MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #include "moab/MOABConfig.h" 00002 #ifdef WIN32 /* windows */ 00003 #define _USE_MATH_DEFINES // For M_PI 00004 #endif 00005 00006 #include "NCHelperEuler.hpp" 00007 #include "moab/FileOptions.hpp" 00008 00009 #include <cmath> 00010 #include <sstream> 00011 00012 #ifdef WIN32 00013 #ifdef size_t 00014 #undef size_t 00015 #endif 00016 #endif 00017 00018 namespace moab 00019 { 00020 00021 bool NCHelperEuler::can_read_file( ReadNC* readNC, int fileId ) 00022 { 00023 std::vector< std::string >& dimNames = readNC->dimNames; 00024 00025 // If dimension names "lon" AND "lat' exist then it could be either the Eulerian Spectral grid 00026 // or the FV grid 00027 if( ( std::find( dimNames.begin(), dimNames.end(), std::string( "lon" ) ) != dimNames.end() ) && 00028 ( std::find( dimNames.begin(), dimNames.end(), std::string( "lat" ) ) != dimNames.end() ) ) 00029 { 00030 // If dimension names "lon" AND "lat" AND "slon" AND "slat" exist then it should be the FV 00031 // grid 00032 if( ( std::find( dimNames.begin(), dimNames.end(), std::string( "slon" ) ) != dimNames.end() ) && 00033 ( std::find( dimNames.begin(), dimNames.end(), std::string( "slat" ) ) != dimNames.end() ) ) 00034 return false; 00035 00036 // Make sure it is CAM grid 00037 std::map< std::string, ReadNC::AttData >::iterator attIt = readNC->globalAtts.find( "source" ); 00038 if( attIt == readNC->globalAtts.end() ) return false; 00039 unsigned int sz = attIt->second.attLen; 00040 std::string att_data; 00041 att_data.resize( sz + 1 ); 00042 att_data[sz] = '\000'; 00043 int success = 00044 NCFUNC( get_att_text )( fileId, attIt->second.attVarId, attIt->second.attName.c_str(), &att_data[0] ); 00045 if( success ) return false; 00046 if( att_data.find( "CAM" ) == std::string::npos ) return false; 00047 00048 return true; 00049 } 00050 00051 return false; 00052 } 00053 00054 ErrorCode NCHelperEuler::init_mesh_vals() 00055 { 00056 Interface*& mbImpl = _readNC->mbImpl; 00057 std::vector< std::string >& dimNames = _readNC->dimNames; 00058 std::vector< int >& dimLens = _readNC->dimLens; 00059 std::map< std::string, ReadNC::VarData >& varInfo = _readNC->varInfo; 00060 DebugOutput& dbgOut = _readNC->dbgOut; 00061 bool& isParallel = _readNC->isParallel; 00062 int& partMethod = _readNC->partMethod; 00063 ScdParData& parData = _readNC->parData; 00064 00065 // Look for names of center i/j dimensions 00066 // First i 00067 std::vector< std::string >::iterator vit; 00068 unsigned int idx; 00069 if( ( vit = std::find( dimNames.begin(), dimNames.end(), "lon" ) ) != dimNames.end() ) 00070 idx = vit - dimNames.begin(); 00071 else 00072 { 00073 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lon' dimension" ); 00074 } 00075 iCDim = idx; 00076 gCDims[0] = 0; 00077 gCDims[3] = dimLens[idx] - 1; 00078 00079 // Check i periodicity and set globallyPeriodic[0] 00080 std::vector< double > til_vals( 2 ); 00081 ErrorCode rval = read_coordinate( "lon", gCDims[3] - 1, gCDims[3], til_vals );MB_CHK_SET_ERR( rval, "Trouble reading 'lon' variable" ); 00082 if( std::fabs( 2 * til_vals[1] - til_vals[0] - 360 ) < 0.001 ) globallyPeriodic[0] = 1; 00083 00084 // Now we can set gDims for i 00085 gDims[0] = 0; 00086 gDims[3] = 00087 gCDims[3] + ( globallyPeriodic[0] ? 