value to be set 01058 * \param lower_dim_ents If true, lower-dimensional ents (incl. vertices) set too 01059 * (and created if they don't exist) 01060 * \param verts_too If true, vertices also set 01061 * \param operation If UNION, pstatus_val is OR-d with existing value, otherwise 01062 * existing value is over-written 01063 */ 01064 ErrorCode set_pstatus_entities( Range& pstatus_ents, 01065 unsigned char pstatus_val, 01066 bool lower_dim_ents = false, 01067 bool verts_too = true, 01068 int operation = Interface::UNION ); 01069 01070 /** \brief Set pstatus values on entities (vector-based function) 01071 * 01072 * \param pstatus_ents Entities to be set 01073 * \param pstatus_val Pstatus value to be set 01074 * \param lower_dim_ents If true, lower-dimensional ents (incl. vertices) set too 01075 * (and created if they don't exist) 01076 * \param verts_too If true, vertices also set 01077 * \param operation If UNION, pstatus_val is OR-d with existing value, otherwise 01078 * existing value is over-written 01079 */ 01080 ErrorCode set_pstatus_entities( EntityHandle* pstatus_ents, 01081 int num_ents, 01082 unsigned char pstatus_val, 01083 bool lower_dim_ents = false, 01084 bool verts_too = true, 01085 int operation = Interface::UNION ); 01086 01087 //! estimate size required to pack entities 01088 int estimate_ents_buffer_size( Range& entities, const bool store_remote_handles ); 01089 01090 //! estimate size required to pack sets 01091 int estimate_sets_buffer_size( Range& entities, const bool store_remote_handles ); 01092 01093 //! send the indicated buffer, possibly sending size first 01094 ErrorCode send_buffer( const unsigned int to_proc, 01095 Buffer* send_buff, 01096 const int msg_tag, 01097 MPI_Request& send_req, 01098 MPI_Request& ack_recv_req, 01099 int* ack_buff, 01100 int& this_incoming, 01101 int next_mesg_tag = -1, 01102 Buffer* next_recv_buff = NULL, 01103 MPI_Request* next_recv_req = NULL, 01104 int* next_incoming = NULL ); 01105 01106 //! process incoming message; if longer than the initial size, post 01107 //! recv for next part then send ack; if ack, send second part; else 01108 //! indicate that we're done and buffer is ready for processing 01109 ErrorCode recv_buffer( int mesg_tag_expected, 01110 const MPI_Status& mpi_status, 01111 Buffer* recv_buff, 01112 MPI_Request& recv_2nd_req, 01113 MPI_Request& ack_req, 01114 int& this_incoming, 01115 Buffer* send_buff, 01116 MPI_Request& send_req, 01117 MPI_Request& sent_ack_req, 01118 bool& done, 01119 Buffer* next_buff = NULL, 01120 int next_tag = -1, 01121 MPI_Request* next_req = NULL, 01122 int* next_incoming = NULL ); 01123 01124 //! pack a range of entities with equal # verts per entity, along with 01125 //! the range on the sending proc 01126 ErrorCode pack_entity_seq( const int nodes_per_entity, 01127 const bool store_remote_handles, 01128 const int to_proc, 01129 Range& these_ents, 01130 std::vector< EntityHandle >& entities, 01131 Buffer* buff ); 01132 01133 ErrorCode print_buffer( unsigned char* buff_ptr, int mesg_type, int from_proc, bool sent ); 01134 01135 //! for all the entities in the received buffer; for each, save 01136 //! entities in this instance which match connectivity, or zero if none found 01137 ErrorCode unpack_iface_entities( unsigned char*& buff_ptr, 01138 const int from_proc, 01139 const int ind, 01140 std::vector< EntityHandle >& recd_ents ); 01141 01142 ErrorCode pack_sets( Range& entities, Buffer* buff, const bool store_handles, const int to_proc ); 01143 01144 