bsp_tree_test.cpp File Reference
#include "moab/Core.hpp"
#include "TestUtil.hpp"
#include "moab/BSPTree.hpp"
#include "moab/CartVect.hpp"
#include "moab/BSPTreePoly.hpp"
#include "moab/Range.hpp"
#include <algorithm>
+ Include dependency graph for bsp_tree_test.cpp:
Defines
#define CHECK_RAY_XSECTS(PT, DIR, T_IN, T_OUT)
Functions
void test_set_plane ()
void test_iterator ()
void test_box_iterator ()
void test_tree_create ()
void test_box_tree_create ()
void test_leaf_containing_point_bounded_tree ()
void test_leaf_containing_point_unbounded_tree ()
void test_merge_leaf ()
void test_box_iter_neighbors ()
void test_leaf_sibling ()
void test_leaf_volume (bool box)
void test_leaf_volume_box ()
void test_leaf_volume_gen ()
void test_leaf_splits_intersects ()
void test_leaf_intersects_ray_common (bool box)
void test_box_leaf_intersects_ray ()
void test_gen_leaf_intersects_ray ()
void test_leaf_polyhedron ()
int main ()
void check_equal (const BSPTree::Plane &p1, const BSPTree::Plane &p2, const char *exp1, const char *exp2, int line, const char *file)
bool compare_hexes (const double expected[8][3], const double actual[8][3], double epsilon)
static void aabox_corners (const double min[3], const double max[3], double corners[8][3])
static void aabox_corners (double min_x, double min_y, double min_z, double max_x, double max_y, double max_z, double corners[8][3])
static std::vector< int > neighbors (const BSPTreeBoxIter &iter, const EntityHandle leaves[8], BSPTreeBoxIter::SideBits side, double epsilon)
static void box (const double pts[], int num_pts, double minpt[3], double maxpt[3])
static EntityHandle build_tree (const double points[], int num_points, BSPTree &tool)
Define Documentation
#define CHECK_RAY_XSECTS (   PT,
  DIR,
  T_IN,
  T_OUT
Value:
do                                                               \
        CHECK( iter.intersect_ray( ( PT ), ( DIR ), t_in, t_out ) ); \
        CHECK_REAL_EQUAL( ( T_IN ), t_in, 1e-6 );                    \
        CHECK_REAL_EQUAL( ( T_OUT ), t_out, 1e-6 );                  \
    } while( false )
Definition at line 1515 of file bsp_tree_test.cpp.
Referenced by test_leaf_intersects_ray_common().
Function Documentation
static void aabox_corners ( const double  min[3],
) [static]
Definition at line 222 of file bsp_tree_test.cpp.
Referenced by aabox_corners(), test_box_iterator(), test_box_tree_create(), test_leaf_containing_point_bounded_tree(), and test_merge_leaf().
    const double expt[8][3] = { { min[0], min[1], min[2] }, { max[0], min[1], min[2] }, { max[0], max[1], min[2] },
                                { min[0], max[1], min[2] }, { min[0], min[1], max[2] }, { max[0], min[1], max[2] },
                                { max[0], max[1], max[2] }, { min[0], max[1], max[2] } };
    memcpy( corners, expt, sizeof( expt ) );
static void aabox_corners ( double  min_x,
double  min_y,
double  min_z,
double  max_x,
double  max_y,
double  max_z,
) [static]
Definition at line 230 of file bsp_tree_test.cpp.
References aabox_corners().
    double min[] = { min_x, min_y, min_z };
    double max[] = { max_x, max_y, max_z };
    aabox_corners( min, max, corners );
static void box ( const double  pts[],
int  num_pts,
double  minpt[3],
double  maxpt[3]
) [static]
Examples:
DeformMeshRemap.cpp, and StructuredMeshSimple.cpp.
Definition at line 1668 of file bsp_tree_test.cpp.
Referenced by moab::BVHTree::bruteforce_find(), moab::AdaptiveKDTree::build_tree(), moab::BVHTree::build_tree(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::build_tree(), build_tree(), moab::common_tree::construct_element_map(), moab::BVHTree::construct_element_vec(), DeformMeshRemap::deform_master(), moab::BVHTree::distance_search(), moab::AdaptiveKDTree::distance_search(), do_closest_point_test(), do_ray_fire_test(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::establish_buckets(), moab::BVHTree::establish_buckets(), moab::AdaptiveKDTree::get_info(), moab::AdaptiveKDTree::get_last_iterator(), moab::AdaptiveKDTree::get_tree_iterator(), moab::ParallelMergeMesh::GetGlobalBox(), moab::Coupler::initialize_tree(), moab::Element::Map::inside_box(), TriStats::leaf(), LeafHexer::leaf(), moab::BVHTree::local_build_tree(), moab::Coupler::locate_points(), main(), moab::common_tree::operator<<(), moab::AdaptiveKDTree::point_search(), moab::BVHTree::point_search(), moab::AdaptiveKDTree::print(), moab::TreeNodePrinter::print_geometry(), moab::AdaptiveKDTree::ray_intersect_triangles(), moab::ScdInterface::remove_box(), moab::BVHTree::set_interval(), moab::Bvh_tree< _Entity_handles, _Box, _Moab, _Parametrizer >::set_interval(), moab::ScdInterface::tag_shared_vertices(), test_bound_box(), test_build_from_pts(), test_build_from_tri(), moab::Coupler::test_local_box(), test_locator(), test_save(), TriStats::TriStats(), moab::BoundBox::update(), TriCounter::visit(), TreeValidator::visit(), and CubitWriter::visit().
    minpt[0] = maxpt[0] = pts[0];
    minpt[1] = maxpt[1] = pts[1];
    minpt[2] = maxpt[2] = pts[2];
    for( int i = 1; i < num_pts; ++i )
        for( int d = 0; d < 3; ++d )
            if( pts[3 * i + d] < minpt[d] ) minpt[d] = pts[3 * i + d];
            if( pts[3 * i + d] > maxpt[d] ) maxpt[d] = pts[3 * i + d];
static EntityHandle build_tree ( const double  points[],
int  num_points,
BSPTree &  tool
) [static]
Definition at line 1683 of file bsp_tree_test.cpp.