0 : 1 ); // Only if not periodic is vertex param max > elem param max 00088 00089 // Then j 00090 if( ( vit = std::find( dimNames.begin(), dimNames.end(), "lat" ) ) != dimNames.end() ) 00091 idx = vit - dimNames.begin(); 00092 else 00093 { 00094 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lat' dimension" ); 00095 } 00096 jCDim = idx; 00097 gCDims[1] = 0; 00098 gCDims[4] = dimLens[idx] - 1; 00099 00100 // For Eul models, will always be non-periodic in j 00101 gDims[1] = 0; 00102 gDims[4] = gCDims[4] + 1; 00103 00104 // Try a truly 2D mesh 00105 gDims[2] = -1; 00106 gDims[5] = -1; 00107 00108 // Look for time dimension 00109 if( ( vit = std::find( dimNames.begin(), dimNames.end(), "time" ) ) != dimNames.end() ) 00110 idx = vit - dimNames.begin(); 00111 else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "t" ) ) != dimNames.end() ) 00112 idx = vit - dimNames.begin(); 00113 else 00114 { 00115 MB_SET_ERR( MB_FAILURE, "Couldn't find 'time' or 't' dimension" ); 00116 } 00117 tDim = idx; 00118 nTimeSteps = dimLens[idx]; 00119 00120 // Look for level dimension 00121 if( ( vit = std::find( dimNames.begin(), dimNames.end(), "lev" ) ) != dimNames.end() ) 00122 idx = vit - dimNames.begin(); 00123 else if( ( vit = std::find( dimNames.begin(), dimNames.end(), "ilev" ) ) != dimNames.end() ) 00124 idx = vit - dimNames.begin(); 00125 else 00126 { 00127 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lev' or 'ilev' dimension" ); 00128 } 00129 levDim = idx; 00130 nLevels = dimLens[idx]; 00131 00132 // Parse options to get subset 00133 int rank = 0, procs = 1; 00134 #ifdef MOAB_HAVE_MPI 00135 if( isParallel ) 00136 { 00137 ParallelComm*& myPcomm = _readNC->myPcomm; 00138 rank = myPcomm->proc_config().proc_rank(); 00139 procs = myPcomm->proc_config().proc_size(); 00140 } 00141 #endif 00142 if( procs > 1 ) 00143 { 00144 for( int i = 0; i < 6; i++ ) 00145 parData.gDims[i] = gDims[i]; 00146 for( int i = 0; i < 3; i++ ) 00147 parData.gPeriodic[i] = globallyPeriodic[i]; 00148 parData.partMethod = partMethod; 00149 int pdims[3]; 00150 00151 rval = ScdInterface::compute_partition( procs, rank, parData, lDims, locallyPeriodic, pdims );MB_CHK_ERR( rval ); 00152 for( int i = 0; i < 3; i++ ) 00153 parData.pDims[i] = pdims[i]; 00154 00155 dbgOut.tprintf( 1, "Partition: %dx%d (out of %dx%d)\n", lDims[3] - lDims[0] + 1, lDims[4] - lDims[1] + 1, 00156 gDims[3] - gDims[0] + 1, gDims[4] - gDims[1] + 1 ); 00157 if( 0 == rank ) 00158 dbgOut.tprintf( 1, "Contiguous chunks of size %d bytes.\n", 00159 8 * ( lDims[3] - lDims[0] + 1 ) * ( lDims[4] - lDims[1] + 1 ) ); 00160 } 00161 else 00162 { 00163 for( int i = 0; i < 6; i++ ) 00164 lDims[i] = gDims[i]; 00165 locallyPeriodic[0] = globallyPeriodic[0]; 00166 } 00167 00168 _opts.get_int_option( "IMIN", lDims[0] ); 00169 _opts.get_int_option( "IMAX", lDims[3] ); 00170 _opts.get_int_option( "JMIN", lDims[1] ); 00171 _opts.get_int_option( "JMAX", lDims[4] ); 00172 00173 // Now get actual coordinate values for vertices and cell centers 00174 lCDims[0] = lDims[0]; 00175 if( locallyPeriodic[0] ) 00176 // If locally periodic, doesn't matter what global periodicity is, # vertex coords = # elem 00177 // coords 00178 lCDims[3] = lDims[3]; 00179 else 00180 lCDims[3] = lDims[3] - 1; 00181 00182 // For Eul models, will always be non-periodic in j 00183 lCDims[1] = lDims[1]; 00184 lCDims[4] = lDims[4] - 1; 00185 00186 // Resize vectors to store values later 00187 if( -1 != lDims[0] ) ilVals.resize( lDims[3] - lDims[0] + 1 ); 00188 if( -1 != lCDims[0] ) ilCVals.resize( lCDims[3] - lCDims[0] + 1 ); 00189 if( -1 != lDims[1] ) jlVals.resize( lDims[4] - lDims[1] + 1 ); 