ErrorCode unpack_sets( unsigned char*& buff_ptr, 01145 std::vector< EntityHandle >& entities, 01146 const bool store_handles, 01147 const int to_proc ); 01148 01149 ErrorCode pack_adjacencies( Range& entities, 01150 Range::const_iterator& start_rit, 01151 Range& whole_range, 01152 unsigned char*& buff_ptr, 01153 int& count, 01154 const bool just_count, 01155 const bool store_handles, 01156 const int to_proc ); 01157 01158 ErrorCode unpack_adjacencies( unsigned char*& buff_ptr, 01159 Range& entities, 01160 const bool store_handles, 01161 const int from_proc ); 01162 01163 /* \brief Unpack message with remote handles (const pointer to buffer) 01164 */ 01165 ErrorCode unpack_remote_handles( unsigned int from_proc, 01166 const unsigned char* buff_ptr, 01167 std::vector< EntityHandle >& L2hloc, 01168 std::vector< EntityHandle >& L2hrem, 01169 std::vector< unsigned int >& L2p ); 01170 01171 //! given connectivity and type, find an existing entity, if there is one 01172 ErrorCode find_existing_entity( const bool is_iface, 01173 const int owner_p, 01174 const EntityHandle owner_h, 01175 const int num_ents, 01176 const EntityHandle* connect, 01177 const int num_connect, 01178 const EntityType this_type, 01179 std::vector< EntityHandle >& L2hloc, 01180 std::vector< EntityHandle >& L2hrem, 01181 std::vector< unsigned int >& L2p, 01182 EntityHandle& new_h ); 01183 01184 ErrorCode build_sharedhps_list( const EntityHandle entity, 01185 const unsigned char pstatus, 01186 const int sharedp, 01187 const std::set< unsigned int >& procs, 01188 unsigned int& num_ents, 01189 int* tmp_procs, 01190 EntityHandle* tmp_handles ); 01191 01192 /**\brief Get list of tags for which to exchange data 01193 * 01194 * Get tags and entities for which to exchange tag data. This function 01195 * was originally part of 'pack_tags' requested with the 01196 * 'all_possible_tags' parameter. 01197 * 01198 *\param all_entities Input. The set of entities for which data is to 01199 * be communicated. 01200 *\param all_tags Output. Populated with the handles of tags to be 01201 * sent. 01202 *\param tag_ranges Output. For each corresponding tag in all_tags, the 01203 * subset of 'all_entities' for which a tag value has 01204 * been set. 01205 */ 01206 ErrorCode get_tag_send_list( const Range& all_entities, 01207 std::vector< Tag >& all_tags, 01208 std::vector< Range >& tag_ranges ); 01209 01210 /**\brief Serialize entity tag data 01211 * 01212 * This function operates in two passes. The first phase, 01213 * specified by 'just_count == true' calculates the necessary 01214 * buffer size for the serialized data. The second phase 01215 * writes the actual binary serialized representation of the 01216 * data to the passed buffer. 01217 * 01218 *\NOTE First two arguments are not used. (Legacy interface?) 01219 * 01220 *\param entities NOT USED 01221 *\param start_rit NOT USED 01222 *\param whole_range Should be the union of the sets of entities for 01223 * which tag values are to be serialized. Also 01224 * specifies ordering for indexes for tag values and 01225 * serves as the superset from which to compose entity 01226 * lists from individual tags if just_count and 01227 * all_possible_tags are both true. 01228 *\param buff_ptr Buffer into which to write binary serialized data 01229 *\param count Output: The size of the serialized data is added 01230 * to this parameter. NOTE: Should probably initialize 01231 * to zero before calling. 