MOAB: Mesh Oriented datABase
(version 5.4.1)
Multi-CPU information for parallel MOAB. More...
#include <ProcConfig.hpp>
Collaboration diagram for moab::ProcConfig:Public Member Functions | |
| ProcConfig (MPI_Comm proc_comm) | |
| Constructor. | |
| ~ProcConfig () | |
| unsigned | proc_rank () const |
| Get the current processor number. | |
| unsigned | proc_size () const |
| Get the number of processors. | |
| gs_data::crystal_data * | crystal_router (bool construct_if_missing=true) |
| get a crystal router for this parallel job | |
| MPI_Comm | proc_comm () const |
| get/set the communicator for this proc config | |
| void | proc_comm (MPI_Comm this_comm) |
| void | proc_rank (unsigned r) |
| set rank/size; USED FOR TESTING ONLY! | |
| void | proc_size (unsigned s) |
Private Attributes | |
| MPI_Comm | procComm |
| MPI communicator set for this instance. | |
| unsigned | procRank |
| rank of this processor | |
| unsigned | procSize |
| number of processors | |
| gs_data::crystal_data * | crystalData |
Definition at line 31 of file ProcConfig.hpp.
| moab::ProcConfig::ProcConfig | ( | MPI_Comm | proc_comm | ) |
Constructor.
Definition at line 23 of file ProcConfig.cpp.
Definition at line 49 of file ProcConfig.cpp.
References crystalData.
if( crystalData )
#ifdef MOAB_HAVE_MPI
crystalData->reset();
#endif
delete crystalData;
crystalData = 0;
| gs_data::crystal_data * moab::ProcConfig::crystal_router | ( | bool | construct_if_missing = true | ) |
Definition at line 37 of file ProcConfig.cpp.
References crystalData, and procComm.
Referenced by moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ParCommGraph::compute_partition(), moab::ParallelComm::delete_entities(), iMOAB_SetDoubleTagStorageWithGid(), moab::DataCoupler::interpolate(), moab::Coupler::interpolate(), moab::Coupler::locate_points(), main(), moab::ParallelComm::resolve_shared_ents(), and moab::ParallelComm::resolve_shared_sets().
if( !crystalData && construct_if_missing )
crystalData = new gs_data::crystal_data( procComm );
#endif
return crystalData;
| MPI_Comm moab::ProcConfig::proc_comm | ( | ) | const [inline] |
Definition at line 54 of file ProcConfig.hpp.
References procComm.
Referenced by moab::MeshOutputFunctor::assign_global_ids(), moab::ParallelComm::assign_global_ids(), moab::ParallelComm::augment_default_sets_with_ghosts(), moab::ParallelComm::broadcast_entities(), moab::ParallelComm::comm(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), moab::WriteHDF5Parallel::create_dataset(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::WriteHDF5Parallel::create_tag_tables(), moab::WriteHDF5Parallel::debug_barrier_line(), moab::Coupler::do_normalization(), moab::ParallelComm::exchange_all_shared_handles(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::ReadHDF5::find_sets_containing(), moab::Coupler::get_matching_entities(), iMeshP_getNumOfTopoAll(), iMeshP_getNumOfTypeAll(), iMeshP_getPartitionComm(), moab::Coupler::initialize_tree(), moab::ReadDamsel::load_file(), moab::ReadParallel::load_file(), main(), moab::WriteHDF5Parallel::negotiate_type_list(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ParallelComm::post_irecv(), moab::WriteHDF5Parallel::print_times(), moab::ReadHDF5::print_times(), moab::ReadHDF5::read_all_set_meta(), read_mesh_parallel(), moab::ParallelComm::recv_buffer(), moab::ParallelComm::recv_entities(), moab::ParallelComm::reduce_tags(), moab::ParallelComm::resolve_shared_sets(), moab::ParallelComm::scatter_entities(), moab::ParallelComm::send_buffer(), moab::ParallelComm::send_recv_entities(), moab::ReadHDF5::set_up_read(), moab::ParallelComm::settle_intersection_points(), moab::ScdInterface::tag_shared_vertices(), and test_read_parallel().
return procComm;
| void moab::ProcConfig::proc_comm | ( | MPI_Comm | this_comm | ) | [inline] |
| unsigned moab::ProcConfig::proc_rank | ( | ) | const [inline] |
Definition at line 39 of file ProcConfig.hpp.
