MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"#include "moab_mpi.h"#include "moab/ParallelComm.hpp"#include "MBParallelConventions.h"#include "moab/iMOAB.h"#include "TestUtil.hpp"#include "moab/CpuTimer.hpp"#include "moab/ProgOptions.hpp"#include <iostream>#include <sstream>#include "imoab_coupler_utils.hpp"
Include dependency graph for imoab_coupler_twohop.cpp:Go to the source code of this file.
Defines | |
| #define | ENABLE_ATMOCN_COUPLING |
| #define | ENABLE_ATMCPLOCN_COUPLING |
Functions | |
| int | main (int argc, char *argv[]) |
| #define ENABLE_ATMCPLOCN_COUPLING |
Definition at line 42 of file imoab_coupler_twohop.cpp.
| #define ENABLE_ATMOCN_COUPLING |
Definition at line 41 of file imoab_coupler_twohop.cpp.
| int main | ( | int | argc, |
| char * | argv[] | ||
we will use the element global id, which should uniquely identify the element
Definition at line 48 of file imoab_coupler_twohop.cpp.
References ProgOptions::addOpt(), atmFilename, CHECKIERR, cmpatm, create_group_and_comm(), create_joint_comm_group(), DENSE_DOUBLE, DENSE_INTEGER, endG1, endG2, fileWriteOptions(), groupTasks, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_GetDoubleTagStorage(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_Initialize(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_WriteLocalMesh(), iMOAB_WriteMesh(), jgroup, MPI_COMM_WORLD, nghlay, numProcesses, ProgOptions::parseCommandLine(), POP_TIMER, PUSH_TIMER, rankInAtmComm, rankInGlobalComm, readopts(), setup_component_coupler_meshes(), startG1, and startG2.
int ierr;
int rankInGlobalComm, numProcesses;
MPI_Group jgroup;
std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" );
std::string readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" );
// Timer data
moab::CpuTimer timer;
double timer_ops;
std::string opName;
int repartitioner_scheme = 0;
#ifdef MOAB_HAVE_ZOLTAN
repartitioner_scheme = 2; // use the graph partitioner in that caseS
#endif
MPI_Init( &argc, &argv );
MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm );
MPI_Comm_size( MPI_COMM_WORLD, &numProcesses );
MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup
std::string atmFilename = TestDir + "unittest/wholeATM_T.h5m";
// on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ;
// intx atm/ocn is not in e3sm yet, give a number
// 6 * 100+ 18 = 618 : atmocnid
// 9 LND, 10 CPLLND
// 6 * 100 + 10 = 610 atmlndid:
// cmpatm is for atm on atm pes
// cmpocn is for ocean, on ocean pe
// cplatm is for atm on coupler pes
// cplocn is for ocean on coupelr pes
// atmocnid is for intx atm / ocn on coupler pes
int rankInAtmComm = -1;
int cmpatm = 5,
cplatm = 6; // component ids are unique over all pes, and established in advance;
#ifdef ENABLE_ATMOCN_COUPLING
std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m";
std::string baseline = TestDir + "unittest/baseline1.txt";
int rankInOcnComm = -1;
int cmpocn = 17, cplocn = 18,
atmocnid = 618; // component ids are unique over all pes, and established in advance;
#endif
#ifdef ENABLE_ATMCPLOCN_COUPLING
int cplatm2 = 10,
atm2ocnid = 610; // component ids are unique over all pes, and established in advance;
#endif
int rankInCouComm = -1;
int nghlay = 0; // number of ghost layers for loading the file
std::vector< int > groupTasks;
int startG1 = 0, startG2 = 0,
endG1 = numProcesses - 1, endG2 = numProcesses - 1; // Support launch of imoab_coupler test on any combo of 2*x processes
int startG4 = startG1, endG4 = endG1; // these are for coupler layout
int context_id = -1; // used now for freeing buffers
// default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx
// later, we need to compute weight matrix with tempestremap
ProgOptions opts;
opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename );
opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename );
#endif
opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 );
opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 );
opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 );
opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 );
#endif
opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 );
opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 );
opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme );
int n = 1; // number of send/receive / project / send back cycles
opts.addOpt< int >( "iterations,n", "number of iterations for coupler", &n );
bool no_regression_test = false;
opts.addOpt< void >( "no_regression,r", "do not do regression test against baseline 1", &no_regression_test );
opts.parseCommandLine( argc, argv );
char fileWriteOptions[] = "PARALLEL=WRITE_PART";
if( !rankInGlobalComm )
std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 <<
"\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 <<
#endif
"\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n ";
// load files on 3 different communicators, groups
// first groups has task 0, second group tasks 0 and 1
// coupler will be on joint tasks, will be on a third group (0 and 1, again)
MPI_Group atmPEGroup;
MPI_Comm atmComm;
ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm );
CHECKIERR( ierr, "Cannot create atm MPI group and communicator " )
MPI_Group ocnPEGroup;
MPI_Comm ocnComm;
ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm );
CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " )
#endif
// we will always have a coupler
MPI_Group couPEGroup;
MPI_Comm couComm;
ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm );
CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " )
// atm_coupler
MPI_Group joinAtmCouGroup;
MPI_Comm atmCouComm;
ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm );
CHECKIERR( ierr, "Cannot create joint atm cou communicator" )
// ocn_coupler
MPI_Group joinOcnCouGroup;
MPI_Comm ocnCouComm;
ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm );
CHECKIERR( ierr, "Cannot create joint ocn cou communicator" )
#endif
ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should
CHECKIERR( ierr, "Cannot initialize iMOAB" )
int cmpAtmAppID = -1;
iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm
int cplAtmAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs
int cmpOcnAppID = -1;
iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn
int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs
iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs
#endif
int cplAtm2AppID = -1; // -1 means it is not initialized
iMOAB_AppID cplAtm2PID = &cplAtm2AppID; // atm on second coupler PEs
int cplAtm2OcnAppID = -1; // -1 means it is not initialized
iMOAB_AppID cplAtm2OcnPID = &cplAtm2OcnAppID; // intx atm - lnd on coupler PEs
#endif
if( couComm != MPI_COMM_NULL )
MPI_Comm_rank( couComm, &rankInCouComm );
// Register all the applications on the coupler PEs
ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm,
cplAtmPID ); // atm on coupler pes
CHECKIERR( ierr, "Cannot register ATM over coupler PEs" )
ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn,
cplOcnPID ); // ocn on coupler pes
CHECKIERR( ierr, "Cannot register OCN over coupler PEs" )
#endif
ierr = iMOAB_RegisterApplication( "ATMX2", &couComm, &cplatm2,
cplAtm2PID ); // second atm on coupler pes
CHECKIERR( ierr, "Cannot register second ATM over coupler PEs" )
#endif
if( atmComm != MPI_COMM_NULL )
MPI_Comm_rank( atmComm, &rankInAtmComm );
ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID );
CHECKIERR( ierr, "Cannot register ATM App" )
if( ocnComm != MPI_COMM_NULL )
MPI_Comm_rank( ocnComm, &rankInOcnComm );
ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID );
CHECKIERR( ierr, "Cannot register OCN App" )
#endif
// atm
ierr =
setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm,
&couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme );
CHECKIERR( ierr, "Cannot load and migrate atm mesh" )
// ocean
ierr =
setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm,
&couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme );
CHECKIERR( ierr, "Cannot load and migrate ocn mesh" )
#endif // #ifdef ENABLE_ATMOCN_COUPLING
// then send mesh to second coupler pes
ierr = iMOAB_SendMesh( cmpAtmPID, &atmCouComm, &couPEGroup, &cplatm2,
&repartitioner_scheme ); // send to coupler pes