References moab::Interface::add_entities(), moab::CartVect::array(), moab::Range::begin(), box(), CHECK, CHECK_ERR, moab::BSPTree::create_tree(), moab::Interface::create_vertex(), moab::Range::end(), ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), leaf, moab::BSPTree::leaf_containing_point(), length_squared(), MB_ENTITY_NOT_FOUND, MB_SUCCESS, moab::BSPTree::moab(), moab::CartVect::normalize(), moab::BSPTree::split_leaf(), and moab::BSPTreeIter::step().
Referenced by main(), and test_leaf_polyhedron().
    // create points
    ErrorCode rval;
    std::vector< EntityHandle > pts( num_points );
    for( int i = 0; i < num_points; ++i )
        rval = tool.moab()->create_vertex( points + 3 * i, pts[i] );CHECK_ERR( rval );
    // calculate bounding box of tree
    double minpt[3], maxpt[3];
    box( points, num_points, minpt, maxpt );
    // create initial (1-node) tree
    EntityHandle root;
    rval = tool.create_tree( minpt, maxpt, root );CHECK_ERR( rval );
    BSPTreeIter iter;
    rval = tool.get_tree_iterator( root, iter );CHECK_ERR( rval );
    rval = tool.moab()->add_entities( root, &pts[0], pts.size() );CHECK_ERR( rval );
    // build tree
    std::vector< EntityHandle > left_pts, right_pts;
    std::vector< CartVect > coords( num_points ), tmp_coords;
    for( ; MB_SUCCESS == rval; rval = iter.step() )
        pts.clear();
        rval = tool.moab()->get_entities_by_handle( iter.handle(), pts );CHECK_ERR( rval );
        while( pts.size() > 1 )
            coords.resize( pts.size() );
            rval = tool.moab()->get_coords( &pts[0], pts.size(), coords[0].array() );CHECK_ERR( rval );
            // find two points far apart apart
            std::vector< CartVect >* ptr;
            if( coords.size() < 10 )
                ptr = &coords;
            else
                tmp_coords.resize( 16 );
                CartVect pn, px;
                box( coords[0].array(), coords.size(), pn.array(), px.array() );
                tmp_coords[8]  = pn;
                tmp_coords[9]  = CartVect( px[0], pn[1], pn[2] );
                tmp_coords[10] = CartVect( px[0], px[1], pn[2] );
                tmp_coords[11] = CartVect( pn[0], px[1], pn[2] );
                tmp_coords[12] = CartVect( pn[0], pn[1], px[2] );
                tmp_coords[13] = CartVect( px[0], pn[1], px[2] );
                tmp_coords[14] = px;
                tmp_coords[15] = CartVect( pn[0], px[1], px[2] );
                for( int i = 0; i < 8; ++i )
                    tmp_coords[i] = coords[0];
                    for( size_t j = 1; j < coords.size(); ++j )
                        if( ( coords[j] - tmp_coords[i + 8] ).length_squared() <
                            ( tmp_coords[i] - tmp_coords[i + 8] ).length_squared() )
                            tmp_coords[i] = coords[j];
                tmp_coords.resize( 8 );
                ptr = &tmp_coords;
            size_t pt1 = 0, pt2 = 0;
            double lsqr = -1;
            for( size_t i = 0; i < ptr->size(); ++i )
                for( size_t j = 0; j < ptr->size(); ++j )
                    double ls = ( ( *ptr )[i] - ( *ptr )[j] ).length_squared();
                    if( ls > lsqr )
                        lsqr = ls;
                        pt1  = i;
                        pt2  = j;
            // if all points are coincident
            if( lsqr <= 1e-12 ) break;
            // define normal orthogonal to line through two points
            CartVect norm = ( *ptr )[pt1] - ( *ptr )[pt2];
            norm.normalize();
            // find mean position for plane
            double coeff = 0.0;
            for( size_t i = 0; i < coords.size(); ++i )
                coeff -= norm % coords[i];
            coeff /= coords.size();
            // left/right sort points
            left_pts.clear();
            right_pts.clear();
                double d = -( norm % coords[i] );
                if( d >= coeff )
                    left_pts.push_back( pts[i] );
                else
                    right_pts.push_back( pts[i] );
            rval = tool.split_leaf( iter, BSPTree::Plane( norm.array(), coeff ), left_pts, right_pts );CHECK_ERR( rval );
            CHECK( !left_pts.empty() && !right_pts.empty() );
            pts.swap( left_pts );
        //    printf("Leaf %d contains %d vertices: ", (int)ID_FROM_HANDLE(iter.handle()),
        //                                             (int)(pts.size()) );
        //    for (size_t i = 0; i < pts.size(); ++i)
        //      printf( "%d, ", (int)ID_FROM_HANDLE(pts[i]));
        //    printf("\n");
    CHECK( rval == MB_ENTITY_NOT_FOUND );
    // verify that tree is constructed correctly
        CartVect pt( points + 3 * i );
        EntityHandle leaf;
        rval = tool.leaf_containing_point( root, pt.array(), leaf );CHECK_ERR( rval );
        Range ents;
        rval = tool.moab()->get_entities_by_handle( leaf, ents );CHECK_ERR( rval );
        bool found = false;
        for( Range::iterator j = ents.begin(); j != ents.end(); ++j )
            CartVect ent_coords;
            rval = tool.moab()->get_coords( &*j, 1, ent_coords.array() );CHECK_ERR( rval );
            if( ( pt - ent_coords ).length_squared() < 1e-6 ) found = true;
        CHECK( found );
    return root;
void check_equal ( const BSPTree::Plane &  p1,
const BSPTree::Plane &  p2,
const char *  exp1,
const char *  exp2,
int  line,
const char *  file
Definition at line 67 of file bsp_tree_test.cpp.
References moab::BSPTree::Plane::coeff, FLAG_ERROR, and moab::BSPTree::Plane::norm.
Referenced by check_equal(), and check_equal_eigvect().
    if( fabs( p1.norm[0] - p2.norm[0] ) > 1e-6 || fabs( p1.norm[1] - p2.norm[1] ) > 1e-6 ||
        fabs( p1.norm[2] - p2.norm[2] ) > 1e-6 || fabs( p1.coeff - p2.coeff ) > 1e-6 )
        printf( "Equality Test Failed: %s == %s\n", exp1, exp2 );
        printf( "  at line %d of '%s'\n", line, file );
        printf( "  Expected: %f x + %f y + %f z + %f = 0\n", p1.norm[0], p1.norm[1], p1.norm[2], p1.coeff );
        printf( "  Actual  : %f x + %f y + %f z + %f = 0\n", p2.norm[0], p2.norm[1], p2.norm[2], p2.coeff );
        printf( "\n" );
        FLAG_ERROR;
bool compare_hexes ( const double  expected[8][3],
double  epsilon
Definition at line 181 of file bsp_tree_test.cpp.