00190 if( -1 != lCDims[1] ) jlCVals.resize( lCDims[4] - lCDims[1] + 1 ); 00191 if( nTimeSteps > 0 ) tVals.resize( nTimeSteps ); 00192 00193 // Now read coord values 00194 std::map< std::string, ReadNC::VarData >::iterator vmit; 00195 if( -1 != lCDims[0] ) 00196 { 00197 if( ( vmit = varInfo.find( "lon" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00198 { 00199 rval = read_coordinate( "lon", lCDims[0], lCDims[3], ilCVals );MB_CHK_SET_ERR( rval, "Trouble reading 'lon' variable" ); 00200 } 00201 else 00202 { 00203 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lon' variable" ); 00204 } 00205 } 00206 00207 if( -1 != lCDims[1] ) 00208 { 00209 if( ( vmit = varInfo.find( "lat" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00210 { 00211 rval = read_coordinate( "lat", lCDims[1], lCDims[4], jlCVals );MB_CHK_SET_ERR( rval, "Trouble reading 'lat' variable" ); 00212 } 00213 else 00214 { 00215 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lat' variable" ); 00216 } 00217 } 00218 00219 if( -1 != lDims[0] ) 00220 { 00221 if( ( vmit = varInfo.find( "lon" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00222 { 00223 double dif = ( ilCVals[1] - ilCVals[0] ) / 2; 00224 std::size_t i; 00225 for( i = 0; i != ilCVals.size(); i++ ) 00226 ilVals[i] = ilCVals[i] - dif; 00227 // The last one is needed only if not periodic 00228 if( !locallyPeriodic[0] ) ilVals[i] = ilCVals[i - 1] + dif; 00229 } 00230 else 00231 { 00232 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lon' variable" ); 00233 } 00234 } 00235 00236 if( -1 != lDims[1] ) 00237 { 00238 if( ( vmit = varInfo.find( "lat" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00239 { 00240 if( !isParallel || ( ( gDims[4] - gDims[1] ) == ( lDims[4] - lDims[1] ) ) ) 00241 { 00242 std::string gwName( "gw" ); 00243 std::vector< double > gwVals( lDims[4] - lDims[1] - 1 ); 00244 rval = read_coordinate( gwName.c_str(), lDims[1], lDims[4] - 2, gwVals );MB_CHK_SET_ERR( rval, "Trouble reading 'gw' variable" ); 00245 // Copy the correct piece 00246 jlVals[0] = -( M_PI / 2 ) * 180 / M_PI; 00247 std::size_t i = 0; 00248 double gwSum = -1; 00249 for( i = 1; i != gwVals.size() + 1; i++ ) 00250 { 00251 gwSum += gwVals[i - 1]; 00252 jlVals[i] = std::asin( gwSum ) * 180 / M_PI; 00253 } 00254 jlVals[i] = 90.0; // Using value of i after loop exits. 00255 } 00256 else 00257 { 00258 std::string gwName( "gw" ); 00259 double gwSum = 0; 00260 00261 // If this is the first row 00262 if( lDims[1] == gDims[1] ) 00263 { 00264 std::vector< double > gwVals( lDims[4] ); 00265 rval = read_coordinate( gwName.c_str(), 0, lDims[4] - 1, gwVals );MB_CHK_SET_ERR( rval, "Trouble reading 'gw' variable" ); 00266 // Copy the correct piece 00267 jlVals[0] = -( M_PI / 2 ) * 180 / M_PI; 00268 gwSum = -1; 00269 for( std::size_t i = 1; i != jlVals.size(); i++ ) 00270 { 00271 gwSum += gwVals[i - 1]; 00272 jlVals[i] = std::asin( gwSum ) * 180 / M_PI; 00273 } 00274 } 00275 // Or if it's the last row 00276 else if( lDims[4] == gDims[4] ) 00277 { 00278 std::vector< double > gwVals( lDims[4] - 1 ); 00279 rval = read_coordinate( gwName.c_str(), 0, lDims[4] - 2, gwVals );MB_CHK_SET_ERR( rval, "Trouble reading 'gw' variable" ); 00280 // Copy the correct piece 00281 gwSum = -1; 00282 for( int j = 0; j != lDims[1] - 1; j++ ) 00283 gwSum += gwVals[j]; 00284 std::size_t i = 0; 00285 for( ; i != jlVals.size() - 1; i++ ) 00286 { 00287 gwSum += gwVals[lDims[1] - 1 + i]; 00288 jlVals[i] = std::asin( gwSum ) * 180 / M_PI; 00289 } 00290 jlVals[i] = 90.0; // Using value of i after loop exits. 