CHECKIERR( ierr, "cannot send elements to coupler-2" )
// now, receive mesh, on coupler communicator; first mesh 1, atm
ierr = iMOAB_ReceiveMesh( cplAtm2PID, &atmCouComm, &atmPEGroup,
&cmpatm ); // receive from component
CHECKIERR( ierr, "cannot receive elements on coupler app" )
// we can now free the sender buffers
int context_id = cplatm;
ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &context_id );
CHECKIERR( ierr, "cannot free buffers used to send atm mesh" )
if( couComm != MPI_COMM_NULL && 1 == n )
{ // write only for n==1 case
char outputFileLnd[] = "recvAtm2.h5m";
ierr = iMOAB_WriteMesh( cplAtm2PID, outputFileLnd, fileWriteOptions );
CHECKIERR( ierr, "cannot write second atm mesh after receiving" )
#endif // #ifdef ENABLE_ATMCPLOCN_COUPLING
MPI_Barrier( MPI_COMM_WORLD );
// now compute intersection between OCNx and ATMx on coupler PEs
ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID );
CHECKIERR( ierr, "Cannot register atm/ocn intersection over coupler pes " )
#endif
// now compute intersection between LNDx and ATMx on coupler PEs
ierr = iMOAB_RegisterApplication( "ATM2OCN", &couComm, &atm2ocnid, cplAtm2OcnPID );
CHECKIERR( ierr, "Cannot register atm2/ocn intersection over coupler pes " )
#endif
int disc_orders[3] = { 4, 1, 1 };
const std::string weights_identifiers[2] = { "scalar", "scalar-pc" };
const std::string disc_methods[3] = { "cgll", "fv", "pcloud" };
const std::string dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" };
PUSH_TIMER( "Compute ATM-OCN mesh intersection" )
ierr = iMOAB_ComputeMeshIntersectionOnSphere(
cplAtmPID, cplOcnPID,
cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes
// basically, atm was redistributed according to target (ocean) partition, to "cover" the
// ocean partitions check if intx valid, write some h5m intx file
CHECKIERR( ierr, "cannot compute intersection for atm/ocn" )
POP_TIMER( couComm, rankInCouComm )
#ifdef VERBOSE
char prefix[] = "intx_atmocn";
ierr = iMOAB_WriteLocalMesh( cplAtmOcnPID, prefix, strlen( prefix ) );
CHECKIERR( ierr, "failed to write local intx mesh" );
#endif
if( atmCouComm != MPI_COMM_NULL )
// the new graph will be for sending data from atm comp to coverage mesh;
// it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID
// results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh
// after this, the sending of tags from atm pes to coupler pes will use the new par comm
// graph, that has more precise info about what to send for ocean cover ; every time, we
// will
// use the element global id, which should uniquely identify the element
PUSH_TIMER( "Compute OCN coverage graph for ATM mesh" )
ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm,
&cplocn ); // it happens over joint communicator
CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" )
POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank
#endif
cplAtm2PID, cplOcnPID,
cplAtm2OcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes
CHECKIERR( ierr, "cannot compute intersection for atm2/ocn" )
// if( atmCouComm != MPI_COMM_NULL )
// the new graph will be for sending data from atm comp to coverage mesh for land mesh;
// results are in cplAtmLndPID, intx mesh; remapper also has some info about coverage mesh
// graph, that has more precise info about what to send (specifically for land cover); every
// time,
/// we will use the element global id, which should uniquely identify the element
PUSH_TIMER( "Compute OCN coverage graph for ATM2 mesh" )
// Context: cplatm2 already holds the comm-graph for communicating between atm component and coupler2
// We just need to create a comm graph to internally transfer data from coupler atm to coupler ocean
// ierr = iMOAB_CoverageGraph( &couComm, cplAtm2PID, cplAtm2OcnPID, cplAtm2OcnPID, &cplatm2, &atm2ocnid,
// &cplocn ); // it happens over joint communicator
int type1 = 1;
int type2 = 1;
ierr = iMOAB_ComputeCommGraph( cplAtm2PID, cplAtm2OcnPID, &couComm, &couPEGroup, &couPEGroup, &type1, &type2,
&cplatm2, &atm2ocnid );
CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean from atm2" )
POP_TIMER( couComm, rankInCouComm ) // hijack this rank