Referenced by test_box_iterator(), test_box_tree_create(), test_leaf_containing_point_bounded_tree(), and test_merge_leaf().
    // for each of three possible rotations
    const int rotation_maps[3][8] = {
        { 0, 1, 2, 3, 4, 5, 6, 7 }, { 3, 2, 6, 7, 0, 1, 5, 4 }, { 7, 3, 2, 6, 4, 0, 1, 5 } };
    for( int i = 0; i < 3; ++i )
        // compare for rotationts about axis from face 4 to 5
        for( int j = 0; j < 4; ++j )
            bool match = true;
            // for each face vertex
            for( int k = 0; k < 4 && match; ++k )
                // for each coordinate
                    if( fabs( expected[( j + k ) % 4][d] - actual[rotation_maps[i][k]][d] ) > epsilon ||
                        fabs( expected[( j + k ) % 4 + 4][d] - actual[rotation_maps[i][k + 4]][d] ) > epsilon )
                        match = false;
                        break;
            if( match ) return true;
    printf( "Hex vertex copmarison failed.\n" );
    printf( "           Exected                         Actual\n" );
    for( int v = 0; v < 8; ++v )
        printf( "% 9f % 9f % 9f   % 9f % 9f % 9f\n", expected[v][0], expected[v][1], expected[v][2], actual[v][0],
                actual[v][1], actual[v][2] );
    return false;
static std::vector< int > neighbors ( const BSPTreeBoxIter &  iter,
double  epsilon
) [static]
Definition at line 972 of file bsp_tree_test.cpp.
References CHECK_ERR, ErrorCode, and moab::BSPTreeBoxIter::get_neighbors().
Referenced by MetisPartitioner::assemble_graph(), ZoltanPartitioner::assemble_graph(), MetisPartitioner::assemble_taggedsets_graph(), moab::Intx2Mesh::DetermineOrderedNeighbors(), get_part_boundary_verts(), iMeshP_getNumPartNborsArr(), moab::Intx2Mesh::intersect_meshes(), ZoltanPartitioner::partition_owned_cells(), test_box_iter_neighbors(), test_entity_copy_parts(), and test_get_neighbors().
    std::vector< BSPTreeBoxIter > list;
    ErrorCode rval = iter.get_neighbors( side, list, epsilon );CHECK_ERR( rval );
    std::vector< int > results;
    for( size_t i = 0; i < list.size(); ++i )
        results.push_back( std::find( leaves, leaves + 8, list[i].handle() ) - leaves );
    std::sort( results.begin(), results.end() );
    return results;
Definition at line 987 of file bsp_tree_test.cpp.
References moab::BSPTreeBoxIter::B0154, moab::BSPTreeBoxIter::B1265, moab::BSPTreeBoxIter::B2376, moab::BSPTreeBoxIter::B3047, moab::BSPTreeBoxIter::B3210, moab::BSPTreeBoxIter::B4567, CHECK_EQUAL, CHECK_ERR, moab::BSPTree::create_tree(), ErrorCode, moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), neighbors(), moab::BSPTree::split_leaf(), and moab::BSPTreeBoxIter::step().
Referenced by main().
    Core moab;
    BSPTree tool( &moab );
    ErrorCode rval;
    EntityHandle root;
    BSPTreeBoxIter iter;
    BSPTree::Plane p;
    /*  Build Tree */
    const double corners[8][3] = { { 0, 0, 0 }, { 8, 0, 0 }, { 8, 2, 0 }, { 0, 2, 0 },
                                   { 0, 0, 1 }, { 8, 0, 1 }, { 8, 2, 1 }, { 0, 2, 1 } };
    rval                       = tool.create_tree( corners, root );CHECK_ERR( rval );
    EntityHandle leaves[8];
       |                   0*                   |
    p    = BSPTree::Plane( 1, 0, 0, -4 );
    rval = tool.split_leaf( iter, p );CHECK_ERR( rval );
       |         0*        |         1          |
    p    = BSPTree::Plane( -1, 0, 0, 2 );
       |    1    |    0*   |         2          |
    p    = BSPTree::Plane( 0, 1, 0, -1 );
       |         |    1    |                    |
       |    2    +---------+         3          |
       |         |    0*   |                    |
    leaves[0] = iter.handle();
    rval      = iter.step();CHECK_ERR( rval );
    leaves[1] = iter.handle();
       |         |    1    |                    |
       |    2*   +---------+         3          |
       |         |    0    |                    |
    p    = BSPTree::Plane( 0, -1, 0, 1 );
       |    2*   |    1    |                    |
       +---------+---------+         4          |
       |    3    |    0    |                    |
    leaves[2] = iter.handle();
    leaves[3] = iter.handle();
       |    2    |    1    |                    |
       +---------+---------+         4*         |
       |    3    |    0    |                    |
       |    2    |    1    |         5          |
       |    3    |    0    |         4*         |
    p    = BSPTree::Plane( 1, 0, 0, -6 );
       |    2    |    1    |          6         |
       |    3    |    0    |    4*    |    5    |
    leaves[4] = iter.handle();
    leaves[5] = iter.handle();
       |    2    |    1    |          6*        |
       |    3    |    0    |     4    |    5    |
    p    = BSPTree::Plane( -1, 0, 0, 6 );
       |    2    |    1    |     7    |    6    |
       |    3    |    0    |     4    |    5    |
    leaves[6] = iter.handle();
    leaves[7] = iter.handle();
    /* check all neighbors of each leaf */
    // NOTE:  Several values in the expected result list are
    //        commented out in the tests below.  When the tolerance
    //        is greater than zero, the search algorithm may or may
    //        not return leaves that are not face-adjacent (e.g. adjacent
    //        only along edges or at corners.)  The determining factor
    //        for whether or not such a neighbor is returned is which
    //        sub-tree of the split that defined the source leaf side
    //        the neighbor is on.  The algorithm will not search the subtree
    //        of the split that created the side and that contains the
    //        source leaf.