01232 *\param just_count If true, just calculate the buffer size required to 01233 * hold the serialized data. Will also append to 01234 * 'all_tags' and 'tag_ranges' if all_possible_tags 01235 * == true. 01236 *\param store_handles The data for each tag is preceded by a list of 01237 * EntityHandles designating the entity each of 01238 * the subsequent tag values corresponds to. This value 01239 * may be one of: 01240 * 1) If store_handles == false: 01241 * An invalid handle composed of {MBMAXTYPE,idx}, where 01242 * idx is the position of the entity in "whole_range". 01243 * 2) If store_hanldes == true and a valid remote 01244 * handle exists, the remote handle. 01245 * 3) If store_hanldes == true and no valid remote 01246 * handle is defined for the entity, the same as 1). 01247 *\param to_proc If 'store_handles' is true, the processor rank for 01248 * which to store the corresponding remote entity 01249 * handles. 01250 *\param all_tags List of tags to write 01251 *\param tag_ranges List of entities to serialize tag data, one 01252 * for each corresponding tag handle in 'all_tags. 01253 */ 01254 ErrorCode pack_tags( Range& entities, 01255 const std::vector< Tag >& src_tags, 01256 const std::vector< Tag >& dst_tags, 01257 const std::vector< Range >& tag_ranges, 01258 Buffer* buff, 01259 const bool store_handles, 01260 const int to_proc ); 01261 01262 /**\brief Calculate buffer size required to pack tag data 01263 *\param source_tag The tag for which data will be serialized 01264 *\param entities The entities for which tag values will be serialized 01265 *\param count_out Output: The required buffer size, in bytes. 01266 */ 01267 ErrorCode packed_tag_size( Tag source_tag, const Range& entities, int& count_out ); 01268 01269 /**\brief Serialize tag data 01270 *\param source_tag The tag for which data will be serialized 01271 *\param destination_tag Tag in which to store unpacked tag data. Typically 01272 * the same as source_tag. 01273 *\param entities The entities for which tag values will be serialized 01274 *\param whole_range Calculate entity indices as location in this range 01275 *\param buff_ptr Input/Output: As input, pointer to the start of the 01276 * buffer in which to serialize data. As output, the 01277 * position just passed the serialized data. 01278 *\param count_out Output: The required buffer size, in bytes. 01279 *\param store_handles The data for each tag is preceded by a list of 01280 * EntityHandles designating the entity each of 01281 * the subsequent tag values corresponds to. This value 01282 * may be one of: 01283 * 1) If store_handles == false: 01284 * An invalid handle composed of {MBMAXTYPE,idx}, where 01285 * idx is the position of the entity in "whole_range". 01286 * 2) If store_hanldes == true and a valid remote 01287 * handle exists, the remote handle. 01288 * 3) If store_hanldes == true and no valid remote 01289 * handle is defined for the entity, the same as 1). 01290 *\param to_proc If 'store_handles' is true, the processor rank for 01291 * which to store the corresponding remote entity 01292 * handles. 