#endif
int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 0, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0;
#ifdef VERBOSE
char serialWriteOptions[] = ""; // for writing in serial
std::stringstream outf;
outf << "intxAtmOcn_" << rankInCouComm << ".h5m";
std::string intxfile = outf.str(); // write in serial the intx file, for debugging
ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions );
CHECKIERR( ierr, "cannot write intx file result" )
#endif
PUSH_TIMER( "Compute the projection weights with TempestRemap" )
ierr =
iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(),
&disc_orders[0], disc_methods[1].c_str(), &disc_orders[1], &fNoBubble,
&fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve,
&fValidate, dof_tag_names[0].c_str(), dof_tag_names[1].c_str() );
CHECKIERR( ierr, "cannot compute scalar projection weights" )
// Let us now write the map file to disk and then read it back to test the I/O API in iMOAB
#ifdef MOAB_HAVE_NETCDF
const std::string atmocn_map_file_name = "atm_ocn_map2.nc";
ierr = iMOAB_WriteMappingWeightsToFile( cplAtmOcnPID, weights_identifiers[0].c_str(),
atmocn_map_file_name.c_str() );
CHECKIERR( ierr, "failed to write map file to disk" );
const std::string intx_from_file_identifier = "map-from-file";
int dummyCpl = -1;
int dummy_rowcol = -1;
int dummyType = 0;
ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, &dummyCpl, &dummy_rowcol, &dummyType,
intx_from_file_identifier.c_str(), atmocn_map_file_name.c_str() );
CHECKIERR( ierr, "failed to load map file from disk" );
#endif
#endif
PUSH_TIMER( "Compute the projection weights with TempestRemap for atm2/ocn" )
ierr =
iMOAB_ComputeScalarProjectionWeights( cplAtm2OcnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(),
CHECKIERR( ierr, "cannot compute scalar projection weights for atm2/ocn" )
const std::string atmocn_map_file_name = "atm2_ocn_map.nc";
ierr = iMOAB_WriteMappingWeightsToFile( cplAtm2OcnPID, weights_identifiers[0].c_str(),
const std::string intx_from_file_identifier = "map2-from-file";
int dummyCpl = -1;
int dummyType = 0;
ierr = iMOAB_LoadMappingWeightsFromFile( cplAtm2OcnPID, &dummyCpl, &dummy_rowcol, &dummyType,
#endif
#endif
int tagIndex[2];
int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE };
int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/;
const char* bottomFields = "a2oTbot:a2oUbot:a2oVbot";
const char* bottomProjectedFields = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj";
const char* bottomSourceFields2 = "a2oT2bot_src:a2oU2bot_src:a2oV2bot_src";
const char* bottomProjectedFields3 = "a2oT2bot_proj:a2oU2bot_proj:a2oV2bot_proj";
ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
CHECKIERR( ierr, "failed to define the field tag a2oTbot" );
ierr = iMOAB_DefineTagStorage( cplAtm2PID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] );
CHECKIERR( ierr, "failed to define the field tag a2oTbot_proj" );
#endif
ierr = iMOAB_DefineTagStorage( cplAtm2PID, bottomSourceFields2, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] );
CHECKIERR( ierr, "failed to define the field tag a2oT2bot_proj" );
ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields3, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] );
#endif
// need to make sure that the coverage mesh (created during intx method) received the tag that
// need to be projected to target so far, the coverage mesh has only the ids and global dofs;
// need to change the migrate method to accommodate any GLL tag
// now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh
// (cplAtmPID), using the new coverage graph communicator
// make the tag 0, to check we are actually sending needed data
if( cplAtmAppID >= 0 )
int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3];
* Each process in the communicator will have access to a local mesh instance, which
* will contain the original cells in the local partition and ghost entities. Number of
* vertices, primary cells, visible blocks, number of sidesets and nodesets boundary
* conditions will be returned in numProcesses 3 arrays, for local, ghost and total
* numbers.
ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc );
CHECKIERR( ierr, "failed to get num primary elems" );
int numAllElem = nelem[2];
std::vector< double > vals;
int storLeng = atmCompNDoFs * numAllElem *3; // 3 tags
int eetype = 1;
vals.resize( storLeng );
for( int k = 0; k < storLeng; k++ )
vals[k] = 0.;
ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] );
CHECKIERR( ierr, "cannot make tag nul" )
// set the tag to 0
if( cplAtm2AppID >= 0 )
* numbers.
ierr = iMOAB_GetMeshInfo( cplAtm2PID, nverts, nelem, nblocks, nsbc, ndbc );
int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags
int eetype = 1;
vals[k] = 0.;
ierr = iMOAB_SetDoubleTagStorage( cplAtm2PID, bottomSourceFields2, &storLeng, &eetype, &vals[0] );
// set the tag to 0
// start a virtual loop for number of iterations
for( int iters = 0; iters < n; iters++ )
PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" )
// as always, use nonblocking sends
// this is for projection to ocean:
ierr = iMOAB_SendElementTag( cmpAtmPID, bottomFields, &atmCouComm, &cplocn );
CHECKIERR( ierr, "cannot send tag values" )
// receive on atm on coupler pes, that was redistributed according to coverage
ierr = iMOAB_ReceiveElementTag( cplAtmPID, bottomFields, &atmCouComm, &cplocn );
CHECKIERR( ierr, "cannot receive tag values" )
POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm )
ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplocn ); // context is for ocean
CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" )
#ifdef VERBOSE
char outputFileRecvd[] = "recvAtmCoupOcn.h5m";
ierr = iMOAB_WriteMesh( cplAtmPID, outputFileRecvd, fileWriteOptions );
CHECKIERR( ierr, "could not write recvAtmCoupOcn.h5m to disk" )
#endif
/* We have the remapping weights now. Let us apply the weights onto the tag we defined
on the source mesh and get the projection on the target mesh */
PUSH_TIMER( "Apply Scalar projection weights" )
ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), bottomFields,
bottomProjectedFields );
CHECKIERR( ierr, "failed to compute projection weight application" );
if( 1 == n ) // write only for n==1 case
char outputFileTgt[] = "fOcnOnCpl1.h5m";
ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions );
CHECKIERR( ierr, "could not write fOcnOnCpl1.h5m to disk" )
// send the projected tag back to ocean pes, with send/receive tag
int tagIndexIn2;
ierr =
iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 );
CHECKIERR( ierr, "failed to define the field tag for receiving back the tags "
"a2oTbot_proj, a2oUbot_proj, a2oVbot_proj on ocn pes" );
// send the tag to ocean pes, from ocean mesh on coupler pes
// from couComm, using common joint comm ocn_coupler
// original graph (context is -1_
// need to use ocean comp id for context
context_id = cmpocn; // id for ocean on comp
ierr =
iMOAB_SendElementTag( cplOcnPID, bottomProjectedFields, &ocnCouComm, &context_id );
CHECKIERR( ierr, "cannot send tag values back to ocean pes" )
// receive on component 2, ocean
context_id = cplocn; // id for ocean on coupler
ierr = iMOAB_ReceiveElementTag( cmpOcnPID, bottomProjectedFields, &ocnCouComm,
&context_id );
CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" )
ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id );
CHECKIERR( ierr, "cannot free send/receive buffers for OCN context" )
if( ocnComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case
char outputFileOcn[] = "OcnWithProj.h5m";
ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions );
CHECKIERR( ierr, "could not write OcnWithProj.h5m to disk" )
// test results only for n == 1, for bottomTempProjectedField
if( !no_regression_test )
// the same as remap test
// get temp field on ocean, from conservative, the global ids, and dump to the baseline file
// first get GlobalIds from ocn, and fields:
int nverts[3], nelem[3];
ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 );
CHECKIERR( ierr, "failed to get ocn mesh info" );
std::vector< int > gidElems;
gidElems.resize( nelem[2] );
std::vector< double > tempElems;
tempElems.resize( nelem[2] );
// get global id storage
const std::string GidStr = "GLOBAL_ID"; // hard coded too