    // check neighbors of leaf 0
    std::vector< int > expected;
    CHECK_EQUAL( leaves[0], iter.handle() );
    expected.clear();
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, 1e-6 ) );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3210, 1e-6 ) );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B4567, 1e-6 ) );
    expected.push_back( 3 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, -1e-6 ) );
    expected.insert( expected.begin(), 2 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B3047, 1e-6 ) );
    expected.clear();
    expected.push_back( 1 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, -1e-6 ) );
    // See NOTE //  expected.push_back( 2 ); expected.push_back( 7 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B2376, 1e-6 ) );
    expected.clear();
    expected.push_back( 4 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, -1e-6 ) );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B1265, 1e-6 ) );
    // check neighbors of leaf 1
    CHECK_ERR( iter.step() );
    CHECK_EQUAL( leaves[1], iter.handle() );
    expected.clear();
    expected.clear();
    expected.push_back( 0 );
    CHECK_EQUAL( expected, neighbors( iter, leaves, BSPTreeBoxIter::B0154, -1e-6 ) );
    // See NOTE //  expected.push_back( 3 ); expected.push_back( 4 );
    expected.clear();
    expected.insert( expected.begin(), 4 );
       |    2    |    1    |     7    |    6    |
       |    3    |    0    |     4    |    5    |
    // check neighbors of leaf 2
    CHECK_EQUAL( leaves[2], iter.handle() );
    expected.clear();
    // See NOTE // expected.insert( expected.begin(), 0 );
    expected.clear();
    // check neighbors of leaf 3
    CHECK_EQUAL( leaves[3], iter.handle() );
    expected.clear();
    // See NOTE // expected.insert( expected.begin(), 1 );
    expected.clear();
       |    2    |    1    |     7    |    6    |
       |    3    |    0    |     4    |    5    |
    // check neighbors of leaf 4
    CHECK_EQUAL( leaves[4], iter.handle() );
    expected.clear();
    expected.clear();
    expected.insert( expected.begin(), 6 );
    expected.clear();
    expected.push_back( 5 );
    // See NOTE // expected.push_back( 6 );
    // check neighbors of leaf 5
    CHECK_EQUAL( leaves[5], iter.handle() );
    expected.clear();
    // See NOTE // expected.push_back( 7 );
    expected.clear();
       |    2    |    1    |     7    |    6    |
       |    3    |    0    |     4    |    5    |
    // check neighbors of leaf 6
    CHECK_EQUAL( leaves[6], iter.handle() );
    expected.clear();
    // See NOTE // expected.insert( expected.begin(), 4 );
    expected.clear();
    // check neighbors of leaf 7
    CHECK_EQUAL( leaves[7], iter.handle() );
    expected.clear();
    expected.clear();
    expected.clear();
    // See NOTE // expected.insert( expected.begin(), 5 );
Definition at line 243 of file bsp_tree_test.cpp.
References aabox_corners(), moab::BSPTreeBoxIter::back(), CHECK, CHECK_EQUAL, CHECK_ERR, compare_hexes(), moab::BSPTree::create_tree(), moab::BSPTreeIter::depth(), ErrorCode, moab::BSPTreeBoxIter::get_box_corners(), moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_end_iterator(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), MB_ENTITY_NOT_FOUND, moab::BSPTree::Plane::norm, moab::BSPTree::split_leaf(), moab::BSPTreeBoxIter::step(), and moab::BSPTreeIter::tool().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    const double min[3] = { -1, -2, -3 };
    const double max[3] = { 3, 2, 1 };
    // create a depth-1 tree
    rval = tool.create_tree( min, max, root );CHECK_ERR( rval );
    // check initial state of iterator
    CHECK_EQUAL( &tool, iter.tool() );
    CHECK_EQUAL( root, iter.handle() );
    CHECK_EQUAL( 1u, iter.depth() );
    // check initial corner values
    double corners[8][3], expt[8][3];
    aabox_corners( min, max, expt );
    rval = iter.get_box_corners( corners );CHECK_ERR( rval );
    CHECK( compare_hexes( expt, corners, 1e-6 ) );
    // should fail if at root
    BSPTree::Plane p;
    rval = iter.get_parent_split_plane( p );
    CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
    // check that step past end returns correct value
    rval = iter.step();
    // reset iterator
    // check that step past start returns correct value
    rval = iter.back();
    // reset iterator
    // insert a single split plane
    rval = tool.split_leaf( iter, BSPTree::Plane( 2, 0, 0, 0 ) );CHECK_ERR( rval );
    // check initial location
    CHECK_EQUAL( 2u, iter.depth() );
    CHECK( iter.handle() != root );
    // create new iterators at left and right ends
    BSPTreeIter left, right;
    rval = tool.get_tree_iterator( root, left );CHECK_ERR( rval );
    rval = tool.get_tree_end_iterator( root, right );CHECK_ERR( rval );
    // compare post-split iterator to left
    CHECK_EQUAL( left.depth(), iter.depth() );
    CHECK_EQUAL( left.handle(), iter.handle() );
    // check box
        if( expt[i][0] > 0 ) expt[i][0] = 0;
    // step to other leaf
    // check location
    // compare stepped iterator to right
    CHECK_EQUAL( right.depth(), iter.depth() );
    CHECK_EQUAL( right.handle(), iter.handle() );
    // check box
        if( expt[i][0] < 0 ) expt[i][0] = 0;
    // step to back to first leaf
    rval = iter.back();CHECK_ERR( rval );
    // compare to left
    // check box
    // check plane
    // should have unit normal
    left.get_parent_split_plane( p );
    CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, 0 ), p );
    p.norm[0] = 11;
    right.get_parent_split_plane( p );
    // check step past ends
    rval = left.back();
    rval = right.step();
Definition at line 32 of file bsp_tree_test.cpp.
References test_leaf_intersects_ray_common().
Definition at line 435 of file bsp_tree_test.cpp.