References procRank.
Referenced by moab::ParallelComm::assign_global_ids(), ZoltanPartitioner::balance_mesh(), moab::ParallelComm::broadcast_entities(), moab::ParallelComm::build_sharedhps_list(), moab::ParallelComm::check_all_shared_handles(), moab::ParallelComm::check_clean_iface(), moab::ParallelComm::check_local_shared(), check_shared_ents(), moab::NCWriteGCRM::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteHOMME::collect_mesh_info(), moab::WriteHDF5Parallel::communicate_shared_set_data(), moab::WriteHDF5Parallel::communicate_shared_set_ids(), create_coarse_mesh(), moab::WriteHDF5Parallel::create_dataset(), create_fine_mesh(), moab::ParallelComm::create_interface_sets(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::WriteHDF5Parallel::create_meshset_tables(), moab::ParallelComm::create_part(), moab::ReadParallel::create_partition_sets(), moab::WriteHDF5Parallel::create_tag_tables(), moab::ReadParallel::delete_nonlocal_entities(), moab::WriteHDF5Parallel::exchange_file_ids(), moab::ParallelComm::exchange_ghost_cells(), moab::ParallelComm::exchange_owned_mesh(), moab::ParallelComm::exchange_tags(), moab::ReadHDF5::find_sets_containing(), gather_one_cell_var(), moab::ParallelComm::get_buffers(), moab::ParallelComm::get_interface_procs(), moab::ParallelData::get_interface_sets(), moab::ParallelComm::get_owner_handle(), moab::ParallelComm::get_owning_part(), moab::ParallelComm::get_part_id(), moab::ParallelComm::get_proc_nvecs(), moab::ParallelComm::get_remote_handles(), moab::ScdInterface::get_shared_vertices(), moab::ParallelComm::get_sharing_parts(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::ParallelComm::initialize(), moab::Coupler::initialize_tree(), intersection_at_level(), moab::ReadParallel::load_file(), moab::Coupler::locate_points(), main(), ZoltanPartitioner::mbFinalizePoints(), ZoltanPartitioner::mbGlobalSuccess(), ZoltanPartitioner::mbInitializePoints(), ZoltanPartitioner::mbPrintGlobalResult(), ZoltanPartitioner::mbShowError(), multiple_loads_of_same_file(), moab::WriteHDF5Parallel::negotiate_type_list(), moab::WriteHDF5Parallel::parallel_create_file(), moab::ParallelComm::ParallelComm(), ZoltanPartitioner::partition_mesh_and_geometry(), moab::ParallelComm::post_irecv(), moab::ParallelComm::print_buffer(), moab::WriteHDF5Parallel::print_times(), moab::ReadHDF5::print_times(), moab::ParallelComm::rank(), moab::ReadHDF5::read_all_set_meta(), read_mesh_parallel(), moab::ReadParallel::ReadParallel(), moab::ParallelComm::recv_buffer(), moab::ParallelComm::recv_entities(), moab::ParallelComm::recv_messages(), moab::ParallelComm::recv_remote_handle_messages(), moab::ParallelComm::reduce_tags(), moab::RefinerTagManager::RefinerTagManager(), ZoltanPartitioner::repartition(), moab::ParallelComm::resolve_shared_ents(), moab::ParallelComm::resolve_shared_sets(), moab::ParallelComm::scatter_entities(), moab::ParallelComm::send_buffer(), moab::ParallelComm::send_entities(), moab::ParallelComm::send_recv_entities(), moab::ParallelComm::set_rank(), moab::ParallelComm::set_sharing_data(), moab::ReadHDF5::set_up_read(), ZoltanPartitioner::SetHSFC_Parameters(), ZoltanPartitioner::SetHypergraph_Parameters(), ZoltanPartitioner::SetOCTPART_Parameters(), ZoltanPartitioner::SetPARMETIS_Parameters(), ZoltanPartitioner::SetRCB_Parameters(), ZoltanPartitioner::SetRIB_Parameters(), moab::ParallelComm::settle_intersection_points(), moab::ParallelComm::tag_shared_verts(), test_delete_entities(), test_elements_on_several_procs(), test_gather_onevar(), test_ghost_elements(), test_ghost_tag_exchange(), test_intx_in_parallel_elem_based(), test_intx_mpas(), test_read_eul_onevar(), test_read_fv_onevar(), test_read_parallel(), moab::ParallelComm::unpack_entities(), moab::ParallelComm::update_remote_data_old(), and moab::NCWriteHelper::write_set_variables().