int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0;
ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd );
CHECKIERR( ierr, "failed to define global id tag" );
int ent_type = 1;
ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] );
CHECKIERR( ierr, "failed to get global ids" );
ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type,
&tempElems[0] );
CHECKIERR( ierr, "failed to get temperature field" );
int err_code = 1;
check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code );
if( 0 == err_code )
std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n";
#endif
PUSH_TIMER( "Send/receive data from atm2 component to coupler of all data" )
ierr = iMOAB_SendElementTag( cmpAtmPID, bottomFields, &atmCouComm, &cplatm2 );
ierr = iMOAB_ReceiveElementTag( cplAtm2PID, bottomFields, &atmCouComm, &cmpatm );
ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplatm ); // context is for ocean
// #ifdef VERBOSE
char outputFileRecvd[] = "recvAtm2CoupFull.h5m";
ierr = iMOAB_WriteMesh( cplAtm2PID, outputFileRecvd, fileWriteOptions );
CHECKIERR( ierr, "could not write recvAtmCoupLnd.h5m to disk" )
// #endif
PUSH_TIMER( "Send/receive data from atm2 coupler to ocean coupler based on coverage data" )
ierr = iMOAB_SendElementTag( cplAtm2PID, bottomFields, &couComm, &atm2ocnid );
// receive in the coverage mesh, basically
ierr = iMOAB_ReceiveElementTag( cplAtm2OcnPID, bottomSourceFields2, &couComm, &cplatm2 );
ierr = iMOAB_FreeSenderBuffers( cplAtm2PID, &atm2ocnid ); // context is intx external id
// #ifdef VERBOSE
// we should not write this one, is should be the same as recvAtm2CoupFull above
/* if( couComm != MPI_COMM_NULL && 1 == n )
char outputFileRecvd[] = "recvAtm2CoupOcnCtx.h5m";
// #endif*/
ierr = iMOAB_ApplyScalarProjectionWeights( cplAtm2OcnPID, weights_identifiers[0].c_str(),
bottomSourceFields2, bottomProjectedFields3 );
char outputFileTgt[] = "fOcnOnCpl0.h5m";
CHECKIERR( ierr, "could not write the second fOcnOnCpl0.h5m to disk" )
std::cout << "applied scalar projection\n";
int tagIndexIn2;
ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields3, &tagTypes[1],
std::cout << "defined tag agian on ocn\n";
ierr = iMOAB_SendElementTag( cplOcnPID, bottomProjectedFields3, &ocnCouComm, &context_id );
std::cout << "sent ocn data from coupler to component\n";
ierr = iMOAB_ReceiveElementTag( cmpOcnPID, bottomProjectedFields3, &ocnCouComm,
&context_id );
std::cout << "received ocn data from coupler to component\n";
std::cout << "freed send/recv ocn data from coupler to component\n";
char outputFileOcn[] = "Ocn2WithProj.h5m";
CHECKIERR( ierr, "could not write Ocn2WithProj.h5m to disk" )
int ent_type = 1;
ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type, &tempElems[0] );
int err_code = 1;
if( 0 == err_code )
std::cout << "wrote ocn data on component to disk\n";
#endif // ENABLE_ATMCPLOCN_COUPLING
} // end loop iterations n
ierr = iMOAB_DeregisterApplication( cplAtm2OcnPID );
CHECKIERR( ierr, "cannot deregister app intx AO" )
ierr = iMOAB_DeregisterApplication( cplAtmOcnPID );
ierr = iMOAB_DeregisterApplication( cmpOcnPID );
CHECKIERR( ierr, "cannot deregister app OCN1" )
#endif // ENABLE_ATMOCN_COUPLING
ierr = iMOAB_DeregisterApplication( cmpAtmPID );
CHECKIERR( ierr, "cannot deregister app ATM1" )
ierr = iMOAB_DeregisterApplication( cplOcnPID );
CHECKIERR( ierr, "cannot deregister app OCNX" )
ierr = iMOAB_DeregisterApplication( cplAtmPID );
CHECKIERR( ierr, "cannot deregister app ATMX" )
//#endif
ierr = iMOAB_Finalize();
CHECKIERR( ierr, "did not finalize iMOAB" )
// free atm coupler group and comm
if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm );
MPI_Group_free( &joinAtmCouGroup );
if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm );
if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm );
// free ocn - coupler group and comm
if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm );
MPI_Group_free( &joinOcnCouGroup );
#endif
if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm );
MPI_Group_free( &atmPEGroup );
MPI_Group_free( &ocnPEGroup );
#endif
MPI_Group_free( &couPEGroup );
MPI_Group_free( &jgroup );
MPI_Finalize();
return 0;