References aabox_corners(), CHECK, CHECK_EQUAL, CHECK_ERR, compare_hexes(), moab::BSPTree::create_tree(), moab::BSPTreeIter::depth(), ErrorCode, moab::BSPTreeBoxIter::get_box_corners(), moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), MB_ENTITY_NOT_FOUND, moab::BSPTree::split_leaf(), moab::BSPTreeBoxIter::step(), and moab::BSPTreeIter::tool().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTree::Plane p;
    const double min[3] = { -2, -2, -2 };
    const double max[3] = { 2, 2, 2 };
    // Try splits that should fail because they
    // do not intersect the leaf at all
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 1, 4 ) );
    CHECK_EQUAL( MB_FAILURE, rval );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 0, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 0, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, 7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, -7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, 7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, -7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, 7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, -7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, 7 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, -7 ) );
    // Try a split that should fail because the
    // resulting leaf would not be a hexahedron.
    // Clip each corner twice using planes with opposing normals
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, -1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, -1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, -1, 4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 1, -4 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, -1, 4 ) );
    // Clip each edge
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, -1, 0, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, -1, 0, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 0, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 0, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, -1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, -1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, 1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 0, -1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, -1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 0, 1, -2 ) );
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 0, 1, -2 ) );
    // verify that iterator is still valid after many failed splits
    // split with z=0
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, 0.5, 0 ) );CHECK_ERR( rval );
    // check that parent split plane is correct
    rval = iter.get_parent_split_plane( p );CHECK_ERR( rval );
    CHECK_EQUAL( BSPTree::Plane( 0, 0, 1, 0 ), p );
    // check that box corners are correct
    for( unsigned i = 0; i < 8; ++i )
        if( expt[i][2] > 0.0 ) expt[i][2] = 0.0;
    // split with z=-1 and normal in opposite direction
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 0, -2, -2 ) );CHECK_ERR( rval );
    CHECK_EQUAL( 3u, iter.depth() );
        if( expt[i][2] < -1.0 ) expt[i][2] = -1.0;
    // step to next leaf (z < -1)
        if( expt[i][2] > -1.0 ) expt[i][2] = -1.0;
    // split at x = -1
    rval = tool.split_leaf( iter, BSPTree::Plane( -0.1, 0, 0, -0.1 ) );CHECK_ERR( rval );
    CHECK_EQUAL( 4u, iter.depth() );
    CHECK_EQUAL( BSPTree::Plane( -1, 0, 0, -1 ), p );
    // check that leaf box is correct
    aabox_corners( -1, -2, -2, 2, 2, -1, expt );
    // split at x = 1
    rval = tool.split_leaf( iter, BSPTree::Plane( 5, 0, 0, -5 ) );CHECK_ERR( rval );
    CHECK_EQUAL( 5u, iter.depth() );
    CHECK_EQUAL( BSPTree::Plane( 1, 0, 0, -1 ), p );
    aabox_corners( -1, -2, -2, 1, 2, -1, expt );
    // split at y = -1
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, -1, 0, -1 ) );CHECK_ERR( rval );
    CHECK_EQUAL( 6u, iter.depth() );
    CHECK_EQUAL( BSPTree::Plane( 0, -1, 0, -1 ), p );
    aabox_corners( -1, -1, -2, 1, 2, -1, expt );
    // split at y = 1
    rval = tool.split_leaf( iter, BSPTree::Plane( 0, 1, 0, -1 ) );CHECK_ERR( rval );
    CHECK_EQUAL( 7u, iter.depth() );
    CHECK_EQUAL( BSPTree::Plane( 0, 1, 0, -1 ), p );
    aabox_corners( -1, -1, -2, 1, 1, -1, expt );
    // iterate over tree, verifying
    CHECK_EQUAL( BSPTree::Plane( 0, 0, -1, -1 ), p );
    aabox_corners( -2, -2, -1, 2, 2, 0, expt );
    aabox_corners( -1, 1, -2, 1, 2, -1, expt );
    aabox_corners( -1, -2, -2, 1, -1, -1, expt );
    aabox_corners( 1, -2, -2, 2, 2, -1, expt );
    aabox_corners( -2, -2, -2, -1, 2, -1, expt );
    aabox_corners( -2, -2, 0, 2, 2, 2, expt );
    // no more leaves
    rval = iter.step();
Definition at line 36 of file bsp_tree_test.cpp.
void test_iterator ( )
Definition at line 96 of file bsp_tree_test.cpp.
References moab::BSPTreeIter::back(), CHECK, CHECK_EQUAL, CHECK_ERR, moab::BSPTree::create_tree(), moab::BSPTreeIter::depth(), ErrorCode, moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_end_iterator(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), MB_ENTITY_NOT_FOUND, moab::BSPTree::split_leaf(), moab::BSPTreeIter::step(), and moab::BSPTreeIter::tool().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTreeIter iter;
    rval = tool.create_tree( root );CHECK_ERR( rval );
    BSPTree::Plane p;
    rval = iter.step();
    // reset iterator
    rval = iter.back();
    // reset iterator
    // check location
    // compare to left
    // check plane
    p.norm[0] = 11;
    rval = left.back();
Definition at line 706 of file bsp_tree_test.cpp.