return procRank;
| void moab::ProcConfig::proc_rank | ( | unsigned | r | ) | [inline] |
Definition at line 64 of file ProcConfig.hpp.
procRank = r;
| unsigned moab::ProcConfig::proc_size | ( | ) | const [inline] |
Definition at line 45 of file ProcConfig.hpp.
References procSize.
Referenced by moab::MeshOutputFunctor::assign_global_ids(), moab::ParallelComm::assign_global_ids(), moab::ParallelComm::augment_default_sets_with_ghosts(), ZoltanPartitioner::balance_mesh(), moab::NCWriteHOMME::collect_mesh_info(), moab::NCWriteMPAS::collect_mesh_info(), moab::NCWriteGCRM::collect_mesh_info(), moab::ScdNCWriteHelper::collect_mesh_info(), moab::WriteHDF5Parallel::create_dataset(), moab::NCHelperScrip::create_mesh(), moab::NCHelperHOMME::create_mesh(), moab::NCHelperGCRM::create_mesh(), moab::NCHelperMPAS::create_mesh(), moab::ReadParallel::delete_nonlocal_entities(), moab::ParallelComm::gather_data(), gather_one_cell_var(), moab::ScdInterface::get_shared_vertices(), moab::NCHelperDomain::init_mesh_vals(), moab::NCHelperFV::init_mesh_vals(), moab::NCHelperEuler::init_mesh_vals(), moab::Coupler::initialize_tree(), moab::ReadParallel::load_file(), moab::Coupler::locate_points(), main(), ZoltanPartitioner::mbFinalizePoints(), ZoltanPartitioner::mbGlobalSuccess(), ZoltanPartitioner::mbInitializePoints(), ZoltanPartitioner::mbPrintGlobalResult(), multiple_loads_of_same_file(), moab::WriteHDF5Parallel::negotiate_type_list(), MetisPartitioner::partition_mesh(), ZoltanPartitioner::partition_mesh_and_geometry(), read_mesh_parallel(), ZoltanPartitioner::repartition(), moab::ParallelComm::scatter_entities(), moab::ParallelComm::set_rank(), moab::ParallelComm::set_size(), moab::ParallelComm::size(), test_read_all(), test_read_conn(), test_read_eul_onevar(), test_read_fv_onevar(), test_read_no_mixed_elements(), test_read_novars(), test_read_onevar(), and test_read_parallel().
return procSize;
| void moab::ProcConfig::proc_size | ( | unsigned | s | ) | [inline] |
Definition at line 84 of file ProcConfig.hpp.
Referenced by crystal_router(), and ~ProcConfig().
MPI_Comm moab::ProcConfig::procComm [private] |
Definition at line 75 of file ProcConfig.hpp.
Referenced by crystal_router(), proc_comm(), and ProcConfig().
unsigned moab::ProcConfig::procRank [private] |
Definition at line 78 of file ProcConfig.hpp.
Referenced by proc_rank(), and ProcConfig().
unsigned moab::ProcConfig::procSize [private] |
Definition at line 81 of file ProcConfig.hpp.
Referenced by proc_size(), and ProcConfig().