01293 */ 01294 ErrorCode pack_tag( Tag source_tag, 01295 Tag destination_tag, 01296 const Range& entities, 01297 const std::vector< EntityHandle >& whole_range, 01298 Buffer* buff, 01299 const bool store_remote_handles, 01300 const int to_proc ); 01301 01302 ErrorCode unpack_tags( unsigned char*& buff_ptr, 01303 std::vector< EntityHandle >& entities, 01304 const bool store_handles, 01305 const int to_proc, 01306 const MPI_Op* const mpi_op = NULL ); 01307 01308 ErrorCode tag_shared_verts( TupleList& shared_verts, 01309 Range* skin_ents, 01310 std::map< std::vector< int >, std::vector< EntityHandle > >& proc_nvecs, 01311 Range& proc_verts ); 01312 01313 ErrorCode get_proc_nvecs( int resolve_dim, 01314 int shared_dim, 01315 Range* skin_ents, 01316 std::map< std::vector< int >, std::vector< EntityHandle > >& proc_nvecs ); 01317 01318 // after verifying shared entities, now parent/child links between sets can be established 01319 ErrorCode create_iface_pc_links(); 01320 01321 //! pack a range map with keys in this_range and values a contiguous series 01322 //! of handles starting at actual_start 01323 ErrorCode pack_range_map( Range& this_range, EntityHandle actual_start, HandleMap& handle_map ); 01324 01325 //! returns true if the set is an interface shared with to_proc 01326 bool is_iface_proc( EntityHandle this_set, int to_proc ); 01327 01328 //! for any remote_handles set to zero, remove corresponding sent_ents from 01329 //! iface_sets corresponding to from_proc 01330 ErrorCode update_iface_sets( Range& sent_ents, std::vector< EntityHandle >& remote_handles, int from_proc ); 01331 01332 //! for specified bridge/ghost dimension, to_proc, and number 01333 //! of layers, get the entities to be ghosted, and info on additional procs 01334 //! needing to communicate with to_proc 01335 ErrorCode get_ghosted_entities( int bridge_dim, 01336 int ghost_dim, 01337 int to_proc, 01338 int num_layers, 01339 int addl_ents, 01340 Range& ghosted_ents ); 01341 01342 //! add vertices adjacent to entities in this list 01343 ErrorCode add_verts( Range& sent_ents ); 01344 01345 //! Every processor sends shared entity handle data to every other processor 01346 //! that it shares entities with. Passed back map is all received data, 01347 //! indexed by processor ID. This function is intended to be used for 01348 //! debugging. 01349 ErrorCode exchange_all_shared_handles( std::vector< std::vector< SharedEntityData > >& send_data, 01350 std::vector< std::vector< SharedEntityData > >& result ); 01351 01352 //! replace handles in from_vec with corresponding handles on 01353 //! to_proc (by checking shared[p/h]_tag and shared[p/h]s_tag; 01354 //! if no remote handle and new_ents is non-null, substitute 01355 //! instead CREATE_HANDLE(MBMAXTYPE, index) where index is handle's 01356 //! position in new_ents 01357 ErrorCode get_remote_handles( const bool store_remote_handles, 01358 EntityHandle* from_vec, 01359 EntityHandle* to_vec_tmp, 01360 int num_ents, 01361 int to_proc, 01362 const std::vector< EntityHandle >& new_ents ); 01363 01364 //! same as other version, except from_range and to_range should be 01365 //! different here 01366 ErrorCode get_remote_handles( const bool store_remote_handles, 01367 const Range& from_range, 01368 Range& to_range, 01369 int to_proc, 01370 const std::vector< EntityHandle >& new_ents ); 01371 01372 //! same as other version, except packs range into vector 01373 ErrorCode get_remote_handles( const bool store_remote_handles, 01374 const Range& from_range, 01375 EntityHandle* to_vec, 01376 int to_proc, 01377 const std::vector< EntityHandle >& new_ents ); 01378 01379 //! goes through from_vec, and for any with type MBMAXTYPE, replaces with 01380 //! new_ents value at index corresponding to id of entity in from_vec 01381 ErrorCode get_local_handles( EntityHandle* from_vec, int num_ents, const Range& new_ents ); 01382 01383 //! same as above except puts results in range 01384 ErrorCode get_local_handles( const