References aabox_corners(), CHECK, CHECK_EQUAL, CHECK_ERR, compare_hexes(), moab::BSPTree::create_tree(), ErrorCode, moab::BSPTreeBoxIter::get_box_corners(), moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), moab::BSPTree::leaf_containing_point(), MB_ENTITY_NOT_FOUND, moab::BSPTree::split_leaf(), and moab::BSPTreeIter::step().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTreeIter iter;
    BSPTreeBoxIter b_iter;
    BSPTree::Plane p;
    EntityHandle h;
    double expected[8][3], corners[8][3];
    /*  Build Tree
      1.0 +---------+--------------+
          |    A    |              |
      0.7 +---------+      C       |
          |    B    |              |
          |         +--------------+ 0.3
          |         |      D       |
      0.0 +---------+--------------+
          0.0       0.4            1.0  */
    const BSPTree::Plane X_split( 1.0, 0.0, 0.0, -0.4 );
    const BSPTree::Plane AB_split( 0.0, -1.0, 0.0, 0.7 );
    const BSPTree::Plane CD_split( 0.0, -1.0, 0.0, 0.3 );
    const double min[3] = { 0, 0, 0 };
    const double max[3] = { 1, 1, 1 };
    rval = tool.split_leaf( iter, X_split );CHECK_ERR( rval );
    rval = tool.split_leaf( iter, AB_split );CHECK_ERR( rval );
    const EntityHandle A = iter.handle();
    const EntityHandle B = iter.handle();
    rval = tool.split_leaf( iter, CD_split );CHECK_ERR( rval );
    const EntityHandle C = iter.handle();
    const EntityHandle D = iter.handle();
    // Test queries inside tree
    const double A_point[] = { 0.1, 0.8, 0.5 };
    rval                   = tool.leaf_containing_point( root, A_point, h );CHECK_ERR( rval );
    CHECK_EQUAL( A, h );
    rval = tool.leaf_containing_point( root, A_point, iter );CHECK_ERR( rval );
    CHECK_EQUAL( A, iter.handle() );
    CHECK_EQUAL( AB_split, p );
    rval = tool.leaf_containing_point( root, A_point, b_iter );CHECK_ERR( rval );
    CHECK_EQUAL( A, b_iter.handle() );
    aabox_corners( 0.0, 0.7, 0.0, 0.4, 1.0, 1.0, expected );
    rval = b_iter.get_box_corners( corners );CHECK_ERR( rval );
    CHECK( compare_hexes( expected, corners, 1e-6 ) );
    const double B_point[] = { 0.3, 0.1, 0.6 };
    rval                   = tool.leaf_containing_point( root, B_point, h );CHECK_ERR( rval );
    CHECK_EQUAL( B, h );
    rval = tool.leaf_containing_point( root, B_point, iter );CHECK_ERR( rval );
    CHECK_EQUAL( B, iter.handle() );
    rval = tool.leaf_containing_point( root, B_point, b_iter );CHECK_ERR( rval );
    CHECK_EQUAL( B, b_iter.handle() );
    aabox_corners( 0.0, 0.0, 0.0, 0.4, 0.7, 1.0, expected );
    const double C_point[] = { 0.9, 0.9, 0.1 };
    rval                   = tool.leaf_containing_point( root, C_point, h );CHECK_ERR( rval );
    CHECK_EQUAL( C, h );
    rval = tool.leaf_containing_point( root, C_point, iter );CHECK_ERR( rval );
    CHECK_EQUAL( C, iter.handle() );
    CHECK_EQUAL( CD_split, p );
    rval = tool.leaf_containing_point( root, C_point, b_iter );CHECK_ERR( rval );
    CHECK_EQUAL( C, b_iter.handle() );
    aabox_corners( 0.4, 0.3, 0.0, 1.0, 1.0, 1.0, expected );
    const double D_point[] = { 0.5, 0.2, 0.9 };
    rval                   = tool.leaf_containing_point( root, D_point, h );CHECK_ERR( rval );
    CHECK_EQUAL( D, h );
    rval = tool.leaf_containing_point( root, D_point, iter );CHECK_ERR( rval );
    CHECK_EQUAL( D, iter.handle() );
    rval = tool.leaf_containing_point( root, D_point, b_iter );CHECK_ERR( rval );
    CHECK_EQUAL( D, b_iter.handle() );
    aabox_corners( 0.4, 0.0, 0.0, 1.0, 0.3, 1.0, expected );
    // Try a couple points outside of the tree
    const double above_pt[] = { 0.5, 0.5, 2.0 };
    rval                    = tool.leaf_containing_point( root, above_pt, b_iter );
    const double left_pt[] = { -1.0, 0.5, 0.5 };
    rval                   = tool.leaf_containing_point( root, left_pt, b_iter );
Definition at line 822 of file bsp_tree_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::BSPTree::create_tree(), ErrorCode, moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), moab::BSPTree::leaf_containing_point(), moab::BSPTree::split_leaf(), and moab::BSPTreeIter::step().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTreeIter iter;
    BSPTree::Plane p;
    EntityHandle h;
    /*  Build Tree
         \  C  o (0,4,0)
         B   \ |         D
       ________o (0,0,0)
           A      \
                   o (1,-2,0)
    const BSPTree::Plane X_split( 2.0, 1.0, 0.0, 0.0 );
    const BSPTree::Plane AB_split( 0.0, 1.0, 0.0, 0.0 );
    const BSPTree::Plane CD_split( 1.0, 0.0, 0.0, 0.0 );
    const double A_point[] = { -1000, -1000, -1000 };
    const double B_point[] = { -3, 1, 100 };
    const double C_point[] = { -10, 500, 0 };
    const double D_point[] = { 10, 500, 0 };
void test_leaf_intersects_ray_common ( bool  box)
Start with only root box for initial testing
Now split twice and test the bottom right corne
Definition at line 1523 of file bsp_tree_test.cpp.
References CHECK, CHECK_ERR, CHECK_RAY_XSECTS, moab::BSPTree::create_tree(), ErrorCode, moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::intersect_ray(), moab::BSPTree::split_leaf(), moab::BSPTreeIter::step(), moab::BSPTree::X, and moab::BSPTree::Y.
Referenced by test_box_leaf_intersects_ray(), and test_gen_leaf_intersects_ray().