00291 } 00292 // It's in the middle 00293 else 00294 { 00295 int start = lDims[1] - 1; 00296 int end = lDims[4] - 1; 00297 std::vector< double > gwVals( end ); 00298 rval = read_coordinate( gwName.c_str(), 0, end - 1, gwVals );MB_CHK_SET_ERR( rval, "Trouble reading 'gw' variable" ); 00299 gwSum = -1; 00300 for( int j = 0; j != start - 1; j++ ) 00301 gwSum += gwVals[j]; 00302 std::size_t i = 0; 00303 for( ; i != jlVals.size(); i++ ) 00304 { 00305 gwSum += gwVals[start - 1 + i]; 00306 jlVals[i] = std::asin( gwSum ) * 180 / M_PI; 00307 } 00308 } 00309 } 00310 } 00311 else 00312 { 00313 MB_SET_ERR( MB_FAILURE, "Couldn't find 'lat' variable" ); 00314 } 00315 } 00316 00317 // Store time coordinate values in tVals 00318 if( nTimeSteps > 0 ) 00319 { 00320 if( ( vmit = varInfo.find( "time" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00321 { 00322 rval = read_coordinate( "time", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 'time' variable" ); 00323 } 00324 else if( ( vmit = varInfo.find( "t" ) ) != varInfo.end() && ( *vmit ).second.varDims.size() == 1 ) 00325 { 00326 rval = read_coordinate( "t", 0, nTimeSteps - 1, tVals );MB_CHK_SET_ERR( rval, "Trouble reading 't' variable" ); 00327 } 00328 else 00329 { 00330 // If expected time variable is not available, set dummy time coordinate values to tVals 00331 for( int t = 0; t < nTimeSteps; t++ ) 00332 tVals.push_back( (double)t ); 00333 } 00334 } 00335 00336 dbgOut.tprintf( 1, "I=%d-%d, J=%d-%d\n", lDims[0], lDims[3], lDims[1], lDims[4] ); 00337 dbgOut.tprintf( 1, "%d elements, %d vertices\n", ( lDims[3] - lDims[0] ) * ( lDims[4] - lDims[1] ), 00338 ( lDims[3] - lDims[0] + 1 ) * ( lDims[4] - lDims[1] + 1 ) ); 00339 00340 // For each variable, determine the entity location type and number of levels 00341 std::map< std::string, ReadNC::VarData >::iterator mit; 00342 for( mit = varInfo.begin(); mit != varInfo.end(); ++mit ) 00343 { 00344 ReadNC::VarData& vd = ( *mit ).second; 00345 00346 // Default entLoc is ENTLOCSET 00347 if( std::find( vd.varDims.begin(), vd.varDims.end(), tDim ) != vd.varDims.end() ) 00348 { 00349 if( ( std::find( vd.varDims.begin(), vd.varDims.end(), iCDim ) != vd.varDims.end() ) && 00350 ( std::find( vd.varDims.begin(), vd.varDims.end(), jCDim ) != vd.varDims.end() ) ) 00351 vd.entLoc = ReadNC::ENTLOCFACE; 00352 } 00353 00354 // Default numLev is 0 00355 if( std::find( vd.varDims.begin(), vd.varDims.end(), levDim ) != vd.varDims.end() ) vd.numLev = nLevels; 00356 } 00357 00358 // For Eul models, slon and slat are "virtual" dimensions (not defined in the file header) 00359 std::vector< std::string > ijdimNames( 4 ); 00360 ijdimNames[0] = "__slon"; 00361 ijdimNames[1] = "__slat"; 00362 ijdimNames[2] = "__lon"; 00363 ijdimNames[3] = "__lat"; 00364 00365 std::string tag_name; 00366 Tag tagh; 00367 00368 // __<dim_name>_LOC_MINMAX (for virtual slon, virtual slat, lon and lat) 00369 for( unsigned int i = 0; i != ijdimNames.size(); i++ ) 00370 { 00371 std::vector< int > val( 2, 0 ); 00372 if( ijdimNames[i] == "__slon" ) 00373 { 00374 val[0] = lDims[0]; 00375 val[1] = lDims[3]; 00376 } 00377 else if( ijdimNames[i] == "__slat" ) 00378 { 00379 val[0] = lDims[1]; 00380 val[1] = lDims[4]; 00381 } 00382 else if( ijdimNames[i] == "__lon" ) 00383 { 00384 val[0] = lCDims[0]; 00385 val[1] = lCDims[3]; 00386 } 00387 else if( ijdimNames[i] == "__lat" ) 00388 { 00389 val[0] = lCDims[1]; 00390 val[1] = lCDims[4]; 00391 } 00392 std::stringstream ss_tag_name; 00393 ss_tag_name << ijdimNames[i] << "_LOC_MINMAX"; 00394 tag_name = ss_tag_name.str(); 00395 rval = mbImpl->tag_get_handle( tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00396 rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00397 if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Conventional tag %s is created.