Range& remote_handles, 01385 Range& local_handles, 01386 const std::vector< EntityHandle >& new_ents ); 01387 01388 //! same as above except gets new_ents from vector 01389 ErrorCode get_local_handles( EntityHandle* from_vec, int num_ents, const std::vector< EntityHandle >& new_ents ); 01390 01391 ErrorCode update_remote_data( Range& local_range, 01392 Range& remote_range, 01393 int other_proc, 01394 const unsigned char add_pstat ); 01395 01396 ErrorCode update_remote_data( const EntityHandle new_h, 01397 const int* ps, 01398 const EntityHandle* hs, 01399 const int num_ps, 01400 const unsigned char add_pstat ); 01401 01402 ErrorCode update_remote_data_old( const EntityHandle new_h, 01403 const int* ps, 01404 const EntityHandle* hs, 01405 const int num_ps, 01406 const unsigned char add_pstat ); 01407 01408 /** \brief Set pstatus tag interface bit on entities in sets passed in 01409 */ 01410 ErrorCode tag_iface_entities(); 01411 01412 //! add a pc to the iface instance tag PARALLEL_COMM 01413 int add_pcomm( ParallelComm* pc ); 01414 01415 //! remove a pc from the iface instance tag PARALLEL_COMM 01416 void remove_pcomm( ParallelComm* pc ); 01417 01418 //! check entities to make sure there are no zero-valued remote handles 01419 //! where they shouldn't be 01420 ErrorCode check_sent_ents( Range& allsent ); 01421 01422 //! assign entities to the input processor part 01423 ErrorCode assign_entities_part( std::vector< EntityHandle >& entities, const int proc ); 01424 01425 //! remove entities to the input processor part 01426 ErrorCode remove_entities_part( Range& entities, const int proc ); 01427 01428 //! MB interface associated with this writer 01429 Interface* mbImpl; 01430 01431 //! Proc config object, keeps info on parallel stuff 01432 ProcConfig procConfig; 01433 01434 //! Sequence manager, to get more efficient access to entities 01435 SequenceManager* sequenceManager; 01436 01437 //! Error handler 01438 Error* errorHandler; 01439 01440 //! more data buffers, proc-specific 01441 std::vector< Buffer* > localOwnedBuffs, remoteOwnedBuffs; 01442 01443 //! reset message buffers to their initial state 01444 // void reset_all_buffers(); 01445 01446 //! delete all buffers, freeing up any memory held by them 01447 void delete_all_buffers(); 01448 01449 //! request objects, may be used if store_remote_handles is used 01450 std::vector< MPI_Request > sendReqs; 01451 01452 //! receive request objects 01453 std::vector< MPI_Request > recvReqs, recvRemotehReqs; 01454 01455 //! processor rank for each buffer index 01456 std::vector< unsigned int > buffProcs; 01457 01458 //! the partition, interface sets for this comm'n instance 01459 Range partitionSets, interfaceSets; 01460 01461 //! all local entities shared with others, whether ghost or ghosted 01462 std::set< EntityHandle > sharedEnts; 01463 01464 //! tags used to save sharing procs and handles 01465 Tag sharedpTag, sharedpsTag, sharedhTag, sharedhsTag, pstatusTag, ifaceSetsTag, partitionTag; 01466 01467 int globalPartCount; //!< Cache of global part count 01468 01469 EntityHandle partitioningSet; //!