    ErrorCode rval;
    Core moab;
    double t_in, t_out;
    /** Start with only root box for initial testing **/
    /*  (1,5,-3)   (2,5,-3)
              o----o
   (1,5,-1)o----o       \
           |  :  Y \        \
           |  :  +-->X   \        \ (6,1,-3)
           |  o./..........\.......o
           | . L             \    /
           |. Z                \ /
           o--------------------o
    (1,1,-1)                    (6,1,-1)
    EntityHandle root;
    const double corners[][3] = { { 1, 1, -3 }, { 6, 1, -3 }, { 2, 5, -3 }, { 1, 5, -3 },
                                  { 1, 1, -1 }, { 6, 1, -1 }, { 2, 5, -1 }, { 1, 5, -1 } };
    BSPTreeIter gen_iter;
    BSPTreeBoxIter box_iter;
    BSPTreeIter& iter = box ? static_cast< BSPTreeIter& >( box_iter ) : gen_iter;
    // start with point inside box
    const double pt1[]  = { 3.5, 3, -2 };
    const double dir1[] = { 0.1, 0.1, 0.1 };
    CHECK_RAY_XSECTS( pt1, dir1, 0, 2.5 );
    const double dir2[] = { 5, 5, 5 };
    CHECK_RAY_XSECTS( pt1, dir2, 0, 0.05 );
    const double pxdir[] = { 1, 0, 0 };
    CHECK_RAY_XSECTS( pt1, pxdir, 0, 0.5 );
    const double nxdir[] = { -1, 0, 0 };
    CHECK_RAY_XSECTS( pt1, nxdir, 0, 2.5 );
    const double pydir[] = { 0, 1, 0 };
    CHECK_RAY_XSECTS( pt1, pydir, 0, 0.5 );
    const double nydir[] = { 0, -1, 0 };
    CHECK_RAY_XSECTS( pt1, nydir, 0, 2 );
    const double pzdir[] = { 0, 0, 1 };
    CHECK_RAY_XSECTS( pt1, pzdir, 0, 1 );
    const double nzdir[] = { 0, 0, -1 };
    CHECK_RAY_XSECTS( pt1, nzdir, 0, 1 );
    // point below box
    const double pt2[] = { 3.5, 3, -4 };
    CHECK( !iter.intersect_ray( pt2, dir1, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, dir2, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, pxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, nxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt2, nydir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt2, pzdir, 1, 3 );
    CHECK( !iter.intersect_ray( pt2, nzdir, t_in, t_out ) );
    // point right of box
    const double pt3[] = { 7, 3, -2 };
    CHECK( !iter.intersect_ray( pt3, dir1, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, dir2, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, pxdir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt3, nxdir, 3, 6 );
    CHECK( !iter.intersect_ray( pt3, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, nydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, pzdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt3, nzdir, t_in, t_out ) );
    // a few more complex test cases
    const double dira[] = { -2, -2, 0 };
    CHECK_RAY_XSECTS( pt3, dira, 0.75, 1.0 );
    const double dirb[] = { -1, -2.1, 0 };
    CHECK( !iter.intersect_ray( pt3, dirb, t_in, t_out ) );
    /** Now split twice and test the bottom right corne **/
    BSPTree::Plane Y3( BSPTree::Y, 3.0 );
    rval = tool.split_leaf( iter, Y3 );CHECK_ERR( rval );
    BSPTree::Plane X2( BSPTree::X, 2.0 );
    rval = tool.split_leaf( iter, X2 );CHECK_ERR( rval );
               (2,3,-3)
                   o--------o (4,3,-3)
        (2,3,-1)o--------o(4,3,-1)\ (6,1,-3)
                |  o.......\.......o
                o---------------o
           (2,1,-1)             (6,1,-1)
    const double pt4[] = { 4, 2, -2 };
    CHECK_RAY_XSECTS( pt4, dir1, 0, 5 );
    CHECK_RAY_XSECTS( pt4, dir2, 0, 0.1 );
    CHECK_RAY_XSECTS( pt4, pxdir, 0, 1 );
    CHECK_RAY_XSECTS( pt4, nxdir, 0, 2 );
    CHECK_RAY_XSECTS( pt4, pydir, 0, 1 );
    CHECK_RAY_XSECTS( pt4, nydir, 0, 1 );
    CHECK_RAY_XSECTS( pt4, pzdir, 0, 1 );
    CHECK_RAY_XSECTS( pt4, nzdir, 0, 1 );
    // point below box
    const double pt5[] = { 4, 2, -4 };
    CHECK( !iter.intersect_ray( pt5, dir1, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt5, dir2, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt5, pxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt5, nxdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt5, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt5, nydir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt5, pzdir, 1, 3 );
    CHECK( !iter.intersect_ray( pt5, nzdir, t_in, t_out ) );
    const double pt6[] = { 7, 2, -2 };
    CHECK( !iter.intersect_ray( pt6, dir1, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt6, dir2, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt6, pxdir, t_in, t_out ) );
    CHECK_RAY_XSECTS( pt6, nxdir, 2, 5 );
    CHECK( !iter.intersect_ray( pt6, pydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt6, nydir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt6, pzdir, t_in, t_out ) );
    CHECK( !iter.intersect_ray( pt6, nzdir, t_in, t_out ) );
    const double dird[] = { -2, -2, 0 };
    CHECK_RAY_XSECTS( pt6, dird, 0.5, 0.5 );
    const double dire[] = { -3, -2, 0 };
    CHECK_RAY_XSECTS( pt6, dire, 0.4, 0.5 );
    const double dirf[] = { -2, -2.1, 0 };
    CHECK( !iter.intersect_ray( pt6, dirf, t_in, t_out ) );
Definition at line 1824 of file bsp_tree_test.cpp.
References build_tree(), moab::BSPTreeIter::calculate_polyhedron(), CHECK, CHECK_ERR, ErrorCode, moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), moab::BSPTreePoly::is_point_contained(), moab::BSPTreePoly::is_valid(), MB_SUCCESS, moab::BSPTree::moab(), moab::BSPTreeIter::step(), and moab::BSPTreePoly::volume().
    // array of 20 points used to construct tree
    static const double points[] = { 7, 6, 3, 5, 3, 5, 9, 2, 6, 7, 2, 1, 3, 9, 0, 6, 0, 6, 1, 6,
                                     2, 9, 7, 8, 2, 0, 2, 5, 7, 3, 2, 2, 9, 7, 9, 8, 1, 6, 3, 3,
                                     9, 2, 4, 9, 1, 4, 8, 7, 3, 0, 5, 0, 1, 6, 2, 3, 6, 1, 6, 0 };
    const int num_pts            = sizeof( points ) / ( 3 * sizeof( double ) );
    ErrorCode rval;
    Core moab;
    EntityHandle root = build_tree( points, num_pts, tool );
    BSPTreeIter iter;
    std::vector< EntityHandle > pts;
    std::vector< CartVect > coords;
    for( ; rval == MB_SUCCESS; rval = iter.step() )
        BSPTreePoly poly;
        rval = iter.calculate_polyhedron( poly );CHECK_ERR( rval );
        CHECK( poly.is_valid() );
        CHECK( poly.volume() > 0.0 );
        pts.clear();
        CHECK( !pts.empty() );
        for( size_t i = 0; i < pts.size(); ++i )
            CHECK( poly.is_point_contained( coords[i] ) );
Definition at line 1441 of file bsp_tree_test.cpp.