\n", tag_name.c_str() ); 00398 } 00399 00400 // __<dim_name>_LOC_VALS (for virtual slon, virtual slat, lon and lat) 00401 // Assume all have the same data type as lon (expected type is float or double) 00402 switch( varInfo["lon"].varDataType ) 00403 { 00404 case NC_FLOAT: 00405 case NC_DOUBLE: 00406 break; 00407 default: 00408 MB_SET_ERR( MB_FAILURE, "Unexpected variable data type for 'lon'" ); 00409 } 00410 00411 for( unsigned int i = 0; i != ijdimNames.size(); i++ ) 00412 { 00413 void* val = NULL; 00414 int val_len = 0; 00415 if( ijdimNames[i] == "__slon" ) 00416 { 00417 val = &ilVals[0]; 00418 val_len = ilVals.size(); 00419 } 00420 else if( ijdimNames[i] == "__slat" ) 00421 { 00422 val = &jlVals[0]; 00423 val_len = jlVals.size(); 00424 } 00425 else if( ijdimNames[i] == "__lon" ) 00426 { 00427 val = &ilCVals[0]; 00428 val_len = ilCVals.size(); 00429 } 00430 else if( ijdimNames[i] == "__lat" ) 00431 { 00432 val = &jlCVals[0]; 00433 val_len = jlCVals.size(); 00434 } 00435 00436 std::stringstream ss_tag_name; 00437 ss_tag_name << ijdimNames[i] << "_LOC_VALS"; 00438 tag_name = ss_tag_name.str(); 00439 rval = mbImpl->tag_get_handle( tag_name.c_str(), 0, MB_TYPE_DOUBLE, tagh, 00440 MB_TAG_CREAT | MB_TAG_SPARSE | MB_TAG_VARLEN );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00441 rval = mbImpl->tag_set_by_ptr( tagh, &_fileSet, 1, &val, &val_len );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00442 if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Conventional tag %s is created.\n", tag_name.c_str() ); 00443 } 00444 00445 // __<dim_name>_GLOBAL_MINMAX (for virtual slon, virtual slat, lon and lat) 00446 for( unsigned int i = 0; i != ijdimNames.size(); i++ ) 00447 { 00448 std::vector< int > val( 2, 0 ); 00449 if( ijdimNames[i] == "__slon" ) 00450 { 00451 val[0] = gDims[0]; 00452 val[1] = gDims[3]; 00453 } 00454 else if( ijdimNames[i] == "__slat" ) 00455 { 00456 val[0] = gDims[1]; 00457 val[1] = gDims[4]; 00458 } 00459 else if( ijdimNames[i] == "__lon" ) 00460 { 00461 val[0] = gCDims[0]; 00462 val[1] = gCDims[3]; 00463 } 00464 else if( ijdimNames[i] == "__lat" ) 00465 { 00466 val[0] = gCDims[1]; 00467 val[1] = gCDims[4]; 00468 } 00469 std::stringstream ss_tag_name; 00470 ss_tag_name << ijdimNames[i] << "_GLOBAL_MINMAX"; 00471 tag_name = ss_tag_name.str(); 00472 rval = mbImpl->tag_get_handle( tag_name.c_str(), 2, MB_TYPE_INTEGER, tagh, MB_TAG_SPARSE | MB_TAG_CREAT );MB_CHK_SET_ERR( rval, "Trouble creating conventional tag " << tag_name ); 00473 rval = mbImpl->tag_set_data( tagh, &_fileSet, 1, &val[0] );MB_CHK_SET_ERR( rval, "Trouble setting data to conventional tag " << tag_name ); 00474 if( MB_SUCCESS == rval ) dbgOut.tprintf( 2, "Conventional tag %s is created.\n", tag_name.c_str() ); 00475 } 00476 00477 // Hack: create dummy variables, if needed, for dimensions with no corresponding coordinate 00478 // variables 00479 rval = create_dummy_variables();MB_CHK_SET_ERR( rval, "Failed to create dummy variables" ); 00480 00481 return MB_SUCCESS; 00482 } 00483 00484 } // namespace moab