< entity set containing all parts 01470 01471 std::ofstream myFile; 01472 01473 int pcommID; 01474 01475 int ackbuff; 01476 01477 //! used to set verbosity level and to report output 01478 DebugOutput* myDebug; 01479 01480 //! Data about shared sets 01481 SharedSetData* sharedSetData; 01482 }; 01483 01484 inline ParallelComm::Buffer::Buffer( const Buffer& other_buff ) 01485 { 01486 alloc_size = other_buff.alloc_size; 01487 mem_ptr = (unsigned char*)malloc( alloc_size ); 01488 memcpy( mem_ptr, other_buff.mem_ptr, alloc_size ); 01489 buff_ptr = mem_ptr + ( other_buff.buff_ptr - other_buff.mem_ptr ); 01490 } 01491 01492 inline ParallelComm::Buffer::Buffer( unsigned int new_size ) : mem_ptr( NULL ), buff_ptr( NULL ), alloc_size( 0 ) 01493 { 01494 if( new_size ) this->reserve( new_size ); 01495 } 01496 01497 inline ParallelComm::Buffer::~Buffer() 01498 { 01499 if( mem_ptr ) 01500 { 01501 free( mem_ptr ); 01502 mem_ptr = NULL; 01503 } 01504 } 01505 01506 #define DEBUG_BUFFER 0 01507 01508 inline void ParallelComm::Buffer::reserve( unsigned int new_size ) 01509 { 01510 01511 #ifdef DEBUG_BUFFER 01512 int tmp_pos = 0; 01513 if( mem_ptr ) 01514 { 01515 tmp_pos = buff_ptr - mem_ptr; 01516 } 01517 buff_ptr = (unsigned char*)malloc( new_size ); 01518 assert( 0 <= tmp_pos && tmp_pos <= (int)alloc_size ); 01519 if( tmp_pos ) memcpy( buff_ptr, mem_ptr, tmp_pos ); 01520 if( mem_ptr ) free( mem_ptr ); 01521 mem_ptr = buff_ptr; 01522 alloc_size = new_size; 01523 buff_ptr = mem_ptr + tmp_pos; 01524 #else 01525 if( mem_ptr && alloc_size < new_size ) 01526 { 01527 size_t tmp_pos = mem_ptr ? buff_ptr - mem_ptr : 0; 01528 mem_ptr = (unsigned char*)realloc( mem_ptr, new_size ); 01529 alloc_size = new_size; 01530 buff_ptr = mem_ptr + tmp_pos; 01531 } 01532 else if( !mem_ptr ) 01533 { 01534 mem_ptr = (unsigned char*)malloc( new_size ); 01535 alloc_size = new_size; 01536 buff_ptr = mem_ptr; 01537 } 01538 #endif 01539 } 01540 01541 inline void ParallelComm::Buffer::check_space( unsigned int addl_space ) 01542 { 01543 assert( buff_ptr >= mem_ptr && buff_ptr <= mem_ptr + alloc_size ); 01544 unsigned int new_size = buff_ptr - mem_ptr + addl_space; 01545 if( new_size > alloc_size ) reserve( 3 * new_size / 2 ); 01546 } 01547 01548 inline void ParallelComm::reset_all_buffers() 01549 { 01550 std::vector< Buffer* >::iterator vit; 01551 for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit ) 01552 ( *vit )->reset_buffer(); 01553 for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit ) 01554 ( *vit )->reset_buffer(); 01555 } 01556 01557 inline void ParallelComm::delete_all_buffers() 01558 { 01559 std::vector< Buffer* >::iterator vit; 01560 for( vit = localOwnedBuffs.begin(); vit != localOwnedBuffs.end(); ++vit ) 01561 delete( *vit ); 01562 localOwnedBuffs.clear(); 01563 01564 for( vit = remoteOwnedBuffs.begin(); vit != remoteOwnedBuffs.end(); ++vit ) 01565 delete( *vit ); 01566 remoteOwnedBuffs.clear(); 01567 } 01568 01569 inline const std::vector< unsigned int >& ParallelComm::buff_procs() const 01570 { 01571 return buffProcs; 01572 } 01573 01574 inline ErrorCode ParallelComm::get_shared_proc_tags( Tag& sharedp, 01575 Tag& sharedps, 01576 Tag& sharedh, 01577 Tag& sharedhs, 01578 Tag& pstatus ) 01579 { 01580 sharedp = sharedp_tag(); 01581 sharedps = sharedps_tag(); 01582 sharedh = sharedh_tag(); 01583 sharedhs = sharedhs_tag(); 01584 pstatus = pstatus_tag(); 01585 01586 return MB_SUCCESS; 01587 } 01588 01589 inline ErrorCode ParallelComm::exchange_tags( const char* tag_name, const Range& entities ) 01590 { 01591 // get the tag handle 01592 std::vector< Tag > tags( 1 ); 01593 ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY ); 01594 if( MB_SUCCESS != result ) 01595 return result; 01596 else if( !tags[0] ) 01597 return MB_TAG_NOT_FOUND; 01598 01599 return exchange_tags( tags, tags, entities ); 01600 } 01601 01602 inline ErrorCode ParallelComm::exchange_tags( Tag tagh, const Range& entities ) 01603 { 01604 // get the tag handle 01605 std::vector< Tag > tags; 01606 tags.push_back( tagh ); 01607 01608 return exchange_tags( tags, tags, entities ); 01609 } 01610 01611 inline ErrorCode ParallelComm::reduce_tags( const char* tag_name, const MPI_Op mpi_op, const Range& entities ) 01612 { 01613 // get the tag handle 01614 std::vector< Tag > tags( 1 ); 01615 ErrorCode result = mbImpl->tag_get_handle( tag_name, 0, MB_TYPE_OPAQUE, tags[0], MB_TAG_ANY ); 01616 if( MB_SUCCESS != result ) 01617 return result; 01618 else if( !tags[0] ) 01619 return MB_TAG_NOT_FOUND; 01620 01621 return reduce_tags( tags, tags, mpi_op, entities ); 01622 } 01623 01624 inline ErrorCode ParallelComm::reduce_tags( Tag tagh, const MPI_Op mpi_op, const Range& entities ) 01625 { 01626 // get the tag handle 01627 std::vector< Tag > tags; 01628 tags.push_back( tagh ); 01629 01630 return reduce_tags( tags, tags, mpi_op, entities ); 01631 } 01632 01633 inline ErrorCode ParallelComm::get_comm_procs( std::set< unsigned int >& procs ) 01634 { 01635 ErrorCode result = get_interface_procs( procs ); 01636 if( MB_SUCCESS != result ) return result; 01637 01638 std::copy( buffProcs.begin(), buffProcs.end(), std::inserter( procs, procs.begin() ) ); 01639 01640 return MB_SUCCESS; 01641 } 01642 01643 inline ErrorCode ParallelComm::get_owner( EntityHandle entity, int& owner ) 01644 { 01645 EntityHandle tmp_handle; 01646 return get_owner_handle( entity, owner, tmp_handle ); 01647 } 01648 01649 /* \brief Unpack message with remote handles (const pointer to buffer) 01650 */ 01651 inline ErrorCode ParallelComm::unpack_remote_handles( unsigned int from_proc, 01652 const unsigned char* buff_ptr, 01653 std::vector< EntityHandle >& L2hloc, 01654 std::vector< EntityHandle >& L2hrem, 01655 std::vector< unsigned int >& L2p ) 01656 { 01657 // cast away const-ness, we won't be passing back a modified ptr 01658 unsigned char* tmp_buff = const_cast< unsigned char* >( buff_ptr ); 01659 return unpack_remote_handles( from_proc, tmp_buff, L2hloc, L2hrem, L2p ); 01660 } 01661 01662 inline void ParallelComm::set_rank( unsigned int r ) 01663 { 01664 procConfig.proc_rank( r ); 01665 if( procConfig.proc_size() < r ) procConfig.proc_size( r + 1 ); 01666 } 01667 01668 inline void ParallelComm::set_size( unsigned int s ) 01669 { 01670 procConfig.proc_size( s ); 01671 } 01672 01673 inline ErrorCode ParallelComm::get_sharing_data( const EntityHandle* entities, 01674 int num_entities, 01675 std::set< int >& procs, 01676 int op ) 01677 { 01678 Range dum_range; 01679 // cast away constness 'cuz the range is passed as const 01680 EntityHandle* ents_cast = const_cast< EntityHandle* >( entities ); 01681 std::copy( ents_cast, ents_cast + num_entities, range_inserter( dum_range ) ); 01682 return get_sharing_data( dum_range, procs, op ); 01683 } 01684 01685 inline ErrorCode ParallelComm::get_sharing_data( const EntityHandle entity, 01686 int* ps, 01687 EntityHandle* hs, 01688 unsigned char& pstat, 01689 int& num_ps ) 01690 { 01691 unsigned int dum_ps; 01692 ErrorCode result = get_sharing_data( entity, ps, hs, pstat, dum_ps ); 01693 if( MB_SUCCESS == result ) num_ps = dum_ps; 01694 return result; 01695 } 01696 01697 inline void ParallelComm::set_send_request( int n_request ) 01698 { 01699 sendReqs.resize( n_request, MPI_REQUEST_NULL ); 01700 } 01701 01702 inline void ParallelComm::set_recv_request( int n_request ) 01703 { 01704 recvReqs.resize( n_request, MPI_REQUEST_NULL ); 01705 } 01706 } // namespace moab 01707 01708 #endif