References CHECK, CHECK_EQUAL, CHECK_ERR, moab::BSPTree::create_tree(), ErrorCode, moab::BSPTree::Plane::flip(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeBoxIter::intersects(), moab::BSPTreeBoxIter::MISS, moab::BSPTreeBoxIter::NONHEX, moab::BSPTree::Plane::set(), moab::BSPTreeBoxIter::SPLIT, and moab::BSPTreeBoxIter::splits().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTree::Plane p;
    const double max[3] = { 1, 2, 3 };
    p.set( 1, 0, 0, 1 );  // x == -1
    CHECK_EQUAL( BSPTreeBoxIter::MISS, iter.splits( p ) );
    CHECK( !iter.intersects( p ) );
    p.flip();
    p.set( 1, 0, 0, 0 );  // x == 0
    CHECK_EQUAL( BSPTreeBoxIter::NONHEX, iter.splits( p ) );
    p.flip();
    p.set( 1, 0, 0, -0.5 );  // x == 0.5
    CHECK_EQUAL( BSPTreeBoxIter::SPLIT, iter.splits( p ) );
    CHECK( iter.intersects( p ) );
    p.flip();
    p.set( 1, 0, 0, -1 );  // x == 1
    p.flip();
    p.set( 1, 0, 0, -2 );  // x == 2
    p.flip();
    double pt1[3] = { 0, 0, 1.5 };
    double pt2[3] = { 1, 0, 1.5 };
    double pt3[3] = { 0, 1, 3.0 };
    p.set( pt1, pt2, pt3 );
    p.flip();
    double pt4[3] = { 0, 2, 2.8 };
    p.set( pt1, pt2, pt4 );
    p.flip();
    double pta[3] = { 0.8, 0, 0 };
    double ptb[3] = { 0, 0.2, 3 };
    double ptc[3] = { 0.8, 2, 3 };
    p.set( pta, ptb, ptc );
    p.flip();
void test_leaf_volume ( bool  box)
Definition at line 1389 of file bsp_tree_test.cpp.
References CHECK_ERR, CHECK_REAL_EQUAL, moab::BSPTree::create_tree(), ErrorCode, moab::BSPTree::get_tree_iterator(), moab::BSPTree::split_leaf(), moab::BSPTreeIter::step(), and moab::BSPTreeIter::volume().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTreeIter g_iter;
    BSPTreeIter& iter = box ? b_iter : g_iter;
    /*  Build Tree
          |    A    |              |
      0.7 +---------+      C       |
          |    B    |              |
          |         |      D       |
          0.0       0.4            1.0  */
    // reset iterator
    // check leaf volumes
    CHECK_REAL_EQUAL( 0.12, iter.volume(), 1e-12 );  // A
    CHECK_REAL_EQUAL( 0.28, iter.volume(), 1e-12 );  // B
    CHECK_REAL_EQUAL( 0.42, iter.volume(), 1e-12 );  // C
    CHECK_REAL_EQUAL( 0.18, iter.volume(), 1e-12 );  // D
Definition at line 22 of file bsp_tree_test.cpp.
References test_leaf_volume().
    test_leaf_volume( true );
Definition at line 26 of file bsp_tree_test.cpp.
    test_leaf_volume( false );
void test_merge_leaf ( )
Definition at line 905 of file bsp_tree_test.cpp.
References aabox_corners(), CHECK, CHECK_EQUAL, CHECK_ERR, compare_hexes(), moab::BSPTree::create_tree(), moab::BSPTreeIter::depth(), ErrorCode, moab::BSPTreeBoxIter::get_box_corners(), moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), MB_ENTITY_NOT_FOUND, moab::BSPTree::merge_leaf(), moab::BSPTree::split_leaf(), and moab::BSPTreeBoxIter::step().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTree::Plane p;
    /*  Build Tree
          |    A    |              |
      0.7 +---------+      C       |
          |    B    |              |
          |         |      D       |
          0.0       0.4            1.0  */
    const EntityHandle AB = iter.handle();
    const EntityHandle CD = iter.handle();
    rval = tool.merge_leaf( iter );CHECK_ERR( rval );
    CHECK_EQUAL( AB, iter.handle() );
    CHECK_EQUAL( X_split, p );
    aabox_corners( 0.0, 0.0, 0.0, 0.4, 1.0, 1.0, expected );
    CHECK_EQUAL( CD, iter.handle() );
    aabox_corners( 0.4, 0.0, 0.0, 1.0, 1.0, 1.0, expected );
    rval = iter.step();
void test_set_plane ( )
Definition at line 86 of file bsp_tree_test.cpp.
References CHECK_REAL_EQUAL, moab::BSPTree::Plane::distance(), and moab::BSPTree::Plane::set().
    BSPTree::Plane p;
    const double points[3][3] = { { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } };
    p.set( points[0], points[1], points[2] );
    CHECK_REAL_EQUAL( 0.0, p.distance( points[0] ), 1e-10 );
    CHECK_REAL_EQUAL( 0.0, p.distance( points[1] ), 1e-10 );
    CHECK_REAL_EQUAL( 0.0, p.distance( points[2] ), 1e-10 );
void test_tree_create ( )
Definition at line 357 of file bsp_tree_test.cpp.
References CHECK_EQUAL, CHECK_ERR, moab::BSPTree::create_tree(), moab::BSPTreeIter::depth(), ErrorCode, moab::BSPTreeIter::get_parent_split_plane(), moab::BSPTree::get_tree_iterator(), moab::BSPTreeIter::handle(), MB_ENTITY_NOT_FOUND, moab::BSPTree::split_leaf(), moab::BSPTreeIter::step(), and moab::BSPTreeIter::tool().
    Core moab;
    ErrorCode rval;
    EntityHandle root;
    BSPTreeIter iter;
    BSPTree::Plane p;
    // split with z=0
    // split lower leaf with diagonal plane
    rval = tool.split_leaf( iter, BSPTree::Plane( 1, 1, 0, 0 ) );CHECK_ERR( rval );
    const double r = 0.5 * sqrt( 2.0 );
    CHECK_EQUAL( BSPTree::Plane( r, r, 0, 0 ), p );
    // step to upper leaf
    // split upper leaf with diagonal plane
    rval = tool.split_leaf( iter, BSPTree::Plane( -1, 1, 0, 0 ) );CHECK_ERR( rval );
    CHECK_EQUAL( BSPTree::Plane( -r, r, 0, 0 ), p );
    // iterate over four leaves
    // first leaf
    // second leaf
    // third leaf
    // fourth leaf
    // no more leaves
    rval = iter.step();
